According to specification etsi 102 622 chapter 4.4 pipes
identifier is 7 bits long giving a 127 possible pipes value.
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Signed-off-by: Christophe Ricard <christophe-h.ricard@st.com>
According to etsi 102 622 chapter 11.2.2.4 EVT_TRANSACTION,
the nfc_evt_transaction parameters can be 0 up to 255 byte long.
According to specification etsi 102 622 chapter 4.4 pipes identifier
A simple forward for firmware download (i.e. sending a new firmware
to the NFC adapter) from the NFC subsystem to the drivers.
This feature is required to update the firmware of NXP-NCI NFC
controllers but can be used by any NCI driver.
This feature has been present in the HCI subsystem since 9a695d.
Signed-off-by: Clément Perrochaud <clement.perrochaud@effinnov.com>
conn_info is currently allocated only after nfcee_discovery_ntf
which is not generic enough for logical connection other than
NFCEE. The corresponding conn_info is now created in
nci_core_conn_create_rsp().
For consistency sake change nci_core_conn_create_rsp structure
credits field to credits_cnt.
The current implementation limits nci_core_conn_create_req()
to only manage NCI_DESTINATION_NFCEE.
Add new parameters to nci_core_conn_create() to support all
destination types described in the NCI specification.
Because there are some parameters with variable size dynamic
buffer allocation is needed.
The NCI_STATIC_RF_CONN_ID logical connection is the most used
connection. Keeping it directly accessible in the nci_dev
structure will simplify and optimize the access.
The NFCC sends an NCI_OP_RF_NFCEE_ACTION_NTF notification
to the host (DH) to let it know that for example an RF
transaction with a payment reader is done.
For now the notification handler is empty.
NFC_EVT_TRANSACTION is sent through netlink in order for a
specific application running on a secure element to notify
userspace of an event. Typically the secure element application
counterpart on the host could interpret that event and act
upon it.
Forwarded information contains:
- SE host generating the event
- Application IDentifier doing the operation
- Applications parameters
According to the NCI specification, one can use HCI over NCI
to talk with specific NFCEE. The HCI network is viewed as one
logical NFCEE.
This is needed to support secure element running HCI only
firmwares embedded on an NCI capable chipset, like e.g. the
st21nfcb.
There is some duplication between this piece of code and the
HCI core code, but the latter would need to be abstracted even
more to be able to use NCI as a logical transport for HCP packets.
In order to communicate with an NFCEE, we need to open a logical
connection to it, by sending the NCI_OP_CORE_CONN_CREATE_CMD
command to the NFCC. It's left up to the drivers to decide when
to close an already opened logical connection.
NFCEEs can be enabled or disabled by sending the
NCI_OP_NFCEE_MODE_SET_CMD command to the NFCC. This patch
provides an API for drivers to enable and disable e.g. their
NCI discoveredd secure elements.
NFCEEs (NFC Execution Environment) have to be explicitly
discovered by sending the NCI_OP_NFCEE_DISCOVER_CMD
command. The NFCC will respond to this command by telling
us how many NFCEEs are connected to it. Then the NFCC sends
a notification command for each and every NFCEE connected.
Here we implement support for sending
NCI_OP_NFCEE_DISCOVER_CMD command, receiving the response
and the potential notifications.
Add NFCEE NCI constant for:
- NFCEE Interface/Protocols
- Destination type
- Destination-specific parameters type
- NFCEE Discovery Action
The current NCI core only support the RF static connection.
For other NFC features such as Secure Element communication, we
may need to create logical connections to the NFCEE (Execution
Environment.
In order to track each logical connection ID dynamically, we add a
linked list of connection info pointers to the nci_dev structure.
When a command is received, it is sometime needed to let the CLF driver do
some additional operations. (ex: count remaining pipe notification...)
As there can be several pipes connected to the same gate, we need
to know which pipe ID to use when sending an HCI response. A gate
ID is not enough.
Instead of changing the nfc_hci_send_response() API to something
not aligned with the rest of the HCI API, we call nfc_hci_hcp_message_tx
directly.
In order to keep host source information on specific hci event (such as
evt_connectivity or evt_transaction) and because 2 pipes can be connected
to the same gate, it is necessary to add a table referencing every pipe
with a {gate, host} tuple.
Several pipes may point to the same CLF gate, so getting the gate ID
as an input is not enough.
For example dual secure element may have 2 pipes (1 for uicc and
1 for eSE) pointing to the connectivity gate.
As resolving gate and host IDs can be done from a pipe, we now pass
the pipe ID to the event received handler.
Some pipe are only created by other host (different than the
Terminal Host).
