This patch converts the EMC device handler to use a proper
state machine. We now also parse the extended INQUIRY
information to determine if long trespass commands are
supported. And we're now using the long trespass command
correctly. And finally there's now an check at init time
to refuse to attach to devices not supporting EMC-specific
VPD pages.
Signed-off-by: Hannes Reinecke <hare@suse.de>
Signed-off-by: Chandra Seetharaman <sekharan@us.ibm.com>
Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
Instead of having each and every driver implement its own
device table scanning code we should rather implement a common
routine and scan the device tables there.
This allows us also to implement a general notifier chain
callback for all device handler instead for one per handler.
[sekharan: Fix rejections caused by conflicting bug fix]
Daniel Debonzi reports that he has managed to wrap host_no. Increasing
the number of host numbers available to 32-bit from 16-bit allows the
problem to be evaded for another hundred years.
Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
Kobjects do not have a limit in name size since a while, so stop
pretending that they do.
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (102 commits)
[SCSI] scsi_dh: fix kconfig related build errors
[SCSI] sym53c8xx: Fix bogus sym_que_entry re-implementation of container_of
[SCSI] scsi_cmnd.h: remove double inclusion of linux/blkdev.h
[SCSI] make struct scsi_{host,target}_type static
[SCSI] fix locking in host use of blk_plug_device()
[SCSI] zfcp: Cleanup external header file
[SCSI] zfcp: Cleanup code in zfcp_erp.c
[SCSI] zfcp: zfcp_fsf cleanup.
[SCSI] zfcp: consolidate sysfs things into one file.
[SCSI] zfcp: Cleanup of code in zfcp_aux.c
[SCSI] zfcp: Cleanup of code in zfcp_scsi.c
[SCSI] zfcp: Move status accessors from zfcp to SCSI include file.
[SCSI] zfcp: Small QDIO cleanups
[SCSI] zfcp: Adapter reopen for large number of unsolicited status
[SCSI] zfcp: Fix error checking for ELS ADISC requests
[SCSI] zfcp: wait until adapter is finished with ERP during auto-port
[SCSI] ibmvfc: IBM Power Virtual Fibre Channel Adapter Client Driver
[SCSI] sg: Add target reset support
[SCSI] lib: Add support for the T10 (SCSI) Data Integrity Field CRC
[SCSI] sd: Move scsi_disk() accessor function to sd.h
Do not automatically "select" SCSI_DH for dm-multipath. If SCSI_DH
doesn't exist,just do not allow hardware handlers to be used.
Handle SCSI_DH being a module also. Make sure it doesn't allow DM_MULTIPATH
to be compiled in when SCSI_DH is a module.
[jejb: added comment for Kconfig syntax]
Reported-by: Randy Dunlap <randy.dunlap@oracle.com>
Reported-by: Andrew Morton <akpm@linux-foundation.org>
Adds a new scsi_device flag, start_stop_pwr_cond: If enabled, the sd
driver will not send plain START STOP UNIT commands but ones with the
power condition field set to 3 (standby) or 1 (active) respectively.
Some FireWire disk firmwares do not stop the motor if power condition is
zero. Or worse, they become unresponsive after a START STOP UNIT with
power condition = 0 and start = 0.
http://lkml.org/lkml/2008/4/29/704
This patch only adds the necessary code to sd_mod but doesn't activate
it. Follow-up patches to the FireWire drivers will add detection of
affected devices and enable the code for them.
I did not add power condition values to scsi_error.c::scsi_eh_try_stu()
for now. The three firmwares which suffer from above mentioned problems
do not need START STOP UNIT in the error handler, and they are not
adversely affected by START STOP UNIT with power condition = 0 and start
= 1 (like scsi_eh_try_stu() sends it if scsi_device.allow_restart is
enabled).
Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
Tested-by: Tino Keitel <tino.keitel@gmx.de>
Signed-off-by: Alexander Beregalov <a.beregalov@gmail.com>
Move the accessor functions for the scsi_cmnd status from zfcp to the
SCSI include file. Change the interface to the functions to pass the
scsi_cmnd pointer instead of the status pointer.
Signed-off-by: Martin Petermann <martin@linux.vnet.ibm.com>
Signed-off-by: Christof Schmitt <christof.schmitt@de.ibm.com>
Adds support for target reset to SG_SCSI_RESET.
Signed-off-by: Brian King <brking@linux.vnet.ibm.com>
Acked-by: Douglas Gilbert <dougg@torque.net>
Christoph objected to having sd.h in include/scsi since it is internal
to the sd driver. Move it to drivers/scsi/sd.h.
Let through upto the largest command of 260 defined by the scsi standard.
iscsi core supports this already. Now that the scsi-ml supports it we can
start using large commands.
