path: root/include/media
2007-03-27V4L/DVB (5441): Saa7146: Fix allocation of clipping memoryOliver Endriss
Olaf Hering pointed out that SAA7146_CLIPPING_MEM would become very large for PAGE_SIZE > 4K. In fact, the number of clipping windows is limited to 16, and calculate_clipping_registers_rect() does not use more than 256 bytes. SAA7146_CLIPPING_MEM adjusted accordingly. Thanks-to: Olaf Hering <olaf@aepfle.de> Acked-by: Michael Hunold <hunold@linuxtv.org> Signed-off-by: Oliver Endriss <o.endriss@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-03-01V4L/DVB (5271): Add VIDIOC_TRY_ENCODER_CMD and VIDIOC_ENCODER_CMD ioctls.Hans Verkuil
Add support for starting, stopping, pausing and resuming an MPEG (or similar compressed stream) encoder. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-03-01V4L/DVB (5270): Add VIDIOC_G_ENC_INDEX ioctlHans Verkuil
The VIDIOC_G_ENC_INDEX ioctl can obtain the MPEG index from an MPEG encoder. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-03-01V4L/DVB (5304): Improve chip matching in v4l2_registerHans Verkuil
The chip matching in struct v4l2_register for VIDIOC_DBG_G/S_REGISTER was rather primitive. It could not be extended to other busses besides i2c and it lacked a way to. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-02-21V4L/DVB (5200): V4l_printk_ioctl_arg() is no longer used.Adrian Bunk
Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-02-21V4L/DVB (5147): Make vivi driver to use vmalloced pointersMauro Carvalho Chehab
Before this patch, vivi were simulating a scatter gather DMA transfer. While this is academic, showing how stuff really works on a real PCI device, this means a non-optimized code. There are only two memory models that vivi implements: 1) kernel alloced memory. This is also used by read() method. On this case, a vmalloc32 buffer is allocated at kernel; 2) userspace allocated memory. This is used by most userspace apps. video-buf will store this pointer. a simple copy_to_user is enough to transfer data. The third memory model scenario supported by video-buf is overlay mode. This model is not implemented on vivi and unlikely to be implemented on newer drivers, since now, most userspace apps do some post-processing (like de-interlacing). After this patch, some cleanups may be done at video-buf.c to avoid allocating pages, when the driver doesn't need a PCI buffer. This is the case of vivi and usb drivers. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-02-21V4L/DVB (5146): Make VIDIOC_INT_[SG]_REGISTER ioctls no longer internal onlyTrent Piepho
The direct register access ioctls were defined as kernel internal only, but they are very useful for debugging hardware from userspace and are used as such. Officially export them. VIDIOC_INT_[SG]_REGISTER is renamed to VIDIOC_DBG_[SG]_REGISTER Definition of ioctl and struct v4l2_register is moved from v4l2-common.h to videodev2.h. Types used in struct v4l2_register are changed to the userspace exportable versions (u32 -> __u32, etc). Use of VIDIOC_DBG_S_REGISTER requires CAP_SYS_ADMIN permission, so move the check into the video_ioctl2() dispatcher so it doesn't need to be duplicated in each driver's call-back function. CAP_SYS_ADMIN check is added to pvrusb2 (which doesn't use video_ioctl2). Signed-off-by: Trent Piepho <xyzzy@speakeasy.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-02-21V4L/DVB (5144): Restore VIDIOC_INT_[SG]_REGISTER callsTrent Piepho
Add support for these ioctls to the video_ioctl2 system and the cx88 driver. Signed-off-by: Trent Piepho <xyzzy@speakeasy.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-02-21V4L/DVB (5113): Adds video output routingMarco Schluessler
Nexus CA needs to use a different routing on saa7115 module. Signed-off-by: Marco Schluessler <marco@lordzodiac.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-02-21V4L/DVB (5070): Budget-ci: add support for the Technotrend 1500 bundled remoteVille-Pekka Vainio
