path: root/include/media/saa7115.h
2008-10-12V4L/DVB (8940): saa7115: fix saa7111(a) supportHans Verkuil
The saa7111 support in saa7115.c was missing some features and did not properly take some of the differences into account. With this patch saa7115 can be used in the mxb driver instead of saa7111.c. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2007-02-21V4L/DVB (5113): Adds video output routingMarco Schluessler
Nexus CA needs to use a different routing on saa7115 module. Signed-off-by: Marco Schluessler <marco@lordzodiac.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-06-25V4L/DVB (3711): Add support for VIDIOC_INT_S_CRYSTAL_FREQ internal command.Hans Verkuil
Some saa7115-based cards use a different crystal frequency and a different audio clock generation. Add a new VIDIOC_INT_S_CRYSTAL_FREQ command to be able to set these values. Also change the default APLL setting to 0. It makes no sense to have the audio clock independent from the video clock, this can lead to audio/video synchronization problems. Setting this to 0 is also consistent with the old saa7114.c source and the way the Hauppauge Windows driver sets it. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-04-02V4L/DVB (3607): Implement routing command for saa7115.cHans Verkuil
