path: root/include/rdma
2017-03-12RDMA/core: Fix incorrect structure packing for booleansJason Gunthorpe
commit 55efcfcd7776165b294f8b5cd6e05ca00ec89b7c upstream. The RDMA core uses ib_pack() to convert from unpacked CPU structs to on-the-wire bitpacked structs. This process requires that 1 bit fields are declared as u8 in the unpacked struct, otherwise the packing process does not read the value properly and the packed result is wired to 0. Several places wrongly used int. Crucially this means the kernel has never, set reversible correctly in the path record request. It has always asked for irreversible paths even if the ULP requests otherwise. When the kernel is used with a SM that supports this feature, it completely breaks communication management if reversible paths are not properly requested. The only reason this ever worked is because opensm ignores the reversible bit. Fixes: 1da177e4c3f4 ("Linux-2.6.12-rc2") Signed-off-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com> Signed-off-by: Doug Ledford <dledford@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-09IB/cma: Fix a race condition in iboe_addr_get_sgid()Bart Van Assche
commit fba332b079029c2f4f7e84c1c1cd8e3867310c90 upstream. Code that dereferences the struct net_device ip_ptr member must be protected with an in_dev_get() / in_dev_put() pair. Hence insert calls to these functions. Fixes: commit 7b85627b9f02 ("IB/cma: IBoE (RoCE) IP-based GID addressing") Signed-off-by: Bart Van Assche <bart.vanassche@sandisk.com> Reviewed-by: Moni Shoua <monis@mellanox.com> Cc: Or Gerlitz <ogerlitz@mellanox.com> Cc: Roland Dreier <roland@purestorage.com> Signed-off-by: Doug Ledford <dledford@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-04IB/security: Restrict use of the write() interfaceJason Gunthorpe
commit e6bd18f57aad1a2d1ef40e646d03ed0f2515c9e3 upstream. The drivers/infiniband stack uses write() as a replacement for bi-directional ioctl(). This is not safe. There are ways to trigger write calls that result in the return structure that is normally written to user space being shunted off to user specified kernel memory instead. For the immediate repair, detect and deny suspicious accesses to the write API. For long term, update the user space libraries and the kernel API to something that doesn't present the same security vulnerabilities (likely a structured ioctl() interface). The impacted uAPI interfaces are generally only available if hardware from drivers/infiniband is installed in the system. Reported-by: Jann Horn <jann@thejh.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com> [ Expanded check to all known write() entry points ] Signed-off-by: Doug Ledford <dledford@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-12-08IB/mad: Require CM send method for everything except ClassPortInfoHal Rosenstock
Receipt of CM MAD with other than the Send method for an attribute other than the ClassPortInfo attribute is invalid. CM attributes other than ClassPortInfo only use the send method. The SRP initiator does not maintain a timeout policy for CM connect requests relies on the CM layer to do that. The result was that the SRP initiator hung as the connect request never completed. A new SRP target has been observed to respond to Send CM REQ with GetResp of CM REQ with bad status. This is non conformant with IBA spec but exposes a vulnerability in the current MAD/CM code which will respond to the incoming GetResp of CM REQ as if it was a valid incoming Send of CM REQ rather than tossing this on the floor. It also causes the MAD layer not to retransmit the original REQ even though it has not received a REP. Reviewed-by: Sagi Grimberg <sagig@mellanox.com> Signed-off-by: Hal Rosenstock <hal@mellanox.com> Reviewed-by: Ira Weiny <ira.weiny@intel.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2015-12-07IB/core: use RCU for uverbs id lookupMike Marciniszyn
The current implementation gets a spin_lock, and at any scale with qib and hfi1 post send, the lock contention grows exponentially with the number of QPs. idr_find() is RCU compatibile, so read doesn't need the lock. Change to use rcu_read_lock() and rcu_read_unlock() in __idr_get_uobj(). kfree_rcu() is used to insure a grace period between the idr removal and actual free. Reviewed-by: Ira Weiny <ira.weiny@intel.com> Signed-off-by: Mike Marciniszyn <mike.marciniszyn@intel.com> Reviewed-By: Jason Gunthorpe <jgunthorpe@obsidianresearch.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2015-10-30IB/core, cma: Make __attribute_const__ declarations sparse-friendlyBart Van Assche
