Adding Active-discharge option for SDx rails.
bug 859415
Change-Id: Ia4d3933b9dbf4a0ec646c586f99a7411d2a93371
Reviewed-on: http://git-master/r/50281
Tested-by: Harry Hong <hhong@nvidia.com>
Allowing 2% error in calculated baudrate when finding the best clock
source uart controller.
bug 870388
Change-Id: Id765efd7bf087e10bc93a8ba5bd1eec8a8f3ef48
Reviewed-on: http://git-master/r/50255
Tested-by: Laxman Dewangan <ldewangan@nvidia.com>
Add support to query syncpoint ID assigned
to the AVP by nvhost driver.
Change-Id: Id963e6c32f97e095da253de4b7d83ee8fa8d62a8
Reviewed-on: http://git-master/r/49702
Tested-by: Gajanan Bhat <gbhat@nvidia.com>
Reviewed-by: Scott Williams <scwilliams@nvidia.com>
Reviewed-by: Kaz Fukuoka <kfukuoka@nvidia.com>
Reviewed-by: Isaac Richards <irichards@nvidia.com>
Reviewed-by: Krishna Reddy <vdumpa@nvidia.com>
Add RTC driver for Maxim PMU MAX77663.
Bug 849360
Change-Id: Ia7c910a852527f6a7bf5d2622cb1f76fd72222cd
Signed-off-by: Jin Park <jinyoungp@nvidia.com>
Reviewed-on: http://git-master/r/49584
Added support for sub-zero temperatures
Change-Id: Id35590ee4d058f35625088089623cc063f9a711a
Reviewed-on: http://git-master/r/48690
Reviewed-by: Bitan Biswas <bbiswas@nvidia.com>
Tested-by: Bitan Biswas <bbiswas@nvidia.com>
Reviewed-by: Ramachandrudu Kandhala <rkandhala@nvidia.com>
Reviewed-by: Diwakar Tundlam <dtundlam@nvidia.com>
Added device for audio test manager, dam restructuring and added device ioctls
Added EXPORT_SYMBOL for functions used by audio test manager
Change-Id: I0bd73f0586132598f7161b18fcdd2cdfafc39677
Reviewed-on: http://git-master/r/48919
Tested-by: Rahul Mittal <rmittal@nvidia.com>
Reviewed-by: Vijay Mali <vmali@nvidia.com>
Reviewed-by: Scott Peterson <speterson@nvidia.com>
Adding battery-gauge driver for TPS8003x controller
bug 841080
Change-Id: Id65c3de88e6893005a8d7590fc7273cd7c43a1b3
Reviewed-on: http://git-master/r/48428
Tested-by: Syed Rafiuddin <srafiuddin@nvidia.com>
Adding battery charger driver for tps80031.
bug 841080
Change-Id: Id5bd717f4784b9bb48b2c2cb0b1b16a8a85aa830
Reviewed-on: http://git-master/r/48361
BUG 860982
Change-Id: I7ffaa6825ed873364143784d9939bea8224d8200
Reviewed-on: http://git-master/r/47385
Reviewed-by: Hyong Bin Kim <hyongbink@nvidia.com>
Tested-by: Hyong Bin Kim <hyongbink@nvidia.com>
Reviewed-by: Simon Je <sje@nvidia.com>
Tested-by: Simon Je <sje@nvidia.com>
Adding support for delay configuration after setting the voltage
from platform data based on board behavior.
Also providing flag to enable the VBUS discharging though internal
pull down.
bug 853393
Change-Id: I27e7ae1eab9893241e775e17ec7b98afac71195b
Reviewed-on: http://git-master/r/41886
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
In the current implementation, if pdata->max_current is not set or
AAT2870_CURRENT_0_45, it makes same result.
Change-Id: I8ba17e92b81cd0e5668e583da48eaa56a57a09cf
Reviewed-on: http://git-master/r/48138
Adding charging rail ID for registering as regulator.
Change-Id: I654f8d040be5387bc8d6949e0338db6d4fdd5ed4
Reviewed-on: http://git-master/r/48208
Adding io mutex into I2C update function to prevent race condition
problem.
Change-Id: Ibff85a825a6716bfc88eea55704bbbcc565cf962
Reviewed-on: http://git-master/r/48136
Adding slew rate and forced PWM mode for SD power rails.
