In some cases it will be useful having the key size used for
encrypting the link. For example, some profiles may restrict
some operations depending on the key length.
The key size is stored in the key that is passed to userspace
using the pin_length field in the key structure.
For now this field is only valid for LE controllers. 3.0+HS
controllers define the Read Encryption Key Size command, this
field is intended for storing the value returned by that
command.
Signed-off-by: Vinicius Costa Gomes <vinicius.gomes@openbossa.org>
Signed-off-by: Gustavo F. Padovan <padovan@profusion.mobi>
As the LTK (the new type of key being handled now) has more data
associated with it, we need to store this extra data and retrieve
the keys based on that data.
Methods for searching for a key and for adding a new LTK are
introduced here.
We need these changes because SMP keys may have more information
associated with them, for example, in the LTK case, it has an
encrypted diversifier (ediv) and a random number (rand).
Since we have the extended LMP features properly implemented, we
should check the LMP_HOST_LE bit to know if the host supports LE.
Signed-off-by: Andre Guedes <andre.guedes@openbossa.org>
This new field holds the extended LMP features value. Some LE
mechanism such as discovery procedure needs to read the extended
LMP features to work properly.
priv and lock are never used
Move blacklisting functions to hci_core.c, so that they can
be used by both management interface and hci socket interface.
Signed-off-by: Antti Julku <antti.julku@nokia.com>
If the pending security level is greater than the current security
level and the link is now encrypted, we should update the link
security level.
This is only useful for LE links, when the only event generated
when SMP is sucessful in the Encrypt Change event.
This adds support for starting SMP Phase 2 Encryption, when the initial
SMP negotiation is successful. This adds the LE Start Encryption and LE
Long Term Key Request commands and related events.
This will allow using the crypto subsystem for encrypting data. As SMP
(Security Manager Protocol) is implemented almost entirely on the host
side and the crypto module already implements the needed methods
(AES-128), it makes sense to use it.
There's now a new module option to enable/disable SMP support.
Signed-off-by: Anderson Briglia <anderson.briglia@openbossa.org>
Fix lines longer than 80 chars in length.
Change-Id: I448077965c5f7723a4a9537977bfa664cfe104fd
Signed-off-by: Waldemar Rymarkiewicz <waldemar.rymarkiewicz@tieto.com>
Add BT_POWER socket option used to control the power
characteristics of the underlying ACL link. When the remote end
has put the link in sniff mode and the host stack wants to send
data we need need to explicitly exit sniff mode to work well with
certain devices (For example, A2DP on Plantronics Voyager 855).
However, this causes problems with HID devices.
Hence, moving into active mode when sending data, irrespective
of who set the sniff mode has been made as a socket option. By
default, we will move into active mode. HID devices can set the
L2CAP socket option to prevent this from happening.
Currently, this has been implemented for L2CAP sockets. This has been
tested with incoming and outgoing L2CAP sockets for HID and A2DP.
Based on discussions on linux-bluetooth and patches submitted by
Andrei Emeltchenko.
Signed-off-by: Jaikumar Ganesh <jaikumar@google.com>
This patch adds a new field (dst_type) to the struct hci_conn which
holds the type of the destination address (bdaddr_t dst). This
approach is needed in order to use the struct hci_conn as an
abstraction of LE connections in HCI Layer. For non-LE this field
is ignored.
This patch also set properly the 'dst_type' field after initializing
LE hci_conn structures.
Change-Id: I1e363bb6de263fdb1fe976a5a16ed5debc9b8c0c
Legacy devices don't re-authenticate the link properly if a link key
already exists. Thus, don't update sec_level for this case even if
hci_auth_complete_evt indicates success. Otherwise the sec_level will
not reflect a real security on the link.
This patch adds a timer to clear 'adv_entries' after three minutes.
After some amount of time, the advertising entries cached during
the last LE scan should be considered expired and they should be
removed from the advertising cache.
