path: root/include/net
2009-06-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: bnx2: Fix the behavior of ethtool when ONBOOT=no qla3xxx: Don't sleep while holding lock. qla3xxx: Give the PHY time to come out of reset. ipv4 routing: Ensure that route cache entries are usable and reclaimable with caching is off net: Move rx skb_orphan call to where needed ipv6: Use correct data types for ICMPv6 type and code net: let KS8842 driver depend on HAS_IOMEM can: let SJA1000 driver depend on HAS_IOMEM netxen: fix firmware init handshake netxen: fix build with without CONFIG_PM netfilter: xt_rateest: fix comparison with self netfilter: xt_quota: fix incomplete initialization netfilter: nf_log: fix direct userspace memory access in proc handler netfilter: fix some sparse endianess warnings netfilter: nf_conntrack: fix conntrack lookup race netfilter: nf_conntrack: fix confirmation race condition netfilter: nf_conntrack: death_by_timeout() fix
2009-06-23net: Move rx skb_orphan call to where neededHerbert Xu
In order to get the tun driver to account packets, we need to be able to receive packets with destructors set. To be on the safe side, I added an skb_orphan call for all protocols by default since some of them (IP in particular) cannot handle receiving packets destructors properly. Now it seems that at least one protocol (CAN) expects to be able to pass skb->sk through the rx path without getting clobbered. So this patch attempts to fix this properly by moving the skb_orphan call to where it's actually needed. In particular, I've added it to skb_set_owner_[rw] which is what most users of skb->destructor call. This is actually an improvement for tun too since it means that we only give back the amount charged to the socket when the skb is passed to another socket that will also be charged accordingly. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Tested-by: Oliver Hartkopp <olver@hartkopp.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-23ipv6: Use correct data types for ICMPv6 type and codeBrian Haley
Change all the code that deals directly with ICMPv6 type and code values to use u8 instead of a signed int as that's the actual data type. Signed-off-by: Brian Haley <brian.haley@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-22Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (43 commits) via-velocity: Fix velocity driver unmapping incorrect size. mlx4_en: Remove redundant refill code on RX mlx4_en: Removed redundant check on lso header size mlx4_en: Cancel port_up check in transmit function mlx4_en: using stop/start_all_queues mlx4_en: Removed redundant skb->len check mlx4_en: Counting all the dropped packets on the TX side usbnet cdc_subset: fix issues talking to PXA gadgets Net: qla3xxx, remove sleeping in atomic ipv4: fix NULL pointer + success return in route lookup path isdn: clean up documentation index cfg80211: validate station settings cfg80211: allow setting station parameters in mesh cfg80211: allow adding/deleting stations on mesh ath5k: fix beacon_int handling MAINTAINERS: Fix Atheros pattern paths ath9k: restore PS mode, before we put the chip into FULL SLEEP state. ath9k: wait for beacon frame along with CAB acer-wmi: fix rfkill conversion ath5k: avoid PCI FATAL interrupts by restoring RETRY_TIMEOUT disabling ...
