After commit 0ddcf43d5d4a ("ipv4: FIB Local/MAIN table collapse")
fib_local is set but not used. Remove it.
Signed-off-by: David Ahern <dsa@cumulusnetworks.com>
Multipath route lookups should consider knowledge about next hops and not
select a hop that is known to be failed.
Example:
[h2] [h3] 15.0.0.5
3| 3|
[SP1] [SP2]--+
1 2 1 2
| X |
1 2 1 2
12.0.0.2 [TOR1] 3-----------------3 [TOR2] 12.0.0.3
4 4
1 2
[TOR3]
3|
[h1] 12.0.0.1
host h1 with IP 12.0.0.1 has 2 paths to host h3 at 15.0.0.5:
root@h1:~# ip ro ls
12.0.0.0/24 dev swp1 proto kernel scope link src 12.0.0.1
15.0.0.0/16
nexthop via 12.0.0.2 dev swp1 weight 1
nexthop via 12.0.0.3 dev swp1 weight 1
If the link between tor3 and tor1 is down and the link between tor1
and tor2 then tor1 is effectively cut-off from h1. Yet the route lookups
in h1 are alternating between the 2 routes: ping 15.0.0.5 gets one and
ssh 15.0.0.5 gets the other. Connections that attempt to use the
12.0.0.2 nexthop fail since that neighbor is not reachable:
root@h1:~# ip neigh show
12.0.0.3 dev swp1 lladdr 00:02:00:00:00:1b REACHABLE
12.0.0.2 dev swp1 FAILED
The failed path can be avoided by considering known neighbor information
when selecting next hops. If the neighbor lookup fails we have no
knowledge about the nexthop, so give it a shot. If there is an entry
then only select the nexthop if the state is sane. This is similar to
what fib_detect_death does.
To maintain backward compatibility use of the neighbor information is
based on a new sysctl, fib_multipath_use_neigh.
Reviewed-by: Julian Anastasov <ja@ssi.bg>
Signed-off-by: Nikolay Borisov <kernel@kyup.com>
This was initially introduced in df2cf4a78e488d26 ("IGMP: Inhibit
reports for local multicast groups") by defining the sysctl in the
ipv4_net_table array, however it was never implemented to be
namespace aware. Fix this by changing the code accordingly.
This is the final part required to namespaceify the tcp
keep alive mechanism.
This is required to have full tcp keepalive mechanism namespace
support.
Different net namespaces might have different requirements as to
the keepalive time of tcp sockets. This might be required in cases
where different firewall rules are in place which require tcp
timeout sockets to be increased/decreased independently of the host.
Allow accepted sockets to derive their sk_bound_dev_if setting from the
l3mdev domain in which the packets originated. A sysctl setting is added
to control the behavior which is similar to sk_mark and
sysctl_tcp_fwmark_accept.
This effectively allow a process to have a "VRF-global" listen socket,
with child sockets bound to the VRF device in which the packet originated.
A similar behavior can be achieved using sk_mark, but a solution using marks
is incomplete as it does not handle duplicate addresses in different L3
domains/VRFs. Allowing sockets to inherit the sk_bound_dev_if from l3mdev
domain provides a complete solution.
After commit 07f4c90062f8f ("tcp/dccp: try to not exhaust
ip_local_port_range in connect()") it is advised to have an even number
of ports described in /proc/sys/net/ipv4/ip_local_port_range
This means start/end values should have a different parity.
Let's warn sysadmins of this, so that they can update their settings
if they want to.
Suggested-by: David S. Miller <davem@davemloft.net>
This work as a follow-up of commit f7b3bec6f516 ("net: allow setting ecn
via routing table") and adds RFC3168 section 6.1.1.1. fallback for outgoing
ECN connections. In other words, this work adds a retry with a non-ECN
setup SYN packet, as suggested from the RFC on the first timeout:
[...] A host that receives no reply to an ECN-setup SYN within the
normal SYN retransmission timeout interval MAY resend the SYN and
any subsequent SYN retransmissions with CWR and ECE cleared. [...]
Schematic client-side view when assuming the server is in tcp_ecn=2 mode,
that is, Linux default since 2009 via commit 255cac91c3c9 ("tcp: extend
ECN sysctl to allow server-side only ECN"):
1) Normal ECN-capable path:
SYN ECE CWR ----->
<----- SYN ACK ECE
ACK ----->
2) Path with broken middlebox, when client has fallback:
SYN ECE CWR ----X crappy middlebox drops packet
(timeout, rtx)
SYN ----->
<----- SYN ACK
ACK ----->
In case we would not have the fallback implemented, the middlebox drop
point would basically end up as:
(timeout, rtx)
(timeout, rtx)
(timeout, rtx)
In any case, it's rather a smaller percentage of sites where there would
occur such additional setup latency: it was found in end of 2014 that ~56%
of IPv4 and 65% of IPv6 servers of Alexa 1 million list would negotiate
ECN (aka tcp_ecn=2 default), 0.42% of these webservers will fail to connect
when trying to negotiate with ECN (tcp_ecn=1) due to timeouts, which the
fallback would mitigate with a slight latency trade-off. Recent related
paper on this topic:
Brian Trammell, Mirja Kühlewind, Damiano Boppart, Iain Learmonth,
Gorry Fairhurst, and Richard Scheffenegger:
"Enabling Internet-Wide Deployment of Explicit Congestion Notification."
