commit 62f0342de1f012f3e90607d39e20fce811391169 upstream.
Every USB Host controller should use this new
macro to define for how long resume signalling
should be driven on the bus.
Currently, almost every single USB controller
is using a 20ms timeout for resume signalling.
That's problematic for two reasons:
a) sometimes that 20ms timer expires a little
before 20ms, which makes us fail certification
b) some (many) devices actually need more than
20ms resume signalling.
Sure, in case of (b) we can state that the device
is against the USB spec, but the fact is that
we have no control over which device the certification
lab will use. We also have no control over which host
they will use. Most likely they'll be using a Windows
PC which, again, we have no control over how that
USB stack is written and how long resume signalling
they are using.
At the end of the day, we must make sure Linux passes
electrical compliance when working as Host or as Device
and currently we don't pass compliance as host because
we're driving resume signallig for exactly 20ms and
that confuses certification test setup resulting in
Certification failure.
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Acked-by: Peter Chen <peter.chen@freescale.com>
Signed-off-by: Felipe Balbi <balbi@ti.com>
[ Upstream commit 2ea2f62c8bda242433809c7f4e9eae1c52c40bbe ]
When I added pfmemalloc support in build_skb(), I forgot netlink
was using build_skb() with a vmalloc() area.
In this patch I introduce __build_skb() for netlink use,
and build_skb() is a wrapper handling both skb->head_frag and
skb->pfmemalloc
This means netlink no longer has to hack skb->head_frag
[ 1567.700067] kernel BUG at arch/x86/mm/physaddr.c:26!
[ 1567.700067] invalid opcode: 0000 [#1] PREEMPT SMP KASAN
[ 1567.700067] Dumping ftrace buffer:
[ 1567.700067] (ftrace buffer empty)
[ 1567.700067] Modules linked in:
[ 1567.700067] CPU: 9 PID: 16186 Comm: trinity-c182 Not tainted 4.0.0-next-20150424-sasha-00037-g4796e21 #2167
[ 1567.700067] task: ffff880127efb000 ti: ffff880246770000 task.ti: ffff880246770000
[ 1567.700067] RIP: __phys_addr (arch/x86/mm/physaddr.c:26 (discriminator 3))
[ 1567.700067] RSP: 0018:ffff8802467779d8 EFLAGS: 00010202
[ 1567.700067] RAX: 000041000ed8e000 RBX: ffffc9008ed8e000 RCX: 000000000000002c
[ 1567.700067] RDX: 0000000000000004 RSI: 0000000000000000 RDI: ffffffffb3fd6049
[ 1567.700067] RBP: ffff8802467779f8 R08: 0000000000000019 R09: ffff8801d0168000
[ 1567.700067] R10: ffff8801d01680c7 R11: ffffed003a02d019 R12: ffffc9000ed8e000
[ 1567.700067] R13: 0000000000000f40 R14: 0000000000001180 R15: ffffc9000ed8e000
[ 1567.700067] FS: 00007f2a7da3f700(0000) GS:ffff8801d1000000(0000) knlGS:0000000000000000
[ 1567.700067] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 1567.700067] CR2: 0000000000738308 CR3: 000000022e329000 CR4: 00000000000007e0
[ 1567.700067] Stack:
[ 1567.700067] ffffc9000ed8e000 ffff8801d0168000 ffffc9000ed8e000 ffff8801d0168000
[ 1567.700067] ffff880246777a28 ffffffffad7c0a21 0000000000001080 ffff880246777c08
[ 1567.700067] ffff88060d302e68 ffff880246777b58 ffff880246777b88 ffffffffad9a6821
[ 1567.700067] Call Trace:
[ 1567.700067] build_skb (include/linux/mm.h:508 net/core/skbuff.c:316)
[ 1567.700067] netlink_sendmsg (net/netlink/af_netlink.c:1633 net/netlink/af_netlink.c:2329)
[ 1567.774369] ? sched_clock_cpu (kernel/sched/clock.c:311)
[ 1567.774369] ? netlink_unicast (net/netlink/af_netlink.c:2273)
[ 1567.774369] sock_sendmsg (net/socket.c:614 net/socket.c:623)
[ 1567.774369] sock_write_iter (net/socket.c:823)
[ 1567.774369] ? sock_sendmsg (net/socket.c:806)
[ 1567.774369] __vfs_write (fs/read_write.c:479 fs/read_write.c:491)
[ 1567.774369] ? get_lock_stats (kernel/locking/lockdep.c:249)
[ 1567.774369] ? default_llseek (fs/read_write.c:487)
[ 1567.774369] ? vtime_account_user (kernel/sched/cputime.c:701)
[ 1567.774369] ? rw_verify_area (fs/read_write.c:406 (discriminator 4))
[ 1567.774369] vfs_write (fs/read_write.c:539)
[ 1567.774369] SyS_write (fs/read_write.c:586 fs/read_write.c:577)
[ 1567.774369] ? SyS_read (fs/read_write.c:577)
[ 1567.774369] ? __this_cpu_preempt_check (lib/smp_processor_id.c:63)
[ 1567.774369] ? trace_hardirqs_on_caller (kernel/locking/lockdep.c:2594 kernel/locking/lockdep.c:2636)
[ 1567.774369] ? trace_hardirqs_on_thunk (arch/x86/lib/thunk_64.S:42)
[ 1567.774369] system_call_fastpath (arch/x86/kernel/entry_64.S:261)
Fixes: 79930f5892e ("net: do not deplete pfmemalloc reserve")
Reported-by: Sasha Levin <sasha.levin@oracle.com>
commit 33692f27597fcab536d7cbbcc8f52905133e4aa7 upstream.
The core VM already knows about VM_FAULT_SIGBUS, but cannot return a
"you should SIGSEGV" error, because the SIGSEGV case was generally
handled by the caller - usually the architecture fault handler.
That results in lots of duplication - all the architecture fault
handlers end up doing very similar "look up vma, check permissions, do
retries etc" - but it generally works. However, there are cases where
the VM actually wants to SIGSEGV, and applications _expect_ SIGSEGV.
In particular, when accessing the stack guard page, libsigsegv expects a
SIGSEGV. And it usually got one, because the stack growth is handled by
that duplicated architecture fault handler.
However, when the generic VM layer started propagating the error return
from the stack expansion in commit fee7e49d4514 ("mm: propagate error
from stack expansion even for guard page"), that now exposed the
existing VM_FAULT_SIGBUS result to user space. And user space really
expected SIGSEGV, not SIGBUS.
