path: root/include/net/mac80211.h
2009-08-28mac80211: remove ieee80211_rx namespace hackJohn W. Linville
With the libipw naming scheme change, it is no longer necessary for mac80211 to avoid the ieee80211_rx name clash. Reported-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-08-20mac80211: remove deprecated APIJohannes Berg
All but two drivers have now stopped using the two deprecated members radio_enabled and beacon_int, so it's about time to remove them for good. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Acked-by: Kalle Valo <kalle.valo@iki.fi> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-08-20mac80211: allow configure_filter callback to sleepJohannes Berg
Over time, a whole bunch of drivers have come up with their own scheme to delay the configure_filter operation to a workqueue. To be able to simplify things, allow configure_filter to sleep, and add a new prepare_multicast callback that drivers that need the multicast address list implement. This new callback must be atomic, but most drivers either don't care or just calculate a hash which can be done atomically and then uploaded to the hardware non-atomically. A cursory look suggests that at76c50x-usb, ar9170, mwl8k (which is actually very broken now), rt2x00, wl1251, wl1271 and zd1211 should make use of this new capability. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-08-14mac80211: allow DMA optimisationJohannes Berg
If we have a lot of frames to transmit at once, for instance with fragmentation, it can be an optimisation to only tell the DMA engine about them on the last fragment/frame to avoid banging the IO too much. This patch allows implementation such an optimisation by telling the driver when more frames can be expected. Currently, this is used by mac80211 only on fragmented frames, but could also be used in the future on other frames when the queue was full and there are multiple frames pending. Note that drivers need to be careful when using this flag, they need to kick their DMA engines not just when this flag is clear, but also when the queue gets full so that progress can be made. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-08-14mac80211: document TX powersave filter requirementsJohannes Berg
This documents what's required to implement that TX powersave filter properly wrt. handling hardware queues. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-08-14mac80211: explain TX retry and statusJohannes Berg
Add some more documentation including an example so that it's clearer what should be done for TX retries. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-08-04mac80211: FIF_PSPOLL filter flagIgor Perminov
When an interface is configured in the AP mode, the mac80211 implementation doesn't inform the driver to receive PS Poll frames. It leads to inability to communicate with power-saving stations reliably. The FIF_CONTROL flag isn't passed by mac80211 to ieee80211_ops.configure_filter when an interface is in the AP mode. And it's ok, because we don't want to receive ACK frames and other control ones, but only PS Poll ones. This patch introduces the FIF_PSPOLL filter flag in addition to FIF_CONTROL, which means for the driver "pass PS Poll frames". This flag is passed to the driver: A) When an interface is configured in the AP mode. B) In all cases, when the FIF_CONTROL flag was passed earlier (in addition to it). Signed-off-by: Igor Perminov <igor.perminov@inbox.ru> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-08-04mac80211: redefine usage of the mac80211 workqueueLuis R. Rodriguez
The mac80211 workqueue exists to enable mac80211 and drivers to queue their own work on a single threaded workqueue. mac80211 takes care to flush the workqueue during suspend but we never really had requirements on drivers for how they should use the workqueue in consideration for suspend. We extend mac80211 to document how the mac80211 workqueue should be used, how it should not be used and finally move raw access to the workqueue to mac80211 only. Drivers and mac80211 use helpers to queue work onto the mac80211 workqueue: * ieee80211_queue_work() * ieee80211_queue_delayed_work() These helpers will now warn if mac80211 already completed its suspend cycle and someone is trying to queue work. mac80211 flushes the mac80211 workqueue prior to suspend a few times, but we haven't taken the care to ensure drivers won't add more work after suspend. To help with this we add a warning when someone tries to add work and mac80211 already completed the suspend cycle. Drivers should ensure they cancel any work or delayed work in the mac80211 stop() callback. Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-27mac80211: fix PS-poll response, raceJohannes Berg
When a station queries us for a PS-poll response, we wrongly queue the frame on the virtual interface's queue rather than the pending queue. Additionally, fix a race condition where we could potentially send multiple frames to the sleeping station due to using a station flag rather than a packet flag. When converting to a packet flag, we can also convert p54 and remove the filter clearing we added for it. (Also remove a now dead function) Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Reported-by: Bob Copeland <me@bobcopeland.com> Tested-by: Bob Copeland <me@bobcopeland.com> Cc: Christian Lamparter <chunkeey@web.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-24mac80211: remove master netdevJohannes Berg
