path: root/include/scsi/osd_ore.h
2014-01-23ore: Fix wrong math in allocation of per device BIOBoaz Harrosh
At IO preparation we calculate the max pages at each device and allocate a BIO per device of that size. The calculation was wrong on some unaligned corner cases offset/length combination and would make prepare return with -ENOMEM. This would be bad for pnfs-objects that would in that case IO through MDS. And fatal for exofs were it would fail writes with EIO. Fix it by doing the proper math, that will work in all cases. (I ran a test with all possible offset/length combinations this time round). Also when reading we do not need to allocate for the parity units since we jump over them. Also lower the max_io_length to take into account the parity pages so not to allocate BIOs bigger than PAGE_SIZE CC: Stable Kernel <stable@vger.kernel.org> Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
2012-03-04BUG: headers with BUG/BUG_ON etc. need linux/bug.hPaul Gortmaker
If a header file is making use of BUG, BUG_ON, BUILD_BUG_ON, or any other BUG variant in a static inline (i.e. not in a #define) then that header really should be including <linux/bug.h> and not just expecting it to be implicitly present. We can make this change risk-free, since if the files using these headers didn't have exposure to linux/bug.h already, they would have been causing compile failures/warnings. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-24ore: RAID5 WriteBoaz Harrosh
This is finally the RAID5 Write support. The bigger part of this patch is not the XOR engine itself, But the read4write logic, which is a complete mini prepare_for_striping reading engine that can read scattered pages of a stripe into cache so it can be used for XOR calculation. That is, if the write was not stripe aligned. The main algorithm behind the XOR engine is the 2 dimensional array: struct __stripe_pages_2d. A drawing might save 1000 words --- __stripe_pages_2d | n = pages_in_stripe_unit; w = group_width - parity; | pages array presented to the XOR lib | | V | __1_page_stripe[0].pages --> [c0][c1]..[cw][c_par] <---| | | __1_page_stripe[1].pages --> [c0][c1]..[cw][c_par] <--- | ... | ... | __1_page_stripe[n].pages --> [c0][c1]..[cw][c_par] ^ | data added columns first then row --- The pages are put on this array columns first. .i.e: p0-of-c0, p1-of-c0, ... pn-of-c0, p0-of-c1, ... So we are doing a corner turn of the pages. Note that pages will zigzag down and left. but are put sequentially in growing order. So when the time comes to XOR the stripe, only the beginning and end of the array need be checked. We scan the array and any NULL spot will be field by pages-to-be-read. The FS that wants to support RAID5 needs to supply an operations-vector that searches a given page in cache, and specifies if the page is uptodate or need reading. All these pages to be read are put on a slave ore_io_state and synchronously read. All the pages of a stripe are read in one IO, using the scatter gather mechanism. In write we constrain our IO to only be incomplete on a single stripe. Meaning either the complete IO is within a single stripe so we might have pages to read from both beginning or end of the strip. Or we have some reading to do at beginning but end at strip boundary. The left over pages are pushed to the next IO by the API already established by previous work, where an IO offset/length combination presented to the ORE might get the length truncated and the user must re-submit the leftover pages. (Both exofs and NFS support this) But any ORE user should make it's best effort to align it's IO before hand and avoid complications. A cached ore_layout->stripe_size member can be used for that calculation. (NOTE: that ORE demands that stripe_size may not be bigger then 32bit) What else? Well read it and tell me. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
2011-10-24ore: RAID5 readBoaz Harrosh
This patch introduces the first stage of RAID5 support mainly the skip-over-raid-units when reading. For writes it inserts BLANK units, into where XOR blocks should be calculated and written to. It introduces the new "general raid maths", and the main additional parameters and components needed for raid5. Since at this stage it could corrupt future version that actually do support raid5. The enablement of raid5 mounting and setting of parity-count > 0 is disabled. So the raid5 code will never be used. Mounting of raid5 is only enabled later once the basic XOR write is also in. But if the patch "enable RAID5" is applied this code has been tested to be able to properly read raid5 volumes and is according to standard. Also it has been tested that the new maths still properly supports RAID0 and grouping code just as before. (BTW: I have found more bugs in the pnfs-obj RAID math fixed here) The ore.c file is getting too big, so new ore_raid.[hc] files are added that will include the special raid stuff that are not used in striping and mirrors. In future write support these will get bigger. When adding the ore_raid.c to Kbuild file I was forced to rename ore.ko to libore.ko. Is it possible to keep source file, say ore.c and module file ore.ko the same even if there are multiple files inside ore.ko? Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
2011-10-24ore: Make ore_calc_stripe_info EXPORT_SYMBOLBoaz Harrosh
ore_calc_stripe_info is needed by exofs::export.c for the layout calculations. Make it exportable Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
2011-10-14ore/exofs: Change ore_check_io APIBoaz Harrosh
