path: root/include/net/9p
2015-04-119p: switch p9_client_read() to passing struct iov_iter *Al Viro
... and make it loop Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-04-119p: switch p9_client_write() to passing it struct iov_iter *Al Viro
... and make it loop until it's done Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-04-11net/9p: switch the guts of p9_client_{read,write}() to iov_iterAl Viro
... and have get_user_pages_fast() mapping fewer pages than requested to generate a short read/write. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-11-06net/9p: remove a comment about pref member which doesn't existRyo Munakata
Signed-off-by: Ryo Munakata <ryomnktml@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-03-259pnet: p9_client->conn field is unused. Remove it.Simon Derr
Signed-off-by: Simon Derr <simon.derr@bull.net> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2014-03-259P: Get rid of REQ_STATUS_FLSHSimon Derr
This request state is mostly useless, and properly implementing it for RDMA would require an extra lock to be taken in handle_recv() and in rdma_cancel() to avoid this race: handle_recv() rdma_cancel() . . . if req->state == SENT req->state = RCVD . . req->state = FLSH So just get rid of it. Signed-off-by: Simon Derr <simon.derr@bull.net> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2014-03-259P: Add cancelled() to the transport functions.Simon Derr
And move transport-specific code out of net/9p/client.c Signed-off-by: Simon Derr <simon.derr@bull.net> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2014-03-259P: Add memory barriers to protect request fields over cb/rpc threads handoffDominique Martinet
We need barriers to guarantee this pattern works as intended: [w] req->rc, 1 [r] req->status, 1 wmb rmb [w] req->status, 1 [r] req->rc Where the wmb ensures that rc gets written before status, and the rmb ensures that if you observe status == 1, rc is the new value. Signed-off-by: Dominique Martinet <dominique.martinet@cea.fr> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2013-09-11Merge tag 'for-linus-3.12-merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs Pull 9p updates from Eric Van Hensbergen: "Minor 9p fixes and tweaks for 3.12 merge window The first fixes namespace issues which causes a kernel NULL pointer dereference, the second fixes uevent handling to work better with udev, and the third switches some code to use srlcpy instead of strncpy in order to be safer. All changes have been baking in for-next for at least 2 weeks" * tag 'for-linus-3.12-merge' of git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs: fs/9p: avoid accessing utsname after namespace has been torn down 9p: send uevent after adding/removing mount_tag attribute fs: 9p: use strlcpy instead of strncpy
2013-08-26fs/9p: avoid accessing utsname after namespace has been torn downWill Deacon
During trinity fuzzing in a kvmtool guest, I stumbled across the following: Unable to handle kernel NULL pointer dereference at virtual address 00000004 PC is at v9fs_file_do_lock+0xc8/0x1a0 LR is at v9fs_file_do_lock+0x48/0x1a0 [<c01e2ed0>] (v9fs_file_do_lock+0xc8/0x1a0) from [<c0119154>] (locks_remove_flock+0x8c/0x124) [<c0119154>] (locks_remove_flock+0x8c/0x124) from [<c00d9bf0>] (__fput+0x58/0x1e4) [<c00d9bf0>] (__fput+0x58/0x1e4) from [<c0044340>] (task_work_run+0xac/0xe8) [<c0044340>] (task_work_run+0xac/0xe8) from [<c002e36c>] (do_exit+0x6bc/0x8d8) [<c002e36c>] (do_exit+0x6bc/0x8d8) from [<c002e674>] (do_group_exit+0x3c/0xb0) [<c002e674>] (do_group_exit+0x3c/0xb0) from [<c002e6f8>] (__wake_up_parent+0x0/0x18) I believe this is due to an attempt to access utsname()->nodename, after exit_task_namespaces() has been called, leaving current->nsproxy->uts_ns as NULL and causing the above dereference. A similar issue was fixed for lockd in 9a1b6bf818e7 ("LOCKD: Don't call utsname()->nodename from nlmclnt_setlockargs"), so this patch attempts something similar for 9pfs. Cc: Eric Van Hensbergen <ericvh@gmail.com> Cc: Ron Minnich <rminnich@sandia.gov> Cc: Latchesar Ionkov <lucho@ionkov.net> Cc: Trond Myklebust <Trond.Myklebust@netapp.com> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2013-07-309p: client: remove unused code and any reference to "cancelled" functionAndi Shyti
This patch reverts commit 80b45261a0b263536b043c5ccfc4ba4fc27c2acc which was implementing a 'cancelled' functionality to notify that a cancelled request will not be replied. This implementation was not used anywhere and therefore removed. Signed-off-by: Andi Shyti <andi@etezian.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-07-079P: Add cancelled() to the transport functions.Simon Derr
