path: root/include/net/ipv6.h
2009-07-12udpv6: Remove unused skb argument of ipv6_select_ident()Sridhar Samudrala
- move ipv6_select_ident() inline function to ipv6.h and remove the unused skb argument Signed-off-by: Sridhar Samudrala <sri@us.ibm.com> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-04-27snmp: add missing counters for RFC 4293Neil Horman
The IP MIB (RFC 4293) defines stats for InOctets, OutOctets, InMcastOctets and OutMcastOctets: http://tools.ietf.org/html/rfc4293 But it seems we don't track those in any way that easy to separate from other protocols. This patch adds those missing counters to the stats file. Tested successfully by me With help from Eric Dumazet. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-02-14net: replace __constant_{endian} uses in net headersHarvey Harrison
Base versions handle constant folding now. For headers exposed to userspace, we must only expose the __ prefixed versions. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-08ipv6: making ip and icmp statistics per/namespaceDenis V. Lunev
Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-08ipv6: added net argument to _DEVINC/_DEVADDDenis V. Lunev
2008-10-08ipv6: added net argument to ICMP6MSGIN_INC_STATS_BHDenis V. Lunev
2008-10-08ipv6: ICMP6MSGIN_INC_STATS is not usedDenis V. Lunev
Removed. Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-08ipv6: added net argument to ICMP6MSGOUT_INC_STATS_BHDenis V. Lunev
2008-10-08ipv6: added net argument to ICMP6MSGOUT_INC_STATSDenis V. Lunev
2008-10-08ipv6: added net argument to ICMP6_INC_STATS_BHDenis V. Lunev
2008-10-08ipv6: added net argument to ICMP6_INC_STATSDenis V. Lunev
2008-10-08ipv6: added net argument to IP6_ADD_STATS_BHDenis V. Lunev
2008-10-08ipv6: added net argument to IP6_INC_STATS_BHDenis V. Lunev
2008-10-08netns: add net parameter to IP6_INC_STATSDenis V. Lunev
2008-10-01ipv6: almost identical frag hashing funcs combinedIlpo Järvinen
$ diff-funcs ip6qhashfn reassembly.c netfilter/nf_conntrack_reasm.c --- reassembly.c:ip6qhashfn() +++ netfilter/nf_conntrack_reasm.c:ip6qhashfn() @@ -1,5 +1,5 @@ -static unsigned int ip6qhashfn(__be32 id, struct in6_addr *saddr, - struct in6_addr *daddr) +static unsigned int ip6qhashfn(__be32 id, const struct in6_addr *saddr, + const struct in6_addr *daddr) { u32 a, b, c; @@ -9,7 +9,7 @@ a += JHASH_GOLDEN_RATIO; b += JHASH_GOLDEN_RATIO; - c += ip6_frags.rnd; + c += nf_frags.rnd; __jhash_mix(a, b, c); a += (__force u32)saddr->s6_addr32[3]; And codiff xx.o.old xx.o.new: net/ipv6/netfilter/nf_conntrack_reasm.c: ip6qhashfn | -512 nf_hashfn | +6 nf_ct_frag6_gather | +36 3 functions changed, 42 bytes added, 512 bytes removed, diff: -470 net/ipv6/reassembly.c: ip6qhashfn | -512 ip6_hashfn | +7 ipv6_frag_rcv | +89 3 functions changed, 96 bytes added, 512 bytes removed, diff: -416 net/ipv6/reassembly.c: inet6_hash_frag | +510 1 function changed, 510 bytes added, diff: +510 Total: -376 Compile tested. Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-07-27missing bits of net-namespace / sysctlAl Viro
Piss-poor sysctl registration API strikes again, film at 11... What we really need is _pathname_ required to be present in already registered table, so that kernel could warn about bad order. That's the next target for sysctl stuff (and generally saner and more explicit order of initialization of ipv[46] internals wouldn't hurt either). For the time being, here are full fixups required by ..._rotable() stuff; we make per-net sysctl sets descendents of "ro" one and make sure that sufficient skeleton is there before we start registering per-net sysctls. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-19ipv6: remove unused macros from net/ipv6.hDenis V. Lunev
2008-07-19ipv6: remove unused parameter from ip6_ra_controlDenis V. Lunev
2008-06-28Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/net/wireless/iwlwifi/iwl4965-base.c
2008-06-19ipv6: Drop packets for loopback address from outside of the box.YOSHIFUJI Hideaki
