[ Upstream commit b56511c15713ba6c7572e77a41f7ddba9c1053ec ]
Clang warns when one enumerated type is implicitly converted to another.
drivers/infiniband/hw/mlx4/mad.c:1811:41: warning: implicit conversion
from enumeration type 'enum mlx4_ib_qp_flags' to different enumeration
type 'enum ib_qp_create_flags' [-Wenum-conversion]
qp_init_attr.init_attr.create_flags = MLX4_IB_SRIOV_TUNNEL_QP;
drivers/infiniband/hw/mlx4/mad.c:1819:41: warning: implicit conversion
qp_init_attr.init_attr.create_flags = MLX4_IB_SRIOV_SQP;
The type mlx4_ib_qp_flags explicitly provides supplemental values to the
type ib_qp_create_flags. Make that clear to Clang by changing the
create_flags type to u32.
Reported-by: Nick Desaulniers <ndesaulniers@google.com>
Signed-off-by: Nathan Chancellor <natechancellor@gmail.com>
Signed-off-by: Jason Gunthorpe <jgg@mellanox.com>
[ Upstream commit a9018adfde809d44e71189b984fa61cc89682b5e ]
The issue is in drivers/infiniband/core/uverbs_std_types_cq.c in the
UVERBS_HANDLER(UVERBS_METHOD_CQ_CREATE) function. We check that:
if (attr.comp_vector >= attrs->ufile->device->num_comp_vectors) {
But we don't check if "attr.comp_vector" is negative. It could
potentially lead to an array underflow. My concern would be where
cq->vector is used in the create_cq() function from the cxgb4 driver.
And really "attr.comp_vector" is appears as a u32 to user space so that's
the right type to use.
Fixes: 9ee79fce3642 ("IB/core: Add completion queue (cq) object actions")
Link: https://lore.kernel.org/r/20191011133419.GA22905@mwanda
Reviewed-by: Jason Gunthorpe <jgg@mellanox.com>
commit f794809a7259dfaa3d47d90ef5a86007cf48b1ce upstream.
The upstream kernel commit cited below modified the workqueue in the
new CQ API to be bound to a specific CPU (instead of being unbound).
This caused ALL users of the new CQ API to use the same bound WQ.
Specifically, MAD handling was severely delayed when the CPU bound
to the WQ was busy handling (higher priority) interrupts.
This caused a delay in the MAD "heartbeat" response handling,
which resulted in ports being incorrectly classified as "down".
To fix this, add a new "unbound" WQ type to the new CQ API, so that users
have the option to choose either a bound WQ or an unbound WQ.
For MADs, choose the new "unbound" WQ.
Fixes: b7363e67b23e ("IB/device: Convert ib-comp-wq to be CPU-bound")
Signed-off-by: Jack Morgenstein <jackm@dev.mellanox.co.il>
Signed-off-by: Leon Romanovsky <leonro@mellanox.com>
Reviewed-by: Sagi Grimberg <sagi@grimberg.m>
[ Upstream commit 9a59739bd01f77db6fbe2955a4fce165f0f43568 ]
This enum has become part of the uABI, as both RXE and the
ib_uverbs_post_send() command expect userspace to supply values from this
enum. So it should be properly placed in include/uapi/rdma.
In userspace this enum is called 'enum ibv_wr_opcode' as part of
libibverbs.h. That enum defines different values for IB_WR_LOCAL_INV,
IB_WR_SEND_WITH_INV, and IB_WR_LSO. These were introduced (incorrectly, it
turns out) into libiberbs in 2015.
The kernel has changed its mind on the numbering for several of the IB_WC
values over the years, but has remained stable on IB_WR_LOCAL_INV and
below.
Based on this we can conclude that there is no real user space user of the
values beyond IB_WR_ATOMIC_FETCH_AND_ADD, as they have never worked via
rdma-core. This is confirmed by inspection, only rxe uses the kernel enum
and implements the latter operations. rxe has clearly never worked with
these attributes from userspace. Other drivers that support these opcodes
implement the functionality without calling out to the kernel.
