path: root/include/net/snmp.h
2014-10-15Merge branch 'for-3.18-consistent-ops' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu Pull percpu consistent-ops changes from Tejun Heo: "Way back, before the current percpu allocator was implemented, static and dynamic percpu memory areas were allocated and handled separately and had their own accessors. The distinction has been gone for many years now; however, the now duplicate two sets of accessors remained with the pointer based ones - this_cpu_*() - evolving various other operations over time. During the process, we also accumulated other inconsistent operations. This pull request contains Christoph's patches to clean up the duplicate accessor situation. __get_cpu_var() uses are replaced with with this_cpu_ptr() and __this_cpu_ptr() with raw_cpu_ptr(). Unfortunately, the former sometimes is tricky thanks to C being a bit messy with the distinction between lvalues and pointers, which led to a rather ugly solution for cpumask_var_t involving the introduction of this_cpu_cpumask_var_ptr(). This converts most of the uses but not all. Christoph will follow up with the remaining conversions in this merge window and hopefully remove the obsolete accessors" * 'for-3.18-consistent-ops' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: (38 commits) irqchip: Properly fetch the per cpu offset percpu: Resolve ambiguities in __get_cpu_var/cpumask_var_t -fix ia64: sn_nodepda cannot be assigned to after this_cpu conversion. Use __this_cpu_write. percpu: Resolve ambiguities in __get_cpu_var/cpumask_var_t Revert "powerpc: Replace __get_cpu_var uses" percpu: Remove __this_cpu_ptr clocksource: Replace __this_cpu_ptr with raw_cpu_ptr sparc: Replace __get_cpu_var uses avr32: Replace __get_cpu_var with __this_cpu_write blackfin: Replace __get_cpu_var uses tile: Use this_cpu_ptr() for hardware counters tile: Replace __get_cpu_var uses powerpc: Replace __get_cpu_var uses alpha: Replace __get_cpu_var ia64: Replace __get_cpu_var uses s390: cio driver &__get_cpu_var replacements s390: Replace __get_cpu_var uses mips: Replace __get_cpu_var uses MIPS: Replace __get_cpu_var uses in FPU emulator. arm: Replace __this_cpu_ptr with raw_cpu_ptr ...
2014-09-19net: fix sparse warnings in SNMP_UPD_PO_STATS(_BH)Sabrina Dubroca
ptr used to be a non __percpu pointer (result of a this_cpu_ptr assignment, 7d720c3e4f0c4 ("percpu: add __percpu sparse annotations to net")). Since d25398df59b56 ("net: avoid reloads in SNMP_UPD_PO_STATS"), that's no longer the case, SNMP_UPD_PO_STATS uses this_cpu_add and ptr is now __percpu. Silence sparse warnings by preserving the original type and annotation, and remove the out-of-date comment. warning: incorrect type in initializer (different address spaces) expected unsigned long long *ptr got unsigned long long [noderef] <asn:3>*<noident> warning: incorrect type in initializer (different address spaces) expected void const [noderef] <asn:3>*__vpp_verify got unsigned long long *<noident> warning: incorrect type in initializer (different address spaces) expected void const [noderef] <asn:3>*__vpp_verify got unsigned long long *<noident> Signed-off-by: Sabrina Dubroca <sd@queasysnail.net> Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2014-08-26net: Replace get_cpu_var through this_cpu_ptrChristoph Lameter
Replace uses of get_cpu_var for address calculation through this_cpu_ptr. Cc: netdev@vger.kernel.org Cc: Eric Dumazet <edumazet@google.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Christoph Lameter <cl@linux.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2014-05-07net: clean up snmp stats codeWANG Cong
commit 8f0ea0fe3a036a47767f9c80e (snmp: reduce percpu needs by 50%) reduced snmp array size to 1, so technically it doesn't have to be an array any more. What's more, after the following commit: commit 933393f58fef9963eac61db8093689544e29a600 Date: Thu Dec 22 11:58:51 2011 -0600 percpu: Remove irqsafe_cpu_xxx variants We simply say that regular this_cpu use must be safe regardless of preemption and interrupt state. That has no material change for x86 and s390 implementations of this_cpu operations. However, arches that do not provide their own implementation for this_cpu operations will now get code generated that disables interrupts instead of preemption. probably no arch wants to have SNMP_ARRAY_SZ == 2. At least after almost 3 years, no one complains. So, just convert the array to a single pointer and remove snmp_mib_init() and snmp_mib_free() as well. Cc: Christoph Lameter <cl@linux.com> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Cong Wang <xiyou.wangcong@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-08-06net: avoid reloads in SNMP_UPD_PO_STATSEric Dumazet
Avoid two instructions to reload dev->nd_net->mib.ip_statistics pointer, unsing a temp variable, in ip_rcv(), ip_output() paths for example. Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-01-09Merge branch 'for-3.3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu * 'for-3.3' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: percpu: Remove irqsafe_cpu_xxx variants Fix up conflict in arch/x86/include/asm/percpu.h due to clash with cebef5beed3d ("x86: Fix and improve percpu_cmpxchg{8,16}b_double()") which edited the (now removed) irqsafe_cpu_cmpxchg*_double code.
