path: root/include/net/ndisc.h
2016-06-156lowpan: introduce 6lowpan-ndAlexander Aring
This patch introduce different 6lowpan handling for receive and transmit NS/NA messages for the ipv6 neighbour discovery. The first use-case is for supporting 802.15.4 short addresses inside the option fields and handling for RFC6775 6CO option field as userspace option. Cc: David S. Miller <davem@davemloft.net> Cc: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru> Cc: James Morris <jmorris@namei.org> Cc: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org> Cc: Patrick McHardy <kaber@trash.net> Reviewed-by: Stefan Schmidt <stefan@osg.samsung.com> Acked-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: Alexander Aring <aar@pengutronix.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-06-15ipv6: export several functionsAlexander Aring
This patch exports some neighbour discovery functions which can be used by 6lowpan neighbour discovery ops functionality then. Cc: David S. Miller <davem@davemloft.net> Cc: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru> Cc: James Morris <jmorris@namei.org> Cc: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org> Cc: Patrick McHardy <kaber@trash.net> Acked-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Reviewed-by: Stefan Schmidt <stefan@osg.samsung.com> Signed-off-by: Alexander Aring <aar@pengutronix.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-06-15ipv6: introduce neighbour discovery opsAlexander Aring
This patch introduces neighbour discovery ops callback structure. The idea is to separate the handling for 6LoWPAN into the 6lowpan module. These callback offers 6lowpan different handling, such as 802.15.4 short address handling or RFC6775 (Neighbor Discovery Optimization for IPv6 over 6LoWPANs). Cc: David S. Miller <davem@davemloft.net> Cc: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru> Cc: James Morris <jmorris@namei.org> Cc: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org> Cc: Patrick McHardy <kaber@trash.net> Acked-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: Alexander Aring <aar@pengutronix.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-06-15ndisc: add __ndisc_opt_addr_data functionAlexander Aring
This patch adds __ndisc_opt_addr_data as low-level function for ndisc_opt_addr_data which doesn't depend on net_device parameter. Cc: David S. Miller <davem@davemloft.net> Cc: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru> Cc: James Morris <jmorris@namei.org> Cc: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org> Cc: Patrick McHardy <kaber@trash.net> Acked-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Reviewed-by: Stefan Schmidt <stefan@osg.samsung.com> Signed-off-by: Alexander Aring <aar@pengutronix.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2016-06-15ndisc: add __ndisc_opt_addr_space functionAlexander Aring
This patch adds __ndisc_opt_addr_space as low-level function for ndisc_opt_addr_space which doesn't depend on net_device parameter. Cc: David S. Miller <davem@davemloft.net> Cc: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru> Cc: James Morris <jmorris@namei.org> Cc: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org> Cc: Patrick McHardy <kaber@trash.net> Acked-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Reviewed-by: Stefan Schmidt <stefan@osg.samsung.com> Signed-off-by: Alexander Aring <aar@pengutronix.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-12-01Revert "ipv6: ndisc: inherit metadata dst when creating ndisc requests"Nicolas Dichtel
This reverts commit ab450605b35caa768ca33e86db9403229bf42be4. In IPv6, we cannot inherit the dst of the original dst. ndisc packets are IPv6 packets and may take another route than the original packet. This patch breaks the following scenario: a packet comes from eth0 and is forwarded through vxlan1. The encapsulated packet triggers an NS which cannot be sent because of the wrong route. CC: Jiri Benc <jbenc@redhat.com> CC: Thomas Graf <tgraf@suug.ch> Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-09-24ipv6: remove unused neigh parameter from ndisc functionsJiri Benc
Since commit 12fd84f4383b1 ("ipv6: Remove unused neigh argument for icmp6_dst_alloc() and its callers."), the neigh parameter of ndisc_send_na and ndisc_send_ns is unused. CC: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: Jiri Benc <jbenc@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-08-20ipv6: ndisc: inherit metadata dst when creating ndisc requestsJiri Benc
If output device wants to see the dst, inherit the dst of the original skb in the ndisc request. This is an IPv6 counterpart of commit 0accfc268f4d ("arp: Inherit metadata dst when creating ARP requests"). Signed-off-by: Jiri Benc <jbenc@redhat.com> Acked-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2015-03-04neigh: Factor out ___neigh_lookup_norefEric W. Biederman