[ Based upon original report and patch by Karsten Keil. Karsten has verified that this fixes the TAHI test case "ICMPv6 test v6LC.5.1.2 Part F". -DaveM ] Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-11net: remove CVS keywordsAdrian Bunk
This patch removes CVS keywords that weren't updated for a long time from comments. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-23IPv6 support for NFS server export cachesAurélien Charbon
This adds IPv6 support to the interfaces that are used to express nfsd exports. All addressed are stored internally as IPv6; backwards compatibility is maintained using mapped addresses. Thanks to Bruce Fields, Brian Haley, Neil Brown and Hideaki Joshifuji for comments Signed-off-by: Aurelien Charbon <aurelien.charbon@bull.net> Cc: Neil Brown <neilb@suse.de> Cc: Brian Haley <brian.haley@hp.com> Cc: YOSHIFUJI Hideaki / 吉藤英明 <yoshfuji@linux-ipv6.org> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-04-12[IPV6]: Make address arguments const.YOSHIFUJI Hideaki
- net/ipv6/addrconf.c: ipv6_get_ifaddr(), ipv6_dev_get_saddr() - net/ipv6/mcast.c: ipv6_sock_mc_join(), ipv6_sock_mc_drop(), inet6_mc_check(), ipv6_dev_mc_inc(), __ipv6_dev_mc_dec(), ipv6_dev_mc_dec(), ipv6_chk_mcast_addr() - net/ipv6/route.c: rt6_lookup(), icmp6_dst_alloc() - net/ipv6/ip6_output.c: ip6_nd_hdr() - net/ipv6/ndisc.c: ndisc_send_ns(), ndisc_send_rs(), ndisc_send_redirect(), ndisc_get_neigh(), __ndisc_send() Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-04-12[IPV6]: Use XOR and OR rather than mutiple ands for ipv6 address comparisons.YOSHIFUJI Hideaki
ipv6_addr_equal(), ipv6_addr_v4mapped(), ipv6_addr_is_ll_all_{nodes,routers}(), ipv6_masked_addr_cmp() Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-03-27[IPV6]: Remove three unused method declarations in include/net/ipv6.hRami Rosen
This patch removes three unused method declarations in include/net/ipv6.h: inet_getfrag_t(), ipv6_build_nfrag_opts() and ipv6_build_frag_opts(). Signed-off-by: Rami Rosen <ramirose@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-26[NETNS][IPV6] flowlabels - make flowlabels per namespaceBenjamin Thery
This patch introduces a new member, fl_net, in struct ip6_flowlabel. This allows to create labels with the same value in different namespaces. Signed-off-by: Benjamin Thery <benjamin.thery@bull.net> Signed-off-by: Daniel Lezcano <dlezcano@fr.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-26[NETNS][IPV6] anycast - handle several network namespaceDaniel Lezcano
Make use of the network namespace information to have this protocol to handle several network namespace. Signed-off-by: Daniel Lezcano <dlezcano@fr.ibm.com> Signed-off-by: Benjamin Thery <benjamin.thery@bull.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-21[NETNS][IPV6] tcp6 - make proc per namespaceDaniel Lezcano
Make the proc for tcp6 to be per namespace. Signed-off-by: Daniel Lezcano <dlezcano@fr.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-21[NETNS][IPV6] udp6 - make proc per namespaceDaniel Lezcano
The proc init/exit functions take a new network namespace parameter in order to register/unregister /proc/net/udp6 for a namespace. Signed-off-by: Daniel Lezcano <dlezcano@fr.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-06[UDP]: Revert udplite and code split.David S. Miller
This reverts commit db1ed684f6c430c4cdad67d058688b8a1b5e607c ("[IPV6] UDP: Rename IPv6 UDP files."), commit 8be8af8fa4405652e6c0797db5465a4be8afb998 ("[IPV4] UDP: Move IPv4-specific bits to other file.") and commit e898d4db2749c6052072e9bc4448e396cbdeb06a ("[UDP]: Allow users to configure UDP-Lite."). First, udplite is of such small cost, and it is a core protocol just like TCP and normal UDP are. We spent enormous amounts of effort to make udplite share as much code with core UDP as possible. All of that work is less valuable if we're just going to slap a config option on udplite support. It is also causing build failures, as reported on linux-next, showing that the changeset was not tested very well. In fact, this is the second build failure resulting from the udplite change. Finally, the config options provided was a bool, instead of a modular option. Meaning the udplite code does not even get build tested by allmodconfig builds, and furthermore the user is not presented with a reasonable modular build option which is particularly needed by distribution vendors. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-03[NETNS][IPV6] rt6_stats - make the stats per network namespaceBenjamin Thery
