commit e0b9daeb453e602a95ea43853dc12d385558ce1f upstream.
We're going to want to manipulate the migration mode for compaction in the
page allocator, and currently compact_control's sync field is only a bool.
Currently, we only do MIGRATE_ASYNC or MIGRATE_SYNC_LIGHT compaction
depending on the value of this bool. Convert the bool to enum
migrate_mode and pass the migration mode in directly. Later, we'll want
to avoid MIGRATE_SYNC_LIGHT for thp allocations in the pagefault patch to
avoid unnecessary latency.
This also alters compaction triggered from sysfs, either for the entire
system or for a node, to force MIGRATE_SYNC.
[akpm@linux-foundation.org: fix build]
[iamjoonsoo.kim@lge.com: use MIGRATE_SYNC in alloc_contig_range()]
Signed-off-by: David Rientjes <rientjes@google.com>
Suggested-by: Mel Gorman <mgorman@suse.de>
Acked-by: Vlastimil Babka <vbabka@suse.cz>
Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com>
commit 35979ef3393110ff3c12c6b94552208d3bdf1a36 upstream.
Each zone has a cached migration scanner pfn for memory compaction so that
subsequent calls to memory compaction can start where the previous call
left off.
Currently, the compaction migration scanner only updates the per-zone
cached pfn when pageblocks were not skipped for async compaction. This
creates a dependency on calling sync compaction to avoid having subsequent
calls to async compaction from scanning an enormous amount of non-MOVABLE
pageblocks each time it is called. On large machines, this could be
potentially very expensive.
This patch adds a per-zone cached migration scanner pfn only for async
compaction. It is updated everytime a pageblock has been scanned in its
entirety and when no pages from it were successfully isolated. The cached
migration scanner pfn for sync compaction is updated only when called for
sync compaction.
Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
commit 68711a746345c44ae00c64d8dbac6a9ce13ac54a upstream.
Memory migration uses a callback defined by the caller to determine how to
allocate destination pages. When migration fails for a source page,
however, it frees the destination page back to the system.
This patch adds a memory migration callback defined by the caller to
determine how to free destination pages. If a caller, such as memory
compaction, builds its own freelist for migration targets, this can reuse
already freed memory instead of scanning additional memory.
If the caller provides a function to handle freeing of destination pages,
it is called when page migration fails. If the caller passes NULL then
freeing back to the system will be handled as usual. This patch
introduces no functional change.
commit 29f175d125f0f3a9503af8a5596f93d714cceb08 upstream.
Commit f9acc8c7b35a ("readahead: sanify file_ra_state names") left
ra_submit with a single function call.
Move ra_submit to internal.h and inline it to save some stack. Thanks
to Andrew Morton for commenting different versions.
Signed-off-by: Fabian Frederick <fabf@skynet.be>
Suggested-by: Andrew Morton <akpm@linux-foundation.org>
commit 67f9fd91f93c582b7de2ab9325b6e179db77e4d5 upstream.
This patch removes read_cache_page_async() which wasn't really needed
anywhere and simplifies the code around it a bit.
read_cache_page_async() is useful when we want to read a page into the
cache without waiting for it to complete. This happens when the
appropriate callback 'filler' doesn't complete its read operation and
releases the page lock immediately, and instead queues a different
completion routine to do that. This never actually happened anywhere in
the code.
read_cache_page_async() had 3 different callers:
- read_cache_page() which is the sync version, it would just wait for
the requested read to complete using wait_on_page_read().
- JFFS2 would call it from jffs2_gc_fetch_page(), but the filler
function it supplied doesn't do any async reads, and would complete
before the filler function returns - making it actually a sync read.
- CRAMFS would call it using the read_mapping_page_async() wrapper, with
a similar story to JFFS2 - the filler function doesn't do anything that
reminds async reads and would always complete before the filler function
returns.
To sum it up, the code in mm/filemap.c never took advantage of having
read_cache_page_async(). While there are filler callbacks that do async
reads (such as the block one), we always called it with the
read_cache_page().
This patch adds a mandatory wait for read to complete when adding a new
page to the cache, and removes read_cache_page_async() and its wrappers.
commit 0cd6144aadd2afd19d1aca880153530c52957604 upstream.
shmem mappings already contain exceptional entries where swap slot
information is remembered.
To be able to store eviction information for regular page cache, prepare
every site dealing with the radix trees directly to handle entries other
than pages.
The common lookup functions will filter out non-page entries and return
NULL for page cache holes, just as before. But provide a raw version of
the API which returns non-page entries as well, and switch shmem over to
use it.
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Reviewed-by: Minchan Kim <minchan@kernel.org>
Cc: Bob Liu <bob.liu@oracle.com>
Cc: Jan Kara <jack@suse.cz>
Cc: Luigi Semenzato <semenzato@google.com>
Cc: Metin Doslu <metin@citusdata.com>
Cc: Michel Lespinasse <walken@google.com>
Cc: Ozgun Erdogan <ozgun@citusdata.com>
Cc: Roman Gushchin <klamm@yandex-team.ru>
Cc: Ryan Mallon <rmallon@gmail.com>
Cc: Tejun Heo <tj@kernel.org>
commit e7b563bb2a6f4d974208da46200784b9c5b5a47e upstream.
The radix tree hole searching code is only used for page cache, for
example the readahead code trying to get a a picture of the area
surrounding a fault.
It sufficed to rely on the radix tree definition of holes, which is
"empty tree slot". But this is about to change, though, as shadow page
descriptors will be stored in the page cache after the actual pages get
evicted from memory.
Move the functions over to mm/filemap.c and make them native page cache
operations, where they can later be adapted to handle the new definition
of "page cache hole".
commit 53c59f262d747ea82e7414774c59a489501186a0 upstream.
Provide a function that does not just delete an entry at a given index,
but also allows passing in an expected item. Delete only if that item
is still located at the specified index.
This is handy when lockless tree traversals want to delete entries as
well because they don't have to do an second, locked lookup to verify
the slot has not changed under them before deleting the entry.
commit 96a2adbc6f501996418da9f7afe39bf0e4d006a9 upstream.
kernel/time/jiffies.c provides a default clocksource_default_clock()
definition explicitly marked "weak". arch/s390 provides its own definition
intended to override the default, but the "weak" attribute on the
declaration applied to the s390 definition as well, so the linker chose one
based on link order (see 10629d711ed7 ("PCI: Remove __weak annotation from
pcibios_get_phb_of_node decl")).
Remove the "weak" attribute from the clocksource_default_clock()
declaration so we always prefer a non-weak definition over the weak one,
independent of link order.
Fixes: f1b82746c1e9 ("clocksource: Cleanup clocksource selection")
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
Acked-by: John Stultz <john.stultz@linaro.org>
Acked-by: Ingo Molnar <mingo@kernel.org>
CC: Daniel Lezcano <daniel.lezcano@linaro.org>
CC: Martin Schwidefsky <schwidefsky@de.ibm.com>
commit 107bcc6d566cb40184068d888637f9aefe6252dd upstream.
kernel/debug/debug_core.c provides a default kgdb_arch_pc() definition
explicitly marked "weak". Several architectures provide their own
definitions intended to override the default, but the "weak" attribute on
the declaration applied to the arch definitions as well, so the linker
chose one based on link order (see 10629d711ed7 ("PCI: Remove __weak
annotation from pcibios_get_phb_of_node decl")).
Remove the "weak" attribute from the declaration so we always prefer a
non-weak definition over the weak one, independent of link order.
Fixes: 688b744d8bc8 ("kgdb: fix signedness mixmatches, add statics, add declaration to header")
Tested-by: Vineet Gupta <vgupta@synopsys.com> # for ARC build
Reviewed-by: Harvey Harrison <harvey.harrison@gmail.com>
commit 5ab03ac5aaa1f032e071f1b3dc433b7839359c03 upstream.
For the following functions:
elfcorehdr_alloc()
elfcorehdr_free()
elfcorehdr_read()
elfcorehdr_read_notes()
remap_oldmem_pfn_range()
fs/proc/vmcore.c provides default definitions explicitly marked "weak".
arch/s390 provides its own definitions intended to override the default
ones, but the "weak" attribute on the declarations applied to the s390
definitions as well, so the linker chose one based on link order (see
10629d711ed7 ("PCI: Remove __weak annotation from pcibios_get_phb_of_node
decl")).