To fix that case, we need to add a VM_FAULT_SIGSEGV, and teach all those
duplicate architecture fault handlers about it. They all already have
the code to handle SIGSEGV, so it's about just tying that new return
value to the existing code, but it's all a bit annoying.
This is the mindless minimal patch to do this. A more extensive patch
would be to try to gather up the mostly shared fault handling logic into
one generic helper routine, and long-term we really should do that
cleanup.
Just from this patch, you can generally see that most architectures just
copied (directly or indirectly) the old x86 way of doing things, but in
the meantime that original x86 model has been improved to hold the VM
semaphore for shorter times etc and to handle VM_FAULT_RETRY and other
"newer" things, so it would be a good idea to bring all those
improvements to the generic case and teach other architectures about
them too.
Reported-and-tested-by: Takashi Iwai <tiwai@suse.de>
Tested-by: Jan Engelhardt <jengelh@inai.de>
Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com> # "s390 still compiles and boots"
Cc: stable@vger.kernel.org
[shengyong: Backport to 3.14
- adjust context
- ignore modification for arch nios2, because 3.14 does not support it
- add SIGSEGV handling to powerpc/cell spu_fault.c, because 3.14 does not
separate it to copro_fault.c
- add SIGSEGV handling to mm/memory.c, because 3.14 does not separate it
to gup.c
Signed-off-by: Sheng Yong <shengyong1@huawei.com>
commit 80e0b6e8a001361316a2d62b748fe677ec46b860 upstream.
We accidentally declared pid_alive without any extern/inline connotation.
Some platforms were fine with this, some like ia64 and mips were very angry.
If the function is inline, the prototype should be inline!
on ia64:
include/linux/sched.h:1718: warning: 'pid_alive' declared inline after
being called
Signed-off-by: Richard Guy Briggs <rgb@redhat.com>
Signed-off-by: Eric Paris <eparis@redhat.com>
Signed-off-by: hujianyang <hujianyang@huawei.com>
commit 946e51f2bf37f1656916eb75bd0742ba33983c28 upstream.
move d_rcu from overlapping d_child to overlapping d_alias
Cc: Ben Hutchings <ben@decadent.org.uk>
[hujianyang: Backported to 3.14 refer to the work of Ben Hutchings in 3.2:
- Apply name changes in all the different places we use d_alias and d_child
- Move the WARN_ON() in __d_free() to d_free() as we don't have dentry_free()]
[ Upstream commit f60e5990d9c1424af9dbca60a23ba2a1c7c1ce90 ]
We should not consult skb->sk for output decisions in xmit recursion
levels > 0 in the stack. Otherwise local socket settings could influence
the result of e.g. tunnel encapsulation process.
ipv6 does not conform with this in three places:
1) ip6_fragment: we do consult ipv6_npinfo for frag_size
2) sk_mc_loop in ipv6 uses skb->sk and checks if we should
loop the packet back to the local socket
3) ip6_skb_dst_mtu could query the settings from the user socket and
force a wrong MTU
Furthermore:
In sk_mc_loop we could potentially land in WARN_ON(1) if we use a
PF_PACKET socket ontop of an IPv6-backed vxlan device.
Reuse xmit_recursion as we are currently only interested in protecting
tunnel devices.
Cc: Jiri Pirko <jiri@resnulli.us>
commit d75e4af14e228bbe3f86e29bcecb8e6be98d4e04 upstream.
Thomas Schlichter reports the following issue on his Samsung NC20:
"The C-states C1 and C2 to the OS when connected to AC, and additionally
provides the C3 C-state when disconnected from AC. However, the number
of C-states shown in sysfs is fixed to the number of C-states present
at boot.
If I boot with AC connected, I always only see the C-states up to C2
even if I disconnect AC.
The reason is commit 130a5f692425 (ACPI / cpuidle: remove dev->state_count
setting). It removes the update of dev->state_count, but sysfs uses
exactly this variable to show the C-states.
The fix is to use drv->state_count in sysfs. As this is currently the
last user of dev->state_count, this variable can be completely removed."
Remove dev->state_count as per the above.
Reported-by: Thomas Schlichter <thomas.schlichter@web.de>
Signed-off-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
Acked-by: Daniel Lezcano <daniel.lezcano@linaro.org>
[ rjw: Changelog ]
commit bba0bdd7ad4713d82338bcd9b72d57e9335a664b upstream.
SCSI transport drivers and SCSI LLDs block a SCSI device if the
transport layer is not operational. This means that in this state
no requests should be processed, even if the REQ_PREEMPT flag has
been set. This patch avoids that a rescan shortly after a cable
pull sporadically triggers the following kernel oops:
BUG: unable to handle kernel paging request at ffffc9001a6bc084
IP: [<ffffffffa04e08f2>] mlx4_ib_post_send+0xd2/0xb30 [mlx4_ib]
Process rescan-scsi-bus (pid: 9241, threadinfo ffff88053484a000, task ffff880534aae100)
Call Trace:
[<ffffffffa0718135>] srp_post_send+0x65/0x70 [ib_srp]
[<ffffffffa071b9df>] srp_queuecommand+0x1cf/0x3e0 [ib_srp]
[<ffffffffa0001ff1>] scsi_dispatch_cmd+0x101/0x280 [scsi_mod]
[<ffffffffa0009ad1>] scsi_request_fn+0x411/0x4d0 [scsi_mod]
[<ffffffff81223b37>] __blk_run_queue+0x27/0x30
[<ffffffff8122a8d2>] blk_execute_rq_nowait+0x82/0x110
[<ffffffff8122a9c2>] blk_execute_rq+0x62/0xf0
[<ffffffffa000b0e8>] scsi_execute+0xe8/0x190 [scsi_mod]
[<ffffffffa000b2f3>] scsi_execute_req+0xa3/0x130 [scsi_mod]
[<ffffffffa000c1aa>] scsi_probe_lun+0x17a/0x450 [scsi_mod]
[<ffffffffa000ce86>] scsi_probe_and_add_lun+0x156/0x480 [scsi_mod]
[<ffffffffa000dc2f>] __scsi_scan_target+0xdf/0x1f0 [scsi_mod]
[<ffffffffa000dfa3>] scsi_scan_host_selected+0x183/0x1c0 [scsi_mod]
[<ffffffffa000edfb>] scsi_scan+0xdb/0xe0 [scsi_mod]
[<ffffffffa000ee13>] store_scan+0x13/0x20 [scsi_mod]
[<ffffffff811c8d9b>] sysfs_write_file+0xcb/0x160
[<ffffffff811589de>] vfs_write+0xce/0x140
[<ffffffff81158b53>] sys_write+0x53/0xa0
[<ffffffff81464592>] system_call_fastpath+0x16/0x1b
[<00007f611c9d9300>] 0x7f611c9d92ff
Reported-by: Max Gurtuvoy <maxg@mellanox.com>
Signed-off-by: Bart Van Assche <bart.vanassche@sandisk.com>
Reviewed-by: Mike Christie <michaelc@cs.wisc.edu>
Signed-off-by: James Bottomley <JBottomley@Odin.com>
PREEMPT_NONE
commit 8603e1b30027f943cc9c1eef2b291d42c3347af1 upstream.