The keymap is based on a previous patch by Jussi Kukkonen. This remote is identified by subsystem_device id 0x1010. Signed-off-by: Ville-Pekka Vainio <vpivaini@cs.helsinki.fi> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-02-21V4L/DVB (5017): DVB: fix compile errorAdrian Bunk
This patch fixes the following compile error: <-- snip --> ... LD drivers/media/video/built-in.o drivers/media/video/saa7134/built-in.o:(.data+0x85ec): multiple definition of `ir_rc5_remote_gap' drivers/media/video/bt8xx/built-in.o:(.data+0x734c): first defined here drivers/media/video/saa7134/built-in.o:(.data+0x85f0): multiple definition of `ir_rc5_key_timeout' drivers/media/video/bt8xx/built-in.o:(.data+0x7350): first defined here make[4]: *** [drivers/media/video/built-in.o] Error 1 <-- snip --> Since this variables were needlessly global, this patch implements the trivial fix of making them static. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-02-21V4L/DVB (5015): Add support for more Encore TV cardsJuan Pablo Sormani
Signed-off-by: Juan Pablo Sormani <sorman@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-02-21V4L/DVB (4986): Removed unimplemented cx2341x API commandsHans Verkuil
The commands CX2341X_DEC_SET_AUDIO_OUTPUT, CX2341X_DEC_SET_AV_DELAY and CX2341X_ENC_SET_3_2_PULLDOWN are not implemented in the Conexant firmware. So these commands are removed. This also means that the V4L2_CID_MPEG_VIDEO_PULLDOWN control in cx2341x.c and pvrusb2-hdw.c is removed. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-02-21V4L/DVB (4961): Add support for the ASUS P7131 remote controlHermann Pitton
Besides adding the board specific code, this patch moves the RC5 decoding code from bt8xx to ir-functions.c to make it available for all drivers. Signed-off-by: Marc Fargas <telenieko.telenieko.com> Signed-off-by: Hermann Pitton <hermann-pitton@arcor.de> Signed-off-by: Hartmut Hackmann <hartmut.hackmann@t-online.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-12-27V4L/DVB (5001): Add two required headers on kernel 2.6.20-rc1Mauro Carvalho Chehab
include/media/ir-common.h:78: error: field 'work' has incomplete type drivers/media/common/ir-functions.c: In function 'ir_rc5_timer_end': drivers/media/common/ir-functions.c:301: error: 'jiffies' undeclared (first use in this function) drivers/media/common/ir-functions.c:301: error: (Each undeclared identifier is reported only once) drivers/media/common/ir-functions.c:301: error: for each function it appears in.) drivers/media/common/ir-functions.c:347: error: 'HZ' undeclared (first use in this function) Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-12-27V4L/DVB (4988): Cx2341x audio_properties is an u16, not u8Hans Verkuil
This bug broke the MPEG audio mode controls. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-12-10V4L/DVB (4935): Added the capability of selecting fm gain by tunerMauro Carvalho Chehab
Some tuners require using cGainNormal instead of cGainLow for high sensibility on FM reception. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-12-10V4L/DVB (4934): Usbvision radio requires GainNormal at e registerMauro Carvalho Chehab
Adds an option to select GainNormal at tda9887 and make usbvision to use it. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-12-10V4L/DVB (4917): Saa7146: Convert SAA7146_IER_{DIS,EN}ABLE macros to inline ↵Oliver Endriss
functions Convert SAA7146_IER_{DIS,EN}ABLE macros to inline functions. Fixes a problem with macro expansion (reported by C.Y.M). Signed-off-by: Oliver Endriss <o.endriss@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-12-10V4L/DVB (4914): Saa7146: Protect access to the IER register by a spinlockHartmut Birr
