Basic I2C module integration of AMFM module to ARD platform IMX6Q
and IMX6DL rev A and rev B boards. Supported for kernel 3.0.15.
Signed-off-by: Alejandro Sierra <b18039@freescale.com>
The tuner ops g_frequency, g_tuner and s_tuner require that the tuner type
field is filled in. Document this.
The tuner-core doc is based on a patch from Mauro Carvalho Chehab <mchehab@redhat.com>.
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com>
s_mode is no longer used, so remove it.
Signed-off-by: HeungJun, Kim <riverful.kim@samsung.com>
Store the cdev pointer in struct irctl, allocated dynamically as needed,
rather than having a static array. At the same time, recycle some of the
saved memory to nudge the maximum number of lirc devices supported up a
ways -- its not that uncommon these days, now that we have the rc-core
lirc bridge driver, to see a system with at least 4 raw IR receivers.
(consider a mythtv backend with several video capture devices and the
possible need for IR transmit hardware).
Signed-off-by: Jarod Wilson <jarod@redhat.com>
The name 'entity' is used twice in the macro body, once as the macro
argument, and once as a structure field name. This breaks compilation if
the macro is called with its argument not named 'entity'.
Fix this by renaming the macro argument '__e'. This should avoid
namespace clashes.
Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Signed-off-by: Hans Petter Selasky <hselasky@c2i.net>
Add I2C/V4L2 subdev driver for M-5MOLS integrated image signal processor
with 8 Mega Pixel sensor.
Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
When device_add is called in rc_register_device, the rc sysfs nodes show
up, and there's a window in which ir-keytable can be launched via udev
and trigger a show_protocols call, which runs without various rc_dev
fields filled in yet. Add some locking around registration and
store/show_protocols to prevent that from happening.
The problem manifests thusly:
[64692.957872] BUG: unable to handle kernel NULL pointer dereference at 0000000000000090
[64692.957878] IP: [<ffffffffa036a4c1>] show_protocols+0x47/0xf1 [rc_core]
[64692.957890] PGD 19cfc7067 PUD 19cfc6067 PMD 0
[64692.957894] Oops: 0000 [#1] SMP
[64692.957897] last sysfs file: /sys/devices/pci0000:00/0000:00:03.1/usb3/3-1/3-1:1.0/rc/rc2/protocols
[64692.957902] CPU 3
[64692.957903] Modules linked in: redrat3(+) ir_lirc_codec lirc_dev ir_sony_decoder ir_jvc_decoder ir_rc6_decoder ir_rc5_decoder rc_hauppauge ir_nec
_decoder rc_core ip6t_REJECT nf_conntrack_ipv6 nf_defrag_ipv6 ip6table_filter ip6_tables snd_emu10k1_synth snd_emux_synth snd_seq_virmidi snd_seq_mi
di_event snd_seq_midi_emul snd_emu10k1 snd_rawmidi snd_ac97_codec ac97_bus snd_seq snd_pcm snd_seq_device snd_timer snd_page_alloc snd_util_mem pcsp
kr tg3 snd_hwdep emu10k1_gp snd amd64_edac_mod gameport edac_core soundcore edac_mce_amd k8temp shpchp i2c_piix4 lm63 e100 mii uinput ipv6 raid0 rai
d1 ata_generic firewire_ohci pata_acpi firewire_core crc_itu_t sata_svw pata_serverworks floppy radeon ttm drm_kms_helper drm i2c_algo_bit i2c_core
[last unloaded: redrat3]
[64692.957949] [64692.957952] Pid: 12265, comm: ir-keytable Tainted: G M W 2.6.39-rc6+ #2 empty empty/TYAN Thunder K8HM S3892
[64692.957957] RIP: 0010:[<ffffffffa036a4c1>] [<ffffffffa036a4c1>] show_protocols+0x47/0xf1 [rc_core]
[64692.957962] RSP: 0018:ffff880194509e38 EFLAGS: 00010202
[64692.957964] RAX: 0000000000000000 RBX: ffffffffa036d1e0 RCX: ffffffffa036a47a
[64692.957966] RDX: ffff88019a84d000 RSI: ffffffffa036d1e0 RDI: ffff88019cf2f3f0
[64692.957969] RBP: ffff880194509e68 R08: 0000000000000002 R09: 0000000000000000
[64692.957971] R10: 0000000000000002 R11: 0000000000001617 R12: ffff88019a84d000
[64692.957973] R13: 0000000000001000 R14: ffff8801944d2e38 R15: ffff88019ce5f190
[64692.957976] FS: 00007f0a30c9a720(0000) GS:ffff88019fc00000(0000) knlGS:0000000000000000
[64692.957979] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[64692.957981] CR2: 0000000000000090 CR3: 000000019a8e0000 CR4: 00000000000006e0
[64692.957983] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
[64692.957986] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400