Move the __attribute_const__ declarations such that sparse understands that these apply to the function itself and not to the return type. This avoids that sparse reports error messages like the following: drivers/infiniband/core/verbs.c:73:12: error: symbol 'ib_event_msg' redeclared with different type (originally declared at include/rdma/ib_verbs.h:470) - different modifiers Fixes: 2b1b5b601230 ("IB/core, cma: Nice log-friendly string helpers") Signed-off-by: Bart Van Assche <bart.vanassche@sandisk.com> Cc: Sagi Grimberg <sagig@mellanox.com> Reviewed-by: Sagi Grimberg <sagig@mellanox.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2015-10-29IB/core: Remove old fast registration APISagi Grimberg
No callers and no providers left, go ahead and remove it. Signed-off-by: Sagi Grimberg <sagig@mellanox.com> Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Doug Ledford <dledford@redhat.com>
2015-10-28IB/core: Introduce new fast registration APISagi Grimberg
The new fast registration verb ib_map_mr_sg receives a scatterlist and converts it to a page list under the verbs API thus hiding the specific HW mapping details away from the consumer. The provider drivers are provided with a generic helper ib_sg_to_pages that converts a scatterlist into a vector of page addresses. The drivers can still perform any HW specific page address setting by passing a set_page function pointer which will be invoked for each page address. This allows drivers to avoid keeping a shadow page vectors and convert them to HW specific translations by doing extra copies. This API will allow ULPs to remove the duplicated code of constructing a page vector from a given sg list. The send work request ib_reg_wr also shrinks as it will contain only mr, key and access flags in addition. Signed-off-by: Sagi Grimberg <sagig@mellanox.com> Tested-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Doug Ledford <dledford@redhat.com>
2015-10-28Merge branch 'wr-cleanup' into k.o/for-4.4Doug Ledford
2015-10-28IB/cma: Add support for network namespacesGuy Shapiro
Add support for network namespaces in the ib_cma module. This is accomplished by: 1. Adding network namespace parameter for rdma_create_id. This parameter is used to populate the network namespace field in rdma_id_private. rdma_create_id keeps a reference on the network namespace. 2. Using the network namespace from the rdma_id instead of init_net inside of ib_cma, when listening on an ID and when looking for an ID for an incoming request. 3. Decrementing the reference count for the appropriate network namespace when calling rdma_destroy_id. In order to preserve the current behavior init_net is passed when calling from other modules. Signed-off-by: Guy Shapiro <guysh@mellanox.com> Signed-off-by: Haggai Eran <haggaie@mellanox.com> Signed-off-by: Yotam Kenneth <yotamke@mellanox.com> Signed-off-by: Shachar Raindel <raindel@mellanox.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2015-10-28IB/addr: Pass network namespace as a parameterGuy Shapiro
Add network namespace support to the ib_addr module. For that, all the address resolution and matching should be done using the appropriate namespace instead of init_net. This is achieved by: 1. Adding an explicit network namespace argument to exported function that require a namespace. 2. Saving the namespace in the rdma_addr_client structure. 3. Using it when calling networking functions. In order to preserve the behavior of calling modules, &init_net is passed as the parameter in calls from other modules. This is modified as namespace support is added on more levels. Signed-off-by: Haggai Eran <haggaie@mellanox.com> Signed-off-by: Yotam Kenneth <yotamke@mellanox.com> Signed-off-by: Shachar Raindel <raindel@mellanox.com> Signed-off-by: Guy Shapiro <guysh@mellanox.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2015-10-21IB/core: Remove smac and vlan id from path recordMatan Barak
The GID cache accompanies every GID with attributes. The GID attributes link the GID with its netdevice, which could be resolved to smac and vlan id easily. Since we've added the netdevice (ifindex and net) to the path record, storing the L2 attributes is duplicated data and hence these attributes are removed. Signed-off-by: Matan Barak <matanb@mellanox.com> Reviewed-By: Devesh Sharma <devesh.sharma@avagotech.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2015-10-21IB/core: Remove smac and vlan id from qp_attr and ah_attrMatan Barak
Smac and vlan id could be resolved from the GID attribute, and thus these attributes aren't needed anymore. Removing them. Signed-off-by: Matan Barak <matanb@mellanox.com> Reviewed-By: Devesh Sharma <devesh.sharma@avagotech.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2015-10-21IB/core: Use GID table in AH creation and dmac resolutionMatan Barak