cancel[_delayed]_work_sync() are implemented using
__cancel_work_timer() which grabs the PENDING bit using
try_to_grab_pending() and then flushes the work item with PENDING set
to prevent the on-going execution of the work item from requeueing
itself.
try_to_grab_pending() can always grab PENDING bit without blocking
except when someone else is doing the above flushing during
cancelation. In that case, try_to_grab_pending() returns -ENOENT. In
this case, __cancel_work_timer() currently invokes flush_work(). The
assumption is that the completion of the work item is what the other
canceling task would be waiting for too and thus waiting for the same
condition and retrying should allow forward progress without excessive
busy looping
Unfortunately, this doesn't work if preemption is disabled or the
latter task has real time priority. Let's say task A just got woken
up from flush_work() by the completion of the target work item. If,
before task A starts executing, task B gets scheduled and invokes
__cancel_work_timer() on the same work item, its try_to_grab_pending()
will return -ENOENT as the work item is still being canceled by task A
and flush_work() will also immediately return false as the work item
is no longer executing. This puts task B in a busy loop possibly
preventing task A from executing and clearing the canceling state on
the work item leading to a hang.
task A task B worker
executing work
set work CANCELING
flush_work()
block for work completion
completion, wakes up A
while (forever) {
-ENOENT as work is being canceled
flush_work()
false as work is no longer executing
This patch removes the possible hang by updating __cancel_work_timer()
to explicitly wait for clearing of CANCELING rather than invoking
flush_work() after try_to_grab_pending() fails with -ENOENT.
Link: http://lkml.kernel.org/g/20150206171156.GA8942@axis.com
v3: bit_waitqueue() can't be used for work items defined in vmalloc
area. Switched to custom wake function which matches the target
work item and exclusive wait and wakeup.
v2: v1 used wake_up() on bit_waitqueue() which leads to NULL deref if
the target bit waitqueue has wait_bit_queue's on it. Use
DEFINE_WAIT_BIT() and __wake_up_bit() instead. Reported by Tomeu
Vizoso.
Reported-by: Rabin Vincent <rabin.vincent@axis.com>
Cc: Tomeu Vizoso <tomeu.vizoso@gmail.com>
Tested-by: Jesper Nilsson <jesper.nilsson@axis.com>
Tested-by: Rabin Vincent <rabin.vincent@axis.com>
commit 5efd2ea8c9f4f12916ffc8ba636792ce052f6911 upstream.
the following error pops up during "testusb -a -t 10"
| musb-hdrc musb-hdrc.1.auto: dma_pool_free buffer-128, f134e000/be842000 (bad dma)
hcd_buffer_create() creates a few buffers, the smallest has 32 bytes of
size. ARCH_KMALLOC_MINALIGN is set to 64 bytes. This combo results in
hcd_buffer_alloc() returning memory which is 32 bytes aligned and it
might by identified by buffer_offset() as another buffer. This means the
buffer which is on a 32 byte boundary will not get freed, instead it
tries to free another buffer with the error message.
This patch fixes the issue by creating the smallest DMA buffer with the
size of ARCH_KMALLOC_MINALIGN (or 32 in case ARCH_KMALLOC_MINALIGN is
smaller). This might be 32, 64 or even 128 bytes. The next three pools
will have the size 128, 512 and 2048.
In case the smallest pool is 128 bytes then we have only three pools
instead of four (and zero the first entry in the array).
The last pool size is always 2048 bytes which is the assumed PAGE_SIZE /
2 of 4096. I doubt it makes sense to continue using PAGE_SIZE / 2 where
we would end up with 8KiB buffer in case we have 16KiB pages.
Instead I think it makes sense to have a common size(s) and extend them
if there is need to.
There is a BUILD_BUG_ON() now in case someone has a minalign of more than
128 bytes.
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
commit 6ee8e25fc3e916193bce4ebb43d5439e1e2144ab upstream.
Commit e9fd702a58c4 ("audit: convert audit watches to use fsnotify
instead of inotify") broke handling of renames in audit. Audit code
wants to update inode number of an inode corresponding to watched name
in a directory. When something gets renamed into a directory to a
watched name, inotify previously passed moved inode to audit code
however new fsnotify code passes directory inode where the change
happened. That confuses audit and it starts watching parent directory
instead of a file in a directory.
This can be observed for example by doing:
cd /tmp
touch foo bar
auditctl -w /tmp/foo
touch foo
mv bar foo
touch foo
In audit log we see events like:
type=CONFIG_CHANGE msg=audit(1423563584.155:90): auid=1000 ses=2 op="updated rules" path="/tmp/foo" key=(null) list=4 res=1
type=PATH msg=audit(1423563584.155:91): item=2 name="bar" inode=1046884 dev=08:0 2 mode=0100644 ouid=0 ogid=0 rdev=00:00 nametype=DELETE
type=PATH msg=audit(1423563584.155:91): item=3 name="foo" inode=1046842 dev=08:0 2 mode=0100644 ouid=0 ogid=0 rdev=00:00 nametype=DELETE
type=PATH msg=audit(1423563584.155:91): item=4 name="foo" inode=1046884 dev=08:0 2 mode=0100644 ouid=0 ogid=0 rdev=00:00 nametype=CREATE
and that's it - we see event for the first touch after creating the
audit rule, we see events for rename but we don't see any event for the
last touch. However we start seeing events for unrelated stuff
happening in /tmp.
Fix the problem by passing moved inode as data in the FS_MOVED_FROM and
FS_MOVED_TO events instead of the directory where the change happens.
