path: root/include/scsi
2009-06-21sd, sr: fix Driver 'sd' needs updating messageHannes Reinecke
If a SCSI ULD driver sets blk_queue_prep_rq(), it should clean it up itself on remove(), and not from the bus callbacks. This removes the need to hook into bus->remove(), which should not be used at the same time as driver->remove(). [jejb: fix sdkp initialisation problem due to mismerge] Signed-off-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-06-21libfc: Add runtime debugging with debug_logging module parameterRobert Love
This patch adds the /sys/module/libfc/parameters/debug_logging file to sysfs as a module parameter. It accepts an integer bitmask for logging. Currently it supports: bit LSB 0 = general libfc debugging 1 = lport debugging 2 = disc debugging 3 = rport debugging 4 = fcp debugging 5 = EM debugging 6 = exch/seq debugging 7 = scsi logging (mostly error handling) the other bits are not used at this time. The patch converts all of the libfc source files to use these new macros and removes the old FC_DBG macro. Signed-off-by: Robert Love <robert.w.love@intel.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-06-21libiscsi: don't run scsi eh if iscsi task is making progressMike Christie
If we are sending or receiving data for the task successfully do not run the scsi eh, because we know the task is making progress. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-06-17Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: [SCSI] aic79xx: make driver respect nvram for IU and QAS settings [SCSI] don't attach ULD to Dell Universal Xport [SCSI] lpfc 8.3.3 : Update driver version to 8.3.3 [SCSI] lpfc 8.3.3 : Add support for Target Reset handler entrypoint [SCSI] lpfc 8.3.3 : Fix a couple of spin_lock and memory issues and a crash [SCSI] lpfc 8.3.3 : FC/FCOE discovery fixes [SCSI] lpfc 8.3.3 : Fix various SLI-3 vs SLI-4 differences [SCSI] qla2xxx: Resolve a performance issue in interrupt [SCSI] cnic, bnx2i: Fix build failure when CONFIG_PCI is not set. [SCSI] nsp_cs: time_out reaches -1 [SCSI] qla2xxx: fix printk format warnings [SCSI] ncr53c8xx: div reaches -1 [SCSI] compat: don't perform unneeded copy in sg_io code [SCSI] zfcp: Update FC pass-through support [SCSI] zfcp: Add FC pass-through support [SCSI] FC Pass Thru support
2009-06-15[SCSI] aic79xx: make driver respect nvram for IU and QAS settingsJames Bottomley
This patch allows the Adaptec firmware to pass on its values for Packetize and QAS. To do this, the settings max_iu and max_qas have been introduced into the SPI transport class and populated from the adaptec NVram tables. Domain validation in the SPI transport class will respect the max settings when configuring to the highest possible speed for testing. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-06-15Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: Documentation/feature-removal-schedule.txt drivers/scsi/fcoe/fcoe.c net/core/drop_monitor.c net/core/net-traces.c
2009-06-12[SCSI] FC Pass Thru supportJames Smart
Attached is the ELS/CT pass-thru patch for the FC Transport. The patch creates a generic framework that lays on top of bsg and the SGIO v4 ioctl in order to pass transaction requests to LLDD's. The interface supports the following operations: On an fc_host basis: Request login to the specified N_Port_ID, creating an fc_rport. Request logout of the specified N_Port_ID, deleting an fc_rport Send ELS request to specified N_Port_ID w/o requiring a login, and wait for ELS response. Send CT request to specified N_Port_ID and wait for CT response. Login is required, but LLDD is allowed to manage login and decide whether it stays in place after the request is satisfied. Vendor-Unique request. Allows a LLDD-specific request to be passed to the LLDD, and the passing of a response back to the application. On an fc_rport basis: Send ELS request to nport and wait for ELS response. Send CT request to nport and wait for CT response. The patch also exports several headers from include/scsi such that they can be available to user-space applications: include/scsi/scsi.h include/scsi/scsi_netlink.h include/scsi/scsi_netlink_fc.h include/scsi/scsi_bsg_fc.h For further information, refer to the last RFC: http://marc.info/?l=linux-scsi&m=123436574018579&w=2 Note: Documentation is still spotty and will be added later. [bharrosh@panasas.com: update for new block API] Signed-off-by: James Smart <james.smart@emulex.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-06-12[SCSI] Merge branch 'linus'James Bottomley