The rt6_stats is now per namespace with this patch. It is allocated when a network namespace is created and freed when the network namespace exits and references are relative to the network namespace. Signed-off-by: Benjamin Thery <benjamin.thery@bull.net> Signed-off-by: Daniel Lezcano <dlezcano@fr.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-03[NETNS][IPV6] rt6_stats - dynamically allocate the routes statisticsDaniel Lezcano
This patch allocates the rt6_stats struct dynamically when the fib6 is initialized. That provides the ability to create several instances of this structure for the network namespaces. Signed-off-by: Daniel Lezcano <dlezcano@fr.ibm.com> Signed-off-by: Benjamin Thery <benjamin.thery@bull.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-03-04[IPV6]: Move packet_type{} related bits to af_inet6.c.YOSHIFUJI Hideaki
2008-03-04[UDP]: Allow users to configure UDP-Lite.YOSHIFUJI Hideaki
Let's give users an option for disabling UDP-Lite (~4K). old: | text data bss dec hex filename | 286498 12432 6072 305002 4a76a net/ipv4/built-in.o | 193830 8192 3204 205226 321aa net/ipv6/ipv6.o new (without UDP-Lite): | text data bss dec hex filename | 284086 12136 5432 301654 49a56 net/ipv4/built-in.o | 191835 7832 3076 202743 317f7 net/ipv6/ipv6.o Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-02-28[IPV6]: Fix source address selection for ORCHID addressesJuha-Matti Tapio
Skip the prefix length matching in source address selection for orchid -> non-orchid addresses. Overlay Routable Cryptographic Hash IDentifiers (RFC 4843, 2001:10::/28) are currenty not globally reachable. Without this check a host with an ORCHID address can end up preferring those over regular addresses when talking to other regular hosts in the 2001::/16 range thus breaking non-orchid connections. Signed-off-by: Juha-Matti Tapio <jmtapio@verkkotelakka.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-05[IPV6]: Fix sysctl compilation error.Daniel Lezcano
Move ipv6_icmp_sysctl_init and ipv6_route_sysctl_init into the right ifdef section otherwise that does not compile when CONFIG_SYSCTL=yes and CONFIG_PROC_FS=no Signed-off-by: Daniel Lezcano <dlezcano@fr.ibm.com> Acked-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETNS][FRAGS]: Make the mem counter per-namespace.Pavel Emelyanov
This is also simple, but introduces more changes, since then mem counter is altered in more places. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETNS][FRAGS]: Make the nqueues counter per-namespace.Pavel Emelyanov
This is simple - just move the variable from struct inet_frags to struct netns_frags and adjust the usage appropriately. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETNS][FRAGS]: Move ctl tables around.Pavel Emelyanov
This is a preparation for sysctl netns-ization. Move the ctl tables to the files, where the tuning variables reside. Plus make the helpers to register the tables. This will simplify the later patches and will keep similar things closer to each other. ipv4, ipv6 and conntrack_reasm are patched differently, but the result is all the tables are in appropriate files. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[IPV6]: Sparse: Declare non-static ipv6_{route,icmp,frag}_sysctl_init() in ↵YOSHIFUJI Hideaki
header. Fix the following sparse warnings: | net/ipv6/route.c:2491:18: warning: symbol 'ipv6_route_sysctl_init' was not declared. Should it be static? | net/ipv6/icmp.c:922:18: warning: symbol 'ipv6_icmp_sysctl_init' was not declared. Should it be static? | net/ipv6/reassembly.c:628:6: warning: symbol 'ipv6_frag_sysctl_init' was not declared. Should it be static? Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-01-28[NETNS][IPV6]: Make ip6_frags per namespace.Daniel Lezcano