It was chosen a three minutes timeout as an initial attempt. This
value might change in future.
This patch implements the LE advertising cache. It stores sensitive
information (bdaddr and bdaddr_type so far) gathered from LE
advertising report events.
Only advertising entries from connectables devices are added to the
cache.
__u16 sco_pkt_type is introduced to struct sockaddr_sco. It allows bitwise
selection of SCO/eSCO packet types. Currently those bits are:
0x0001 HV1 may be used.
0x0002 HV2 may be used.
0x0004 HV3 may be used.
0x0008 EV3 may be used.
0x0010 EV4 may be used.
0x0020 EV5 may be used.
0x0040 2-EV3 may be used.
0x0080 3-EV3 may be used.
0x0100 2-EV5 may be used.
0x0200 3-EV5 may be used.
This is similar to the Packet Type parameter in the HCI Setup Synchronous
Connection Command, except that we are not reversing the logic on the EDR bits.
This makes the use of sco_pkt_tpye forward portable for the use case of
white-listing packet types, which we expect will be the primary use case.
If sco_pkt_type is zero, or userspace uses the old struct sockaddr_sco,
then the default behavior is to allow all packet types.
Packet type selection is just a request made to the Bluetooth chipset, and
it is up to the link manager on the chipset to negiotiate and decide on the
actual packet types used. Furthermore, when a SCO/eSCO connection is eventually
made there is no way for the host stack to determine which packet type was used
(however it is possible to get the link type of SCO or eSCO).
sco_pkt_type is ignored for incoming SCO connections. It is possible
to add this in the future as a parameter to the Accept Synchronous Connection
Command, however its a little trickier because the kernel does not
currently preserve sockaddr_sco data between userspace calls to accept().
The most common use for sco_pkt_type will be to white-list only SCO packets,
which can be done with the hci.h constant SCO_ESCO_MASK.
This patch is motivated by broken Bluetooth carkits such as the Motorolo
HF850 (it claims to support eSCO, but will actually reject eSCO connections
after 5 seconds) and the 2007/2008 Infiniti G35/37 (fails to route audio
if a 2-EV5 packet type is negiotiated). With this patch userspace can maintain
a list of compatible packet types to workaround remote devices such as these.
Based on a patch by Marcel Holtmann.
Rebased to 2.6.39.
Change-Id: Ide1c89574fa4f6f1b9218282e1af17051eb86315
Signed-off-by: Nick Pelly <npelly@google.com>
Legacy pairing is a bit of a problem because on the incoming end it is
impossible to know pairing has begun:
2009-09-18 18:29:24.115692 > HCI Event: Connect Request (0x04) plen 10
bdaddr 00:23:D4:04:51:7A class 0x58020c type ACL
2009-09-18 18:29:24.115966 < HCI Command: Accept Connection Request (0x01|0x0009) plen 7
bdaddr 00:23:D4:04:51:7A role 0x00
Role: Master
2009-09-18 18:29:24.117065 > HCI Event: Command Status (0x0f) plen 4
Accept Connection Request (0x01|0x0009) status 0x00 ncmd 1
2009-09-18 18:29:24.282928 > HCI Event: Role Change (0x12) plen 8
status 0x00 bdaddr 00:23:D4:04:51:7A role 0x00
Role: Master
2009-09-18 18:29:24.291534 > HCI Event: Connect Complete (0x03) plen 11
status 0x00 handle 1 bdaddr 00:23:D4:04:51:7A type ACL encrypt 0x00
2009-09-18 18:29:24.291839 < HCI Command: Read Remote Supported Features (0x01|0x001b) plen 2
handle 1
2009-09-18 18:29:24.292144 > HCI Event: Page Scan Repetition Mode Change (0x20) plen 7
bdaddr 00:23:D4:04:51:7A mode 1
2009-09-18 18:29:24.293823 > HCI Event: Command Status (0x0f) plen 4
Read Remote Supported Features (0x01|0x001b) status 0x00 ncmd 1
2009-09-18 18:29:24.303588 > HCI Event: Max Slots Change (0x1b) plen 3
handle 1 slots 5
2009-09-18 18:29:24.309448 > HCI Event: Read Remote Supported Features (0x0b) plen 11
Features: 0xff 0xff 0x2d 0xfe 0x9b 0xff 0x79 0x83
2009-09-18 18:29:24.345916 < HCI Command: Remote Name Request (0x01|0x0019) plen 10
bdaddr 00:23:D4:04:51:7A mode 2 clkoffset 0x0000