Conflicts: drivers/message/fusion/mptsas.c fixed up conflict between req->data_len accessors and mptsas driver updates. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-06-11Merge branch 'for-2.6.31' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.31' of git://git.kernel.dk/linux-2.6-block: (153 commits) block: add request clone interface (v2) floppy: fix hibernation ramdisk: remove long-deprecated "ramdisk=" boot-time parameter fs/bio.c: add missing __user annotation block: prevent possible io_context->refcount overflow Add serial number support for virtio_blk, V4a block: Add missing bounce_pfn stacking and fix comments Revert "block: Fix bounce limit setting in DM" cciss: decode unit attention in SCSI error handling code cciss: Remove no longer needed sendcmd reject processing code cciss: change SCSI error handling routines to work with interrupts enabled. cciss: separate error processing and command retrying code in sendcmd_withirq_core() cciss: factor out fix target status processing code from sendcmd functions cciss: simplify interface of sendcmd() and sendcmd_withirq() cciss: factor out core of sendcmd_withirq() for use by SCSI error handling code cciss: Use schedule_timeout_uninterruptible in SCSI error handling code block: needs to set the residual length of a bidi request Revert "block: implement blkdev_readpages" block: Fix bounce limit setting in DM Removed reference to non-existing file Documentation/PCI/PCI-DMA-mapping.txt ... Manually fix conflicts with tracing updates in: block/blk-sysfs.c drivers/ide/ide-atapi.c drivers/ide/ide-cd.c drivers/ide/ide-floppy.c drivers/ide/ide-tape.c include/trace/events/block.h kernel/trace/blktrace.c
2009-06-10[SCSI] osduld: use filp_open() when looking up an osd-deviceBoaz Harrosh
This patch was inspired by Al Viro, for simplifying and fixing the retrieval of osd-devices by in-kernel users, eg: file systems. In-Kernel users, now, go through the same path user-mode does by opening a file on the osd char-device and though holding a reference to both the device and the Module. A file pointer was added to the osd_dev structure which is now allocated for each user. The internal osd_dev is no longer exposed outside of the uld. I wanted to do that for a long time so each libosd user can have his own defaults on the device. The API is left the same, so user code need not change. It is no longer needed to open/close a file handle on the osd char-device from user-mode, before mounting an exofs on it. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> CC: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-06-10[SCSI] libosd: Define an osd_dev wrapper to retrieve the request_queueBoaz Harrosh
libosd users that need to work with bios, must sometime use the request_queue associated with the osd_dev. Make a wrapper for that, and convert all in-tree users. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-06-10[SCSI] libosd: osd_req_{read,write} takes a length parameterBoaz Harrosh
For supporting of chained-bios we can not inspect the first bio only, as before. Caller shall pass the total length of the request, ie. sum_bytes(bio-chain). Also since the bio might be a chain we don't set it's direction on behalf of it's callers. The bio direction should be properly set prior to this call. So fix a couple of write users that now need to set the bio direction properly [In this patch I change both library code and user sites at exofs, to make it easy on integration. It should be submitted via James's scsi-misc tree.] Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> CC: Jeff Garzik <jeff@garzik.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-06-10[SCSI] libosd: osd_req_{read,write}_kern new APIBoaz Harrosh
By popular demand, define usefull wrappers for osd_req_read/write that recieve kernel pointers. All users had their own. Also remove these from exofs Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-06-10[SCSI] libosd: OSD2r05: Attribute definitionsBoaz Harrosh
