[ Upstream commit 5ec7d18d1813a5bead0b495045606c93873aecbb ]
This patch is to delay the endpoint free by calling call_rcu() to fix
another use-after-free issue in sctp_sock_dump():
BUG: KASAN: use-after-free in __lock_acquire+0x36d9/0x4c20
Call Trace:
__lock_acquire+0x36d9/0x4c20 kernel/locking/lockdep.c:3218
lock_acquire+0x1ed/0x520 kernel/locking/lockdep.c:3844
__raw_spin_lock_bh include/linux/spinlock_api_smp.h:135 [inline]
_raw_spin_lock_bh+0x31/0x40 kernel/locking/spinlock.c:168
spin_lock_bh include/linux/spinlock.h:334 [inline]
__lock_sock+0x203/0x350 net/core/sock.c:2253
lock_sock_nested+0xfe/0x120 net/core/sock.c:2774
lock_sock include/net/sock.h:1492 [inline]
sctp_sock_dump+0x122/0xb20 net/sctp/diag.c:324
sctp_for_each_transport+0x2b5/0x370 net/sctp/socket.c:5091
sctp_diag_dump+0x3ac/0x660 net/sctp/diag.c:527
__inet_diag_dump+0xa8/0x140 net/ipv4/inet_diag.c:1049
inet_diag_dump+0x9b/0x110 net/ipv4/inet_diag.c:1065
netlink_dump+0x606/0x1080 net/netlink/af_netlink.c:2244
__netlink_dump_start+0x59a/0x7c0 net/netlink/af_netlink.c:2352
netlink_dump_start include/linux/netlink.h:216 [inline]
inet_diag_handler_cmd+0x2ce/0x3f0 net/ipv4/inet_diag.c:1170
__sock_diag_cmd net/core/sock_diag.c:232 [inline]
sock_diag_rcv_msg+0x31d/0x410 net/core/sock_diag.c:263
netlink_rcv_skb+0x172/0x440 net/netlink/af_netlink.c:2477
sock_diag_rcv+0x2a/0x40 net/core/sock_diag.c:274
This issue occurs when asoc is peeled off and the old sk is freed after
getting it by asoc->base.sk and before calling lock_sock(sk).
To prevent the sk free, as a holder of the sk, ep should be alive when
calling lock_sock(). This patch uses call_rcu() and moves sock_put and
ep free into sctp_endpoint_destroy_rcu(), so that it's safe to try to
hold the ep under rcu_read_lock in sctp_transport_traverse_process().
If sctp_endpoint_hold() returns true, it means this ep is still alive
and we have held it and can continue to dump it; If it returns false,
it means this ep is dead and can be freed after rcu_read_unlock, and
we should skip it.
In sctp_sock_dump(), after locking the sk, if this ep is different from
tsp->asoc->ep, it means during this dumping, this asoc was peeled off
before calling lock_sock(), and the sk should be skipped; If this ep is
the same with tsp->asoc->ep, it means no peeloff happens on this asoc,
and due to lock_sock, no peeloff will happen either until release_sock.
Note that delaying endpoint free won't delay the port release, as the
port release happens in sctp_endpoint_destroy() before calling call_rcu().
Also, freeing endpoint by call_rcu() makes it safe to access the sk by
asoc->base.sk in sctp_assocs_seq_show() and sctp_rcv().
Thanks Jones to bring this issue up.
v1->v2:
- improve the changelog.
- add kfree(ep) into sctp_endpoint_destroy_rcu(), as Jakub noticed.
Reported-by: syzbot+9276d76e83e3bcde6c99@syzkaller.appspotmail.com
Reported-by: Lee Jones <lee.jones@linaro.org>
Fixes: d25adbeb0cdb ("sctp: fix an use-after-free issue in sctp_sock_dump")
Signed-off-by: Xin Long <lucien.xin@gmail.com>
This patch is to fix a NULL-ptr deref in selinux_socket_connect_helper:
[...] kasan: GPF could be caused by NULL-ptr deref or user memory access
[...] RIP: 0010:selinux_socket_connect_helper+0x94/0x460
[...] Call Trace:
[...] selinux_sctp_bind_connect+0x16a/0x1d0
[...] security_sctp_bind_connect+0x58/0x90
[...] sctp_process_asconf+0xa52/0xfd0 [sctp]
[...] sctp_sf_do_asconf+0x785/0x980 [sctp]
[...] sctp_do_sm+0x175/0x5a0 [sctp]
[...] sctp_assoc_bh_rcv+0x285/0x5b0 [sctp]
[...] sctp_backlog_rcv+0x482/0x910 [sctp]
[...] __release_sock+0x11e/0x310
[...] release_sock+0x4f/0x180
[...] sctp_accept+0x3f9/0x5a0 [sctp]
[...] inet_accept+0xe7/0x720
It was caused by that the 'newsk' sk_socket was not set before going to
security sctp hook when processing asconf chunk with SCTP_PARAM_ADD_IP
or SCTP_PARAM_SET_PRIMARY:
inet_accept()->
sctp_accept():
lock_sock():
lock listening 'sk'
do_softirq():
sctp_rcv(): <-- [1]
asconf chunk arrives and
enqueued in 'sk' backlog
sctp_sock_migrate():
set asoc's sk to 'newsk'
release_sock():
sctp_backlog_rcv():
lock 'newsk'
sctp_process_asconf() <-- [2]
unlock 'newsk'
sock_graft():
set sk_socket <-- [3]
As it shows, at [1] the asconf chunk would be put into the listening 'sk'
backlog, as accept() was holding its sock lock. Then at [2] asconf would
get processed with 'newsk' as asoc's sk had been set to 'newsk'. However,
'newsk' sk_socket is not set until [3], while selinux_sctp_bind_connect()
would deref it, then kernel crashed.