Bug 849360
Change-Id: Ie66074bd36e600f2f72ba04e2c04331a58dd6a5c
Reviewed-on: http://git-master/r/47830
Adding ricoh583 regulator driver to supprot RICOH 583 PMIC.
bug 822562
Change-Id: Ie4b3aab91f2057965e2352f7a9509c651fb2ad0a
Reviewed-on: http://git-master/r/40319
Adding core driver for the Powermanagement system device
RICOH 583.
bug 822562
Change-Id: I8a21b42800bd9043f901689ed354618165c42534
Reviewed-on: http://git-master/r/40035
Updated the tegra_i2c_platform_data to remove warnings.
bug 854305
Change-Id: I21257dc7b78b6fe3a6d19c959f003f2cb13b10f1
Reviewed-on: http://git-master/r/47729
Reviewed-by: Alok Chauhan <alokc@nvidia.com>
Tested-by: Alok Chauhan <alokc@nvidia.com>
In this change, nvhost_cdma starts a timer (if a timeout is specified
in the userctx), for the buffer at the head of the sync_queue that has
not reached its syncpt threshold.
If the timeout fires, nvhost_cdma initiates a channel / module reset.
It then detects up to where in the sync_queue it stopped execution
(based on the current HW syncpt value).
For any remaining uncompleted buffers in the context, nvhost_cdma NOPs
the entry and CPU incrs the syncpt to where it should be had it completed.
If one of the sync_queue entries belongs to another context, it still
does the syncpt incrs for this context, but via the PB as a GATHER opcode,
At the end, CDMA is restarted, so buffers are refetched (either with
NOP slots, or GATHERs to incr syncpts). This appears as though the
buffer has completed (and the associated resources released).
For testing, debugfs entries have been added under /d/tegra_nvhost
force_timeout_val - set the timeout value, in ms
force_timeout_channel - channel ID, were timeouts checks occur
force_timeout_pid - process ID to set the userctx
The idea is to set the timeout_val, then the timeout_channel (e.g. for
3D, the channel ID is 1) and then the process ID, gotten from running
adb shell ps.
Bug 625545
Change-Id: I659e9255f1105f3439ce23e9169a19739b83ea52
Signed-off-by: Terje Bergstrom <tbergstrom@nvidia.com>
Reviewed-on: http://git-master/r/42655
This module lets subsystem authors prioritize ftrace events
by calling tracelevel_register(...). High priority traces
will be automatically enabled on boot. See tracelevel.h
for more details
Change-Id: If03699e96c598bdcf93b9a9f73918ce7b0c750cb
Reviewed-on: http://git-master/r/40290
Reviewed-by: Alon Farchy <afarchy@nvidia.com>
Tested-by: Alon Farchy <afarchy@nvidia.com>
Reviewed-by: Daniel Willemsen <dwillemsen@nvidia.com>
Tested-by: Daniel Solomon <daniels@nvidia.com>
Implementation to load the app ucode from driver
instead of each client instance maintaining copy
of common ucode.The driver will load and maintain
a single instance of the app ucode, but gives
ability to flag external ucode usage for every
submit call. The driver also caches both the os
and app ucode till driver is unloaded.
Change-Id: I96ad3c039bf96c621774d41b3f838ea6fbe52ae9
Reviewed-on: http://git-master/r/45872
Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
Updated arbitration lost recovery to accumulate i2c multiplexing.
bug 854305
Change-Id: I3f669c507980df78fa443c84b304d337bbe6a6da
Reviewed-on: http://git-master/r/46630
Reviewed-by: Bandi Krishna Chaitanya <bandik@nvidia.com>
Tested-by: Bandi Krishna Chaitanya <bandik@nvidia.com>
To prepare for kernel modularization, nvhost include files need to be
moved from mach-tegra/include to kernel/include. At the same time
user space specific part is split into nvhost_ioctl.h.
Bug 854182
Change-Id: I3694a40d786028733310ecf5b59341282af571be
Reviewed-on: http://git-master/r/43211
Setting the charging current limit through
the regulator for drawing the vbus current.
Bug 854993
Change-Id: I4e1d3578de7f234f7fc9cd1af09fdd1d9dc227d9
Reviewed-on: http://git-master/r/46704
Reviewed-by: Suresh Mangipudi <smangipudi@nvidia.com>
Tested-by: Suresh Mangipudi <smangipudi@nvidia.com>
Reviewed-by: Hanumanth Venkateswa Moganty <vmoganty@nvidia.com>
Added support for SDIO 3.0 asynchronous card
interrupt in 4-bit mode.
Bug 853800
Change-Id: If65bfe6ed2d663897037324b519484f77c35d3b5
Reviewed-on: http://git-master/r/46928
Tested-by: Pavan Kunapuli <pkunapuli@nvidia.com>
These were missing from tegra_overlay.h, but present in tegrafb.h.
bug 818525
Change-Id: Ia174516a068dd3c53d462eb9c68b3e76e0ea25ff
Signed-off-by: Robert Morell <rmorell@nvidia.com>
Reviewed-on: http://git-master/r/40511
Reviewed-by: Jonathan Mayo <jmayo@nvidia.com>
Adding SDIO 3.0 support. Adding support for
voltage switch, bus speed mode selection,
8 bit buswidth support and frequency tuning.