Some New revision 5 Attribute definitions. Some missing definitions of Attributes and pages Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-06-10[SCSI] libosd: OSD2r05: Additional command enumsBoaz Harrosh
Add all constant definitions of new OSD commands added in revision 4 & 5. Mainly for creating snapshots and clones. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-06-09[SCSI] iscsi class: Add new NETLINK_ISCSI messages for cnic/bnx2i driver.Michael Chan
Add ISCSI_NETLINK messages for iSCSI NICs to get information such as path from userspace. Original iscsid messages are now always sent as multicast to group 1. The new messages are sent to group 2. The multicast changes were made by Mike Christie. Signed-off-by: Michael Chan <mchan@broadcom.com> Signed-off-by: Benjamin Li <benli@broadcom.com> Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-06-08[SCSI] net, libfcoe: Add the FCoE Initialization Protocol ethertypeJoe Eykholt
FIP is the FCoE Initialization Protocol and this patch adds the protocol ethertype to the kernel's list of ethertypes. Signed-off-by: Joe Eykholt <jeykholt@cisco.com> Signed-off-by: Robert Love <robert.w.love@intel.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-05-23[SCSI] libfc,fcoe,fnic: Separate rport and lport max retry countsAbhijeet Joglekar
This allows fnic to configure number of retries for lport and rport separately. Signed-off-by: Abhijeet Joglekar <abjoglek@cisco.com> Acked-by: Robert Love <robert.w.love@intel.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-05-23[SCSI] libiscsi: add task aborted stateMike Christie
If a task did not complete normally due to a TMF, libiscsi will now complete the task with the state ISCSI_TASK_ABRT_TMF. Drivers like bnx2i that need to free resources if a command did not complete normally can then check the task state. If a driver does not need to send a special command if we have dropped the session then they can check for ISCSI_TASK_ABRT_SESS_RECOV. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-05-23[SCSI] libiscsi: handle cleanup task racesMike Christie
bnx2i needs to send a hardware specific cleanup command if a command has not completed normally (iscsi/scsi response from target), and the session is still ok (this is the case when we send a TMF to stop the command). At this time it will need to drop the session lock. The problem with the current code is that fail_all_commands assumes we will hold the lock the entire time, so it uses list_for_each_entry_safe. If while bnx2i drops the session lock multiple cmds complete then list_for_each_entry_safe will not handle this correctly. This patch removes the running lists and just has us loop over the cmds array (in later patches we will then replace that array with a block tag map at the session level). It also fixes up the completion path so that if the TMF code and the normal recv path were completing the same command then they both do not try to do release the refcount taken when the task is queued. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-05-23[SCSI] libiscsi: export iscsi_itt_to_task for bnx2iMike Christie
bnx2i needs to be able to look up mgmt task like login and nop, because it does some processing of them on the completion path. This exports iscsi_itt_to_task so it can look up the task. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-05-23[SCSI] iscsi: pass ep connect shostMike Christie
When we create the tcp/ip connection by calling ep_connect, we currently just go by the routing table info. I think there are two problems with this. 1. Some drivers do not have access to a routing table. Some drivers like qla4xxx do not even know about other ports. 2. If you have two initiator ports on the same subnet, the user may have set things up so that session1 was supposed to be run through port1. and session2 was supposed to be run through port2. It looks like we could end with both sessions going through one of the ports. Fixes for cxgb3i from Karen Xie. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-05-22Merge branch 'master' into for-2.6.31Jens Axboe
Conflicts: drivers/block/hd.c drivers/block/mg_disk.c Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-05-18Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/scsi/fcoe/fcoe.c
2009-05-17fcoe: adds spma mode supportVasu Dev
