path: root/include/net/ndisc.h
2011-04-24net: Remove __KERNEL__ cpp checks from include/netDavid S. Miller
These header files are never installed to user consumption, so any __KERNEL__ cpp checks are superfluous. Projects should also not copy these files into their userland utility sources and try to use them there. If they insist on doing so, the onus is on them to sanitize the headers as needed. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-22inet: constify ip headers and in6_addrEric Dumazet
Add const qualifiers to structs iphdr, ipv6hdr and in6_addr pointers where possible, to make code intention more obvious. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-02net: kill unused macros from head fileShan Wei
These macros have been defined for several years since v2.6.12-rc2(tracing by git), but never be used. So remove them. Signed-off-by: Shan Wei <shanwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-03net: use __packed annotationEric Dumazet
cleanup patch. Use new __packed annotation in net/ and include/ (except netfilter) Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-24sysctl: remove "struct file *" argument of ->proc_handlerAlexey Dobriyan
It's unused. It isn't needed -- read or write flag is already passed and sysctl shouldn't care about the rest. It _was_ used in two places at arch/frv for some reason. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: David Howells <dhowells@redhat.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-04ipv6: Fix sporadic sendmsg -EINVAL when sending to multicast groups.David S. Miller
Thanks to excellent diagnosis by Eduard Guzovsky. The core problem is that on a network with lots of active multicast traffic, the neighbour cache can fill up. If we try to allocate a new route and thus neighbour cache entry, the bog-standard GC attempt the neighbour layer does in ineffective because route entries hold a reference to the existing neighbour entries and GC can only liberate entries with no references. IPV4 already has a way to handle this, by doing a route cache GC in such situations (when neigh attach returns -ENOBUFS). So simply mimick this on the ipv6 side. Tested-by: Eduard Guzovsky <eguzovsky@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-06bonding: send IPv6 neighbor advertisement on failoverBrian Haley
This patch adds better IPv6 failover support for bonding devices, especially when in active-backup mode and there are only IPv6 addresses configured, as reported by Alex Sidorenko. - Creates a new file, net/drivers/bonding/bond_ipv6.c, for the IPv6-specific routines. Both regular bonds and VLANs over bonds are supported. - Adds a new tunable, num_unsol_na, to limit the number of unsolicited IPv6 Neighbor Advertisements that are sent on a failover event. Default is 1. - Creates two new IPv6 neighbor discovery functions: ndisc_build_skb() ndisc_send_skb() These were required to support VLANs since we have to be able to add the VLAN id to the skb since ndisc_send_na() and friends shouldn't be asked to do this. These two routines are basically __ndisc_send() split into two pieces, in a slightly different order. - Updates Documentation/networking/bonding.txt and bumps the rev of bond support to 3.4.0. On failover, this new code will generate one packet: - An unsolicited IPv6 Neighbor Advertisement, which helps the switch learn that the address has moved to the new slave. Testing has shown that sending just the NA results in pretty good behavior when in active-back mode, I saw no lost ping packets for example. Signed-off-by: Brian Haley <brian.haley@hp.com> Signed-off-by: Jay Vosburgh <fubar@us.ibm.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-10-16sysctl: simplify ->strategyAlexey Dobriyan
name and nlen parameters passed to ->strategy hook are unused, remove them. In general ->strategy hook should know what it's doing, and don't do something tricky for which, say, pointer to original userspace array may be needed (name). Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: David S. Miller <davem@davemloft.net> [ networking bits ] Cc: Ralf Baechle <ralf@linux-mips.org> Cc: David Howells <dhowells@redhat.com> Cc: Matt Mackall <mpm@selenic.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-19ndisc: Add missing strategies for per-device retrans timer/reachable time ↵YOSHIFUJI Hideaki
settings. Noticed from Al Viro <viro@ftp.linux.org.uk> via David Miller <davem@davemloft.net>. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-12[IPV6]: Make address arguments const.YOSHIFUJI Hideaki
- net/ipv6/addrconf.c: ipv6_get_ifaddr(), ipv6_dev_get_saddr() - net/ipv6/mcast.c: ipv6_sock_mc_join(), ipv6_sock_mc_drop(), inet6_mc_check(), ipv6_dev_mc_inc(), __ipv6_dev_mc_dec(), ipv6_dev_mc_dec(), ipv6_chk_mcast_addr() - net/ipv6/route.c: rt6_lookup(), icmp6_dst_alloc() - net/ipv6/ip6_output.c: ip6_nd_hdr() - net/ipv6/ndisc.c: ndisc_send_ns(), ndisc_send_rs(), ndisc_send_redirect(), ndisc_get_neigh(), __ndisc_send() Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-04-10[IPV6] Remove three method declarations in include/net/ndisc.h.Rami Rosen
This patch removes two unused method declarations in include/net/ndisc.h: ndisc_forwarding_on(void) and ndisc_forwarding_off(void); Also igmp6_cleanup(void) appears twice in this header, so one igmp6_cleanup(void) declaration is removed. Signed-off-by: Rami Rosen <ramirose@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-03[IPV6] SIT: Add PRL management for ISATAP.Templin, Fred L
This patch updates the Linux the Intra-Site Automatic Tunnel Addressing Protocol (ISATAP) implementation. It places the ISATAP potential router list (PRL) in the kernel and adds three new private ioctls for PRL management. [Add several changes of structure name, constant names etc. - yoshfuji] Signed-off-by: Fred L. Templin <fred.l.templin@boeing.com> Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-02-29[INET]: Remove struct net_proto_family* from _init calls.Denis V. Lunev
struct net_proto_family* is not used in icmp[v6]_init, ndisc_init, igmp_init and tcp_v4_init. Remove it. Signed-off-by: Denis V. Lunev <den@openvz.org> Acked-by: Daniel Lezcano <dlezcano@fr.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-12[IPV6]: remove unused method declaration (net/ndisc.h).Rami Rosen
This patch removes unused declaration of dflt_rt_lookup() method in include/net/ndisc.h Signed-off-by: Rami Rosen <ramirose@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[IPv6]: Export userland ND options through netlink (RDNSS support)Pierre Ynard
As discussed before, this patch provides userland with a way to access relevant options in Router Advertisements, after they are processed and validated by the kernel. Extra options are processed in a generic way; this patch only exports RDNSS options described in RFC5006, but support to control which options are exported could be easily added. A new rtnetlink message type is defined, to transport Neighbor Discovery options, along with optional context information. At the moment only the address of the router sending an RDNSS option is included, but additional attributes may be later defined, if needed by new use cases. Signed-off-by: Pierre Ynard <linkfanel@yahoo.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[IPV6]: Misc endianness annotations.Al Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2006-03-20[IPV6]: ROUTE: Add experimental support for Route Information Option in RA ↵YOSHIFUJI Hideaki
(RFC4191). Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[INET_SOCK]: Move struct inet_sock & helper functions to net/inet_sock.hArnaldo Carvalho de Melo
To help in reducing the number of include dependencies, several files were touched as they were getting needed headers indirectly for stuff they use. Thanks also to Alan Menegotto for pointing out that net/dccp/proto.c had linux/dccp.h include twice. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