2011-12-22percpu: Remove irqsafe_cpu_xxx variantsChristoph Lameter
We simply say that regular this_cpu use must be safe regardless of preemption and interrupt state. That has no material change for x86 and s390 implementations of this_cpu operations. However, arches that do not provide their own implementation for this_cpu operations will now get code generated that disables interrupts instead of preemption. -tj: This is part of on-going percpu API cleanup. For detailed discussion of the subject, please refer to the following thread. http://thread.gmane.org/gmane.linux.kernel/1222078 Signed-off-by: Christoph Lameter <cl@linux.com> Signed-off-by: Tejun Heo <tj@kernel.org> LKML-Reference: <alpine.DEB.2.00.1112221154380.11787@router.home>
2011-11-14ipv6: reduce percpu needs for icmpv6msg mibsEric Dumazet
Reading /proc/net/snmp6 on a machine with a lot of cpus is very expensive (can be ~88000 us). This is because ICMPV6MSG MIB uses 4096 bytes per cpu, and folding values for all possible cpus can read 16 Mbytes of memory (32MBytes on non x86 arches) ICMP messages are not considered as fast path on a typical server, and eventually few cpus handle them anyway. We can afford an atomic operation instead of using percpu data. This saves 4096 bytes per cpu and per network namespace. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-11-09ipv4: reduce percpu needs for icmpmsg mibsEric Dumazet
Reading /proc/net/snmp on a machine with a lot of cpus is very expensive (can be ~88000 us). This is because ICMPMSG MIB uses 4096 bytes per cpu, and folding values for all possible cpus can read 16 Mbytes of memory. ICMP messages are not considered as fast path on a typical server, and eventually few cpus handle them anyway. We can afford an atomic operation instead of using percpu data. This saves 4096 bytes per cpu and per network namespace. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-06-11snmp: reduce percpu needs by 50%Eric Dumazet
SNMP mibs use two percpu arrays, one used in BH context, another in USER context. With increasing number of cpus in machines, and fact that ipv6 uses per network device ipstats_mib, this is consuming a lot of memory if many network devices are registered. commit be281e554e2a (ipv6: reduce per device ICMP mib sizes) shrinked percpu needs for ipv6, but we can reduce memory use a bit more. With recent percpu infrastructure (irqsafe_cpu_inc() ...), we no longer need this BH/USER separation since we can update counters in a single x86 instruction, regardless of the BH/USER context. Other arches than x86 might need to disable irq in their irqsafe_cpu_inc() implementation : If this happens to be a problem, we can make SNMP_ARRAY_SZ arch dependent, but a previous poll ( https://lkml.org/lkml/2011/3/17/174 ) to arch maintainers did not raise strong opposition. Only on 32bit arches, we need to disable BH for 64bit counters updates done from USER context (currently used for IP MIB) This also reduces vmlinux size : 1) x86_64 build $ size vmlinux.before vmlinux.after text data bss dec hex filename 7853650 1293772 1896448 11043870 a8841e vmlinux.before 7850578 1293772 1896448 11040798 a8781e vmlinux.after 2) i386 build $ size vmlinux.before vmlinux.afterpatch text data bss dec hex filename 6039335 635076 3670016 10344427 9dd7eb vmlinux.before 6037342 635076 3670016 10342434 9dd022 vmlinux.afterpatch Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> CC: Andi Kleen <andi@firstfloor.org> CC: Ingo Molnar <mingo@elte.hu> CC: Tejun Heo <tj@kernel.org> CC: Christoph Lameter <cl@linux-foundation.org> CC: Benjamin Herrenschmidt <benh@kernel.crashing.org CC: linux-arch@vger.kernel.org Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-19ipv6: reduce per device ICMP mib sizesEric Dumazet
ipv6 has per device ICMP SNMP counters, taking too much space because they use percpu storage. needed size per device is : (512+4)*sizeof(long)*number_of_possible_cpus*2 On a 32bit kernel, 16 possible cpus, this wastes more than 64kbytes of memory per ipv6 enabled network device, taken in vmalloc pool. Since ICMP messages are rare, just use shared counters (atomic_long_t) Per network space ICMP counters are still using percpu memory, we might also convert them to shared counters in a future patch. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> CC: Denys Fedoryshchenko <denys@visp.net.lb> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-21snmp: SNMP_UPD_PO_STATS_BH() always called from softirqEric Dumazet
We dont need to test if we run from softirq context, we definitely are. This saves few instructions in ip_rcv() & ip_rcv_finish() Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-02net: kill unused macros from head fileShan Wei
