Enable pd2vi_clk in case of Null sensor
Bug 870406
Change-Id: I29ab4e4d3d24a54b2eace84eeb8266582e53dd1f
Reviewed-on: http://git-master/r/50822
Tested-by: Krupal Divvela <kdivvela@nvidia.com>
Reviewed-by: Prayas Mohanty <pmohanty@nvidia.com>
Add IOCTL (OV5650_IOCTL_SET_BINNING) that user code
can access to registers which have 2x2 binning control
bits.
Bug 835589
Change-Id: I07f8d3536fcdb92e8bae0af294d1a0f8523cefbc
Reviewed-on: http://git-master/r/43727
Tested-by: Changyeon Jo <cjo@nvidia.com>
The sh532u focuser is enabled to pair with the stereo right camera
with the required power control configurations.
Bug 827897
Change-Id: Icc21bcd2327671da193a8b8f24c338b0b2f6729c
Reviewed-on: http://git-master/r/36571
Reviewed-by: Varun Colbert <vcolbert@nvidia.com>
Tested-by: Varun Colbert <vcolbert@nvidia.com>
initial support for sensor ov9726
bug 829399
Change-Id: I67315dfce7baf2c14f49bf526c10fe19cf32d1d3
Reviewed-on: http://git-master/r/40472
Reviewed-by: Daniel Willemsen <dwillemsen@nvidia.com>
Reviewed-by: Chonglei Huang <chahuang@nvidia.com>
Tested-by: Chonglei Huang <chahuang@nvidia.com>
Separate board specific sequence from ar0832 driver and add it to board
files. Add function that changes device slave address in real time to support
multiple devices in the same I2C bus.
Bug 844021
Change-Id: I48641909eb531b4ba827096bc30fa4eccf83469e
Reviewed-on: http://git-master/r/40385
Reviewed-by: Jihoon Bang <jbang@nvidia.com>
Tested-by: Jihoon Bang <jbang@nvidia.com>
Support only one sensor for now.
Change-Id: I1d0b804077e271052a6d6f4554865675fa70d612
Reviewed-on: http://git-master/r/36779
Kernel driver for TPS61050 flash/torch camera device.
Bug 794431
Change-Id: I760bd086c283076dc7136bd8ccd6b75e6e823ea8
Reviewed-on: http://git-master/r/34208
Tested-by: Erik M Lilliebjerg <elilliebjerg@nvidia.com>
Reviewed-by: Michael Stewart <mstewart@nvidia.com>
Reviewed-by: John Sasinowski <jsasinowski@nvidia.com>
update headers for camera files
bug 846086
Change-Id: Id53c77ead17b569ad05c0a5b8ec7f2a5d1aef869
Reviewed-on: http://git-master/r/39102
Reviewed-by: Erik M Lilliebjerg <elilliebjerg@nvidia.com>
Reviewed-by: Abhinav Sinha <absinha@nvidia.com>
Tested-by: Frank Chen <frankc@nvidia.com>
Reviewed-by: Jonathan Mayo <jmayo@nvidia.com>
For stereo camera, it is important that both sensors
should start sending data at the same time for them to
be in sync. Add IOCTL (OV5650_IOCTL_SYNC_SENSORS),
which user code can access to synchronize both sensors.
bug 787214
bug 786928
Change-Id: I6bf34a8af3b7dd51150d5c0247b6787b824c1dae
Reviewed-on: http://git-master/r/30005
Tested-by: Bharat Nihalani <bnihalani@nvidia.com>
When device sh532u is open, it calls board related initialization
and de- initialization function.
In the board related functions, the client can initialize the required
signal, power on/off the device etc.
bug 802264
Change-Id: Ie69a6e70c5d104489d248bef538e89263208ee54
Reviewed-on: http://git-master/r/30169
Tested-by: Laxman Dewangan <ldewangan@nvidia.com>
Reviewed-by: Danielle Sun <dsun@nvidia.com>
Tested-by: Danielle Sun <dsun@nvidia.com>
Return last requested position if the motor settled or timeout occurs.