With the internal 'pending' queue system in place, we can simply put packets there instead of pushing them off to the master dev, getting rid of the master interface completely. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-24mac80211: add helper for management / no-ack frame rate decisionLuis R. Rodriguez
All current rate control algorithms agree to send management and no-ack frames at the lowest rate. They also agree to do this when sta and the private rate control data is NULL. We add a hlper to mac80211 for this and simplify the rate control algorithm code. Developers wishing to make enhancements to rate control algorithms are for broadcast/multicast can opt to not use this in their gate_rate() mac80211 callback. Cc: Zhu Yi <yi.zhu@intel.com> Acked-by: Reinette Chatre <reinette.chatre@intel.com> Cc: ipw3945-devel@lists.sourceforge.net Cc: Gabor Juhos <juhosg@openwrt.org> Acked-by: Felix Fietkau <nbd@openwrt.org> Cc: Derek Smithies <derek@indranet.co.nz> Cc: Chittajit Mitra <Chittajit.Mitra@Atheros.com> Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-24mac80211: drop frames for sta with no valid rateLuis R. Rodriguez
When we're associated we should be able to send data to target sta. If we cannot we may be trying to use the incorrect band to talk to the sta. Lets catch any such cases, warn, and drop the frames to not invalidate assumptions being made on rate control algorithms when they have a valid sta to communicate with. Any such cases should be handled and fixed. Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-10cfg80211: introduce nl80211 testmode commandJohannes Berg
This introduces a new NL80211_CMD_TESTMODE for testing and calibration use with nl80211. There's no multiplexing like like iwpriv had, and the command is not available by default, it needs to be explicitly enabled in Kconfig and shouldn't be enabled in most kernels. The command requires a wiphy index or interface index to identify the device to operate on, and the new TESTDATA attribute. There also is API for sending replies to the command, and testmode multicast messages (on a testmode multicast group). I've also updated mac80211 to be able to pass through the command to the driver, since it itself doesn't implement the testmode command. Additionally, to give people an idea of how to use the command, I've added a little code to hwsim that makes use of the new command to set the powersave mode, this is currently done via debugfs and should remain there, and the testmode command only serves as an example of how to use this best -- with nested netlink attributes in the TESTDATA attribute. A hwsim testmode tool can be found at http://git.sipsolutions.net/hwsim.git/. This tool is BSD licensed so people can easily use it as a basis for their own internal fabrication and validation tools. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-07-10mac80211: push rx status into skb->cbJohannes Berg
Within mac80211, we often need to copy the rx status into skb->cb. This is wasteful, as drivers could be building it in there to start with. This patch changes the API so that drivers are expected to pass the RX status in skb->cb, now accessible as IEEE80211_SKB_RXCB(skb). It also updates all drivers to pass the rx status in there, but only by making them memcpy() it into place before the call to the receive function (ieee80211_rx(_irqsafe)). Each driver can now be optimised on its own schedule. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-06-10mac80211: do not pass PS frames out of mac80211 againJohannes Berg
In order to handle powersave frames properly we had needed to pass these out to the device queues again, and introduce the skb->requeue bit. This, however, also has unnecessary overhead by needing to 'clean up' already tried frames, and this clean-up code is also buggy when software encryption is used. Instead of sending the frames via the master netdev queue again, simply put them into the pending queue. This also fixes a problem where frames for that particular station could be reordered when some were still on the software queues and older ones are re-injected into the software queue after them. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-06-03cfg80211: add rfkill supportJohannes Berg
To be easier on drivers and users, have cfg80211 register an rfkill structure that drivers can access. When soft-killed, simply take down all interfaces; when hard-killed the driver needs to notify us and we will take down the interfaces after the fact. While rfkilled, interfaces cannot be set UP. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-06-03mac80211: deprecate conf.beacon_int properlyJohannes Berg
Ivo has updated the driver to no longer use the change flag, so we can remove that, but rt2x00 and ath5k still use the actual value so let's mark it as deprecated too. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-05-22wireless: move some utility functions from mac80211 to cfg80211Zhu Yi
The patch moves some utility functions from mac80211 to cfg80211. Because these functions are doing generic 802.11 operations so they are not mac80211 specific. The moving allows some fullmac drivers to be also benefit from these utility functions. Signed-off-by: Zhu Yi <yi.zhu@intel.com> Signed-off-by: Samuel Ortiz <samuel.ortiz@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-05-20mac80211: fix kernel-docJohannes Berg
Moving information from config_interface to bss_info_changed removed struct ieee80211_if_conf which the documentation still refers to, additionally there's one kernel-doc description too much and one other missing, fix all this. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-05-11mac80211: remove ieee80211_ht_bss_infoJohannes Berg
