[ Upstream commit 258a980d1ec23e2c786e9536a7dd260bea74bae6 ]
When storing a pointer to a dst_metrics structure in dst_entry._metrics,
two flags are added in the least significant bits of the pointer value.
Hence this assumes all pointers to dst_metrics structures have at least
4-byte alignment.
However, on m68k, the minimum alignment of 32-bit values is 2 bytes, not
4 bytes. Hence in some kernel builds, dst_default_metrics may be only
2-byte aligned, leading to obscure boot warnings like:
WARNING: CPU: 0 PID: 7 at lib/refcount.c:28 refcount_warn_saturate+0x44/0x9a
refcount_t: underflow; use-after-free.
Modules linked in:
CPU: 0 PID: 7 Comm: ksoftirqd/0 Tainted: G W 5.5.0-rc2-atari-01448-g114a1a1038af891d-dirty #261
Stack from 10835e6c:
10835e6c 0038134f 00023fa6 00394b0f 0000001c 00000009 00321560 00023fea
00394b0f 0000001c 001a70f8 00000009 00000000 10835eb4 00000001 00000000
04208040 0000000a 00394b4a 10835ed4 00043aa8 001a70f8 00394b0f 0000001c
00000009 00394b4a 0026aba8 003215a4 00000003 00000000 0026d5a8 00000001
003215a4 003a4361 003238d6 000001f0 00000000 003215a4 10aa3b00 00025e84
003ddb00 10834000 002416a8 10aa3b00 00000000 00000080 000aa038 0004854a
Call Trace: [<00023fa6>] __warn+0xb2/0xb4
[<00023fea>] warn_slowpath_fmt+0x42/0x64
[<001a70f8>] refcount_warn_saturate+0x44/0x9a
[<00043aa8>] printk+0x0/0x18
[<0026aba8>] refcount_sub_and_test.constprop.73+0x38/0x3e
[<0026d5a8>] ipv4_dst_destroy+0x5e/0x7e
[<00025e84>] __local_bh_enable_ip+0x0/0x8e
[<002416a8>] dst_destroy+0x40/0xae
Fix this by forcing 4-byte alignment of all dst_metrics structures.
Fixes: e5fd387ad5b30ca3 ("ipv6: do not overwrite inetpeer metrics prematurely")
[ Upstream commit 3fb07daff8e99243366a081e5129560734de4ada ]
Andrey Konovalov reported crashes in ipv4_mtu()
I could reproduce the issue with KASAN kernels, between
10.246.7.151 and 10.246.7.152 :
1) 20 concurrent netperf -t TCP_RR -H 10.246.7.152 -l 1000 &
2) At the same time run following loop :
while :
do
ip ro add 10.246.7.152 dev eth0 src 10.246.7.151 mtu 1500
ip ro del 10.246.7.152 dev eth0 src 10.246.7.151 mtu 1500
done
Cong Wang attempted to add back rt->fi in commit
82486aa6f1b9 ("ipv4: restore rt->fi for reference counting")
but this proved to add some issues that were complex to solve.
Instead, I suggested to add a refcount to the metrics themselves,
being a standalone object (in particular, no reference to other objects)
I tried to make this patch as small as possible to ease its backport,
instead of being super clean. Note that we believe that only ipv4 dst
need to take care of the metric refcount. But if this is wrong,
this patch adds the basic infrastructure to extend this to other
families.
Many thanks to Julian Anastasov for reviewing this patch, and Cong Wang
for his efforts on this problem.
Fixes: 2860583fe840 ("ipv4: Kill rt->fi")
Reported-by: Andrey Konovalov <andreyknvl@google.com>
Reviewed-by: Julian Anastasov <ja@ssi.bg>
Acked-by: Cong Wang <xiyou.wangcong@gmail.com>
Commit 751a587ac9f9 ("route: fix breakage after moving lwtunnel state")
moved lwtstate to the end of dst_entry for 32bit archs. This makes it share
the cacheline with __refcnt which had an unkown effect on performance. For
this reason, the pointer was kept in place for 64bit archs.
