Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
1) This is not allowed by the kernel coding style
2) Just configure your editor correctly
3) It's really ugly
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com>
Acked-by: Sakari Ailus <sakari.ailus@linux.intel.com>
Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
This callback were meant to allow overriding a FE callback, before its
call, but it is not really needed, as the callback can be intercepted
after tuner attachment.
Worse than that, only DVBv3 calls are intercepted this way, so a DVBv5
application will produce different effects than a DVBv3 one.
So, get rid of it.
Acked-by: Antti Palosaari <crope@iki.fi>
Reviewed-by: Antti Palosaari <crope@iki.fi>
Signed-off-by: Hans Petter Selasky <hselasky@c2i.net>
override frontend ioctls
Signed-off-by: Michael Krufky <mkrufky@kernellabs.com>
frontend de-allocator
This creates a self contained frontend de-allocator
for the instances where an adapter has not been
registered yet frontend de-allocation may
be required.
Signed-off-by: Darron Broad <darron@kewl.org>
This patch marks those two functions as static:
static int videobuf_dvb_register_adapter(struct videobuf_dvb_frontends *fe,
static int videobuf_dvb_register_frontend(struct dvb_adapter *adapter,
Since MFE patches changed their calls by videobuf_dvb_register_bus.
To avoid having to declare the prototypes, the patch moves
videobuf_dvb_register_bus() to be after the declaration of the above functions
used there.
Cc: Steven Toth <stoth@linuxtv.org>
To optimise data storage even further one other redundant
var has been removed.
This also removes a redundant assignment.
Signed-off-by: Steven Toth <stoth@linuxtv.org>
To optimise data storage redundant vars are removed.
This add frontend R/W mutual exclusion.
Prior to this point in time it was possible to open both
frontends simultaneously which an MFE card cannot support.
In order to stop this, a delayed open is performed which
has the following function:
- Return EBUSY after a configurable amount of time
if a frontend is unavailable due to the other being
in use.
- Only allow opening of a frontend if the kernel thread
of the other has stopped.
This solution was chosen to allow switching between
frontends to work as seamlessly as possible. When both
frontends are actually opened simultaneously then one
will only open, but if quick switching is performed
between one of many then the new open will succeed in
a clean fashion rather than interrupting a kernel
thread.
This adds a configurable (one per card) gate control option
for multi-frontend. Prior to this point gate control was
assumed to be on the primary frontend, this is a fault
when the gate to the analogue section is on the secondary
which is the default for both the HVR-3000 and HVR-4000
in MFE.
A detailed description from the original patches 2 years ago:
"The WinTV-HVR3000 has a single transport bus which is shared between
a DVB-T and DVB-S modulator. These patches build on the bus acquisition
cx88 work from a few weeks ago to add support for this.
So to applications the HVR3000 looks like this:
/dev/dvb/adapter0/fe0 (cx24123 DVB-S demod)
/dev/dvb/adapter0/fe1 (cx22702 DVB-T demod)
Additional boards continue as before, eg:
/dev/dvb/adapter1/fe0 (lgdt3302 ATSC demod)
The basic change is removing the single instance of the videobuf_dvb in
cx8802_dev and saa7134_dev(?) and replacing it with a list and some
supporting functions.
*NOTE* This branch was taken before v4l-dvb was closed for 2.6.19 so
two or three current cx88 patches appear to be reversed by this tree,
this will be cleaned up in the near future. The patches missing change
the mutex handing to core->lock, fix an enumeration problem."
It should be recognised that a number of people have been maintaining
this patchset. Significant levels of Kudos to everyone one involved,
including but not limited to:
Darron Broad
Fabio M. Di Nitto
Carlo Scarfoglio
Hans Werner
Without the work of these people, and countless others, my two year old
patches would of died on the Mercurial linuxtv.org vine a long time
ago.
TODO: Revise these patches a little further so that the need for
demux1 and dvr0 is optional, not mandatory on the HVR3000.
HISTORY (darron):
This is the last update to MFE prepared by Hans which is based
upon the `scratchpad' diff created by Carlo.
All MFE work prior to that point must be attributed to Fabio
who ported and maintained Steve's original patch up to that
time.
The adapter_nr module options can be used to allocate static adapter
numbers on a driver level. It avoids problems with changing DVB apapter
numbers after warm/cold boot or device unplugging and repluging.
Each driver holds DVB_MAX_ADAPTER long array of the preferred order of
adapter numbers.
options dvb-usb-dib0700 adapter_nr=7,6,5,4,3,2,1,0 would result in a
reversed allocation of adapter numbers.
With adapter_nr=2,5 it tries first to get adapter number 2 and 5. If
both are already in use it will allocate the lowest free adapter number.
Signed-off-by: Janne Grunau <janne-dvb@grunau.be>
Acked-by: Hermann Pitton <hermann.pitton@arcor.de>
Signed-off-by: Michael Krufky <mkrufky@linuxtv.org>
Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
the other patches