This doesn't introduce any new problems because noone besides
audit_watch.c cares about the passed value:
fs/notify/fanotify/fanotify.c cares only about FSNOTIFY_EVENT_PATH events.
fs/notify/dnotify/dnotify.c doesn't care about passed 'data' value at all.
fs/notify/inotify/inotify_fsnotify.c uses 'data' only for FSNOTIFY_EVENT_PATH.
kernel/audit_tree.c doesn't care about passed 'data' at all.
kernel/audit_watch.c expects moved inode as 'data'.
Fixes: e9fd702a58c49db ("audit: convert audit watches to use fsnotify instead of inotify")
Cc: Paul Moore <paul@paul-moore.com>
Cc: Eric Paris <eparis@redhat.com>
commit 45f87de57f8fad59302fd263dd81ffa4843b5b24 upstream.
Commit 2457aec63745 ("mm: non-atomically mark page accessed during page
cache allocation where possible") has added a separate parameter for
specifying gfp mask for radix tree allocations.
Not only this is less than optimal from the API point of view because it
is error prone, it is also buggy currently because
grab_cache_page_write_begin is using GFP_KERNEL for radix tree and if
fgp_flags doesn't contain FGP_NOFS (mostly controlled by fs by
AOP_FLAG_NOFS flag) but the mapping_gfp_mask has __GFP_FS cleared then
the radix tree allocation wouldn't obey the restriction and might
recurse into filesystem and cause deadlocks. This is the case for most
filesystems unfortunately because only ext4 and gfs2 are using
AOP_FLAG_NOFS.
Let's simply remove radix_gfp_mask parameter because the allocation
context is same for both page cache and for the radix tree. Just make
sure that the radix tree gets only the sane subset of the mask (e.g. do
not pass __GFP_WRITE).
Long term it is more preferable to convert remaining users of
AOP_FLAG_NOFS to use mapping_gfp_mask instead and simplify this
interface even further.
Reported-by: Dave Chinner <david@fromorbit.com>
commit 4ffeaf3560a52b4a69cc7909873d08c0ef5909d4 upstream.
The fair zone allocation policy round-robins allocations between zones
within a node to avoid age inversion problems during reclaim. If the
first allocation fails, the batch counts are reset and a second attempt
made before entering the slow path.
One assumption made with this scheme is that batches expire at roughly
the same time and the resets each time are justified. This assumption
does not hold when zones reach their low watermark as the batches will
be consumed at uneven rates. Allocation failure due to watermark
depletion result in additional zonelist scans for the reset and another
watermark check before hitting the slowpath.
On UMA, the benefit is negligible -- around 0.25%. On 4-socket NUMA
machine it's variable due to the variability of measuring overhead with
the vmstat changes. The system CPU overhead comparison looks like
3.16.0-rc3 3.16.0-rc3 3.16.0-rc3
vanilla vmstat-v5 lowercost-v5
User 746.94 774.56 802.00
System 65336.22 32847.27 40852.33
Elapsed 27553.52 27415.04 27368.46
However it is worth noting that the overall benchmark still completed
faster and intuitively it makes sense to take as few passes as possible
through the zonelists.
commit 0d5d823ab4e608ec7b52ac4410de4cb74bbe0edd upstream.
zone->pages_scanned is a write-intensive cache line during page reclaim
and it's also updated during page free. Move the counter into vmstat to
take advantage of the per-cpu updates and do not update it in the free
paths unless necessary.
On a small UMA machine running tiobench the difference is marginal. On
a 4-node machine the overhead is more noticable. Note that automatic
NUMA balancing was disabled for this test as otherwise the system CPU
overhead is unpredictable.
vanillarearrange-v5 vmstat-v5
User 746.94 759.78 774.56
System 65336.22 58350.98 32847.27
Elapsed 27553.52 27282.02 27415.04
Note that the overhead reduction will vary depending on where exactly
pages are allocated and freed.
reclaim lines
commit 3484b2de9499df23c4604a513b36f96326ae81ad upstream.
The arrangement of struct zone has changed over time and now it has
reached the point where there is some inappropriate sharing going on.
On x86-64 for example
o The zone->node field is shared with the zone lock and zone->node is
accessed frequently from the page allocator due to the fair zone
allocation policy.
o span_seqlock is almost never used by shares a line with free_area
o Some zone statistics share a cache line with the LRU lock so
reclaim-intensive and allocator-intensive workloads can bounce the cache
line on a stat update
This patch rearranges struct zone to put read-only and read-mostly
fields together and then splits the page allocator intensive fields, the
zone statistics and the page reclaim intensive fields into their own
cache lines. Note that the type of lowmem_reserve changes due to the
watermark calculations being signed and avoiding a signed/unsigned
conversion there.
On the test configuration I used the overall size of struct zone shrunk
by one cache line. On smaller machines, this is not likely to be
noticable. However, on a 4-node NUMA machine running tiobench the
system CPU overhead is reduced by this patch.
vanillarearrange-v5r9
User 746.94 759.78
commit 21bda264f4243f61dfcc485174055f12ad0530b4 upstream.
Commit 71e3aac0724f ("thp: transparent hugepage core") adds
copy_pte_range prototype to huge_mm.h. I'm not sure why (or if) this
function have been used outside of memory.c, but it currently isn't.
This patch makes copy_pte_range() static again.
Signed-off-by: Jerome Marchand <jmarchan@redhat.com>
Acked-by: David Rientjes <rientjes@google.com>
possible
commit 2457aec63745e235bcafb7ef312b182d8682f0fc upstream.
aops->write_begin may allocate a new page and make it visible only to have
mark_page_accessed called almost immediately after. Once the page is
visible the atomic operations are necessary which is noticable overhead
when writing to an in-memory filesystem like tmpfs but should also be
noticable with fast storage. The objective of the patch is to initialse
the accessed information with non-atomic operations before the page is
visible.
The bulk of filesystems directly or indirectly use
grab_cache_page_write_begin or find_or_create_page for the initial
allocation of a page cache page. This patch adds an init_page_accessed()
helper which behaves like the first call to mark_page_accessed() but may
called before the page is visible and can be done non-atomically.
The primary APIs of concern in this care are the following and are used
by most filesystems.
find_get_page
find_lock_page
find_or_create_page
grab_cache_page_nowait
All of them are very similar in detail to the patch creates a core helper
pagecache_get_page() which takes a flags parameter that affects its
behavior such as whether the page should be marked accessed or not. Then
old API is preserved but is basically a thin wrapper around this core
function.