To make IB_WR_SEND_WITH_INV and related work for RXE in userspace we
choose to renumber the IB_WR enum in the kernel to match the uABI that
userspace has bee using since before Soft RoCE was merged. This is an
overall simpler configuration for the whole software stack, and obviously
can't break anything existing.
Reported-by: Seth Howell <seth.howell@intel.com>
Tested-by: Seth Howell <seth.howell@intel.com>
Fixes: 8700e3e7c485 ("Soft RoCE driver")
Cc: <stable@vger.kernel.org>
commit af8aab71370a692eaf7e7969ba5b1a455ac20113 upstream.
All threads queuing CQ entries on different CQs are unnecessarily
synchronized by a spin lock to check if the CQ kthread worker hasn't
been destroyed before queuing an CQ entry.
The lock used in 6efaf10f163d ("IB/rdmavt: Avoid queuing work into a
destroyed cq kthread worker") is a device global lock and will have
poor performance at scale as completions are entered from a large
number of CPUs.
Convert to use RCU where the read side of RCU is rvt_cq_enter() to
determine that the worker is alive prior to triggering the
completion event.
Apply write side RCU semantics in rvt_driver_cq_init() and
rvt_cq_exit().
Fixes: 6efaf10f163d ("IB/rdmavt: Avoid queuing work into a destroyed cq kthread worker")
Cc: <stable@vger.kernel.org> # 4.14.x
Reviewed-by: Mike Marciniszyn <mike.marciniszyn@intel.com>
Signed-off-by: Sebastian Sanchez <sebastian.sanchez@intel.com>
Signed-off-by: Dennis Dalessandro <dennis.dalessandro@intel.com>
Signed-off-by: Doug Ledford <dledford@redhat.com>
commit 08bb558ac11ab944e0539e78619d7b4c356278bd upstream.
Make the MR writability flags check, which is performed in umem.c,
a static inline function in file ib_verbs.h
This allows the function to be used by low-level infiniband drivers.
commit 8e907ed4882714fd13cfe670681fc6cb5284c780 upstream.
User-space may invoke ibv_reg_mr and ibv_dereg_mr in different threads.
If ibv_dereg_mr is called after the thread which invoked ibv_reg_mr has
exited, get_pid_task will return NULL and ib_umem_release will not
decrease mm->pinned_vm.
Instead of using threads to locate the mm, use the overall tgid from the
ib_ucontext struct instead. This matches the behavior of ODP and
disassociate in handling the mm of the process that called ibv_reg_mr.
Fixes: 87773dd56d54 ("IB: ib_umem_release() should decrement mm->pinned_vm from ib_umem_get")
Signed-off-by: Lidong Chen <lidongchen@tencent.com>
[ Upstream commit 87daac68f77a3e21a1113f816e6a7be0b38bdde8 ]
iWarp devices do not support the creation of address handles
so return AH_ATTR_TYPE_UNDEFINED for all iWarp devices.
While we are here reduce the size of port_num to u8 and add
a comment.
Fixes: 44c58487d51a ("IB/core: Define 'ib' and 'roce' rdma_ah_attr types")
Reported-by: Parav Pandit <parav@mellanox.com>
CC: Sean Hefty <sean.hefty@intel.com>
Reviewed-by: Ira Weiny <ira.weiny@intel.com>
Reviewed-by: Shiraz Saleem <shiraz.saleem@intel.com>
Signed-off-by: Don Hiatt <don.hiatt@intel.com>
[ Upstream commit a6532e7139660c103dda181aa5b2c734aa26ed6c ]
iWARP does not use rdma_ah_attr_type, and for this reason we do not have a
RDMA_AH_ATTR_TYPE_IWARP. rdma_ah_find_type should not even be called on iwarp
ports and for clarity it shouldn't have a special test for iWarp.
