The ene_ir driver was using a private define of MS_TO_NS, which is meant
to be microseconds to nanoseconds. The mceusb driver copied it,
intending to use is a milliseconds to microseconds. Lets move the
defines to a common location, expand and standardize them a touch, so
that we now have:
MS_TO_NS - milliseconds to nanoseconds
MS_TO_US - milliseconds to microseconds
US_TO_NS - microseconds to nanoseconds
Reported-by: David Härdeman <david@hardeman.nu>
CC: Maxim Levitsky <maximlevitsky@gmail.com>
Signed-off-by: Jarod Wilson <jarod@redhat.com>
Fix some minor comments etc which are leftover from the old naming scheme.
Signed-off-by: David Härdeman <david@hardeman.nu>
The struct that describes a rc mapping had an weird and long name.
We should properly name it, to make easier for developers to work
with it, and to avoid confusion.
Basically, generated by this script:
for i in `find drivers/staging -type f -name *.[ch]` `find include/media -type f -name *.[ch]` `find drivers/media -type f -name *.[ch]`; do sed s,ir_scancode_table,rc_map,g <$i >a && mv a $i; done
for i in `find drivers/staging -type f -name *.[ch]` `find include/media -type f -name *.[ch]` `find drivers/media -type f -name *.[ch]`; do sed s,rc_tab,rc_map,g <$i >a && mv a $i; done
(and manually fixed where needed)
for i in `find drivers/staging -type f -name *.[ch]` `find include/media -type f -name *.[ch]` `find drivers/media -type f -name *.[ch]`; do sed s,IR_TYPE,RC_TYPE,g <$i >a && mv a $i; done
for i in `find drivers/staging -type f -name *.[ch]` `find include/media -type f -name *.[ch]` `find drivers/media -type f -name *.[ch]`; do sed s,ir_type,rc_type,g <$i >a && mv a $i; done
Those functions are not InfraRed specific. So, rename them to properly
reflect it.
The Remote Controller subsystem is meant to be used not only by Infra Red
but also for similar types of Remote Controllers. The core is not specific
to Infra Red. As such, rename:
- ir-core.h to rc-core.h
- IR_CORE to RC_CORE
- namespace inside rc-core.c/rc-core.h
To be consistent with the other changes.
No functional change on this patch.