The pipe values will for example be notified by
NFC_HCI_ADM_NOTIFY_PIPE_CREATED.
se_io allows to send apdu over the CLF to the embedded Secure Element.
secure element
Some NFC controller using NCI protocols may need a proprietary commands
flow to disable a secure element
secure element
flow to enable a secure element
available secure element
flow to discover all available secure element
The Target responds to the ATR_REQ with the ATR_RES. Configure the General
Bytes in ATR_RES with the first three octets equal to the NFC Forum LLCP
magic number, followed by some LLC Parameters TLVs described in section
4.5 of [LLCP].
Signed-off-by: Julien Lefrique <lefrique@marvell.com>
Changes:
* Extract the Listen mode activation parameters from RF_INTF_ACTIVATED_NTF.
* Store the General Bytes of ATR_REQ.
* Signal that Target mode is activated in case of an activation in NFC-DEP.
* Update the NCI state accordingly.
* Use the various constants defined in nfc.h.
* Fix the ATR_REQ and ATR_RES maximum size. As per NCI 1.0 and NCI 1.1, the
Activation Parameters for both Poll and Listen mode contain all the bytes of
ATR_REQ/ATR_RES starting and including Byte 3 as defined in [DIGITAL].
In [DIGITAL], the maximum size of ATR_REQ/ATR_RES is 64 bytes and they are
numbered starting from Byte 1.
Send LA_SEL_INFO and LF_PROTOCOL_TYPE with NFC-DEP protocol enabled.
Configure 212 Kbit/s and 412 Kbit/s bit rates for Listen F.
When an NFC-DEP Initiator times out when waiting for
a DEP_RES from the Target, its supposed to send an
ATN to the Target. The Target should respond to the
ATN with a similar ATN PDU and the Initiator can then
resend the last non-ATN PDU that it sent. No more
than 'N(retry,atn)' are to be send where
2 <= 'N(retry,atn)' <= 5. If the Initiator had just
sent a NACK PDU when the timeout occurred, it is to
continue sending NACKs until 'N(retry,nack)' NACKs
have been send. This is described in section
14.12.5.6 of the NFC-DEP Digital Protocol Spec.
The digital layer's NFC-DEP code doesn't implement
this so add that support.
The value chosen for 'N(retry,atn)' is 2.
Reviewed-by: Thierry Escande <thierry.escande@linux.intel.com>
Tested-by: Thierry Escande <thierry.escande@linux.intel.com>
Signed-off-by: Mark A. Greer <mgreer@animalcreek.com>
When an NFC-DEP Target receives a NACK PDU with
a PNI equal to 1 less than the current PNI, it
is supposed to re-send the last PDU. This is
implied in section 14.12.5.4 of the NFC Digital
Protocol Spec.
Target-side NACK handing so add it. The last PDU
that was sent is saved in the 'nfc_digital_dev'
structure's 'saved_skb' member. The skb will have
an additional reference taken to ensure that the skb
isn't freed when the driver performs a kfree_skb()
on the skb. The length of the skb/PDU is also saved
so the length can be restored when re-sending the PDU
in the skb (the driver will perform an skb_pull() so
an skb_push() needs to be done to restore the skb's
data pointer/length).
When an NFC-DEP Initiator receives a frame with
an incorrect CRC or with a parity error, and the
frame is at least 4 bytes long, its supposed to
send a NACK to the Target. The Initiator can
send up to 'N(retry,nack)' consecutive NACKs
where 2 <= 'N(retry,nack)' <= 5. When the limit
is exceeded, a PROTOCOL EXCEPTION is raised.
Any other type of transmission error is to be
ignored and the Initiator should continue
waiting for a new frame. This is described
in section 14.12.5.4 of the NFC Digital Protocol
Spec.
any of this so add it. This support diverges from
the spec in two significant ways:
a) NACKs will be sent for ANY error reported by the
driver except a timeout. This is done because
there is currently no way for the digital layer
to distinguish a CRC or parity error from any
other type of error reported by the driver.
b) All other errors will cause a PROTOCOL EXCEPTION
even frames with CRC errors that are less than 4
bytes.
The value chosen for 'N(retry,nack)' is 2.
Targets do not send NACK PDUs.
When the NFC-DEP code is given a packet to send
that is larger than the peer's maximum payload,
its supposed to set the 'MI' bit in the 'I' PDU's
Protocol Frame Byte (PFB). Setting this bit
indicates that NFC-DEP chaining is to occur.
When NFC-DEP chaining is progress, sender 'I' PDUs
are acknowledged with 'ACK' PDUs until the last 'I'
PDU in the chain (which has the 'MI' bit cleared)
is responded to with a normal 'I' PDU. This can
occur while in Initiator mode or in Target mode.