This changes the result from RDMA_AH_ATTR_TYPE_ROCE to RDMA_AH_ATTR_TYPE_IB
when wrongly called on an iWarp port.
Signed-off-by: Parav Pandit <parav@mellanox.com>
Signed-off-by: Leon Romanovsky <leon@kernel.org>
commit 84652aefb347297aa08e91e283adf7b18f77c2d5 upstream.
There are several places in the ucma ABI where userspace can pass in a
sockaddr but set the address family to AF_IB. When that happens,
rdma_addr_size() will return a size bigger than sizeof struct sockaddr_in6,
and the ucma kernel code might end up copying past the end of a buffer
not sized for a struct sockaddr_ib.
Fix this by introducing new variants
int rdma_addr_size_in6(struct sockaddr_in6 *addr);
int rdma_addr_size_kss(struct __kernel_sockaddr_storage *addr);
that are type-safe for the types used in the ucma ABI and return 0 if the
size computed is bigger than the size of the type passed in. We can use
these new variants to check what size userspace has passed in before
copying any addresses.
Reported-by: <syzbot+6800425d54ed3ed8135d@syzkaller.appspotmail.com>
Signed-off-by: Roland Dreier <roland@purestorage.com>
commit cd2a6e7d384b043d5d029e39663061cebc949385 upstream.
The change of slid from u16 to u32 results in sizeof(struct ib_wc)
cross 64B boundary, which causes more cache misses. This patch
rearranges the fields and remain the size to 64B.
Pahole output before this change:
struct ib_wc {
union {
u64 wr_id; /* 8 */
struct ib_cqe * wr_cqe; /* 8 */
}; /* 0 8 */
enum ib_wc_status status; /* 8 4 */
enum ib_wc_opcode opcode; /* 12 4 */
u32 vendor_err; /* 16 4 */
u32 byte_len; /* 20 4 */
struct ib_qp * qp; /* 24 8 */
union {
__be32 imm_data; /* 4 */
u32 invalidate_rkey; /* 4 */
} ex; /* 32 4 */
u32 src_qp; /* 36 4 */
int wc_flags; /* 40 4 */
u16 pkey_index; /* 44 2 */
/* XXX 2 bytes hole, try to pack */
u32 slid; /* 48 4 */
u8 sl; /* 52 1 */
u8 dlid_path_bits; /* 53 1 */
u8 port_num; /* 54 1 */
u8 smac[6]; /* 55 6 */
/* XXX 1 byte hole, try to pack */
u16 vlan_id; /* 62 2 */
/* --- cacheline 1 boundary (64 bytes) --- */
u8 network_hdr_type; /* 64 1 */
/* size: 72, cachelines: 2, members: 17 */
/* sum members: 62, holes: 2, sum holes: 3 */
/* padding: 7 */
/* last cacheline: 8 bytes */
Pahole output after this change:
struct ib_wc {
union {
u64 wr_id; /* 8 */
}; /* 0 8 */
union {
} ex; /* 32 4 */
u32 slid; /* 40 4 */
int wc_flags; /* 44 4 */
u16 pkey_index; /* 48 2 */
u8 sl; /* 50 1 */
u8 dlid_path_bits; /* 51 1 */
u8 port_num; /* 52 1 */
u8 smac[6]; /* 53 6 */
u16 vlan_id; /* 60 2 */
u8 network_hdr_type; /* 62 1 */
/* size: 64, cachelines: 1, members: 17 */
/* sum members: 62, holes: 1, sum holes: 1 */
/* padding: 1 */
Fixes: 7db20ecd1d97 ("IB/core: Change wc.slid from 16 to 32 bits")
Signed-off-by: Bodong Wang <bodong@mellanox.com>
Reviewed-by: Parav Pandit <parav@mellanox.com>
[ Upstream commit 1c3aea2bc8f0b2e5b57375ead40457ff75a3a2ec ]
Since ipv4_addr is a big endian 32-bit number, annotate it as such.
