path: root/include/media/saa6588.h
2010-12-29[media] saa6588: rename rds.h to saa6588.hHans Verkuil
The naming of the media/rds.h header suggested that it was a generic RDS header, when in fact it is just a saa6588 module API that is internal to the kernel. Rename the header and the struct and defines in it to make this clear. Also removed the header include in radio-si470x.h (not used anymore) and from ioctl-number.txt (it's internal to the kernel and never called from userspace). Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