While looking at the mpls code I found myself writing yet another version of neigh_lookup_noref. We currently have __ipv4_lookup_noref and __ipv6_lookup_noref. So to make my work a little easier and to make it a smidge easier to verify/maintain the mpls code in the future I stopped and wrote ___neigh_lookup_noref. Then I rewote __ipv4_lookup_noref and __ipv6_lookup_noref in terms of this new function. I tested my new version by verifying that the same code is generated in ip_finish_output2 and ip6_finish_output2 where these functions are inlined. To get to ___neigh_lookup_noref I added a new neighbour cache table function key_eq. So that the static size of the key would be available. I also added __neigh_lookup_noref for people who want to to lookup a neighbour table entry quickly but don't know which neibhgour table they are going to look up. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-09-21ndisc.h: Remove extern from function prototypesJoe Perches
There are a mix of function prototypes with and without extern in the kernel sources. Standardize on not using extern for function prototypes. Function prototypes don't need to be written with extern. extern is assumed by the compiler. Its use is as unnecessary as using auto to declare automatic/local variables in a block. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-09-11ipv6: don't call fib6_run_gc() until routing is readyMichal Kubeček
When loading the ipv6 module, ndisc_init() is called before ip6_route_init(). As the former registers a handler calling fib6_run_gc(), this opens a window to run the garbage collector before necessary data structures are initialized. If a network device is initialized in this window, adding MAC address to it triggers a NETDEV_CHANGEADDR event, leading to a crash in fib6_clean_all(). Take the event handler registration out of ndisc_init() into a separate function ndisc_late_init() and move it after ip6_route_init(). Signed-off-by: Michal Kubecek <mkubecek@suse.cz> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-08-31vxlan: add ipv6 proxy supportCong Wang
This patch adds the IPv6 version of "arp_reduce", ndisc_send_na() will be needed. Cc: David S. Miller <davem@davemloft.net> Cc: David Stevens <dlstevens@us.ibm.com> Signed-off-by: Cong Wang <amwang@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-07-31ndisc: Add missing inline to ndisc_addr_option_padJoe Perches
2013-06-19ndisc: Convert use of typedef ctl_table to struct ctl_tableJoe Perches
This typedef is unnecessary and should just be removed. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-01-21ndisc: Move ndisc_opt_addr_space() to include/net/ndisc.h.YOSHIFUJI Hideaki / 吉藤英明
This also makes ndisc_opt_addr_data() and ndisc_fill_addr_option() use ndisc_opt_addr_space(). Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-01-17ndisc: Introduce __ipv6_neigh_lookup_noref().YOSHIFUJI Hideaki / 吉藤英明
This function, which looks up neighbour entry for an IPv6 address without touching refcnt, will be used for patches to remove dependency on rt->n (neighbour entry in rt6_info). Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2013-01-17ndisc: Remove tbl argument for __ipv6_neigh_lookup().YOSHIFUJI Hideaki / 吉藤英明
We can refer to nd_tbl directly. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-12-14ipv6: Change skb->data before using icmpv6_notify() to propagate redirectDuan Jiong
In function ndisc_redirect_rcv(), the skb->data points to the transport header, but function icmpv6_notify() need the skb->data points to the inner IP packet. So before using icmpv6_notify() to propagate redirect, change skb->data to point the inner IP packet that triggered the sending of the Redirect, and introduce struct rd_msg to make it easy. Signed-off-by: Duan Jiong <djduanjiong@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-12-12ndisc: Unexport ndisc_{build,send}_skb().YOSHIFUJI Hideaki
These symbols were exported for bonding device by commit 305d552a ("bonding: send IPv6 neighbor advertisement on failover"). It bacame obsolete by commit 7c899432 ("bonding, ipv4, ipv6, vlan: Handle NETDEV_BONDING_FAILOVER like NETDEV_NOTIFY_PEERS") and removed by commit 4f5762ec ("bonding: Remove obsolete source file 'bond_ipv6.c'"). Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-09net: Dont use ifindices in hash fnsPavel Emelyanov
Eric noticed, that when there will be devices with equal indices, some hash functions that use them will become less effective as they could. Fix this in advance by mixing the net_device address into the hash value instead of the device index. This is true for arp and ndisc hash fns. The netlabel, can and llc ones are also ifindex-based, but that three are init_net-only, thus will not be affected. Many thanks to David and Eric for the hash32_ptr implementation! Signed-off-by: Pavel Emelyanov <xemul@parallels.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-11ipv6: Export ndisc option parsing from ndisc.cDavid S. Miller
