path: root/include/net
2012-12-04bluetooth: hid: make Android code conditionalMursalin Akon
Commit 7c786ce33a1b4194cb95aa1e68bc38d552eda932 introduced couple of fields, which are not used in standard bluez user space stack. However, Android bluez use them. This CL, conditionally builds the part of the code introduced in the above commit. Bug 1178960 Change-Id: I7254fe83c7fb4bbfd14e00dda3ec3a14afc1b234 Signed-off-by: Mursalin Akon <makon@nvidia.com> (cherry picked from commit e3375fd96fa5e0d7cfcda848d797cd512c12b7a6) Reviewed-on: http://git-master/r/167540 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Eric Brower <ebrower@nvidia.com> Reviewed-by: Matthew Pedro <mapedro@nvidia.com>
2012-07-12mac80211 & nl80211: add support to abort a scan request on txWei Ni
This fix comes from: https://gerrit.chromium.org/gerrit/#change,5744 https://gerrit.chromium.org/gerrit/#change,5745 So that it can work with the related wpa_supplicant tool. BUG=895591 Change-Id: Ie81f6d6052bd45dab13c936f9f0c5f4eb277496a Original-Signed-off-by: Wei Ni <wni@nvidia.com> Signed-off-by: Rhyland Klein <rklein@nvidia.com> Reviewed-on: http://git-master/r/111333 Reviewed-by: Automatic_Commit_Validation_User Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com>
2012-06-15cfg80211: fix a crash in nl80211_send_stationFelix Fietkau
mac80211 leaves sinfo->assoc_req_ies uninitialized, causing a random pointer memory access in nl80211_send_station. Instead of checking if the pointer is null, use sinfo->filled, like the rest of the fields. Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2012-02-08netns: Fail conspicously if someone uses net_generic at an inappropriate time.Eric W. Biederman
[ Upstream commit 5ee4433efe99b9f39f6eff5052a177bbcfe72cea ] By definition net_generic should never be called when it can return NULL. Fail conspicously with a BUG_ON to make it clear when people mess up that a NULL return should never happen. Recently there was a bug in the CAIF subsystem where it was registered with register_pernet_device instead of register_pernet_subsys. It was erroneously concluded that net_generic could validly return NULL and that net_assign_generic was buggy (when it was just inefficient). Hopefully this BUG_ON will prevent people to coming to similar erroneous conclusions in the futrue. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Tested-by: Sasha Levin <levinsasha928@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Varun Wadekar <vwadekar@nvidia.com> Change-Id: I7936b0403664d9745e4932aad72fd09c100f526c Reviewed-on: http://git-master/r/79690 Reviewed-by: Automatic_Commit_Validation_User
2012-02-03nl80211/cfg80211: Make addition of new sinfo fields saferJouni Malinen
Add a comment pointing out the use of enum station_info_flags for all new struct station_info fields. In addition, memset the sinfo buffer to zero before use on all paths in the current tree to avoid leaving uninitialized pointers in the data. (cherry picked from commit 87159de9c30dab02b84cbaffa7498140d4ebc1a1 from android.googlesource.com/common.git) Signed-off-by: Jouni Malinen <jouni@qca.qualcomm.com> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Dmitry Shmidt <dimitrysh@google.com> Signed-off-by: Varun Wadekar <vwadekar@nvidia.com> Change-Id: I24301d45108587e66c8421a7f2a94ea98300ebeb Reviewed-on: http://git-master/r/78887 Reviewed-by: Automatic_Commit_Validation_User
2012-02-03cfg80211/nl80211: Send AssocReq IEs to user space in AP modeJouni Malinen
When user space SME/MLME (e.g., hostapd) is not used in AP mode, the IEs from the (Re)Association Request frame that was processed in firmware need to be made available for user space (e.g., RSN IE for hostapd). Allow this to be done with cfg80211_new_sta(). (cherry picked from commit d692df224b8605095cb7f770c1c99d3150834daf from android.googlesource.com/common.git) Signed-off-by: Jouni Malinen <jouni@qca.qualcomm.com> Acked-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Dmitry Shmidt <dimitrysh@google.com> Signed-off-by: Varun Wadekar <vwadekar@nvidia.com> Change-Id: I211171ca4953832cc998402c149ecf3fc429f9e6 Reviewed-on: http://git-master/r/78886 Reviewed-by: Automatic_Commit_Validation_User
2012-01-11net: introduce DST_NOPEER dst flagEric Dumazet