However, later performance measurements showed this is of no concern. It
turns out that every performance sensitive path that accesses lwtstate
accesses also struct rtable or struct rt6_info which share the same cache
line.
Thus, to get rid of a few #ifdefs, move the field to the end of the struct
also for 64bit.
Signed-off-by: Jiri Benc <jbenc@redhat.com>
We can just add a small helper dst_tclassid() for retrieving the
dst->tclassid value. It makes the code a bit better in that we can
get rid of the ifdef from filter.c by moving this into the header.
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
David Wilder reported crashes caused by dst reuse.
<quote David>
I am seeing a crash on a distro V4.2.3 kernel caused by a double
release of a dst_entry. In ipv4_dst_destroy() the call to
list_empty() finds a poisoned next pointer, indicating the dst_entry
has already been removed from the list and freed. The crash occurs
18 to 24 hours into a run of a network stress exerciser.
</quote>
Thanks to his detailed report and analysis, we were able to understand
the core issue.
IP early demux can associate a dst to skb, after a lookup in TCP/UDP
sockets.
When socket cache is not properly set, we want to store into
sk->sk_dst_cache the dst for future IP early demux lookups,
by acquiring a stable refcount on the dst.
Problem is this acquisition is simply using an atomic_inc(),
which works well, unless the dst was queued for destruction from
dst_release() noticing dst refcount went to zero, if DST_NOCACHE
was set on dst.
We need to make sure current refcount is not zero before incrementing
it, or risk double free as David reported.
This patch, being a stable candidate, adds two new helpers, and use
them only from IP early demux problematic paths.
It might be possible to merge in net-next skb_dst_force() and
skb_dst_force_safe(), but I prefer having the smallest patch for stable
kernels : Maybe some skb_dst_force() callers do not expect skb->dst
can suddenly be cleared.
Can probably be backported back to linux-3.6 kernels
Reported-by: David J. Wilder <dwilder@us.ibm.com>
Tested-by: David J. Wilder <dwilder@us.ibm.com>
The network namespace is already passed into dst_output pass it into
dst->output lwt->output and friends.
Replace dst_output_okfn with dst_output
Very soon, TCP stack might call inet_csk_route_req(), which
calls inet_csk_route_req() with an unlocked listener socket,
so we need to make sure ip_route_output_flow() is not trying to
change any field from its socket argument.
This is immediately motivated by the bridge code that chains functions that
call into netfilter. Without passing net into the okfns the bridge code would
need to guess about the best expression for the network namespace to process
packets in.
As net is frequently one of the first things computed in continuation functions
after netfilter has done it's job passing in the desired network namespace is in
many cases a code simplification.
To support this change the function dst_output_okfn is introduced to
simplify passing dst_output as an okfn. For the moment dst_output_okfn
just silently drops the struct net.
Add a sock paramter to dst_output making dst_output_sk superfluous.
Add a skb->sk parameter to all of the callers of dst_output
Have the callers of dst_output_sk call dst_output.
Currently, the following case doesn't use DCTCP, even if it should:
A responder has f.e. Cubic as system wide default, but for a specific
route to the initiating host, DCTCP is being set in RTAX_CC_ALGO. The
initiating host then uses DCTCP as congestion control, but since the
initiator sets ECT(0), tcp_ecn_create_request() doesn't set ecn_ok,
and we have to fall back to Reno after 3WHS completes.
We were thinking on how to solve this in a minimal, non-intrusive
way without bloating tcp_ecn_create_request() needlessly: lets cache
the CA ecn option flag in RTAX_FEATURES. In other words, when ECT(0)
is set on the SYN packet, set ecn_ok=1 iff route RTAX_FEATURES
contains the unexposed (internal-only) DST_FEATURE_ECN_CA. This allows
to only do a single metric feature lookup inside tcp_ecn_create_request().
Joint work with Florian Westphal.
This variation on skb_dst_copy() doesn't require two skbs.
Signed-off-by: Joe Stringer <joestringer@nicira.com>
Acked-by: Pravin B Shelar <pshelar@nicira.com>
Acked-by: Thomas Graf <tgraf@suug.ch>
__recnt and related fields need to be in its own cacheline for performance
reasons. Commit 61adedf3e3f1 ("route: move lwtunnel state to dst_entry")
broke that on 32bit archs, causing BUILD_BUG_ON in dst_hold to be triggered.