If we can find a type NETDEV_HW_ADDR_T_SAN mac address from the corresponding netdev for a fcoe interface then sets up added the fc->ctlr.spma flag and stores spma mode address in ctl_src_addr. In case the spma flag is set then:- 1. Adds spma mode MAC address in ctl_src_addr as secondary MAC address, the FLOGI for FIP and pre-FIP will go out using this address. 2. Cleans up stored spma MAC address in ctl_src_addr in fcoe_netdev_cleanup. 3. Sets up spma bit in fip_flags for FIP solicitations along with exiting FPMA bit setting. 4. Initialize the FLOGI FIP MAC descriptor to stored spma MAC address in ctl_src_addr. This is used as proposed FCoE MAC address from initiator along with both SPMA and FPMA bit set in FIP solicitation, in response the switch may grant any FPMA or SPMA mode MAC address to initiator. Removes FIP descriptor type checking against ELS type ELS_FLOGI in fcoe_ctlr_encaps to update a FIP MAC descriptor, instead now checks against FIP_DT_FLOGI. I've tested this with available FPMA-only FCoE switch but since data_src_addr is updated using same old code for both FPMA and SPMA modes with FIP or pre-FIP links, so added SPMA mode will work with SPMA-only switch also provided that switch grants a valid MAC address. Signed-off-by: Vasu Dev <vasu.dev@intel.com> Signed-off-by: Yi Zou <yi.zou@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-05-15[SCSI] fc-transport: Close state transition-window during rport deletion.Andrew Vasquez
Andrew Vasquez wrote: > fc-transport: Close state transition-window during rport deletion. > > After an rport's state has transitioned to FC_PORTSTATE_BLOCKED, > but, prior to making the upcall to 'block' the scsi-target > associated with an rport, queued commands can recycle and > ultimately run out of retries causing failures to propagate to > upper-level drivers. Close this transition-window by returning > the non-'retries' modifying DID_IMM_RETRY status for submitted > I/Os. The same can happen for iscsi when transitioning from logged in to failed and blocking the sdevs. This patch converts iscsi and fc's transitions back to use DID_IMM_RETRY instead of DID_TRANSPORT_DISRUPTED which has a limited number of retries that we do not want to use for handling this race. Signed-off-by: Andrew Vasquez <andrew.vasquez@qlogic.com> [Addition of iscsi and fc port online devloss case conversion by Mike Christie] Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-05-11block: convert to pos and nr_sectors accessorsTejun Heo
With recent cleanups, there is no place where low level driver directly manipulates request fields. This means that the 'hard' request fields always equal the !hard fields. Convert all rq->sectors, nr_sectors and current_nr_sectors references to accessors. While at it, drop superflous blk_rq_pos() < 0 test in swim.c. [ Impact: use pos and nr_sectors accessors ] Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Tested-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Grant Likely <grant.likely@secretlab.ca> Tested-by: Adrian McMenamin <adrian@mcmen.demon.co.uk> Acked-by: Adrian McMenamin <adrian@mcmen.demon.co.uk> Acked-by: Mike Miller <mike.miller@hp.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Cc: Borislav Petkov <petkovbb@googlemail.com> Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: Eric Moore <Eric.Moore@lsi.com> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Pete Zaitcev <zaitcev@redhat.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Paul Clements <paul.clements@steeleye.com> Cc: Tim Waugh <tim@cyberelk.net> Cc: Jeff Garzik <jgarzik@pobox.com> Cc: Jeremy Fitzhardinge <jeremy@xensource.com> Cc: Alex Dubov <oakad@yahoo.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Dario Ballabio <ballabio_dario@emc.com> Cc: David S. Miller <davem@davemloft.net> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: unsik Kim <donari75@gmail.com> Cc: Laurent Vivier <Laurent@lvivier.info> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-27[SCSI] libosd: OSD2r05: on-the-wire changes for latest OSD2 revision 5.Boaz Harrosh
