path: root/include/media/ir-common.h
2008-04-24V4L/DVB (7677): saa7134: Add/fix Beholder entriesDmitry Belimov
Beholder TV/FM tuners: Changes: Add support Beholder Columbus PCMCIA card. Add key map for remote control of Beholder Columbus PCMCIA card. Fix gpiomask for all Beholder tuners. Signed-off-by: Beholder Intl. Ltd. Dmitry Belimov <d.belimov@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7506): Powercolor Real Angel 330 (remote control support)Dâniel Fraga
The attached patch adds complete remote control support for Powercolor Real Angel 330. Signed-off-by: Daniel Fraga <fragabr@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7372): cx88: Add IR support for Pixelview MPEG 8000GTMauro Carvalho Chehab
2008-02-18V4L/DVB (7192): Adds support for Genius TVGo A11MCEAdrian Pardini
Signed-off-by: Adrian Pardini <pardo.bsso@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-01-25V4L/DVB (7058): IR corrections for the Pinnacle 800iSteven Toth
IR corrections for the Pinnacle 800i Signed-off-by: Steven Toth <stoth@hauppauge.com> Signed-off-by: Chaogui Zhang <czhang1974@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-01-25V4L/DVB (6973): Add Beholder TV 401/405/407/409/505/507/609/M6 supportAndrey J. Melnikoff (TEMHOTA)
This patch updates cardlist for Beholder TV tuners: old models (with GPIO ir) 401, 403, 405, 407, 409, 505, 507 and add support for 607, 609, M6 cards with new i2c-ir. Signed-off-by: Igor Kuznetsov <igk72@yandex.ru> Signed-off-by: Andrey J. Melnikov <temnota@kmv.ru> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-01-25V4L/DVB (6574): common/ir-functions.c: make a function staticAdrian Bunk
ir_rc5_decode() can become static. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-09V4L/DVB (6179): Clean up FusionHDTV ir codeMichael Krufky
- fixed missing buttons in keymap. - make function names & descriptions more generic, since this same ir receiver and remote is used in many FusionHDTV products. - miscellaneous cleanups. Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-09V4L/DVB (6178): add IR remote support for FusionHDTV 5 RT GoldChaogui Zhang
This patch adds support for the built-in IR receiver of the DViCO Fusion HDTV5 RT GOLD PCI card, using FusionHDTV MCE remote controller. Signed-off-by: Chaogui Zhang <czhang1974@gmail.com> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-02-21V4L/DVB (5070): Budget-ci: add support for the Technotrend 1500 bundled remoteVille-Pekka Vainio
The keymap is based on a previous patch by Jussi Kukkonen. This remote is identified by subsystem_device id 0x1010. Signed-off-by: Ville-Pekka Vainio <vpivaini@cs.helsinki.fi> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-02-21V4L/DVB (5017): DVB: fix compile errorAdrian Bunk
This patch fixes the following compile error: <-- snip --> ... LD drivers/media/video/built-in.o drivers/media/video/saa7134/built-in.o:(.data+0x85ec): multiple definition of `ir_rc5_remote_gap' drivers/media/video/bt8xx/built-in.o:(.data+0x734c): first defined here drivers/media/video/saa7134/built-in.o:(.data+0x85f0): multiple definition of `ir_rc5_key_timeout' drivers/media/video/bt8xx/built-in.o:(.data+0x7350): first defined here make[4]: *** [drivers/media/video/built-in.o] Error 1 <-- snip --> Since this variables were needlessly global, this patch implements the trivial fix of making them static. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-02-21V4L/DVB (5015): Add support for more Encore TV cardsJuan Pablo Sormani
Signed-off-by: Juan Pablo Sormani <sorman@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-02-21V4L/DVB (4961): Add support for the ASUS P7131 remote controlHermann Pitton
Besides adding the board specific code, this patch moves the RC5 decoding code from bt8xx to ir-functions.c to make it available for all drivers. Signed-off-by: Marc Fargas <telenieko.telenieko.com> Signed-off-by: Hermann Pitton <hermann-pitton@arcor.de> Signed-off-by: Hartmut Hackmann <hartmut.hackmann@t-online.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-12-27V4L/DVB (5001): Add two required headers on kernel 2.6.20-rc1Mauro Carvalho Chehab
include/media/ir-common.h:78: error: field 'work' has incomplete type drivers/media/common/ir-functions.c: In function 'ir_rc5_timer_end': drivers/media/common/ir-functions.c:301: error: 'jiffies' undeclared (first use in this function) drivers/media/common/ir-functions.c:301: error: (Each undeclared identifier is reported only once) drivers/media/common/ir-functions.c:301: error: for each function it appears in.) drivers/media/common/ir-functions.c:347: error: 'HZ' undeclared (first use in this function) Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-12-10V4L/DVB (4879): budget-ci IR: integrate with ir-commonDavid Hardeman
This converts the budget-ci driver so that it uses ir-common for some of its IR processing. In particular, the keymap for the Nova-T (sub 13c2:1011) is switched to the Hauppauge grey/black keymap, of which the keys on the supplied R808 remote control form a subset. The old budget-ci keymap is moved to ir-keymaps.c and is used for other remotes. The debounce logic for buggy remotes (i.e. Zenith) is made conditional the new debounce parameter and defaults to off (so that repeat keypresses aren't ignored for all working remotes). Some parts are based on Darren Salt's dvb-ir patchset. Signed-off-by: David Hardeman <david@hardeman.nu> Signed-off-by: Andrew de Quincey <adq_dvb@lidskialf.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-09-26V4L/DVB (4629): Saa7134: add card support for Proteus Pro 2309Michal Majchrowicz