This patch fixes the breakage by moving the lwtunnel state to the end of
dst_entry on 32bit archs. Unfortunately, this makes it share the cacheline
with __refcnt and may affect performance, thus further patches may be
needed.
Reported-by: kbuild test robot <fengguang.wu@intel.com>
Fixes: 61adedf3e3f1 ("route: move lwtunnel state to dst_entry")
Currently, the lwtunnel state resides in per-protocol data. This is
a problem if we encapsulate ipv6 traffic in an ipv4 tunnel (or vice versa).
The xmit function of the tunnel does not know whether the packet has been
routed to it by ipv4 or ipv6, yet it needs the lwtstate data. Moving the
lwtstate data to dst_entry makes such inter-protocol tunneling possible.
As a bonus, this brings a nice diffstat.
Acked-by: Roopa Prabhu <roopa@cumulusnetworks.com>
Introduces a new dst_metadata which enables to carry per packet metadata
between forwarding and processing elements via the skb->dst pointer.
The structure is set up to be a union. Thus, each separate type of
metadata requires its own dst instance. If demand arises to carry
multiple types of metadata concurrently, metadata dst entries can be
made stackable.
The metadata dst entry is refcnt'ed as expected for now but a non
reference counted use is possible if the reference is forced before
queueing the skb.
In order to allow allocating dsts with variable length, the existing
dst_alloc() is split into a dst_alloc() and dst_init() function. The
existing dst_init() function to initialize the subsystem is being
renamed to dst_subsys_init() to make it clear what is what.
The check before ip_route_input() is changed to ignore metadata dsts
and drop the dst inside the routing function thus allowing to interpret
metadata in a later commit.
Signed-off-by: Thomas Graf <tgraf@suug.ch>
As xfrm_output_one() is the only caller of skb_dst_pop(), we should
make skb_dst_pop() localized.
Signed-off-by: Ying Xue <ying.xue@windriver.com>
_rt6i_peer is no longer needed after the last patch,
'ipv6: Stop rt6_info from using inet_peer's metrics'.
DST_METRICS_FORCE_OVERWRITE is added by
commit e5fd387ad5b3 ("ipv6: do not overwrite inetpeer metrics prematurely").
Since inetpeer is no longer used for metrics, this bit is also not needed.
Signed-off-by: Martin KaFai Lau <kafai@fb.com>
Reviewed-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
Cc: Michal Kubeček <mkubecek@suse.cz>
Cc: Steffen Klassert <steffen.klassert@secunet.com>
dst_orig should be released on error. Function like __xfrm_route_forward()
expects that behavior.
Since a recent commit, xfrm_lookup() may also be called by xfrm_lookup_route(),
which expects the opposite.
Let's introduce a new flag (XFRM_LOOKUP_KEEP_DST_REF) to tell what should be
done in case of error.
Fixes: f92ee61982d("xfrm: Generate blackhole routes only from route lookup functions")
Signed-off-by: huaibin Wang <huaibin.wang@6wind.com>
Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
Currently we genarate a queueing route if we have matching policies
but can not resolve the states and the sysctl xfrm_larval_drop is
disabled. Here we assume that dst_output() is called to kill the
queued packets. Unfortunately this assumption is not true in all
cases, so it is possible that these packets leave the system unwanted.
We fix this by generating queueing routes only from the
route lookup functions, here we can guarantee a call to
dst_output() afterwards.
Fixes: a0073fe18e71 ("xfrm: Add a state resolution packet queue")
Reported-by: Konstantinos Kolelis <k.kolelis@sirrix.com>
Currently we genarate a blackhole route route whenever we have
matching policies but can not resolve the states. Here we assume
that dst_output() is called to kill the balckholed packets.
Unfortunately this assumption is not true in all cases, so
We fix this by generating blackhole routes only from the
Fixes: 2774c131b1d ("xfrm: Handle blackhole route creation via afinfo.")
