path: root/include/media/lirc.h
2015-11-17[media] bz#75751: Move internal header file lirc.h to uapi/Alec Leamas
The file include/media/lirc.h describes a public interface and should thus be a public header. See kernel bug https://bugzilla.kernel.org/show_bug.cgi?id=75751 which has a manpage describing the interface + an acknowledgment that this info belongs to uapi. Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
2010-08-08V4L/DVB: IR: extend interfaces to support more device settingsMaxim Levitsky
LIRC: add new IOCTL that enables learning mode (wide band receiver) Still missing features: carrier report & timeout reports. Will need to pack these into ir_raw_event Signed-off-by: Maxim Levitsky <maximlevitsky@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-08-02V4L/DVB: IR/lirc: make lirc userspace and staging modules buildableJarod Wilson
The lirc userspace needs all the current ioctls defined, and we need to put the header files in places out-of-tree and/or staging lirc drivers (which I plan to prep soon) can easily build with. I've actually tested this in a tree w/all the lirc drivers queued up to be submitted for staging. I'm also reasonably sure that Andy Walls is going to need most of the ioctls anyway for his cx23888 IR driver work. Signed-off-by: Jarod Wilson <jarod@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-08-02V4L/DVB: IR: add lirc device interfaceJarod Wilson
v2: currently unused ioctls are included, but #if 0'd out Signed-off-by: Jarod Wilson <jarod@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