OSC's OSD2 target: [git clone git://git.open-osd.org/osc-osd/ master] (Initiator code prior to this patch must use: "git checkout CDB_VER_OSD2r01" in the target tree above) This is a summery of the wire changes: * OSDv2_ADDITIONAL_CDB_LENGTH == 192 => 228 (Total CDB is now 236 bytes) * Attributes List Element Header grew, so attribute values are 8 bytes aligned. * Cryptographic keys and signatures are 20 => 32 * Few new definitions. (Still missing new standard definitions attribute values, these do not change wire format and will be added later when needed) Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-04-27[SCSI] libosd: OSD2r05: OSD_CRYPTO_KEYID_SIZE will grow 20 => 32 bytesBoaz Harrosh
In OSD2r04 draft, cryptographic key size changed to 32 bytes from OSD1's 20 bytes. This causes a couple of on-the-wire structures to change, including the CDB. In this patch the OSD1/OSD2 handling is separated out in regard to affected structures, but on-the-wire is still the same. All on the wire changes will be submitted in one patch for bisect-ability. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-04-27[SCSI] libosd: OSD2r05: Prepare for rev5 attribute list changesBoaz Harrosh
In OSD2r05 draft each attribute list element header was changed so attribute-value would be 8 bytes aligned. In OSD2r01-r04 it was aligned on 2 bytes. (This is because in OSD2r01 the complete element was 8 bytes padded at end but the header was not adjusted and caused permanent miss-alignment.) OSD1 elements are not padded and might be or might not be aligned. OSD1 is still supported. In this code we do all the code re-factoring to separate OSD1/OSD2 differences but do not change actual wire format. All wire format changes will happen in one patch later, for bisect-ability. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-04-27[SCSI] libfc: Fix compilation warnings with allmodconfigRobert Love
When building with a .config generated from 'make allmodconfig' some build warnings are generated. This patch corrects the warnings, adds a FC_FID_NONE (= 0) enumeration for FC-IDs and cleans up one variable naming to meet our variable naming conventions. For example, fc_lport's should be named "lport," not "lp." Signed-off-by: Robert Love <robert.w.love@intel.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-04-27[SCSI] libfc: Track rogue remote portsAbhijeet Joglekar
Rogue ports are currently not tracked on any list. The only reference to them is through any outstanding exchanges pending on the rogue ports. If the module is removed while a retry is set on a rogue port (say a Plogi retry for instance), this retry is not cancelled because there is no reference to the rogue port in the discovery rports list. Thus the local port can clean itself up, delete the exchange pool, and then the rogue port timeout can fire and try to start up another exchange. This patch tracks the rogue ports in a new list disc->rogue_rports. Creating a new list instead of using the disc->rports list keeps remote port code change to a minimum. 1) Whenever a rogue port is created, it is immediately added to the disc->rogue_rports list. 2) When the rogues port goes to ready, it is removed from the rogue list and the real remote port is added to the disc->rports list 3) The removal of the rogue from the disc->rogue_rports list is done in the context of the fc_rport_work() workQ thread in discovery callback. 4) Real rports are removed from the disc->rports list like before. Lookup is done only in the real rports list. This avoids making large changes to the remote port code. 5) In fc_disc_stop_rports, the rogues list is traversed in addition to the real list to stop the rogue ports and issue logoffs on them. This way, rogue ports get cleaned up when the local port goes away. 6) rogue remote ports are not removed from the list right away, but removed late in fc_rport_work() context, multiple threads can find the same remote port in the list and call rport_logoff(). Rport_logoff() only continues with the logoff if port is not in NONE state, thus preventing multiple logoffs and multiple list deletions. 7) Since the rport is removed from the disc list at a later stage (in the disc callback), incoming frames can find the rport even if rport_logoff() has been called on the rport. When rport_logoff() is called, the rport state is set to NONE, and we are trying to cancel all exchanges and retries on that port. While in this state, if an incoming Plogi/Prli/Logo or other frames match the rport, we should not reply because the rport is in the NONE state. Just drop the frame, since the rport will be deleted soon in the disc callback (fc_rport_work) 8) In fc_disc_single(), remove rport lookup and call to fc_disc_del_target. fc_disc_single() is called from recv_rscn_req() where rport lookup and rport_logoff is already done. Signed-off-by: Abhijeet Joglekar <abjoglek@cisco.com> Signed-off-by: Robert Love <robert.w.love@intel.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-04-27[SCSI] cxgb3i, iser, iscsi_tcp: set target can queueMike Christie