Add card support for Proteus Pro 2309, based on saa7130 bridge Signed-off-by: Michal Majchrowicz <mmajchrowicz@gmail.com> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-09-26V4L/DVB (4361): Cx88: add support for Norwood PCI TV Tuner (non-pro)Peter Naulls
This patch adds support for Norwood PCI TV Tuner (non-pro) Signed-off-by: Peter Naulls <peter@chocky.org> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-06-25V4L/DVB (4038): New cx88 card #50: NPG Tech RealTVRicardo Cerqueira
Added support for a new cx88 card, including it's remote Signed-off-by: Ricardo Cerqueira <v4l@cerqueira.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-06-25V4L/DVB (4023): Subject: Pinnacle PCTV grey remote control supportSylvain Pasche
This adds support for the older (?) Pinnacle PCTV remotes (with all buttons colored in grey). There's no autodetection for the type of remote, though; saa7134 defaults to the colored one, to use the grey remote the "pinnacle_remote=1" option must be passed to the saa7134 module Signed-off-by: Sylvain Pasche <sylvain.pasche@gmail.com> Signed-off-by: Ricardo Cerqueira <v4l@cerqueira.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-01-23V4L/DVB (3400): Remove duplicated keymaps and add keymap for KWorld LTV883IR.Nickolay V. Shmyrev
- Remove duplicated keymaps and add keymap for KWorld LTV883IR. Thanks to Jon Ferguson <jon@sd-6.org>. Signed-off-by: Nickolay V. Shmyrev <nshmyrev@yandex.ru> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-01-23V4L/DVB (3393): Move all IR keymaps to ir-common moduleRicardo Cerqueira
- All the keymaps have the same structure, and can be shared between different chips, so it makes no sense having them scattered between the input files. This aggregates them all at ir-common module. - Added new Hauppauge remote (Hauppauge grey), contributed by J.O. Aho <trizt@iname.com> (with some small changes) Changed KEY_KPx (keypad numerals) references to KEY_x, to avoid problems when NumLock is off (suggested by Peter Missel <peter.missel@onlinehome.de>) - Some cleanups at IR code Signed-off-by: Ricardo Cerqueira <v4l@cerqueira.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2005-11-13[PATCH] v4l: (935) Moved common IR stuff to ir-common.cRicardo Cerqueira
- The pinnacle handler & remote are common to saa7134 PCI boards and em28xx USB boards, so the keymap was moved to ir-common and the keyhandler is back to ir-kbd-i2c - request_module("ir-kbd-i2c") is no longer necessary at saa7134-core since saa7134.ko now depends on ir-kbd-i2c.ko to get the keyhandler Signed-off-by: Ricardo Cerqueira <v4l@cerqueira.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] v4l: 784: several improvement on i2c ir handling for em2820Mauro Carvalho Chehab
- Several Improvement on I2C IR handling for em2820: - moved Pinnacle IR table (ir_codes_em2820) to em2820-input.c - IR struct renamed and moved to a header file. - New file to handle em2820-specific IR. - Some cleanups. - attach now detects I2C IR and calls em2820-specific IR code - IR compat code moved to compat.h - New header with struct IR_i2c there, to allow it to be used by board-specific input handlers. - Some improvements at em28xx board detection: - Board detection message improved to show interface and class. - Now it doesn't touch audio interfaces. Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] v4l: common part Updates and tuner additionsMauro Carvalho Chehab
- Remove $Id CVS logs for V4L files - Included newer cards. - Added a new NEC protocol for ir based on pulse distance. - Enable ATSC support for DViCO FusionHDTV5 Gold. - Added tuner LG NTSC (TALN mini series). - Fixed tea5767 autodetection. - Resolve more tuner types. - Commented debug function removed from mainstream. - Remove comments from mainstream. Still on development tree. - linux/version dependencies removed. - BTSC Lang1 now is set to auto_stereo mode. - New tuner standby API. - i2c-core.c uses hexadecimal for the i2c address, so it should stay consistent. Signed-off-by: Uli Luckas <luckas@musoft.de> Signed-off-by: Mac Michaels <wmichaels1@earthlink.net> Signed-off-by: Michael Krufky <mkrufky@m1k.net> Signed-off-by: Hermann Pitton <hermann.pitton@onlinehome.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] v4l: update for tuner cards and some V4L chipsMauro Carvalho Chehab
Tuner improvements and additions. TEA5767 FM tuner added. Several small fixes. Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Nickolay V Shmyrev <nshmyrev@yandex.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] v4l: add support for PixelView Ultra ProManuel Capinha
The following patch adds support for the PixelView Ultra Pro video capture card in v4l. - It removes the remote control key definitions from ir-kbd-gpio.c and moves them to ir-common.c so that they can be shared between bt878 and cx88 based cards. - The patch also moves the FUSIONHDTV_3_GOLD_Q card from number 27 to 28 to regain compatibility with the V4L cvs. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