[ Upstream commit e688a604807647c9450f9c12a7cb6d027150a895 ] Chris Boot reported crashes occurring in ipv6_select_ident(). [ 461.457562] RIP: 0010:[<ffffffff812dde61>] [<ffffffff812dde61>] ipv6_select_ident+0x31/0xa7 [ 461.578229] Call Trace: [ 461.580742] <IRQ> [ 461.582870] [<ffffffff812efa7f>] ? udp6_ufo_fragment+0x124/0x1a2 [ 461.589054] [<ffffffff812dbfe0>] ? ipv6_gso_segment+0xc0/0x155 [ 461.595140] [<ffffffff812700c6>] ? skb_gso_segment+0x208/0x28b [ 461.601198] [<ffffffffa03f236b>] ? ipv6_confirm+0x146/0x15e [nf_conntrack_ipv6] [ 461.608786] [<ffffffff81291c4d>] ? nf_iterate+0x41/0x77 [ 461.614227] [<ffffffff81271d64>] ? dev_hard_start_xmit+0x357/0x543 [ 461.620659] [<ffffffff81291cf6>] ? nf_hook_slow+0x73/0x111 [ 461.626440] [<ffffffffa0379745>] ? br_parse_ip_options+0x19a/0x19a [bridge] [ 461.633581] [<ffffffff812722ff>] ? dev_queue_xmit+0x3af/0x459 [ 461.639577] [<ffffffffa03747d2>] ? br_dev_queue_push_xmit+0x72/0x76 [bridge] [ 461.646887] [<ffffffffa03791e3>] ? br_nf_post_routing+0x17d/0x18f [bridge] [ 461.653997] [<ffffffff81291c4d>] ? nf_iterate+0x41/0x77 [ 461.659473] [<ffffffffa0374760>] ? br_flood+0xfa/0xfa [bridge] [ 461.665485] [<ffffffff81291cf6>] ? nf_hook_slow+0x73/0x111 [ 461.671234] [<ffffffffa0374760>] ? br_flood+0xfa/0xfa [bridge] [ 461.677299] [<ffffffffa0379215>] ? nf_bridge_update_protocol+0x20/0x20 [bridge] [ 461.684891] [<ffffffffa03bb0e5>] ? nf_ct_zone+0xa/0x17 [nf_conntrack] [ 461.691520] [<ffffffffa0374760>] ? br_flood+0xfa/0xfa [bridge] [ 461.697572] [<ffffffffa0374812>] ? NF_HOOK.constprop.8+0x3c/0x56 [bridge] [ 461.704616] [<ffffffffa0379031>] ? nf_bridge_push_encap_header+0x1c/0x26 [bridge] [ 461.712329] [<ffffffffa037929f>] ? br_nf_forward_finish+0x8a/0x95 [bridge] [ 461.719490] [<ffffffffa037900a>] ? nf_bridge_pull_encap_header+0x1c/0x27 [bridge] [ 461.727223] [<ffffffffa0379974>] ? br_nf_forward_ip+0x1c0/0x1d4 [bridge] [ 461.734292] [<ffffffff81291c4d>] ? nf_iterate+0x41/0x77 [ 461.739758] [<ffffffffa03748cc>] ? __br_deliver+0xa0/0xa0 [bridge] [ 461.746203] [<ffffffff81291cf6>] ? nf_hook_slow+0x73/0x111 [ 461.751950] [<ffffffffa03748cc>] ? __br_deliver+0xa0/0xa0 [bridge] [ 461.758378] [<ffffffffa037533a>] ? NF_HOOK.constprop.4+0x56/0x56 [bridge] This is caused by bridge netfilter special dst_entry (fake_rtable), a special shared entry, where attaching an inetpeer makes no sense. Problem is present since commit 87c48fa3b46 (ipv6: make fragment identifications less predictable) Introduce DST_NOPEER dst flag and make sure ipv6_select_ident() and __ip_select_ident() fallback to the 'no peer attached' handling. Reported-by: Chris Boot <bootc@bootc.net> Tested-by: Chris Boot <bootc@bootc.net> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Change-Id: Id23270aae3214c26691f95922a63c70549232c22 Reviewed-on: http://git-master/r/74224 Reviewed-by: Varun Wadekar <vwadekar@nvidia.com> Tested-by: Varun Wadekar <vwadekar@nvidia.com>
2012-01-11net: Add a flow_cache_flush_deferred functionSteffen Klassert
[ Upstream commit c0ed1c14a72ca9ebacd51fb94a8aca488b0d361e ] flow_cach_flush() might sleep but can be called from atomic context via the xfrm garbage collector. So add a flow_cache_flush_deferred() function and use this if the xfrm garbage colector is invoked from within the packet path. Signed-off-by: Steffen Klassert <steffen.klassert@secunet.com> Acked-by: Timo Teräs <timo.teras@iki.fi> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Change-Id: I6561c4fa576a9e83f4e2faf7b62dbd1d9b598c39 Reviewed-on: http://git-master/r/74221 Reviewed-by: Varun Wadekar <vwadekar@nvidia.com> Tested-by: Varun Wadekar <vwadekar@nvidia.com>
2012-01-11sctp: fix incorrect overflow check on autocloseXi Wang
[ Upstream commit 2692ba61a82203404abd7dd2a027bda962861f74 ] Commit 8ffd3208 voids the previous patches f6778aab and 810c0719 for limiting the autoclose value. If userspace passes in -1 on 32-bit platform, the overflow check didn't work and autoclose would be set to 0xffffffff. This patch defines a max_autoclose (in seconds) for limiting the value and exposes it through sysctl, with the following intentions. 1) Avoid overflowing autoclose * HZ. 2) Keep the default autoclose bound consistent across 32- and 64-bit platforms (INT_MAX / HZ in this patch). 3) Keep the autoclose value consistent between setsockopt() and getsockopt() calls. Suggested-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: Xi Wang <xi.wang@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Change-Id: I74631fca684d7a475f1eed5f6823c11b62bbd2bc Reviewed-on: http://git-master/r/74219 Reviewed-by: Varun Wadekar <vwadekar@nvidia.com> Tested-by: Varun Wadekar <vwadekar@nvidia.com>
2011-12-14Merge branch 'linux-3.1.5' into android-tegra-nv-3.1Varun Wadekar