Each of the filesystems are then updated to avoid calling
mark_page_accessed when it is known that the VM interfaces have already
done the job. There is a slight snag in that the timing of the
mark_page_accessed() has now changed so in rare cases it's possible a page
gets to the end of the LRU as PageReferenced where as previously it might
have been repromoted. This is expected to be rare but it's worth the
filesystem people thinking about it in case they see a problem with the
timing change. It is also the case that some filesystems may be marking
pages accessed that previously did not but it makes sense that filesystems
have consistent behaviour in this regard.
The test case used to evaulate this is a simple dd of a large file done
multiple times with the file deleted on each iterations. The size of the
file is 1/10th physical memory to avoid dirty page balancing. In the
async case it will be possible that the workload completes without even
hitting the disk and will have variable results but highlight the impact
of mark_page_accessed for async IO. The sync results are expected to be
more stable. The exception is tmpfs where the normal case is for the "IO"
to not hit the disk.
The test machine was single socket and UMA to avoid any scheduling or NUMA
artifacts. Throughput and wall times are presented for sync IO, only wall
times are shown for async as the granularity reported by dd and the
variability is unsuitable for comparison. As async results were variable
do to writback timings, I'm only reporting the maximum figures. The sync
results were stable enough to make the mean and stddev uninteresting.
The performance results are reported based on a run with no profiling.
Profile data is based on a separate run with oprofile running.
async dd
3.15.0-rc3 3.15.0-rc3
vanilla accessed-v2
ext3 Max elapsed 13.9900 ( 0.00%) 11.5900 ( 17.16%)
tmpfs Max elapsed 0.5100 ( 0.00%) 0.4900 ( 3.92%)
btrfs Max elapsed 12.8100 ( 0.00%) 12.7800 ( 0.23%)
ext4 Max elapsed 18.6000 ( 0.00%) 13.3400 ( 28.28%)
xfs Max elapsed 12.5600 ( 0.00%) 2.0900 ( 83.36%)
The XFS figure is a bit strange as it managed to avoid a worst case by
sheer luck but the average figures looked reasonable.
samples percentage
ext3 86107 0.9783 vmlinux-3.15.0-rc4-vanilla mark_page_accessed
ext3 23833 0.2710 vmlinux-3.15.0-rc4-accessed-v3r25 mark_page_accessed
ext3 5036 0.0573 vmlinux-3.15.0-rc4-accessed-v3r25 init_page_accessed
ext4 64566 0.8961 vmlinux-3.15.0-rc4-vanilla mark_page_accessed
ext4 5322 0.0713 vmlinux-3.15.0-rc4-accessed-v3r25 mark_page_accessed
ext4 2869 0.0384 vmlinux-3.15.0-rc4-accessed-v3r25 init_page_accessed
xfs 62126 1.7675 vmlinux-3.15.0-rc4-vanilla mark_page_accessed
xfs 1904 0.0554 vmlinux-3.15.0-rc4-accessed-v3r25 init_page_accessed
xfs 103 0.0030 vmlinux-3.15.0-rc4-accessed-v3r25 mark_page_accessed
btrfs 10655 0.1338 vmlinux-3.15.0-rc4-vanilla mark_page_accessed
btrfs 2020 0.0273 vmlinux-3.15.0-rc4-accessed-v3r25 init_page_accessed
btrfs 587 0.0079 vmlinux-3.15.0-rc4-accessed-v3r25 mark_page_accessed
tmpfs 59562 3.2628 vmlinux-3.15.0-rc4-vanilla mark_page_accessed
tmpfs 1210 0.0696 vmlinux-3.15.0-rc4-accessed-v3r25 init_page_accessed
tmpfs 94 0.0054 vmlinux-3.15.0-rc4-accessed-v3r25 mark_page_accessed
[akpm@linux-foundation.org: don't run init_page_accessed() against an uninitialised pointer]
Cc: Jan Kara <jack@suse.cz>
Cc: Theodore Ts'o <tytso@mit.edu>
Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
Tested-by: Prabhakar Lad <prabhakar.csengg@gmail.com>
commit 07a427884348d38a6fd56fa4d78249c407196650 upstream.
shmem_getpage_gfp uses an atomic operation to set the SwapBacked field
before it's even added to the LRU or visible. This is unnecessary as what
could it possible race against? Use an unlocked variant.
commit b745bc85f21ea707e4ea1a91948055fa3e72c77b upstream.
cold is a bool, make it one. Make the likely case the "if" part of the
block instead of the else as according to the optimisation manual this is
preferred.
commit dc4b0caff24d9b2918e9f27bc65499ee63187eba upstream.
In the free path we calculate page_to_pfn multiple times. Reduce that.
Acked-by: Vlastimil Babka <vbabka@suse.cz>
commit 7aeb09f9104b760fc53c98cb7d20d06640baf9e6 upstream.
X86 prefers the use of unsigned types for iterators and there is a
tendency to mix whether a signed or unsigned type if used for page order.
This converts a number of sites in mm/page_alloc.c to use unsigned int for
order where possible.
commit 664eeddeef6539247691197c1ac124d4aa872ab6 upstream.
If cpusets are not in use then we still check a global variable on every
page allocation. Use jump labels to avoid the overhead.
commit ea5e9539abf1258f23e725cb9cb25aa74efa29eb upstream.
This patch exposes the jump_label reference count in preparation for the
next patch. cpusets cares about both the jump_label being enabled and how
many users of the cpusets there currently are.
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
commit 2329d3751b082b4fd354f334a88662d72abac52d upstream.
In mm/swap.c, __lru_cache_add() is exported, but actually there are no
users outside this file.
This patch unexports __lru_cache_add(), and makes it static. It also
exports lru_cache_add_file(), as it is use by cifs and fuse, which can
loaded as modules.
Signed-off-by: Jianyu Zhan <nasa4836@gmail.com>
Cc: Minchan Kim <minchan@kernel.org>
Cc: Shaohua Li <shli@kernel.org>
Cc: Bob Liu <bob.liu@oracle.com>
Cc: Seth Jennings <sjenning@linux.vnet.ibm.com>
Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Cc: Rafael Aquini <aquini@redhat.com>
Cc: Khalid Aziz <khalid.aziz@oracle.com>
Reviewed-by: Zhang Yanfei <zhangyanfei@cn.fujitsu.com>
commit 5d26a105b5a73e5635eae0629b42fa0a90e07b7b upstream.