Remove the "weak" attribute from the declarations so we always prefer a
Fixes: be8a8d069e50 ("vmcore: introduce ELF header in new memory feature")
Fixes: 9cb218131de1 ("vmcore: introduce remap_oldmem_pfn_range()")
Acked-by: Andrew Morton <akpm@linux-foundation.org>
Acked-by: Vivek Goyal <vgoyal@redhat.com>
CC: Michael Holzheu <holzheu@linux.vnet.ibm.com>
commit e0a8400c6923a163265d52798cdd4c33f3f8ab5a upstream.
drivers/base/memory.c provides a default memory_block_size_bytes()
definition explicitly marked "weak". Several architectures provide their
own definitions intended to override the default, but the "weak" attribute
on the declaration applied to the arch definitions as well, so the linker
Fixes: 41f107266b19 ("drivers: base: Add prototype declaration to the header file")
CC: Rashika Kheria <rashika.kheria@gmail.com>
CC: Nathan Fontenot <nfont@austin.ibm.com>
CC: Anton Blanchard <anton@au1.ibm.com>
CC: Heiko Carstens <heiko.carstens@de.ibm.com>
CC: Yinghai Lu <yinghai@kernel.org>
unbind
commit cdaf3e15385d3232b52287e50692506f8fd01a09 upstream.
The charger manager obtained in probe references to power supplies for
all chargers with power_supply_get_by_name() for later usage. However
if such charger driver was removed then this reference would point to
old power supply (from driver which was removed).
This lead to accessing invalid memory which could be observed with:
$ echo "max77693-charger" > /sys/bus/platform/drivers/max77693-charger/unbind
$ grep . /sys/devices/virtual/power_supply/battery/charger.0/*
$ grep . /sys/devices/virtual/power_supply/battery/*
[ 15.339817] Unable to handle kernel paging request at virtual address 0001c12c
[ 15.346187] pgd = edd08000
[ 15.348814] [0001c12c] *pgd=6dce2831, *pte=00000000, *ppte=00000000
[ 15.355075] Internal error: Oops: 80000007 [#1] PREEMPT SMP ARM
[ 15.360967] Modules linked in:
[ 15.364010] CPU: 2 PID: 1388 Comm: grep Not tainted 3.17.0-next-20141007-00027-ga95e761db1b0 #245
[ 15.372859] task: ee03ad00 ti: edcf6000 task.ti: edcf6000
[ 15.378241] PC is at 0x1c12c
[ 15.381113] LR is at is_ext_pwr_online+0x30/0x6c
[ 15.385706] pc : [<0001c12c>] lr : [<c0339fc4>] psr: a0000013
[ 15.385706] sp : edcf7e88 ip : 00000000 fp : 00000000
[ 15.397161] r10: eeb02c08 r9 : c04b1f84 r8 : eeb02c00
[ 15.402369] r7 : edc69a10 r6 : eea6ac10 r5 : eea6ac10 r4 : 00000004
[ 15.408878] r3 : 0001c12c r2 : edcf7e8c r1 : 00000004 r0 : ee914418
[ 15.415390] Flags: NzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 15.422506] Control: 10c5387d Table: 6dd0804a DAC: 00000015
[ 15.428236] Process grep (pid: 1388, stack limit = 0xedcf6240)
[ 15.434050] Stack: (0xedcf7e88 to 0xedcf8000)
[ 15.438395] 7e80: ee03ad00 00000000 edcf7f80 eea6aca8 edcf7ec4 c033b7b0
[ 15.446554] 7ea0: 00000001 ee1cc3f0 00000004 c06e1e44 eebdc000 c06e1e44 eeb02c00 c0337144
[ 15.454713] 7ec0: ee2dac68 c005cffc ee1cc3c0 c06e1e44 00000fff 00001000 eebdc000 c0278ca8
[ 15.462872] 7ee0: c0278c8c ee1cc3c0 eeb7ce00 c014422c edcf7f20 00008000 ee1cc3c0 ee9a48c0
[ 15.471030] 7f00: 00000001 00000001 edcf7f80 c0142d94 c0142d70 c01060f4 00021000 ee1cc3f0
[ 15.479190] 7f20: 00000000 00000000 c06a2150 eebdc000 2e7ec000 ee9a48c0 00008000 00021000
[ 15.487349] 7f40: edcf7f80 00008000 edcf6000 00021000 00021000 c00e39a4 00000000 ee9a48c0
[ 15.495508] 7f60: 00004000 00000000 00000000 ee9a48c0 ee9a48c0 00008000 00021000 c00e3aa0
[ 15.503668] 7f80: 00000000 00000000 0001f2e0 0001f2e0 00021000 00001000 00000003 c000f364
[ 15.511826] 7fa0: 00000000 c000f1a0 0001f2e0 00021000 00000003 00021000 00008000 00000000
[ 15.519986] 7fc0: 0001f2e0 00021000 00001000 00000003 00000001 000205e8 00000000 00021000
[ 15.528145] 7fe0: 00008000 bebbe910 0000a7ad b6edc49c 60000010 00000003 aaaaaaaa aaaaaaaa
[ 15.536320] [<c0339fc4>] (is_ext_pwr_online) from [<c033b7b0>] (charger_get_property+0x170/0x314)
[ 15.545164] [<c033b7b0>] (charger_get_property) from [<c0337144>] (power_supply_show_property+0x48/0x20c)
[ 15.554719] [<c0337144>] (power_supply_show_property) from [<c0278ca8>] (dev_attr_show+0x1c/0x48)
[ 15.563577] [<c0278ca8>] (dev_attr_show) from [<c014422c>] (sysfs_kf_seq_show+0x84/0x104)
[ 15.571725] [<c014422c>] (sysfs_kf_seq_show) from [<c0142d94>] (kernfs_seq_show+0x24/0x28)
[ 15.579973] [<c0142d94>] (kernfs_seq_show) from [<c01060f4>] (seq_read+0x1b0/0x484)
[ 15.587614] [<c01060f4>] (seq_read) from [<c00e39a4>] (vfs_read+0x88/0x144)
[ 15.594552] [<c00e39a4>] (vfs_read) from [<c00e3aa0>] (SyS_read+0x40/0x8c)
[ 15.601417] [<c00e3aa0>] (SyS_read) from [<c000f1a0>] (ret_fast_syscall+0x0/0x48)
[ 15.608877] Code: bad PC value
[ 15.611991] ---[ end trace a88fcc95208db283 ]---
The charger-manager should get reference to charger power supply on
each use of get_property callback.
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Fixes: 3bb3dbbd56ea ("power_supply: Add initial Charger-Manager driver")
Signed-off-by: Sebastian Reichel <sre@kernel.org>
gauge unbind
commit bdbe81445407644492b9ac69a24d35e3202d773b upstream.
The charger manager obtained reference to fuel gauge power supply in probe
with power_supply_get_by_name() for later usage. However if fuel gauge
driver was removed and re-added then this reference would point to old
This lead to accessing old (and probably invalid) memory which could be
observed with:
$ echo "12-0036" > /sys/bus/i2c/drivers/max17042/unbind
$ echo "12-0036" > /sys/bus/i2c/drivers/max17042/bind
$ cat /sys/devices/virtual/power_supply/battery/capacity
[ 240.480084] INFO: task cat:1393 blocked for more than 120 seconds.