Conflicts: arch/arm/Kconfig Change-Id: If8aaaf3efcbbf6c9017b38efb6d76ef933f147fa Signed-off-by: Varun Wadekar <vwadekar@nvidia.com>
2011-12-09sch_red: fix red_calc_qavg_from_idle_timeEric Dumazet
[ Upstream commit ea6a5d3b97b768561db6358f15e4c84ced0f4f7e ] Since commit a4a710c4a7490587 (pkt_sched: Change PSCHED_SHIFT from 10 to 6) it seems RED/GRED are broken. red_calc_qavg_from_idle_time() computes a delay in us units, but this delay is now 16 times bigger than real delay, so the final qavg result smaller than expected. Use standard kernel time services since there is no need to obfuscate them. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-12-09inet: add a redirect generation id in inetpeerEric Dumazet
[ Upstream commit de68dca1816660b0d3ac89fa59ffb410007a143f ] Now inetpeer is the place where we cache redirect information for ipv4 destinations, we must be able to invalidate informations when a route is added/removed on host. As inetpeer is not yet namespace aware, this patch adds a shared redirect_genid, and a per inetpeer redirect_genid. This might be changed later if inetpeer becomes ns aware. Cache information for one inerpeer is valid as long as its redirect_genid has the same value than global redirect_genid. Reported-by: Arkadiusz Miśkiewicz <a.miskiewicz@gmail.com> Tested-by: Arkadiusz Miśkiewicz <a.miskiewicz@gmail.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-30HACK merge fixups for compileDan Willemsen
Rebase-Id: Rbc628711479b187a90437bea94776066c7a58b54
2011-11-30tegra bluesleep: Bluetooth active power management driverAnantha Idapalapati
A new driver is implemented to actively manage the bluetooth module power. bluesleep also tries to manage the power of the transport used. Two signals (GPIOs) are used to manage the power events. BT_WAKE : signal from HOST to BT chip to intimate BT chip can sleep. HOST_WAKE: signal from BT chip to HOST to intimate HOST should wakeup/ activate the transport modules required for BT communication. Bug 791669, 773186 (cherry picked from commit 111f4ccd3c4cfde2fa52ae4c0c56a2288c3af3a8) Original-Change-Id: Iff1e81bb22d9bd43113f7cdd01329da3ae852a15 Reviewed-on: http://git-master/r/19858 Reviewed-by: Bharat Nihalani <bnihalani@nvidia.com> Tested-by: Bharat Nihalani <bnihalani@nvidia.com> Rebase-Id: R1eca7f2f51475daf6104e71e90ad5db1213fa6ea
2011-11-30ipv6: updates to privacy addresses per RFC 4941JP Abgrall
Update the code to handle some of the differences between RFC 3041 and RFC 4941, which obsoletes it. Also a couple of janitorial fixes. - Allow router advertisements to increase the lifetime of temporary addresses. This was not allowed by RFC 3041, but is specified by RFC 4941. It is useful when RA lifetimes are lower than TEMP_{VALID,PREFERRED}_LIFETIME: in this case, the previous code would delete or deprecate addresses prematurely. - Change the default of MAX_RETRY to 3 per RFC 4941. - Add a comment to clarify that the preferred and valid lifetimes in inet6_ifaddr are relative to the timestamp. - Shorten lines to 80 characters in a couple of places. Change-Id: I4da097664d4b1de7c1cebf410895319601c7f1cc Signed-off-by: Lorenzo Colitti <lorenzo@google.com> Signed-off-by: JP Abgrall <jpa@google.com>
2011-11-30Bluetooth: Add support for SMP timeoutVinicius Costa Gomes
This patch adds support for disconnecting the link when SMP procedure takes more than 30 seconds. SMP begins when either the Pairing Request command is sent or the Pairing Response is received, and it ends when the link is encrypted (or terminated). Vol 3, Part H Section 3.4. Signed-off-by: Vinicius Costa Gomes <vinicius.gomes@openbossa.org> Signed-off-by: Gustavo F. Padovan <padovan@profusion.mobi>
2011-11-30Bluetooth: Clean up some code style issuesWaldemar Rymarkiewicz
Fix lines longer than 80 chars in length. Change-Id: I448077965c5f7723a4a9537977bfa664cfe104fd Signed-off-by: Waldemar Rymarkiewicz <waldemar.rymarkiewicz@tieto.com> Signed-off-by: Gustavo F. Padovan <padovan@profusion.mobi>
2011-11-30Bluetooth: Allow SCO/eSCO packet type selection for outgoing SCO connections.Nick Pelly