[jejb:rejections fixed up]
Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
Acked-by: Mike Christie <michaelc@cs.wisc.edu>
The recv lock was defined so the iscsi layer could block
the recv path from processing IO during recovery. It
turns out iser just set a lock to that pointer which was pointless.
We now disconnect the transport connection before doing recovery
so we do not need the recv lock. For iscsi_tcp we still stop
the recv path incase older tools are being used.
This patch also has iscsi_itt_to_ctask user grab the session lock
and has the caller access the task with the lock or get a ref
to it in case the target is broken and sends a tmf success response
then sends data or a response for the command that was supposed to
be affected bty the tmf.
Signed-off-by: Mike Christie <michaelc@cs.wisc.edu>
Drivers expect that the cmds_max value they pass to the iscsi layer
is the max scsi commands + mgmt tasks. This patch implements that
and fixes some checks for nr cmd limits.
This adds two new attrs used for creating initiator ports and
binding sessions to hardware.
The session level initiatorname:
Since bnx2i does a scsi_host per host device, we need to add the
iface initiator port settings on the session, so we can create
multiple initiator ports (each with different inames) per device/scsi_host.
The current iname reflects that qla4xxx can have one iname per hba, and we are
allocating a host per session for software. The iname on the host will
remain so we can export and set the hba level qla4xxx setting.
The ifacename attr:
To bind a session to a some peice of hardware in userspace we maintain
some mappings, but during boot or iscsid restart (iscsid contains the user
space part of the driver) we need to be able to figure out which of those
host mappings abstractions maps to certain sessions. This patch adds
a ifacename attr, which userspace can set to id the host side of the
endpoint across pivot_roots and iscsid restarts.
Add sysfs representation for the endpoint, so userspace can match the
host and session to the endpoint. This will allow us to set the host's
parent correctly at host creation time.
The next patches will convert tcp and iser, and fix iser's dma_mask
bug.
session list
Currently we duplicate the list of sessions, because we were using the
test for if a session was on the host list to indicate if the session
was bound or unbound. We can instead use the target_id and fix up
the class so that drivers like bnx2i do not have to manage the target id
space.
This is the second part of the iscsi task merging, and
all it does it rename iscsi_cmd_task to iscsi_task and
mtask/ctask to just task.
There is no need to have the mgmt and cmd tasks separate
structs. It used to save a lot of memory when we overprealocated
memory for tasks, but the next patches will set up the
driver so in the future they can use a mempool or some other
common scsi command allocator and common tagging.
Currently to get a ctask from the session cmd array, you have to
know to use the itt modifier. To make this easier on LLDs and
so in the future we can easilly kill the session array and use
the host shared map instead, this patch adds a nice wrapper
to strip the itt into a session->cmds index and return a ctask.
Some drivers want to be able to just pass in the driver data pointers
to the iscsi objects. To enable this we need the iscsi printk macro
to cast the object.
This removes the session and conn data_size fields from the iscsi_transport.
Just pass in the value like with host allocation. This patch also makes
it so the LLD iscsi_conn data is allocated with the iscsi_cls_conn.
This finishes the host/session unbinding, by adding some helpers
to add and remove hosts and the session they manage.
bnx2i allocates a host per netdevice but will use libiscsi,
so this unbinds the session from the host in that code.
This will also be useful for the iser parent device dma settings
fixes.
This renames the iscsi_host to iscsi_cls_host to match the other
structs, because libiscsi wants to use the iscsi_host name in
the future.
max_cmd_len and max_conn are not really used. max_cmd_len is
always 16 and can be set by the LLD. max_conn is always one
since we do not support MCS.
iscsi offload (bnx2i and qla4xx) allocate a scsi host per hba,
so the session creation path needs a shost/host_no argument.
Software iscsi/iser will follow the same behabior as before
where it allcoates a host per session, but in the future iser
will probably look more like bnx2i where the host's parent is
the hardware (rnic for iser and for bnx2i it is the nic), because
it does not use a socket layer like how iscsi_tcp does.
Some of the storage devices (that can be accessed through multiple paths),
do need some special handling for
1. Activating the passive path of the storage access.
2. Decode and handle the special sense codes returned by the devices.
3. Handle the I/Os being sent to the passive path, especially
during the device probe time.
when accessed through multiple paths.
As of today this special device handling is done at the dm-multipath
layer using dm-handlers. That works well for (1); for (2) to be handled
at dm layer, scsi sense information need to be exported from SCSI to dm-layer,
which is not very attractive; (3) cannot be done at all at the dm layer.
Device handler has been moved to SCSI mainly to handle (2) and (3) properly.