Bug 853800
Change-Id: Ie778b7d67f2f09a9840cc8576d1dc750f18c7978
Reviewed-on: http://git-master/r/46388
Reviewed-by: Pavan Kunapuli <pkunapuli@nvidia.com>
Added the arbitration lost error recovery code into
i2c driver.
bug 854305
Change-Id: Ib855f3541d139c01ea34fd9070feef7969eed395
Reviewed-on: http://git-master/r/43201
tegra-pwm-backlight now has a notify function that enables the
brightness to be passed back to the boardfile where it is modified.
Bug 854820
Change-Id: I1425d801f77987485b58c3cbedae464b5db88444
Reviewed-on: http://git-master/r/42639
Set PWM pin to SFIO before it is configured to DC output pin:
Having too early SFIO setting for this pin makes black screen
in display transition from bootloader to kenel and android
since backlight can be turned off.
Bug 858120
Change-Id: I952aa73c50d1df57b1cedf0a5f9ffee0044048ea
Reviewed-on: http://git-master/r/44304
Add regulator driver for Maxim PMU MAX77663.
Bug 849360
Bug 854414
Change-Id: I740f484ee1f39deefa8e5b9669426d6e6bafb42d
Reviewed-on: http://git-master/r/44484
Add mfd core driver for Maxim PMU MAX77663.
Bug 849360
Bug 854414
Change-Id: I6699540fd7d0f7b428a1be64cf06f7cd65b5b32e
Reviewed-on: http://git-master/r/41503
Unlike SDSC and SDHC, for SDXC cards CMD20 needs to be
issued to meet the class performance for speed class
recording. Adding mmc_speed_class_control() which should
be used by an AV recording app/utility before starting
recording on an SDXC card.
Bug 820469
Bug 769962
Change-Id: Ic89fd6e475e6bf7ea610e43c78a752dcb444d477
Reviewed-on: http://git-master/r/39394
Reviewed-by: Sachin Nikam <snikam@nvidia.com>
Providing the different clock source option through platform data
to select best clock source based on required interface frequency.
bug 851642
Change-Id: I18bf817b63cf1afac7db3969f266cc5fcaeee81e
Reviewed-on: http://git-master/r/41226
Reviewed-by: Aleksandr Frid <afrid@nvidia.com>
Add regulator enable notifications (not sent by the current code).
Add voltage notifications sent only if regulator output is actually
changed (keep intact existing voltage change notification that is
sent unconditionally - even if voltage change was not allowed by
constraints, or no actual change since regulator is disabled):
PRE_ENABLE Regulator is to be enabled
POST_ENABLE Regulator was enabled
OUT_PRECHANGE Regulator is enabled and its voltage is to be changed
OUT_POSTCHANGE Regulator is enabled and its voltage was changed
Bug 853132
Change-Id: I2759ada1c5d1e43f746f6c866f9b3c203b68aed6
Reviewed-on: http://git-master/r/42262
Tested-by: Aleksandr Frid <afrid@nvidia.com>
Reviewed-by: Karan Jhavar <kjhavar@nvidia.com>
New AVP driver based on channel model. The AVP
acts as s/w host1x channel and has a syncpoint
allocated to synchronize audio/video operation
submitted by the host. The driver is responsible
for loading the AVP kernel and initializing s/w
channel.
Change-Id: I20b68fc3cbb88b7c95542bae0a1acf5edc52c715
Reviewed-on: http://git-master/r/37420
bug 815933
Change-Id: I3b8f8910b12ff4f8a5f9588615bd0bb6452bdc3b
Reviewed-on: http://git-master/r/40263
Reviewed-by: Xin Xie <xxie@nvidia.com>
Tested-by: Xin Xie <xxie@nvidia.com>
Adding the TPS6591x gpio definition in tps6591x core header
files.
bug 849976
Change-Id: I1f7a7cc38e220c091ccf44db5af6e43c34daa1cd
Reviewed-on: http://git-master/r/41040
Moving the definitions of regulator rail names into regulator
header from core header.
bug 849977
Change-Id: Ia2e4e9394b6ee013e2e12355038e15609d5077ea
Reviewed-on: http://git-master/r/41023
Tested-by: Mallikarjun Kasoju <mkasoju@nvidia.com>
bug 849977
Change-Id: I84cb56e64995c37fbf79f51936bfab9c01644c00
Reviewed-on: http://git-master/r/41015
Adding public definition in the 80031 header so that client
can used directly in place of defining at client level.
