path: root/include/net/phonet
2011-05-02net: dont hold rtnl mutex during netlink dump callbacksEric Dumazet
Four years ago, Patrick made a change to hold rtnl mutex during netlink dump callbacks. I believe it was a wrong move. This slows down concurrent dumps, making good old /proc/net/ files faster than rtnetlink in some situations. This occurred to me because one "ip link show dev ..." was _very_ slow on a workload adding/removing network devices in background. All dump callbacks are able to use RCU locking now, so this patch does roughly a revert of commits : 1c2d670f366 : [RTNETLINK]: Hold rtnl_mutex during netlink dump callbacks 6313c1e0992 : [RTNETLINK]: Remove unnecessary locking in dump callbacks This let writers fight for rtnl mutex and readers going full speed. It also takes care of phonet : phonet_route_get() is now called from rcu read section. I renamed it to phonet_route_get_rcu() Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Patrick McHardy <kaber@trash.net> Cc: Remi Denis-Courmont <remi.denis-courmont@nokia.com> Acked-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-09Phonet: allocate sock from accept syscall rather than soft IRQRémi Denis-Courmont
This moves most of the accept logic to process context like other socket stacks do. Then we can use a few more common socket helpers and simplify a bit. Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-25Phonet: fix flawed "SYN/ACK" logicRémi Denis-Courmont
* Do not fail if the peer supports more or less than 3 algorithms. * Ignore unknown congestion control algorithms instead of failing. * Simplify congestion algorithm negotiation (largest is best). * Do not use a static buffer. * Fix off-by-two read overflow. * Avoid extra memory copy (in addition to skb_copy_bits()). The previous code really made no sense. Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-25Phonet: don't bother with transaction IDs (especially for indications)Rémi Denis-Courmont
2011-02-25Phonet: remove redumdant pep->pipe_stateRémi Denis-Courmont
sk->sk_state already contains the pipe state. Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-02-25Phonet: use socket destination in pipe protocolRémi Denis-Courmont
2011-02-25Phonet: implement per-socket destination/peer addressRémi Denis-Courmont
2011-01-10phonet: some signedness bugsDan Carpenter
Dan Rosenberg pointed out that there were some signed comparison bugs in the phonet protocol. http://marc.info/?l=full-disclosure&m=129424528425330&w=2 The problem is that we check for array overflows but "protocol" is signed and we don't check for array underflows. If you have already have CAP_SYS_ADMIN then you could use the bugs to get root, or someone could cause an oops by mistake. Signed-off-by: Dan Carpenter <error27@gmail.com> Acked-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-13Phonet: 'connect' socket implementation for Pipe controllerKumar Sanghvi
Based on suggestion by Rémi Denis-Courmont to implement 'connect' for Pipe controller logic, this patch implements 'connect' socket call for the Pipe controller logic. The patch does following:- - Removes setsockopts for PNPIPE_CREATE and PNPIPE_DESTROY - Adds setsockopt for setting the Pipe handle value - Implements connect socket call - Updates the Pipe controller logic User-space should now follow below sequence with Pipe controller:- -socket -bind -setsockopt for PNPIPE_PIPE_HANDLE -connect -setsockopt for PNPIPE_ENCAP_IP -setsockopt for PNPIPE_ENABLE GPRS/3G data has been tested working fine with this. Signed-off-by: Kumar Sanghvi <kumar.sanghvi@stericsson.com> Acked-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-27Phonet: Implement Pipe Controller to support Nokia Slim ModemsKumar Sanghvi
Phonet stack assumes the presence of Pipe Controller, either in Modem or on Application Processing Engine user-space for the Pipe data. Nokia Slim Modems like WG2.5 used in ST-Ericsson U8500 platform do not implement Pipe controller in them. This patch adds Pipe Controller implemenation to Phonet stack to support Pipe data over Phonet stack for Nokia Slim Modems. Signed-off-by: Kumar Sanghvi <kumar.sanghvi@stericsson.com> Acked-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-15Phonet: list subscribed resources via proc_fsRémi Denis-Courmont
2010-09-15Phonet: resource routing backendRémi Denis-Courmont
When both destination device and object are nul, Phonet routes the packet according to the resource field. In fact, this is the most common pattern when sending Phonet "request" packets. In this case, the packet is delivered to whichever endpoint (socket) has registered the resource. This adds a new table so that Linux processes can register their Phonet sockets to Phonet resources, if they have adequate privileges. (Namespace support is not implemented at the moment.) Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-15Phonet: remove dangling pipe if an endpoint is closed earlyRémi Denis-Courmont