[ 240.484799] Not tainted 3.17.0-next-20141007-00028-ge60b6dd79570 #203
[ 240.491782] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[ 240.499589] cat D c0469530 0 1393 1 0x00000000
[ 240.505947] [<c0469530>] (__schedule) from [<c0469d3c>] (schedule_preempt_disabled+0x14/0x20)
[ 240.514449] [<c0469d3c>] (schedule_preempt_disabled) from [<c046af08>] (mutex_lock_nested+0x1bc/0x458)
[ 240.523736] [<c046af08>] (mutex_lock_nested) from [<c0287a98>] (regmap_read+0x30/0x60)
[ 240.531647] [<c0287a98>] (regmap_read) from [<c032238c>] (max17042_get_property+0x2e8/0x350)
[ 240.540055] [<c032238c>] (max17042_get_property) from [<c03247d8>] (charger_get_property+0x264/0x348)
[ 240.549252] [<c03247d8>] (charger_get_property) from [<c0320764>] (power_supply_show_property+0x48/0x1e0)
[ 240.558808] [<c0320764>] (power_supply_show_property) from [<c027308c>] (dev_attr_show+0x1c/0x48)
[ 240.567664] [<c027308c>] (dev_attr_show) from [<c0141fb0>] (sysfs_kf_seq_show+0x84/0x104)
[ 240.575814] [<c0141fb0>] (sysfs_kf_seq_show) from [<c0140b18>] (kernfs_seq_show+0x24/0x28)
[ 240.584061] [<c0140b18>] (kernfs_seq_show) from [<c0104574>] (seq_read+0x1b0/0x484)
[ 240.591702] [<c0104574>] (seq_read) from [<c00e1e24>] (vfs_read+0x88/0x144)
[ 240.598640] [<c00e1e24>] (vfs_read) from [<c00e1f20>] (SyS_read+0x40/0x8c)
[ 240.605507] [<c00e1f20>] (SyS_read) from [<c000e760>] (ret_fast_syscall+0x0/0x48)
[ 240.612952] 4 locks held by cat/1393:
[ 240.616589] #0: (&p->lock){+.+.+.}, at: [<c01043f4>] seq_read+0x30/0x484
[ 240.623414] #1: (&of->mutex){+.+.+.}, at: [<c01417dc>] kernfs_seq_start+0x1c/0x8c
[ 240.631086] #2: (s_active#31){++++.+}, at: [<c01417e4>] kernfs_seq_start+0x24/0x8c
[ 240.638777] #3: (&map->mutex){+.+...}, at: [<c0287a98>] regmap_read+0x30/0x60
The charger-manager should get reference to fuel gauge power supply on
each use of get_property callback. The thermal zone 'tzd' field of
power supply should not be used because of the same reason.
Additionally this change solves also the issue with nested
thermal_zone_get_temp() calls and related false lockdep positive for
deadlock for thermal zone's mutex [1]. When fuel gauge is used as source of
temperature then the charger manager forwards its get_temp calls to fuel
gauge thermal zone. So actually different mutexes are used (one for
charger manager thermal zone and second for fuel gauge thermal zone) but
for lockdep this is one class of mutex.
The recursion is removed by retrieving temperature through power
supply's get_property().
In case external thermal zone is used ('cm-thermal-zone' property is
present in DTS) the recursion does not exist. Charger manager simply
exports POWER_SUPPLY_PROP_TEMP_AMBIENT property (instead of
POWER_SUPPLY_PROP_TEMP) thus no thermal zone is created for this power
supply.
[1] https://lkml.org/lkml/2014/10/6/309
commit 8c393f9a721c30a030049a680e1bf896669bb279 upstream.
For pNFS direct writes, layout driver may dynamically allocate ds_cinfo.buckets.
So we need to take care to free them when freeing dreq.
Ideally this needs to be done inside layout driver where ds_cinfo.buckets
are allocated. But buckets are attached to dreq and reused across LD IO iterations.
So I feel it's OK to free them in the generic layer.
Signed-off-by: Peng Tao <tao.peng@primarydata.com>
Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
commit a87fa1d81a9fb5e9adca9820e16008c40ad09f33 upstream.
The string property read helpers will run off the end of the buffer if
it is handed a malformed string property. Rework the parsers to make
sure that doesn't happen. At the same time add new test cases to make
sure the functions behave themselves.
The original implementations of of_property_read_string_index() and
of_property_count_strings() both open-coded the same block of parsing
code, each with it's own subtly different bugs. The fix here merges
functions into a single helper and makes the original functions static
inline wrappers around the helper.
One non-bugfix aspect of this patch is the addition of a new wrapper,
of_property_read_string_array(). The new wrapper is needed by the
device_properties feature that Rafael is working on and planning to
merge for v3.19. The implementation is identical both with and without
the new static inline wrapper, so it just got left in to reduce the
churn on the header file.
Signed-off-by: Grant Likely <grant.likely@linaro.org>
Cc: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
Cc: Mika Westerberg <mika.westerberg@linux.intel.com>
Cc: Rob Herring <robh+dt@kernel.org>
Cc: Darren Hart <darren.hart@intel.com>
commit 0b750b3baa2d64f1b77aecc10f20deeb28efe60d upstream.
Add quirk to make sure that a device is always polled for input events
even if it hasn't been opened.
This is needed for devices that disconnects from the bus unless the
interrupt endpoint has been polled at least once or when not responding
to an input event (e.g. after having shut down X).
Signed-off-by: Johan Hovold <johan@kernel.org>
commit 2a159389bf5d962359349a76827b2f683276a1c7 upstream.
Add new quirk for devices that cannot handle requests for the
device_qualifier descriptor.
A USB-2.0 compliant device must respond to requests for the
device_qualifier descriptor (even if it's with a request error), but at
least one device is known to misbehave after such a request.
Suggested-by: Bjørn Mork <bjorn@mork.no>
commit 5695be142e203167e3cb515ef86a88424f3524eb upstream.
PM freezer relies on having all tasks frozen by the time devices are
getting frozen so that no task will touch them while they are getting
frozen. But OOM killer is allowed to kill an already frozen task in
order to handle OOM situtation. In order to protect from late wake ups
OOM killer is disabled after all tasks are frozen. This, however, still
keeps a window open when a killed task didn't manage to die by the time
freeze_processes finishes.
Reduce the race window by checking all tasks after OOM killer has been
disabled. This is still not race free completely unfortunately because
oom_killer_disable cannot stop an already ongoing OOM killer so a task
might still wake up from the fridge and get killed without
freeze_processes noticing. Full synchronization of OOM and freezer is,
however, too heavy weight for this highly unlikely case.
Introduce and check oom_kills counter which gets incremented early when
the allocator enters __alloc_pages_may_oom path and only check all the
tasks if the counter changes during the freezing attempt. The counter
is updated so early to reduce the race window since allocator checked
oom_killer_disabled which is set by PM-freezing code. A false positive
will push the PM-freezer into a slow path but that is not a big deal.
Changes since v1
- push the re-check loop out of freeze_processes into
check_frozen_processes and invert the condition to make the code more
readable as per Rafael
Fixes: f660daac474c6f (oom: thaw threads if oom killed thread is frozen before deferring)
commit b8839b8c55f3fdd60dc36abcda7e0266aff7985c upstream.
The math in both blk_stack_limits() and queue_limit_alignment_offset()
assume that a block device's io_min (aka minimum_io_size) is always a
power-of-2. Fix the math such that it works for non-power-of-2 io_min.
This issue (of alignment_offset != 0) became apparent when testing
dm-thinp with a thinp blocksize that matches a RAID6 stripesize of
1280K. Commit fdfb4c8c1 ("dm thin: set minimum_io_size to pool's data
block size") unlocked the potential for alignment_offset != 0 due to
the dm-thin-pool's io_min possibly being a non-power-of-2.
Signed-off-by: Mike Snitzer <snitzer@redhat.com>
Acked-by: Martin K. Petersen <martin.petersen@oracle.com>
Signed-off-by: Jens Axboe <axboe@fb.com>
commit d4c5efdb97773f59a2b711754ca0953f24516739 upstream.
zatimend has reported that in his environment (3.16/gcc4.8.3/corei7)
memset() calls which clear out sensitive data in extract_{buf,entropy,
entropy_user}() in random driver are being optimized away by gcc.
Add a helper memzero_explicit() (similarly as explicit_bzero() variants)
that can be used in such cases where a variable with sensitive data is
being cleared out in the end. Other use cases might also be in crypto
code. [ I have put this into lib/string.c though, as it's always built-in
and doesn't need any dependencies then. ]
Fixes kernel bugzilla: 82041
Reported-by: zatimend@hotmail.co.uk
Signed-off-by: Daniel Borkmann <dborkman@redhat.com>
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
Cc: Alexey Dobriyan <adobriyan@gmail.com>
Signed-off-by: Theodore Ts'o <tytso@mit.edu>
commit 90a8020278c1598fafd071736a0846b38510309c upstream.
