path: root/include/media/sh_mobile_ceu.h
2010-08-02V4L/DVB: V4L2: sh_mobile_camera_ceu: add support for CSI2Guennadi Liakhovetski
Using CEU with CSI2 on SH-Mobile requires some special configuration of the former. We also have to switch from calling only one subdev .s_mbus_fmt and .try_mbus_fmt to calling all subdevices. Take care to increment CSI2 driver use count to prevent it from unloading, while in use. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-16V4L/DVB (13665): sh_mobile_ceu_camera: Add support for sync polarity selectionKuninori Morimoto
Signed-off-by: Kuninori Morimoto <morimoto.kuninori@renesas.com> Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-30V4L/DVB (10671): sh_mobile_ceu: SOCAM flags are not platform dependentKuninori Morimoto
sh_mobile_ceu_camera.c support for signal polarity flags isn't platform dependent, provide them locally. Only the bus width is implementation specific. Signed-off-by: Kuninori Morimoto <morimoto.kuninori@renesas.com> Acked-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-12V4L/DVB (8687): soc-camera: Move .power and .reset from soc_camera host to ↵Stefan Herbrechtsmeier
sensor driver Make .power and .reset callbacks per camera instead of per host, also move their invocation to camera drivers. .arch/arm/mach-pxa/include/mach/camera.h | 2 - Signed-off-by: Stefan Herbrechtsmeier <hbmeier@hni.uni-paderborn.de> Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-07-20V4L/DVB (8342): sh_mobile_ceu_camera: Add SuperH Mobile CEU driver V3Magnus Damm
This is V3 of the SuperH Mobile CEU soc_camera driver. The CEU hardware block is configured in a transparent data fetch mode, frames are captured from the attached camera and written to physically contiguous memory buffers provided by the newly added videobuf-dma-contig queue. Tested on sh7722 and sh7723 processors. Changes since V2: - remove SUPERH Kconfig dependency - move sh_mobile_ceu.h to include/media - add board callback support with enable_camera()/disable_camera() - add support for declare_coherent_memory - rework video memory limit - more verbose error messages Changes since V1: - fixed the CEU driver to work with the newly updated patches Signed-off-by: Magnus Damm <damm@igel.co.jp> Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@pengutronix.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