Here to fix it by adding the chunk to sk_backlog until newsk sk_socket is
set when .accept() is done.
Note that sk->sk_socket can be NULL when the sock is closed, so SOCK_DEAD
flag is also needed to check in sctp_newsk_ready().
Thanks to Ondrej for reviewing the code.
Fixes: d452930fd3b9 ("selinux: Add SCTP support")
Reported-by: Ying Xu <yinxu@redhat.com>
Suggested-by: Marcelo Ricardo Leitner <marcelo.leitner@gmail.com>
Acked-by: Marcelo Ricardo Leitner <marcelo.leitner@gmail.com>
Signed-off-by: Jakub Kicinski <jakub.kicinski@netronome.com>
Based on 1 normalized pattern(s):
this sctp implementation is free software you can redistribute it
and or modify it under the terms of the gnu general public license
as published by the free software foundation either version 2 or at
your option any later version this sctp implementation is
distributed in the hope that it will be useful but without any
warranty without even the implied warranty of merchantability or
fitness for a particular purpose see the gnu general public license
for more details you should have received a copy of the gnu general
public license along with gnu cc see the file copying if not see
http www gnu org licenses
extracted by the scancode license scanner the SPDX license identifier
GPL-2.0-or-later
has been chosen to replace the boilerplate/reference in 42 file(s).
Reviewed-by: Richard Fontana <rfontana@redhat.com>
Reviewed-by: Allison Randal <allison@lohutok.net>
Cc: linux-spdx@vger.kernel.org
Link: https://lkml.kernel.org/r/20190523091649.683323110@linutronix.de
sk_forward_alloc's updating is also done on rx path, but to be consistent
we change to use sk_mem_charge() in sctp_skb_set_owner_r().
In sctp_eat_data(), it's not enough to check sctp_memory_pressure only,
which doesn't work for mem_cgroup_sockets_enabled, so we change to use
sk_under_memory_pressure().
When it's under memory pressure, sk_mem_reclaim() and sk_rmem_schedule()
should be called on both RENEGE or CHUNK DELIVERY path exit the memory
pressure status as soon as possible.
Note that sk_rmem_schedule() is using datalen to make things easy there.
Reported-by: Matteo Croce <mcroce@redhat.com>
Tested-by: Matteo Croce <mcroce@redhat.com>
Several conflicts, seemingly all over the place.
I used Stephen Rothwell's sample resolutions for many of these, if not
just to double check my own work, so definitely the credit largely
goes to him.
The NFP conflict consisted of a bug fix (moving operations
past the rhashtable operation) while chaning the initial
argument in the function call in the moved code.
The net/dsa/master.c conflict had to do with a bug fix intermixing of
making dsa_master_set_mtu() static with the fixing of the tagging
attribute location.
cls_flower had a conflict because the dup reject fix from Or
overlapped with the addition of port range classifiction.
__set_phy_supported()'s conflict was relatively easy to resolve
because Andrew fixed it in both trees, so it was just a matter
of taking the net-next copy. Or at least I think it was :-)
Joe Stringer's fix to the handling of netns id 0 in bpf_sk_lookup()
intermixed with changes on how the sdif and caller_net are calculated
in these code paths in net-next.
The remaining BPF conflicts were largely about the addition of the
__bpf_md_ptr stuff in 'net' overlapping with adjustments and additions
to the relevant data structure where the MD pointer macros are used.
If for some reason an association's fragmentation point is zero,
sctp_datamsg_from_user will try to endlessly try to divide a message
into zero-sized chunks. This eventually causes kernel panic due to
running out of memory.
Although this situation is quite unlikely, it has occurred before as
reported. I propose to add this simple last-ditch sanity check due to
the severity of the potential consequences.
Signed-off-by: Jakub Audykowicz <jakub.audykowicz@gmail.com>
This reverts commit 22d7be267eaa8114dcc28d66c1c347f667d7878a.
The dst's mtu in transport can be updated by a non sctp place like
in xfrm where the MTU information didn't get synced between asoc,
transport and dst, so it is still needed to do the pmtu check
in sctp_packet_config.
This is a part of sk_reuseport support for sctp. It defines a helper
sctp_bind_addrs_check() to check if the bind_addrs in two socks are
matched. It will add sock_reuseport if they are completely matched,
and return err if they are partly matched, and alloc sock_reuseport
if all socks are not matched at all.
It will work until sk_reuseport support is added in
sctp_get_port_local() in the next patch.
v1->v2:
- use 'laddr->valid && laddr2->valid' check instead as Marcelo
pointed in sctp_bind_addrs_check().
We'll need this to handle ICMP errors for tunnels without a sending socket
(i.e. FoU and GUE). There, we might have to look up different types of IP
tunnels, registered as network protocols, before we get a match, so we
want this for the error handlers of IPPROTO_IPIP and IPPROTO_IPV6 in both
inet_protos and inet6_protos. These error codes will be used in the next
patch.