Signed-off-by: Mike Anderson <andmike@linux.vnet.ibm.com>
[SCSI] aic94xx: fix section mismatch
[SCSI] u14-34f: Fix 32bit only problem
[SCSI] dpt_i2o: sysfs code
[SCSI] dpt_i2o: 64 bit support
[SCSI] dpt_i2o: move from virt_to_bus/bus_to_virt to dma_alloc_coherent
[SCSI] dpt_i2o: use standard __init / __exit code
[SCSI] megaraid_sas: fix suspend/resume sections
[SCSI] aacraid: Add Power Management support
[SCSI] aacraid: Fix jbod operations scan issues
[SCSI] aacraid: Fix warning about macro side-effects
[SCSI] add support for variable length extended commands
[SCSI] Let scsi_cmnd->cmnd use request->cmd buffer
[SCSI] bsg: add large command support
[SCSI] aacraid: Fix down_interruptible() to check the return value correctly
[SCSI] megaraid_sas; Update the Version and Changelog
[SCSI] ibmvscsi: Handle non SCSI error status
[SCSI] bug fix for free list handling
[SCSI] ipr: Rename ipr's state scsi host attribute to prevent collisions
[SCSI] megaraid_mbox: fix Dell CERC firmware problem
Add support for variable-length, extended, and vendor specific
CDBs to scsi-ml. It is now possible for initiators and ULD's
to issue these types of commands. LLDs need not change much.
All they need is to raise the .max_cmd_len to the longest command
they support (see iscsi patch).
- clean-up some code paths that did not expect commands to be
larger than 16, and change cmd_len members' type to short as
char is not enough.
Signed-off-by: Benny Halevy <bhalevy@panasas.com>
- struct scsi_cmnd had a 16 bytes command buffer of its own.
This is an unnecessary duplication and copy of request's
cmd. It is probably left overs from the time that scsi_cmnd
could function without a request attached. So clean that up.
- Once above is done, few places, apart from scsi-ml, needed
adjustments due to changing the data type of scsi_cmnd->cmnd.
- Lots of drivers still use MAX_COMMAND_SIZE. So I have left
that #define but equate it to BLK_MAX_CDB. The way I see it
and is reflected in the patch below is.
MAX_COMMAND_SIZE - means: The longest fixed-length (*) SCSI CDB
as per the SCSI standard and is not related
to the implementation.
BLK_MAX_CDB. - The allocated space at the request level
- I have audit all ISA drivers and made sure none use ->cmnd in a DMA
Operation. Same audit was done by Andi Kleen.
(*)fixed-length here means commands that their size can be determined
by their opcode and the CDB does not carry a length specifier, (unlike
the VARIABLE_LENGTH_CMD(0x7f) command). This is actually not exactly
true and the SCSI standard also defines extended commands and
vendor specific commands that can be bigger than 16 bytes. The kernel
will support these using the same infrastructure used for VARLEN CDB's.
So in effect MAX_COMMAND_SIZE means the maximum size command
scsi-ml supports without specifying a cmd_len by ULD's
Count FMR alignment violations per session as part of the iscsi
statistics.
Signed-off-by: Eli Dorfman <elid@voltaire.com>
Signed-off-by: Roland Dreier <rolandd@cisco.com>
The current target allocation code registeres each possible target
with sysfs; it will be deleted again if no useable LUN on this target
was found. This results in a string of 'target add/target remove' uevents.
Based on a patch by Hannes Reinecke <hare@suse.de> this patch reworks
the target allocation code so that only uevents for existing targets
are sent. The sysfs registration is split off from the existing
scsi_target_alloc() into a in a new scsi_add_target() function, which
should be called whenever an existing target is found. Only then a
uevent is sent, so we'll be generating events for existing targets
only.
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-2.6: (36 commits)
SCSI: convert struct class_device to struct device
DRM: remove unused dev_class
IB: rename "dev" to "srp_dev" in srp_host structure
IB: convert struct class_device to struct device
memstick: convert struct class_device to struct device
driver core: replace remaining __FUNCTION__ occurrences
sysfs: refill attribute buffer when reading from offset 0
PM: Remove destroy_suspended_device()
Firmware: add iSCSI iBFT Support
PM: Remove legacy PM (fix)
Kobject: Replace list_for_each() with list_for_each_entry().
SYSFS: Explicitly include required header file slab.h.
Driver core: make device_is_registered() work for class devices
PM: Convert wakeup flag accessors to inline functions
PM: Make wakeup flags available whenever CONFIG_PM is set
PM: Fix misuse of wakeup flag accessors in serial core
Driver core: Call device_pm_add() after bus_add_device() in device_add()
PM: Handle device registrations during suspend/resume
block: send disk "change" event for rescan_partitions()
sysdev: detect multiple driver registrations
Fixed trivial conflict in include/linux/memory.h due to semaphore header
file change (made irrelevant by the change to mutex).
It's big, but there doesn't seem to be a way to split it up smaller...