RDMA needs to post a buffer for each incoming reply. Hence it needs to keep count of these and needs to be aware of whether a flushed request has received a reply or not. This patch adds the cancelled() callback to the transport modules. It is called when RFLUSH has been received and that the corresponding request will never receive a reply. Signed-off-by: Simon Derr <simon.derr@bull.net> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2013-07-07net/9p: add privport option to 9p tcp transportJim Garlick
If the privport option is specified, the tcp transport binds local address to a reserved port before connecting to the 9p server. In some cases when 9P AUTH cannot be implemented, this is better than nothing. Signed-off-by: Jim Garlick <garlick@llnl.gov> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2013-02-279p: turn fid->dlist into hlistAl Viro
2013-02-129p: Modify struct 9p_fid to use a kuid_t not a uid_tEric W. Biederman
Change struct 9p_fid and it's associated functions to use kuid_t's instead of uid_t. Cc: Eric Van Hensbergen <ericvh@gmail.com> Cc: Ron Minnich <rminnich@gmail.com> Cc: Latchesar Ionkov <lucho@ionkov.net> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2013-02-129p: Modify the stat structures to use kuid_t and kgid_tEric W. Biederman
9p has thre strucrtures that can encode inode stat information. Modify all of those structures to contain kuid_t and kgid_t values. Modify he wire encoders and decoders of those structures to use 'u' and 'g' instead of 'd' in the format string where uids and gids are present. This results in all kuid and kgid conversion to and from on the wire values being performed by the same code in protocol.c where the client is known at the time of the conversion. Cc: Eric Van Hensbergen <ericvh@gmail.com> Cc: Ron Minnich <rminnich@gmail.com> Cc: Latchesar Ionkov <lucho@ionkov.net> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2013-02-129p: Transmit kuid and kgid valuesEric W. Biederman
Modify the p9_client_rpc format specifiers of every function that directly transmits a uid or a gid from 'd' to 'u' or 'g' as appropriate. Modify those same functions to take kuid_t and kgid_t parameters instead of uid_t and gid_t parameters. Cc: Eric Van Hensbergen <ericvh@gmail.com> Cc: Ron Minnich <rminnich@gmail.com> Cc: Latchesar Ionkov <lucho@ionkov.net> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-01-059p: Reduce object size with CONFIG_NET_9P_DEBUGJoe Perches
Reduce object size by deduplicating formats. Use vsprintf extension %pV. Rename P9_DPRINTK uses to p9_debug, align arguments. Add function for _p9_debug and macro to add __func__. Add missing "\n"s to p9_debug uses. Remove embedded function names as p9_debug adds it. Remove P9_EPRINTK macro and convert use to pr_<level>. Add and use pr_fmt and pr_<level>. $ size fs/9p/built-in.o* text data bss dec hex filename 62133 984 16000 79117 1350d fs/9p/built-in.o.new 67342 984 16928 85254 14d06 fs/9p/built-in.o.old $ size net/9p/built-in.o* text data bss dec hex filename 88792 4148 22024 114964 1c114 net/9p/built-in.o.new 94072 4148 23232 121452 1da6c net/9p/built-in.o.old Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-10-24net/9p: Convert net/9p protocol dumps to tracepointsAneesh Kumar K.V
This helps in more control over debugging. root@qemu-img-64:~# ls /pass/123 ls: cannot access /pass/123: No such file or directory root@qemu-img-64:~# cat /sys/kernel/debug/tracing/trace # tracer: nop # # TASK-PID CPU# TIMESTAMP FUNCTION # | | | | | ls-1536 [001] 70.928584: 9p_protocol_dump: clnt 18446612132784021504 P9_TWALK(tag = 1) 000: 16 00 00 00 6e 01 00 01 00 00 00 02 00 00 00 01 010: 00 03 00 31 32 33 00 00 00 ff ff ff ff 00 00 00 ls-1536 [001] 70.928587: <stack trace> => trace_9p_protocol_dump => p9pdu_finalize => p9_client_rpc => p9_client_walk => v9fs_vfs_lookup => d_alloc_and_lookup => walk_component => path_lookupat ls-1536 [000] 70.929696: 9p_protocol_dump: clnt 18446612132784021504 P9_RLERROR(tag = 1) 000: 0b 00 00 00 07 01 00 02 00 00 00 4e 03 00 02 00 010: 00 00 00 00 03 00 02 00 00 00 00 00 ff 43 00 00 ls-1536 [000] 70.929697: <stack trace> => trace_9p_protocol_dump => p9_client_rpc => p9_client_walk => v9fs_vfs_lookup => d_alloc_and_lookup => walk_component => path_lookupat => do_path_lookup Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-10-24fs/9p: change an int to unsigned intDan Carpenter
Without this msize=4294967295 will result in a crash Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-10-24fs/9p: Update zero-copy implementation in 9pAneesh Kumar K.V