Fixes: commit be1d325a3358 ("IB/core: Set RoCEv2 MGID according to spec")
Signed-off-by: Bart Van Assche <bart.vanassche@wdc.com>
Reviewed-by: Leon Romanovsky <leonro@mellanox.com>
[ Upstream commit 99260132fde7bddc6e0132ce53da94d1c9ccabcb ]
The original code only took into consideration the largest header
possible after the IB_BTH_BYTES. This was incorrect, as the largest
possible header size is the largest possible combination of headers we
might run into. The new code accounts for all possible headers in the
largest possible combination and subtracts that from the MTU to make
sure that all packets will fit on the wire.
Link: https://www.spinics.net/lists/linux-rdma/msg54558.html
Fixes: 3c86aa70bf67 ("RDMA/cm: Add RDMA CM support for IBoE devices")
Reviewed-by: Daniel Jurgens <danielj@mellanox.com>
Reported-by: Roland Dreier <roland@purestorage.com>
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
The ib_mr->length represents the length of the MR in bytes as per
the IBTA spec 1.3 section 11.2.10.3 (REGISTER PHYSICAL MEMORY REGION).
Currently ib_mr->length field is defined as only 32-bits field.
This might result into truncation and failed WRs of consumers who
registers more than 4GB bytes memory regions and whose WRs accessing
such MRs.
This patch makes the length 64-bit to avoid such truncation.
Cc: Sagi Grimberg <sagi@grimberg.me>
Cc: Chuck Lever <chuck.lever@oracle.com>
Cc: Faisal Latif <faisal.latif@intel.com>
Fixes: 4c67e2bfc8b7 ("IB/core: Introduce new fast registration API")
Signed-off-by: Ilya Lesokhin <ilyal@mellanox.com>
The tag matching functionality is implemented by mlx5 driver
by extending XRQ, however this internal kernel information was
exposed to user space applications with *xrq* name instead of *tm*.
This patch renames *xrq* to *tm* to handle that.
Fixes: 8d50505ada72 ("IB/uverbs: Expose XRQ capabilities")
Reviewed-by: Yishai Hadas <yishaih@mellanox.com>
Pull nfsd updates from Bruce Fields:
"More RDMA work and some op-structure constification from Chuck Lever,
and a small cleanup to our xdr encoding"
* tag 'nfsd-4.14' of git://linux-nfs.org/~bfields/linux:
svcrdma: Estimate Send Queue depth properly
rdma core: Add rdma_rw_mr_payload()
svcrdma: Limit RQ depth
svcrdma: Populate tail iovec when receiving
nfsd: Incoming xdr_bufs may have content in tail buffer
svcrdma: Clean up svc_rdma_build_read_chunk()
sunrpc: Const-ify struct sv_serv_ops
nfsd: Const-ify NFSv4 encoding and decoding ops arrays
sunrpc: Const-ify instances of struct svc_xprt_ops
nfsd4: individual encoders no longer see error cases
nfsd4: skip encoder in trivial error cases
nfsd4: define ->op_release for compound ops
nfsd4: opdesc will be useful outside nfs4proc.c
nfsd4: move some nfsd4 op definitions to xdr4.h
Allow interval trees to quickly check for overlaps to avoid unnecesary
tree lookups in interval_tree_iter_first().
As of this patch, all interval tree flavors will require using a
'rb_root_cached' such that we can have the leftmost node easily
available. While most users will make use of this feature, those with
special functions (in addition to the generic insert, delete, search
calls) will avoid using the cached option as they can do funky things
with insertions -- for example, vma_interval_tree_insert_after().