2009-06-19af_iucv: Return -EAGAIN if iucv msg limit is exceededHendrik Brueckner
If the iucv message limit for a communication path is exceeded, sendmsg() returns -EAGAIN instead of -EPIPE. The calling application can then handle this error situtation, e.g. to try again after waiting some time. For blocking sockets, sendmsg() waits up to the socket timeout before returning -EAGAIN. For the new wait condition, a macro has been introduced and the iucv_sock_wait_state() has been refactored to this macro. Signed-off-by: Hendrik Brueckner <brueckner@linux.vnet.ibm.com> Signed-off-by: Ursula Braun <ursula.braun@de.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-18Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (55 commits) netxen: fix tx ring accounting netxen: fix detection of cut-thru firmware mode forcedeth: fix dma api mismatches atm: sk_wmem_alloc initial value is one net: correct off-by-one write allocations reports via-velocity : fix no link detection on boot Net / e100: Fix suspend of devices that cannot be power managed TI DaVinci EMAC : Fix rmmod error net: group address list and its count ipv4: Fix fib_trie rebalancing, part 2 pkt_sched: Update drops stats in act_police sky2: version 1.23 sky2: add GRO support sky2: skb recycling sky2: reduce default transmit ring sky2: receive counter update sky2: fix shutdown synchronization sky2: PCI irq issues sky2: more receive shutdown sky2: turn off pause during shutdown ... Manually fix trivial conflict in net/core/skbuff.c due to kmemcheck
2009-06-17net: sk_wmem_alloc has initial value of one, not zeroEric Dumazet
commit 2b85a34e911bf483c27cfdd124aeb1605145dc80 (net: No more expensive sock_hold()/sock_put() on each tx) changed initial sk_wmem_alloc value. Some protocols check sk_wmem_alloc value to determine if a timer must delay socket deallocation. We must take care of the sk_wmem_alloc value being one instead of zero when no write allocations are pending. Reported by Ingo Molnar, and full diagnostic from David Miller. This patch introduces three helpers to get read/write allocations and a followup patch will use these helpers to report correct write allocations to user. Reported-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-16Merge branch 'for-linus2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/vegard/kmemcheck * 'for-linus2' of git://git.kernel.org/pub/scm/linux/kernel/git/vegard/kmemcheck: (39 commits) signal: fix __send_signal() false positive kmemcheck warning fs: fix do_mount_root() false positive kmemcheck warning fs: introduce __getname_gfp() trace: annotate bitfields in struct ring_buffer_event net: annotate struct sock bitfield c2port: annotate bitfield for kmemcheck net: annotate inet_timewait_sock bitfields ieee1394/csr1212: fix false positive kmemcheck report ieee1394: annotate bitfield net: annotate bitfields in struct inet_sock net: use kmemcheck bitfields API for skbuff kmemcheck: introduce bitfield API kmemcheck: add opcode self-testing at boot x86: unify pte_hidden x86: make _PAGE_HIDDEN conditional kmemcheck: make kconfig accessible for other architectures kmemcheck: enable in the x86 Kconfig kmemcheck: add hooks for the page allocator kmemcheck: add hooks for page- and sg-dma-mappings kmemcheck: don't track page tables ...
2009-06-16x25: Fix sleep from timer on socket destroy.David S. Miller
If socket destuction gets delayed to a timer, we try to lock_sock() from that timer which won't work. Use bh_lock_sock() in that case. Signed-off-by: David S. Miller <davem@davemloft.net> Tested-by: Ingo Molnar <mingo@elte.hu>
2009-06-15net: annotate struct sock bitfieldVegard Nossum
2009/2/24 Ingo Molnar <mingo@elte.hu>: > ok, this is the last warning i have from today's overnight -tip > testruns - a 32-bit system warning in sock_init_data(): > > [ 2.610389] NET: Registered protocol family 16 > [ 2.616138] initcall netlink_proto_init+0x0/0x170 returned 0 after 7812 usecs > [ 2.620010] WARNING: kmemcheck: Caught 32-bit read from uninitialized memory (f642c184) > [ 2.624002] 010000000200000000000000604990c000000000000000000000000000000000 > [ 2.634076] i i i i i i u u i i i i i i i i i i i i i i i i i i i i i i i i > [ 2.641038] ^ > [ 2.643376] > [ 2.644004] Pid: 1, comm: swapper Not tainted (2.6.29-rc6-tip-01751-g4d1c22c-dirty #885) > [ 2.648003] EIP: 0060:[<c07141a1>] EFLAGS: 00010282 CPU: 0 > [ 2.652008] EIP is at sock_init_data+0xa1/0x190 > [ 2.656003] EAX: 0001a800 EBX: f6836c00 ECX: 00463000 EDX: c0e46fe0 > [ 