__u16 sco_pkt_type is introduced to struct sockaddr_sco. It allows bitwise selection of SCO/eSCO packet types. Currently those bits are: 0x0001 HV1 may be used. 0x0002 HV2 may be used. 0x0004 HV3 may be used. 0x0008 EV3 may be used. 0x0010 EV4 may be used. 0x0020 EV5 may be used. 0x0040 2-EV3 may be used. 0x0080 3-EV3 may be used. 0x0100 2-EV5 may be used. 0x0200 3-EV5 may be used. This is similar to the Packet Type parameter in the HCI Setup Synchronous Connection Command, except that we are not reversing the logic on the EDR bits. This makes the use of sco_pkt_tpye forward portable for the use case of white-listing packet types, which we expect will be the primary use case. If sco_pkt_type is zero, or userspace uses the old struct sockaddr_sco, then the default behavior is to allow all packet types. Packet type selection is just a request made to the Bluetooth chipset, and it is up to the link manager on the chipset to negiotiate and decide on the actual packet types used. Furthermore, when a SCO/eSCO connection is eventually made there is no way for the host stack to determine which packet type was used (however it is possible to get the link type of SCO or eSCO). sco_pkt_type is ignored for incoming SCO connections. It is possible to add this in the future as a parameter to the Accept Synchronous Connection Command, however its a little trickier because the kernel does not currently preserve sockaddr_sco data between userspace calls to accept(). The most common use for sco_pkt_type will be to white-list only SCO packets, which can be done with the hci.h constant SCO_ESCO_MASK. This patch is motivated by broken Bluetooth carkits such as the Motorolo HF850 (it claims to support eSCO, but will actually reject eSCO connections after 5 seconds) and the 2007/2008 Infiniti G35/37 (fails to route audio if a 2-EV5 packet type is negiotiated). With this patch userspace can maintain a list of compatible packet types to workaround remote devices such as these. Based on a patch by Marcel Holtmann. Rebased to 2.6.39. Change-Id: Ide1c89574fa4f6f1b9218282e1af17051eb86315 Signed-off-by: Nick Pelly <npelly@google.com>
2011-11-30net: Support nuking IPv6 sockets as well as IPv4.Lorenzo Colitti
On Linux, when an interface goes down all its IPv6 addresses are deleted, so relying on knowing the previous IPv6 addresses on the interface is brittle. Instead, support nuking all sockets that are bound to IP addresses that are not configured and up on the system. This behaviour is triggered by specifying the unspecified address (:: or 0.0.0.0). If an IP address is specified, the behaviour is unchanged, except the ioctl now supports IPv6 as well as IPv4. Signed-off-by: Lorenzo Colitti <lorenzo@google.com>
2011-11-30net: activity_stats: Add statistics for network transmission activityMike Chan
When enabled, tracks the frequency of network transmissions (inbound and outbound) and buckets them accordingly. Buckets are determined by time between network activity. Each bucket represents the number of network transmisions that were N sec or longer apart. Where N is defined as 1 << bucket index. This network pattern tracking is particularly useful for wireless networks (ie: 3G) where batching network activity closely together is more power efficient than far apart. New file: /proc/net/stat/activity output: Min Bucket(sec) Count 1 7 2 0 4 1 8 0 16 0 32 2 64 1 128 0 Change-Id: I4c4cd8627b872a55f326b1715c51bc3bdd6e8d92 Signed-off-by: Mike Chan <mike@android.com>
2011-11-30Bluetooth: Add ACL MTU, available buffers and total buffers to hci_conn_info.Nick Pelly
This provides userspace debugging tools access to ACL flow control state. Signed-off-by: Nick Pelly <npelly@google.com>
2011-11-30Bluetooth: Increase timeout for legacy pairing from 10 seconds to 40 seconds.Nick Pelly
Legacy pairing is a bit of a problem because on the incoming end it is impossible to know pairing has begun: 2009-09-18 18:29:24.115692 > HCI Event: Connect Request (0x04) plen 10 bdaddr 00:23:D4:04:51:7A class 0x58020c type ACL 2009-09-18 18:29:24.115966 < HCI Command: Accept Connection Request (0x01|0x0009) plen 7 bdaddr 00:23:D4:04:51:7A role 0x00 Role: Master 2009-09-18 18:29:24.117065 > HCI Event: Command Status (0x0f) plen 4 Accept Connection Request (0x01|0x0009) status 0x00 ncmd 1 2009-09-18 18:29:24.282928 > HCI Event: Role Change (0x12) plen 8 status 0x00 bdaddr 00:23:D4:04:51:7A role 0x00 Role: Master 2009-09-18 18:29:24.291534 > HCI Event: Connect Complete (0x03) plen 11 status 0x00 handle 1 bdaddr 00:23:D4:04:51:7A type ACL encrypt 0x00 2009-09-18 18:29:24.291839 < HCI Command: Read Remote Supported Features (0x01|0x001b) plen 2 handle 1 2009-09-18 18:29:24.292144 > HCI Event: Page Scan Repetition Mode Change (0x20) plen 7 bdaddr 00:23:D4:04:51:7A mode 1 2009-09-18 18:29:24.293823 > HCI Event: Command Status (0x0f) plen 4 Read Remote Supported Features (0x01|0x001b) status 0x00 ncmd 1 2009-09-18 18:29:24.303588 > HCI Event: Max Slots Change (0x1b) plen 3 handle 1 slots 5 2009-09-18 18:29:24.309448 > HCI Event: Read Remote Supported Features (0x0b) plen 11 status 0x00 handle 1 Features: 0xff 0xff 0x2d 0xfe 0x9b 0xff 0x79 0x83 2009-09-18 18:29:24.345916 < HCI Command: Remote Name Request (0x01|0x0019) plen 10 bdaddr 00:23:D4:04:51:7A mode 2 clkoffset 0x0000 2009-09-18 18:29:24.346923 > HCI Event: Command Status (0x0f) plen 4 Remote Name Request (0x01|0x0019) status 0x00 ncmd 1 2009-09-18 18:29:24.375793 > HCI Event: Remote Name Req Complete (0x07) plen 255 status 0x00 bdaddr 00:23:D4:04:51:7A name 'test' 2009-09-18 18:29:34.332190 < HCI Command: Disconnect (0x01|0x0006) plen 3 handle 1 reason 0x13 There are some mainline patches such as "Add different pairing timeout for Legacy Pairing" but they do not address the HCI sequence above. I think the real solution is to avoid using CreateBond(), and instead make the profile connection immediately. This way both sides will use a longer timeout because there is a higher level connection in progress, and we will not end up with the useless HCI sequence above. Signed-off-by: Nick Pelly <npelly@google.com>
2011-11-30net: socket ioctl to reset connections matching local addressRobert Love
Introduce a new socket ioctl, SIOCKILLADDR, that nukes all sockets bound to the same local address. This is useful in situations with dynamic IPs, to kill stuck connections. Signed-off-by: Brian Swetland <swetland@google.com> net: fix tcp_v4_nuke_addr Signed-off-by: Dima Zavin <dima@android.com> net: ipv4: Fix a spinlock recursion bug in tcp_v4_nuke. We can't hold the lock while calling to tcp_done(), so we drop it before calling. We then have to start at the top of the chain again. Signed-off-by: Dima Zavin <dima@android.com> net: ipv4: Fix race in tcp_v4_nuke_addr(). To fix a recursive deadlock in 2.6.29, we stopped holding the hash table lock across tcp_done() calls. This fixed the deadlock, but introduced a race where the socket could die or change state. Fix: Before unlocking the hash table, we grab a reference to the socket. We can then unlock the hash table without risk of the socket going away. We then lock the socket, which is safe because it is pinned. We can then call tcp_done() without recursive deadlock and without race. Upon return, we unlock the socket and then unpin it, killing it. Change-Id: Idcdae072b48238b01bdbc8823b60310f1976e045 Signed-off-by: Robert Love <rlove@google.com> Acked-by: Dima Zavin <dima@android.com> ipv4: disable bottom halves around call to tcp_done(). Signed-off-by: Robert Love <rlove@google.com> Signed-off-by: Colin Cross <ccross@android.com> ipv4: Move sk_error_report inside bh_lock_sock in tcp_v4_nuke_addr When sk_error_report is called, it wakes up the user-space thread, which then calls tcp_close. When the tcp_close is interrupted by the tcp_v4_nuke_addr ioctl thread running tcp_done, it leaks 392 bytes and triggers a WARN_ON. This patch moves the call to sk_error_report inside the bh_lock_sock, which matches the locking used in tcp_v4_err. Signed-off-by: Colin Cross <ccross@android.com>
2011-10-17Merge branch 'nf' of git://1984.lsi.us.es/netDavid S. Miller
2011-10-17udplite: fast-path computation of checksum coverageGerrit Renker
Commit 903ab86d195cca295379699299c5fc10beba31c7 of 1 March this year ("udp: Add lockless transmit path") introduced a new fast TX path that broke the checksum coverage computation of UDP-lite, which so far depended on up->len (only set if the socket is locked and 0 in the fast path). Fixed by providing both fast- and slow-path computation of checksum coverage. The latter can be removed when UDP(-lite)v6 also uses a lockless transmit path. Reported-by: Thomas Volkert <thomas@homer-conferencing.com> Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-10-12IPVS netns shutdown/startup dead-lockHans Schillstrom
ip_vs_mutext is used by both netns shutdown code and startup and both implicit uses sk_lock-AF_INET mutex. cleanup CPU-1 startup CPU-2 ip_vs_dst_event() ip_vs_genl_set_cmd() sk_lock-AF_INET __ip_vs_mutex sk_lock-AF_INET __ip_vs_mutex * DEAD LOCK * A new mutex placed in ip_vs netns struct called sync_mutex is added. Comments from Julian and Simon added. This patch has been running for more than 3 month now and it seems to work. Ver. 3 IP_VS_SO_GET_DAEMON in do_ip_vs_get_ctl protected by sync_mutex instead of __ip_vs_mutex as sugested by Julian. Signed-off-by: Hans Schillstrom <hans@schillstrom.com> Acked-by: Julian Anastasov <ja@ssi.bg> Signed-off-by: Simon Horman <horms@verge.net.au> Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2011-09-18tcp: fix build error if !CONFIG_SYN_COOKIESEric Dumazet