For consistency, return sensible error codes in protocol error handlers
whenever handlers can't handle errors because, even if valid, they don't
match a protocol or any of its states.
This has no effect on existing error handling paths.
Signed-off-by: Stefano Brivio <sbrivio@redhat.com>
Reviewed-by: Sabrina Dubroca <sd@queasysnail.net>
The poll() changes were not well thought out, and completely
unexplained. They also caused a huge performance regression, because
"->poll()" was no longer a trivial file operation that just called down
to the underlying file operations, but instead did at least two indirect
calls.
Indirect calls are sadly slow now with the Spectre mitigation, but the
performance problem could at least be largely mitigated by changing the
"->get_poll_head()" operation to just have a per-file-descriptor pointer
to the poll head instead. That gets rid of one of the new indirections.
But that doesn't fix the new complexity that is completely unwarranted
for the regular case. The (undocumented) reason for the poll() changes
was some alleged AIO poll race fixing, but we don't make the common case
slower and more complex for some uncommon special case, so this all
really needs way more explanations and most likely a fundamental
redesign.
[ This revert is a revert of about 30 different commits, not reverted
individually because that would just be unnecessarily messy - Linus ]
Pull networking updates from David Miller:
1) Add Maglev hashing scheduler to IPVS, from Inju Song.
2) Lots of new TC subsystem tests from Roman Mashak.
3) Add TCP zero copy receive and fix delayed acks and autotuning with
SO_RCVLOWAT, from Eric Dumazet.
4) Add XDP_REDIRECT support to mlx5 driver, from Jesper Dangaard
Brouer.
5) Add ttl inherit support to vxlan, from Hangbin Liu.
6) Properly separate ipv6 routes into their logically independant
components. fib6_info for the routing table, and fib6_nh for sets of
nexthops, which thus can be shared. From David Ahern.
7) Add bpf_xdp_adjust_tail helper, which can be used to generate ICMP
messages from XDP programs. From Nikita V. Shirokov.
8) Lots of long overdue cleanups to the r8169 driver, from Heiner
Kallweit.
9) Add BTF ("BPF Type Format"), from Martin KaFai Lau.
10) Add traffic condition monitoring to iwlwifi, from Luca Coelho.
11) Plumb extack down into fib_rules, from Roopa Prabhu.
12) Add Flower classifier offload support to igb, from Vinicius Costa
Gomes.
13) Add UDP GSO support, from Willem de Bruijn.
14) Add documentation for eBPF helpers, from Quentin Monnet.
15) Add TLS tx offload to mlx5, from Ilya Lesokhin.
16) Allow applications to be given the number of bytes available to read
on a socket via a control message returned from recvmsg(), from
Soheil Hassas Yeganeh.
17) Add x86_32 eBPF JIT compiler, from Wang YanQing.
18) Add AF_XDP sockets, with zerocopy support infrastructure as well.
From Björn Töpel.
19) Remove indirect load support from all of the BPF JITs and handle
these operations in the verifier by translating them into native BPF
instead. From Daniel Borkmann.
20) Add GRO support to ipv6 gre tunnels, from Eran Ben Elisha.
21) Allow XDP programs to do lookups in the main kernel routing tables
for forwarding. From David Ahern.
22) Allow drivers to store hardware state into an ELF section of kernel
dump vmcore files, and use it in cxgb4. From Rahul Lakkireddy.
23) Various RACK and loss detection improvements in TCP, from Yuchung
Cheng.
24) Add TCP SACK compression, from Eric Dumazet.
25) Add User Mode Helper support and basic bpfilter infrastructure, from
Alexei Starovoitov.
26) Support ports and protocol values in RTM_GETROUTE, from Roopa
Prabhu.
27) Support bulking in ->ndo_xdp_xmit() API, from Jesper Dangaard
Brouer.
28) Add lots of forwarding selftests, from Petr Machata.
29) Add generic network device failover driver, from Sridhar Samudrala.
* ra.kernel.org:/pub/scm/linux/kernel/git/davem/net-next: (1959 commits)
strparser: Add __strp_unpause and use it in ktls.
rxrpc: Fix terminal retransmission connection ID to include the channel
net: hns3: Optimize PF CMDQ interrupt switching process
net: hns3: Fix for VF mailbox receiving unknown message
net: hns3: Fix for VF mailbox cannot receiving PF response
bnx2x: use the right constant
Revert "net: sched: cls: Fix offloading when ingress dev is vxlan"
net: dsa: b53: Fix for brcm tag issue in Cygnus SoC
enic: fix UDP rss bits
netdev-FAQ: clarify DaveM's position for stable backports
rtnetlink: validate attributes in do_setlink()
mlxsw: Add extack messages for port_{un, }split failures
netdevsim: Add extack error message for devlink reload
devlink: Add extack to reload and port_{un, }split operations
net: metrics: add proper netlink validation
ipmr: fix error path when ipmr_new_table fails
ip6mr: only set ip6mr_table from setsockopt when ip6mr_new_table succeeds
net: hns3: remove unused hclgevf_cfg_func_mta_filter
netfilter: provide udp*_lib_lookup for nf_tproxy
qed*: Utilize FW 8.37.2.0
Pull aio updates from Al Viro:
"Majority of AIO stuff this cycle. aio-fsync and aio-poll, mostly.
The only thing I'm holding back for a day or so is Adam's aio ioprio -
his last-minute fixup is trivial (missing stub in !CONFIG_BLOCK case),
but let it sit in -next for decency sake..."