Previously, vlan id and source MAC were used from QP attributes. Since the net device is now stored in the GID attributes, they could be used instead of getting this information from the QP attributes. IB_QP_SMAC, IB_QP_ALT_SMAC, IB_QP_VID and IB_QP_ALT_VID were removed because there is no known libibverbs that uses them. This commit also modifies the vendors (mlx4, ocrdma) drivers in order to use the new approach. ocrdma driver changes were done by Somnath Kotur <Somnath.Kotur@Avagotech.Com> Signed-off-by: Matan Barak <matanb@mellanox.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2015-10-21IB/cache: Add ib_find_gid_by_filter cache APIMatan Barak
GID cache API users might want to search for GIDs with specific attributes rather than just specifying GID, net device and port. This is used in a later patch, where we find the sgid index by L2 Ethernet attributes. Signed-off-by: Matan Barak <matanb@mellanox.com> Reviewed-By: Devesh Sharma <devesh.sharma@avagotech.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2015-10-21IB/core: Add netdev to path recordMatan Barak
In order to find the sgid_index, one could just query the IB cache with the correct GID and netdevice. Therefore, instead of storing the L2 attributes directly in the path, we only store the ifindex and net and use them later to get the sgid_index. The vlan_id and smac L2 attributes are removed in a later patch. Signed-off-by: Matan Barak <matanb@mellanox.com> Reviewed-By: Devesh Sharma <devesh.sharma@avagotech.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2015-10-21IB/core: Expose and rename ib_find_cached_gid_by_port cache APIMatan Barak
Sometime consumers might want to search for a GID in a specific port. For example, when a WC arrives and we want to search the GID that matches that port - it's better to search only the relevant port. Exposing and renaming ib_cache_gid_find_by_port in order to match the naming convention of the module. Signed-off-by: Matan Barak <matanb@mellanox.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2015-10-21IB/core: Add netdev and gid attributes paramteres to cacheMatan Barak
Adding an ability to query the IB cache by a netdev and get the attributes of a GID. These parameters are necessary in order to successfully resolve the required GID (when the netdevice is known) and get the Ethernet L2 attributes from a GID. Signed-off-by: Matan Barak <matanb@mellanox.com> Reviewed-By: Devesh Sharma <devesh.sharma@avagotech.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2015-10-21ib_pack.h: Fix commentary IBA reference for CNP in IB opcode enumHal Rosenstock
IBA spec is now 1.3 not 3.1 and vol 1 should be mentioned as there is also vol 2. Signed-off-by: Hal Rosenstock <hal@mellanox.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2015-10-08IB: remove xrc_remote_srq_num from struct ib_send_wrChristoph Hellwig
The field is only initialized in mlx, but never used. If we want to add proper XRC support it should be done with a new struct ib_xrc_wr. This shrinks the various WR structures by another 4 bytes. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Sagi Grimberg <sagig@mellanox.com> Reviewed-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com> Tested-by: Haggai Eran <haggaie@mellanox.com>
2015-10-08IB: split struct ib_send_wrChristoph Hellwig
This patch split up struct ib_send_wr so that all non-trivial verbs use their own structure which embedds struct ib_send_wr. This dramaticly shrinks the size of a WR for most common operations: sizeof(struct ib_send_wr) (old): 96 sizeof(struct ib_send_wr): 48 sizeof(struct ib_rdma_wr): 64 sizeof(struct ib_atomic_wr): 96 sizeof(struct ib_ud_wr): 88 sizeof(struct ib_fast_reg_wr): 88 sizeof(struct ib_bind_mw_wr): 96 sizeof(struct ib_sig_handover_wr): 80 And with Sagi's pending MR rework the fast registration WR will also be down to a reasonable size: sizeof(struct ib_fastreg_wr): 64 Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Bart Van Assche <bart.vanassche@sandisk.com> [srp, srpt] Reviewed-by: Chuck Lever <chuck.lever@oracle.com> [sunrpc] Tested-by: Haggai Eran <haggaie@mellanox.com> Tested-by: Sagi Grimberg <sagig@mellanox.com> Tested-by: Steve Wise <swise@opengridcomputing.com>
2015-09-28IB/core: Add support of checksum capability reporting for RC and RAWBodong Wang