This struct is no longer used (and hasn't been for a while). Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-05-11mac80211: move HT operation mode BSS infoJohannes Berg
There really is no need to have a separate struct for a single variable. The fact that it exists is due to the code legacy, but we can remove that now. Very simple. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-05-06mac80211: tell driver when idleJohannes Berg
When we aren't doing anything in mac80211, we can turn off much of the hardware, depending on the driver/hw. Not doing anything, aka being idle, means: * no monitor interfaces * no AP/mesh/wds interfaces * any station interfaces are in DISABLED state * any IBSS interfaces aren't trying to be in a network * we aren't trying to scan By creating a new function that verifies these conditions and calling it at strategic points where the states of those conditions change, we can easily make mac80211 tell the driver when we are idle to save power. Additionally, this fixes a small quirk where a recalculated powersave state is passed to the driver even if the hardware is about to stopped completely. This patch intentionally doesn't touch radio_enabled because that is currently implemented to be a soft rfkill which is inappropriate here when we need to be able to wake up with low latency. One thing I'm not entirely sure about is this: phy0: device no longer idle - in use wlan0: direct probe to AP 00:11:24:91:07:4d try 1 wlan0 direct probe responded wlan0: authenticate with AP 00:11:24:91:07:4d wlan0: authenticated > phy0: device now idle > phy0: device no longer idle - in use wlan0: associate with AP 00:11:24:91:07:4d wlan0: RX AssocResp from 00:11:24:91:07:4d (capab=0x401 status=0 aid=1) wlan0: associated Is it appropriate to go into idle state for a short time when we have just authenticated, but not associated yet? This happens only with the userspace SME, because we cannot really know how long it will wait before asking us to associate. Would going idle after a short timeout be more appropriate? We may need to revisit this, depending on what happens. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-05-06mac80211: unify config_interface and bss_info_changedJohannes Berg
The config_interface method is a little strange, it contains the BSSID and beacon updates, while bss_info_changed contains most other BSS information for each interface. This patch removes config_interface and rolls all the information it previously passed to drivers into bss_info_changed. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-05-06mac80211: clean up beacon interval settingsJohannes Berg
We currently have two beacon interval configuration knobs: hw.conf.beacon_int and vif.bss_info.beacon_int. This is rather confusing, even though the former is used when we beacon ourselves and the latter when we are associated to an AP. This just deprecates the hw.conf.beacon_int setting in favour of always using vif.bss_info.beacon_int. Since it touches all the beaconing IBSS code anyway, we can also add support for the cfg80211 IBSS beacon interval configuration easily. NOTE: The hw.conf.beacon_int setting is retained for now due to drivers still using it -- I couldn't untangle all drivers, some are updated in this patch. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-05-06mac80211: rename max_sleep_interval to max_sleep_periodJohannes Berg
Kalle points out that max_sleep_interval is somewhat confusing because the value is measured in beacon intervals, and not in TU. Rename it to max_sleep_period to be consistent with things like DTIM period that are also measured in beacon intervals. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-04-22mac80211: calculate maximum sleep intervalJohannes Berg
The maximum sleep interval, for powersave purposes, is determined by the DTIM period (it may not be larger) and the required networking latency (it must be small enough to fulfil those constraints). This makes mac80211 calculate the maximum sleep interval based on those constraints, and pass it to the driver. Then the driver should instruct the device to sleep at most that long. Note that the device is responsible for aligning the maximum sleep interval between DTIMs, we make sure it's not longer but it needs to make sure it's between them. Also, group some powersave documentation together and make it more explicit that we support managed mode only, and no IBSS powersaving (yet). Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-04-22mac80211: remove IEEE80211_CONF_CHANGE_DYNPS_TIMEOUTJohannes Berg
Just setting IEEE80211_CONF_CHANGE_PS should be sufficient for changes in the power saving things. The driver already tells us whether it wants notification of dynps via the "have dynps support" hw flag. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Reviewed-by: Kalle Valo <kalle.valo@iki.fi> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-04-22cfg80211: clean up includesJohannes Berg
Trying to separate header files into net/wireless.h and net/cfg80211.h has been a source of confusion. Remove net/wireless.h (because there also is the linux/wireless.h) and subsume everything into net/cfg80211.h -- except the definitions for regulatory structures which get moved to a new header net/regulatory.h. The "new" net/cfg80211.h is now divided into sections. There are no real changes in this patch but code shuffling and some very minor documentation fixes. I have also, to make things reflect reality, put in a copyright line for Luis to net/regulatory.h since that is probably exclusively written by him but was formerly in a file that only had my copyright line. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Cc: Luis R. Rodriguez <lrodriguez@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-04-22mac80211: document powersaving/beacon filter futureJohannes Berg