The ip6_frags is moved to the network namespace structure. Because there can be multiple instances of the network namespaces, and the ip6_frags is no longer a global static variable, a helper function has been added to facilitate the initialization of the variables. Until the ipv6 protocol is not per namespace, the variables are accessed relatively from the initial network namespace. Signed-off-by: Daniel Lezcano <dlezcano@fr.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETNS][IPV6]: Make bindv6only sysctl per namespace.Daniel Lezcano
This patch moves the bindv6only sysctl to the network namespace structure. Until the ipv6 protocol is not per namespace, the sysctl variable is always from the initial network namespace. Signed-off-by: Daniel Lezcano <dlezcano@fr.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETNS][IPV6]: Make multiple instance of sysctl tables.Daniel Lezcano
Each network namespace wants its own set of sysctl value, eg. we should not be able from a namespace to set a sysctl value for another namespace , especially for the initial network namespace. This patch duplicates the sysctl table when we register a new network namespace for ipv6. The duplicated table are postfixed with the "template" word to notify the developper the table is cloned. Signed-off-by: Daniel Lezcano <dlezcano@fr.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETNS][IPV6]: Make ipv6_sysctl_register to return a value.Daniel Lezcano
This patch makes the function ipv6_sysctl_register to return a value. The af_inet6 init function is now able to handle an error and catch it from the initialization of the sysctl. Signed-off-by: Daniel Lezcano <dlezcano@fr.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[NETFILTER]: Switch to using ctl_paths in nf_queue and conntrack modulesPavel Emelyanov
This includes the most simple cases for netfilter. The first part is tne queue modules for ipv4 and ipv6, on which the net/ipv4/ and net/ipv6/ paths are reused from the appropriate ipv4 and ipv6 code. The conntrack module is also patched, but this hunk is very small and simple. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[IPV6]: make the protocol initialization to return an error codeDaniel Lezcano
This patchset makes the different protocols to return an error code, so the af_inet6 module can check the initialization was correct or not. The raw6 was taken into account to be consistent with the rest of the protocols, but the registration is at the same place. Because the raw6 has its own init function, the proto and the ops structure can be moved inside the raw6.c file. Signed-off-by: Daniel Lezcano <dlezcano@fr.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[IPV6]: make flowlabel to return an errorDaniel Lezcano
This patch makes the flowlab subsystem to return an error code and makes some cleanup with procfs ifdefs. The af_inet6 will use the flowlabel init return code to check the initialization was correct. Signed-off-by: Daniel Lezcano <dlezcano@fr.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[SNMP]: Remove unused devconf macros.Pavel Emelyanov
The SNMP_INC_STATS_OFFSET_BH is used only by ICMP6_INC_STATS_OFFSET_BH. The ICMP6_INC_STATS_OFFSET_BH is unused. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[UDP]: Restore missing inDatagrams incrementsHerbert Xu
The previous move of the the UDP inDatagrams counter caused the counting of encapsulated packets, SUNRPC data (as opposed to call) packets and RXRPC packets to go missing. This patch restores all of these. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[IPV6]: Add ip6_local_outHerbert Xu
Most callers of the LOCAL_OUT chain will set the IP packet length before doing so. They also share the same output function dst_output. This patch creates a new function called ip6_local_out which does all of that and converts the appropriate users over to it. Apart from removing duplicate code, it will also help in merging the IPsec output path. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
