path: root/include/net
2005-12-27[IPV6] mcast: Fix multiple issues in MLDv2 reports.David L Stevens
The below "jumbo" patch fixes the following problems in MLDv2. 1) Add necessary "ntohs" to recent "pskb_may_pull" check [breaks all nonzero source queries on little-endian (!)] 2) Add locking to source filter list [resend of prior patch] 3) fix "mld_marksources()" to a) send nothing when all queried sources are excluded b) send full exclude report when source queried sources are not excluded c) don't schedule a timer when there's nothing to report NOTE: RFC 3810 specifies the source list should be saved and each source reported individually as an IS_IN. This is an obvious DOS path, requiring the host to store and then multicast as many sources as are queried (e.g., millions...). This alternative sends a full, relevant report that's limited to number of sources present on the machine. 4) fix "add_grec()" to send empty-source records when it should The original check doesn't account for a non-empty source list with all sources inactive; the new code keeps that short-circuit case, and also generates the group header with an empty list if needed. 5) fix mca_crcount decrement to be after add_grec(), which needs its original value These issues (other than item #1 ;-) ) were all found by Yan Zheng, much thanks! Signed-off-by: David L Stevens <dlstevens@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-12-21[IPV6]: Defer IPv6 device initialization until the link becomes ready.YOSHIFUJI Hideaki
NETDEV_UP might be sent even if the link attached to the interface was not ready. DAD does not make sense in such case, so we won't do so. After interface Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2005-12-19[IPSEC]: Perform SA switchover immediately.David S. Miller
When we insert a new xfrm_state which potentially subsumes an existing one, make sure all cached bundles are flushed so that the new SA is used immediately. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-12-05[DECNET]: add memory buffer settings Steven Whitehouse
The patch (originally from Steve) simply adds memory buffer settings to DECnet similar to those in TCP. Signed-off-by: Patrick Caulfield <patrick@tykepenguin.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-22[IPV4]: Fix secondary IP addresses after promotionJamal Hadi Salim
This patch fixes the problem with promoting aliases when: a) a single primary and > 1 secondary addresses b) multiple primary addresses each with at least one secondary address Based on earlier efforts from Brian Pomerantz <bapper@piratehaven.org>, Patrick McHardy <kaber@trash.net> and Thomas Graf <tgraf@suug.ch> Signed-off-by: Jamal Hadi Salim <hadi@cyberus.ca> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-20Merge git://git.skbuff.net/gitroot/yoshfuji/linux-2.6.14+advapi-fix/David S. Miller
2005-11-20[IPV6]: Fix sending extension headers before and including routing header.YOSHIFUJI Hideaki
Based on suggestion from Masahide Nakamura <nakam@linux-ipv6.org>. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
2005-11-18[PATCH] git-netdev-all-ieee80211_get_payload-warning-fixAndrew Morton
include/net/ieee80211.h: In function `ieee80211_get_payload': include/net/ieee80211.h:1046: warning: control reaches end of non-void function Cc: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-11-15[TCP]: More spelling fixes.Stephen Hemminger
From Joe Perches Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-14[LLC]: Fix typoJochen Friedrich
Signed-off-by: Jochen Friedrich <jochen@scram.de> Acked-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-11[SCTP]: Include ulpevents in socket receive buffer accounting.Neil Horman
Also introduces a sysctl option to configure the receive buffer accounting policy to be either at socket or association level. Default is all the associations on the same socket share the receive buffer. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-11[SCTP]: Fix ia64 NaT consumption fault with sctp_sideffect commands.Vladislav Yasevich
On ia64, it is possible to get NaT Consumption Fault and a kernel panic when initializing sctp sideeffect commands arguments. The union sctp_arg_t contains different sized elements and when loading a smaller sized element (32 or 16 bits), it is possible for a speculative load to fail and result in a NaT bit set which causes a kernel crash. The easy way to get around it is to load the largerst member of the union. Signed-off-by: Vladislav Yasevich <vladislav.yasevich@hp.com> Signed-off-by: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-11[SCTP]: Remove timeouts[] array from sctp_endpoint.Vladislav Yasevich
The socket level timeout values are maintained in sctp_sock and association level timeouts are in sctp_association. So there is no need for ep->timeouts. Signed-off-by: Vladislav Yasevich <vladislav.yasevich@hp.com> Signed-off-by: Sridhar Samudrala <sri@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-10[TCP]: speed up SACK processingStephen Hemminger
Use "hints" to speed up the SACK processing. Various forms of this have been used by TCP developers (Web100, STCP, BIC) to avoid the 2x linear search of outstanding segments. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-10[TCP]: spelling fixesStephen Hemminger
