commit 58d75f4b1ce26324b4d809b18f94819843a98731 upstream.
The recent conversion of saa7134 to vb2 unconvered a poll() bug that
broke the teletext applications alevt and mtt. These applications
expect that calling poll() without having called VIDIOC_STREAMON will
cause poll() to return POLLERR. That did not happen in vb2.
This patch fixes that behavior. It also fixes what should happen when
poll() is called when STREAMON is called but no buffers have been
queued. In that case poll() will also return POLLERR, but only for
capture queues since output queues will always return POLLOUT
anyway in that situation.
This brings the vb2 behavior in line with the old videobuf behavior.
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com>
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
commit a19dec6ea94c036af68c31930c1c92681f55af41 upstream.
This patch fixes following error:
include/media/v4l2-ctrls.h:193:15: error: field ‘_lock’ has incomplete type
include/media/v4l2-ctrls.h: In function ‘v4l2_ctrl_lock’:
include/media/v4l2-ctrls.h:570:2: error: implicit declaration of
function ‘mutex_lock’ [-Werror=implicit-function-declaration]
include/media/v4l2-ctrls.h: In function ‘v4l2_ctrl_unlock’:
include/media/v4l2-ctrls.h:579:2: error: implicit declaration of
function ‘mutex_unlock’ [-Werror=implicit-function-declaration]
Signed-off-by: Andrzej Hajda <a.hajda@samsung.com>
Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media
Pull media fixes from Mauro Carvalho Chehab:
"Series of fixes for 3.10. There are some usual driver fixes (mostly
on s5p/exynos playform drivers), plus some fixes at V4L2 core"
* 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (40 commits)
[media] soc_camera: error dev remove and v4l2 call
[media] sh_veu: fix the buffer size calculation
[media] sh_veu: keep power supply until the m2m context is released
[media] sh_veu: invoke v4l2_m2m_job_finish() even if a job has been aborted
[media] v4l2-ioctl: don't print the clips list
[media] v4l2-ctrls: V4L2_CTRL_CLASS_FM_RX controls are also valid radio controls
[media] cx88: fix NULL pointer dereference
[media] DocBook/media/v4l: update version number
[media] exynos4-is: Remove "sysreg" clock handling
[media] exynos4-is: Fix reported colorspace at FIMC-IS-ISP subdev
[media] exynos4-is: Ensure fimc-is clocks are not enabled until properly configured
[media] exynos4-is: Prevent NULL pointer dereference when firmware isn't loaded
[media] s5p-mfc: Add NULL check for allocated buffer
[media] s5p-mfc: added missing end-of-lines in debug messages
[media] s5p-mfc: v4l2 controls setup routine moved to initialization code
[media] s5p-mfc: separate encoder parameters for h264 and mpeg4
[media] s5p-mfc: Remove special clock usage in driver
[media] s5p-mfc: Remove unused s5p_mfc_get_decoded_status_v6() function
[media] v4l2: mem2mem: save irq flags correctly
[media] coda: v4l2-compliance fix: add VIDIOC_CREATE_BUFS support
Signed-off-by: Philipp Zabel <p.zabel@pengutronix.de>
Signed-off-by: Kamil Debski <k.debski@samsung.com>
Pull omap3isp clk support from Mauro Carvalho Chehab:
"This patch were sent in separate as it depends on a merge from clock
framework, that you merged in commit 362ed48dee50"
* 'topic/omap3isp' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media:
[media] omap3isp: Use the common clock framework
* topic/si476x:
Revert "[media] mfd: Add chip properties handling code for SI476X MFD"
Revert "[media] mfd: Add the main bulk of core driver for SI476x code"
Revert "[media] mfd: Add commands abstraction layer for SI476X MFD"
[media] v4l2: Add a V4L2 driver for SI476X MFD
videobuf_queue_dma_contig_init_cached() is not used anywhere.
Drop support for it, cleaning up the code a little bit.
Acked-by: Hans Verkuil <hans.verkuil@cisco.com>
This commit adds a driver that exposes all the radio related
functionality of the Si476x series of chips via the V4L2 subsystem.
[mchehab@redhat.com: change it to depends on MFD_SI476X_CORE instead of
selecting it; vidioc_s_register now uses const struct]
Signed-off-by: Andrey Smirnov <andrew.smirnov@gmail.com>
As requested by Andrey Smirnov <andrew.smirnov@gmail.com>, revert
this patch.