Document what mac80211 will do in the future to help save power. We're not quite there yet, but a plan helps. Also, while at it, fix the docs wrt. multicast traffic. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Reviewed-by: Kalle Valo <kalle.valo@iki.fi> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-04-22mac80211: add hardware restart functionJohannes Berg
Some hardware defects may require the hardware to be re-initialised completely from scratch. Drivers would need much information (for instance the current MAC address, crypto keys, beaconing information, etc.) stored duplicated from mac80211 to be able to do this, so let mac80211 help them. The new ieee80211_restart_hw() function requires the same code as resuming, so move that code into a new ieee80211_reconfig() function in util.c and leave only the suspend code in pm.c. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-04-22mac80211: pass all probe request IEs to driverJohannes Berg
Instead of just passing the cfg80211-requested IEs, pass the locally generated ones as well. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-03-27mac80211/iwlwifi: move virtual A-MDPU queue bookkeeping to iwlwifiJohannes Berg
This patch removes all the virtual A-MPDU-queue bookkeeping from mac80211. Curiously, iwlwifi already does its own bookkeeping, so it doesn't require much changes except where it needs to handle starting and stopping the queues in mac80211. To handle the queue stop/wake properly, we rewrite the software queue number for aggregation frames and internally to iwlwifi keep track of the queues that map into the same AC queue, and only talk to mac80211 about the AC queue. The implementation requires calling two new functions, iwl_stop_queue and iwl_wake_queue instead of the mac80211 counterparts. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Cc: Reinette Chattre <reinette.chatre@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-03-27mac80211: fix aggregation to not require queue stopJohannes Berg
Instead of stopping the entire AC queue when enabling aggregation (which was only done for hardware with aggregation queues) buffer the packets for each station, and release them to the pending skb queue once aggregation is turned on successfully. We get a little more code, but it becomes conceptually simpler and we can remove the entire virtual queue mechanism from mac80211 in a follow-up patch. This changes how mac80211 behaves towards drivers that support aggregation but have no hardware queues -- those drivers will now not be handed packets while the aggregation session is being established, but only after it has been fully established. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-03-27mac80211: unify and fix TX aggregation startJohannes Berg
When TX aggregation becomes operational, we do a number of steps: 1) print a debug message 2) wake the virtual queue 3) notify the driver Unfortunately, 1) and 3) are only done if the driver is first to reply to the aggregation request, it is, however, possible that the remote station replies before the driver! Thus, unify the code for this and call the new function ieee80211_agg_tx_operational in both places where TX aggregation can become operational. Additionally, rename the driver notification from IEEE80211_AMPDU_TX_RESUME to IEEE80211_AMPDU_TX_OPERATIONAL. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-03-27mac80211: rate control status only for controlled packetsJohannes Berg
This patch changes mac80211 to not notify the rate control algorithm's tx_status() method when reporting status for a packet that didn't go through the rate control algorithm's get_rate() method. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-03-27mac80211: add beacon filtering supportKalle Valo
Add IEEE80211_HW_BEACON_FILTERING flag so that driver inform that it supports beacon filtering. Drivers need to call the new function ieee80211_beacon_loss() to notify about beacon loss. Signed-off-by: Kalle Valo <kalle.valo@nokia.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-03-27mac80211: disable power save when scanningKalle Valo
When software scanning we need to disable power save so that all possible probe responses and beacons are received. For hardware scanning assume that hardware will take care of that and document that assumption. Signed-off-by: Kalle Valo <kalle.valo@nokia.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-03-27mac80211: kill IEEE80211_CONF_SHORT_SLOT_TIMEJohannes Berg
No drivers use it any more, so it can now be removed safely. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-03-27mac80211: reduce max number of queuesJohannes Berg
No hw/driver actually supports more than four queues right now, and we allocate a number of things per queue which means we waste a bit of memory. Reduce the maximum number to four to accurately reflect what we do (and need for QoS). Even if we had hardware supporting more queues we couldn't take advantage of that right now anyway. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-03-27mac80211: remove ieee80211_num_regular_queuesJohannes Berg