[64692.957989] Process ir-keytable (pid: 12265, threadinfo ffff880194508000, task ffff88019a9fc720)
[64692.957991] Stack:
[64692.957992] 0000000000000002 ffffffffa036d1e0 ffff880194509f58 0000000000001000
[64692.957997] ffff8801944d2e38 ffff88019ce5f190 ffff880194509e98 ffffffff8131484b
[64692.958001] ffffffff8118e923 ffffffff810e9b2f ffff880194509e98 ffff8801944d2e18
[64692.958005] Call Trace:
[64692.958014] [<ffffffff8131484b>] dev_attr_show+0x27/0x4e
[64692.958014] [<ffffffff8118e923>] ? sysfs_read_file+0x94/0x172
[64692.958014] [<ffffffff810e9b2f>] ? __get_free_pages+0x16/0x52
[64692.958014] [<ffffffff8118e94c>] sysfs_read_file+0xbd/0x172
[64692.958014] [<ffffffff8113205e>] vfs_read+0xac/0xf3
[64692.958014] [<ffffffff8113347b>] ? fget_light+0x3a/0xa1
[64692.958014] [<ffffffff811320f2>] sys_read+0x4d/0x74
[64692.958014] [<ffffffff814c19c2>] system_call_fastpath+0x16/0x1b
Its a bit difficult to reproduce, but I'm fairly confident this has
fixed the problem.
This reverts commit c29fcff3daafbf46d64a543c1950bbd206ad8c1c.
Signed-off-by: Bob Liu <lliubbo@gmail.com>
12-bit formats, similar to YUV 4:2:0 occupy 3 bytes for each two pixels
and cannot be described by any of the existing SOC_MBUS_PACKING_* macros.
This patch adds a new one SOC_MBUS_PACKING_1_5X8 to describe such
formats and extends soc_mbus_samples_per_pixel() to support it.
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Recently mediabus pixel format codes have become a part of the user-
space API, at which time their values also have been changed from
contiguous numbers, running from 0 to sparse numbers with values
around 0x1000, 0x2000, 0x3000... This made them unsuitable for the
use as array indices. This patch switches soc-camera internal format
look-ups to not depend on values of those macros.
Signed-off-by: Kassey Lee <ygli@marvell.com>
Signed-off-by: Qing Xu <qingx@marvell.com>
[g.liakhovetski@gmx.de: fixed compiler warning]
Add an soc-camera host livecrop operation to implement live zoom. If
a host driver implements it, it should take care to preserve output
frame format, then live crop doesn't break streaming.
The MT9V032 is a parallel wide VGA sensor from Aptina (formerly Micron)
controlled through I2C.
The driver creates a V4L2 subdevice. It currently supports binning and
cropping, and the gain, auto gain, exposure, auto exposure and test
pattern controls.
Signed-off-by: Detlev Casanova <detlev.casanova@gmail.com>
instances
Add helper inline functions to correctly manage dynamic allocation and
freeing of platform devices. This avoids the ugly code to nullify
device objects.
Acked-by: Magnus Damm <damm@opensource.se>
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6
* 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (42 commits)
[media] media: vb2: correct queue initialization order
[media] media: vb2: fix incorrect v4l2_buffer->flags handling
[media] s5p-fimc: Add support for the buffer timestamps and sequence
[media] s5p-fimc: Fix bytesperline and plane payload setup
[media] s5p-fimc: Do not allow changing format after REQBUFS
[media] s5p-fimc: Fix FIMC3 pixel limits on Exynos4
[media] tda18271: update tda18271c2_rf_cal as per NXP's rev.04 datasheet
[media] tda18271: update tda18271_rf_band as per NXP's rev.04 datasheet
[media] tda18271: fix bad calculation of main post divider byte
[media] tda18271: prog_cal and prog_tab variables should be s32, not u8
[media] tda18271: fix calculation bug in tda18271_rf_tracking_filters_init
[media] omap3isp: queue: Don't corrupt buf->npages when get_user_pages() fails
[media] v4l: Don't register media entities for subdev device nodes
[media] omap3isp: Don't increment node entity use count when poweron fails
[media] omap3isp: lane shifter support
[media] omap3isp: ccdc: support Y10/12, 8-bit bayer fmts
[media] media: add missing 8-bit bayer formats and Y12
[media] v4l: add V4L2_PIX_FMT_Y12 format
cx23885: Fix stv0367 Kconfig dependency
[media] omap3isp: Use isp xclk defines
Fix up trivial conflict (spelink errurs) in drivers/media/video/omap3isp/isp.c
v4l2_device_unregister_subdev() wrongly uses "arg..." instead of "## arg"
in its body. Fix it.