->page_mkwrite() is used by filesystems to allocate blocks under a page
which is becoming writeably mmapped in some process' address space. This
allows a filesystem to return a page fault if there is not enough space
available, user exceeds quota or similar problem happens, rather than
silently discarding data later when writepage is called.
However VFS fails to call ->page_mkwrite() in all the cases where
filesystems need it when blocksize < pagesize. For example when
blocksize = 1024, pagesize = 4096 the following is problematic:
ftruncate(fd, 0);
pwrite(fd, buf, 1024, 0);
map = mmap(NULL, 1024, PROT_WRITE, MAP_SHARED, fd, 0);
map[0] = 'a'; ----> page_mkwrite() for index 0 is called
ftruncate(fd, 10000); /* or even pwrite(fd, buf, 1, 10000) */
mremap(map, 1024, 10000, 0);
map[4095] = 'a'; ----> no page_mkwrite() called
At the moment ->page_mkwrite() is called, filesystem can allocate only
one block for the page because i_size == 1024. Otherwise it would create
blocks beyond i_size which is generally undesirable. But later at
->writepage() time, we also need to store data at offset 4095 but we
don't have block allocated for it.
This patch introduces a helper function filesystems can use to have
->page_mkwrite() called at all the necessary moments.
commit a743419f420a64d442280845c0377a915b76644f upstream.
When aborting a connection to preserve source ports, don't wake the task in
xs_error_report. This allows tasks with RPC_TASK_SOFTCONN to succeed if the
connection needs to be re-established since it preserves the task's status
instead of setting it to the status of the aborting kernel_connect().
This may also avoid a potential conflict on the socket's lock.
Signed-off-by: Benjamin Coddington <bcodding@redhat.com>
commit 71458cfc782eafe4b27656e078d379a34e472adf upstream.
We're missing include/linux/compiler-gcc5.h which is required now
because gcc branched off to v5 in trunk.
Just copy the relevant bits out of include/linux/compiler-gcc4.h,
no new code is added as of now.
This fixes a build error when using gcc 5.
commit 934f3072c17cc8886f4c043b47eeeb1b12f8de33 upstream.
commit 21caf2fc1931 ("mm: teach mm by current context info to not do I/O
during memory allocation") introduces PF_MEMALLOC_NOIO flag to avoid doing
I/O inside memory allocation, __GFP_IO is cleared when this flag is set,
but __GFP_FS implies __GFP_IO, it should also be cleared. Or it may still
run into I/O, like in superblock shrinker. And this will make the kernel
run into the deadlock case described in that commit.
See Dave Chinner's comment about io in superblock shrinker:
Filesystem shrinkers do indeed perform IO from the superblock shrinker and
have for years. Even clean inodes can require IO before they can be freed
- e.g. on an orphan list, need truncation of post-eof blocks, need to
wait for ordered operations to complete before it can be freed, etc.
IOWs, Ext4, btrfs and XFS all can issue and/or block on arbitrary amounts
of IO in the superblock shrinker context. XFS, in particular, has been
doing transactions and IO from the VFS inode cache shrinker since it was
first introduced....
Fix this by clearing __GFP_FS in memalloc_noio_flags(), this function has
masked all the gfp_mask that will be passed into fs for the processes
setting PF_MEMALLOC_NOIO in the direct reclaim path.
v1 thread at: https://lkml.org/lkml/2014/9/3/32
Signed-off-by: Junxiao Bi <junxiao.bi@oracle.com>
Cc: joyce.xue <xuejiufei@huawei.com>
Cc: Ming Lei <ming.lei@canonical.com>
Cc: Trond Myklebust <trond.myklebust@primarydata.com>
commit bb048713bba3ead39f6112910906d9fe3f88ede7 upstream.
This patch adds the PCI id for Intel Quark ILB.
It will be used for GPIO and Multifunction device driver.
Signed-off-by: Josef Ahmad <josef.ahmad@intel.com>
Acked-by: Bjorn Helgaas <bhelgaas@google.com>
Signed-off-by: Lee Jones <lee.jones@linaro.org>
Signed-off-by: Chang Rebecca Swee Fun <rebecca.swee.fun.chang@intel.com>
commit ddbe1fca0bcb87ca8c199ea873a456ca8a948567 upstream.
This full-speed USB device generates spurious remote wakeup event
as soon as USB_DEVICE_REMOTE_WAKEUP feature is set. As the result,
Linux can't enter system suspend and S0ix power saving modes once
this keyboard is used.
This patch tries to introduce USB_QUIRK_IGNORE_REMOTE_WAKEUP quirk.
With this quirk set, wakeup capability will be ignored during
device configure.
This patch could be back-ported to kernels as old as 2.6.39.
Signed-off-by: Lu Baolu <baolu.lu@linux.intel.com>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
[ Upstream commit 0d5501c1c828fb97d02af50aa9d2b1a5498b94e4 ]
Currently the functionality to untag traffic on input resides
as part of the vlan module and is build only when VLAN support
is enabled in the kernel. When VLAN is disabled, the function
vlan_untag() turns into a stub and doesn't really untag the
packets. This seems to create an interesting interaction
between VMs supporting checksum offloading and some network drivers.
There are some drivers that do not allow the user to change
tx-vlan-offload feature of the driver. These drivers also seem
to assume that any VLAN-tagged traffic they transmit will
have the vlan information in the vlan_tci and not in the vlan
header already in the skb. When transmitting skbs that already
have tagged data with partial checksum set, the checksum doesn't
appear to be updated correctly by the card thus resulting in a
failure to establish TCP connections.
The following is a packet trace taken on the receiver where a
sender is a VM with a VLAN configued. The host VM is running on
doest not have VLAN support and the outging interface on the
host is tg3:
10:12:43.503055 52:54:00:ae:42:3f > 28:d2:44:7d:c2:de, ethertype 802.1Q
(0x8100), length 78: vlan 100, p 0, ethertype IPv4, (tos 0x0, ttl 64, id 27243,
offset 0, flags [DF], proto TCP (6), length 60)
10.0.100.1.58545 > 10.0.100.10.ircu-2: Flags [S], cksum 0xdc39 (incorrect
-> 0x48d9), seq 1069378582, win 29200, options [mss 1460,sackOK,TS val
4294837885 ecr 0,nop,wscale 7], length 0
10:12:44.505556 52:54:00:ae:42:3f > 28:d2:44:7d:c2:de, ethertype 802.1Q
(0x8100), length 78: vlan 100, p 0, ethertype IPv4, (tos 0x0, ttl 64, id 27244,
-> 0x44ee), seq 1069378582, win 29200, options [mss 1460,sackOK,TS val
4294838888 ecr 0,nop,wscale 7], length 0
This connection finally times out.
I've only access to the TG3 hardware in this configuration thus have
only tested this with TG3 driver. There are a lot of other drivers
that do not permit user changes to vlan acceleration features, and
I don't know if they all suffere from a similar issue.
The patch attempt to fix this another way. It moves the vlan header
stipping code out of the vlan module and always builds it into the
kernel network core. This way, even if vlan is not supported on
a virtualizatoin host, the virtual machines running on top of such
host will still work with VLANs enabled.
CC: Patrick McHardy <kaber@trash.net>
CC: Nithin Nayak Sujir <nsujir@broadcom.com>
CC: Michael Chan <mchan@broadcom.com>
CC: Jiri Pirko <jiri@resnulli.us>
Signed-off-by: Vladislav Yasevich <vyasevic@redhat.com>
Acked-by: Jiri Pirko <jiri@resnulli.us>
commit 615d6e8756c87149f2d4c1b93d471bca002bd849 upstream.
This patch is a continuation of efforts trying to optimize find_vma(),
avoiding potentially expensive rbtree walks to locate a vma upon faults.
The original approach (https://lkml.org/lkml/2013/11/1/410), where the
largest vma was also cached, ended up being too specific and random,
thus further comparison with other approaches were needed. There are
two things to consider when dealing with this, the cache hit rate and
the latency of find_vma(). Improving the hit-rate does not necessarily
translate in finding the vma any faster, as the overhead of any fancy
caching schemes can be too high to consider.
