Modified mxb to load the i2c modules through v4l2_subdev. So no more probing.
Modified tea6415c and tea6420 to use the standard routing ops to do the
routing, rather than using private commands. Dropped the private commands
from tda9840 (they were never used except during initialization of the
module).
Added saa7146 support for VIDIOC_DBG_G_CHIP_IDENT.
Converted saa5246a and saa5249 to v4l2_subdev.
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl>
instead of ID.
Since the i2c driver ID will be removed in the near future we have to
modify the v4l2 debugging API to use the driver name instead of driver ID.
Note that this API is not used in applications other than v4l2-dbg.cpp
as it is for debugging and testing only.
Should anyone use the old VIDIOC_G_CHIP_IDENT, then this will be logged
with a warning that it is deprecated and will be removed in 2.6.30.
Micron
This camera is rather similar to MT9M001, but also has a couple of
enhanced features, like pixel binning.
create mode 100644 drivers/media/video/mt9t031.c
Signed-off-by: Guennadi Liakhovetski <lg@denx.de>
Acked-by: Jean Delvare <khali@linux-fr.org>
This patch adds tw9910 driver that use soc_camera framework.
It was tested on SH Migo-r board and mplayer.
create mode 100644 drivers/media/video/tw9910.c
create mode 100644 include/media/tw9910.h
Signed-off-by: Kuninori Morimoto <morimoto.kuninori@renesas.com>
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
The chip is largely compatible with MT9M111 and is going to be supported by the
same driver.
Signed-off-by: Mike Rapoport <mike@compulab.co.il>
This patch adds ov772x driver that use soc_camera framework.
It was tested on SH Migo-r board.
Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr>
Cleaned up the saa6752hs i2c driver.
Add AC-3 support.
Add VIDIOC_CHIP_IDENT support.
Converted the last users of audiochip.h to the v4l2-chip-ident.h header
and remove the now unused audiochip.h header.
Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
Many thanks to Steve Toth from Hauppauge and Nattu Dakshinamurthy from
Conexant for their support. I am in particular thankful to Hauppauge
since without their help this driver would not exist. It should also
be noted that Steve did the work to get the DVB part up and running.
Thank you!
Signed-off-by: Steven Toth <stoth@hauppauge.com>
Signed-off-by: Michael Krufky <mkrufky@linuxtv.org>
Signed-off-by: G. Andrew Walls <awalls@radix.net>
Add V4L2_IDENT chip IDs for mt9m001 and mt9v022 cameras, will be used by
future patches, primarily to implement the g_chip_ident ioctl.
This driver is used by the ASUS Falcon2 cx23416-based cards.
This device is internal to the Panasonic VP27S tuner and is used to set
the mono/stereo/bilingual setting of the tuner.
It is used by two Japanese cx23416-based cards.
Signed-off-by: Takahiro Adachi <tadachi@tadachi-net.com>
VIDIOC_G_CHIP_IDENT improves debugging of card problems: it can be
used to detect which chips are on the board and based on that information
selected register dumps can be made, making it easy to debug complicated
media chips containing tens or hundreds of registers.
This ioctl replaces the internal VIDIOC_INT_G_CHIP_IDENT ioctl.