Protect the access to the IER register of the SAA7146 by the device spinlock. I2C transfers may use interrupt mode now. Signed-off-by: Oliver Endriss <o.endriss@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-12-10V4L/DVB (4879): budget-ci IR: integrate with ir-commonDavid Hardeman
This converts the budget-ci driver so that it uses ir-common for some of its IR processing. In particular, the keymap for the Nova-T (sub 13c2:1011) is switched to the Hauppauge grey/black keymap, of which the keys on the supplied R808 remote control form a subset. The old budget-ci keymap is moved to ir-keymaps.c and is used for other remotes. The debounce logic for buggy remotes (i.e. Zenith) is made conditional the new debounce parameter and defaults to off (so that repeat keypresses aren't ignored for all working remotes). Some parts are based on Darren Salt's dvb-ir patchset. Signed-off-by: David Hardeman <david@hardeman.nu> Signed-off-by: Andrew de Quincey <adq_dvb@lidskialf.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-12-10V4L/DVB (4861): Remove the need of a STD array for drivers using video_ioctl2Mauro Carvalho Chehab
video_ioctl2 will auto-generate standard entries at ENUM_FMT. Also, now, a driver may return a subset of the video array at the return, to be stored as the current_norm. For example, a driver may ask for V4L2_STD_PAL. At return, driver may change it to V4L2_STD_PAL_B. This way, a futher call to G_STD will return the exact detected video std. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-12-10V4L/DVB (4812): Detect presence of IR receiver/IR transmitter in tveepromHans Verkuil
Thanks to input from Steven Toth from Hauppauge the tveeprom module has been extended to detect the presence of an IR transmitter (aka IR-blaster). Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-12-10V4L/DVB (4798): OmniVision OV7670 driverJonathan Corbet
This patch adds a V4L2 driver for the OmniVision OV7670 camera. Signed-off-by: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-12-10V4L/DVB (4796): A couple of V4L2 defines needed by Cafe Camara driverJonathan Corbet
Two defines for V4L2, needed by the Cafe camera driver: 1) Add the RGB444 image format 2) Add the "init" internal command which is separate from "reset". Signed-off-by: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-10-03V4L/DVB (4666): Ensure the WM8775 driver is loaded generically for any board.Steven Toth
A generic change to cards to allow any board to specify whether it needs the wm8775 module loaded (by the core) or not. Signed-off-by: Steven Toth <stoth@hauppauge.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-09-30Merge master.kernel.org:/pub/scm/linux/kernel/git/mchehab/v4l-dvbLinus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/mchehab/v4l-dvb: (180 commits) V4L/DVB (4641): Trivial: use lowercase letters in hex subsystem ids V4L/DVB (4639): Cx88: add autodetection for alternate revision of Leadtek PVR V4L/DVB (4638): Basic DVB-T and analog TV support for the HVR1300. V4L/DVB (4637): Add a default method for VIDIOC_G_PARM V4L/DVB (4635): Extend bttv and saa7134 to check for both AGP and PCI PCI failure case V4L/DVB (4634): Zr36120: implement pcipci checks V4L/DVB (4632): Zoran: Implement pcipci failure check V4L/DVB (4631): Av7110: remove V4L2_CAP_VBI_CAPTURE flag V4L/DVB (4630): Av7110: FW_LOADER depemdency fixed V4L/DVB (4629): Saa7134: add card support for Proteus Pro 2309 V4L/DVB (4628): Fix VIDIOC_ENUMSTD ioctl in videodev.c V4L/DVB (4627): Vivi crashes with mplayer V4L/DVB (4626): On saa7111/7113, LUMA_CTRL need a different value V4L/DVB (4624): Tvaudio: Replaced kernel_thread() with kthread_run() V4L/DVB (4622): Copy-paste bug in videodev.c V4L/DVB (4620): Fix AGC configuration for MOD3000P-based boards V4L/DVB (4619): Fixes some I2C dependencies on V4L devices V4L/DVB (4617): Problem with dibusb-mb.c USB IDs V4L/DVB (4616): [PATCH] Nebula DigiTV USB RC support V4L/DVB (4614): Export symbol saa7134_tvaudio_setmute from saa7134 for saa7134-alsa ...