* 'work.aio-1' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (46 commits)
aio: sanitize the limit checking in io_submit(2)
aio: fold do_io_submit() into callers
aio: shift copyin of iocb into io_submit_one()
aio_read_events_ring(): make a bit more readable
aio: all callers of aio_{read,write,fsync,poll} treat 0 and -EIOCBQUEUED the same way
aio: take list removal to (some) callers of aio_complete()
aio: add missing break for the IOCB_CMD_FDSYNC case
random: convert to ->poll_mask
timerfd: convert to ->poll_mask
eventfd: switch to ->poll_mask
pipe: convert to ->poll_mask
crypto: af_alg: convert to ->poll_mask
net/rxrpc: convert to ->poll_mask
net/iucv: convert to ->poll_mask
net/phonet: convert to ->poll_mask
net/nfc: convert to ->poll_mask
net/caif: convert to ->poll_mask
net/bluetooth: convert to ->poll_mask
net/sctp: convert to ->poll_mask
net/tipc: convert to ->poll_mask
Lots of easy overlapping changes in the confict
resolutions here.
Now sctp uses inet_dgram_connect as its proto_ops .connect, and the flags
param can't be passed into its proto .connect where this flags is really
needed.
sctp works around it by getting flags from socket file in __sctp_connect.
It works for connecting from userspace, as inherently the user sock has
socket file and it passes f_flags as the flags param into the proto_ops
.connect.
However, the sock created by sock_create_kern doesn't have a socket file,
and it passes the flags (like O_NONBLOCK) by using the flags param in
kernel_connect, which calls proto_ops .connect later.
So to fix it, this patch defines a new proto_ops .connect for sctp,
sctp_inet_connect, which calls __sctp_connect() directly with this
flags param. After this, the sctp's proto .connect can be removed.
Note that sctp_inet_connect doesn't need to do some checks that are not
needed for sctp, which makes thing better than with inet_dgram_connect.
Reviewed-by: Michal Kubecek <mkubecek@suse.cz>
We are now keeping the MTU information synced between asoc, transport
and dst, which makes the check at sctp_packet_config() not needed
anymore. As it was the sole caller to this function, lets remove it.
Signed-off-by: Marcelo Ricardo Leitner <marcelo.leitner@gmail.com>
Which makes sure that the MTU respects the minimum value of
SCTP_DEFAULT_MINSEGMENT and that it is correctly aligned.
No need for this helper.
and avoid the open-coded versions of it.
Now sctp_datamsg_from_user can just re-use asoc->frag_point as it will
always be updated.
When given a MTU, this function calculates how much payload we can carry
on it. Without a MTU, it calculates the amount of header overhead we
have.
So that when we have extra overhead, like the one added for IP options
on SELinux patches, it is easier to handle it.
git://git.kernel.org/pub/scm/linux/kernel/git/pcmoore/selinux
Pull SELinux updates from Paul Moore:
"A bigger than usual pull request for SELinux, 13 patches (lucky!)
along with a scary looking diffstat.
Although if you look a bit closer, excluding the usual minor
tweaks/fixes, there are really only two significant changes in this
pull request: the addition of proper SELinux access controls for SCTP
and the encapsulation of a lot of internal SELinux state.
The SCTP changes are the result of a multi-month effort (maybe even a
year or longer?) between the SELinux folks and the SCTP folks to add
proper SELinux controls. A special thanks go to Richard for seeing
this through and keeping the effort moving forward.
The state encapsulation work is a bit of janitorial work that came out
of some early work on SELinux namespacing. The question of namespacing
is still an open one, but I believe there is some real value in the
encapsulation work so we've split that out and are now sending that up
to you"
* tag 'selinux-pr-20180403' of git://git.kernel.org/pub/scm/linux/kernel/git/pcmoore/selinux:
selinux: wrap AVC state
selinux: wrap selinuxfs state
selinux: fix handling of uninitialized selinux state in get_bools/classes
selinux: Update SELinux SCTP documentation
selinux: Fix ltp test connect-syscall failure
selinux: rename the {is,set}_enforcing() functions
selinux: wrap global selinux state
selinux: fix typo in selinux_netlbl_sctp_sk_clone declaration
sctp: Add LSM hooks
sctp: Add ip option support
security: Add support for SCTP security hooks
netlabel: If PF_INET6, check sk_buff ip header version
use proc_remove_subtree() for subtree removal, both on setup failure
halfway through and on teardown. No need to make simple things
complex...
Add ip option support to allow LSM security modules to utilise CIPSO/IPv4
and CALIPSO/IPv6 services.
Signed-off-by: Richard Haines <richard_c_haines@btinternet.com>
Signed-off-by: Paul Moore <paul@paul-moore.com>
1) Significantly shrink the core networking routing structures. Result
of http://vger.kernel.org/~davem/seoul2017_netdev_keynote.pdf
2) Add netdevsim driver for testing various offloads, from Jakub
Kicinski.
3) Support cross-chip FDB operations in DSA, from Vivien Didelot.
4) Add a 2nd listener hash table for TCP, similar to what was done for
UDP. From Martin KaFai Lau.
5) Add eBPF based queue selection to tun, from Jason Wang.
6) Lockless qdisc support, from John Fastabend.
7) SCTP stream interleave support, from Xin Long.
8) Smoother TCP receive autotuning, from Eric Dumazet.