Two enum members IB_DEVICE_RC_IP_CSUM and IB_DEVICE_RAW_IP_CSUM are added to ib_device_cap_flags. Device should set these two flags if they support insertion of UDP and TCP checksum on outgoing IPv4 messages and can verify the validity of checksum for incoming IPv4 messages, for RC IPoIB and RAW over Ethernet respectively. They are similar to IB_DEVICE_UD_IP_CSUM. Signed-off-by: Bodong Wang <bodong@mellanox.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2015-09-19Merge tag 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dledford/rdma Pull rdma fixes from Doug Ledford: "The new hfi1 driver in staging/rdma has had a number of fixup patches since being added to the tree. This is the first batch of those fixes" * tag 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dledford/rdma: IB/hfi: Properly set permissions for user device files IB/hfi1: mask vs shift confusion IB/hfi1: clean up some defines IB/hfi1: info leak in get_ctxt_info() IB/hfi1: fix a locking bug IB/hfi1: checking for NULL instead of IS_ERR IB/hfi1: fix sdma_descq_cnt parameter parsing IB/hfi1: fix copy_to/from_user() error handling IB/hfi1: fix pstateinfo from returning improperly byteswapped value
2015-09-18IB/hfi1: fix pstateinfo from returning improperly byteswapped valueIra Weiny
Byteswap link_width_downgrade_*_active values before sending on the wire. In addition properly define the Port State Info structure. Reviewed-by: Dennis Dalessandro <dennis.dalessandro@intel.com> Reviewed-by: Christian Gomez <christian.gomez@intel.com> Signed-off-by: Rimmer, Todd <todd.rimmer@intel.com> Signed-off-by: Ira Weiny <ira.weiny@intel.com> Acked-by: Mike Marciniszyn <mike.marciniszyn@intel.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2015-09-09Merge tag 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dledford/rdma Pull inifiniband/rdma updates from Doug Ledford: "This is a fairly sizeable set of changes. I've put them through a decent amount of testing prior to sending the pull request due to that. There are still a few fixups that I know are coming, but I wanted to go ahead and get the big, sizable chunk into your hands sooner rather than waiting for those last few fixups. Of note is the fact that this creates what is intended to be a temporary area in the drivers/staging tree specifically for some cleanups and additions that are coming for the RDMA stack. We deprecated two drivers (ipath and amso1100) and are waiting to hear back if we can deprecate another one (ehca). We also put Intel's new hfi1 driver into this area because it needs to be refactored and a transfer library created out of the factored out code, and then it and the qib driver and the soft-roce driver should all be modified to use that library. I expect drivers/staging/rdma to be around for three or four kernel releases and then to go away as all of the work is completed and final deletions of deprecated drivers are done. Summary of changes for 4.3: - Create drivers/staging/rdma - Move amso1100 driver to staging/rdma and schedule for deletion - Move ipath driver to staging/rdma and schedule for deletion - Add hfi1 driver to staging/rdma and set TODO for move to regular tree - Initial support for namespaces to be used on RDMA devices - Add RoCE GID table handling to the RDMA core caching code - Infrastructure to support handling of devices with differing read and write scatter gather capabilities - Various iSER updates - Kill off unsafe usage of global mr registrations - Update SRP driver - Misc mlx4 driver updates - Support for the mr_alloc verb - Support for a netlink interface between kernel and user space cache daemon to speed path record queries and route resolution - Ininitial support for safe hot removal of verbs devices" * tag 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dledford/rdma: (136 commits) IB/ipoib: Suppress warning for send only join failures IB/ipoib: Clean up send-only multicast joins IB/srp: Fix possible protection fault IB/core: Move SM class defines from ib_mad.h to ib_smi.h IB/core: Remove unnecessary defines from ib_mad.h IB/hfi1: Add PSM2 user space header to header_install IB/hfi1: Add CSRs for CONFIG_SDMA_VERBOSITY mlx5: Fix incorrect wc pkey_index assignment for GSI messages IB/mlx5: avoid destroying a NULL mr in reg_user_mr error flow IB/uverbs: reject invalid or unknown opcodes IB/cxgb4: Fix if statement in pick_local_ip6adddrs IB/sa: Fix rdma netlink message flags IB/ucma: HW Device hot-removal support IB/mlx4_ib: Disassociate support IB/uverbs: Enable device removal when there are active user space applications IB/uverbs: Explicitly pass ib_dev to uverbs commands IB/uverbs: Fix race between ib_uverbs_open and remove_one IB/uverbs: Fix reference counting usage of event files IB/core: Make ib_dealloc_pd return void IB/srp: Create an insecure all physical rkey only if needed ...