Proc. PAM 2015, New York.
http://ecn.ethz.ch/ecn-pam15.pdf
Thus, when net.ipv4.tcp_ecn=1 is being set, the patch will perform RFC3168,
section 6.1.1.1. fallback on timeout. For users explicitly not wanting this
which can be in DC use case, we add a net.ipv4.tcp_ecn_fallback knob that
allows for disabling the fallback.
tp->ecn_flags are not being cleared in tcp_ecn_clear_syn() on output, but
rather we let tcp_ecn_rcv_synack() take that over on input path in case a
SYN ACK ECE was delayed. Thus a spurious SYN retransmission will not prevent
ECN being negotiated eventually in that case.
Reference: https://www.ietf.org/proceedings/92/slides/slides-92-iccrg-1.pdf
Reference: https://www.ietf.org/proceedings/89/slides/slides-89-tsvarea-1.pdf
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
Signed-off-by: Mirja Kühlewind <mirja.kuehlewind@tik.ee.ethz.ch>
Signed-off-by: Brian Trammell <trammell@tik.ee.ethz.ch>
Cc: Eric Dumazet <edumazet@google.com>
Cc: Dave That <dave.taht@gmail.com>
Now that all of the operations are safe on a single hash table
accross network namespaces, allocate a single global hash table
and update the code to use it.
As per RFC4821 7.3. Selecting Probe Size, a probe timer should
be armed once probing has converged. Once this timer expired,
probing again to take advantage of any path PMTU change. The
recommended probing interval is 10 minutes per RFC1981. Probing
interval could be sysctled by sysctl_tcp_probe_interval.
Eric Dumazet suggested to implement pseudo timer based on 32bits
jiffies tcp_time_stamp instead of using classic timer for such
rare event.
Signed-off-by: Fan Du <fan.du@intel.com>
Current probe_size is chosen by doubling mss_cache,
the probing process will end shortly with a sub-optimal
mss size, and the link mtu will not be taken full
advantage of, in return, this will make user to tweak
tcp_base_mss with care.
Use binary search to choose probe_size in a fine
granularity manner, an optimal mss will be found
to boost performance as its maxmium.
In addition, introduce a sysctl_tcp_probe_threshold
to control when probing will stop in respect to
the width of search range.
Test env:
Docker instance with vxlan encapuslation(82599EB)
iperf -c 10.0.0.24 -t 60
before this patch:
1.26 Gbits/sec
After this patch: increase 26%
1.59 Gbits/sec
Acked-by: John Heffner <johnwheffner@gmail.com>
If something goes wrong with IPv4 FIB offload, mark entire net offload
disabled. This is brute force policy to basically shut down IPv4 FIB offload
permanently if there is a problem offloading any route to an external device.
We can refine the policy in the future, to handle failures on a per-device or
per-route basis, but for now, this policy is per-net.
What we're trying to avoid is an inconsistent split between the kernel's FIB
and the offload device's FIB. We don't want the device to fwd a pkt
inconsitent with what the kernel would do. An example of a split is if device
has 10.0.0.0/16 and kernel has 10.0.0.0/16 and 10.0.0.0/24, the device wouldn't
see the longest prefix 10.0.0.0/24 and potentially forward pkts incorrectly.
Limited capacity or limited capability are two ways a route may fail to install
to the offload device. We'll not differentiate between failures at this time,
and treat any failure as fatal and mark the net as fib_offload_disabled.
Signed-off-by: Scott Feldman <sfeldma@gmail.com>
The fib_table was wrapped in several places with an
rcu_read_lock/rcu_read_unlock however after looking over the code I found
several spots where the tables were being accessed as just standard
pointers without any protections. This change fixes that so that all of
the proper protections are in place when accessing the table to take RCU
replacement or removal of the table into account.
Signed-off-by: Alexander Duyck <alexander.h.duyck@redhat.com>
Joining multicast group on ethernet level via "ip maddr" command would
not work if we have an Ethernet switch that does igmp snooping since
the switch would not replicate multicast packets on ports that did not
have IGMP reports for the multicast addresses.
