path: root/include/net/dcbnl.h
2015-03-06net/dcb: Add IEEE QCN attributeShani Michaeli
As specified in 802.1Qau spec. Add this optional attribute to the DCB netlink layer. To allow for application to use the new attribute, NIC drivers should implement and register the callbacks ieee_getqcn, ieee_setqcn and ieee_getqcnstats. The QCN attribute holds a set of parameters for management, and a set of statistics to provide informative data on Congestion-Control defined by this spec. Signed-off-by: Shani Michaeli <shanim@mellanox.com> Signed-off-by: Shachar Raindel <raindel@mellanox.com> Signed-off-by: Or Gerlitz <ogerlitz@mellanox.com> Acked-by: John Fastabend <john.r.fastabend@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-07-17Update setapp/getapp prototypes in dcbnl_rtnl_ops to return int instead of u8Anish Bhatt
v2: fixed issue with checking return of dcbnl_rtnl_ops->getapp() Signed-off-by: Anish Bhatt <anish@chelsio.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-12-06include/net/: Fix FSF address in file headersJeff Kirsher
Several files refer to an old address for the Free Software Foundation in the file header comment. Resolve by replacing the address with the URL <http://www.gnu.org/licenses/> so that we do not have to keep updating the header comments anytime the address changes. Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-05net/dcb: Add an optional max rate attributeAmir Vadai
Although not specified in 8021Qaz spec, it could be useful to enable drivers whose HW supports setting a rate limit for an ETS TC. This patch adds this optional attribute to DCB netlink. To use it, drivers should implement and register the callbacks ieee_setmaxrate and ieee_getmaxrate. The units are 64 bits long and specified in Kbps to enable usage over both slow and very fast networks. Signed-off-by: Amir Vadai <amirv@mellanox.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-03-02net: dcb: getnumtcs()/setnumtcs() should return an intJohn Fastabend
{g|s}etnumtcs() today returns a u8 that is only used by the DCB code to verify no error occurred. Today the driver implementations return negative error codes which end up being non-zero so the logic works out but triggers some sparse warnings. To fix the sparse warnings convert the return value to an int. CC: Eilon Greenstein <eilong@broadcom.com> Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: John Fastabend <john.r.fastabend@intel.com> Tested-by: Ross Brattain <ross.b.brattain@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2011-10-06dcb: add DCBX mode to event notifier attributesJohn Fastabend
Add DCBX mode to event notifiers so listeners can learn currently enabled mode. Signed-off-by: John Fastabend <john.r.fastabend@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-10-06dcb: Use ifindex instead of ifnameMark Rustad
Use ifindex instead of ifname in the DCB app ring. This makes for a smaller data structure and faster comparisons. It also avoids possible issues when a net device is renamed. Signed-off-by: Mark Rustad <mark.d.rustad@intel.com> Signed-off-by: John Fastabend <john.r.fastabend@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-05dcbnl: Add CEE notificationShmulik Ravid
This patch add an unsolicited notification of the DCBX negotiated parameters for the CEE flavor of the DCBX protocol. The notification message is identical to the aggregated CEE get operation and holds all the pertinent local and peer information. The notification routine is exported so it can be invoked by drivers supporting an embedded DCBX stack. Signed-off-by: Shmulik Ravid <shmulikr@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-21dcb: fix return type on dcb_setapp()John Fastabend
Incorrect return type on dcb_setapp() this routine returns negative error codes. All call sites of dcb_setapp() assign the return value to an int already so no need to update drivers. Signed-off-by: John Fastabend <john.r.fastabend@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-21dcb: Add dcb_ieee_getapp_mask() for drivers to query APP settingsJohn Fastabend
With multiple APP entries per selector and protocol drivers or stacks may want to pick a specific value or stripe traffic across many priorities. Also if an APP entry in use is deleted the stack/driver may want to choose from the existing APP entries. To facilitate this and avoid having duplicate code to walk the APP ring provide a routine dcb_ieee_getapp_mask() to return a u8 bitmask of all priorities set for the specified selector and protocol. This routine and bitmask is a helper for DCB kernel users. Signed-off-by: John Fastabend <john.r.fastabend@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-21dcb: Add ieee_dcb_delapp() and dcb op to delete app entryJohn Fastabend