9) Lots of erspan tunneling enhancements, from William Tu.
10) Add true function call support to BPF, from Alexei Starovoitov.
11) Add explicit support for GRO HW offloading, from Michael Chan.
12) Support extack generation in more netlink subsystems. From Alexander
Aring, Quentin Monnet, and Jakub Kicinski.
13) Add 1000BaseX, flow control, and EEE support to mvneta driver. From
Russell King.
14) Add flow table abstraction to netfilter, from Pablo Neira Ayuso.
15) Many improvements and simplifications to the NFP driver bpf JIT,
from Jakub Kicinski.
16) Support for ipv6 non-equal cost multipath routing, from Ido
Schimmel.
17) Add resource abstration to devlink, from Arkadi Sharshevsky.
18) Packet scheduler classifier shared filter block support, from Jiri
Pirko.
19) Avoid locking in act_csum, from Davide Caratti.
20) devinet_ioctl() simplifications from Al viro.
21) More TCP bpf improvements from Lawrence Brakmo.
22) Add support for onlink ipv6 route flag, similar to ipv4, from David
Ahern.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1925 commits)
tls: Add support for encryption using async offload accelerator
ip6mr: fix stale iterator
net/sched: kconfig: Remove blank help texts
openvswitch: meter: Use 64-bit arithmetic instead of 32-bit
tcp_nv: fix potential integer overflow in tcpnv_acked
r8169: fix RTL8168EP take too long to complete driver initialization.
qmi_wwan: Add support for Quectel EP06
rtnetlink: enable IFLA_IF_NETNSID for RTM_NEWLINK
ipmr: Fix ptrdiff_t print formatting
ibmvnic: Wait for device response when changing MAC
qlcnic: fix deadlock bug
tcp: release sk_frag.page in tcp_disconnect
ipv4: Get the address of interface correctly.
net_sched: gen_estimator: fix lockdep splat
net: macb: Handle HRESP error
net/mlx5e: IPoIB, Fix copy-paste bug in flow steering refactoring
ipv6: addrconf: break critical section in addrconf_verify_rtnl()
ipv6: change route cache aging logic
i40e/i40evf: Update DESC_NEEDED value to reflect larger value
bnxt_en: cleanup DIM work on device shutdown
Pull poll annotations from Al Viro:
"This introduces a __bitwise type for POLL### bitmap, and propagates
the annotations through the tree. Most of that stuff is as simple as
'make ->poll() instances return __poll_t and do the same to local
variables used to hold the future return value'.
Some of the obvious brainos found in process are fixed (e.g. POLLIN
misspelled as POLL_IN). At that point the amount of sparse warnings is
low and most of them are for genuine bugs - e.g. ->poll() instance
deciding to return -EINVAL instead of a bitmap. I hadn't touched those
in this series - it's large enough as it is.
Another problem it has caught was eventpoll() ABI mess; select.c and
eventpoll.c assumed that corresponding POLL### and EPOLL### were
equal. That's true for some, but not all of them - EPOLL### are
arch-independent, but POLL### are not.
The last commit in this series separates userland POLL### values from
the (now arch-independent) kernel-side ones, converting between them
in the few places where they are copied to/from userland. AFAICS, this
is the least disruptive fix preserving poll(2) ABI and making epoll()
work on all architectures.
As it is, it's simply broken on sparc - try to give it EPOLLWRNORM and
it will trigger only on what would've triggered EPOLLWRBAND on other
architectures. EPOLLWRBAND and EPOLLRDHUP, OTOH, are never triggered
at all on sparc. With this patch they should work consistently on all
architectures"
* 'misc.poll' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (37 commits)
make kernel-side POLL... arch-independent
eventpoll: no need to mask the result of epi_item_poll() again
eventpoll: constify struct epoll_event pointers
debugging printk in sg_poll() uses %x to print POLL... bitmap
annotate poll(2) guts
9p: untangle ->poll() mess
->si_band gets POLL... bitmap stored into a user-visible long field
ring_buffer_poll_wait() return value used as return value of ->poll()
the rest of drivers/*: annotate ->poll() instances
media: annotate ->poll() instances
fs: annotate ->poll() instances
ipc, kernel, mm: annotate ->poll() instances
net: annotate ->poll() instances
apparmor: annotate ->poll() instances
tomoyo: annotate ->poll() instances
sound: annotate ->poll() instances
acpi: annotate ->poll() instances
crypto: annotate ->poll() instances
block: annotate ->poll() instances
x86: annotate ->poll() instances
assign_number is added as a member of sctp_stream_interleave, used
to assign ssn for data or mid (message id) for idata, called in
sctp_packet_append_data. sctp_chunk_assign_ssn is left as it is,
and sctp_chunk_assign_mid is added for sctp_stream_interleave_1.
This procedure is described in section 2.2.2 of RFC8260.
All sizeof(struct sctp_data_chunk) in tx path is replaced with
sctp_datachk_len, to make it right for idata as well. And also
adjust sctp_chunk_is_data for SCTP_CID_I_DATA.
After this patch, idata can be built and sent in tx path.
Note that if sp strm_interleave is set, it has to wait_connect in
sctp_sendmsg, as asoc intl_enable need to be known after 4 shake-
hands, to decide if it should use data or idata later. data and
idata can't be mixed to send in one asoc.
