path: root/include/media
2005-08-01[PATCH] V4L: Miscellaneous fixesMauro Carvalho Chehab
- Fixed some bttv card numbers. - BTTV and SAA7134 version numbers incremented to reflect changes. - pci_dma_supported() is called after pci_set_dma_mask() which already did check that for us. This patch removes the unneeded call to pci_dma_supported() at bttv-driver.c - Ensure a sufficient I2C bus idle time between 2 messages for saa7134-i2c.c - It is important to write at first to MO_GP3_IO for cx88-tvaudio.c - Use try_to_freeze() instead of refrigerator at msp3400.c - Recognizing the MFPE05-2 Tuner at tveeprom.c - Add new parameter to help identify radio chipsets at tuner module: show_i2c=1 will show 16 reading bytes from detected tuners. - BTTV does generate some Unimplemented IOCTL log at tuner module: 0x40046d11(dir=1,tp=0x6d,nr=17,sz=4) means that it is sending MSP3400 calls to non-msp3400 tuners. Warning eliminated. VIDIOSAUDIO is also called, so debug messages updated. It is still requiring IOCTL implementation. - Added two more tuners. - Add support for the SVideo input on the GDI Black Gold. Signed-off-by: Peter Missel <peter.missel@onlinehome.de> Signed-off-by: Graham Bevan <graham.bevan@ntlworld.com> Signed-off-by: Torsten Seeboth <Torsten.Seeboth@t-online.de> Signed-off-by: Hartmut Hackmann <hartmut.hackmann@t.online.de> Signed-off-by: Tobias Klauser <tklauser@nuerscht.ch> Signed-off-by: Michael Krufky <mkrufky@m1k.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-27[PATCH] drivers/media/video/tveeprom.c: possible cleanupsAdrian Bunk
This patch contains the following possible cleanups: - make two needlessly global structs static - #if 0 the EXPORT_SYMBOL'ed but unused function tveeprom_dump Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-12[PATCH] v4l: I2C TunerMauro Carvalho Chehab
- Fixed a trouble on tuner-core that generates erros on computers with more than one TV card. - Rename tuner structures fields. - Tail spaces removed. - I2C cleanups and converged to a basic reference structure. - Removed unused structures. - Fix setting frequency on tda8290. - Added code for TEA5767 autodetection. - Standby mode support implemented. It is used to disable a non used tuner. Currenlty implemented on tea5767. - New macro: set_type disables other tuner when changing mode. - Some cleanups. - Use 50 kHz step when tunning radio for most tuners to improve precision. Signed-off-by: Fabien Perrot <perrot1983@yahoo.fr> Signed-off-by: Michael Krufky <mkrufky@m1k.net> Signed-off-By: Nickolay V. Shmyrev <nshmyrev@yandex.ru> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-12[PATCH] v4l: I2C MiscelaneousMauro Carvalho Chehab
- Removed unused structures. - CodingStyle rules applied to comments. Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-12[PATCH] v4l: SAA7134 hybrid DVBMauro Carvalho Chehab
- Add new Typhoon DVB-T Cardbus. - DVB-T support for MD7134 cardbus and the PCI variants - initial DVB-T support for Lifeview Flydvb-t duo - DVB-T support for Philips TOUGH reference design - Don't turn off the xtal output of tda8274/75 in sleep mode - Let Kconfig decide whether to include frontend-specific code in saa7134-dvb. - Removed unused structures. Signed-off-by: Juergen Orschiedt <jorschiedt@web.de> Signed-off-by: Michael Krufky <mkrufky@m1k.net> Signed-off-by: Hartmut Hackmann <hartmut.hackmann@t-online.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-28[PATCH] v4l: tuner improvementsMauro Carvalho Chehab