2009-09-18 18:29:24.346923 > HCI Event: Command Status (0x0f) plen 4
Remote Name Request (0x01|0x0019) status 0x00 ncmd 1
2009-09-18 18:29:24.375793 > HCI Event: Remote Name Req Complete (0x07) plen 255
status 0x00 bdaddr 00:23:D4:04:51:7A name 'test'
2009-09-18 18:29:34.332190 < HCI Command: Disconnect (0x01|0x0006) plen 3
handle 1 reason 0x13
There are some mainline patches such as "Add different pairing timeout for
Legacy Pairing" but they do not address the HCI sequence above.
I think the real solution is to avoid using CreateBond(), and instead make
the profile connection immediately. This way both sides will use a longer
timeout because there is a higher level connection in progress, and we will
not end up with the useless HCI sequence above.
In case of pre v2.1 devices authentication request will return
success immediately if the link key already exists without any
authentication process.
That means, it's not possible to re-authenticate the link if you
already have combination key and for instance want to re-authenticate
to get the high security (use 16 digit pin).
Therefore, it's necessary to check security requirements on auth
complete event to prevent not enough secure connection.
Even for keys that shouldn't be stored some use cases require the
knowledge of a new key having been created so that the conclusion of a
successful pairing can be made. Therefore, always send the mgmt_new_key
event but add a store_hint parameter to it to indicate to user space
whether the key should be stored or not.
Signed-off-by: Johan Hedberg <johan.hedberg@nokia.com>
User space shouldn't have any need for the old key type so remove it
from the corresponding Management interface event.
Link keys should only be stored if very specific criteria of the
authentication process are fulfilled. This patch essentially copies the
criteria that user space has so far been using to the kernel side so
that the management interface works properly.
When accepting a pairing request which fulfills the SSP auto-accept
criteria we need to push the request all the way to the user for
confirmation. This patch adds a new hint to the user_confirm_request
management event so user space can know when to show a numeric
comparison dialog and when to show a simple yes/no confirmation dialog.
Some test systems require an arbitrary delay to the auto-accept test
cases for Secure Simple Pairing in order for the tests to pass.
Previously when this was handled in user space it was worked around by
code modifications and recompilation, but now that it's on the kernel
side it's more convenient if there's a debugfs interface for it.
Extend the mgmt_pin_code_request interface to require secure
pin code (16 digit) for authentication.
This is a kernel part of the secure pin code requirement notification
to user space agent.
Code styling fix by Johan Hedberg.
Keep the link key type together with connection and use it to
map security level to link key requirements. Authenticate and/or
encrypt connection if the link is insufficiently secure.
This patch adds a new event to the Management interface to track when
local adapters are discovering remote devices. For now this only tracks
BR/EDR discovery procedures.
This patch adds a new remote_name event to the Management interface
which is sent every time the name of a remote device is resolved (over
BR/EDR).
This patch adds a device_found event to the Management interface. For
now the event only maps to BR/EDR inquiry result HCI events, but in the
future the plan is to also use it for the LE device discovery process.
This patch adds automated creation of the local EIR data based on what
16-bit UUIDs are registered and what the device name is. This should
cover the majority use cases, however things like 32/128-bit UUIDs, TX
power and Device ID will need to be added later to be on par with what
bluetoothd is capable of doing (without the Management interface).