Minor spelling fixes for TCP code. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-10[TCP]: Appropriate Byte Count supportStephen Hemminger
This is an updated version of the RFC3465 ABC patch originally for Linux 2.6.11-rc4 by Yee-Ting Li. ABC is a way of counting bytes ack'd rather than packets when updating congestion control. The orignal ABC described in the RFC applied to a Reno style algorithm. For advanced congestion control there is little change after leaving slow start. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-10[TCP]: add tcp_slow_start helperStephen Hemminger
Move all the code that does linear TCP slowstart to one inline function to ease later patch to add ABC support. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-10[TCP]: fix congestion window update when using TSO deferalStephen Hemminger
TCP peformance with TSO over networks with delay is awful. On a 100Mbit link with 150ms delay, we get 4Mbits/sec with TSO and 50Mbits/sec without TSO. The problem is with TSO, we intentionally do not keep the maximum number of packets in flight to fill the window, we hold out to until we can send a MSS chunk. But, we also don't update the congestion window unless we have filled, as per RFC2861. This patch replaces the check for the congestion window being full with something smarter that accounts for TSO. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-10[NET]: Detect hardware rx checksum faults correctlyHerbert Xu
Here is the patch that introduces the generic skb_checksum_complete which also checks for hardware RX checksum faults. If that happens, it'll call netdev_rx_csum_fault which currently prints out a stack trace with the device name. In future it can turn off RX checksum. I've converted every spot under net/ that does RX checksum checks to use skb_checksum_complete or __skb_checksum_complete with the exceptions of: * Those places where checksums are done bit by bit. These will call netdev_rx_csum_fault directly. * The following have not been completely checked/converted: ipmr ip_vs netfilter dccp This patch is based on patches and suggestions from Stephen Hemminger and David S. Miller. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-10[NETLINK]: Generic netlink familyThomas Graf
The generic netlink family builds on top of netlink and provides simplifies access for the less demanding netlink users. It solves the problem of protocol numbers running out by introducing a so called controller taking care of id management and name resolving. Generic netlink modules register themself after filling out their id card (struct genl_family), after successful registration the modules are able to register callbacks to command numbers by filling out a struct genl_ops and calling genl_register_op(). The registered callbacks are invoked with attributes parsed making life of simple modules a lot easier. Although generic netlink modules can request static identifiers, it is recommended to use GENL_ID_GENERATE and to let the controller assign a unique identifier to the module. Userspace applications will then ask the controller and lookup the idenfier by the module name. Due to the current multicast implementation of netlink, the number of generic netlink modules is restricted to 1024 to avoid wasting memory for the per socket multiacst subscription bitmask. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-10[NETLINK]: Generic netlink receive queue processorThomas Graf
Introduces netlink_run_queue() to handle the receive queue of a netlink socket in a generic way. Processes as much as there was in the queue upon entry and invokes a callback function for each netlink message found. The callback function may refuse a message by returning a negative error code but setting the error pointer to 0 in which case netlink_run_queue() will return with a qlen != 0. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-10[NETLINK]: Type-safe netlink messages/attributes interfaceThomas Graf
Introduces a new type-safe interface for netlink message and attributes handling. The interface is fully binary compatible with the old interface towards userspace. Besides type safety, this interface features attribute validation capabilities, simplified message contstruction, and documentation. The resulting netlink code should be smaller, less error prone and easier to understand. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-09[NETFILTER]: Add nf_conntrack subsystem.Yasuyuki Kozakai
The existing connection tracking subsystem in netfilter can only handle ipv4. There were basically two choices present to add connection tracking support for ipv6. We could either duplicate all of the ipv4 connection tracking code into an ipv6 counterpart, or (the choice taken by these patches) we could design a generic layer that could handle both ipv4 and ipv6 and thus requiring only one sub-protocol (TCP, UDP, etc.) connection tracking helper module to be written. In fact nf_conntrack is capable of working with any layer 3 protocol. The existing ipv4 specific conntrack code could also not deal with the pecularities of doing connection tracking on ipv6, which is also cured here. For example, these issues include: 1) ICMPv6 handling, which is used for neighbour discovery in ipv6 thus some messages such as these should not participate in connection tracking since effectively they are like ARP messages 