[jglisse@redhat.com: fix deadlock from typo vm_lock_anon_vma()]
Link: http://lkml.kernel.org/r/20170808225719.20723-1-jglisse@redhat.com
Link: http://lkml.kernel.org/r/20170719014603.19029-12-dave@stgolabs.net
Signed-off-by: Davidlohr Bueso <dbueso@suse.de>
Signed-off-by: Jérôme Glisse <jglisse@redhat.com>
Acked-by: Christian König <christian.koenig@amd.com>
Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org>
Acked-by: Doug Ledford <dledford@redhat.com>
Acked-by: Michael S. Tsirkin <mst@redhat.com>
Cc: David Airlie <airlied@linux.ie>
Cc: Jason Wang <jasowang@redhat.com>
Cc: Christian Benvenuti <benve@cisco.com>
The amount of payload per MR depends on device capabilities and
the memory registration mode in use. The new rdma_rw API hides both,
making it difficult for ULPs to determine how large their transport
send queues need to be.
Expose the MR payload information via a new API.
Signed-off-by: Chuck Lever <chuck.lever@oracle.com>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
In order to use the parsing tree, we need to assign the root
to all drivers. Currently, we just assign the default parsing
tree via ib_uverbs_add_one. The driver could override this by
assigning a parsing tree prior to registering the device.
Signed-off-by: Matan Barak <matanb@mellanox.com>
In this phase, we don't want to change all the drivers to use
flexible driver's specific attributes. Therefore, we add two default
attributes: UHW_IN and UHW_OUT. These attributes are optional in some
methods and they encode the driver specific command data. We add
a function that extract this data and creates the legacy udata over
it.
Driver's data should start from UVERBS_UDATA_DRIVER_DATA_FLAG. This
turns on the first bit of the namespace, indicating this attribute
belongs to the driver's namespace.
Add a new ib_user_ioctl_verbs.h which exports all required ABI
enums and structs to the user-space.
Export the default types to user-space through this file.
When some objects are destroyed, we need to extract their status at
destruction. After object's destruction, this status
(e.g. events_reported) relies in the uobject. In order to have the
latest and correct status, the underlying object should be destroyed,
but we should keep the uobject alive and read this information off the
uobject. We introduce a rdma_explicit_destroy function. This function
destroys the class type object (for example, the IDR class type which
destroys the underlying object as well) and then convert the uobject
to be of a null class type. This uobject will then be destroyed as any
other uobject once uverbs_finalize_object[s] is called.
This patch adds macros for declaring objects, methods and
attributes. These definitions are later used by downstream patches
to declare some of the default types.
Different drivers support different features and even subset of the
common uverbs implementation. Currently, this is handled as bitmask
in every driver that represents which kind of methods it supports, but
doesn't go down to attributes granularity. Moreover, drivers might
want to add their specific types, methods and attributes to let
their user-space counter-parts be exposed to some more efficient
abstractions. It means that existence of different features is
validated syntactically via the parsing infrastructure rather than
using a complex in-handler logic.
In order to do that, we allow defining features and abstractions
as parsing trees. These per-feature parsing tree could be merged
to an efficient (perfect-hash based) parsing tree, which is later
used by the parsing infrastructure.
To sum it up, this makes a parse tree unique for a device and
represents only the features this particular device supports.
This is done by having a root specification tree per feature.
Before a device registers itself as an IB device, it merges
all these trees into one parsing tree. This parsing tree
is used to parse all user-space commands.
A future user-space application could read this parse tree. This
tree represents which objects, methods and attributes are
supported by this device.
This is based on the idea of
Jason Gunthorpe <jgunthorpe@obsidianresearch.com>
This adds the DEVICE object. This object supports creating the context
that all objects are created from. Moreover, it supports executing
methods which are related to the device itself, such as QUERY_DEVICE.
This is a singleton object (per file instance).
All standard objects are put in the root structure. This root will later
on be used in drivers as the source for their whole parsing tree.
Later on, when new features are added, these drivers could mix this root
with other customized objects.
Switch all uverbs_type_attrs_xxxx with DECLARE_UVERBS_OBJECT
macros. This will be later used in order to embed the object
specific methods in the objects as well.
In this ioctl interface, processing the command starts from
properties of the command and fetching the appropriate user objects
before calling the handler.
Parsing and validation is done according to a specifier declared by
the driver's code. In the driver, all supported objects are declared.