Current ore_check_io API receives a residual pointer, to report partial IO. But it is actually not used, because in a multiple devices IO there is never a linearity in the IO failure. On the other hand if every failing device is reported through a received callback measures can be taken to handle only failed devices. One at a time. This will also be needed by the objects-layout-driver for it's error reporting facility. Exofs is not currently using the new information and keeps the old behaviour of failing the complete IO in case of an error. (No partial completion) TODO: Use an ore_check_io callback to set_page_error only the failing pages. And re-dirty write pages. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
2011-10-14ore/exofs: Define new ore_verify_layoutBoaz Harrosh
All users of the ore will need to check if current code supports the given layout. For example RAID5/6 is not currently supported. So move all the checks from exofs/super.c to a new ore_verify_layout() to be used by ore users. Note that any new layout should be passed through the ore_verify_layout() because the ore engine will prepare and verify some internal members of ore_layout, and assumes it's called. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
2011-10-14ore: Support for partial component tableBoaz Harrosh
Users like the objlayout-driver would like to only pass a partial device table that covers the IO in question. For example exofs divides the file into raid-group-sized chunks and only serves group_width number of devices at a time. The partiality is communicated by setting ore_componets->first_dev and the array covers all logical devices from oc->first_dev upto (oc->first_dev + oc->numdevs) The ore_comp_dev() API receives a logical device index and returns the actual present device in the table. An out-of-range dev_index will BUG. Logical device index is the theoretical device index as if all the devices of a file are present. .i.e: total_devs = group_width * mirror_p1 * group_count 0 <= dev_index < total_devs Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
2011-10-14ore: cleanup: Embed an ore_striping_info inside ore_io_stateBoaz Harrosh
Now that each ore_io_state covers only a single raid group. A single striping_info math is needed. Embed one inside ore_io_state to cache the calculation results and eliminate an extra call. Also the outer _prepare_for_striping is removed since it does nothing. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
2011-10-04ore/exofs: Change the type of the devices array (API change)Boaz Harrosh
In the pNFS obj-LD the device table at the layout level needs to point to a device_cache node, where it is possible and likely that many layouts will point to the same device-nodes. In Exofs we have a more orderly structure where we have a single array of devices that repeats twice for a round-robin view of the device table This patch moves to a model that can be used by the pNFS obj-LD where struct ore_components holds an array of ore_dev-pointers. (ore_dev is newly defined and contains a struct osd_dev *od member) Each pointer in the array of pointers will point to a bigger user-defined dev_struct. That can be accessed by use of the container_of macro. In Exofs an __alloc_dev_table() function allocates the ore_dev-pointers array as well as an exofs_dev array, in one allocation and does the addresses dance to set everything pointing correctly. It still keeps the double allocation trick for the inodes round-robin view of the table. The device table is always allocated dynamically, also for the single device case. So it is unconditionally freed at umount. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
2011-10-03ore: Make ore_striping_info and ore_calc_stripe_info publicBoaz Harrosh
The struct ore_striping_info will be used later in other structures. And ore_calc_stripe_info as well. Rename them make struct ore_striping_info public. ore_calc_stripe_info is still static, will be made public on first use. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
2011-10-03exofs: Remove unused data_map member from exofs_sb_infoBoaz Harrosh
The struct pnfs_osd_data_map data_map member of exofs_sb_info was never used after mount. In fact all it's members were duplicated by the ore_layout structure. So just remove the duplicated information. Also removed some stupid, but perfectly supported, restrictions on layout parameters. The case where num_devices is not divisible by mirror_count+1 is perfectly fine since the rotating device view will eventually use all the devices it can get. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: Benny Halevy <bhalevy@tonian.com>
2011-10-03exofs: Rename struct ore_components comps => ocBoaz Harrosh
ore_components already has a comps member so this leads to things like comps->comps which is annoying. the name oc was already used in new code. So rename all old usage of ore_components comps => ore_components oc. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
2011-08-06exofs: Rename raid engine from exofs/ios.c => oreBoaz Harrosh
ORE stands for "Objects Raid Engine" This patch is a mechanical rename of everything that was in ios.c and its API declaration to an ore.c and an osd_ore.h header. The ore engine will later be used by the pnfs objects layout driver. * File ios.c => ore.c * Declaration of types and API are moved from exofs.h to a new osd_ore.h * All used types are prefixed by ore_ from their exofs_ name. * Shift includes from exofs.h to osd_ore.h so osd_ore.h is independent, include it from exofs.h. Other than a pure rename there are no other changes. Next patch will move the ore into it's own module and will export the API to be used by exofs and later the layout driver Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