2015-09-03IB/core: Move SM class defines from ib_mad.h to ib_smi.hIra Weiny
When the hfi1 driver was added these definitions were moved from the qib driver to ib_mad.h to be used by both qib and hfi1. They should have been moved to ib_smi.h instead. Fixes: d4ab347005fb ("IB/core: Add core header changes needed for OPA") Reviewed-by: Hal Rosenstock <hal@mellanox.com> Signed-off-by: Ira Weiny <ira.weiny@intel.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2015-09-03IB/core: Remove unnecessary defines from ib_mad.hIra Weiny
Remove the unused IB_NOTICE_REPRESS_* defines. When the hfi1 driver was added these definitions were moved from the qib driver to ib_mad.h. They should have been removed instead. Fixes: d4ab347005fb ("IB/core: Add core header changes needed for OPA") Signed-off-by: Ira Weiny <ira.weiny@intel.com> Reviewed-by: Hal Rosenstock <hal@mellanox.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2015-08-30IB/uverbs: Enable device removal when there are active user space applicationsYishai Hadas
Enables the uverbs_remove_one to succeed despite the fact that there are running IB applications working with the given ib device. This functionality enables a HW device to be unbind/reset despite the fact that there are running user space applications using it. It exposes a new IB kernel API named 'disassociate_ucontext' which lets a driver detaching its HW resources from a given user context without crashing/terminating the application. In case a driver implemented the above API and registered with ib_uverb there will be no dependency between its device to its uverbs_device. Upon calling remove_one of ib_uverbs the call should return after disassociating the open HW resources without waiting to clients disconnecting. In case driver didn't implement this API there will be no change to current behaviour and uverbs_remove_one will return only when last client has disconnected and reference count on uverbs device became 0. In case the lower driver device was removed any application will continue working over some zombie HCA, further calls will ended with an immediate error. Signed-off-by: Yishai Hadas <yishaih@mellanox.com> Signed-off-by: Shachar Raindel <raindel@mellanox.com> Reviewed-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2015-08-30IB/core: Make ib_dealloc_pd return voidJason Gunthorpe
The majority of callers never check the return value, and even if they did, they can't do anything about a failure. All possible failure cases represent a bug in the caller, so just WARN_ON inside the function instead. This fixes a few random errors: net/rd/iw.c infinite loops while it fails. (racing with EBUSY?) This also lays the ground work to get rid of error return from the drivers. Most drivers do not error, the few that do are broken since it cannot be handled. Since uverbs can legitimately make use of EBUSY, open code the check. Signed-off-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com> Reviewed-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2015-08-30IB/mad: Remove ib_get_dma_mr callsJason Gunthorpe
The pd now has a local_dma_lkey member which completely replaces ib_get_dma_mr, use it instead. Signed-off-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2015-08-30IB/core: Guarantee that a local_dma_lkey is availableJason Gunthorpe
Every single ULP requires a local_dma_lkey to do anything with a QP, so let us ensure one exists for every PD created. If the driver can supply a global local_dma_lkey then use that, otherwise ask the driver to create a local use all physical memory MR associated with the new PD. Signed-off-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com> Reviewed-by: Sagi Grimberg <sagig@dev.mellanox.co.il> Acked-by: Christoph Hellwig <hch@infradead.org> Reviewed-by: Steve Wise <swise@opengridcomputing.com> Reviewed-by: Ira Weiny <ira.weiny@intel.com> Tested-by: Ira Weiny <ira.weiny@intel.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2015-08-30IB/core: Add rdma netlink helper functionsKaike Wan
This patch adds a function to check if listeners for a netlink multicast group are present. It also adds a function to receive netlink response messages. Signed-off-by: Kaike Wan <kaike.wan@intel.com> Signed-off-by: John Fleck <john.fleck@intel.com> Signed-off-by: Ira Weiny <ira.weiny@intel.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2015-08-30IB/mlx4: Implement ib_device callbacksMoni Shoua