2.660003] ESI: f642c180 EDI: c0b83088 EBP: f6863ed8 ESP: c0c412ec > [ 2.664003] DS: 007b ES: 007b FS: 00d8 GS: 00e0 SS: 0068 > [ 2.668003] CR0: 8005003b CR2: f682c400 CR3: 00b91000 CR4: 000006f0 > [ 2.672003] DR0: 00000000 DR1: 00000000 DR2: 00000000 DR3: 00000000 > [ 2.676003] DR6: ffff4ff0 DR7: 00000400 > [ 2.680002] [<c07423e5>] __netlink_create+0x35/0xa0 > [ 2.684002] [<c07443cc>] netlink_kernel_create+0x4c/0x140 > [ 2.688002] [<c072755e>] rtnetlink_net_init+0x1e/0x40 > [ 2.696002] [<c071b601>] register_pernet_operations+0x11/0x30 > [ 2.700002] [<c071b72c>] register_pernet_subsys+0x1c/0x30 > [ 2.704002] [<c0bf3c8c>] rtnetlink_init+0x4c/0x100 > [ 2.708002] [<c0bf4669>] netlink_proto_init+0x159/0x170 > [ 2.712002] [<c0101124>] do_one_initcall+0x24/0x150 > [ 2.716002] [<c0bbf3c7>] do_initcalls+0x27/0x40 > [ 2.723201] [<c0bbf3fc>] do_basic_setup+0x1c/0x20 > [ 2.728002] [<c0bbfb8a>] kernel_init+0x5a/0xa0 > [ 2.732002] [<c0103e47>] kernel_thread_helper+0x7/0x10 > [ 2.736002] [<ffffffff>] 0xffffffff We fix this false positive by annotating the bitfield in struct sock. Reported-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Vegard Nossum <vegard.nossum@gmail.com>
2009-06-15net: annotate inet_timewait_sock bitfieldsVegard Nossum
The use of bitfields here would lead to false positive warnings with kmemcheck. Silence them. (Additionally, one erroneous comment related to the bitfield was also fixed.) Signed-off-by: Vegard Nossum <vegard.nossum@gmail.com>
2009-06-15net: annotate bitfields in struct inet_sockVegard Nossum
2009-06-15pkt_sched: Rename PSCHED_US2NS and PSCHED_NS2USJarek Poplawski
Let's use TICKS instead of US, so PSCHED_TICKS2NS and PSCHED_NS2TICKS (like in PSCHED_TICKS_PER_SEC already) to avoid misleading. Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-13netfilter: conntrack: optional reliable conntrack event deliveryPablo Neira Ayuso
This patch improves ctnetlink event reliability if one broadcast listener has set the NETLINK_BROADCAST_ERROR socket option. The logic is the following: if an event delivery fails, we keep the undelivered events in the missed event cache. Once the next packet arrives, we add the new events (if any) to the missed events in the cache and we try a new delivery, and so on. Thus, if ctnetlink fails to deliver an event, we try to deliver them once we see a new packet. Therefore, we may lose state transitions but the userspace process gets in sync at some point. At worst case, if no events were delivered to userspace, we make sure that destroy events are successfully delivered. Basically, if ctnetlink fails to deliver the destroy event, we remove the conntrack entry from the hashes and we insert them in the dying list, which contains inactive entries. Then, the conntrack timer is added with an extra grace timeout of random32() % 15 seconds to trigger the event again (this grace timeout is tunable via /proc). The use of a limited random timeout value allows distributing the "destroy" resends, thus, avoiding accumulating lots "destroy" events at the same time. Event delivery may re-order but we can identify them by means of the tuple plus the conntrack ID. The maximum number of conntrack entries (active or inactive) is still handled by nf_conntrack_max. Thus, we may start dropping packets at some point if we accumulate a lot of inactive conntrack entries that did not successfully report the destroy event to userspace. During my stress tests consisting of setting a very small buffer of 2048 bytes for conntrackd and the NETLINK_BROADCAST_ERROR socket flag, and generating lots of very small connections, I noticed very few destroy entries on the fly waiting to be resend. A simple way to test this patch consist of creating a lot of entries, set a very small Netlink buffer in conntrackd (+ a patch which is not in the git tree to set the BROADCAST_ERROR flag) and invoke `conntrack -F'. For expectations, no changes are introduced in this patch. Currently, event delivery is only done for new expectations (no events from expectation expiration, removal and confirmation). In that case, they need a per-expectation event cache to implement the same idea that is exposed in this patch. This patch can be useful to provide reliable flow-accouting. We still have to add a new conntrack extension to store the creation and destroy time. Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Patrick McHardy <kaber@trash.net>
2009-06-13netfilter: conntrack: move helper destruction to nf_ct_helper_destroy()Pablo Neira Ayuso