dma_addr_t may not fit into void* on some architectures. To be safe, make
vb2_dma_contig_cookie() return a pointer to dma_addr_t and dereference it
in vb2_dma_contig_plane_paddr() back to dma_addr_t.
Signed-off-by: Pawel Osciak <pawel@osciak.com>
Reported-by: Hans Verkuil <hverkuil@xs4all.nl>
This fixes the problem in which a host driver
sets a personalized sizeimage or bytesperline field,
and gets ignored when doing G_FMT.
Signed-off-by: Sergio Aguirre <saaguirre@ti.com>
There are two "hauppauge-new" keymaps, one with protocol
unknown, and the other with the protocol marked accordingly.
However, both tables are miss-named.
Also, the old rc-hauppauge-new is broken, as it mixes
three different controllers as if they were just one.
This patch solves half of the problem by renaming the
correct keycode table as just rc-hauppauge. This table
contains the codes for the four different types of
remote controllers found on Hauppauge cards, properly
mapped with their different addresses.
create mode 100644 drivers/media/rc/keymaps/rc-hauppauge.c
delete mode 100644 drivers/media/rc/keymaps/rc-rc5-hauppauge-new.c
[Jarod: fix up RC_MAP_HAUPPAUGE defines]
Rather than guess which driver supports core priority handling, require drivers
that do to explicitly set the V4L2_FL_USE_FH_PRIO flag in video_device.
Updated the core prio handling accordingly and set the flag in the three
drivers that do.
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl>
The video_device struct has proper ref counting and its release function
will be called when the last user releases it. But no such support was
available for struct v4l2_device. This made it hard to determine when a
USB driver can release the device if it has multiple device nodes.
With one device node it is easy of course, since when the device node is
released, the whole device can be released.
This patch adds refcounting to v4l2_device. When registering device nodes
the v4l2_device refcount will be increased, when releasing device nodes
it will be decreased. The (optional) release function will be called when
the last device node was released.
Drivers that use v4l2_fh can now use the core framework support of g/s_priority.
Several drivers need to do something when the first filehandle is opened
or the last filehandle is closed. Most implement some use count mechanism,
but if they use v4l2_fh, then you can also just check if this is the only
filehandle for the device node. A simple helper function can do this.
Add two new functions: v4l2_fh_open allocates and initializes a struct v4l2_fh
based on a struct file pointer and v4l2_fh_release releases and frees a struct
v4l2_fh.
Integrate the v4l2_prio_state into the core, ready for use.
One struct v4l2_prio_state is added to v4l2_device and a pointer
to a prio state is added to video_device.
We are going to move priority handling into the v4l2 core. As a consequence
the v4l2_prio helper functions need to be moved into the core videodev
module as well to prevent circular dependencies.
Remote used for TerraTec Cinergy T Stick RC.
Keytable from Martin Groszhauser <mgroszhauser@gmail.com>
Signed-off-by: Antti Palosaari <crope@iki.fi>
Cc: Martin Groszhauser <mgroszhauser@gmail.com>
Cc: TerraTux <TerraTux@terratec.de>
Allow the MIPI-CSI data alignment to be defined in the board setup
as it may be different across various camera sensors.
Add num_clients field to struct s5p_fimc_isp_info to define exactly
size of clients array which simplifies a bit the sensors management.
Some buggy sensors generate corrupt frames when the stream is started.
This new operation return the number of corrupt frames to skip when
starting the stream.
Acked-by: Hans Verkuil <hverkuil@xs4all.nl>
This patch adds the VIDIOC_SUBDEV_S_CROP and G_CROP ioctls to the
userland API. CROPCAP is not implemented because it's redundant.