* remove lot of update to different data structure * add a seperate callback for zero copy request. * above makes non zero copy code path simpler * remove conditionalizing TREAD/TREADDIR/TWRITE in the zero copy path * Fix the dotu p9_check_errors with zero copy. Add sufficient doc around * Add support for both in and output buffers in zero copy callback * pin and unpin pages in the same context * use helpers instead of defining page offset and rest of page ourself * Fix mem leak in p9_check_errors * Remove 'E' and 'F' in p9pdu_vwritef Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-09-06fs/9p: Use protocol-defined value for lock/getlock 'type' field.Jim Garlick
Signed-off-by: Jim Garlick <garlick@llnl.gov> Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
2011-09-06fs/9p: Add OS dependent open flags in 9p protocolAneesh Kumar K.V
Some of the flags are OS/arch dependent we add a 9p protocol value which maps to asm-generic/fcntl.h values in Linux Based on the original patch from Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
2011-07-23fs/9p: add 9P2000.L unlinkat operationAneesh Kumar K.V
unlinkat - Remove a directory entry size[4] Tunlinkat tag[2] dirfid[4] name[s] flag[4] size[4] Runlinkat tag[2] older Tremove have the below request format size[4] Tremove tag[2] fid[4] The remove message is used to remove a directory entry either file or directory The remove opreation is actually a directory opertation and should ideally have dirfid, if not we cannot represent the fid on server with anything other than name. We will have to derive the directory name from fid in the Tremove request. NOTE: The operation doesn't clunk the unlink fid. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-07-23fs/9p: add 9P2000.L renameat operationAneesh Kumar K.V
renameat - change name of file or directory size[4] Trenameat tag[2] olddirfid[4] oldname[s] newdirfid[4] newname[s] size[4] Rrenameat tag[2] older Trename have the below request format size[4] Trename tag[2] fid[4] newdirfid[4] name[s] The rename message is used to change the name of a file, possibly moving it to a new directory. The rename opreation is actually a directory opertation and should ideally have olddirfid, if not we cannot represent the fid on server with anything other than name. We will have to derive the old directory name from fid in the Trename request. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-07-23fs/9p: Clean-up get_protocol_version() to use strcmpPrem Karat
Signed-off-by: Prem Karat <prem.karat@linux.vnet.ibm.com> Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-07-23net/9p: Remove structure not used in the codeAneesh Kumar K.V
2011-07-239p: clean up packet dump codeEric Van Hensbergen
Switch to generic kernel hexdump library and cleanup macros to be more consistent with the way we do normal debug prints. Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-05-259p: Small cleanup in <net/9p/9p.h>Sasha Levin
There are two small cleanups in this patch: - p9_errstr2errno was declared twice - remove one declaration. - A uint8_t type was mixed in, change it to u8 to match with the rest of the type names and remove dependency. Cc: Eric Van Hensbergen <ericvh@gmail.com> Cc: Ron Minnich <rminnich@sandia.gov> Cc: Latchesar Ionkov <lucho@ionkov.net> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Sasha Levin <levinsasha928@gmail.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-05-259p: typo fixes and minor cleanupsRob Landley
Typo fixes and minor cleanups for v9fs Signed-off-by: Rob Landley <rob@landley.net> Reviewed-by: Venkateswararao Jujjuri (JV) <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-04-15net/9p: nwname should be an unsigned intHarsh Prateek Bora
Signed-off-by: Harsh Prateek Bora <harsh@linux.vnet.ibm.com> Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric VAn Hensbergen <ericvh@gmail.com>
2011-04-159p: revert tsyncfs related changesAneesh Kumar K.V
Now that we use write_inode to flush server cache related to fid, we don't need tsyncfs either fort dotl or dotu protocols. For dotu this helps to do a more efficient server flush. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-03-15net/9p: Implement syncfs 9P operationAneesh Kumar K.V
2011-03-15[net/9p] Small non-IO PDUs for zero-copy supporting transports.Venkateswararao Jujjuri (JV)
If a transport prefers payload to be sent separate from the PDU (P9_TRANS_PREF_PAYLOAD_SEP), there is no need to allocate msize PDU buffers(struct p9_fcall). This patch allocates only upto 4k buffers for this kind of transports and there won't be any change to the legacy transports. Hence, this patch on top of zero copy changes allows user to specify higher msizes through the mount option without hogging the kernel heap. Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-03-15[net/9p] Add preferences to transport layer.Venkateswararao Jujjuri (JV)