We currently cache the last used vma for the whole address space, which
provides a nice optimization, reducing the total cycles in find_vma() by
up to 250%, for workloads with good locality. On the other hand, this
simple scheme is pretty much useless for workloads with poor locality.
Analyzing ebizzy runs shows that, no matter how many threads are
running, the mmap_cache hit rate is less than 2%, and in many situations
below 1%.
The proposed approach is to replace this scheme with a small per-thread
cache, maximizing hit rates at a very low maintenance cost.
Invalidations are performed by simply bumping up a 32-bit sequence
number. The only expensive operation is in the rare case of a seq
number overflow, where all caches that share the same address space are
flushed. Upon a miss, the proposed replacement policy is based on the
page number that contains the virtual address in question. Concretely,
the following results are seen on an 80 core, 8 socket x86-64 box:
1) System bootup: Most programs are single threaded, so the per-thread
scheme does improve ~50% hit rate by just adding a few more slots to
the cache.
| caching scheme | hit-rate | cycles (billion) |
| baseline | 50.61% | 19.90 |
| patched | 73.45% | 13.58 |
2) Kernel build: This one is already pretty good with the current
approach as we're dealing with good locality.
| baseline | 75.28% | 11.03 |
| patched | 88.09% | 9.31 |
3) Oracle 11g Data Mining (4k pages): Similar to the kernel build workload.
| baseline | 70.66% | 17.14 |
| patched | 91.15% | 12.57 |
4) Ebizzy: There's a fair amount of variation from run to run, but this
approach always shows nearly perfect hit rates, while baseline is just
about non-existent. The amounts of cycles can fluctuate between
anywhere from ~60 to ~116 for the baseline scheme, but this approach
reduces it considerably. For instance, with 80 threads:
| baseline | 1.06% | 91.54 |
| patched | 99.97% | 14.18 |
[akpm@linux-foundation.org: fix nommu build, per Davidlohr]
[akpm@linux-foundation.org: document vmacache_valid() logic]
[akpm@linux-foundation.org: attempt to untangle header files]
[akpm@linux-foundation.org: add vmacache_find() BUG_ON]
[hughd@google.com: add vmacache_valid_mm() (from Oleg)]
[akpm@linux-foundation.org: adjust and enhance comments]
Signed-off-by: Davidlohr Bueso <davidlohr@hp.com>
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Reviewed-by: Michel Lespinasse <walken@google.com>
Tested-by: Hugh Dickins <hughd@google.com>
commit d26914d11751b23ca2e8747725f2cae10c2f2c1b upstream.
Since put_mems_allowed() is strictly optional, its a seqcount retry, we
don't need to evaluate the function if the allocation was in fact
successful, saving a smp_rmb some loads and comparisons on some relative
fast-paths.
Since the naming, get/put_mems_allowed() does suggest a mandatory
pairing, rename the interface, as suggested by Mel, to resemble the
seqcount interface.
This gives us: read_mems_allowed_begin() and read_mems_allowed_retry(),
where it is important to note that the return value of the latter call
is inverted from its previous incarnation.
commit 18ab4d4ced0817421e6db6940374cc39d28d65da upstream.
Originally get_swap_page() started iterating through the singly-linked
list of swap_info_structs using swap_list.next or highest_priority_index,
which both were intended to point to the highest priority active swap
target that was not full. The first patch in this series changed the
singly-linked list to a doubly-linked list, and removed the logic to start
at the highest priority non-full entry; it starts scanning at the highest
priority entry each time, even if the entry is full.
Replace the manually ordered swap_list_head with a plist, swap_active_head.
Add a new plist, swap_avail_head. The original swap_active_head plist
contains all active swap_info_structs, as before, while the new
swap_avail_head plist contains only swap_info_structs that are active and
available, i.e. not full. Add a new spinlock, swap_avail_lock, to protect
the swap_avail_head list.
Mel Gorman suggested using plists since they internally handle ordering
the list entries based on priority, which is exactly what swap was doing
manually. All the ordering code is now removed, and swap_info_struct
entries and simply added to their corresponding plist and automatically
ordered correctly.
Using a new plist for available swap_info_structs simplifies and
optimizes get_swap_page(), which no longer has to iterate over full
swap_info_structs. Using a new spinlock for swap_avail_head plist
allows each swap_info_struct to add or remove themselves from the
plist when they become full or not-full; previously they could not
do so because the swap_info_struct->lock is held when they change
from full<->not-full, and the swap_lock protecting the main
swap_active_head must be ordered before any swap_info_struct->lock.
Signed-off-by: Dan Streetman <ddstreet@ieee.org>
Cc: Shaohua Li <shli@fusionio.com>
Cc: Dan Streetman <ddstreet@ieee.org>
Cc: Christian Ehrhardt <ehrhardt@linux.vnet.ibm.com>
Cc: Weijie Yang <weijieut@gmail.com>
Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
commit a75f232ce0fe38bd01301899ecd97ffd0254316a upstream.
Add plist_requeue(), which moves the specified plist_node after all other
same-priority plist_nodes in the list. This is essentially an optimized
plist_del() followed by plist_add().
This is needed by swap, which (with the next patch in this set) uses a
plist of available swap devices. When a swap device (either a swap
partition or swap file) are added to the system with swapon(), the device
is added to a plist, ordered by the swap device's priority. When swap
needs to allocate a page from one of the swap devices, it takes the page
from the first swap device on the plist, which is the highest priority
swap device. The swap device is left in the plist until all its pages are
used, and then removed from the plist when it becomes full.
However, as described in man 2 swapon, swap must allocate pages from swap
devices with the same priority in round-robin order; to do this, on each
swap page allocation, swap uses a page from the first swap device in the
plist, and then calls plist_requeue() to move that swap device entry to
after any other same-priority swap devices. The next swap page allocation
will again use a page from the first swap device in the plist and requeue
it, and so on, resulting in round-robin usage of equal-priority swap
devices.
Also add plist_test_requeue() test function, for use by plist_test() to
test plist_requeue() function.
commit fd16618e12a05df79a3439d72d5ffdac5d34f3da upstream.
Add PLIST_HEAD() to plist.h, equivalent to LIST_HEAD() from list.h, to
define and initialize a struct plist_head.
Add plist_for_each_continue() and plist_for_each_entry_continue(),
equivalent to list_for_each_continue() and list_for_each_entry_continue(),
to iterate over a plist continuing after the current position.
Add plist_prev() and plist_next(), equivalent to (struct list_head*)->prev
and ->next, implemented by list_prev_entry() and list_next_entry(), to
access the prev/next struct plist_node entry. These are needed because
unlike struct list_head, direct access of the prev/next struct plist_node
isn't possible; the list must be navigated via the contained struct
list_head. e.g. instead of accessing the prev by list_prev_entry(node,
node_list) it can be accessed by plist_prev(node).
commit adfab836f4908deb049a5128082719e689eed964 upstream.
The logic controlling the singly-linked list of swap_info_struct entries
for all active, i.e. swapon'ed, swap targets is rather complex, because:
- it stores the entries in priority order
- there is a pointer to the highest priority entry
- there is a pointer to the highest priority not-full entry
- there is a highest_priority_index variable set outside the swap_lock
- swap entries of equal priority should be used equally
this complexity leads to bugs such as: https://lkml.org/lkml/2014/2/13/181
where different priority swap targets are incorrectly used equally.
That bug probably could be solved with the existing singly-linked lists,
but I think it would only add more complexity to the already difficult to
understand get_swap_page() swap_list iteration logic.
The first patch changes from a singly-linked list to a doubly-linked list
using list_heads; the highest_priority_index and related code are removed
and get_swap_page() starts each iteration at the highest priority
swap_info entry, even if it's full. While this does introduce unnecessary
list iteration (i.e. Schlemiel the painter's algorithm) in the case where
one or more of the highest priority entries are full, the iteration and
manipulation code is much simpler and behaves correctly re: the above bug;
and the fourth patch removes the unnecessary iteration.
The second patch adds some minor plist helper functions; nothing new
really, just functions to match existing regular list functions. These
are used by the next two patches.