This patch adds commands to add and remove remote OOB data to the managment
interface. Remote data is stored in kernel and can be used by corresponding
HCI commands and events when needed.
Signed-off-by: Szymon Janc <szymon.janc@tieto.com>
This patch adds a command to read local OOB data to the managment interface.
The command maps directly to the Read Local OOB Data HCI command.
This patch adds a new set_local_name management command as well as a
local_name_changed management event. With these user space can both
change the local name as well as monitor changes to it by others.
This patch adds a clear define for the maximum device name length in HCI
messages and thereby avoids magic numbers in the code.
To properly track bonding completion an event to indicate authentication
failure is needed. This event will be sent whenever an authentication
complete HCI event with a non-zero status comes. It will also be sent
when we're acting in acceptor role for SSP authentication in which case
the controller will send a Simple Pairing Complete event.
This patch adds support for the user confirmation (numeric comparison)
Secure Simple Pairing authentication method.
This patch adds a new mgmt_pair_device which can be used to initiate a
dedicated bonding procedure. Some extra callbacks are added to the
hci_conn struct so that the pairing code can get notified of the
completion of the procedure.
If the new connection update parameter are accepted, the LE master
host sends the LE Connection Update Command to its controller informing
the new requested parameters.
Signed-off-by: Claudio Takahasi <claudio.takahasi@openbossa.org>
Use proper timer instead of hci command flow control to timeout
failed hci commands. Otherwise stack ends up sending commands
when flow control is used to block new commands.
2010-09-01 18:29:41.592132 < HCI Command: Remote Name Request (0x01|0x0019) plen 10
bdaddr 00:16:CF:E1:C7:D7 mode 2 clkoffset 0x0000
2010-09-01 18:29:41.592681 > HCI Event: Command Status (0x0f) plen 4
Remote Name Request (0x01|0x0019) status 0x00 ncmd 0
2010-09-01 18:29:51.022033 < HCI Command: Remote Name Request Cancel (0x01|0x001a) plen 6
Signed-off-by: Ville Tervo <ville.tervo@nokia.com>
Bluetooth chips may have separate buffers for LE traffic.
This patch add support to use LE buffers provided by the chip.
Acked-by: Marcel Holtmann <marcel@holtmann.org>
Bluetooth V4.0 adds support for Low Energy (LE) connections.
Specification introduces new set of hci commands to control LE
connection. This patch adds logic to create, cancel and disconnect
LE connections.
This patch adds a new set_io_capability management command which is used
to set the IO capability for Secure Simple Pairing (SSP) as well as the
Security Manager Protocol (SMP). The value is per hci_dev and each
hci_conn object inherits it upon creation.
This patch adds the necessary commands and events needed to communicate
PIN code related actions between the kernel and userspace. This includes
a pin_code_request event as well as pin_code_reply and
pin_code_negative_reply commands.
This patch add a new connect failed management event to track failures
in connecting to remote devices. It is particularly useful for security
mode 3 scenarios when we don't have a connected state while pairing but
still need to detect when the connect attempt failed.
This patch adds a disconnect command to the managment interface. Using
this command user space is able to force the disconnection of connected
devices. The command maps directly to the Disconnect HCI command.
This patch adds connected and disconnected managment events to track the
connection status to remote devices. The events map directly to
successful connection complete and disconnection complete HCI events for
ACL links.
This patch adds a management commands to feed the kernel with all stored
link keys as well as remove specific ones or all of them. Once the
load_keys command has been called the kernel takes over link key
replies. A new_key event is also added to inform userspace of newly
created link keys that should be stored permanently.
This patch adds the possibility for user space to fully control the
Class of Device value of local adapters. To control the service class
bits each UUID that's added comes with a service class "hint" which acts
as a mask of bits that the UUID needs to have enabled. The
set_service_cache management command is used to make sure we queue up
all UUID changes as user space initializes its drivers and then send a
single HCI_Write_Class_of_Device command when initialization is
complete.