get_netdev: get the net_device on the physical port of the IB transport port. In port aggregation mode it is required to return the netdev of the active port. modify_gid: note for a change in the RoCE gid cache. Handle this by writing to the harsware GID table. It is possible that indexes in cahce and hardware tables won't match so a translation is required when modifying a QP or creating an address handle. Signed-off-by: Moni Shoua <monis@mellanox.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2015-08-30IB/core: Add RoCE GID table managementMatan Barak
RoCE GIDs are based on IP addresses configured on Ethernet net-devices which relate to the RDMA (RoCE) device port. Currently, each of the low-level drivers that support RoCE (ocrdma, mlx4) manages its own RoCE port GID table. As there's nothing which is essentially vendor specific, we generalize that, and enhance the RDMA core GID cache to do this job. In order to populate the GID table, we listen for events: (a) netdev up/down/change_addr events - if a netdev is built onto our RoCE device, we need to add/delete its IPs. This involves adding all GIDs related to this ndev, add default GIDs, etc. (b) inet events - add new GIDs (according to the IP addresses) to the table. For programming the port RoCE GID table, providers must implement the add_gid and del_gid callbacks. RoCE GID management requires us to state the associated net_device alongside the GID. This information is necessary in order to manage the GID table. For example, when a net_device is removed, its associated GIDs need to be removed as well. RoCE mandates generating a default GID for each port, based on the related net-device's IPv6 link local. In contrast to the GID based on the regular IPv6 link-local (as we generate GID per IP address), the default GID is also available when the net device is down (in order to support loopback). Locking is done as follows: The patch modify the GID table code both for new RoCE drivers implementing the add_gid/del_gid callbacks and for current RoCE and IB drivers that do not. The flows for updating the table are different, so the locking requirements are too. While updating RoCE GID table, protection against multiple writers is achieved via mutex_lock(&table->lock). Since writing to a table requires us to find an entry (possible a free entry) in the table and then modify it, this mutex protects both the find_gid and write_gid ensuring the atomicity of the action. Each entry in the GID cache is protected by rwlock. In RoCE, writing (usually results from netdev notifier) involves invoking the vendor's add_gid and del_gid callbacks, which could sleep. Therefore, an invalid flag is added for each entry. Updates for RoCE are done via a workqueue, thus sleeping is permitted. In IB, updates are done in write_lock_irq(&device->cache.lock), thus write_gid isn't allowed to sleep and add_gid/del_gid are not called. When passing net-device into/out-of the GID cache, the device is always passed held (dev_hold). The code uses a single work item for updating all RDMA devices, following a netdev or inet notifier. The patch moves the cache from being a client (which was incorrect, as the cache is part of the IB infrastructure) to being explicitly initialized/freed when a device is registered/removed. Signed-off-by: Matan Barak <matanb@mellanox.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2015-08-30IB/core: Drop ib_alloc_fast_reg_mrSagi Grimberg
Fully replaced by a more generic and suitable ib_alloc_mr. Signed-off-by: Sagi Grimberg <sagig@mellanox.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2015-08-30IB: Modify ib_create_mr APISagi Grimberg
Use ib_alloc_mr with specific parameters. Change the existing callers. Signed-off-by: Sagi Grimberg <sagig@mellanox.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2015-08-30IB/core: Get rid of redundant verb ib_destroy_mrSagi Grimberg
This was added in a thought of uniting all mr allocation and deallocation routines but the fact is we have a single deallocation routine already, ib_dereg_mr. And, move mlx5_ib_destroy_mr specific logic into mlx5_ib_dereg_mr (includes only signature stuff for now). And, fixup the only callers (iser/isert) accordingly. Signed-off-by: Sagi Grimberg <sagig@mellanox.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2015-08-30IB/cm: Remove compare_data checksHaggai Eran