This is going to be used internally by the rt6 redirect code. Signed-off-by: David S. Miller <davem@davemloft.net>
2012-04-12Treat ND option 31 as userland (DNSSL support)Alexey I. Froloff
As specified in RFC6106, DNSSL option contains one or more domain names of DNS suffixes. 8-bit identifier of the DNSSL option type as assigned by the IANA is 31. This option should also be treated as userland. Signed-off-by: Alexey I. Froloff <raorn@raorn.name> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-01-27ipv6: Remove neigh argument from ndisc_send_redirect()David S. Miller
Instead, compute it as-needed inside of that function using dst_neigh_lookup(). Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-28ipv6: Create fast inline ipv6 neigh lookup just like ipv4.David S. Miller
Also, create and use an rt6_bind_neighbour() in net/ipv6/route.c to consolidate some common logic. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-28ipv6: Use universal hash for NDISC.David S. Miller
In order to perform a proper universal hash on a vector of integers, we have to use different universal hashes on each vector element. Which means we need 4 different hash randoms for ipv6. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-12-03ipv6: Kill ndisc_get_neigh() inline helper.David S. Miller
It's only used in net/ipv6/route.c and the NULL device check is superfluous for all of the existing call sites. Just expand the __ndisc_lookup_errno() call at each location. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-24net: Remove __KERNEL__ cpp checks from include/netDavid S. Miller
These header files are never installed to user consumption, so any __KERNEL__ cpp checks are superfluous. Projects should also not copy these files into their userland utility sources and try to use them there. If they insist on doing so, the onus is on them to sanitize the headers as needed. Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-22inet: constify ip headers and in6_addrEric Dumazet
Add const qualifiers to structs iphdr, ipv6hdr and in6_addr pointers where possible, to make code intention more obvious. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-02net: kill unused macros from head fileShan Wei
These macros have been defined for several years since v2.6.12-rc2(tracing by git), but never be used. So remove them. Signed-off-by: Shan Wei <shanwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-03net: use __packed annotationEric Dumazet
cleanup patch. Use new __packed annotation in net/ and include/ (except netfilter) Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-09-24sysctl: remove "struct file *" argument of ->proc_handlerAlexey Dobriyan
It's unused. It isn't needed -- read or write flag is already passed and sysctl shouldn't care about the rest. It _was_ used in two places at arch/frv for some reason. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: David Howells <dhowells@redhat.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: "David S. Miller" <davem@davemloft.net> Cc: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-04ipv6: Fix sporadic sendmsg -EINVAL when sending to multicast groups.David S. Miller
Thanks to excellent diagnosis by Eduard Guzovsky. The core problem is that on a network with lots of active multicast traffic, the neighbour cache can fill up. If we try to allocate a new route and thus neighbour cache entry, the bog-standard GC attempt the neighbour layer does in ineffective because route entries hold a reference to the existing neighbour entries and GC can only liberate entries with no references. IPV4 already has a way to handle this, by doing a route cache GC in such situations (when neigh attach returns -ENOBUFS). So simply mimick this on the ipv6 side. Tested-by: Eduard Guzovsky <eguzovsky@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-06bonding: send IPv6 neighbor advertisement on failoverBrian Haley
This patch adds better IPv6 failover support for bonding devices, especially when in active-backup mode and there are only IPv6 addresses configured, as reported by Alex Sidorenko. - Creates a new file, net/drivers/bonding/bond_ipv6.c, for the IPv6-specific routines. Both regular bonds and VLANs over bonds are supported. - Adds a new tunable, num_unsol_na, to limit the number of unsolicited IPv6 Neighbor Advertisements that are sent on a failover event. Default is 1. - Creates two new IPv6 neighbor discovery functions: ndisc_build_skb() ndisc_send_skb() These were required to support VLANs since we have to be able to add the VLAN id to the skb since ndisc_send_na() and friends shouldn't be asked to do this. These two routines are basically __ndisc_send() split into two pieces, in a slightly different order. - Updates Documentation/networking/bonding.txt and bumps the rev of bond support to 3.4.0. On failover, this new code will generate one packet: - An unsolicited IPv6 Neighbor Advertisement, which helps the switch learn that the address has moved to the new slave. Testing has shown that sending just the NA results in pretty good behavior when in active-back mode, I saw no lost ping packets for example. Signed-off-by: Brian Haley <brian.haley@hp.com> Signed-off-by: Jay Vosburgh <fubar@us.ibm.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-10-16sysctl: simplify ->strategyAlexey Dobriyan