This patch moves the helper destruction to a function that lives in nf_conntrack_helper.c. This new function is used in the patch to add ctnetlink reliable event delivery. Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Patrick McHardy <kaber@trash.net>
2009-06-13netfilter: conntrack: move event caching to conntrack extension infrastructurePablo Neira Ayuso
This patch reworks the per-cpu event caching to use the conntrack extension infrastructure. The main drawback is that we consume more memory per conntrack if event delivery is enabled. This patch is required by the reliable event delivery that follows to this patch. BTW, this patch allows you to enable/disable event delivery via /proc/sys/net/netfilter/nf_conntrack_events in runtime, although you can still disable event caching as compilation option. Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Patrick McHardy <kaber@trash.net>
2009-06-11Merge branch 'master' of ↵Patrick McHardy
2009-06-11Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/holtmann/bluetooth-next-2.6
2009-06-11net: No more expensive sock_hold()/sock_put() on each txEric Dumazet
One of the problem with sock memory accounting is it uses a pair of sock_hold()/sock_put() for each transmitted packet. This slows down bidirectional flows because the receive path also needs to take a refcount on socket and might use a different cpu than transmit path or transmit completion path. So these two atomic operations also trigger cache line bounces. We can see this in tx or tx/rx workloads (media gateways for example), where sock_wfree() can be in top five functions in profiles. We use this sock_hold()/sock_put() so that sock freeing is delayed until all tx packets are completed. As we also update sk_wmem_alloc, we could offset sk_wmem_alloc by one unit at init time, until sk_free() is called. Once sk_free() is called, we atomic_dec_and_test(sk_wmem_alloc) to decrement initial offset and atomicaly check if any packets are in flight. skb_set_owner_w() doesnt call sock_hold() anymore sock_wfree() doesnt call sock_put() anymore, but check if sk_wmem_alloc reached 0 to perform the final freeing. Drawback is that a skb->truesize error could lead to unfreeable sockets, or even worse, prematurely calling __sk_free() on a live socket. Nice speedups on SMP. tbench for example, going from 2691 MB/s to 2711 MB/s on my 8 cpu dev machine, even if tbench was not really hitting sk_refcnt contention point. 5 % speedup on a UDP transmit workload (depends on number of flows), lowering TX completion cpu usage. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-10mac80211: do not pass PS frames out of mac80211 againJohannes Berg
In order to handle powersave frames properly we had needed to pass these out to the device queues again, and introduce the skb->requeue bit. This, however, also has unnecessary overhead by needing to 'clean up' already tried frames, and this clean-up code is also buggy when software encryption is used. Instead of sending the frames via the master netdev queue again, simply put them into the pending queue. This also fixes a problem where frames for that particular station could be reordered when some were still on the software queues and older ones are re-injected into the software queue after them. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-06-10netfilter: nf_conntrack: use per-conntrack locks for protocol dataPatrick McHardy
Introduce per-conntrack locks and use them instead of the global protocol locks to avoid contention. Especially tcp_lock shows up very high in profiles on larger machines. This will also allow to simplify the upcoming reliable event delivery patches. Signed-off-by: Patrick McHardy <kaber@trash.net>
2009-06-09net: add NL802154 interface for configuration of 802.15.4 devicesSergey Lapin
Add a netlink interface for configuration of IEEE 802.15.4 device. Also this interface specifies events notification sent by devices towards higher layers. Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Signed-off-by: Sergey Lapin <slapin@ossfans.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-09net: add IEEE 802.15.4 socket family implementationSergey Lapin