Change-Id: Ib0ff58b827fcf871dbf185eb0a284b7fe010aef2
Reviewed-on: http://git-master/r/27978
Reviewed-by: Frank Chen <frankc@nvidia.com>
Reviewed-by: Andrei Denissov <adenissov@nvidia.com>
Reviewed-by: Gary Zhang <garyz@nvidia.com>
Tested-by: Gary Zhang <garyz@nvidia.com>
Reviewed-by: Scott Williams <scwilliams@nvidia.com>
Change-Id: I6f0bc3b5859c8545853051f10bda60ab6ac3dd8b
Bug 819975
Reviewed-on: http://git-master/r/29467
(cherry picked from commit 9c4eac8a44eef360c2e5be07838fecc78096847f)
Change-Id: If868656a2c8811593974723e85010257b07ed22b
Reviewed-on: http://git-master/r/29972
Reviewed-by: Pritesh Raithatha <praithatha@nvidia.com>
Tested-by: Pritesh Raithatha <praithatha@nvidia.com>
Bug: 783488
Change-Id: I0d70ec5bb0fd880b167e9ced0e002829abeccdbf
Reviewed-on: http://git-master/r/24969
Add AD5820 focuser driver for Whistler.
Bug 783488
Change-Id: I0d8a08e7df9f472ffc4edfe7bfa255357bff5126
Reviewed-on: http://git-master/r/26970
-Removed unused sensor mode mode_1920x1088
-Added ov5650_write_reg_helper function to do write_reg()
according to camera_mode.
-ov5650_get_status function is removed as it is reading reg 2
value and there is not any definition of reg 2 in datasheet and
even user space is not using it's value at all.
-Added ov5650_set_power function to on/off camera sensors power
-Added ioctl OV5650_IOCTL_SET_CAMERA_MODE to set camera_mode
from user space.
-Added i2c driver for right ov5650.
Bug 809921
Change-Id: Ib3cf43d0a064c18c218d0850e849fff84e18e661
Reviewed-on: http://git-master/r/26857
Reviewed-by: George Bauernschmidt <georgeb@nvidia.com>
- fix an incorrect i2c address and a function return check.
- add checks for function returns.
- remove the developer name in the beginning comment.
- fix an uninitialized variable..
Change-Id: I2d42025b7ff47eb6228e626e65990f4da04b94ac
Reviewed-on: http://git-master/r/23594
Tested-by: Qinggang Zhou <qzhou@nvidia.com>
Reviewed-by: Yu-Huan Hsu <yhsu@nvidia.com>
This focuser is from SEMCO and is integrated with OV5650 sensor and LC898211 driver.
bug 778859
Change-Id: I6e5dcc129c72aed7d92a00a1d926424050583c1d
Reviewed-on: http://git-master/r/22711
Reviewed-by: Qinggang Zhou <qzhou@nvidia.com>
Change-Id: Id5cb40c9823c7fcfd26e45e4608c45b16a2d431a
Reviewed-on: http://git-master/r/21351
Change-Id: Ie894d71f45cc08709daff3f258e0c4676b7778b0
Reviewed-on: http://git-master/r/19687
Reviewed-by: Nathan Lord <nlord@nvidia.com>
Tested-by: Nathan Lord <nlord@nvidia.com>
Change-Id: I9d9a9a301f23398a13fa7d865058f384288f6c92
Reviewed-on: http://git-master/r/18537
arch/arm/mach-tegra/fuse.c
drivers/misc/Makefile
Change-Id: I300b925d78b31efe00c342190d8dbd50e2e81230
commit a757ee2216211278680dd8ac869aabe7b4a9970d upstream.
Drivers should append their name on exported symbols, to avoid
conflicts with allyesconfig:
drivers/staging/built-in.o: In function `format_by_fourcc':
/home/v4l/work_trees/linus/drivers/staging/cx25821/cx25821-video.c:96: multiple definition of `format_by_fourcc'
drivers/media/built-in.o:/home/v4l/work_trees/linus/drivers/media/common/saa7146_video.c:88: first defined here
Let's rename both occurences with a small shellscript:
for i in drivers/staging/cx25821/*.[ch]; do sed s,format_by_fourcc,cx25821_format_by_fourcc,g <$i >a && mv a $i; done
for i in drivers/media/common/saa7146*.[ch]; do sed s,format_by_fourcc,saa7146_format_by_fourcc,g <$i >a && mv a $i; done
for i in include/media/saa7146*.[ch]; do sed s,format_by_fourcc,saa7146_format_by_fourcc,g <$i >a && mv a $i; done
Source files should not be with executable permission.
