path: root/include/net/wireless.h
2008-03-27cfg80211: don't export ieee80211_get_channelJohannes Berg
This patch makes ieee80211_get_channel a static inline defined in cfg80211's header file which simply calls __ieee80211_get_channel to avoid symbol clashes with the ieee80211 code. The problem was pointed out by David Miller, thanks! Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Cc: David Miller <davem@davemloft.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-03-25wireless: add wiphy channel freq to channel struct lookup helperJohannes Berg
Add ieee80211_get_channel() which gets you a channel struct for a specific wiphy if that channel is present in that wiphy. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-29cfg80211 API for channels/bitrates, mac80211 and driver conversionJohannes Berg
This patch creates new cfg80211 wiphy API for channel and bitrate registration and converts mac80211 and drivers to the new API. The old mac80211 API is completely ripped out. All drivers (except ath5k) are updated to the new API, in many cases I expect that optimisations can be done. Along with the regulatory code I've also ripped out the IEEE80211_HW_DEFAULT_REG_DOMAIN_CONFIGURED flag, I believe it to be unnecessary if the hardware simply gives us whatever channels it wants to support and we then enable/disable them as required, which is pretty much required for travelling. Additionally, the patch adds proper "basic" rate handling for STA mode interface, AP mode interface will have to have new API added to allow userspace to set the basic rate set, currently it'll be empty... However, the basic rate handling will need to be moved to the BSS conf stuff. I do expect there to be bugs in this, especially wrt. transmit power handling where I'm basically clueless about how it should work. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-04-25[WIRELESS] cfg80211: New wireless config infrastructure.Johannes Berg
This patch creates the core cfg80211 code along with some sysfs bits. This is a stripped down version to allow mac80211 to function, but doesn't include any configuration yet except for creating and removing virtual interfaces. This patch includes the nl80211 header file but it only contains the interface types which the cfg80211 interface for creating virtual interfaces relies on. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