In the dst->output() path for ipv4, the code assumes the skb it has to
transmit is attached to an inet socket, specifically via
ip_mc_output() : The sk_mc_loop() test triggers a WARN_ON() when the
provider of the packet is an AF_PACKET socket.
The dst->output() method gets an additional 'struct sock *sk'
parameter. This needs a cascade of changes so that this parameter can
be propagated from vxlan to final consumer.
Fixes: 8f646c922d55 ("vxlan: keep original skb ownership")
Reported-by: lucien xin <lucien.xin@gmail.com>
If an IPv6 host route with metrics exists, an attempt to add a
new route for the same target with different metrics fails but
rewrites the metrics anyway:
12sp0:~ # ip route add fec0::1 dev eth0 rto_min 1000
12sp0:~ # ip -6 route show
fe80::/64 dev eth0 proto kernel metric 256
fec0::1 dev eth0 metric 1024 rto_min lock 1s
12sp0:~ # ip route add fec0::1 dev eth0 rto_min 1500
RTNETLINK answers: File exists
fec0::1 dev eth0 metric 1024 rto_min lock 1.5s
This is caused by all IPv6 host routes using the metrics in
their inetpeer (or the shared default). This also holds for the
new route created in ip6_route_add() which shares the metrics
with the already existing route and thus ip6_route_add()
rewrites the metrics even if the new route ends up not being
used at all.
Another problem is that old metrics in inetpeer can reappear
unexpectedly for a new route, e.g.
12sp0:~ # ip route del fec0::1
12sp0:~ # ip route change fec0::1 dev eth0 hoplimit 10
fec0::1 dev eth0 metric 1024 hoplimit 10 rto_min lock 1s
Resolve the first problem by moving the setting of metrics down
into fib6_add_rt2node() to the point we are sure we are
inserting the new route into the tree. Second problem is
addressed by introducing new flag DST_METRICS_FORCE_OVERWRITE
which is set for a new host route in ip6_route_add() and makes
ipv6_cow_metrics() always overwrite the metrics in inetpeer
(even if they are not "new"); it is reset after that.
v5: use a flag in _metrics member rather than one in flags
v4: fix a typo making a condition always true (thanks to Hannes
Frederic Sowa)
v3: rewritten based on David Miller's idea to move setting the
metrics (and allocation in non-host case) down to the point we
already know the route is to be inserted. Also rebased to
net-next as it is quite late in the cycle.
Signed-off-by: Michal Kubecek <mkubecek@suse.cz>
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
Commit e688a604807647 ("net: introduce DST_NOPEER dst flag") introduced
DST_NOPEER because because of crashes in ipv6_select_ident called from
udp6_ufo_fragment.
Since commit 916e4cf46d0204 ("ipv6: reuse ip6_frag_id from
ip6_ufo_append_data") we don't call ipv6_select_ident any more from
ip6_ufo_append_data, thus this flag lost its purpose and can be removed.
In several places 'skb->rxhash = 0' is being done to clear the
rxhash value in an skb. This does not clear l4_rxhash which could
still be set so that the rxhash wouldn't be recalculated on subsequent
call to skb_get_rxhash. This patch adds an explict function to clear
all the rxhash related information in the skb properly.
skb_clear_hash_if_not_l4 clears the rxhash only if it is not marked as
l4_rxhash.
Fixed up places where 'skb->rxhash = 0' was being called.
Signed-off-by: Tom Herbert <therbert@google.com>
drivers/net/usb/qmi_wwan.c
include/net/dst.h
Trivial merge conflicts, both were overlapping changes.
dst->xfrm is conditionally defined. Provide accessor funtion that
is always available.
Signed-off-by: Vlad Yasevich <vyasevich@gmail.com>
There are a mix of function prototypes with and without extern
in the kernel sources. Standardize on not using extern for
function prototypes.
Function prototypes don't need to be written with extern.
extern is assumed by the compiler. Its use is as unnecessary as
using auto to declare automatic/local variables in a block.
The goal of this patch is to harmonize cleanup done on a skbuff on rx path.
Before this patch, behaviors were different depending of the tunnel type.