Linux vxlan interfaces created via "ip link add vxlan" have the group option
that enables then to do the required join.
By extending ip address command with option "autojoin" we can get similar
functionality for openvswitch vxlan interfaces as well as other tunneling
mechanisms that need to receive multicast traffic. The kernel code is
structured similar to how the vxlan driver does a group join / leave.
example:
ip address add 224.1.1.10/24 dev eth5 autojoin
ip address del 224.1.1.10/24 dev eth5
Signed-off-by: Madhu Challa <challa@noironetworks.com>
Packetization Layer Path MTU Discovery works separately beside
Path MTU Discovery at IP level, different net namespace has
various requirements on which one to chose, e.g., a virutalized
container instance would require TCP PMTU to probe an usable
effective mtu for underlying tunnel, while the host would
employ classical ICMP based PMTU to function.
Hence making TCP PMTU mechanism per net namespace to decouple
two functionality. Furthermore the probe base MSS should also
be configured separately for each namespace.
drivers/net/vxlan.c
drivers/vhost/net.c
include/linux/if_vlan.h
net/core/dev.c
The net/core/dev.c conflict was the overlap of one commit marking an
existing function static whilst another was adding a new function.
In the include/linux/if_vlan.h case, the type used for a local
variable was changed in 'net', whereas the function got rewritten
to fix a stacked vlan bug in 'net-next'.
In drivers/vhost/net.c, Al Viro's iov_iter conversions in 'net-next'
overlapped with an endainness fix for VHOST 1.0 in 'net'.
In drivers/net/vxlan.c, vxlan_find_vni() added a 'flags' parameter
in 'net-next' whereas in 'net' there was a bug fix to pass in the
correct network namespace pointer in calls to this function.
In commit be9f4a44e7d41 ("ipv4: tcp: remove per net tcp_sock")
I tried to address contention on a socket lock, but the solution
I chose was horrible :
commit 3a7c384ffd57e ("ipv4: tcp: unicast_sock should not land outside
of TCP stack") addressed a selinux regression.
commit 0980e56e506b ("ipv4: tcp: set unicast_sock uc_ttl to -1")
took care of another regression.
commit b5ec8eeac46 ("ipv4: fix ip_send_skb()") fixed another regression.
commit 811230cd85 ("tcp: ipv4: initialize unicast_sock sk_pacing_rate")
was another shot in the dark.
Really, just use a proper socket per cpu, and remove the skb_orphan()
call, to re-enable flow control.
This solves a serious problem with FQ packet scheduler when used in
hostile environments, as we do not want to allocate a flow structure
for every RST packet sent in response to a spoofed packet.
Get rid of nr_cpu_ids and use modern percpu allocation.
Note that the sockets themselves are not yet allocated
using NUMA affinity.
net.ipv4.ip_nonlocal_bind sysctl was global to all network
namespaces. This patch allows to set a different value for each
network namespace.
Signed-off-by: Vincent Bernat <vincent@bernat.im>
ip_local_port_range is already per netns, so should ip_local_reserved_ports
be. And since it is none by default we don't actually need it when we don't
enable CONFIG_SYSCTL.
By the way, rename inet_is_reserved_local_port() to inet_is_local_reserved_port()
When using mark-based routing, sockets returned from accept()
may need to be marked differently depending on the incoming
connection request.
This is the case, for example, if different socket marks identify
different networks: a listening socket may want to accept
connections from all networks, but each connection should be
marked with the network that the request came in on, so that
subsequent packets are sent on the correct network.
This patch adds a sysctl to mark TCP sockets based on the fwmark
of the incoming SYN packet. If enabled, and an unmarked socket
receives a SYN, then the SYN packet's fwmark is written to the
connection's inet_request_sock, and later written back to the
accepted socket when the connection is established. If the
socket already has a nonzero mark, then the behaviour is the same
as it is today, i.e., the listening socket's fwmark is used.
Black-box tested using user-mode linux:
- IPv4/IPv6 SYN+ACK, FIN, etc. packets are routed based on the
mark of the incoming SYN packet.
- The socket returned by accept() is marked with the mark of the
- Tested with syncookies=1 and syncookies=2.
Signed-off-by: Lorenzo Colitti <lorenzo@google.com>
Kernel-originated IP packets that have no user socket associated
with them (e.g., ICMP errors and echo replies, TCP RSTs, etc.)
are emitted with a mark of zero. Add a sysctl to make them have
the same mark as the packet they are replying to.
This allows an administrator that wishes to do so to use
mark-based routing, firewalling, etc. for these replies by
marking the original packets inbound.
Tested using user-mode linux:
- ICMP/ICMPv6 echo replies and errors.
- TCP RST packets (IPv4 and IPv6).