This patch adds preferences field to the p9_trans_module. Through this, now transport layer can express its preference about the payload. i.e if payload neds to be part of the PDU or it prefers it to be sent sepearetly so that the transport layer can handle it in a better way. Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-03-15[net/9p] Preparation and helper functions for zero copyVenkateswararao Jujjuri (JV)
This patch prepares p9_fcall structure for zero copy. Added fields send the payload buffer information to the transport layer. In addition it adds a 'private' field for the transport layer to store mapped/pinned page information so that it can be freed/unpinned during req_done. This patch also creates trans_common.[ch] to house helper functions. It adds the following helper functions. p9_release_req_pages - Release pages after the transaction. p9_nr_pages - Return number of pages needed to accomodate the payload. payload_gup - Translates user buffer into kernel pages. Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2010-10-289p: Add datasync to client side TFSYNC/RFSYNC for dotlVenkateswararao Jujjuri (JV)
SYNOPSIS size[4] Tfsync tag[2] fid[4] datasync[4] size[4] Rfsync tag[2] DESCRIPTION The Tfsync transaction transfers ("flushes") all modified in-core data of file identified by fid to the disk device (or other permanent storage device) where that file resides. If datasync flag is specified data will be fleshed but does not flush modified metadata unless that metadata is needed in order to allow a subsequent data retrieval to be correctly handled. Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2010-10-289p: Implement TREADLINK operation for 9p2000.LM. Mohan Kumar
Synopsis size[4] TReadlink tag[2] fid[4] size[4] RReadlink tag[2] target[s] Description Readlink is used to return the contents of the symoblic link referred by fid. Contents of symboic link is returned as a response. target[s] - Contents of the symbolic link referred by fid. Signed-off-by: M. Mohan Kumar <mohan@in.ibm.com> Reviewed-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2010-10-289p: Implement TGETLOCKM. Mohan Kumar
Synopsis size[4] TGetlock tag[2] fid[4] getlock[n] size[4] RGetlock tag[2] getlock[n] Description TGetlock is used to test for the existence of byte range posix locks on a file identified by given fid. The reply contains getlock structure. If the lock could be placed it returns F_UNLCK in type field of getlock structure. Otherwise it returns the details of the conflicting locks in the getlock structure getlock structure: type[1] - Type of lock: F_RDLCK, F_WRLCK start[8] - Starting offset for lock length[8] - Number of bytes to check for the lock If length is 0, check for lock in all bytes starting at the location 'start' through to the end of file pid[4] - PID of the process that wants to take lock/owns the task in case of reply client[4] - Client id of the system that owns the process which has the conflicting lock Signed-off-by: M. Mohan Kumar <mohan@in.ibm.com> Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2010-10-289p: Implement TLOCKM. Mohan Kumar
Synopsis size[4] TLock tag[2] fid[4] flock[n] size[4] RLock tag[2] status[1] Description Tlock is used to acquire/release byte range posix locks on a file identified by given fid. The reply contains status of the lock request flock structure: type[1] - Type of lock: F_RDLCK, F_WRLCK, F_UNLCK flags[4] - Flags could be either of P9_LOCK_FLAGS_BLOCK - Blocked lock request, if there is a conflicting lock exists, wait for that lock to be released. P9_LOCK_FLAGS_RECLAIM - Reclaim lock request, used when client is trying to reclaim a lock after a server restrart (due to crash) start[8] - Starting offset for lock length[8] - Number of bytes to lock If length is 0, lock all bytes starting at the location 'start' through to the end of file pid[4] - PID of the process that wants to take lock client_id[4] - Unique client id status[1] - Status of the lock request, can be P9_LOCK_SUCCESS(0), P9_LOCK_BLOCKED(1), P9_LOCK_ERROR(2) or P9_LOCK_GRACE(3) P9_LOCK_SUCCESS - Request was successful P9_LOCK_BLOCKED - A conflicting lock is held by another process P9_LOCK_ERROR - Error while processing the lock request P9_LOCK_GRACE - Server is in grace period, it can't accept new lock requests in this period (except locks with P9_LOCK_FLAGS_RECLAIM flag set) Signed-off-by: M. Mohan Kumar <mohan@in.ibm.com> Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2010-10-28[9p] Introduce client side TFSYNC/RFSYNC for dotl.Venkateswararao Jujjuri (JV)