These objects are separated to different object namepsaces. Dividing
objects to namespaces is done at initialization by using the higher
bits of the object ids. This initialization can mix objects declared
in different places to one parsing tree using in this ioctl interface.
For each object we list all supported methods. Similarly to objects,
methods are separated to method namespaces too. Namespacing is done
similarly to the objects case. This could be used in order to add
methods to an existing object.
Each method has a specific handler, which could be either a default
handler or a driver specific handler.
Along with the handler, a bunch of attributes are specified as well.
Similarly to objects and method, attributes are namespaced and hashed
by their ids at initialization too. All supported attributes are
subject to automatic fetching and validation. These attributes include
the command, response and the method's related objects' ids.
When these entities (objects, methods and attributes) are used, the
high bits of the entities ids are used in order to calculate the hash
bucket index. Then, these high bits are masked out in order to have a
zero based index. Since we use these high bits for both bucketing and
namespacing, we get a compact representation and O(1) array access.
This is mandatory for efficient dispatching.
Each attribute has a type (PTR_IN, PTR_OUT, IDR and FD) and a length.
Attributes could be validated through some attributes, like:
(*) Minimum size / Exact size
(*) Fops for FD
(*) Object type for IDR
If an IDR/fd attribute is specified, the kernel also states the object
type and the required access (NEW, WRITE, READ or DESTROY).
All uobject/fd management is done automatically by the infrastructure,
meaning - the infrastructure will fail concurrent commands that at
least one of them requires concurrent access (WRITE/DESTROY),
synchronize actions with device removals (dissociate context events)
and take care of reference counting (increase/decrease) for concurrent
actions invocation. The reference counts on the actual kernel objects
shall be handled by the handlers.
objects
| | methods +--------+
| | ns method method_spec +-----+ |len |
+--------+ +------+[d]+-------+ +----------------+[d]+------------+ |attr1+-> |type |
| object +> |method+-> | spec +-> + attr_buckets +-> |default_chain+--> +-----+ |idr_type|
+--------+ +------+ |handler| | | +------------+ |attr2| |access |
| | | | +-------+ +----------------+ |driver chain| +-----+ +--------+
[d] = Hash ids to groups using the high order bits
The right types table is also chosen by using the high bits from
the ids. Currently we have either default or driver specific groups.
Once validation and object fetching (or creation) completed, we call
the handler:
int (*handler)(struct ib_device *ib_dev, struct ib_uverbs_file *ufile,
struct uverbs_attr_bundle *ctx);
ctx bundles attributes of different namespaces. Each element there
is an array of attributes which corresponds to one namespaces of
attributes. For example, in the usually used case:
ctx core
| core: +---> | valid |
+----------------------------+ | cmd_attr |
| driver: | +------------+
|----------------------------+--+ | valid |
| | cmd_attr |
| | valid |
| | obj_attr |
| drivers
+> | valid |
| cmd_attr |
| valid |
| cmd_attr |
| valid |
| obj_attr |
The new ioctl based infrastructure either commits or rollbacks
all objects of the method as one transaction. In order to do
that, we introduce a notion of dealing with a collection of
objects that are related to a specific method.
This also requires adding a notion of a method and attribute.
A method contains a hash of attributes, where each bucket
contains several attributes. The attributes are hashed according
to their namespace which resides in the four upper bits of the id.
For example, an object could be a CQ, which has an action of CREATE_CQ.
This action has multiple attributes. For example, the CQ's new handle
and the comp_channel. Each layer in this hierarchy - objects, methods
and attributes is split into namespaces. The basic example for that is
one namespace representing the default entities and another one
representing the driver specific entities.
When declaring these methods and attributes, we actually declare
their specifications. When a method is executed, we actually
allocates some space to hold auxiliary information. This auxiliary
information contains meta-data about the required objects, such
as pointers to their type information, pointers to the uobjects
themselves (if exist), etc.
The specification, along with the auxiliary information we allocated
and filled is given to the finalize_objects function.
