path: root/include/net/llc_pdu.h
2008-03-31[LLC]: skb allocation size for responsesJoonwoo Park
Allocate the skb for llc responses with the received packet size by using the size adjustable llc_frame_alloc. Don't allocate useless extra payload. Cleanup magic numbers. So, this fixes oops. Reported by Jim Westfall: kernel: skb_over_panic: text:c0541fc7 len:1000 put:997 head:c166ac00 data:c166ac2f tail:0xc166b017 end:0xc166ac80 dev:eth0 kernel: ------------[ cut here ]------------ kernel: kernel BUG at net/core/skbuff.c:95! Signed-off-by: Joonwoo Park <joonwpark81@gmail.com> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce skb_network_header()Arnaldo Carvalho de Melo
For the places where we need a pointer to the network header, it is still legal to touch skb->nh.raw directly if just adding to, subtracting from or setting it to another layer header. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[SK_BUFF]: Introduce skb_reset_network_header(skb)Arnaldo Carvalho de Melo
For the common, open coded 'skb->nh.raw = skb->data' operation, so that we can later turn skb->nh.raw into a offset, reducing the size of struct sk_buff in 64bit land while possibly keeping it as a pointer on 32bit. This one touches just the most simple case, next will handle the slightly more "complex" cases. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-25[LLC]: Kill llc_set_pdu_hdrArnaldo Carvalho de Melo
We'll have skb_reset_network_header soon. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[LLC]: anotationsAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-14[LLC]: Fix typoJochen Friedrich
Signed-off-by: Jochen Friedrich <jochen@scram.de> Acked-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-10-25[LLC]: Strip RIF flag from source MAC addressJochen Friedrich
Signed-off-by: Jochen Friedrich <jochen@scram.de> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