Sender NFC-DEP chaining is currently not implemented
in the digital layer so add that support. Unfortunately,
since sending a frame may require writing the CRC to the
end of the data, the relevant data part of the original
skb must be copied for each intermediate frame.
The maximum payload for NFC-DEP exchanges (i.e., the
number of bytes between SoD and EoD) is negotiated
using the ATR_REQ, ATR_RES, and PSL_REQ commands.
The valid maximum lengths are 64, 128, 192, and 254
bytes.
Currently, NFC-DEP code assumes that both sides are
always using 254 byte maximums and ignores attempts
by the peer to change it. Instead, implement the
negotiation code, enforce the local maximum when
receiving data from the peer, and don't send payloads
that exceed the remote's maximum. The default local
maximum is 254 bytes.
When in Target mode, the Initiator specifies whether
subsequent DEP_REQ and DEP_RES frames will include
a DID byte by the value passed in the ATR_REQ. If
the DID value in the ATR_REQ is '0' then no DID
byte will be included. If the DID value is between
'1' and '14' then a DID byte containing the same
value must be included in subsequent DEP_REQ and
DEP_RES frames. Any other DID value is invalid.
This is specified in sections 14.8.1.2 and 14.8.2.2
of the NFC Digital Protocol Spec.
Checking the DID value (if it should be there at all),
is not currently supported by the digital layer's
NFC-DEP code. Add this support by remembering the
DID value in the ATR_REQ, checking the DID value of
received DEP_REQ frames (if it should be there at all),
and including the remembered DID value in DEP_RES
frames when appropriate.
In NFC Forum NCI specification, some RF Protocol values are
reserved for proprietary use (from 0x80 to 0xfe).
Some CLF vendor may need to use one value within this range
for specific technology.
Furthermore, some CLF may not becompliant with NFC Froum NCI
specification 2.0 and therefore will not support RF Protocol
value 0x06 for PROTOCOL_T5T as mention in a draft specification
and in a recent push.
Adding get_rf_protocol handle to the nci_ops structure will
help to set the correct technology to target.
Update nci.h to respect latest NCI specification proposal
(stop using proprietary opcodes). Handle ISO15693 parameters
in NCI_RF_ACTIVATED_NTF handler.
Signed-off-by: Vincent Cuissard <cuissard@marvell.com>
The digital layer of the NFC subsystem currently
supports a 'tg_listen_mdaa' driver hook that supports
devices that can do mode detection and automatic
anticollision. However, there are some devices that
can do mode detection but not automatic anitcollision
so add the 'tg_listen_md' hook to support those devices.
In order for the digital layer to get the RF technology
detected by the device from the driver, add the
'tg_get_rf_tech' hook. It is only valid to call this
hook immediately after a successful call to 'tg_listen_md'.
CC: Thierry Escande <thierry.escande@linux.intel.com>
Remove extra blank line that was inadvertently
added by a recent commit.
stop_poll allows to stop CLF reader polling. Some other operations might be
necessary for some CLF to stop polling. For example in card mode.
Add new "NFC_DIGITAL_FRAMING_*" calls to the digital
layer so the driver can make the necessary adjustments
when performing anticollision while in target mode.
The driver must ensure that the effect of these calls
happens after the following response has been sent but
before reception of the next request begins.
Acked-by: Thierry Escande <thierry.escande@linux.intel.com>
This allows for a more generic NFC sniffing by using SOCKPROTO_RAW
SOCK_RAW to read RAW NFC frames. This is for sniffing anything but LLCP
(HCI, NCI, etc...).
Signed-off-by: Hiren Tandel <hirent@marvell.com>
Signed-off-by: Rahul Tank <rahult@marvell.com>
Add RF tech and framing macros for the ISO/IEC 14443-B Protocol.
Cc: Thierry Escande <thierry.escande@linux.intel.com>
load_session allows a CLF to restore the gate <-> pipe table from some
proprietary location.
The main advantage to add this function is to reduce the memory wear by
running pipe creation (and storing) only once.
According to the latest draft specification from
the NFC-V committee, ISO/IEC 15693 tags will be
referred to as "Type 5" tags and not "Type V"
tags anymore. Make the code reflect the new
terminology.
This adds support for ATS request and response handling for type 4A tag
activation.
Signed-off-by: Thierry Escande <thierry.escande@linux.intel.com>
Add the header definitions required by upcoming
patches that add support for ISO/IEC 15693.
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next into for-davem
This API can be used by drivers to send their custom
configuration using SET_CONFIG NCI command to the device.
Signed-off-by: Amitkumar Karwar <akarwar@marvell.com>
Signed-off-by: Bing Zhao <bzhao@marvell.com>
Some drivers require special configuration while initializing.
This patch adds setup handler for this custom configuration.