2006-09-26V4L/DVB (4629): Saa7134: add card support for Proteus Pro 2309Michal Majchrowicz
Add card support for Proteus Pro 2309, based on saa7130 bridge Signed-off-by: Michal Majchrowicz <mmajchrowicz@gmail.com> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-09-26V4L/DVB (4582): VIDIOC_INT_S_REGISTER is IOW, not IOR.Hans Verkuil
2006-09-26V4L/DVB (4553): Add support for saa7111 and partial support for saa7118Mauro Carvalho Chehab
2006-09-26V4L/DVB (4546): Add u32 argument to VIDIOC_INT_RESET.Hans Verkuil
The extra argument makes it possible to reset subsystems of a chip if that is supported. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-09-26V4L/DVB (4533): Tda9887: add configuration setting for L standard PLL gatingTrent Piepho
Add a tuner config parameter for TDA9887, default_pll_gating_18, that changes the L standard PLL gating value from 36% to 0% (datasheet says 0%, tda9887 code says 18%). Turn this on for Microtune 4049FM5, as recomended by tuner datasheet. Signed-off-by: Trent Piepho <xyzzy@speakeasy.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-09-26V4L/DVB (4361): Cx88: add support for Norwood PCI TV Tuner (non-pro)Peter Naulls
This patch adds support for Norwood PCI TV Tuner (non-pro) Signed-off-by: Peter Naulls <peter@chocky.org> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-09-26V4L/DVB (4348): Fix: compile for radio aimslab and aztech with V4L2 onlyMauro Carvalho Chehab
All radio devices use an obsolete mode of opening/release driver. Since this is not V4L1 core, better to keep the method available for more time than to rewrite open/release without a radio device to test, since the newer method is much more complex than the previous one (although providing support for multiple opens and multiple devices). Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-09-25v4l-dev2: handle __must_checkAndrew Morton
We get hundreds of these: include/media/v4l2-dev.h:348: warning: ignoring return value of 'class_device_create_file', declared with attribute warn_unused_result Handle it, and propagate the __must_check back a level. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-10V4L/DVB (4605): Fixes an issue with V4L1 and make headers-installMauro Carvalho Chehab
V4L1 support should be disabled when no CONFIG_VIDEO_V4L1_COMPAT is defined, to allow checking for broken V4L2 ports. This is very important during the migration phase for V4L2 API. However, userspace apps should be capable of using both APIs, since they need to test at runtime, via VIDIOCGCAP ioctl, if V4L1 is supported. So, when __KERNEL__ is not defined, those ioctls and corresponding structs should be visible. This patch also removes the obsolete defines HAVE_V4L1 and HAVE_V4L2, that where causing some confusion, and were replaced by CONFIG_VIDEO_V4L1_COMPAT and CONFIG_VIDEO_V4L2. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-08-08V4L/DVB (4340): Videodev.h should be included also when V4L1_COMPAT is selected.Mauro Carvalho Chehab
2006-07-29V4L/DVB (4316): Check __must_check warningsMichael Krufky
Check __must_check warnings for class_device_register and class_device_create_file video_device_create_file was declared as a void, but instead should return the int value of class_device_create_file. Move the check from bttv-driver.c into v4l2-dev.h, because all other callers of video_device_create_file must also be checked. Replace the call to class_device_create_file in videodev.c with video_device_create_file, as defined in v4l2-dev.h, so that the return value of class_device_create_file will be checked. Check the return value of class_device_register in videodev.c and pvrusb2-sysfs.c Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-06-30V4L/DVB (4270): Add tda9887-specific tuner configurationHans Verkuil