This prefixes all crypto module loading with "crypto-" so we never run
the risk of exposing module auto-loading to userspace via a crypto API,
as demonstrated by Mathias Krause:
https://lkml.org/lkml/2013/3/4/70
commit 6ada1fc0e1c4775de0e043e1bd3ae9d065491aa5 upstream.
An unvalidated user input is multiplied by a constant, which can result in
an undefined behaviour for large values. While this is validated later,
we should avoid triggering undefined behaviour.
[jstultz: include trivial milisecond->microsecond correction noticed
by Andy]
Signed-off-by: John Stultz <john.stultz@linaro.org>
commit f331a859e0ee5a898c1f47596eddad4c4f02d657 upstream.
Enable a mechanism for devices to quirk that they do not behave when
doing a PCI bus reset. We require a modest level of spec compliant
behavior in order to do a reset, for instance the device should come
out of reset without throwing errors and PCI config space should be
accessible after reset. This is too much to ask for some devices.
Link: http://lkml.kernel.org/r/20140923210318.498dacbd@dualc.maya.org
Signed-off-by: Alex Williamson <alex.williamson@redhat.com>
Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
commit c291ee622165cb2c8d4e7af63fffd499354a23be upstream.
Since the rework of the sparse interrupt code to actually free the
unused interrupt descriptors there exists a race between the /proc
interfaces to the irq subsystem and the code which frees the interrupt
descriptor.
CPU0 CPU1
show_interrupts()
desc = irq_to_desc(X);
free_desc(desc)
remove_from_radix_tree();
kfree(desc);
raw_spinlock_irq(&desc->lock);
/proc/interrupts is the only interface which can actively corrupt
kernel memory via the lock access. /proc/stat can only read from freed
memory. Extremly hard to trigger, but possible.
The interfaces in /proc/irq/N/ are not affected by this because the
removal of the proc file is serialized in procfs against concurrent
readers/writers. The removal happens before the descriptor is freed.
For architectures which have CONFIG_SPARSE_IRQ=n this is a non issue
as the descriptor is never freed. It's merely cleared out with the irq
descriptor lock held. So any concurrent proc access will either see
the old correct value or the cleared out ones.
Protect the lookup and access to the irq descriptor in
show_interrupts() with the sparse_irq_lock.
Provide kstat_irqs_usr() which is protecting the lookup and access
with sparse_irq_lock and switch /proc/stat to use it.
Document the existing kstat_irqs interfaces so it's clear that the
caller needs to take care about protection. The users of these
interfaces are either not affected due to SPARSE_IRQ=n or already
protected against removal.
Fixes: 1f5a5b87f78f "genirq: Implement a sane sparse_irq allocator"
commit fee7e49d45149fba60156f5b59014f764d3e3728 upstream.
Jay Foad reports that the address sanitizer test (asan) sometimes gets
confused by a stack pointer that ends up being outside the stack vma
that is reported by /proc/maps.
This happens due to an interaction between RLIMIT_STACK and the guard
page: when we do the guard page check, we ignore the potential error
from the stack expansion, which effectively results in a missing guard
page, since the expected stack expansion won't have been done.
And since /proc/maps explicitly ignores the guard page (commit
d7824370e263: "mm: fix up some user-visible effects of the stack guard
page"), the stack pointer ends up being outside the reported stack area.
This is the minimal patch: it just propagates the error. It also
effectively makes the guard page part of the stack limit, which in turn
measn that the actual real stack is one page less than the stack limit.
Let's see if anybody notices. We could teach acct_stack_growth() to
allow an extra page for a grow-up/grow-down stack in the rlimit test,
but I don't want to add more complexity if it isn't needed.
Reported-and-tested-by: Jay Foad <jay.foad@gmail.com>
commit 027bc8b08242c59e19356b4b2c189f2d849ab660 upstream.
On some ARMs the memory can be mapped pgprot_noncached() and still
be working for atomic operations. As pointed out by Colin Cross
<ccross@android.com>, in some cases you do want to use
pgprot_noncached() if the SoC supports it to see a debug printk
just before a write hanging the system.
On ARMs, the atomic operations on strongly ordered memory are
implementation defined. So let's provide an optional kernel parameter
for configuring pgprot_noncached(), and use pgprot_writecombine() by
default.
Cc: Rob Herring <robherring2@gmail.com>
Cc: Randy Dunlap <rdunlap@infradead.org>
Cc: Anton Vorontsov <anton@enomsg.org>
Cc: Colin Cross <ccross@android.com>
Cc: Olof Johansson <olof@lixom.net>
Signed-off-by: Tony Luck <tony.luck@intel.com>
commit 041d7b98ffe59c59fdd639931dea7d74f9aa9a59 upstream.
A regression was caused by commit 780a7654cee8:
audit: Make testing for a valid loginuid explicit.
(which in turn attempted to fix a regression caused by e1760bd)
When audit_krule_to_data() fills in the rules to get a listing, there was a
missing clause to convert back from AUDIT_LOGINUID_SET to AUDIT_LOGINUID.
This broke userspace by not returning the same information that was sent and
expected.
The rule:
auditctl -a exit,never -F auid=-1
gives:
auditctl -l
LIST_RULES: exit,never f24=0 syscall=all
when it should give:
LIST_RULES: exit,never auid=-1 (0xffffffff) syscall=all
Tag it so that it is reported the same way it was set. Create a new
private flags audit_krule field (pflags) to store it that won't interact with
the public one from the API.
Signed-off-by: Paul Moore <pmoore@redhat.com>
commit 9cc46516ddf497ea16e8d7cb986ae03a0f6b92f8 upstream.
- Expose the knob to user space through a proc file /proc/<pid>/setgroups
A value of "deny" means the setgroups system call is disabled in the
current processes user namespace and can not be enabled in the
future in this user namespace.
A value of "allow" means the segtoups system call is enabled.
- Descendant user namespaces inherit the value of setgroups from
their parents.
- A proc file is used (instead of a sysctl) as sysctls currently do
not allow checking the permissions at open time.
- Writing to the proc file is restricted to before the gid_map
for the user namespace is set.
This ensures that disabling setgroups at a user namespace
level will never remove the ability to call setgroups
from a process that already has that ability.
A process may opt in to the setgroups disable for itself by
creating, entering and configuring a user namespace or by calling
setns on an existing user namespace with setgroups disabled.