Change-Id: Ifb64e0ffc83bc29c470d08a49d0915613a677537
Reviewed-on: http://git-master/r/40208
If emc clock is clocked at maximum rate it increases power
consumption. emc clock rate requirement is different for
different platforms.
Change-Id: I21e9afed402d08558c6913b5f194b1a4699ebcb2
Reviewed-on: http://git-master/r/40166
Creating framework so that tps80031 driver can be instantiated with the
name of tps80032 also and it can provide the device/chip info to its
client.
bug 820885
Change-Id: I1c40b7c6bec1f4abbc670aaa4317fad49e5d308a
Reviewed-on: http://git-master/r/38859
Some USB function drivers (e.g. f_mass_storage.c) need to delay or defer the
data/status stages of standard control requests like SET_CONFIGURATION or
SET_INTERFACE till they are done with their bookkeeping and are actually ready
for accepting new commands to their interface.
They can now achieve this functionality by returning USB_GADGET_DELAYED_STATUS
in their setup handlers (e.g. set_alt()). The composite framework will then
defer completion of the control transfer by not completing the data/status stages.
This ensures that the host does not send new packets to the interface till the
function driver is ready to take them.
When the function driver that requested for USB_GADGET_DELAYED_STATUS is done
with its bookkeeping, it should signal the composite framework to continue with
the data/status stages of the control transfer. It can do so by invoking
the new API usb_composite_setup_continue(). This is where the control transfer's
data/status stages are completed and host can initiate new transfers.
The DELAYED_STATUS mechanism is currently only supported if the expected data phase
is 0 bytes (i.e. w_length == 0). Since SET_CONFIGURATION and SET_INTERFACE are the
only cases that will use this mechanism, this is not a limitation.
Signed-off-by: Roger Quadros <roger.quadros@nokia.com>
(cherry picked from commit 1b9ba000177ee47bcc5b44c7c34e48e735f5f9b1 kernel.org, linux-2.6 tree)
Change-Id: I9d7082042f33c10110070febf36c95d61a292f82
Reviewed-on: http://git-master/r/37788
There is multiple independent case for charge control interrupt and
so exposing each of the case as separate interrupt number.
bug 842072
Change-Id: I500d7e921e07b43de4eefdde2590f045022d8169
Reviewed-on: http://git-master/r/38732
Reviewed-by: Niket Sirsi <nsirsi@nvidia.com>
Tested-by: Niket Sirsi <nsirsi@nvidia.com>
The state register is read and write register, if read, it returned
current state, not current written value in register.
So if it want to write the value into state register, it must unconditional
write the value, don't use update(read and compare and then write).
Bug 838189
Change-Id: I2555875a822f159e664b0834af2d00073c859acd
Reviewed-on: http://git-master/r/38396
Based on platform, it is require to control the regulator
output through the peripheral power request signal to pmu.
Supporting this type of platform configuration to control
output voltage by sw as well as through PREQ input line.
bug 839809
bug 829405
Change-Id: Ifa19b9062ca2a2c5cae84de1f311a33cec094ad0
Reviewed-on: http://git-master/r/38936
Providing the control of VBUS through regulator api.
bug 833736
Change-Id: Id79f64dfb0ab30a5f0663521defb60a76681c767
Reviewed-on: http://git-master/r/38499
Reviewed-by: Thomas Cherry <tcherry@nvidia.com>
* Fix suspend/resume bug to prevent unecessary i2cinterrupts when suspended.
* Change input device name to match NVDA IDC name.
* Add I2C address defines.
* Change "printk" to "dev_info" function calls.
BUG 826854
Change-Id: Ic1b25bc469b86d8a26e876e80973597d9f6fb107
Reviewed-on: http://git-master/r/35285
Reviewed-by: Robert R Collins <rcollins@nvidia.com>
Tested-by: Robert R Collins <rcollins@nvidia.com>
Reviewed-by: Narendra Damahe <ndamahe@nvidia.com>
Integrate changes made by Atmel. These changes are in addition to
mainline driver.
NOTE: Driver will compile as a stand-alone.
BUG 826854
Change-Id: If13688d90d97b71718576f3fb756496f57a965d7
Reviewed-on: http://git-master/r/35280
Update to new mainline touch screen driver.
NOTE: Driver will not compile as a stand-alone due to
missing and/or changed support files on kernel.org.
BUG 826854
<As of commit: 8b86c1c28f569301aa1a113a060f9ed803300903>
Change-Id: I0c50a122836d495bcf8f0c47c4729e9a4a7834c9
Reviewed-on: http://git-master/r/35279