Most callers of rhashtable_walk_start don't care about a resize event
which is indicated by a return value of -EAGAIN. So calls to
rhashtable_walk_start are wrapped wih code to ignore -EAGAIN. Something
like this is common:
ret = rhashtable_walk_start(rhiter);
if (ret && ret != -EAGAIN)
goto out;
Since zero and -EAGAIN are the only possible return values from the
function this check is pointless. The condition never evaluates to true.
This patch changes rhashtable_walk_start to return void. This simplifies
code for the callers that ignore -EAGAIN. For the few cases where the
caller cares about the resize event, particularly where the table can be
walked in mulitple parts for netlink or seq file dump, the function
rhashtable_walk_start_check has been added that returns -EAGAIN on a
resize event.
Signed-off-by: Tom Herbert <tom@quantonium.net>
Acked-by: Herbert Xu <herbert@gondor.apana.org.au>
Now each stream sched ops is defined in different .c file and
added into the global ops in another .c file, it uses extern
to make this work.
However extern is not good coding style to get them in and
even make C=2 reports errors for this.
This patch adds sctp_sched_ops_xxx_init for each stream sched
ops in their .c file, then get them into the global ops by
calling them when initializing sctp module.
Fixes: 637784ade221 ("sctp: introduce priority based stream scheduler")
Fixes: ac1ed8b82cd6 ("sctp: introduce round robin stream scheduler")
Now in sctp_setsockopt_maxseg user_frag or frag_point can be set with
val >= 8 and val <= SCTP_MAX_CHUNK_LEN. But both checks are incorrect.
val >= 8 means frag_point can even be less than SCTP_DEFAULT_MINSEGMENT.
Then in sctp_datamsg_from_user(), when it's value is greater than cookie
echo len and trying to bundle with cookie echo chunk, the first_len will
overflow.
The worse case is when it's value is equal as cookie echo len, first_len
becomes 0, it will go into a dead loop for fragment later on. In Hangbin
syzkaller testing env, oom was even triggered due to consecutive memory
allocation in that loop.
Besides, SCTP_MAX_CHUNK_LEN is the max size of the whole chunk, it should
deduct the data header for frag_point or user_frag check.
This patch does a proper check with SCTP_DEFAULT_MINSEGMENT subtracting
the sctphdr and datahdr, SCTP_MAX_CHUNK_LEN subtracting datahdr when
setting frag_point via sockopt. It also improves sctp_setsockopt_maxseg
codes.
Reported-by: Hangbin Liu <liuhangbin@gmail.com>
Commit 86fdb3448cc1 ("sctp: ensure ep is not destroyed before doing the
dump") tried to fix an use-after-free issue by checking !sctp_sk(sk)->ep
with holding sock and sock lock.
But Paolo noticed that endpoint could be destroyed in sctp_rcv without
sock lock protection. It means the use-after-free issue still could be
triggered when sctp_rcv put and destroy ep after sctp_sock_dump checks
!ep, although it's pretty hard to reproduce.
I could reproduce it by mdelay in sctp_rcv while msleep in sctp_close
and sctp_sock_dump long time.
This patch is to add another param cb_done to sctp_for_each_transport
and dump ep->assocs with holding tsp after jumping out of transport's
traversal in it to avoid this issue.
It can also improve sctp diag dump to make it run faster, as no need
to save sk into cb->args[5] and keep calling sctp_for_each_transport
any more.
This patch is also to use int * instead of int for the pos argument
in sctp_for_each_transport, which could make postion increment only
in sctp_for_each_transport and no need to keep changing cb->args[2]
in sctp_sock_filter and sctp_sock_dump any more.
Fixes: 86fdb3448cc1 ("sctp: ensure ep is not destroyed before doing the dump")
Reported-by: Paolo Abeni <pabeni@redhat.com>
This patch is to remove the typedef sctp_socket_type_t, and
replace with enum sctp_socket_type in the places where it's
using this typedef.
This patch is to remove the typedef sctp_state_t, and
replace with enum sctp_state in the places where it's
using this typedef.
This patch is to remove the typedef sctp_sock_state_t, and
replace with enum sctp_sock_state in the places where it's
using this typedef.
This patch is to remove the typedef sctp_scope_t, and
replace with enum sctp_scope in the places where it's
using this typedef.
This patch is to remove the typedef sctp_errhdr_t, and replace
with struct sctp_errhdr in the places where it's using this
typedef.
It is also to use sizeof(variable) instead of sizeof(type).
Commit b1f5bfc27a19 ("sctp: don't dereference ptr before leaving
_sctp_walk_{params, errors}()") tried to fix the issue that it
may overstep the chunk end for _sctp_walk_{params, errors} with
'chunk_end > offset(length) + sizeof(length)'.
But it introduced a side effect: When processing INIT, it verifies
the chunks with 'param.v == chunk_end' after iterating all params
by sctp_walk_params(). With the check 'chunk_end > offset(length)
+ sizeof(length)', it would return when the last param is not yet
accessed. Because the last param usually is fwdtsn supported param
whose size is 4 and 'chunk_end == offset(length) + sizeof(length)'
This is a badly issue even causing sctp couldn't process 4-shakes.
Client would always get abort when connecting to server, due to
the failure of INIT chunk verification on server.
The patch is to use 'chunk_end <= offset(length) + sizeof(length)'
instead of 'chunk_end < offset(length) + sizeof(length)' for both
_sctp_walk_params and _sctp_walk_errors.