Change-Id: I70b6be4cf88fea4be9b092ca2f5dd08e40ee7cbd
Reviewed-on: http://git-master/r/12081
Reviewed-by: Chao Jiang <chaoj@nvidia.com>
Tested-by: Chao Jiang <chaoj@nvidia.com>
Change-Id: I127ea2a132adf2126c28194e8d778cc46b0a2e63
Reviewed-on: http://git-master/r/10573
Reviewed-by: Chien-Yu Chen <chichen@nvidia.com>
The tegra_camera device includes all clock and regulator
functionality needed to support camera on tegra.
Change-Id: I281f1cb5f360276af832309e35dbe17c98b62bb3
Signed-off-by: Dima Zavin <dima@android.com>
arch/arm/configs/tegra_defconfig
arch/arm/mach-tegra/tegra_i2s_audio.c
Change-Id: Ib0d7fc5c84b21a58f78a4a987c245e0e110ff437
The tegra_camera device has been extended to include all clock and
regulator functionality needed by to support camera on tegra.
Change-Id: Ie1611a79c24f7ebe3ae570d38a9f470683af91dd
Signed-off-by: Rebecca Schultz Zavin <rebecca@android.com>
Change-Id: I6ff1bf0e72ef69b59d5875bd60c7cd825fa2ca4f
This fixes a nasty memory corruption bug when using userptr I/O.
The function videobuf_pages_to_sg() sets up the scatter-gather list for the
DMA transfer to the userspace pages. The first transfer is setup correctly
(the size is set to PAGE_SIZE - offset), but all other transfers have size
PAGE_SIZE. This is wrong for the last transfer which may be less than PAGE_SIZE.
Most, if not all, drivers will program the boards DMA engine correctly, i.e.
even though the size in the last sg element is wrong, they will do their
own size calculations and make sure the right amount is DMA-ed, and so seemingly
prevent memory corruption.
However, behind the scenes the dynamic DMA mapping support (in lib/swiotlb.c)
may create bounce buffers if the memory pages are not in DMA-able memory.
This happens for example on a 64-bit linux with a board that only supports
32-bit DMA.
These bounce buffers DO use the information in the sg list to determine the
size. So while the DMA engine transfers the correct amount of data, when the
data is 'bounced' back too much is copied, causing buffer overwrites.
The fix is simple: calculate and set the correct size for the last sg list
element.
Signed-off-by: Hans Verkuil <hans.verkuil@tandberg.com>
Cc: stable@kernel.org
Since this module is also used by drivers that are not yet converted, the old
and new code have to co-exist.
The source is split into three parts: a common part at the top, which is used
by both old and new code, then the old code followed by the new control
framework implementation. This new code is much more readable (and shorter!)
than the original code.
Once all bridge drivers that use this are converted the old code can be
deleted.
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl>
The cx25840 used a private control CX25840_CID_ENABLE_PVR150_WORKAROUND
to be told whether to enable a workaround for certain pvr150 cards.
This is really config data that it needs to get at load time.
Implemented this in cx25840 and ivtv.
Add a new framework to handle controls which makes life for driver
developers much easier.
Note that this patch moves some of the control support that used to be in
v4l2-common.c to v4l2-ctrls.c. The tables were copied unchanged. The body
of v4l2_ctrl_query_fill() was copied to a new v4l2_ctrl_fill() function
in v4l2-ctrls.c. This new function doesn't use the v4l2_queryctrl
struct anymore, which makes it more general.
The remainder of v4l2-ctrls.c is all new. Highlights include:
- No need to implement VIDIOC_QUERYCTRL, QUERYMENU, S_CTRL, G_CTRL,
S_EXT_CTRLS, G_EXT_CTRLS or TRY_EXT_CTRLS in either bridge drivers
or subdevs. New wrapper functions are provided that can just be plugged in.
Once everything has been converted these wrapper functions can be removed as well.
- When subdevices are added their controls can be automatically merged
with the bridge driver's controls.
- Most drivers just need to implement s_ctrl to set the controls.
The framework handles the locking and tries to be as 'atomic' as possible.
- Ready for the subdev device nodes: the same mechanism applies to subdevs
and their device nodes as well. Sub-device drivers can make controls
local, preventing them from being merged with bridge drivers.
- Takes care of backwards compatibility handling of VIDIOC_S_CTRL and
VIDIOC_G_CTRL. Handling of V4L2_CID_PRIVATE_BASE is fully transparent.
CTRL_CLASS controls are automatically added.
Reviewed-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
LIRC: add new IOCTL that enables learning mode (wide band receiver)
Still missing features: carrier report & timeout reports.