This reverts commit 30bac9110455402fa8888740c6819dd3daa2666f.
drivers/media/radio/Kconfig
drivers/media/radio/radio-si476x.c
It is very similar than rc-msi-digivox-iii but new keytable is needed
as there is one existing scancode mapped to different button. Also that
one has less buttons.
NEC extended protocol with address 0x61d6.
Signed-off-by: Antti Palosaari <crope@iki.fi>
Expose the two ISP external clocks XCLKA and XCLKB as common clocks for
subdev drivers.
Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Acked-by: Mike Turquette <mturquette@linaro.org>
This ioctl will be extended to return more information than just the name.
Only enable this ioctl if the VIDEO_ADV_DEBUG config option is set. This
prevents abuse from both userspace and kernelspace (some bridge drivers
abuse DBG_G_CHIP_IDENT, lets prevent that from happening again with this
ioctl).
Configure the device external clock using the common clock framework
instead of a board code callback function.
Acked-by: Sakari Ailus <sakari.ailus@iki.fi>
Move the sub-device group ID definitions to the driver's public header
so they are available to other media drivers that need to share modules
found in exynos4-is.
Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
config looks like a hack that was added to tuner-core to allow some
configuration of TDA8290 tuner (it's not used by any other driver).
But with the new configuration options of tda8290 driver (no_i2c_gate
and std_map), it's no longer sufficient.
Change config to be void * instead, which allows passing tuner-dependent
config struct to drivers.
Also update saa7134 driver to reflect this change (no other driver uses this).
Signed-off-by: Ondrej Zary <linux@rainbow-software.org>
Signed-off-by: Michael Krufky <mkrufky@linuxtv.org>
The FIMC-LITE output DMA allows to configure different YUV order
than the order at the camera input interface. Thus there is some
limited colorspace conversion possible. This patch makes the
color format variable be per FIMC-LITE input/output, rather than
a global per device. This also fixes incorrect behavior where
color format at the FIMC-LITE.N subdev's source pad is modified
by VIDIOC_S_FMT ioctl on the related video node.
YUV order definitions are corrected so that we use notation:
| byte3 | byte2 | byte1 | byte0
YCBYCR | CR | Y | CB | Y
YCRYCB | CB | Y | CR | Y
CBYCRY | Y | CR | Y | CB
CRYCBY | Y | CB | Y | CR
v4l2_of_parse_parallel_bus() function is now static and
EXPORT_SYMBOL() doesn't apply to it any more. Drop this
meaningless statement, which was supposed to be done in
the original merged patch.
While at it, edit the copyright notice so it is sorted in
both the v4l2-of.c and v4l2-of.h file in newest entries
on top order, and state clearly I'm just the author of
parts of the code, not the copyright owner.
Based on work done by Katsuya Matsubara.
Signed-off-by: Phil Edworthy <phil.edworthy@renesas.com>
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Drop fimc-lite.h header inclusion to make the exynos-fimc-lite
module independent on other modules. Move struct fimc_fmt
declaration to the driver's private headers as it is used in
multiple modules.
Reported-by: Shaik Ameer Basha <shaik.ameer@samsung.com>
The sensor (I2C and/or SPI client) devices are instantiated by their
corresponding control bus drivers. Since the I2C client's master clock
is often provided by a video bus receiver (host interface) or other
than I2C/SPI controller device, the drivers of those client devices
are not accessing hardware in their driver's probe() callback. Instead,
after enabling clock, the host driver calls back into a sub-device
when it wants to activate them. This pattern is used by some in-tree
drivers and this patch also uses it for DT case. This patch is intended
as a first step for adding device tree support to the S5P/Exynos SoC
camera drivers. The second one is adding support for asynchronous
sub-devices registration and clock control from sub-device driver
level. The bindings shall not change when asynchronous probing support
is added.
This patch adds changes required for the main camera media device
driver corresponding to the top level 'camera' device node.
The drivers of devices corresponding to child nodes of the 'camera'
node are looked up and and registered as sub-devices to the top
level driver. The main driver's probing is deferred if any of the
sub-device drivers is not yet initialized and ready.
This patch support for binding the driver to the MIPI-CSIS
devices instantiated from device tree and parsing the SoC
and board specific properties. The MIPI CSI-2 channel is
determined by the value of reg property placed in csis'
port subnode.
Add a V4L2 OF parser, implementing bindings documented in
Documentation/devicetree/bindings/media/video-interfaces.txt.