Now that we allow multiple IEEE App entries we need a way to remove specific entries. To do this add the ieee_dcb_delapp() routine. Additionaly drivers may need to remove the APP entry from their firmware tables. Add dcb ops routine to handle this. Signed-off-by: John Fastabend <john.r.fastabend@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-21dcb: Add ieee_dcb_setapp() to be used for IEEE 802.1Qaz APP dataJohn Fastabend
This adds a setapp routine for IEEE802.1Qaz encoded APP data types. The IEEE 802.1Qaz spec encodes the priority bits differently and allows for multiple APP data entries of the same selector and protocol. Trying to force these to use the same set routines was becoming tedious. Furthermore, userspace could probably enforce the correct semantics, but expecting drivers to do this seems error prone in the firmware case. For these reasons add ieee_dcb_setapp() that understands the IEEE 802.1Qaz encoded form. Signed-off-by: John Fastabend <john.r.fastabend@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-21net: dcbnl, add multicast group for DCBJohn Fastabend
Now that dcbnl is being used in many cases by more than a single agent it is beneficial to be notified when some entity either driver or user space has changed the DCB attributes. Today applications either end up polling the interface or relying on a user space database to maintain the DCB state and post events. Polling is a poor solution for obvious reasons. And relying on a user space database has its own downside. Namely it has created strange boot dependencies requiring the database be populated before any applications dependent on DCB attributes starts or the application goes into a polling loop. Populating the database requires negotiating link setting with the peer and can take anywhere from less than a second up to a few seconds depending on the switch implementation. Perhaps more importantly if another application or an embedded agent sets a DCB link attribute the database has no way of knowing other than polling the kernel. This prevents applications from responding quickly to changes in link events which at least in the FCoE case and probably any other protocols expecting a lossless link may result in IO errors. By adding a multicast group for DCB we have clean way to disseminate kernel DCB link attributes up to user space. Avoiding the need for user space to maintain a coherant database and disperse events that potentially do not reflect the current link state. Signed-off-by: John Fastabend <john.r.fastabend@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-02dcbnl: add support for retrieving peer configuration - ceeShmulik Ravid
This patch adds the support for retrieving the remote or peer DCBX configuration via dcbnl for embedded DCBX stacks supporting the CEE DCBX standard. Signed-off-by: Shmulik Ravid <shmulikr@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-02dcbnl: add support for retrieving peer configuration - ieeeShmulik Ravid
These 2 patches add the support for retrieving the remote or peer DCBX configuration via dcbnl for embedded DCBX stacks. The peer configuration is part of the DCBX MIB and is useful for debugging and diagnostics of the overall DCB configuration. The first patch add this support for IEEE 802.1Qaz standard the second patch add the same support for the older CEE standard. Diff for v2 - the peer-app-info is CEE specific. Signed-off-by: Shmulik Ravid <shmulikr@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-31dcbnl: adding DCBX feature flags get-setShmulik Ravid
Adding a pair of set-get routines to dcbnl for setting the negotiation flags of the various DCB features. Conforms to the CEE flavor of DCBX The user sets these flags (enable, advertise, willing) for each feature to be used by the DCBX engine. The 'get' routine returns which of the features is enabled after the negotiation. This patch is dependent on the following patches: [net-next-2.6 PATCH 1/3] dcbnl: add support for ieee8021Qaz attributes [net-next-2.6 PATCH 2/3] dcbnl: add appliction tlv handlers [net-next-2.6 PATCH 3/3] net_dcb: add application notifiers Signed-off-by: Shmulik Ravid <shmulikr@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-31dcbnl: adding DCBX engine capabilityShmulik Ravid
Adding an optional DCBX capability and a pair for get-set routines for setting the device DCBX mode. The DCBX capability is a bit field of supported attributes. The user is expected to set the DCBX mode with a subset of the advertised attributes. This patch is dependent on the following patches: [net-next-2.6 PATCH 1/3] dcbnl: add support for ieee8021Qaz attributes [net-next-2.6 PATCH 2/3] dcbnl: add appliction tlv handlers [net-next-2.6 PATCH 3/3] net_dcb: add application notifiers Signed-off-by: Shmulik Ravid <shmulikr@broadcom.com> Acked-by: John Fastabend <john.r.fastabend@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-31dcbnl: add appliction tlv handlersJohn Fastabend