Closing a pipe endpoint is not normally allowed by the Phonet pipe, other than as a side after-effect of removing the pipe between two endpoints. But there is no way to prevent Linux userspace processes from being killed or suffering from bugs, so this can still happen. We might as well forcefully close Phonet pipe endpoints then. The cellular modem supports only a few existing pipes at a time. So we really should not leak them. This change instructs the modem to destroy the pipe if either of the pipe's endpoint (Linux socket) is closed too early. Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-09phonet: use call_rcu for phonet device freeJiri Pirko
Use call_rcu rather than synchronize_rcu. Signed-off-by: Jiri Pirko <jpirko@redhat.com> Acked-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-07Phonet: zero-copy GPRS TXRémi Denis-Courmont
Send aligned pipe payload if requested to do so. Then, the socket buffer needs not be fragmented anymore. Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-07Phonet: zero-copy aligned GPRS RXRémi Denis-Courmont
Newer Nokia cellular modems can use aligned payload for their GPRS pipe. Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-11-18Phonet: convert devices list to RCURémi Denis-Courmont
2009-11-10Phonet: put sockets in a hash tableRémi Denis-Courmont
2009-10-14Phonet: routing table Netlink interfaceRémi Denis-Courmont
2009-10-14Phonet: routing table backendRémi Denis-Courmont
The Phonet "universe" only has 64 addresses, so we keep a trivial flat routing table. Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-14Phonet: deliver broadcast packets to broadcast socketsRémi Denis-Courmont
2009-07-23Phonet: sockets list through proc_fsRémi Denis-Courmont
This provides a list of sockets with their Phonet bind addresses and some socket debug informations through /proc/net/phonet. Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-25Phonet: publicize the Netlink notification functionRémi Denis-Courmont
2009-01-26Phonet: use per-namespace devices listremi.denis-courmont@nokia
2009-01-26Phonet: handle rtnetlink registration failureremi.denis-courmont@nokia
2009-01-26Phonet: allow phonet_device_init() to fail, put it to __init sectionremi.denis-courmont@nokia
2008-12-17Phonet: use atomic for packet TX windowRémi Denis-Courmont
GPRS TX flow control won't need to lock the underlying socket anymore. Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-12-03Phonet: basic net namespace supportRémi Denis-Courmont
2008-10-26Phonet: include generic link-layer header size in MAX_PHONET_HEADERRemi Denis-Courmont
This fixes an OOPS in hard_header if a Phonet address is assigned to a non-Phonet network interface. Signed-off-by: Remi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-05Phonet: implement GPRS virtual interface over PEP socketRémi Denis-Courmont
2008-10-05Phonet: receive pipe control requests as out-of-band dataRémi Denis-Courmont
2008-10-05Phonet: Pipe End Point for Phonet Pipes protocolRémi Denis-Courmont
This protocol provides some connection handling and negotiated congestion control. Nokia cellular modems use it for bulk transfers. It provides packet boundaries (hence SOCK_SEQPACKET). Congestion control is per packet rather per byte, so we do not re-use the generic socket memory accounting. Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-05Phonet: connected sockets glueRémi Denis-Courmont
Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Acked-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-22Phonet: emit errors when a packet cannot be delivered locallyRemi Denis-Courmont
When there is no listener socket for a received packet, send an error back to the sender. Signed-off-by: Remi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-22Phonet: proc interface for port rangeRemi Denis-Courmont
Phonet endpoints are bound to individual ports. This provides a /proc/sys/net/phonet (or sysctl) interface for selecting the range of automatically allocated ports (much like the ip_local_port_range with IPv4). Signed-off-by: Remi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-22Phonet: Phonet datagram transport protocolRemi Denis-Courmont
This provides the basic SOCK_DGRAM transport protocol for Phonet. Signed-off-by: Remi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-22Phonet: common socket glueRemi Denis-Courmont
This provides the socket API for the Phonet protocols family. Signed-off-by: Remi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-22Phonet: Netlink interfaceRemi Denis-Courmont
This provides support for configuring Phonet addresses, notifying Phonet configuration changes, and dumping the configuration. Signed-off-by: Remi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-22Phonet: network device and address handlingRemi Denis-Courmont
This provides support for adding Phonet addresses to and removing Phonet addresses from network devices. Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-22Phonet: PF_PHONET protocol family supportRemi Denis-Courmont
This is the basis for the Phonet protocol families, and introduces the ETH_P_PHONET packet type and the PF_PHONET socket family. Signed-off-by: Remi Denis-Courmont <remi.denis-courmont@nokia.com> Signed-off-by: David S. Miller <davem@davemloft.net>