commit 946cedccbd7387 (tcp: Change possible SYN flooding messages) added a build error if CONFIG_SYN_COOKIES=n Reported-by: Markus Trippelsdorf <markus@trippelsdorf.de> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-09-18Merge git://github.com/davem330/netLinus Torvalds
* git://github.com/davem330/net: (62 commits) ipv6: don't use inetpeer to store metrics for routes. can: ti_hecc: include linux/io.h IRDA: Fix global type conflicts in net/irda/irsysctl.c v2 net: Handle different key sizes between address families in flow cache net: Align AF-specific flowi structs to long ipv4: Fix fib_info->fib_metrics leak caif: fix a potential NULL dereference sctp: deal with multiple COOKIE_ECHO chunks ibmveth: Fix checksum offload failure handling ibmveth: Checksum offload is always disabled ibmveth: Fix issue with DMA mapping failure ibmveth: Fix DMA unmap error pch_gbe: support ML7831 IOH pch_gbe: added the process of FIFO over run error pch_gbe: fixed the issue which receives an unnecessary packet. sfc: Use 64-bit writes for TX push where possible Revert "sfc: Use write-combining to reduce TX latency" and follow-ups bnx2x: Fix ethtool advertisement bnx2x: Fix 578xx link LED bnx2x: Fix XMAC loopback test ...
2011-09-16net: Handle different key sizes between address families in flow cachedpward
With the conversion of struct flowi to a union of AF-specific structs, some operations on the flow cache need to account for the exact size of the key. Signed-off-by: David Ward <david.ward@ll.mit.edu> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-09-16net: Align AF-specific flowi structs to longDavid Ward
AF-specific flowi structs are now passed to flow_key_compare, which must also be aligned to a long. Signed-off-by: David Ward <david.ward@ll.mit.edu> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-09-16sctp: deal with multiple COOKIE_ECHO chunksMax Matveev
Attempt to reduce the number of IP packets emitted in response to single SCTP packet (2e3216cd) introduced a complication - if a packet contains two COOKIE_ECHO chunks and nothing else then SCTP state machine corks the socket while processing first COOKIE_ECHO and then loses the association and forgets to uncork the socket. To deal with the issue add new SCTP command which can be used to set association explictly. Use this new command when processing second COOKIE_ECHO chunk to restore the context for SCTP state machine. Signed-off-by: Max Matveev <makc@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-09-16Merge branch 'master' of ../netdev/David S. Miller
2011-09-15tcp: Change possible SYN flooding messagesEric Dumazet
"Possible SYN flooding on port xxxx " messages can fill logs on servers. Change logic to log the message only once per listener, and add two new SNMP counters to track : TCPReqQFullDoCookies : number of times a SYNCOOKIE was replied to client TCPReqQFullDrop : number of times a SYN request was dropped because syncookies were not enabled. Based on a prior patch from Tom Herbert, and suggestions from David. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> CC: Tom Herbert <therbert@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-09-08wireless: fix kernel-doc warning in net/cfg80211.hRandy Dunlap
Fix kernel-doc warning in net/cfg80211.h: Warning(include/net/cfg80211.h:1884): No description found for parameter 'registered' Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-09-06fs/9p: Use protocol-defined value for lock/getlock 'type' field.Jim Garlick
Signed-off-by: Jim Garlick <garlick@llnl.gov> Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
2011-09-06fs/9p: Add OS dependent open flags in 9p protocolAneesh Kumar K.V
Some of the flags are OS/arch dependent we add a 9p protocol value which maps to asm-generic/fcntl.h values in Linux Based on the original patch from Venkateswararao Jujjuri <jvrao@linux.vnet.ibm.com> Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
2011-08-30net: relax PKTINFO non local ipv6 udp xmit checkMaciej Żenczykowski