These macros have been defined for several years since v2.6.12-rc2(tracing by git), but never be used. So remove them. Signed-off-by: Shan Wei <shanwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-12-02net: snmp: fix the wrong ICMP_MIB_MAX valueShan Wei
__ICMP_MIB_MAX is equal to the total number of icmp mib, So no need to add 1. This wastes 4/8 bytes memory. Change it to be same as ICMP6_MIB_MAX, TCP_MIB_MAX, UDP_MIB_MAX. Signed-off-by: Shan Wei <shanwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-30snmp: 64bit ipstats_mib for all archesEric Dumazet
/proc/net/snmp and /proc/net/netstat expose SNMP counters. Width of these counters is either 32 or 64 bits, depending on the size of "unsigned long" in kernel. This means user program parsing these files must already be prepared to deal with 64bit values, regardless of user program being 32 or 64 bit. This patch introduces 64bit snmp values for IPSTAT mib, where some counters can wrap pretty fast if they are 32bit wide. # netstat -s|egrep "InOctets|OutOctets" InOctets: 244068329096 OutOctets: 244069348848 Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-06-23snmp: fix SNMP_ADD_STATS()Eric Dumazet
commit aa2ea0586d9d (tcp: fix outsegs stat for TSO segments) incorrectly assumed SNMP_ADD_STATS() was used from BH context. Fix this using mib[!in_softirq()] instead of mib[0] Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> CC: Tom Herbert <therbert@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-22tcp: fix outsegs stat for TSO segmentsTom Herbert
Account for TSO segments of an skb in TCP_MIB_OUTSEGS counter. Without doing this, the counter can be off by orders of magnitude from the actual number of segments sent. Signed-off-by: Tom Herbert <therbert@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-03-21net: snmp mib cleanupEric Dumazet
There is no point to align or pad mibs to cache lines, they are per cpu allocated with a 8 bytes alignment anyway. This wastes space for no gain. This patch removes __SNMP_MIB_ALIGN__ Since SNMP mibs contain "unsigned long" fields only, we can relax the allocation alignment from "unsigned long long" to "unsigned long" Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-02-16percpu: add __percpu sparse annotations to netTejun Heo
Add __percpu sparse annotations to net. These annotations are to make sparse consider percpu variables to be in a different address space and warn if accessed without going through percpu accessors. This patch doesn't affect normal builds. The macro and type tricks around snmp stats make things a bit interesting. DEFINE/DECLARE_SNMP_STAT() macros mark the target field as __percpu and SNMP_UPD_PO_STATS() macro is updated accordingly. All snmp_mib_*() users which used to cast the argument to (void **) are updated to cast it to (void __percpu **). Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: David S. Miller <davem@davemloft.net> Cc: Patrick McHardy <kaber@trash.net> Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Cc: Vlad Yasevich <vladislav.yasevich@hp.com> Cc: netdev@vger.kernel.org Signed-off-by: David S. Miller <davem@davemloft.net>
2010-01-23net: constify MIB name tablesAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-03this_cpu: Use this_cpu operations for SNMP statisticsChristoph Lameter
SNMP statistic macros can be signficantly simplified. This will also reduce code size if the arch supports these operations in hardware. Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: Tejun Heo <tj@kernel.org>
2009-04-27snmp: add missing counters for RFC 4293Neil Horman
The IP MIB (RFC 4293) defines stats for InOctets, OutOctets, InMcastOctets and OutMcastOctets: http://tools.ietf.org/html/rfc4293 But it seems we don't track those in any way that easy to separate from other protocols. This patch adds those missing counters to the stats file. Tested successfully by me With help from Eric Dumazet. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-06-11net: remove CVS keywordsAdrian Bunk
This patch removes CVS keywords that weren't updated for a long time from comments. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[XFRM]: Define packet dropping statistics.Masahide NAKAMURA
This statistics is shown factor dropped by transformation at /proc/net/xfrm_stat for developer. It is a counter designed from current transformation source code and defined as linux private MIB. See Documentation/networking/xfrm_proc.txt for the detail. Signed-off-by: Masahide NAKAMURA <nakam@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[SNMP]: Fix SNMP counters with PREEMPTHerbert Xu