Signed-off-by: Antti Koskipaa <akoskipa@gmail.com>
The three new ioctl VIDIOC_SUBDEV_ENUM_FRAME_INTERVAL,
VIDIOC_SUBDEV_G_FRAME_INTERVAL and VIDIOC_SUBDEV_S_FRAME_INTERVAL can be
used to enumerate and configure a subdev's frame rate from userspace.
Two new video::g/s_frame_interval subdev operations are introduced to
support those ioctls. The existing video::g/s_parm operations are
deprecated and shouldn't be used anymore.
Signed-off-by: Sakari Ailus <sakari.ailus@iki.fi>
Add a userspace API to get, set and enumerate the media format on a
subdev pad.
The format at the output of a subdev usually depends on the format at
its input(s). The try format operation is thus not suitable for probing
format at individual pads, as it can't modify the device state and thus
can't remember the format tried at the input to compute the output
format.
To fix the problem, pass an extra argument to the get/set format
operations to select the 'try' or 'active' format.
The try format is used when probing the subdev. Setting the try format
must not change the device configuration but can store data for later
reuse. Data storage is provided at the file-handle level so applications
probing the subdev concurently won't interfere with each other.
The active format is used when configuring the subdev. It's identical to
the format handled by the usual get/set operations.
Signed-off-by: Stanimir Varbanov <svarbanov@mm-sol.com>
Add a v4l2_subdev_pad_ops structure for the operations that need to be
performed at the pad level such as format-related operations.
Pad format-related operations use v4l2_mbus_framefmt instead of
v4l2_format.
V4L2 sub-devices store pad formats and crop settings in the file handle.
To let drivers initialize those settings properly, add an open operation
that is called when the subdev is opened as well as a corresponding
close operation.
Used for storing subdev information per file handle and hold V4L2 file
handle.
The header defines the v4l2_mbus_framefmt structure which will be used
by the V4L2 subdevs userspace API.
Change the type of the v4l2_mbus_framefmt::code field to __u32, as enum
sizes can differ between different ABIs on the same architectures.
V4L2 subdevices are media entities. As such they need to inherit from
(include) the media_entity structure.
When registering/unregistering the subdevice, the media entity is
automatically registered/unregistered. The entity is acquired on device
open and released on device close.
V4L2 devices are media entities. As such they need to inherit from
When registering/unregistering the device, the media entity is
The pointer will later be used to register/unregister media entities
when registering/unregistering a v4l2_subdev or a video_device.
With the introduction of media devices, device drivers need to store a
pointer to a driver-specific structure in the device's drvdata.
v4l2_device can't claim ownership of the drvdata anymore.
To maintain compatibility with drivers that rely on v4l2_device storing
a pointer to itself in the device's drvdata, v4l2_device_register() will
keep doing so if the drvdata is NULL.
Drivers often need to associate pipeline objects to entities, and to
take stream state into account when configuring entities and links. The
pipeline API helps drivers manage that information.
When starting streaming, drivers call media_entity_pipeline_start(). The
function marks all entities connected to the given entity through
enabled links, either directly or indirectly, as streaming. Similarly,
when stopping the stream, drivers call media_entity_pipeline_stop().
The media_entity_pipeline_start() function takes a pointer to a media
pipeline and stores it in every entity in the graph. Drivers should
embed the media_pipeline structure in higher-level pipeline structures
and can then access the pipeline through the media_entity structure.
Link configuration will fail with -EBUSY by default if either end of the
link is a streaming entity, unless the link is marked with the
MEDIA_LNK_FL_DYNAMIC flag.
Create the following ioctl and implement it at the media device level to
setup links.
- MEDIA_IOC_SETUP_LINK: Modify the properties of a given link
The only property that can currently be modified is the ENABLED link
flag to enable/disable a link. Links marked with the IMMUTABLE link flag
can not be enabled or disabled.
Enabling or disabling a link has effects on entities' use count. Those
changes are automatically propagated through the graph.
Create the following two ioctls and implement them at the media device
level to enumerate entities, pads and links.
- MEDIA_IOC_ENUM_ENTITIES: Enumerate entities and their properties
- MEDIA_IOC_ENUM_LINKS: Enumerate all pads and links for a given entity
Entity IDs can be non-contiguous. Userspace applications should
enumerate entities using the MEDIA_ENT_ID_FLAG_NEXT flag. When the flag
is set in the entity ID, the MEDIA_IOC_ENUM_ENTITIES will return the
next entity with an ID bigger than the requested one.
Only forward links that originate at one of the entity's source pads are
returned during the enumeration process.