When neighbour table is full, dst_neigh_lookup/dst_neigh_lookup_skb will return
-ENOBUFS which is absolutely non zero, while all the code in kernel which use
above functions assume failure only on zero return which will cause panic. (for
example: : https://bugzilla.kernel.org/show_bug.cgi?id=54731).
This patch corrects above error with smallest changes to kernel source code and
also correct two return value check missing bugs in drivers/infiniband/hw/cxgb4/cm.c
Tested on my x86_64 SMP machine
Reported-by: Zhouyi Zhou <zhouzhouyi@gmail.com>
Tested-by: Zhouyi Zhou <zhouzhouyi@gmail.com>
Signed-off-by: Zhouyi Zhou <zhouzhouyi@gmail.com>
Eric Dumazet wrote:
| Some strange crashes happen in rt6_check_expired(), with access
| to random addresses.
| At first glance, it looks like the RTF_EXPIRES and
| stuff added in commit 1716a96101c49186b
| (ipv6: fix problem with expired dst cache)
| are racy : same dst could be manipulated at the same time
| on different cpus.
| At some point, our stack believes rt->dst.from contains a dst pointer,
| while its really a jiffie value (as rt->dst.expires shares the same area
| of memory)
| rt6_update_expires() should be fixed, or am I missing something ?
| CC Neil because of https://bugzilla.redhat.com/show_bug.cgi?id=892060
Because we do not have any locks for dst_entry, we cannot change
essential structure in the entry; e.g., we cannot change reference
to other entity.
To fix this issue, split 'from' and 'expires' field in dst_entry
out of union. Once it is 'from' is assigned in the constructor,
keep the reference until the very last stage of the life time of
the object.
Of course, it is unsafe to change 'from', so make rt6_set_from simple
just for fresh entries.
Reported-by: Eric Dumazet <eric.dumazet@gmail.com>
Reported-by: Neil Horman <nhorman@tuxdriver.com>
CC: Gao Feng <gaofeng@cn.fujitsu.com>
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
Reviewed-by: Eric Dumazet <edumazet@google.com>
Reported-by: Steinar H. Gunderson <sesse@google.com>
Reviewed-by: Neil Horman <nhorman@tuxdriver.com>
As the default, we blackhole packets until the key manager resolves
the states. This patch implements a packet queue where IPsec packets
are queued until the states are resolved. We generate a dummy xfrm
bundle, the output routine of the returned route enqueues the packet
to a per policy queue and arms a timer that checks for state resolution
when dst_output() is called. Once the states are resolved, the packets
are sent out of the queue. If the states are not resolved after some
time, the queue is flushed.
This patch keeps the defaut behaviour to blackhole packets as long
as we have no states. To enable the packet queue the sysctl
xfrm_larval_drop must be switched off.
While investigating on network performance problems, I found this little
gem :
$ nm -v vmlinux | grep -1 dst_default_metrics
ffffffff82736540 b busy.46605
ffffffff82736560 B dst_default_metrics
ffffffff82736598 b dst_busy_list
Apparently, declaring a const array without initializer put it in
(writeable) bss section, in middle of possibly often dirtied cache
lines.
Since we really want dst_default_metrics be const to avoid any possible
false sharing and catch any buggy writes, I force a null initializer.
ffffffff818a4c20 R dst_default_metrics
Cc: Ben Hutchings <bhutchings@solarflare.com>
1) Avoid dirtying neighbour's confirmed field.
TCP workloads hits this cache line for each incoming ACK.
Lets write n->confirmed only if there is a jiffie change.
2) Optimize neigh_hh_output() for the common Ethernet case, were
hh_len is less than 16 bytes. Replace the memcpy() call
by two inlined 64bit load/stores on x86_64.
Bench results using udpflood test, with -C option (MSG_CONFIRM flag
added to sendto(), to reproduce the n->confirmed dirtying on UDP)
24 threads doing 1.000.000 UDP sendto() on dummy device, 4 runs.
before : 2.247s, 2.235s, 2.247s, 2.318s
after : 1.884s, 1.905s, 1.891s, 1.895s
Mark them obsolete so there will be a re-lookup to fetch the
FIB nexthop exception info.