Signed-off-by: Tony Jones <tonyj@suse.de>
Cc: Roland Dreier <rolandd@cisco.com>
Cc: Sean Hefty <sean.hefty@intel.com>
Cc: Hal Rosenstock <hal.rosenstock@gmail.com>
Cc: James Bottomley <James.Bottomley@HansenPartnership.com>
None of these files use any of the functionality promised by
asm/semaphore.h. It's possible that they (or some user of them) rely
on it dragging in some unrelated header file, but I can't build all
these files, so we'll have to fix any build failures as they come up.
Support for extended CDBs in iscsi.
All we need is to check if command spills over 16 bytes then allocate
an iscsi-extended-header for the leftovers.
Reviewed-by: Pete Wyckoff <pw@osc.edu>
Two functions in include/scsi/sas_ata.h don't have static inlines
leading to problems if they're built in:
On Thu, 2008-04-03 at 14:06 +0200, Toralf Förster wrote:
> drivers/scsi/mvsas.o: In function `sas_ata_init_host_and_port':
> mvsas.c:(.text+0x0): multiple definition of `sas_ata_init_host_and_port'
> drivers/scsi/libsas/built-in.o:(.text+0x37f4): first defined here
> drivers/scsi/mvsas.o: In function `sas_ata_task_abort':
> mvsas.c:(.text+0x7): multiple definition of `sas_ata_task_abort'
> drivers/scsi/libsas/built-in.o:(.text+0x37fb): first defined here
> make[2]: *** [drivers/scsi/built-in.o] Error 1
> make[1]: *** [drivers/scsi] Error 2
> make: *** [drivers] Error 2
Add the correct static inline modifiers.
Tested-by: Toralf Förster <toralf.foerster@gmx.de>
This adds scsi_build_sense_buffer, a simple helper function to build
sense data in a buffer.
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
This is needed by things like USB storage that want to set up static
commands for later use at start of day.
LLDs need to copies data between the SG table in struct scsi_cmnd and
liner buffer. So they use the helper functions like
sg_copy_from_buffer(scsi_sglist(sc), scsi_sg_count(sc), buf, buflen)
sg_copy_to_buffer(scsi_sglist(sc), scsi_sg_count(sc), buf, buflen)
This patch just adds wrapper functions:
scsi_sg_copy_from_buffer(sc, buf, buflen)
scsi_sg_copy_to_buffer(sc, buf, buflen)
The problem is that serveral drivers are sending a target reset from the
device reset handler, and if we have multiple devices a target reset gets
sent for each device when only one would be sufficient. And if we do a target
reset it affects all the commands on the target so the device reset handler
code only cleaning up one devices's commands makes programming the driver a
little more difficult than it should be.
This patch adds a target reset handler, which drivers can use to send
a target reset. If successful it cleans up the commands for a devices
accessed through that starget.
Provide a facility to use the request_firmware() interface to get a SAS
address from userspace. This can be used by SAS LLDDs that cannot
obtain the address from the host adapter.
Signed-off-by: Darrick J. Wong <djwong@us.ibm.com>
blocking/unblocking
For qla4xxx, we could be starting a session, but some error (network,
target, IO from a device that got started, etc) could cause the session
to fail and curring the block/unblock and state manipulation could race
with each other. This patch just has those operations done in the
single threaded iscsi eh work queue, so that way they are serialized.
This is needed by the to be added I_T reset function in aic94xx. It
needs to know the local phy so it can send a link or hard reset along
the path.
Since the sg chaining patches went in, our current value of 255 for
SG_ALL excites chaining on some drivers which cannot support it (and
would thus oops). Redefine SG_ALL to mean no sg table size
preference, but use the single allocation (non chained) limit. This
also helps for drivers that use it to size an internal table.
We'll do an opt in system later where truly chaining supporting
drivers can define their sg_tablesize to be anything up to
SCSI_MAX_SG_CHAIN_ELEMENTS.
Small cleanups in scsi_host.h. Few #defines make me wonder if their
description is still up to date..?
Signed-off-by: Pavel Machek <pavel@suse.cz>
A lot of SCSI command replies have a protocol ID field. Add
definitions for the interpretation of that from SPC-3.
The session age mask is only 4 bits, but session->age is 32. When
it gets larger then 15 and we try to or the bits some bits get
dropped and the check for session age in iscsi_verify_itt is useless.
The ISCSI_CID_MASK related bits are also useless since cid is always
one.
Some iscsi class messages have the dev_printk prefix and some libiscsi
and iscsi_tcp messages have "iscsi" or the module name as a prefix which
is normally pretty useless when trying to figure out which session
or connection the message is attached to. This patch adds iscsi lib
and class dev_printks so all messages have a common prefix that
can be used to figure out which object printed it.