Fixes: b1f5bfc27a19 ("sctp: don't dereference ptr before leaving _sctp_walk_{params, errors}()")
If the length field of the iterator (|pos.p| or |err|) is past the end
of the chunk, we shouldn't access it.
This bug has been detected by KMSAN. For the following pair of system
calls:
socket(PF_INET6, SOCK_STREAM, 0x84 /* IPPROTO_??? */) = 3
sendto(3, "A", 1, MSG_OOB, {sa_family=AF_INET6, sin6_port=htons(0),
inet_pton(AF_INET6, "::1", &sin6_addr), sin6_flowinfo=0,
sin6_scope_id=0}, 28) = 1
the tool has reported a use of uninitialized memory:
BUG: KMSAN: use of uninitialized memory in sctp_rcv+0x17b8/0x43b0
CPU: 1 PID: 2940 Comm: probe Not tainted 4.11.0-rc5+ #2926
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs
01/01/2011
Call Trace:
<IRQ>
__dump_stack lib/dump_stack.c:16
dump_stack+0x172/0x1c0 lib/dump_stack.c:52
kmsan_report+0x12a/0x180 mm/kmsan/kmsan.c:927
__msan_warning_32+0x61/0xb0 mm/kmsan/kmsan_instr.c:469
__sctp_rcv_init_lookup net/sctp/input.c:1074
__sctp_rcv_lookup_harder net/sctp/input.c:1233
__sctp_rcv_lookup net/sctp/input.c:1255
sctp_rcv+0x17b8/0x43b0 net/sctp/input.c:170
sctp6_rcv+0x32/0x70 net/sctp/ipv6.c:984
ip6_input_finish+0x82f/0x1ee0 net/ipv6/ip6_input.c:279
NF_HOOK ./include/linux/netfilter.h:257
ip6_input+0x239/0x290 net/ipv6/ip6_input.c:322
dst_input ./include/net/dst.h:492
ip6_rcv_finish net/ipv6/ip6_input.c:69
ipv6_rcv+0x1dbd/0x22e0 net/ipv6/ip6_input.c:203
__netif_receive_skb_core+0x2f6f/0x3a20 net/core/dev.c:4208
__netif_receive_skb net/core/dev.c:4246
process_backlog+0x667/0xba0 net/core/dev.c:4866
napi_poll net/core/dev.c:5268
net_rx_action+0xc95/0x1590 net/core/dev.c:5333
__do_softirq+0x485/0x942 kernel/softirq.c:284
do_softirq_own_stack+0x1c/0x30 arch/x86/entry/entry_64.S:902
</IRQ>
do_softirq kernel/softirq.c:328
__local_bh_enable_ip+0x25b/0x290 kernel/softirq.c:181
local_bh_enable+0x37/0x40 ./include/linux/bottom_half.h:31
rcu_read_unlock_bh ./include/linux/rcupdate.h:931
ip6_finish_output2+0x19b2/0x1cf0 net/ipv6/ip6_output.c:124
ip6_finish_output+0x764/0x970 net/ipv6/ip6_output.c:149
NF_HOOK_COND ./include/linux/netfilter.h:246
ip6_output+0x456/0x520 net/ipv6/ip6_output.c:163
dst_output ./include/net/dst.h:486
ip6_xmit+0x1841/0x1c00 net/ipv6/ip6_output.c:261
sctp_v6_xmit+0x3b7/0x470 net/sctp/ipv6.c:225
sctp_packet_transmit+0x38cb/0x3a20 net/sctp/output.c:632
sctp_outq_flush+0xeb3/0x46e0 net/sctp/outqueue.c:885
sctp_outq_uncork+0xb2/0xd0 net/sctp/outqueue.c:750
sctp_side_effects net/sctp/sm_sideeffect.c:1773
sctp_do_sm+0x6962/0x6ec0 net/sctp/sm_sideeffect.c:1147
sctp_primitive_ASSOCIATE+0x12c/0x160 net/sctp/primitive.c:88
sctp_sendmsg+0x43e5/0x4f90 net/sctp/socket.c:1954
inet_sendmsg+0x498/0x670 net/ipv4/af_inet.c:762
sock_sendmsg_nosec net/socket.c:633
sock_sendmsg net/socket.c:643
SYSC_sendto+0x608/0x710 net/socket.c:1696
SyS_sendto+0x8a/0xb0 net/socket.c:1664
do_syscall_64+0xe6/0x130 arch/x86/entry/common.c:285
entry_SYSCALL64_slow_path+0x25/0x25 arch/x86/entry/entry_64.S:246
RIP: 0033:0x401133
RSP: 002b:00007fff6d99cd38 EFLAGS: 00000246 ORIG_RAX: 000000000000002c
RAX: ffffffffffffffda RBX: 00000000004002b0 RCX: 0000000000401133
RDX: 0000000000000001 RSI: 0000000000494088 RDI: 0000000000000003
RBP: 00007fff6d99cd90 R08: 00007fff6d99cd50 R09: 000000000000001c
R10: 0000000000000001 R11: 0000000000000246 R12: 0000000000000000
R13: 00000000004063d0 R14: 0000000000406460 R15: 0000000000000000
origin:
save_stack_trace+0x37/0x40 arch/x86/kernel/stacktrace.c:59
kmsan_save_stack_with_flags mm/kmsan/kmsan.c:302
kmsan_internal_poison_shadow+0xb1/0x1a0 mm/kmsan/kmsan.c:198
kmsan_poison_shadow+0x6d/0xc0 mm/kmsan/kmsan.c:211
slab_alloc_node mm/slub.c:2743
__kmalloc_node_track_caller+0x200/0x360 mm/slub.c:4351
__kmalloc_reserve net/core/skbuff.c:138
__alloc_skb+0x26b/0x840 net/core/skbuff.c:231
alloc_skb ./include/linux/skbuff.h:933
sctp_packet_transmit+0x31e/0x3a20 net/sctp/output.c:570
return_from_SYSCALL_64+0x0/0x6a arch/x86/entry/entry_64.S:246
Signed-off-by: Alexander Potapenko <glider@google.com>
This patch is to remove the typedef sctp_paramhdr_t, and replace
with struct sctp_paramhdr in the places where it's using this
typedef.