name and nlen parameters passed to ->strategy hook are unused, remove them. In general ->strategy hook should know what it's doing, and don't do something tricky for which, say, pointer to original userspace array may be needed (name). Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: David S. Miller <davem@davemloft.net> [ networking bits ] Cc: Ralf Baechle <ralf@linux-mips.org> Cc: David Howells <dhowells@redhat.com> Cc: Matt Mackall <mpm@selenic.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-19ndisc: Add missing strategies for per-device retrans timer/reachable time ↵YOSHIFUJI Hideaki
settings. Noticed from Al Viro <viro@ftp.linux.org.uk> via David Miller <davem@davemloft.net>. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-12[IPV6]: Make address arguments const.YOSHIFUJI Hideaki
- net/ipv6/addrconf.c: ipv6_get_ifaddr(), ipv6_dev_get_saddr() - net/ipv6/mcast.c: ipv6_sock_mc_join(), ipv6_sock_mc_drop(), inet6_mc_check(), ipv6_dev_mc_inc(), __ipv6_dev_mc_dec(), ipv6_dev_mc_dec(), ipv6_chk_mcast_addr() - net/ipv6/route.c: rt6_lookup(), icmp6_dst_alloc() - net/ipv6/ip6_output.c: ip6_nd_hdr() - net/ipv6/ndisc.c: ndisc_send_ns(), ndisc_send_rs(), ndisc_send_redirect(), ndisc_get_neigh(), __ndisc_send() Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-04-10[IPV6] Remove three method declarations in include/net/ndisc.h.Rami Rosen
This patch removes two unused method declarations in include/net/ndisc.h: ndisc_forwarding_on(void) and ndisc_forwarding_off(void); Also igmp6_cleanup(void) appears twice in this header, so one igmp6_cleanup(void) declaration is removed. Signed-off-by: Rami Rosen <ramirose@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-03[IPV6] SIT: Add PRL management for ISATAP.Templin, Fred L
This patch updates the Linux the Intra-Site Automatic Tunnel Addressing Protocol (ISATAP) implementation. It places the ISATAP potential router list (PRL) in the kernel and adds three new private ioctls for PRL management. [Add several changes of structure name, constant names etc. - yoshfuji] Signed-off-by: Fred L. Templin <fred.l.templin@boeing.com> Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2008-02-29[INET]: Remove struct net_proto_family* from _init calls.Denis V. Lunev
struct net_proto_family* is not used in icmp[v6]_init, ndisc_init, igmp_init and tcp_v4_init. Remove it. Signed-off-by: Denis V. Lunev <den@openvz.org> Acked-by: Daniel Lezcano <dlezcano@fr.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-12[IPV6]: remove unused method declaration (net/ndisc.h).Rami Rosen
This patch removes unused declaration of dflt_rt_lookup() method in include/net/ndisc.h Signed-off-by: Rami Rosen <ramirose@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[IPv6]: Export userland ND options through netlink (RDNSS support)Pierre Ynard
As discussed before, this patch provides userland with a way to access relevant options in Router Advertisements, after they are processed and validated by the kernel. Extra options are processed in a generic way; this patch only exports RDNSS options described in RFC5006, but support to control which options are exported could be easily added. A new rtnetlink message type is defined, to transport Neighbor Discovery options, along with optional context information. At the moment only the address of the router sending an RDNSS option is included, but additional attributes may be later defined, if needed by new use cases. Signed-off-by: Pierre Ynard <linkfanel@yahoo.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-02[IPV6]: Misc endianness annotations.Al Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-04-26Don't include linux/config.h from anywhere else in include/David Woodhouse
2006-03-20[IPV6]: ROUTE: Add experimental support for Route Information Option in RA ↵YOSHIFUJI Hideaki
(RFC4191). Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[INET_SOCK]: Move struct inet_sock & helper functions to net/inet_sock.hArnaldo Carvalho de Melo
To help in reducing the number of include dependencies, several files were touched as they were getting needed headers indirectly for stuff they use. Thanks also to Alan Menegotto for pointing out that net/dccp/proto.c had linux/dccp.h include twice. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