The third patch adds plist_requeue(), which is used by get_swap_page() in
the next patch - it performs the requeueing of same-priority entries
(which moves the entry to the end of its priority in the plist), so that
all equal-priority swap_info_structs get used equally.
The fourth patch converts the main list into a plist, and adds a new plist
that contains only swap_info entries that are both active and not full.
As Mel suggested using plists allows removing all the ordering code from
swap - plists handle ordering automatically. The list naming is also
clarified now that there are two lists, with the original list changed
from swap_list_head to swap_active_head and the new list named
swap_avail_head. A new spinlock is also added for the new list, so
swap_info entries can be added or removed from the new list immediately as
they become full or not full.
This patch (of 4):
Replace the singly-linked list tracking active, i.e. swapon'ed,
swap_info_struct entries with a doubly-linked list using struct
list_heads. Simplify the logic iterating and manipulating the list of
entries, especially get_swap_page(), by using standard list_head
functions, and removing the highest priority iteration logic.
The change fixes the bug:
in which different priority swap entries after the highest priority entry
are incorrectly used equally in pairs. The swap behavior is now as
advertised, i.e. different priority swap entries are used in order, and
equal priority swap targets are used concurrently.
commit d78c9300c51d6ceed9f6d078d4e9366f259de28c upstream.
timeval_to_jiffies tried to round a timeval up to an integral number
of jiffies, but the logic for doing so was incorrect: intervals
corresponding to exactly N jiffies would become N+1. This manifested
itself particularly repeatedly stopping/starting an itimer:
setitimer(ITIMER_PROF, &val, NULL);
setitimer(ITIMER_PROF, NULL, &val);
would add a full tick to val, _even if it was exactly representable in
terms of jiffies_ (say, the result of a previous rounding.) Doing
this repeatedly would cause unbounded growth in val. So fix the math.
Here's what was wrong with the conversion: we essentially computed
(eliding seconds)
jiffies = usec * (NSEC_PER_USEC/TICK_NSEC)
by using scaling arithmetic, which took the best approximation of
NSEC_PER_USEC/TICK_NSEC with denominator of 2^USEC_JIFFIE_SC =
x/(2^USEC_JIFFIE_SC), and computed:
jiffies = (usec * x) >> USEC_JIFFIE_SC
and rounded this calculation up in the intermediate form (since we
can't necessarily exactly represent TICK_NSEC in usec.) But the
scaling arithmetic is a (very slight) *over*approximation of the true
value; that is, instead of dividing by (1 usec/ 1 jiffie), we
effectively divided by (1 usec/1 jiffie)-epsilon (rounding
down). This would normally be fine, but we want to round timeouts up,
and we did so by adding 2^USEC_JIFFIE_SC - 1 before the shift; this
would be fine if our division was exact, but dividing this by the
slightly smaller factor was equivalent to adding just _over_ 1 to the
final result (instead of just _under_ 1, as desired.)
In particular, with HZ=1000, we consistently computed that 10000 usec
was 11 jiffies; the same was true for any exact multiple of
TICK_NSEC.
We could possibly still round in the intermediate form, adding
something less than 2^USEC_JIFFIE_SC - 1, but easier still is to
convert usec->nsec, round in nanoseconds, and then convert using
time*spec*_to_jiffies. This adds one constant multiplication, and is
not observably slower in microbenchmarks on recent x86 hardware.
Tested: the following program:
int main() {
struct itimerval zero = {{0, 0}, {0, 0}};
/* Initially set to 10 ms. */
struct itimerval initial = zero;
initial.it_interval.tv_usec = 10000;
setitimer(ITIMER_PROF, &initial, NULL);
/* Save and restore several times. */
for (size_t i = 0; i < 10; ++i) {
struct itimerval prev;
setitimer(ITIMER_PROF, &zero, &prev);
/* on old kernels, this goes up by TICK_USEC every iteration */
printf("previous value: %ld %ld %ld %ld\n",
prev.it_interval.tv_sec, prev.it_interval.tv_usec,
prev.it_value.tv_sec, prev.it_value.tv_usec);
setitimer(ITIMER_PROF, &prev, NULL);
return 0;
Cc: Paul Turner <pjt@google.com>
Cc: Richard Cochran <richardcochran@gmail.com>
Cc: Prarit Bhargava <prarit@redhat.com>
Reviewed-by: Paul Turner <pjt@google.com>
Reported-by: Aaron Jacobs <jacobsa@google.com>
Signed-off-by: Andrew Hunter <ahh@google.com>
[jstultz: Tweaked to apply to 3.17-rc]
Signed-off-by: John Stultz <john.stultz@linaro.org>
[bwh: Backported to 3.16: adjust filename]
commit 457c1b27ed56ec472d202731b12417bff023594a upstream.
Currently, I am seeing the following when I `mount -t hugetlbfs /none
/dev/hugetlbfs`, and then simply do a `ls /dev/hugetlbfs`. I think it's
related to the fact that hugetlbfs is properly not correctly setting
itself up in this state?:
Unable to handle kernel paging request for data at address 0x00000031
Faulting instruction address: 0xc000000000245710
Oops: Kernel access of bad area, sig: 11 [#1]
SMP NR_CPUS=2048 NUMA pSeries
In KVM guests on Power, in a guest not backed by hugepages, we see the
following:
AnonHugePages: 0 kB
HugePages_Total: 0
HugePages_Free: 0
HugePages_Rsvd: 0
HugePages_Surp: 0
Hugepagesize: 64 kB
HPAGE_SHIFT == 0 in this configuration, which indicates that hugepages
are not supported at boot-time, but this is only checked in
hugetlb_init(). Extract the check to a helper function, and use it in a
few relevant places.
This does make hugetlbfs not supported (not registered at all) in this
environment. I believe this is fine, as there are no valid hugepages
and that won't change at runtime.
[akpm@linux-foundation.org: use pr_info(), per Mel]
[akpm@linux-foundation.org: fix build when HPAGE_SHIFT is undefined]
Signed-off-by: Nishanth Aravamudan <nacc@linux.vnet.ibm.com>
Reviewed-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
Cc: Randy Dunlap <rdunlap@infradead.org>
commit 766a53d059d1500c9755c8af017bd411bd8f1b20 upstream.
Drivers should call this on unload to unregister pmops.
Bug:
https://bugzilla.kernel.org/show_bug.cgi?id=84431
Reviewed-by: Ben Skeggs <bskeggs@redhat.com>
Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
Signed-off-by: Pali Rohár <pali.rohar@gmail.com>
Cc: Ben Skeggs <bskeggs@redhat.com>
commit 22fdcf02f6e80d64a927f702dd9d631a927d87d4 upstream.
This commit reverts the addition of lockdep checking to raw_seqcount_begin
for the following reasons:
1) It violates the naming convention that raw_* functions should not
do lockdep checks (a convention that is also followed by the other
raw_*_seqcount_begin functions).
2) raw_seqcount_begin does not spin, so it can only be part of an ABBA
deadlock in very special circumstances (for instance if a lock
is held across the entire raw_seqcount_begin()+read_seqcount_retry()
loop while also being taken inside the write_seqcount protected area).
3) It is causing false positives with some existing callers, and there
is no non-lockdep alternative for those callers to use.
None of the three existing callers (__d_lookup_rcu, netdev_get_name, and
the NFS state code) appear to use the function in a manner that is ABBA
deadlock prone.
Fixes: 1ca7d67cf5d5: seqcount: Add lockdep functionality to seqcount/seqlock
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Cc: John Stultz <john.stultz@linaro.org>
Cc: Waiman Long <Waiman.Long@hp.com>
Cc: Stephen Boyd <sboyd@codeaurora.org>
Link: http://lkml.kernel.org/r/CAHQdGtRR6SvEhXiqWo24hoUh9AU9cL82Z8Z-d8-7u951F_d+5g@mail.gmail.com
commit e09c2c295468476a239d13324ce9042ec4de05eb upstream.
create_singlethread_workqueue() is a compat interface for single
threaded workqueue which maps to ordered workqueue w/ rescuer in the
current implementation. create_singlethread_workqueue() currently
implemented by invoking alloc_workqueue() w/ appropriate parameters.