*tuner-core.c: - some tuner_info msgs will be generated only if insmod opt tuner_debug enabled. - Implemented tuner-core support for VIDIO_S_TUNER to allow changing mono/stereo mode - Remove unneeded config options. - I2C_CLIENT_MULTI option removed. - support for Philips FMD12ME hybrid tuner - allow to initialize with another tuner - Move PHILIPS_FMD initialization code to set_type function, * tda8290: - Fix dumb error in tda8290 tunning. - Radio tuner uses high-precision step instead of 62.5 KHz. *tea5767.c: - tuner_info msgs will be generated only if insmod tuner option tuner_debug enabled. - some cleanups for better reading. - Radio tuner uses high-precision step instead of 62.5 KHz. - Changing radio mode stereo/mono for tea5767 working. *tuner-simple.c: - TNF9533-D/IF UHF fixup. - Radio tuners now uses high-precision step instead of 62.5 KHz. *mt20xx.c: - Radio tuner uses high-precision step instead of 62.5 KHz. *tda9887.c: - tab and blank spaces corrections. Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Gerd Knorr <kraxel@bytesex.org> Signed-off-by: Nickolay V Shmyrev <nshmyrev@yandex.ru> Signed-off-by: Hartmut Hackmann <hartmut.hackmann@t-online.de> Signed-off-by: Michael Krufky <mkrufky@m1k.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] v4l: update for SAA7134 cardsMauro Carvalho Chehab
This patch adds support for various SAA7134 cards and brings some fixes. Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Fabrice Aeschbacher <fabrice.aeschbacher@laposte.net> Signed-off-by: Hermann Pitton <hermann.pitton@onlinehome.de>. Signed-off-by: Nickolay V Shmyrev <nshmyrev@yandex.ru> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] v4l: update for tuner cards and some V4L chipsMauro Carvalho Chehab
Tuner improvements and additions. TEA5767 FM tuner added. Several small fixes. Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Nickolay V Shmyrev <nshmyrev@yandex.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] v4l: support tuner for Thomson DDT 7611 (ATSC/NTSC)Michael Krufky
Add support for tuner#60: Thomson DDT 7611 (ATSC/NTSC) Change tuner in card#28 (DViCO FusionHDTV3 Gold-T) from tuner=52 (Tuner Thomson DDT 7610) to tuner=60 (Tuner Thomson DDT 7611) Signed-off-by: Michael Krufky <mkrufky@m1k.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] v4l: add support for PixelView Ultra ProManuel Capinha
The following patch adds support for the PixelView Ultra Pro video capture card in v4l. - It removes the remote control key definitions from ir-kbd-gpio.c and moves them to ir-common.c so that they can be shared between bt878 and cx88 based cards. - The patch also moves the FUSIONHDTV_3_GOLD_Q card from number 27 to 28 to regain compatibility with the V4L cvs. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] tuner-core.c improvments and Ymec Tvision TVF8533MF supportMauro Carvalho Chehab
tuner-core.c, tuner.h: - tuner-core changed to support multiple I2C devices used on some adapters; - Kconfig now has an option (CONFIG_TUNER_MULTI_I2C) to enable this new behavor; - By default, even enabling CONFIG_TUNER_MULTI_I2C, tuner-core emulates the old behavor, using first I2C device for both FM and TV; - There is a new i2c command (TUNER_SET_ADDR) to allow tuner clients to select I2C address for FM or TV tuner; - Tuner I2C dettach now generates a warning on syslog if failed. tuner-simple.c: - TVision TVF-8531MF and TVF-5533 MF tuner included. It uses, by default, I2C on 0xC2 address for TV and on 0xC0 for Radio. Both TV and FM Radio mode are working. Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-17[PATCH] dvb: modified dvb_register_adapter() to avoid kmalloc/kfreeJohannes Stezenbach
Modified dvb_register_adapter() to avoid kmalloc/kfree. Drivers have to embed struct dvb_adapter into their private data struct from now on. (Andreas Oberritter) Signed-off-by: Johannes Stezenbach <js@linuxtv.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