Many tda9887 settings depend on the chosen tuner. Expand the tuner parameters to include these tda9887 settings. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-06-29Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/devfs-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/devfs-2.6: (22 commits) [PATCH] devfs: Remove it from the feature_removal.txt file [PATCH] devfs: Last little devfs cleanups throughout the kernel tree. [PATCH] devfs: Rename TTY_DRIVER_NO_DEVFS to TTY_DRIVER_DYNAMIC_DEV [PATCH] devfs: Remove the tty_driver devfs_name field as it's no longer needed [PATCH] devfs: Remove the line_driver devfs_name field as it's no longer needed [PATCH] devfs: Remove the videodevice devfs_name field as it's no longer needed [PATCH] devfs: Remove the gendisk devfs_name field as it's no longer needed [PATCH] devfs: Remove the miscdevice devfs_name field as it's no longer needed [PATCH] devfs: Remove the devfs_fs_kernel.h file from the tree [PATCH] devfs: Remove devfs_remove() function from the kernel tree [PATCH] devfs: Remove devfs_mk_cdev() function from the kernel tree [PATCH] devfs: Remove devfs_mk_bdev() function from the kernel tree [PATCH] devfs: Remove devfs_mk_symlink() function from the kernel tree [PATCH] devfs: Remove devfs_mk_dir() function from the kernel tree [PATCH] devfs: Remove devfs_*_tape() functions from the kernel tree [PATCH] devfs: Remove devfs support from the sound subsystem [PATCH] devfs: Remove devfs support from the ide subsystem. [PATCH] devfs: Remove devfs support from the serial subsystem [PATCH] devfs: Remove devfs from the init code [PATCH] devfs: Remove devfs from the partition code ...
2006-06-27V4L/DVB (4259): Pass an explicit log prefix to cx2341x_log_statusHans Verkuil
A card number is not unique enough. Instead, let the caller specify the prefix of the status messages. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-06-27V4L/DVB (4257): Fix 64-bit compile warnings.Hans Verkuil
2006-06-26[PATCH] devfs: Remove the videodevice devfs_name field as it's no longer neededGreg Kroah-Hartman
Also fixes all drivers that set this field. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-26V4L/DVB (4223): Add V4L2_CID_MPEG_STREAM_VBI_FMT controlHans Verkuil
V4L2_CID_MPEG_STREAM_VBI_FMT controls if and how VBI data is embedded in an MPEG stream. Currently only one format is supported: the format designed for the ivtv driver. This should be extended with new standard formats (such as defined for DVB) in the future. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-06-25V4L/DVB (4205): Merge tda9887 module into tuner.Mauro Carvalho Chehab
Most uses a tda988[5/6/7] IF demodulator as part of the device. Having this as a separate stuff makes harder to configure it, since there are some tda9887 options that are tuner-dependent and should be bound into tuner-types structures. This patch merges tda9887 module into tuner. More work is required to make tuner-types to properly use it. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-06-25V4L/DVB (4203): Explicitly set the enum values.Hans Verkuil
It's better to use explicit enums. It reduces the chance of someone inserting new enums in the middle which would break things. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-06-25V4L/DVB (4202): allow selecting CX2341x port modeHans Verkuil
CX2341X port was always set to 'memory', but 'streaming' is also possible ivtv uses the memory (DMA) interface with the CX2341X, while pvrusb2 and cx88-blackbird use the streaming interface. This setting is now selectable by the driver. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-06-25V4L/DVB (4199): Add cx2341x-specific control array to cx2341x.cHans Verkuil
2006-06-25V4L/DVB (4191): Add CX2341X MPEG encoder module.Hans Verkuil
Adds the cx2341x.c module that handles the programming of the Conexant cx23415/6 MPEG encoder chip used by cx88-blackbird, pvrusb2 and ivtv. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-06-25V4L/DVB (4190): Add helper functions for control processing to v4l2-common.Hans Verkuil
Control processing is often duplicated in the various drivers. Unfortunately, simple things like the names of controls are often different between drivers, even though it is the same controls. Adding in the new extended controls and the need for having control helper functions became apparent. Several functions have now been added to v4l2-common to do things like filling the v4l2_queryctrl and v4l2_querymenu structs, to check for valid control input and to move to the next control when enumerating over all controls. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