SYNOPSIS size[4] Tfsync tag[2] fid[4] size[4] Rfsync tag[2] DESCRIPTION The Tfsync transaction transfers ("flushes") all modified in-core data of file identified by fid to the disk device (or other permanent storage device) where that file resides. Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2010-10-28net/9p: This patch implements TLERROR/RLERROR on the 9P client.Arun R Bharadwaj
Signed-off-by: Arun R Bharadwaj <arun@linux.vnet.ibm.com> Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2010-10-219p: client code cleanupstephen hemminger
Make p9_client_version static since only used in one file. Remove p9_client_auth because it is defined but never used. Compile tested only. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-02net/9p: Implement TXATTRCREATE 9p callAneesh Kumar K.V
TXATTRCREATE: Prepare a fid for setting xattr value on a file system object. size[4] TXATTRCREATE tag[2] fid[4] name[s] attr_size[8] flags[4] size[4] RXATTRCREATE tag[2] txattrcreate gets a fid pointing to xattr. This fid can later be used to set the xattr value. flag value is derived from set Linux setxattr. The manpage says "The flags parameter can be used to refine the semantics of the operation. XATTR_CREATE specifies a pure create, which fails if the named attribute exists already. XATTR_REPLACE specifies a pure replace operation, which fails if the named attribute does not already exist. By default (no flags), the extended attribute will be created if need be, or will simply replace the value if the attribute exists." The actual setxattr operation happens when the fid is clunked. At that point the written byte count and the attr_size specified in TXATTRCREATE should be same otherwise an error will be returned. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2010-08-02net/9p: Implement attrwalk 9p callAneesh Kumar K.V
TXATTRWALK: Descend a ATTR namespace size[4] TXATTRWALK tag[2] fid[4] newfid[4] name[s] size[4] RXATTRWALK tag[2] size[8] txattrwalk gets a fid pointing to xattr. This fid can later be used to read the xattr value. If name is NULL the fid returned can be used to get the list of extended attribute associated to the file system object. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2010-08-029p: Implement LOPENM. Mohan Kumar
Implement 9p2000.L version of open(LOPEN) interface in 9p client. For LOPEN, no need to convert the flags to and from 9p mode to VFS mode. Synopsis: size[4] Tlopen tag[2] fid[4] mode[4] size[4] Rlopen tag[2] qid[13] iounit[4] [Fix mode bit format - jvrao@linux.vnet.ibm.com] Signed-off-by: M. Mohan Kumar <mohan@in.ibm.com> Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbegren <ericvh@gmail.com>
2010-08-02fs/9p: This patch implements TLCREATE for 9p2000.L protocol.Venkateswararao Jujjuri (JV)
SYNOPSIS size[4] Tlcreate tag[2] fid[4] name[s] flags[4] mode[4] gid[4] size[4] Rlcreate tag[2] qid[13] iounit[4] DESCRIPTION The Tlreate request asks the file server to create a new regular file with the name supplied, in the directory (dir) represented by fid. The mode argument specifies the permissions to use. New file is created with the uid if the fid and with supplied gid. The flags argument represent Linux access mode flags with which the caller is requesting to open the file with. Protocol allows all the Linux access modes but it is upto the server to allow/disallow any of these acess modes. If the server doesn't support any of the access mode, it is expected to return error. Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2010-08-029p: Implement TMKDIRM. Mohan Kumar
Implement TMKDIR as part of 2000.L Work Synopsis size[4] Tmkdir tag[2] fid[4] name[s] mode[4] gid[4] size[4] Rmkdir tag[2] qid[13] Description mkdir asks the file server to create a directory with given name, mode and gid. The qid for the new directory is returned with the mkdir reply message. Note: 72 is selected as the opcode for TMKDIR from the reserved list. Signed-off-by: M. Mohan Kumar <mohan@in.ibm.com> Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2010-08-029p: Implement TMKNODM. Mohan Kumar
Synopsis size[4] Tmknod tag[2] fid[4] name[s] mode[4] major[4] minor[4] gid[4] size[4] Rmknod tag[2] qid[13] Description mknod asks the file server to create a device node with given major and minor number, mode and gid. The qid for the new device node is returned with the mknod reply message. [sripathik@in.ibm.com: Fix error handling code] Signed-off-by: M. Mohan Kumar <mohan@in.ibm.com> Signed-off-by: Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