Will need to pack these into ir_raw_event
Signed-off-by: Maxim Levitsky <maximlevitsky@gmail.com>
Some ir input devices have small buffer, and interrupt the host
each time it is full (or half full)
Add a helper that automaticly handles timeouts, and also
automaticly merges samples of same time (space-space)
Such samples might be placed by hardware because size of
sample in the buffer is small (a byte for example).
Also remove constness from ir_dev_props, because it now contains timeout
settings that driver might want to change
Acked-by: Jarod Wilson <jarod@redhat.com>
Currently, ir device registration fails if keymap requested by driver is not found.
Fix that by always compiling in the empty keymap, and using it as a failback.
This ports lirc_streamzap.c over to ir-core in-place, to be followed by
a patch moving the driver over to drivers/media/IR/streamzap.c and
enabling the proper Kconfig bits.
Presently, the in-kernel keymap doesn't work, as the stock Streamzap
remote uses an RC-5-like, but not-quite-RC-5 protocol, which the
in-kernel RC-5 decoder doesn't cope with. The remote can be used right
now with the lirc bridge driver though, and other remotes (at least an
RC-6(A) MCE remote) work perfectly with the driver.
I'll take a look at making the existing RC-5 decoder cope with this odd
duck, possibly implement another standalone decoder engine, or just
throw up my hands and say "meh, use lirc"... But the driver itself
should be perfectly sound.
Remaining items on the streamzap TODO list:
- add LIRC_SET_REC_TIMEOUT-alike support
- add LIRC_GET_M{AX,IN}_TIMEOUT-alike support
- add LIRC_GET_REC_RESOLUTION-alike support
All of the above should be trivial to add. There are patches pending to
add this support to ir-core from Maxim Levitsky, and I'll take care of
these once his patches get integrated. None of them are currently
essential though.
Signed-off-by: Jarod Wilson <jarod@redhat.com>
Signed-off-by: Andy Walls <awalls@md.metrocast.net>
The CX2584x and related cores are multifunction subdevices with a number
of internal blocks that act as interrupt sources. Move the v4L2_subdev
interrupt_service_routine callback from v4l_subdev_ir_ops to
v4l2_subdev_core_ops, as the video and audio blocks of a CX2584x and
related cores can generate interrupts along with the IR block. This
change also makes sense for other subdev's that generate interrupts and
do not have an IR block.
inversion
There is a distinction on IR Tx for the CX2388[578] chips of carrier
sense inversion (space is a carrier burst and mark is no burst) and I/O
pin level inversion (0 is high output level, 1 is low output level).
Allow the caller to set these parameters distinctly as v4l2_subdevice
IR parameters. This permits the IR device to be configured and enabled
without the IR Tx LED being on during idle/space time due to an external
hardware level inversion
Add s_io_pin_config core subdev op for the CX2388[578] AV cores.
This is complete for IR_RX, IR_TX, GPIOs 16,19-23, and IRQ_N.
It likely needs work for the I2S signal direction.
Add a method to v4l2_sudev_core_ops to allow bridge drivers to
manage what signal pads/functions are routed out to multiplexed IO pins on a
pin by pin basis. The interface also allows specifying initial output settings
for pins and disabling an IO pin altogether.
Instead of having one big keytable with 2 protocols inside, break it
into two separate tables, being one for NEC and another for RC-5 variants,
and properly identify what variant should be used at the boards entries.
Using CEU with CSI2 on SH-Mobile requires some special configuration of the
former. We also have to switch from calling only one subdev .s_mbus_fmt and
.try_mbus_fmt to calling all subdevices. Take care to increment CSI2 driver
use count to prevent it from unloading, while in use.
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Some SH-Mobile SoCs implement a MIPI CSI-2 controller, that can interface to
several video clients and send data to the CEU or to the Image Signal
Processor. This patch implements a v4l2-subdevice driver for CSI-2 to be used
within the soc-camera framework, implementing the second subdevice in addition
to the actual video clients.
These formats belong to the standard format set, defined by the MIPI CSI-2
specification.
Endianness notation is meaningless for 8 bit YUYV codes. Switch pixel code
names to explicitly state the order of colour components in the data
stream.
The lirc userspace needs all the current ioctls defined, and we need to
put the header files in places out-of-tree and/or staging lirc drivers
(which I plan to prep soon) can easily build with. I've actually tested this
in a tree w/all the lirc drivers queued up to be submitted for staging. I'm
also reasonably sure that Andy Walls is going to need most of the ioctls
anyway for his cx23888 IR driver work.