Add support for communication over IEEE 802.15.4 networks. This implementation is neither certified nor complete, but aims to that goal. This commit contains only the socket interface for communication over IEEE 802.15.4 networks. One can either send RAW datagrams or use SOCK_DGRAM to encapsulate data inside normal IEEE 802.15.4 packets. Configuration interface, drivers and software MAC 802.15.4 implementation will follow. Initial implementation was done by Maxim Gorbachyov, Maxim Osipov and Pavel Smolensky as a research project at Siemens AG. Later the stack was heavily reworked to better suit the linux networking model, and is now maitained as an open project partially sponsored by Siemens. Signed-off-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Signed-off-by: Sergey Lapin <slapin@ossfans.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-09pkt_sched: Change PSCHED_SHIFT from 10 to 6Jarek Poplawski
Change PSCHED_SHIFT from 10 to 6 to increase schedulers time resolution. This will increase 16x a number of (internal) ticks per nanosecond, and is needed to improve accuracy of schedulers based on rate tables, like HTB, TBF or CBQ, with rates above 100Mbit. It is assumed this change is safe for 32bit accounting of time diffs up to 2 minutes, which should be enough for common use (extremely low rate values may overflow, so get inaccurate instead). To make full use of this change an updated iproute2 will be needed. (But using older iproute2 should be safe too.) This change breaks ticks - microseconds similarity, so some minor code fixes might be needed. It is also planned to change naming adequately eg. to PSCHED_TICKS2NS() etc. in the near future. Reported-by: Antonio Almeida <vexwek@gmail.com> Tested-by: Antonio Almeida <vexwek@gmail.com> Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-09pkt_sched: Use PSCHED_SHIFT in PSCHED time conversionJarek Poplawski
Use PSCHED_SHIFT constant instead of '10' in PSCHED_US2NS() and PSCHED_NS2US() macros to enable changing this value later. Additionally use PSCHED_SHIFT in sch_hfsc SM_SHIFT and ISM_SHIFT definitions. This part of the patch is based on feedback from Patrick McHardy <kaber@trash.net>. Reported-by: Antonio Almeida <vexwek@gmail.com> Tested-by: Antonio Almeida <vexwek@gmail.com> Signed-off-by: Jarek Poplawski <jarkao2@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-08bluetooth: Kill skb_frags_no(), unused.David S. Miller
Furthermore, it twiddles with the details of SKB list handling directly, which we're trying to eliminate. Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-08netfilter: nf_ct_icmp: keep the ICMP ct entries longerJan Kasprzak
Current conntrack code kills the ICMP conntrack entry as soon as the first reply is received. This is incorrect, as we then see only the first ICMP echo reply out of several possible duplicates as ESTABLISHED, while the rest will be INVALID. Also this unnecessarily increases the conntrackd traffic on H-A firewalls. Make all the ICMP conntrack entries (including the replied ones) last for the default of nf_conntrack_icmp{,v6}_timeout seconds. Signed-off-by: Jan "Yenya" Kasprzak <kas@fi.muni.cz> Signed-off-by: Patrick McHardy <kaber@trash.net>
2009-06-08Bluetooth: Add native RFKILL soft-switch support for all devicesMarcel Holtmann
With the re-write of the RFKILL subsystem it is now possible to easily integrate RFKILL soft-switch support into the Bluetooth subsystem. All Bluetooth devices will now get automatically RFKILL support. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2009-06-08Bluetooth: Remove pointless endian conversion helpersMarcel Holtmann
The Bluetooth source uses some endian conversion helpers, that in the end translate to kernel standard routines. So remove this obfuscation since it is fully pointless. Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2009-06-08Bluetooth: Add basic constants for L2CAP ERTM support and use themMarcel Holtmann
This adds the basic constants required to add support for L2CAP Enhanced Retransmission feature. Based on a patch from Nathan Holstein <nathan@lampreynetworks.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2009-06-08Bluetooth: Use macro for L2CAP hint mask on receiving config requestGustavo F. Padovan
Using the L2CAP_CONF_HINT macro is easier to understand than using a hardcoded 0x80 value. Signed-off-by: Gustavo F. Padovan <gustavo@las.ic.unicamp.br> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2009-06-08Bluetooth: Use macros for L2CAP channel identifiersGustavo F. Padovan
Use macros instead of hardcoded numbers to make the L2CAP source code more readable. Signed-off-by: Gustavo F. Padovan <gustavo@las.ic.unicamp.br> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2009-06-07Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6