2) fragmentation must be handled differently in ipv6, because the simplistic "defrag, connection track and NAT, refrag" (which the existing ipv4 connection tracking does) approach simply isn't feasible in ipv6 3) ipv6 extension header parsing must occur at the correct spots before and after connection tracking decisions, and there were no provisions for this in the existing connection tracking design 4) ipv6 has no need for stateful NAT The ipv4 specific conntrack layer is kept around, until all of the ipv4 specific conntrack helpers are ported over to nf_conntrack and it is feature complete. Once that occurs, the old conntrack stuff will get placed into the feature-removal-schedule and we will fully kill it off 6 months later. Signed-off-by: Yasuyuki Kozakai <yasuyuki.kozakai@toshiba.co.jp> Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2005-11-09Merge branch 'upstream-linus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6
2005-11-09ieee80211: cleanup crypto list handling, other minor cleanups.Christoph Hellwig
2005-11-09Merge rsync://bughost.org/repos/ieee80211-delta/Jeff Garzik
2005-11-08[Bluetooth]: Remove the usage of /proc completelyMarcel Holtmann
This patch removes all relics of the /proc usage from the Bluetooth subsystem core and its upper layers. All the previous information are now available via /sys/class/bluetooth through appropriate functions. Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-08[Bluetooth]: Add endian annotations to the coreMarcel Holtmann
This patch adds the endian annotations to the Bluetooth core. Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-08[NET]: sk_add_backlog convert from macro to inlineStephen Hemminger
There is no reason for sk_add_backlog to be a macro. It can just be an inline function and get type checking. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-08[IPV6]: Make ipv6_addr_type() more generic so that we can use it for source ↵YOSHIFUJI Hideaki
address selection. Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-08[IPV6]: Put addr_diff() into common header for future use.YOSHIFUJI Hideaki
2005-11-07Update version ieee80211 stamp to 1.1.7James Ketrenos
2005-11-05Merge branch 'red' of 84.73.165.173:/home/tgr/repos/net-2.6Arnaldo Carvalho de Melo
2005-11-05[TCP/DCCP]: Randomize port selectionStephen Hemminger
This patch randomizes the port selected on bind() for connections to help with possible security attacks. It should also be faster in most cases because there is no need for a global lock. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2005-11-05[NET]: Introduce INET_ECN_set_ce() functionThomas Graf
Changes IP_ECN_set_ce() and IP6_ECN_set_ce() to return 0 if the CE bits could not bet set because none of the ECT bits are set or 1 if the CE bits are already set or have been successfully set. Introduces INET_ECN_set_ce(skb) to enable CE bits for all supported protocols. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2005-11-05[PKT_SCHED]: Generic RED layerThomas Graf
Extracts the RED algorithm from sch_red.c and puts it into include/net/red.h for use by other RED based modules. The statistics are extended to be more fine grained in order to differ between probability/forced marks/drops. We now reset the average queue length when setting new parameters, leaving it might result in an unreasonable qavg for a while depending on the value of W. Signed-off-by: Thomas Graf <tgraf@suug.ch> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2005-10-29Merge branch 'upstream-linus' of ↵Linus Torvalds
2005-10-28Merge master.kernel.org:/pub/scm/linux/kernel/git/sridhar/lksctp-2.6Arnaldo Carvalho de Melo
2005-10-28Merge branch 'master'Jeff Garzik
2005-10-28[SCTP] Rename SCTP specific control message flags.Ivan Skytte Jorgensen
Rename SCTP specific control message flags to use SCTP_ prefix rather than MSG_ prefix as per the latest sctp sockets API draft. Signed-off-by: Ivan Skytte Jorgensen <isj-sctp@i1.dk> Signed-off-by: Sridhar Samudrala <sri@us.ibm.com>
2005-10-28drivers/net: Remove pointless checks for NULL prior to calling kfree()Jesper Juhl
2005-10-28Merge master.kernel.org:/pub/scm/linux/kernel/git/holtmann/bluetooth-2.6Arnaldo Carvalho de Melo
2005-10-28[Bluetooth] Make more functions staticMarcel Holtmann
This patch makes another bunch of functions static. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2005-10-28[Bluetooth] Move CRC table into RFCOMM coreMarcel Holtmann
This patch moves rfcomm_crc_table[] into the RFCOMM core, because there is no need to keep it in a separate file. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2005-10-28Merge branch 'upstream' of ↵Linus Torvalds
2005-10-28Merge master.kernel.org:/pub/scm/linux/kernel/git/acme/net-2.6.15Linus Torvalds
2005-10-28[PATCH] gfp_t: net/*Al Viro
2005-10-26Merge branch 'master'Jeff Garzik
2005-10-26[IPSEC]: Kill obsolete get_mss functionHerbert Xu
Now that we've switched over to storing MTUs in the xfrm_dst entries, we no longer need the dst's get_mss methods. This patch gets rid of them. It also documents the fact that our MTU calculation is not optimal for ESP. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
2005-10-25[LLC]: Strip RIF flag from source MAC addressJochen Friedrich
Signed-off-by: Jochen Friedrich <jochen@scram.de> Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com>