The ioctl infrastructure treats all user-objects in the same manner.
It gets objects ids from the user-space and by using the object type
and type attributes mentioned in the object specification, it executes
this required method. Passing an object id from the user-space as
an attribute is carried out in three stages. The first is carried out
before the actual handler and the last is carried out afterwards.
The different supported operations are read, write, destroy and create.
In the first stage, the former three actions just fetches the object
from the repository (by using its id) and locks it. The last action
allocates a new uobject. Afterwards, the second stage is carried out
when the handler itself carries out the required modification of the
object. The last stage is carried out after the handler finishes and
commits the result. The former two operations just unlock the object.
Destroy calls the "free object" operation, taking into account the
object's type and releases the uobject as well. Creation just adds the
new uobject to the repository, making the object visible to the
application.
In order to abstract these details from the ioctl infrastructure
layer, we add uverbs_get_uobject_from_context and
uverbs_finalize_object functions which corresponds to the first
and last stages respectively.
This patch adds new SRQ type - IB_SRQT_TM. The new SRQ type supports tag
matching and rendezvous offloads for MPI applications.
When SRQ receives a message it will search through the matching list
for the corresponding posted receive buffer. The process of searching
the matching list is called tag matching.
In case the tag matching results in a match, the received message will
be placed in the address specified by the receive buffer. In case no
match was found the message will be placed in a generic buffer until the
corresponding receive buffer will be posted. These messages are called
unexpected and their set is called an unexpected list.
Signed-off-by: Artemy Kovalyov <artemyko@mellanox.com>
Reviewed-by: Yossi Itigin <yosefe@mellanox.com>
Before this change CQ attached to SRQ was part of XRC specific extension.
Moving CQ handle out makes it available to other types extending SRQ
functionality.
This patch adds following TM XRQ capabilities:
* max_rndv_hdr_size - Max size of rendezvous request message
* max_num_tags - Max number of entries in tag matching list
* max_ops - Max number of outstanding list operations
* max_sge - Max number of SGE in tag matching entry
* flags - the following flags are currently defined:
- IB_TM_CAP_RC - Support tag matching on RC transport
A destroy of an MR prior to destroying the QP can cause the following
diagnostic if the QP is referencing the MR being de-registered:
hfi1 0000:05:00.0: hfi1_0: rvt_dereg_mr timeout mr ffff8808562108
00 pd ffff880859b20b00
The solution is to when the a non-zero refcount is encountered when
the MR is destroyed the QPs needs to be iterated looking for QPs in
the same PD as the MR. If rvt_qp_mr_clean() detects any such QP
references the rkey/lkey, the QP needs to be put into an error state
via a call to rvt_qp_error() which will trigger the clean up of any
stuck references.
This solution is as specified in IBTA 1.3 Volume 1 11.2.10.5.
[This is reproduced with the 0.4.9 version of qperf and the rc_bw test]
Reviewed-by: Dennis Dalessandro <dennis.dalessandro@intel.com>
Signed-off-by: Mike Marciniszyn <mike.marciniszyn@intel.com>
There are currently 3 spots in the qib and hfi1 driver that have
knowledge of the internal QP hash list that should only be in
scope to rdmavt QP code.
Add an iterator API for processing all QPs to hide the
nature of the RCU hashlist.
The API consists of:
- rvt_qp_iter_init()
* For iterating QPs one at a time for seq_file semantics
- rvt_qp_iter_next()
- rvt_qp_iter()
* For iterating all QPs
The first two are used for things like seq_file prints.
The last is for code that just needs to iterate all QPs
in the system.
Cleanup patch prior exporting the ib_device_cap_flags
to the user space. In this patch, we are aligning the
indentation, removing IB_DEVICE_INIT_TYPE and IB_DEVICE_RESERVED
fields, because it is not used in the kernel.
The functions ib_register_event_handler() and
ib_unregister_event_handler() always returned success and they can't fail.