Now that there are no ib_cm clients using the compare_data feature for matching IB CM requests' private data, remove the compare_data parameter of ib_cm_listen and remove the code implementing the feature. Signed-off-by: Haggai Eran <haggaie@mellanox.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2015-08-30IB/cm: Expose BTH P_Key in CM and SIDR request eventsHaggai Eran
The rdma_cm module will later use the P_Key from the BTH to de-mux requests. See discussion at: http://www.spinics.net/lists/netdev/msg336067.html Cc: Jason Gunthorpe <jgunthorpe@obsidianresearch.com> Cc: Liran Liss <liranl@mellanox.com> Signed-off-by: Haggai Eran <haggaie@mellanox.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2015-08-30IB/cm: Share listening CM IDsHaggai Eran
Enabling network namespaces for RDMA CM will allow processes on different namespaces to listen on the same port. In order to leave namespace support out of the CM layer, this requires that multiple RDMA CM IDs will be able to share a single CM ID. This patch adds infrastructure to retrieve an existing listening ib_cm_id, based on its device and service ID, or create a new one if one does not already exist. It also adds a reference count for such instances (cm_id_private.listen_sharecount), and prevents cm_destroy_id from destroying a CM if it is still shared. See the relevant discussion [1]. [1] Re: [PATCH v3 for-next 05/13] IB/cm: Reference count ib_cm_ids http://www.spinics.net/lists/netdev/msg328860.html Reviewed-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com> Signed-off-by: Haggai Eran <haggaie@mellanox.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2015-08-30IB/cm: Expose service ID in request eventsHaggai Eran
Expose the service ID on an incoming CM or SIDR request to the event handler. This will allow the RDMA CM module to de-multiplex connection requests based on the information encoded in the service ID. Acked-by: Sean Hefty <sean.hefty@intel.com> Signed-off-by: Haggai Eran <haggaie@mellanox.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2015-08-30IB/core: Find the network device matching connection parametersYotam Kenneth
In the case of IPoIB, and maybe in other cases, the network device is managed by an upper-layer protocol (ULP). In order to expose this network device to other users of the IB device, let ULPs implement a callback that returns network device according to connection parameters. The IB device and port, together with the P_Key and the GID should be enough to uniquely identify the ULP net device. However, in current kernels there can be multiple IPoIB interfaces created with the same GID. Furthermore, such configuration may be desireable to support ipvlan-like configurations for RDMA CM with IPoIB. To resolve the device in these cases the code will also take the IP address as an additional input. Reviewed-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com> Signed-off-by: Haggai Eran <haggaie@mellanox.com> Signed-off-by: Yotam Kenneth <yotamke@mellanox.com> Signed-off-by: Shachar Raindel <raindel@mellanox.com> Signed-off-by: Guy Shapiro <guysh@mellanox.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2015-08-30IB/core: lock client data with lists_rwsemHaggai Eran
An ib_client callback that is called with the lists_rwsem locked only for read is protected from changes to the IB client lists, but not from ib_unregister_device() freeing its client data. This is because ib_unregister_device() will remove the device from the device list with lists_rwsem locked for write, but perform the rest of the cleanup, including the call to remove() without that lock. Mark client data that is undergoing de-registration with a new going_down flag in the client data context. Lock the client data list with lists_rwsem for write in addition to using the spinlock, so that functions calling the callback would be able to lock only lists_rwsem for read and let callbacks sleep. Since ib_unregister_client() now marks the client data context, no need for remove() to search the context again, so pass the client data directly to remove() callbacks. Reviewed-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com> Signed-off-by: Haggai Eran <haggaie@mellanox.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2015-08-28RDMA/Core: remove rdma_cap_read_multi_sge() helperSteve Wise