The SNMP macros use raw_smp_processor_id() in process context which is illegal because the process may be preempted and then migrated to another CPU. This patch makes it use get_cpu/put_cpu to disable preemption. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-01-28[SNMP]: Remove unused devconf macros.Pavel Emelyanov
The SNMP_INC_STATS_OFFSET_BH is used only by ICMP6_INC_STATS_OFFSET_BH. The ICMP6_INC_STATS_OFFSET_BH is unused. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[IPV4]: Add ICMPMsgStats MIB (RFC 4293)David L Stevens
Background: RFC 4293 deprecates existing individual, named ICMP type counters to be replaced with the ICMPMsgStatsTable. This table includes entries for both IPv4 and IPv6, and requires counting of all ICMP types, whether or not the machine implements the type. These patches "remove" (but not really) the existing counters, and replace them with the ICMPMsgStats tables for v4 and v6. It includes the named counters in the /proc places they were, but gets the values for them from the new tables. It also counts packets generated from raw socket output (e.g., OutEchoes, MLD queries, RA's from radvd, etc). Changes: 1) create icmpmsg_statistics mib 2) create icmpv6msg_statistics mib 3) modify existing counters to use these 4) modify /proc/net/snmp to add "IcmpMsg" with all ICMP types listed by number for easy SNMP parsing 5) modify /proc/net/snmp printing for "Icmp" to get the named data from new counters. Signed-off-by: David L Stevens <dlstevens@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10[IPV6]: Add ICMPMsgStats MIB (RFC 4293) [rev 2]David L Stevens
Background: RFC 4293 deprecates existing individual, named ICMP type counters to be replaced with the ICMPMsgStatsTable. This table includes entries for both IPv4 and IPv6, and requires counting of all ICMP types, whether or not the machine implements the type. These patches "remove" (but not really) the existing counters, and replace them with the ICMPMsgStats tables for v4 and v6. It includes the named counters in the /proc places they were, but gets the values for them from the new tables. It also counts packets generated from raw socket output (e.g., OutEchoes, MLD queries, RA's from radvd, etc). Changes: 1) create icmpmsg_statistics mib 2) create icmpv6msg_statistics mib 3) modify existing counters to use these 4) modify /proc/net/snmp to add "IcmpMsg" with all ICMP types listed by number for easy SNMP parsing 5) modify /proc/net/snmp printing for "Icmp" to get the named data from new counters. [new to 2nd revision] 6) support per-interface ICMP stats 7) use common macro for per-device stat macros Signed-off-by: David L Stevens <dlstevens@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-09-22[SCTP]: Extend /proc/net/sctp/snmp to provide more statistics.Sridhar Samudrala
This patch adds more statistics info under /proc/net/sctp/snmp that should be useful for debugging. The additional events that are counted now include timer expirations, retransmits, packet and data chunk discards. The Data chunk discards include all the cases where a data chunk is discarded including high tsn, bad stream, dup tsn and the most useful one(out of receive buffer/rwnd). Also moved the SCTP MIB data structures from the generic include directories to include/sctp/sctp.h. Signed-off-by: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-06-21[PATCH] smp_processor_id() cleanupIngo Molnar
This patch implements a number of smp_processor_id() cleanup ideas that Arjan van de Ven and I came up with. The previous __smp_processor_id/_smp_processor_id/smp_processor_id API spaghetti was hard to follow both on the implementational and on the usage side. Some of the complexity arose from picking wrong names, some of the complexity comes from the fact that not all architectures defined __smp_processor_id. In the new code, there are two externally visible symbols: - smp_processor_id(): debug variant. - raw_smp_processor_id(): nondebug variant. Replaces all existing uses of _smp_processor_id() and __smp_processor_id(). Defined by every SMP architecture in include/asm-*/smp.h. There is one new internal symbol, dependent on DEBUG_PREEMPT: - debug_smp_processor_id(): internal debug variant, mapped to smp_processor_id(). Also, i moved debug_smp_processor_id() from lib/kernel_lock.c into a new lib/smp_processor_id.c file. All related comments got updated and/or clarified. I have build/boot tested the following 8 .config combinations on x86: {SMP,UP} x {PREEMPT,!PREEMPT} x {DEBUG_PREEMPT,!DEBUG_PREEMPT} I have also build/boot tested x64 on UP/PREEMPT/DEBUG_PREEMPT. (Other architectures are untested, but should work just fine.) Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