Processes without privileges already can not call setgroups so this
is a noop. Prodcess with privilege become processes without
privilege when entering a user namespace and as with any other path
to dropping privilege they would not have the ability to call
setgroups. So this remains within the bounds of what is possible
without a knob to disable setgroups permanently in a user namespace.
commit 273d2c67c3e179adb1e74f403d1e9a06e3f841b5 upstream.
setgroups is unique in not needing a valid mapping before it can be called,
in the case of setgroups(0, NULL) which drops all supplemental groups.
The design of the user namespace assumes that CAP_SETGID can not actually
be used until a gid mapping is established. Therefore add a helper function
to see if the user namespace gid mapping has been established and call
that function in the setgroups permission check.
This is part of the fix for CVE-2014-8989, being able to drop groups
without privilege using user namespaces.
Reviewed-by: Andy Lutomirski <luto@amacapital.net>
commit 7ff4d90b4c24a03666f296c3d4878cd39001e81e upstream.
Today there are 3 instances of setgroups and due to an oversight their
permission checking has diverged. Add a common function so that
they may all share the same permission checking code.
This corrects the current oversight in the current permission checks
and adds a helper to avoid this in the future.
A user namespace security fix will update this new helper, shortly.
commit 00b4d9a14125f1e51874def2b9de6092e007412d upstream.
On some 32 bits architectures, including x86, GENMASK(31, 0) returns 0
instead of the expected ~0UL.
This is the same on some 64 bits architectures with GENMASK_ULL(63, 0).
This is due to an overflow in the shift operand, 1 << 32 for GENMASK,
1 << 64 for GENMASK_ULL.
Reported-by: Eric Paire <eric.paire@st.com>
Suggested-by: Rasmus Villemoes <linux@rasmusvillemoes.dk>
Signed-off-by: Maxime Coquelin <maxime.coquelin@st.com>
Cc: linux@rasmusvillemoes.dk
Cc: gong.chen@linux.intel.com
Cc: John Sullivan <jsrhbz@kanargh.force9.co.uk>
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Fixes: 10ef6b0dffe4 ("bitops: Introduce a more generic BITMASK macro")
Link: http://lkml.kernel.org/r/1415267659-10563-1-git-send-email-maxime.coquelin@st.com
commit ccf54555da9a5e91e454b909ca6a5303c7d6b910 upstream.
The direction field is set on 7 bits, thus we need to AND it with 0111 111 mask
in order to retrieve it, that is 0x7F, not 0xCF as it is now.
Fixes: ade7ef7ba (staging:iio: Differential channel handling)
Signed-off-by: Cristina Ciocan <cristina.ciocan@intel.com>
Signed-off-by: Jonathan Cameron <jic23@kernel.org>
commit f144d1496b47e7450f41b767d0d91c724c2198bc upstream.
This can be set by quirks/drivers to be used by the architecture code
that assigns the MSI addresses.
We additionally add verification in the core MSI code that the values
assigned by the architecture do satisfy the limitation in order to fail
gracefully if they don't (ie. the arch hasn't been updated to deal with
that quirk yet).
Acked-by: Bjorn Helgaas <bhelgaas@google.com>
[ Upstream commit 84bc88688e3f6ef843aa8803dbcd90168bb89faf ]
There could be a signed overflow in the following code.
The expression, (32-logmask) is comprised between 0 and 31 included.
It may be equal to 31.
In such a case the left shift will produce a signed integer overflow.
According to the C99 Standard, this is an undefined behavior.
A simple fix is to replace the signed int 1 with the unsigned int 1U.
Signed-off-by: Vincent BENAYOUN <vincent.benayoun@trust-in-soft.com>
commit e0b9daeb453e602a95ea43853dc12d385558ce1f upstream.
We're going to want to manipulate the migration mode for compaction in the
page allocator, and currently compact_control's sync field is only a bool.
Currently, we only do MIGRATE_ASYNC or MIGRATE_SYNC_LIGHT compaction
depending on the value of this bool. Convert the bool to enum
migrate_mode and pass the migration mode in directly. Later, we'll want
to avoid MIGRATE_SYNC_LIGHT for thp allocations in the pagefault patch to
avoid unnecessary latency.
This also alters compaction triggered from sysfs, either for the entire
system or for a node, to force MIGRATE_SYNC.
[akpm@linux-foundation.org: fix build]
[iamjoonsoo.kim@lge.com: use MIGRATE_SYNC in alloc_contig_range()]
Signed-off-by: David Rientjes <rientjes@google.com>
Suggested-by: Mel Gorman <mgorman@suse.de>
Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com>
commit 35979ef3393110ff3c12c6b94552208d3bdf1a36 upstream.
Each zone has a cached migration scanner pfn for memory compaction so that
subsequent calls to memory compaction can start where the previous call
left off.
Currently, the compaction migration scanner only updates the per-zone
cached pfn when pageblocks were not skipped for async compaction. This
creates a dependency on calling sync compaction to avoid having subsequent
calls to async compaction from scanning an enormous amount of non-MOVABLE
pageblocks each time it is called. On large machines, this could be
potentially very expensive.
This patch adds a per-zone cached migration scanner pfn only for async
compaction. It is updated everytime a pageblock has been scanned in its
entirety and when no pages from it were successfully isolated. The cached
migration scanner pfn for sync compaction is updated only when called for
sync compaction.
Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
commit 68711a746345c44ae00c64d8dbac6a9ce13ac54a upstream.
Memory migration uses a callback defined by the caller to determine how to
allocate destination pages. When migration fails for a source page,
however, it frees the destination page back to the system.
This patch adds a memory migration callback defined by the caller to
determine how to free destination pages. If a caller, such as memory
compaction, builds its own freelist for migration targets, this can reuse
already freed memory instead of scanning additional memory.
If the caller provides a function to handle freeing of destination pages,
it is called when page migration fails. If the caller passes NULL then
freeing back to the system will be handled as usual. This patch
introduces no functional change.
commit 29f175d125f0f3a9503af8a5596f93d714cceb08 upstream.
Commit f9acc8c7b35a ("readahead: sanify file_ra_state names") left
ra_submit with a single function call.
Move ra_submit to internal.h and inline it to save some stack. Thanks
to Andrew Morton for commenting different versions.
Signed-off-by: Fabian Frederick <fabf@skynet.be>
Suggested-by: Andrew Morton <akpm@linux-foundation.org>
commit 67f9fd91f93c582b7de2ab9325b6e179db77e4d5 upstream.