[s.nawrocki@samsung.com: various corrections and improvements
since the initial version]
ioctl's number is unsigned int. Fix it at vidioc_default.
Simplify the debugging ioctls by creating the VIDIOC_DBG_G_CHIP_NAME ioctl.
This will eventually replace VIDIOC_DBG_G_CHIP_IDENT. Chip matching is done
by the name or index of subdevices or an index to a bridge chip. Most of this
can all be done automatically, so most drivers just need to provide get/set
register ops.
In particular, it is now possible to get/set subdev registers without
requiring assistance of the bridge driver.
These ioctls are no longer used by any drivers, so remove them.
[mchehab@redhat.com: Fix merge conflict]
These ops are no longer used, so it's time to remove them.
It's no longer used, so it can now be removed.
This based on the wis-uda1342.c driver that's part of the go7007 driver.
It has been converted to a v4l subdev driver by Pete Eberlein, and I made
additional cleanups.
Based on work by: Pete Eberlein <pete@sensoray.com>
This adds support for three Sony BTF tuners:
TUNER_SONY_BTF_PG472Z: PAL+SECAM
TUNER_SONY_BTF_PK467Z: NTSC-M-JP
TUNER_SONY_BTF_PB463Z: NTSC-M
These come from the go7007 staging driver where they were implemented in
the wis-sony-tuner i2c driver.
Adding support for these tuners to tuner-types.c is the first step towards
removing the wis-sony-tuner driver.
Some devices expect a double rate ASCLK. Add a flag to let the driver know
through the s_crystal_freq call.
Needed by the go7007 driver: it assumes a different polarity of the IDQ
signal, so we need to be able to tell the saa7115 about this.
This patch adds a v4l2_subdev_has_op() macro and a v4l2_device_has_op macro to
quickly check if a specific subdev or any subdev supports a particular subdev
operation.
This makes it easy for drivers to disable certain ioctls if none of the subdevs
supports the necessary functionality.
v4l2_ctrl_handler.lock
When calling v4l2_ctrl_add_handler(), lockdep would detect a potential
recursive locking problem on a situation that is by design intended and
not a recursive lock. This happened because all struct
v4l2_ctrl_handler.lock mutexes were created as members of the same lock
class in v4l2_ctrl_handler_init(), and v4l2_ctrl_add_handler() takes the
hdl->lock on two different v4l2_ctrl_handler instances.
This change breaks the large lockdep lock class for struct
v4l2_ctrl_handler.lock and breaks it into v4l2_ctrl_handler
instantiation specific lock classes with meaningful class names.
This will validly eliminate lockdep alarms for v4l2_ctrl_handler locking
validation, as long as the relationships between drivers adding v4l2
controls to their own handler from other v4l2 drivers' control handlers
remains straightforward.
struct v4l2_ctrl_handler.lock lock classes are created with names such
that the output of cat /proc/lockdep indicates where in the v4l2 driver
code v4l2_ctrl_handle_init() is being called on instantiations:
ffffffffa045f490 FD: 10 BD: 8 +.+...: cx2341x:1534:(hdl)->lock
ffffffffa0497d20 FD: 12 BD: 2 +.+.+.: saa7115:1581:(hdl)->lock
ffffffffa04ac660 FD: 14 BD: 2 +.+.+.: msp3400_driver:756:(hdl)->lock
ffffffffa0484b90 FD: 12 BD: 1 +.+.+.: ivtv_gpio:366:(&itv->hdl_gpio)->lock
ffffffffa04eb530 FD: 11 BD: 2 +.+.+.: cx25840_core:1982:(&state->hdl)->lock
ffffffffa04fbc80 FD: 11 BD: 3 +.+.+.: wm8775:246:(&state->hdl)->lock
Some lock chains, that were previously causing the recursion alarms, are
now visible in the output of cat /proc/lockdep_chains:
irq_context: 0
[ffffffffa0497d20] saa7115:1581:(hdl)->lock
[ffffffffa045f490] cx2341x:1534:(hdl)->lock
irq_context: 0
[ffffffffa04ac660] msp3400_driver:756:(hdl)->lock
irq_context: 0
[ffffffffa0484b90] ivtv_gpio:366:(&itv->hdl_gpio)->lock
irq_context: 0
[ffffffffa04eb530] cx25840_core:1982:(&state->hdl)->lock
irq_context: 0
[ffffffffa04fbc80] wm8775:246:(&state->hdl)->lock
Signed-off-by: Andy Walls <awalls@md.metrocast.net>
[hans.verkuil@cisco.com: keep mutex_init in v4l2_ctrl_handler_init_class]
This ioctl is defined as IOW, so pass the argument as const.