It is also to fix some indents and use sizeof(variable) instead
of sizeof(type).
This patch is to remove the typedef sctp_chunkhdr_t, and replace
with struct sctp_chunkhdr in the places where it's using this
typedef.
of sizeof(type)., especially in sctp_new.
This patch is almost to revert commit 02f3d4ce9e81 ("sctp: Adjust PMTU
updates to accomodate route invalidation."). As t->asoc can't be NULL
in sctp_transport_update_pmtu, it could get sk from asoc, and no need
to pass sk into that function.
It is also to remove some duplicated codes from that function.
This patch is to move sctp_transport_dst_check into sctp_packet_config
from sctp_packet_transmit and add pathmtu check in sctp_packet_config.
With this fix, sctp can update dst or pathmtu before appending chunks,
which can void dropping packets in sctp_packet_transmit when dst is
obsolete or dst's mtu is changed.
This patch is also to improve some other codes in sctp_packet_config.
It updates packet max_size with gso_max_size, checks for dst and
pathmtu, and appends ecne chunk only when packet is empty and asoc
is not NULL.
It makes sctp flush work better, as we only need to set up them once
for one flush schedule. It's also safe, since asoc is NULL only when
the packet is created by sctp_ootb_pkt_new in which it just gets the
new dst, no need to do more things for it other than set packet with
transport's pathmtu.
Now when sending a packet, sctp_transport_dst_check will check if dst
is obsolete by calling ipv4/ip6_dst_check. But they return obsolete
only when adding a new cache, after that when the cache's pmtu is
updated again, it will not trigger transport->dst/pmtu's update.
It can be reproduced by reducing route's pmtu twice. At the 1st time
client will add a new cache, and transport->pathmtu gets updated as
sctp_transport_dst_check finds it's obsolete. But at the 2nd time,
cache's mtu is updated, sctp client will never send out any packet,
because transport->pmtu has no chance to update.
This patch is to fix this by also checking if transport pmtu is dst
mtu in sctp_transport_dst_check, so that transport->pmtu can be
updated on time.
Request Parameter
This patch is to implement Sender-Side Procedures for the Add
Outgoing and Incoming Streams Request Parameter described in
rfc6525 section 5.1.5-5.1.6.
It is also to add sockopt SCTP_ADD_STREAMS in rfc6525 section
6.3.4 for users.
This patch is to implement Sender-Side Procedures for the SSN/TSN
Reset Request Parameter descibed in rfc6525 section 5.1.4.
It is also to add sockopt SCTP_RESET_ASSOC in rfc6525 section 6.3.3
for users.
Add new transport flag to allow sockets to confirm neighbour.
When same struct dst_entry can be used for many different
neighbours we can not use it for pending confirmations.
The flag is propagated from transport to every packet.
It is reset when cached dst is reset.
Reported-by: YueHaibing <yuehaibing@huawei.com>
Fixes: 5110effee8fd ("net: Do delayed neigh confirmation.")
Fixes: f2bb4bedf35d ("ipv4: Cache output routes in fib_info nexthops.")
Signed-off-by: Julian Anastasov <ja@ssi.bg>
This patch is to implement sender-side procedures for the Outgoing
and Incoming SSN Reset Request Parameter described in rfc6525 section
5.1.2 and 5.1.3.
It is also add sockopt SCTP_RESET_STREAMS in rfc6525 section 6.3.2
for users.
Note that the new asoc member strreset_outstanding is to make sure
only one reconf request chunk on the fly as rfc6525 section 5.1.1
demands.
This patch is to add a primitive based on sctp primitive frame for
sending stream reconf request. It works as the other primitives,
and create a SCTP_CMD_REPLY command to send the request chunk out.
sctp_primitive_RECONF would be the api to send a reconf request
chunk.
sctp stream reconf, described in RFC 6525, needs a structure to
save per stream information in assoc, like stream state.
In the future, sctp stream scheduler also needs it to save some
stream scheduler params and queues.
This patchset is to prepare the stream array in assoc for stream
reconf. It defines sctp_stream that includes stream arrays inside
to replace ssnmap.
Note that we use different structures for IN and OUT streams, as
the members in per OUT stream will get more and more different
from per IN stream.
v1->v2:
- put these patches into a smaller group.
v2->v3:
- define sctp_stream to contain stream arrays, and create stream.c
to put stream-related functions.
- merge 3 patches into 1, as new sctp_stream has the same name
with before.
Reviewed-by: Marcelo Ricardo Leitner <marcelo.leitner@gmail.com>