This patch adds application tlv handlers. Networking stacks may use the application priority to set the skb priority of their stack using the negoatiated dcbx priority. This patch provides the dcb_{get|set}app() routines for the stack to query these parameters. Notice lower layer drivers can use the dcbnl_ops routines if additional handling is needed. Perhaps in the firmware case for example Signed-off-by: John Fastabend <john.r.fastabend@intel.com> Signed-off-by: Shmulik Ravid <shmulikr@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-31dcbnl: add support for ieee8021Qaz attributesJohn Fastabend
The IEEE8021Qaz is the IEEE standard version of CEE. The standard has had enough significant changes from the CEE version that many of the CEE attributes have no meaning in the new spec or do not easily map to IEEE standards. Rather then attempt to create a complicated mapping between CEE and IEEE standards this patch adds a nested IEEE attribute to the list of DCB attributes. The policy is, [DCB_ATTR_IFNAME] [DCB_ATTR_STATE] ... [DCB_ATTR_IEEE] [DCB_ATTR_IEEE_ETS] [DCB_ATTR_IEEE_PFC] [DCB_ATTR_IEEE_APP_TABLE] [DCB_ATTR_IEEE_APP] ... The following dcbnl_rtnl_ops routines were added to handle the IEEE standard, int (*ieee_getets) (struct net_device *, struct ieee_ets *); int (*ieee_setets) (struct net_device *, struct ieee_ets *); int (*ieee_getpfc) (struct net_device *, struct ieee_pfc *); int (*ieee_setpfc) (struct net_device *, struct ieee_pfc *); int (*ieee_getapp) (struct net_device *, struct dcb_app *); int (*ieee_setapp) (struct net_device *, struct dcb_app *); Signed-off-by: John Fastabend <john.r.fastabend@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-01dcbnl: Add support for setapp/getapp to netdev dcbnl_rtnl_opsYi Zou
Adds support of dcbnl setapp/getapp to dcbnl_rtnl_ops in netdev to allow LLDs to implement their corresponding dcbnl setapp/getapp ops to support the IEEE 802.1Q DCBX setapp/getapp commands. Signed-off-by: Yi Zou <yi.zou@intel.com> Acked-by: Peter P Waskiewicz Jr <peter.p.waskiewicz.jr@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-21net: fix DCB setstate to return success/failureDon Skidmore
Data Center Bridging (DCB) had no way to know if setstate had failed in the driver. This patch enables dcb netlink code to handle the status for the DCB setstate interface. Likewise it allows the driver to return a failed status if MSI-X isn't enabled. Signed-off-by: Don Skidmore <donald.c.skidmore@intel.com> Signed-off-by: Eric W Multanen <eric.w.multanen@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-20DCB: Add support for DCB BCNAlexander Duyck
Adds an interface to configure the Backward Congestion Notification (BCN) feature. In a BCN capabale network, congestion notifications from congested points out in the network can cause the end station limit the rate of a given traffic flow. Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: Peter P Waskiewicz Jr <peter.p.waskiewicz.jr@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-20DCB: Add interface to query the state of PFC feature.Alexander Duyck
Adds a netlink interface for Data Center Bridging (DCB) to get and set the enable state of the Priority Flow Control (PFC) feature. Primarily, this is a way to turn off PFC in the driver while DCB remains enabled. Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: Peter P Waskiewicz Jr <peter.p.waskiewicz.jr@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-20DCB: Add interface to query # of TCs supported by deviceAlexander Duyck
Adds interface for Data Center Bridging (DCB) to query (and set if supported) the number of traffic classes currently supported by the device for the two (DCB) features: priority groups (PG) and priority flow control (PFC). Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: Peter P Waskiewicz Jr <peter.p.waskiewicz.jr@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-20DCB: Add interface to query for the DCB capabilities of an device.Alexander Duyck
Adds to the netlink interface for Data Center Bridging (DCB), allowing the DCB capabilities supported by a device to be queried. Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: Peter P Waskiewicz Jr <peter.p.waskiewicz.jr@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-20ixgbe: this patch adds support for DCB to the kernel and ixgbe driverAlexander Duyck
This adds support for Data Center Bridging (DCB) features in the ixgbe driver and adds an rtnetlink interface for configuring DCB to the kernel. The DCB feature support included are Priority Grouping (PG) - which allows bandwidth guarantees to be allocated to groups to traffic based on the 802.1q priority, and Priority Based Flow Control (PFC) - which introduces a new MAC control PAUSE frame which works at granularity of the 802.1p priority instead of the link (IEEE 802.3x). Signed-off-by: Alexander Duyck <alexander.h.duyck@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: Peter P Waskiewicz Jr <peter.p.waskiewicz.jr@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