Allow transparent sockets to be less restrictive about the source ip of ipv6 udp packets being sent. Google-Bug-Id: 5018138 Signed-off-by: Maciej Żenczykowski <maze@google.com> CC: "Erik Kline" <ek@google.com> CC: "Lorenzo Colitti" <lorenzo@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-26Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless into for-davem
2011-08-22mac80211: fix suspend/resume races with unregister hwStanislaw Gruszka
Do not call ->suspend, ->resume methods after we unregister wiphy. Also delete sta_clanup timer after we finish wiphy unregister to avoid this: WARNING: at lib/debugobjects.c:262 debug_print_object+0x85/0xa0() Hardware name: 6369CTO ODEBUG: free active (active state 0) object type: timer_list hint: sta_info_cleanup+0x0/0x180 [mac80211] Modules linked in: aes_i586 aes_generic fuse bridge stp llc autofs4 sunrpc cpufreq_ondemand acpi_cpufreq mperf ext2 dm_mod uinput thinkpad_acpi hwmon sg arc4 rt2800usb rt2800lib crc_ccitt rt2x00usb rt2x00lib mac80211 cfg80211 i2c_i801 iTCO_wdt iTCO_vendor_support e1000e ext4 mbcache jbd2 sd_mod crc_t10dif sr_mod cdrom yenta_socket ahci libahci pata_acpi ata_generic ata_piix i915 drm_kms_helper drm i2c_algo_bit video [last unloaded: microcode] Pid: 5663, comm: pm-hibernate Not tainted 3.1.0-rc1-wl+ #19 Call Trace: [<c0454cfd>] warn_slowpath_common+0x6d/0xa0 [<c05e05e5>] ? debug_print_object+0x85/0xa0 [<c05e05e5>] ? debug_print_object+0x85/0xa0 [<c0454dae>] warn_slowpath_fmt+0x2e/0x30 [<c05e05e5>] debug_print_object+0x85/0xa0 [<f8a808e0>] ? sta_info_alloc+0x1a0/0x1a0 [mac80211] [<c05e0bd2>] debug_check_no_obj_freed+0xe2/0x180 [<c051175b>] kfree+0x8b/0x150 [<f8a126ae>] cfg80211_dev_free+0x7e/0x90 [cfg80211] [<f8a13afd>] wiphy_dev_release+0xd/0x10 [cfg80211] [<c068d959>] device_release+0x19/0x80 [<c05d06ba>] kobject_release+0x7a/0x1c0 [<c07646a8>] ? rtnl_unlock+0x8/0x10 [<f8a13adb>] ? wiphy_resume+0x6b/0x80 [cfg80211] [<c05d0640>] ? kobject_del+0x30/0x30 [<c05d1a6d>] kref_put+0x2d/0x60 [<c05d056d>] kobject_put+0x1d/0x50 [<c08015f4>] ? mutex_lock+0x14/0x40 [<c068d60f>] put_device+0xf/0x20 [<c069716a>] dpm_resume+0xca/0x160 [<c04912bd>] hibernation_snapshot+0xcd/0x260 [<c04903df>] ? freeze_processes+0x3f/0x90 [<c049151b>] hibernate+0xcb/0x1e0 [<c048fdc0>] ? pm_async_store+0x40/0x40 [<c048fe60>] state_store+0xa0/0xb0 [<c048fdc0>] ? pm_async_store+0x40/0x40 [<c05d0200>] kobj_attr_store+0x20/0x30 [<c0575ea4>] sysfs_write_file+0x94/0xf0 [<c051e26a>] vfs_write+0x9a/0x160 [<c0575e10>] ? sysfs_open_file+0x200/0x200 [<c051e3fd>] sys_write+0x3d/0x70 [<c080959f>] sysenter_do_call+0x12/0x28 Cc: stable@kernel.org Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2011-08-07ipv4: route non-local sources for raw socketJulian Anastasov
The raw sockets can provide source address for routing but their privileges are not considered. We can provide non-local source address, make sure the FLOWI_FLAG_ANYSRC flag is set if socket has privileges for this, i.e. based on hdrincl (IP_HDRINCL) and transparent flags. Signed-off-by: Julian Anastasov <ja@ssi.bg> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-06net: Compute protocol sequence numbers and fragment IDs using MD5.David S. Miller
Computers have become a lot faster since we compromised on the partial MD4 hash which we use currently for performance reasons. MD5 is a much safer choice, and is inline with both RFC1948 and other ISS generators (OpenBSD, Solaris, etc.) Furthermore, only having 24-bits of the sequence number be truly unpredictable is a very serious limitation. So the periodic regeneration and 8-bit counter have been removed. We compute and use a full 32-bit sequence number. For ipv6, DCCP was found to use a 32-bit truncated initial sequence number (it needs 43-bits) and that is fixed here as well. Reported-by: Dan Kaminsky <dan@doxpara.com> Tested-by: Willy Tarreau <w@1wt.eu> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-03net: fix NULL dereferences in check_peer_redir()Eric Dumazet
Gergely Kalman reported crashes in check_peer_redir(). It appears commit f39925dbde778 (ipv4: Cache learned redirect information in inetpeer.) added a race, leading to possible NULL ptr dereference. Since we can now change dst neighbour, we should make sure a reader can safely use a neighbour. Add RCU protection to dst neighbour, and make sure check_peer_redir() can be called safely by different cpus in parallel. As neighbours are already freed after one RCU grace period, this patch should not add typical RCU penalty (cache cold effects) Many thanks to Gergely for providing a pretty report pointing to the bug. Reported-by: Gergely Kalman <synapse@hippy.csoma.elte.hu> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-01doc: Update the email address for Paul Moore in various source filesPaul Moore