8719dceae2f9 ("workqueue: reject adjusting max_active or applying
attrs to ordered workqueues") introduced __WQ_ORDERED to protect
ordered workqueues against dynamic attribute changes which can break
ordering guarantees but forgot to apply it to
create_singlethread_workqueue(). This in itself is okay as nobody
currently uses dynamic attribute change on workqueues created with
However, 4c16bd327c ("workqueue: implement NUMA affinity for unbound
workqueues") broke singlethreaded guarantee for ordered workqueues
through allocating a separate pool_workqueue on each NUMA node by
default. A later change 8a2b75384444 ("workqueue: fix ordered
workqueues in NUMA setups") fixed it by allocating only one global
pool_workqueue if __WQ_ORDERED is set.
Combined, the __WQ_ORDERED omission in create_singlethread_workqueue()
became critical breaking its single threadedness and ordering
guarantee.
Let's make create_singlethread_workqueue() wrap
alloc_ordered_workqueue() instead so that it inherits __WQ_ORDERED and
can implicitly track future ordered_workqueue changes.
v2: I missed that __WQ_ORDERED now protects against pwq splitting
across NUMA nodes and incorrectly described the patch as a
nice-to-have fix to protect against future dynamic attribute
usages. Oleg pointed out that this is actually a critical
breakage due to 8a2b75384444 ("workqueue: fix ordered workqueues
in NUMA setups").
Reported-by: Mike Anderson <mike.anderson@us.ibm.com>
Cc: Oleg Nesterov <onestero@redhat.com>
Cc: Gustavo Luiz Duarte <gduarte@redhat.com>
Cc: Tomas Henzl <thenzl@redhat.com>
Fixes: 4c16bd327c ("workqueue: implement NUMA affinity for unbound workqueues")
commit f153566570fb9e32c2f59182883f4f66048788fb upstream.
Instead of a void function, return the trigger pointer.
Whilst not in of itself a fix, this makes the following set of
7 fixes cleaner than they would otherwise be.
Signed-off-by: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com>
Signed-off-by: Jonathan Cameron <jic23@kernel.org>
commit 44b1d53043c482225196e8a9cd9f35163a1b3336 upstream.
Add d_is_dir(dentry) helper which is analogous to S_ISDIR().
To avoid confusion, rename d_is_directory() to d_can_lookup().
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
Reviewed-by: J. Bruce Fields <bfields@redhat.com>
commit 9566d6742852c527bf5af38af5cbb878dad75705 upstream.
While invesgiating the issue where in "mount --bind -oremount,ro ..."
would result in later "mount --bind -oremount,rw" succeeding even if
the mount started off locked I realized that there are several
additional mount flags that should be locked and are not.
In particular MNT_NOSUID, MNT_NODEV, MNT_NOEXEC, and the atime
flags in addition to MNT_READONLY should all be locked. These
flags are all per superblock, can all be changed with MS_BIND,
and should not be changable if set by a more privileged user.
The following additions to the current logic are added in this patch.
- nosuid may not be clearable by a less privileged user.
- nodev may not be clearable by a less privielged user.
- noexec may not be clearable by a less privileged user.
- atime flags may not be changeable by a less privileged user.
The logic with atime is that always setting atime on access is a
global policy and backup software and auditing software could break if
atime bits are not updated (when they are configured to be updated),
and serious performance degradation could result (DOS attack) if atime
updates happen when they have been explicitly disabled. Therefore an
unprivileged user should not be able to mess with the atime bits set
The additional restrictions are implemented with the addition of
MNT_LOCK_NOSUID, MNT_LOCK_NODEV, MNT_LOCK_NOEXEC, and MNT_LOCK_ATIME
mnt flags.
Taken together these changes and the fixes for MNT_LOCK_READONLY
should make it safe for an unprivileged user to create a user
namespace and to call "mount --bind -o remount,... ..." without
the danger of mount flags being changed maliciously.
Acked-by: Serge E. Hallyn <serge.hallyn@ubuntu.com>
commit a6138db815df5ee542d848318e5dae681590fccd upstream.
Kenton Varda <kenton@sandstorm.io> discovered that by remounting a
read-only bind mount read-only in a user namespace the
MNT_LOCK_READONLY bit would be cleared, allowing an unprivileged user
to the remount a read-only mount read-write.
Correct this by replacing the mask of mount flags to preserve
with a mask of mount flags that may be changed, and preserve
all others. This ensures that any future bugs with this mask and
remount will fail in an easy to detect way where new mount flags
simply won't change.
commit 7d8b6c63751cfbbe5eef81a48c22978b3407a3ad upstream.
This is effectively a revert of 7b9a7ec565505699f503b4fcf61500dceb36e744
plus fixing it a different way...
We found, when trying to run an application from an application which
had dropped privs that the kernel does security checks on undefined
capability bits. This was ESPECIALLY difficult to debug as those
undefined bits are hidden from /proc/$PID/status.
Consider a root application which drops all capabilities from ALL 4
capability sets. We assume, since the application is going to set
eff/perm/inh from an array that it will clear not only the defined caps
less than CAP_LAST_CAP, but also the higher 28ish bits which are
undefined future capabilities.
The BSET gets cleared differently. Instead it is cleared one bit at a
time. The problem here is that in security/commoncap.c::cap_task_prctl()
we actually check the validity of a capability being read. So any task
which attempts to 'read all things set in bset' followed by 'unset all
things set in bset' will not even attempt to unset the undefined bits
higher than CAP_LAST_CAP.
So the 'parent' will look something like:
CapInh: 0000000000000000
CapPrm: 0000000000000000
CapEff: 0000000000000000
CapBnd: ffffffc000000000
All of this 'should' be fine. Given that these are undefined bits that
aren't supposed to have anything to do with permissions. But they do...
So lets now consider a task which cleared the eff/perm/inh completely
and cleared all of the valid caps in the bset (but not the invalid caps
it couldn't read out of the kernel). We know that this is exactly what
the libcap-ng library does and what the go capabilities library does.
They both leave you in that above situation if you try to clear all of
you capapabilities from all 4 sets. If that root task calls execve()
the child task will pick up all caps not blocked by the bset. The bset
however does not block bits higher than CAP_LAST_CAP. So now the child
task has bits in eff which are not in the parent. These are
'meaningless' undefined bits, but still bits which the parent doesn't
have.
The problem is now in cred_cap_issubset() (or any operation which does a
subset test) as the child, while a subset for valid cap bits, is not a
subset for invalid cap bits! So now we set durring commit creds that
the child is not dumpable. Given it is 'more priv' than its parent. It
also means the parent cannot ptrace the child and other stupidity.
The solution here:
1) stop hiding capability bits in status
This makes debugging easier!
2) stop giving any task undefined capability bits. it's simple, it you
don't put those invalid bits in CAP_FULL_SET you won't get them in init
and you won't get them in any other task either.
This fixes the cap_issubset() tests and resulting fallout (which
made the init task in a docker container untraceable among other
things)
3) mask out undefined bits when sys_capset() is called as it might use
~0, ~0 to denote 'all capabilities' for backward/forward compatibility.
This lets 'capsh --caps="all=eip" -- -c /bin/bash' run.
4) mask out undefined bit when we read a file capability off of disk as
again likely all bits are set in the xattr for forward/backward
compatibility.
This lets 'setcap all+pe /bin/bash; /bin/bash' run
Signed-off-by: Eric Paris <eparis@redhat.com>
Cc: Andrew Vagin <avagin@openvz.org>
Cc: Andrew G. Morgan <morgan@kernel.org>
Cc: Serge E. Hallyn <serge.hallyn@canonical.com>
Cc: Steve Grubb <sgrubb@redhat.com>
Cc: Dan Walsh <dwalsh@redhat.com>
Signed-off-by: James Morris <james.l.morris@oracle.com>
commit 8e54caf407b98efa05409e1fee0e5381abd2b088 upstream.
Some Atmel TPMs provide completely wrong timeouts from their
TPM_CAP_PROP_TIS_TIMEOUT query. This patch detects that and returns
new correct values via a DID/VID table in the TIS driver.