Acked-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Acked-by: Lad, Prabhakar <prabhakar.csengg@gmail.com>
This ioctl is defined as IOW, so pass the argument by value instead of by
reference. I could have chosen to add const instead, but this is 1) easier
to handle in drivers and 2) consistent with the s_std subdev operation.
Acked-by: Jonathan Corbet <corbet@lwn.net>
Acked-by: Alexey Klimov <klimov.linux@gmail.com>
store_protocols() treats dev->rc_map.rc_type as a bitmap which is wrong for
two reasons. First of all, it is pretty bogus to change the protocol type of
the keymap just because the hardware has been asked to decode a different
protocol.
Second, dev->rc_map.rc_type is an enum (i.e. a single protocol) as pointed
out by James Hogan <james.hogan@imgtec.com>.
Fix both issues by introducing a separate enabled_protocols member to
struct rc_dev.
Signed-off-by: David Härdeman <david@hardeman.nu>
The patch adds support for THS7353 video amplifier.
The the THS7353 amplifier is very much similar to the
existing THS7303 video amplifier driver.
This patch appropriately makes changes to the existing
ths7303 driver and adds support for the THS7353.
This patch also adds V4L2_IDENT_THS7353 for the THS7353
chip and appropriate changes to Kconfig file for building.
Signed-off-by: Lad, Prabhakar <prabhakar.lad@ti.com>
Signed-off-by: Martin Bugge <marbugge@cisco.com>
Some drivers have special memory requirements for their buffers, usually
related to DMA (e.g. GFP_DMA or __GFP_DMA32). Make it possible to specify
additional GFP flags for those buffers by adding a gfp_flags field to
vb2_queue.
Note that this field will be replaced in the future with a different
mechanism, but that is still work in progress and we need this feature
now so we won't be able to convert drivers with such requirements to vb2.
Acked-by: Marek Szyprowski <m.szyprowski@samsung.com>
Acked-by: Federico Vaga <federico.vaga@gmail.com>
Acked-by: Lad, Prabhakar <prabhakar.lad@ti.com>
drivers/media/platform/davinci/dm644x_ccdc.c: In function ‘validate_ccdc_param’:
drivers/media/platform/davinci/dm644x_ccdc.c:233:32: warning: comparison between ‘enum ccdc_gama_width’ and ‘enum ccdc_data_size’ [-Wenum-compare]
It took a bit of work, see this thread of an earlier attempt to fix this:
https://patchwork.kernel.org/patch/1923091/
I've chosen not to follow the suggestions in that thread since gamma_width is
really a different property from data_size. What you really want is to know if
gamma_width fits inside data_size and for that you need to translate each
enum into a maximum bit number so you can safely compare the two.
So I put in two static inline translation functions instead, keeping the rest
of the code the same (except for fixing the 'gama' typo).
Remove VPBE_ENC_DV_PRESET (the DV_PRESET API is no longer supported) and
VPBE_ENC_CUSTOM_TIMINGS is renamed to VPBE_ENC_DV_TIMINGS since the old
"CUSTOM_TIMINGS" name is deprecated in favor of "DV_TIMINGS".
Acked-by: Sekhar Nori <nsekhar@ti.com>
Provide an ioctl handler for 32-bit binaries on 64-bit systems.
Signed-off-by: Sakari Ailus <sakari.ailus@iki.fi>
Tested-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Not all drivers use monotonic timestamps. This patch adds a way to set the
timestamp type per every queue.
In addition, set proper timestamp type in drivers that I am sure that use
either MONOTONIC or COPY timestamps. Other drivers will correctly report
UNKNOWN timestamp type instead of assuming that all drivers use monotonic
timestamps.
Reviewed-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
VIDIOC_DBG_G_CHIP_IDENT is a prerequisite for the G/S_REGISTER ioctls.
In addition, add support to call G/S_REGISTER for supporting i2c devices.
Some bridge drivers capture pixels during blanking periods if
pixclk is enabled. In order to avoid capturing bogus data we need to
disable pixclk in the sensor during those blanking periods.
Signed-off-by: Javier Martin <javier.martin@vista-silicon.com>