This patch removes read_cache_page_async() which wasn't really needed
anywhere and simplifies the code around it a bit.
read_cache_page_async() is useful when we want to read a page into the
cache without waiting for it to complete. This happens when the
appropriate callback 'filler' doesn't complete its read operation and
releases the page lock immediately, and instead queues a different
completion routine to do that. This never actually happened anywhere in
the code.
read_cache_page_async() had 3 different callers:
- read_cache_page() which is the sync version, it would just wait for
the requested read to complete using wait_on_page_read().
- JFFS2 would call it from jffs2_gc_fetch_page(), but the filler
function it supplied doesn't do any async reads, and would complete
before the filler function returns - making it actually a sync read.
- CRAMFS would call it using the read_mapping_page_async() wrapper, with
a similar story to JFFS2 - the filler function doesn't do anything that
reminds async reads and would always complete before the filler function
returns.
To sum it up, the code in mm/filemap.c never took advantage of having
read_cache_page_async(). While there are filler callbacks that do async
reads (such as the block one), we always called it with the
read_cache_page().
This patch adds a mandatory wait for read to complete when adding a new
page to the cache, and removes read_cache_page_async() and its wrappers.
commit 0cd6144aadd2afd19d1aca880153530c52957604 upstream.
shmem mappings already contain exceptional entries where swap slot
information is remembered.
To be able to store eviction information for regular page cache, prepare
every site dealing with the radix trees directly to handle entries other
than pages.
The common lookup functions will filter out non-page entries and return
NULL for page cache holes, just as before. But provide a raw version of
the API which returns non-page entries as well, and switch shmem over to
use it.
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Reviewed-by: Minchan Kim <minchan@kernel.org>
Cc: Luigi Semenzato <semenzato@google.com>
Cc: Metin Doslu <metin@citusdata.com>
Cc: Michel Lespinasse <walken@google.com>
Cc: Ozgun Erdogan <ozgun@citusdata.com>
Cc: Roman Gushchin <klamm@yandex-team.ru>
Cc: Ryan Mallon <rmallon@gmail.com>
Cc: Tejun Heo <tj@kernel.org>
commit e7b563bb2a6f4d974208da46200784b9c5b5a47e upstream.
The radix tree hole searching code is only used for page cache, for
example the readahead code trying to get a a picture of the area
surrounding a fault.
It sufficed to rely on the radix tree definition of holes, which is
"empty tree slot". But this is about to change, though, as shadow page
descriptors will be stored in the page cache after the actual pages get
evicted from memory.
Move the functions over to mm/filemap.c and make them native page cache
operations, where they can later be adapted to handle the new definition
of "page cache hole".
commit 53c59f262d747ea82e7414774c59a489501186a0 upstream.
Provide a function that does not just delete an entry at a given index,
but also allows passing in an expected item. Delete only if that item
is still located at the specified index.
This is handy when lockless tree traversals want to delete entries as
well because they don't have to do an second, locked lookup to verify
the slot has not changed under them before deleting the entry.
commit 96a2adbc6f501996418da9f7afe39bf0e4d006a9 upstream.
kernel/time/jiffies.c provides a default clocksource_default_clock()
definition explicitly marked "weak". arch/s390 provides its own definition
intended to override the default, but the "weak" attribute on the
declaration applied to the s390 definition as well, so the linker chose one
based on link order (see 10629d711ed7 ("PCI: Remove __weak annotation from
pcibios_get_phb_of_node decl")).
Remove the "weak" attribute from the clocksource_default_clock()
declaration so we always prefer a non-weak definition over the weak one,
independent of link order.
Fixes: f1b82746c1e9 ("clocksource: Cleanup clocksource selection")
Acked-by: John Stultz <john.stultz@linaro.org>
Acked-by: Ingo Molnar <mingo@kernel.org>
CC: Daniel Lezcano <daniel.lezcano@linaro.org>
CC: Martin Schwidefsky <schwidefsky@de.ibm.com>
commit 107bcc6d566cb40184068d888637f9aefe6252dd upstream.
kernel/debug/debug_core.c provides a default kgdb_arch_pc() definition
explicitly marked "weak". Several architectures provide their own
definitions intended to override the default, but the "weak" attribute on
the declaration applied to the arch definitions as well, so the linker
chose one based on link order (see 10629d711ed7 ("PCI: Remove __weak
annotation from pcibios_get_phb_of_node decl")).
Remove the "weak" attribute from the declaration so we always prefer a
non-weak definition over the weak one, independent of link order.
Fixes: 688b744d8bc8 ("kgdb: fix signedness mixmatches, add statics, add declaration to header")
Tested-by: Vineet Gupta <vgupta@synopsys.com> # for ARC build
Reviewed-by: Harvey Harrison <harvey.harrison@gmail.com>
commit 5ab03ac5aaa1f032e071f1b3dc433b7839359c03 upstream.
For the following functions:
elfcorehdr_alloc()
elfcorehdr_free()
elfcorehdr_read()
elfcorehdr_read_notes()
remap_oldmem_pfn_range()
fs/proc/vmcore.c provides default definitions explicitly marked "weak".
arch/s390 provides its own definitions intended to override the default
ones, but the "weak" attribute on the declarations applied to the s390
definitions as well, so the linker chose one based on link order (see
10629d711ed7 ("PCI: Remove __weak annotation from pcibios_get_phb_of_node
decl")).
Remove the "weak" attribute from the declarations so we always prefer a
Fixes: be8a8d069e50 ("vmcore: introduce ELF header in new memory feature")
Fixes: 9cb218131de1 ("vmcore: introduce remap_oldmem_pfn_range()")
Acked-by: Andrew Morton <akpm@linux-foundation.org>
Acked-by: Vivek Goyal <vgoyal@redhat.com>
CC: Michael Holzheu <holzheu@linux.vnet.ibm.com>
commit e0a8400c6923a163265d52798cdd4c33f3f8ab5a upstream.
drivers/base/memory.c provides a default memory_block_size_bytes()
definition explicitly marked "weak". Several architectures provide their
own definitions intended to override the default, but the "weak" attribute
on the declaration applied to the arch definitions as well, so the linker
Fixes: 41f107266b19 ("drivers: base: Add prototype declaration to the header file")
CC: Rashika Kheria <rashika.kheria@gmail.com>
CC: Nathan Fontenot <nfont@austin.ibm.com>
CC: Anton Blanchard <anton@au1.ibm.com>
CC: Heiko Carstens <heiko.carstens@de.ibm.com>
CC: Yinghai Lu <yinghai@kernel.org>