2009-06-03cfg80211: add rfkill supportJohannes Berg
To be easier on drivers and users, have cfg80211 register an rfkill structure that drivers can access. When soft-killed, simply take down all interfaces; when hard-killed the driver needs to notify us and we will take down the interfaces after the fact. While rfkilled, interfaces cannot be set UP. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-06-03cfg80211: move txpower wext from mac80211Johannes Berg
This patch introduces new cfg80211 API to set the TX power via cfg80211, puts the wext code into cfg80211 and updates mac80211 to use all that. The -ENETDOWN bits are a hack but will go away soon. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-06-03rfkill: rewriteJohannes Berg
This patch completely rewrites the rfkill core to address the following deficiencies: * all rfkill drivers need to implement polling where necessary rather than having one central implementation * updating the rfkill state cannot be done from arbitrary contexts, forcing drivers to use schedule_work and requiring lots of code * rfkill drivers need to keep track of soft/hard blocked internally -- the core should do this * the rfkill API has many unexpected quirks, for example being asymmetric wrt. alloc/free and register/unregister * rfkill can call back into a driver from within a function the driver called -- this is prone to deadlocks and generally should be avoided * rfkill-input pointlessly is a separate module * drivers need to #ifdef rfkill functions (unless they want to depend on or select RFKILL) -- rfkill should provide inlines that do nothing if it isn't compiled in * the rfkill structure is not opaque -- drivers need to initialise it correctly (lots of sanity checking code required) -- instead force drivers to pass the right variables to rfkill_alloc() * the documentation is hard to read because it always assumes the reader is completely clueless and contains way TOO MANY CAPS * the rfkill code needlessly uses a lot of locks and atomic operations in locked sections * fix LED trigger to actually change the LED when the radio state changes -- this wasn't done before Tested-by: Alan Jenkins <alan-jenkins@tuffmail.co.uk> Signed-off-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> [thinkpad] Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-06-03mac80211: deprecate conf.beacon_int properlyJohannes Berg
Ivo has updated the driver to no longer use the change flag, so we can remove that, but rt2x00 and ath5k still use the actual value so let's mark it as deprecated too. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-06-03sctp: support non-blocking version of the new sctp_connectx() APIVlad Yasevich
Prior implementation of the new sctp_connectx() call that returns an association ID did not work correctly on non-blocking socket. This is because we could not return both a EINPROGRESS error and an association id. This is a new implementation that supports this. Originally from Ivan Skytte Jørgensen <isj-sctp@i1.dk Signed-off-by: Ivan Skytte Jørgensen <isj-sctp@i1.dk Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
2009-06-03sctp: fix to choose alternate destination when retransmit ASCONF chunkWei Yongjun
RFC 5061 Section 5.1 ASCONF Chunk Procedures said: B4) Re-transmit the ASCONF Chunk last sent and if possible choose an alternate destination address (please refer to [RFC4960], Section 6.4.1). An endpoint MUST NOT add new parameters to this chunk; it MUST be the same (including its Sequence Number) as the last ASCONF sent. An endpoint MAY, however, bundle an additional ASCONF with new ASCONF parameters with the next Sequence Number. For details, see Section 5.5. This patch fix to choose an alternate destination address when re-transmit the ASCONF chunk, with some dup codes cleanup. Signed-off-by: Wei Yongjun <yjwei@cn.fujitsu.com> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
2009-06-03net: skb->dst accessorsEric Dumazet
Define three accessors to get/set dst attached to a skb struct dst_entry *skb_dst(const struct sk_buff *skb) void skb_dst_set(struct sk_buff *skb, struct dst_entry *dst) void skb_dst_drop(struct sk_buff *skb) This one should replace occurrences of : dst_release(skb->dst) skb->dst = NULL; Delete skb->dst field Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-03net: skb->rtable accessorEric Dumazet