Add a big comment explaining how the field works, and use defines
instead of magic constants for the values assigned to it.
Suggested by Joe Perches.
No longer used.
No longer used.
Causes the handler to use the daddr in the ipv4/ipv6 header when
the route gateway is unspecified (local subnet).
When a dst_confirm() happens, mark the confirmation as pending in the
dst. Then on the next packet out, when we have the neigh in-hand, do
the update.
This removes the dependency in dst_confirm() of dst's having an
attached neigh.
While we're here, remove the explicit 'dst' NULL check, all except 2
or 3 call sites ensure it's not NULL. So just fix those cases up.
Fix code style - place the asterisk where it belongs.
Signed-off-by: Eldad Zack <eldad@fogrefinery.com>
Since commit ad0081e43a
"ipv6: Fragment locally generated tunnel-mode IPSec6 packets as needed"
the fragment of packets is incorrect.
because tunnel mode needs IPsec headers and trailer for all fragments,
while on transport mode it is sufficient to add the headers to the
first fragment and the trailer to the last.
so modify mtu and maxfraglen base on ipsec mode and if fragment is first
or last.
with my test,it work well(every fragment's size is the mtu)
and does not trigger slow fragment path.
Changes from v1:
though optimization, mtu_prev and maxfraglen_prev can be delete.
replace xfrm mode codes with dst_entry's new frag DST_XFRM_TUNNEL.
add fuction ip6_append_data_mtu to make codes clearer.
Signed-off-by: Gao feng <gaofeng@cn.fujitsu.com>
bridge: set fake_rtable's dst to NULL to avoid kernel Oops
when bridge is deleted before tap/vif device's delete, kernel may
encounter an oops because of NULL reference to fake_rtable's dst.
Set fake_rtable's dst to NULL before sending packets out can solve
this problem.
v4 reformat, change br_drop_fake_rtable(skb) to {}
v3 enrich commit header
v2 introducing new flag DST_FAKE_RTABLE to dst_entry struct.
[ Use "do { } while (0)" for nop br_drop_fake_rtable()
implementation -DaveM ]
Signed-off-by: Peter Huang <peter.huangpeng@huawei.com>
If the ipv6 dst cache which copy from the dst generated by ICMPV6 RA packet.
this dst cache will not check expire because it has no RTF_EXPIRES flag.
So this dst cache will always be used until the dst gc run.
Change the struct dst_entry,add a union contains new pointer from and expires.
When rt6_info.rt6i_flags has no RTF_EXPIRES flag,the dst.expires has no use.
we can use this field to point to where the dst cache copy from.
The dst.from is only used in IPV6.
rt6_check_expired check if rt6_info.dst.from is expired.
ip6_rt_copy only set dst.from when the ort has flag RTF_ADDRCONF
and RTF_DEFAULT.then hold the ort.
ip6_dst_destroy release the ort.
Add some functions to operate the RTF_EXPIRES flag and expires(from) together.
and change the code to use these new adding functions.
Changes from v5:
modify ip6_route_add and ndisc_router_discovery to use new adding functions.
Only set dst.from when the ort has flag RTF_ADDRCONF
If a header file is making use of BUG, BUG_ON, BUILD_BUG_ON, or any
other BUG variant in a static inline (i.e. not in a #define) then
that header really should be including <linux/bug.h> and not just
expecting it to be implicitly present.
We can make this change risk-free, since if the files using these
headers didn't have exposure to linux/bug.h already, they would have
been causing compile failures/warnings.
net/bluetooth/l2cap_core.c
Just two overlapping changes, one added an initialization of
a local variable, and another change added a new local variable.
Chris Boot reported crashes occurring in ipv6_select_ident().