Let's convert those functions to be void, remove redundant checks and
cleanup tons of goto statements.
Pick up -rc fixes.
Commit 44c58487d51a ("IB/core: Define 'ib' and 'roce' rdma_ah_attr types")
introduced the concept of type in ah_attr:
* During ib_register_device, each port is checked for its type which
is stored in ib_device's port_immutable array.
* During uverbs' modify_qp, the type is inferred using the port number
in ib_uverbs_qp_dest struct (address vector) by accessing the
relevant port_immutable array and the type is passed on to
providers.
IB spec (version 1.3) enforces a valid port value only in Reset to
Init. During Init to RTR, the address vector must be valid but port
number is not mentioned as a field in the address vector, so its
value is not validated, which leads to accesses to a non-allocated
memory when inferring the port type.
Save the real port number in ib_qp during modify to Init (when the
comp_mask indicates that the port number is valid) and use this value
to infer the port type.
Avoid copying the address vector fields if the matching bit is not set
in the attr_mask. Address vector can't be modified before the port, so
no valid flow is affected.
Fixes: 44c58487d51a ('IB/core: Define 'ib' and 'roce' rdma_ah_attr types')
Signed-off-by: Noa Osherovich <noaos@mellanox.com>
If a message comes in and we do not have the client in the table, then
try to load the module supplying that client using MODULE_ALIAS to find
it.
This duplicates the scheme seen in other netlink muxes (eg nfnetlink).
Signed-off-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com>
The macro size is valid. This change makes it less ambiguous.
Bounds check trap type for better security.
Reviewed-by: Michael J. Ruhl <michael.j.ruhl@intel.com>
Signed-off-by: Kamenee Arumugam <kamenee.arumugam@intel.com>
Increase lid used in hfi1 driver to 32 bits. qib continues
to use 16 bit lids.
Signed-off-by: Dasaratharaman Chandramouli <dasaratharaman.chandramouli@intel.com>
Add 16B bypass packet support for UD traffic types.
When address handle attributes are initialized, the LIDs are
transformed to be in the 32 bit LID space.
When constructing the header, hfi1 driver will look at the LID
to determine the packet header to be created.
We introduce a struct hfi1_16b_header to support 16B headers.
16B bypass packets are received by the driver and processed
similar to 9B packets. Add basic support to handle 16B packets.
rvt_check_ah() delegates lid verification to underlying
driver. Underlying driver uses different conditions to
check for dlid depending on whether the device supports
extended LIDs
The pmtu field doens't have be stored in the QP structure
as it can easily be calculated when needed.
This patch series primarily increases sizes of variables that hold
lid values from 16 to 32 bits. Additionally, it adds a check in
the IB mad stack to verify a properly formatted MAD when OPA
extended LIDs are used.
drivers/infiniband/core/iwcm.c - The rdma_netlink patches in
HEAD and the iwarp cm workqueue fix (don't use WQ_MEM_RECLAIM,
we aren't safe for that context) touched the same code.
A sockaddr_in structure on the stack getting passed into rdma_ip2gid
triggers this warning, since we memcpy into a larger sockaddr_in6
structure:
In function 'memcpy',
inlined from 'rdma_ip2gid' at include/rdma/ib_addr.h:175:3,
inlined from 'addr_event.isra.4.constprop' at drivers/infiniband/core/roce_gid_mgmt.c:693:2,
inlined from 'inetaddr_event' at drivers/infiniband/core/roce_gid_mgmt.c:716:9:
include/linux/string.h:305:4: error: call to '__read_overflow2' declared with attribute error: detected read beyond size of object passed as 2nd parameter
The warning seems appropriate here, but the code is also clearly
correct, so we really just want to shut up this instance of the
output.
The best way I found so far is to avoid the memcpy() call and instead
replace it with a struct assignment.
Fixes: 6974f0c4555e ("include/linux/string.h: add the option of fortified string.h functions")
Cc: Daniel Micay <danielmicay@gmail.com>