This functionality already exists via the max_sge_rd device capability. Signed-off-by: Steve Wise <swise@opengridcomputing.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2015-08-28IB/core: Add core header changes needed for OPADennis Dalessandro
This patch adds the value of the CNP opcode to the existing list of enumerated opcodes in ib_pack.h Add common OPA header definitions for driver build: - opa_port_info.h - opa_smi.h - hfi1_user.h Additionally, ib_mad.h, has additional definitions that are common to ib_drivers including: - trap support - cca support The qib driver has the duplication removed in favor those in ib_mad.h Reviewed-by: Mike Marciniszyn <mike.marciniszyn@intel.com> Reviewed-by: John, Jubin <jubin.john@intel.com> Signed-off-by: Ira Weiny <ira.weiny@intel.com> Signed-off-by: Dennis Dalessandro <dennis.dalessandro@intel.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2015-08-05core: Remove the ib_reg_phys_mr() and ib_rereg_phys_mr() verbsChuck Lever
The verbs are obsolete. The ib_rereg_phys_mr() verb is not used by kernel ULPs, and the last ib_reg_phys_mr() call site in the kernel tree has now been removed. Two staging tree call sites remain in the Lustre client. The Lustre team has been notified of the deprecation of reg_phys_mr. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Acked-by: Doug Ledford <dledford@redhat.com> Signed-off-by: Anna Schumaker <Anna.Schumaker@Netapp.com>
2015-07-14IB: Add rdma_cap_ib_switch helper and use where appropriateHal Rosenstock
Persuant to Liran's comments on node_type on linux-rdma mailing list: In an effort to reform the RDMA core and ULPs to minimize use of node_type in struct ib_device, an additional bit is added to struct ib_device for is_switch (IB switch). This is needed to be initialized by any IB switch device driver. This is a NEW requirement on such device drivers which are all "out of tree". In addition, an ib_switch helper was added to ib_verbs.h based on the is_switch device bit rather than node_type (although those should be consistent). The RDMA core (MAD, SMI, agent, sa_query, multicast, sysfs) as well as (IPoIB and SRP) ULPs are updated where appropriate to use this new helper. In some cases, the helper is now used under the covers of using rdma_[start end]_port rather than the open coding previously used. Reviewed-by: Sean Hefty <sean.hefty@intel.com> Reviewed-By: Jason Gunthorpe <jgunthorpe@obsidianresearch.com> Reviewed-by: Ira Weiny <ira.weiny@intel.com> Tested-by: Ira Weiny <ira.weiny@intel.com> Signed-off-by: Hal Rosenstock <hal@mellanox.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2015-06-12IB/mad: Add final OPA MAD processingIra Weiny
For devices which support OPA MADs 1) Use previously defined SMP support functions. 2) Pass correct base version to ib_create_send_mad when processing OPA MADs. 3) Process out_mad_key_index returned by agents for a response. This is necessary because OPA SMP packets must carry a valid pkey. 4) Carry the correct segment size (OPA vs IBTA) of RMPP messages within ib_mad_recv_wc. 5) Handle variable length OPA MADs by: * Adjusting the 'fake' WC for locally routed SMP's to represent the proper incoming byte_len * out_mad_size is used from the local HCA agents 1) when sending agent responses on the wire 2) when passing responses through the local_completions function NOTE: wc.byte_len includes the GRH length and therefore is different from the in_mad_size specified to the local HCA agents. out_mad_size should _not_ include the GRH length as it is added Signed-off-by: Ira Weiny <ira.weiny@intel.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2015-06-12IB/mad: Add partial Intel OPA MAD supportIra Weiny
Add OPA SMP processing functionality. Define the new OPA SMP format, create support functions for this format using the previously defined helper functions as appropriate. These functions are defined in this patch and used in the final OPA MAD support patch. Signed-off-by: Ira Weiny <ira.weiny@intel.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
This patch is the first of 3 which adds processing of OPA MADs 1) Add Intel Omni-Path Architecture defines 2) Increase max management version to accommodate OPA 3) update ib_create_send_mad If the device supports OPA MADs and the MAD being sent is the OPA base version alter the MAD size and sg lengths as appropriate Signed-off-by: Ira Weiny <ira.weiny@intel.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