Tested on ARM using an AT97SC3204T FW version 37.16
[PHuewe: without this fix these 'broken' Atmel TPMs won't function on
older kernels]
Signed-off-by: "Berg, Christopher" <Christopher.Berg@atmel.com>
Signed-off-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com>
Signed-off-by: Peter Huewe <peterhuewe@gmx.de>
commit 3c45ddf823d679a820adddd53b52c6699c9a05ac upstream.
The current code always selects XPRT_TRANSPORT_BC_TCP for the back
channel, even when the forward channel was not TCP (eg, RDMA). When
a 4.1 mount is attempted with RDMA, the server panics in the TCP BC
code when trying to send CB_NULL.
Instead, construct the transport protocol number from the forward
channel transport or'd with XPRT_TRANSPORT_BC. Transports that do
not support bi-directional RPC will not have registered a "BC"
transport, causing create_backchannel_client() to fail immediately.
Fixes: https://bugzilla.linux-nfs.org/show_bug.cgi?id=265
Signed-off-by: Chuck Lever <chuck.lever@oracle.com>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
commit db9ee220361de03ee86388f9ea5e529eaad5323c upstream.
It turns out that there are some serious problems with the on-disk
format of journal checksum v2. The foremost is that the function to
calculate descriptor tag size returns sizes that are too big. This
causes alignment issues on some architectures and is compounded by the
fact that some parts of jbd2 use the structure size (incorrectly) to
determine the presence of a 64bit journal instead of checking the
feature flags.
Therefore, introduce journal checksum v3, which enlarges the
descriptor block tag format to allow for full 32-bit checksums of
journal blocks, fix the journal tag function to return the correct
sizes, and fix the jbd2 recovery code to use feature flags to
determine 64bitness.
Add a few function helpers so we don't have to open-code quite so
many pieces.
Switching to a 16-byte block size was found to increase journal size
overhead by a maximum of 0.1%, to convert a 32-bit journal with no
checksumming to a 32-bit journal with checksum v3 enabled.
Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com>
Reported-by: TR Reardon <thomas_reardon@hotmail.com>
commit aac74dc495456412c4130a1167ce4beb6c1f0b38 upstream.
After learning we'll need some sort of deferred printk functionality in
the timekeeping core, Peter suggested we rename the printk_sched function
so it can be reused by needed subsystems.
This only changes the function name. No logic changes.
Reviewed-by: Steven Rostedt <rostedt@goodmis.org>
Cc: Jiri Bohac <jbohac@suse.cz>
commit 1a112d10f03e83fb3a2fdc4c9165865dec8a3ca6 upstream.
1871ee134b73 ("libata: support the ata host which implements a queue
depth less than 32") directly used ata_port->scsi_host->can_queue from
ata_qc_new() to determine the number of tags supported by the host;
unfortunately, SAS controllers doing SATA don't initialize ->scsi_host
leading to the following oops.
BUG: unable to handle kernel NULL pointer dereference at 0000000000000058
IP: [<ffffffff814e0618>] ata_qc_new_init+0x188/0x1b0
PGD 0
Oops: 0002 [#1] SMP
Modules linked in: isci libsas scsi_transport_sas mgag200 drm_kms_helper ttm
CPU: 1 PID: 518 Comm: udevd Not tainted 3.16.0-rc6+ #62
Hardware name: Intel Corporation S2600CO/S2600CO, BIOS SE5C600.86B.02.02.0002.122320131210 12/23/2013
task: ffff880c1a00b280 ti: ffff88061a000000 task.ti: ffff88061a000000
RIP: 0010:[<ffffffff814e0618>] [<ffffffff814e0618>] ata_qc_new_init+0x188/0x1b0
RSP: 0018:ffff88061a003ae8 EFLAGS: 00010012
RAX: 0000000000000001 RBX: ffff88000241ca80 RCX: 00000000000000fa
RDX: 0000000000000020 RSI: 0000000000000020 RDI: ffff8806194aa298
RBP: ffff88061a003ae8 R08: ffff8806194a8000 R09: 0000000000000000
R10: 0000000000000000 R11: ffff88000241ca80 R12: ffff88061ad58200
R13: ffff8806194aa298 R14: ffffffff814e67a0 R15: ffff8806194a8000
FS: 00007f3ad7fe3840(0000) GS:ffff880627620000(0000) knlGS:0000000000000000
CR2: 0000000000000058 CR3: 000000061a118000 CR4: 00000000001407e0
Stack:
ffff88061a003b20 ffffffff814e96e1 ffff88000241ca80 ffff88061ad58200
ffff8800b6bf6000 ffff880c1c988000 ffff880619903850 ffff88061a003b68
ffffffffa0056ce1 ffff88061a003b48 0000000013d6e6f8 ffff88000241ca80
Call Trace:
[<ffffffff814e96e1>] ata_sas_queuecmd+0xa1/0x430
[<ffffffffa0056ce1>] sas_queuecommand+0x191/0x220 [libsas]
[<ffffffff8149afee>] scsi_dispatch_cmd+0x10e/0x300 [<ffffffff814a3bc5>] scsi_request_fn+0x2f5/0x550
[<ffffffff81317613>] __blk_run_queue+0x33/0x40
[<ffffffff8131781a>] queue_unplugged+0x2a/0x90
[<ffffffff8131ceb4>] blk_flush_plug_list+0x1b4/0x210
[<ffffffff8131d274>] blk_finish_plug+0x14/0x50
[<ffffffff8117eaa8>] __do_page_cache_readahead+0x198/0x1f0
[<ffffffff8117ee21>] force_page_cache_readahead+0x31/0x50
[<ffffffff8117ee7e>] page_cache_sync_readahead+0x3e/0x50
[<ffffffff81172ac6>] generic_file_read_iter+0x496/0x5a0
[<ffffffff81219897>] blkdev_read_iter+0x37/0x40
[<ffffffff811e307e>] new_sync_read+0x7e/0xb0
[<ffffffff811e3734>] vfs_read+0x94/0x170
[<ffffffff811e43c6>] SyS_read+0x46/0xb0
[<ffffffff811e33d1>] ? SyS_lseek+0x91/0xb0
[<ffffffff8171ee29>] system_call_fastpath+0x16/0x1b
Code: 00 00 00 88 50 29 83 7f 08 01 19 d2 83 e2 f0 83 ea 50 88 50 34 c6 81 1d 02 00 00 40 c6 81 17 02 00 00 00 5d c3 66 0f 1f 44 00 00 <89> 14 25 58 00 00 00
Fix it by introducing ata_host->n_tags which is initialized to
ATA_MAX_QUEUE - 1 in ata_host_init() for SAS controllers and set to
scsi_host_template->can_queue in ata_host_register() for !SAS ones.
As SAS hosts are never registered, this will give them the same
ATA_MAX_QUEUE - 1 as before. Note that we can't use
scsi_host->can_queue directly for SAS hosts anyway as they can go
higher than the libata maximum.
Reported-by: Mike Qiu <qiudayu@linux.vnet.ibm.com>
Reported-by: Jesse Brandeburg <jesse.brandeburg@gmail.com>
Reported-by: Peter Hurley <peter@hurleysoftware.com>
Reported-by: Peter Zijlstra <peterz@infradead.org>
Tested-by: Alexey Kardashevskiy <aik@ozlabs.ru>
Fixes: 1871ee134b73 ("libata: support the ata host which implements a queue depth less than 32")
Cc: Kevin Hao <haokexin@gmail.com>
Cc: Dan Williams <dan.j.williams@intel.com>
commit 8b8b36834d0fff67fc8668093f4312dd04dcf21d upstream.
The per_cpu buffers are created one per possible CPU. But these do
not mean that those CPUs are online, nor do they even exist.
With the addition of the ring buffer polling, it assumes that the
caller polls on an existing buffer. But this is not the case if
the user reads trace_pipe from a CPU that does not exist, and this
causes the kernel to crash.
Simple fix is to check the cpu against buffer bitmask against to see
if the buffer was allocated or not and return -ENODEV if it is
not.
More updates were done to pass the -ENODEV back up to userspace.
Link: http://lkml.kernel.org/r/5393DB61.6060707@oracle.com
Reported-by: Sasha Levin <sasha.levin@oracle.com>