[ 461.457562] RIP: 0010:[<ffffffff812dde61>] [<ffffffff812dde61>]
ipv6_select_ident+0x31/0xa7
[ 461.578229] Call Trace:
[ 461.580742] <IRQ>
[ 461.582870] [<ffffffff812efa7f>] ? udp6_ufo_fragment+0x124/0x1a2
[ 461.589054] [<ffffffff812dbfe0>] ? ipv6_gso_segment+0xc0/0x155
[ 461.595140] [<ffffffff812700c6>] ? skb_gso_segment+0x208/0x28b
[ 461.601198] [<ffffffffa03f236b>] ? ipv6_confirm+0x146/0x15e
[nf_conntrack_ipv6]
[ 461.608786] [<ffffffff81291c4d>] ? nf_iterate+0x41/0x77
[ 461.614227] [<ffffffff81271d64>] ? dev_hard_start_xmit+0x357/0x543
[ 461.620659] [<ffffffff81291cf6>] ? nf_hook_slow+0x73/0x111
[ 461.626440] [<ffffffffa0379745>] ? br_parse_ip_options+0x19a/0x19a
[bridge]
[ 461.633581] [<ffffffff812722ff>] ? dev_queue_xmit+0x3af/0x459
[ 461.639577] [<ffffffffa03747d2>] ? br_dev_queue_push_xmit+0x72/0x76
[bridge]
[ 461.646887] [<ffffffffa03791e3>] ? br_nf_post_routing+0x17d/0x18f
[bridge]
[ 461.653997] [<ffffffff81291c4d>] ? nf_iterate+0x41/0x77
[ 461.659473] [<ffffffffa0374760>] ? br_flood+0xfa/0xfa [bridge]
[ 461.665485] [<ffffffff81291cf6>] ? nf_hook_slow+0x73/0x111
[ 461.671234] [<ffffffffa0374760>] ? br_flood+0xfa/0xfa [bridge]
[ 461.677299] [<ffffffffa0379215>] ?
nf_bridge_update_protocol+0x20/0x20 [bridge]
[ 461.684891] [<ffffffffa03bb0e5>] ? nf_ct_zone+0xa/0x17 [nf_conntrack]
[ 461.691520] [<ffffffffa0374760>] ? br_flood+0xfa/0xfa [bridge]
[ 461.697572] [<ffffffffa0374812>] ? NF_HOOK.constprop.8+0x3c/0x56
[bridge]
[ 461.704616] [<ffffffffa0379031>] ?
nf_bridge_push_encap_header+0x1c/0x26 [bridge]
[ 461.712329] [<ffffffffa037929f>] ? br_nf_forward_finish+0x8a/0x95
[bridge]
[ 461.719490] [<ffffffffa037900a>] ?
nf_bridge_pull_encap_header+0x1c/0x27 [bridge]
[ 461.727223] [<ffffffffa0379974>] ? br_nf_forward_ip+0x1c0/0x1d4 [bridge]
[ 461.734292] [<ffffffff81291c4d>] ? nf_iterate+0x41/0x77
[ 461.739758] [<ffffffffa03748cc>] ? __br_deliver+0xa0/0xa0 [bridge]
[ 461.746203] [<ffffffff81291cf6>] ? nf_hook_slow+0x73/0x111
[ 461.751950] [<ffffffffa03748cc>] ? __br_deliver+0xa0/0xa0 [bridge]
[ 461.758378] [<ffffffffa037533a>] ? NF_HOOK.constprop.4+0x56/0x56
[bridge]
This is caused by bridge netfilter special dst_entry (fake_rtable), a
special shared entry, where attaching an inetpeer makes no sense.
Problem is present since commit 87c48fa3b46 (ipv6: make fragment
identifications less predictable)
Introduce DST_NOPEER dst flag and make sure ipv6_select_ident() and
__ip_select_ident() fallback to the 'no peer attached' handling.
Reported-by: Chris Boot <bootc@bootc.net>
Tested-by: Chris Boot <bootc@bootc.net>
To reflect the fact that a refrence is not obtained to the
resulting neighbour entry.
Acked-by: Roland Dreier <roland@purestorage.com>
We move all mtu handling from dst_mtu() down to the protocol
layer. So each protocol can implement the mtu handling in
a different manner.
We plan to invoke the dst_opt->default_mtu() method unconditioally
from dst_mtu(). So rename the method to dst_opt->mtu() to match
the name with the new meaning.