Define skb_rtable(const struct sk_buff *skb) accessor to get rtable from skb Delete skb->rtable field Setting rtable is not allowed, just set dst instead as rtable is an alias. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-03netfilter: conntrack: replace notify chain by function pointerPablo Neira Ayuso
This patch removes the notify chain infrastructure and replace it by a simple function pointer. This issue has been mentioned in the mailing list several times: the use of the notify chain adds too much overhead for something that is only used by ctnetlink. This patch also changes nfnetlink_send(). It seems that gfp_any() returns GFP_KERNEL for user-context request, like those via ctnetlink, inside the RCU read-side section which is not valid. Using GFP_KERNEL is also evil since netlink may schedule(), this leads to "scheduling while atomic" bug reports. Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2009-06-02netfilter: conntrack: simplify event caching systemPablo Neira Ayuso
This patch simplifies the conntrack event caching system by removing several events: * IPCT_[*]_VOLATILE, IPCT_HELPINFO and IPCT_NATINFO has been deleted since the have no clients. * IPCT_COUNTER_FILLING which is a leftover of the 32-bits counter days. * IPCT_REFRESH which is not of any use since we always include the timeout in the messages. After this patch, the existing events are: * IPCT_NEW, IPCT_RELATED and IPCT_DESTROY, that are used to identify addition and deletion of entries. * IPCT_STATUS, that notes that the status bits have changes, eg. IPS_SEEN_REPLY and IPS_ASSURED. * IPCT_PROTOINFO, that reports that internal protocol information has changed, eg. the TCP, DCCP and SCTP protocol state. * IPCT_HELPER, that a helper has been assigned or unassigned to this entry. * IPCT_MARK and IPCT_SECMARK, that reports that the mark has changed, this covers the case when a mark is set to zero. * IPCT_NATSEQADJ, to report that there's updates in the NAT sequence adjustment. Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2009-06-02netfilter: conntrack: remove events flags from userspace exposed filePablo Neira Ayuso
This patch moves the event flags from linux/netfilter/nf_conntrack_common.h to net/netfilter/nf_conntrack_ecache.h. This flags are not of any use from userspace. Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2009-06-02netfilter: conntrack: don't report events on module removalPablo Neira Ayuso
During the module removal there are no possible event listeners since ctnetlink must be removed before to allow removing nf_conntrack. This patch removes the event reporting for the module removal case which is not of any use in the existing code. Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2009-06-02netfilter: ctnetlink: rename tuple() by nf_ct_tuple() macro definitionPablo Neira Ayuso
This patch move the internal tuple() macro definition to the header file as nf_ct_tuple(). Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org>
2009-06-02ipv4: New multicast-all socket optionNivedita Singhvi
After some discussion offline with Christoph Lameter and David Stevens regarding multicast behaviour in Linux, I'm submitting a slightly modified patch from the one Christoph submitted earlier. This patch provides a new socket option IP_MULTICAST_ALL. In this case, default behaviour is _unchanged_ from the current Linux standard. The socket option is set by default to provide original behaviour. Sockets wishing to receive data only from multicast groups they join explicitly will need to clear this socket option. Signed-off-by: Nivedita Singhvi <niv@us.ibm.com> Signed-off-by: Christoph Lameter<cl@linux.com> Acked-by: David Stevens <dlstevens@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-27netfilter: conntrack: add support for DCCP handshake sequence to ctnetlinkPablo Neira Ayuso
This patch adds CTA_PROTOINFO_DCCP_HANDSHAKE_SEQ that exposes the u64 handshake sequence number to user-space. Signed-off-by: Pablo Neira Ayuso <pablo@netfilter.org> Signed-off-by: Patrick McHardy <kaber@trash.net>
2009-05-25Merge branch 'master' of ↵David S. Miller
2009-05-22wireless: move some utility functions from mac80211 to cfg80211Zhu Yi
The patch moves some utility functions from mac80211 to cfg80211. Because these functions are doing generic 802.11 operations so they are not mac80211 specific. The moving allows some fullmac drivers to be also benefit from these utility functions. Signed-off-by: Zhu Yi <yi.zhu@intel.com> Signed-off-by: Samuel Ortiz <samuel.ortiz@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
