path: root/include/media/soc_mediabus.h
2011-03-22[media] v4l: Move the media/v4l2-mediabus.h header to include/linuxLaurent Pinchart
The header defines the v4l2_mbus_framefmt structure which will be used by the V4L2 subdevs userspace API. Change the type of the v4l2_mbus_framefmt::code field to __u32, as enum sizes can differ between different ABIs on the same architectures. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-03-21[media] V4L: soc_mediabus: add a method to obtain the number of samples per ↵Alberto Panizzo
pixel Add a function to calculate the number of samples on the media-bus, required to retrieve one pixel of a certain format. Signed-off-by: Alberto Panizzo <maramaopercheseimorto@gmail.com> Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-16V4L/DVB (13658): v4l: add a media-bus API for configuring v4l2 subdev pixel ↵Guennadi Liakhovetski
and frame formats Video subdevices, like cameras, decoders, connect to video bridges over specialised busses. Data is being transferred over these busses in various formats, which only loosely correspond to fourcc codes, describing how video data is stored in RAM. This is not a one-to-one correspondence, therefore we cannot use fourcc codes to configure subdevice output data formats. This patch adds codes for several such on-the-bus formats and an API, similar to the familiar .s_fmt(), .g_fmt(), .try_fmt(), .enum_fmt() API for configuring those codes. After all users of the old API in struct v4l2_subdev_video_ops are converted, it will be removed. Also add helper routines to support generic pass-through mode for the soc-camera framework. create mode 100644 drivers/media/video/soc_mediabus.c create mode 100644 include/media/soc_mediabus.h create mode 100644 include/media/v4l2-mediabus.h Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Acked-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