This inline is useless and actually makes the code _longer_ rather than shorter. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-02-27mac80211: Add software scan notifiersMichael Buesch
This adds optional notifier functions for software scan. Signed-off-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-02-27mac80211: Extend the rate control API with an update callbackSujith
The AP can switch dynamically between 20/40 Mhz channel width, in which case we switch the local operating channel, but the rate control algorithm is not notified. This patch adds a new callback to indicate such changes to the RC algorithm. Currently, HT channel width change is notified, but this callback can be used to indicate any new requirements that might come up later on. Signed-off-by: Sujith <Sujith.Manoharan@atheros.com> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-02-27mac80211: fix aggregation for hardware with ampdu queuesJohannes Berg
Hardware with AMPDU queues currently has broken aggregation. This patch fixes it by making all A-MPDUs go over the regular AC queues, but keeping track of the hardware queues in mac80211. As a first rough version, it actually stops the AC queue for extended periods of time, which can be removed by adding buffering internal to mac80211, but is currently not a huge problem because people rarely use multiple TIDs that are in the same AC (and iwlwifi currently doesn't operate as AP). This is a short-term fix, my current medium-term plan, which I hope to execute soon as well, but am not sure can finish before .30, looks like this: 1) rework the internal queuing layer in mac80211 that we use for fragments if the driver stopped queue in the middle of a fragmented frame to be able to queue more frames at once (rather than just a single frame with its fragments) 2) instead of stopping the entire AC queue, queue up the frames in a per-station/per-TID queue during aggregation session initiation, when the session has come up take all those frames and put them onto the queue from 1) 3) push the ampdu queue layer abstraction this patch introduces in mac80211 into the driver, and remove the virtual queue stuff from mac80211 again This plan will probably also affect ath9k in that mac80211 queues the frames instead of passing them down, even when there are no ampdu queues. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-02-13cfg80211/nl80211: scanning (and mac80211 update to use it)Johannes Berg
This patch adds basic scan capability to cfg80211/nl80211 and changes mac80211 to use it. The BSS list that cfg80211 maintains is made driver-accessible with a private area in each BSS struct, but mac80211 doesn't yet use it. That's another large project. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-02-13mac80211: Remove TSF atomic requirement from the documentationAlina Friedrichsen
The atomic requirement for the TSF callbacks is outdated. get_tsf() is only called by ieee80211_rx_bss_info() which is indirectly called by the work queue ieee80211_sta_work(). In the same context are called several other non-atomic functions, too. And the atomic requirement causes problems for drivers of USB wifi cards. Signed-off-by: Alina Friedrichsen <x-alina@gmx.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-02-09mac80211: remove HW_SIGNAL_DBJohannes Berg
Giving the signal in dB isn't much more useful to userspace than giving the signal in unspecified units. This removes some radiotap information for zd1211 (the only driver using this flag), but it helps a lot for getting cfg80211-based scanning which won't support dB, and zd1211 being dB is a little fishy anyway. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Cc: Bruno Randolf <bruno@thinktube.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-01-29mac80211: Generic TSF debuggingAlina Friedrichsen
This patch enables low-level driver independent debugging of the TSF and remove the driver specific things of ath5k and ath9k from the debugfs. Signed-off-by: Alina Friedrichsen <x-alina@gmx.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-01-29mac80211: add interface list lockJohannes Berg
Using only the RTNL has a number of problems, most notably that ieee80211_iterate_active_interfaces() and other interface list traversals cannot be done from the internal workqueue because it needs to be flushed under the RTNL. This patch introduces a new mutex that protects the interface list against modifications. A more detailed explanation is part of the code change. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-01-29mac80211: allow mac80211 drivers to get to struct ieee80211_hw from wiphyLuis R. Rodriguez
If a driver is given a wiphy and it wants to get to its private mac80211 driver area it can use wiphy_to_ieee80211_hw() to get first to its ieee80211_hw and then access the private structure via hw->priv. The wiphy_priv() is already being used internally by mac80211 and drivers should not use this. This can be helpful in a drivers reg_notifier(). Signed-off-by: Luis R. Rodriguez <lrodriguez@atheros.com> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-01-29mac80211: Add capability to enable/disable beaconingJohannes Berg
This patch adds a flag to notify drivers to start and stop beaconing when needed, for example, during a scan run. Based on Sujith's first patch to do the same, but now disables beaconing for all virtual interfaces while scanning, has a separate change flag and tracks user-space requests. Signed-off-by: Sujith <Sujith.Manoharan@atheros.com> Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