Similarly, when CONFIG_SYSCTL is not set, ping_group_range should still
work, just that no one can change it. Therefore we should move it out of
sysctl_net_ipv4.c. And, it should not share the same seqlock with
ip_local_port_range.
BTW, rename it to ->ping_group_range instead.
Cc: Francois Romieu <romieu@fr.zoreil.com>
Reported-by: Stefan de Konink <stefan@konink.de>
When CONFIG_SYSCTL is not set, ip_local_port_range should still work,
just that no one can change it. Therefore we should move it out of sysctl_inet.c.
Also, rename it to ->ip_local_ports instead.
pmtu spoofing
While forwarding we should not use the protocol path mtu to calculate
the mtu for a forwarded packet but instead use the interface mtu.
We mark forwarded skbs in ip_forward with IPSKB_FORWARDED, which was
introduced for multicast forwarding. But as it does not conflict with
our usage in unicast code path it is perfect for reuse.
I moved the functions ip_sk_accept_pmtu, ip_sk_use_pmtu and ip_skb_dst_mtu
along with the new ip_dst_mtu_maybe_forward to net/ip.h to fix circular
dependencies because of IPSKB_FORWARDED.
Because someone might have written a software which does probe
destinations manually and expects the kernel to honour those path mtus
I introduced a new per-namespace "ip_forward_use_pmtu" knob so someone
can disable this new behaviour. We also still use mtus which are locked on a
route for forwarding.
The reason for this change is, that path mtus information can be injected
into the kernel via e.g. icmp_err protocol handler without verification
of local sockets. As such, this could cause the IPv4 forwarding path to
wrongfully emit fragmentation needed notifications or start to fragment
packets along a path.
Tunnel and ipsec output paths clear IPCB again, thus IPSKB_FORWARDED
won't be set and further fragmentation logic will use the path mtu to
determine the fragmentation size. They also recheck packet size with
help of path mtu discovery and report appropriate errors.
Cc: John Heffner <johnwheffner@gmail.com>
Cc: Steffen Klassert <steffen.klassert@secunet.com>
The other field in ipv4_config, log_martians, was converted to a
per-interface setting, so we can just remove the whole structure.
The code that is implemented is per memory cgroup not per netns, and
having per netns bits is just confusing. Remove the per netns bits to
make it easier to see what is really going on.
- Move sysctl_local_ports from a global variable into struct netns_ipv4.
- Modify inet_get_local_port_range to take a struct net, and update all
of the callers.
- Move the initialization of sysctl_local_ports into
sysctl_net_ipv4.c:ipv4_sysctl_init_net from inet_connection_sock.c
v2:
- Ensure indentation used tabs
- Fixed ip.h so it applies cleanly to todays net-next
v3:
- Compile fixes of strange callers of inet_get_local_port_range.
This patch now successfully passes an allmodconfig build.
Removed manual inlining of inet_get_local_port_range in ipv4_local_port_range
Originally-by: Samya <samya@twitter.com>
Acked-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
Current net name space has only one genid for both IPv4 and IPv6, it has below
drawbacks:
- Add/delete an IPv4 address will invalidate all IPv6 routing table entries.
- Insert/remove XFRM policy will also invalidate both IPv4/IPv6 routing table
entries even when the policy is only applied for one address family.
Thus, this patch attempt to split one genid for two to cater for IPv4 and IPv6
separately in a fine granularity.
Signed-off-by: Fan Du <fan.du@windriver.com>
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
The xfrm gc threshold can be configured via xfrm{4,6}_gc_thresh
sysctl but currently only in init_net, other namespaces always
use the default value. This can substantially limit the number
of IPsec tunnels that can be effectively used.
Signed-off-by: Michal Kubecek <mkubecek@suse.cz>
Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com>
As per suggestion from Eric Dumazet this patch makes tcp_ecn sysctl
namespace aware. The reason behind this patch is to ease the testing
of ecn problems on the internet and allows applications to tune their
own use of ecn.
Cc: Stephen Hemminger <shemminger@vyatta.com>
drivers/net/team/team.c
drivers/net/usb/qmi_wwan.c
net/batman-adv/bat_iv_ogm.c
net/ipv4/fib_frontend.c
net/ipv4/route.c
net/l2tp/l2tp_netlink.c
The team, fib_frontend, route, and l2tp_netlink conflicts were simply
overlapping changes.
qmi_wwan and bat_iv_ogm were of the "use HEAD" variety.
With help from Antonio Quartulli.
This commit prepares the use of rt_genid by both IPv4 and IPv6.
Initialization is left in IPv4 part.
Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
This merges (3f509c6 netfilter: nf_nat_sip: fix incorrect handling
of EBUSY for RTCP expectation) to Patrick McHardy's IPv6 NAT changes.