My @hp.com will no longer be valid starting August 5, 2011 so an update is necessary. My new email address is employer independent so we don't have to worry about doing this again any time soon. Signed-off-by: Paul Moore <paul.moore@hp.com> Signed-off-by: Paul Moore <paul@paul-moore.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-07-26atomic: use <linux/atomic.h>Arun Sharma
This allows us to move duplicated code in <asm/atomic.h> (atomic_inc_not_zero() for now) to <linux/atomic.h> Signed-off-by: Arun Sharma <asharma@fb.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits) fs: Merge split strings treewide: fix potentially dangerous trailing ';' in #defined values/expressions uwb: Fix misspelling of neighbourhood in comment net, netfilter: Remove redundant goto in ebt_ulog_packet trivial: don't touch files that are removed in the staging tree lib/vsprintf: replace link to Draft by final RFC number doc: Kconfig: `to be' -> `be' doc: Kconfig: Typo: square -> squared doc: Konfig: Documentation/power/{pm => apm-acpi}.txt drivers/net: static should be at beginning of declaration drivers/media: static should be at beginning of declaration drivers/i2c: static should be at beginning of declaration XTENSA: static should be at beginning of declaration SH: static should be at beginning of declaration MIPS: static should be at beginning of declaration ARM: static should be at beginning of declaration rcu: treewide: Do not use rcu_read_lock_held when calling rcu_dereference_check Update my e-mail address PCIe ASPM: forcedly -> forcibly gma500: push through device driver tree ... Fix up trivial conflicts: - arch/arm/mach-ep93xx/dma-m2p.c (deleted) - drivers/gpio/gpio-ep93xx.c (renamed and context nearby) - drivers/net/r8169.c (just context changes)
2011-07-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (145 commits) bnx2x: use pci_pcie_cap() bnx2x: fix bnx2x_stop_on_error flow in bnx2x_sp_rtnl_task bnx2x: enable internal target-read for 57712 and up only bnx2x: count statistic ramrods on EQ to prevent MC assert bnx2x: fix loopback for non 10G link bnx2x: dcb - send all unmapped priorities to same COS as L2 iwlwifi: Fix build with CONFIG_PM disabled. gre: fix improper error handling ipv4: use RT_TOS after some rt_tos conversions via-velocity: remove duplicated #include qlge: remove duplicated #include igb: remove duplicated #include can: c_can: remove duplicated #include bnad: remove duplicated #include net: allow netif_carrier to be called safely from IRQ bna: Header File Consolidation bna: HW Error Counter Fix bna: Add HW Semaphore Unlock Logic bna: IOC Event Name Change bna: Mboxq Flush When IOC Disabled ...
2011-07-23fs/9p: add 9P2000.L unlinkat operationAneesh Kumar K.V
unlinkat - Remove a directory entry size[4] Tunlinkat tag[2] dirfid[4] name[s] flag[4] size[4] Runlinkat tag[2] older Tremove have the below request format size[4] Tremove tag[2] fid[4] The remove message is used to remove a directory entry either file or directory The remove opreation is actually a directory opertation and should ideally have dirfid, if not we cannot represent the fid on server with anything other than name. We will have to derive the directory name from fid in the Tremove request. NOTE: The operation doesn't clunk the unlink fid. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-07-23fs/9p: add 9P2000.L renameat operationAneesh Kumar K.V
renameat - change name of file or directory size[4] Trenameat tag[2] olddirfid[4] oldname[s] newdirfid[4] newname[s] size[4] Rrenameat tag[2] older Trename have the below request format size[4] Trename tag[2] fid[4] newdirfid[4] name[s] The rename message is used to change the name of a file, possibly moving it to a new directory. The rename opreation is actually a directory opertation and should ideally have olddirfid, if not we cannot represent the fid on server with anything other than name. We will have to derive the old directory name from fid in the Trename request. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-07-23fs/9p: Clean-up get_protocol_version() to use strcmpPrem Karat
Signed-off-by: Prem Karat <prem.karat@linux.vnet.ibm.com> Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2011-07-23net/9p: Remove structure not used in the codeAneesh Kumar K.V