Set target can queue limit to the number of preallocated session tasks we have. This along with the cxgb3i can_queue patch will fix a throughput problem where it could only queue one LU worth of data at a time. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-04-13PM/Hibernate: Wait for SCSI devices scan to complete during resumeRafael J. Wysocki
There is a race between resume from hibernation and the asynchronous scanning of SCSI devices and to prevent it from happening we need to call scsi_complete_async_scans() during resume from hibernation. In addition, if the resume from hibernation is userland-driven, it's better to wait for all device probes in the kernel to complete before attempting to open the resume device. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-03[SCSI] fcoe, libfcoe: Add support for FIP. FCoE discovery and keep-alive.Joe Eykholt
FIP is the new standard way to discover Fibre-Channel Forwarders (FCFs) by sending solicitations and listening for advertisements from FCFs. It also provides for keep-alives and period advertisements so that both parties know they have connectivity. If the FCF loses connectivity to the storage fabric, it can send a Link Reset to inform the E_node. This version is also compatible with pre-FIP implementations, so no configured selection between FIP mode and non-FIP mode is required. We wait a couple seconds after sending the initial solicitation and then send an old-style FLOGI. If we receive any FIP frames, we use FIP only mode. If the old FLOGI receives a response, we disable FIP mode. After every reset or link up, this determination is repeated. Signed-off-by: Joe Eykholt <jeykholt@cisco.com> Signed-off-by: Vasu Dev <vasu.dev@intel.com> Signed-off-by: Robert Love <robert.w.love@intel.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-04-03[SCSI] fcoe: Add a header file defining the FIP protocol for FCoE.Joe Eykholt
Adds include/scsi/fc/fc_fip.h for FIP protocol definitions. Signed-off-by: Joe Eykholt <jeykholt@cisco.com> Signed-off-by: Vasu Dev <vasu.dev@intel.com> Signed-off-by: Robert Love <robert.w.love@intel.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-04-03[SCSI] fcoe, libfc: fix double fcoe_softc memory allocVasu Dev
The foce_softc mem was reserved by libfc_host_alloc as well as by fcoe_host_alloc. Removes one liner fcoe_host_alloc completely, instead directly calls libfc_host_alloc to alloc scsi_host with libfc for just one fcoe_softc as fcoe private data. Moves libfc_host_alloc to libfc.h since it is a libfc API, placed lport_priv API adjacent to libfc_host_alloc since this is related to scsi_host priv data. Signed-off-by: Vasu Dev <vasu.dev@intel.com> Signed-off-by: Robert Love <robert.w.love@intel.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-04-03[SCSI] fcoe: cleans up libfcoe.h and adds fcoe.h for fcoe moduleVasu Dev
Removes no where used several inline functions prefixed with skb_* and be16_to_cpu. Moves fcoe module specific func prototypes to fcoe.c from libfcoe.h, moved only need for build. Adds fcoe module header file fcoe.h and then moves fcoe module specific fcoe_percpu_s and fcoe_softc to fcoe.h from libfcoe.h. Moves all defines from fcoe.c to fcoe.h since now fcoe module has its own header file fcoe.h. [jejb: removed EXPORT_SYMBOL_GPL(fcoe_fc_crc) which caused a section mismatch] Signed-off-by: Vasu Dev <vasu.dev@intel.com> Signed-off-by: Robert Love <robert.w.love@intel.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-04-03[SCSI] fcoe: removes default sw transport code file fcoe_sw.cVasu Dev
Moves only required code from fcoe_sw.c to libfcoe.c towards having just one source file for fcoe module, this gets rid off default sw transport code in a separate fcoe_sw.c file. Very minor renaming along this move, dropped _sw_ or _SW_ use in names and replaced them by _if_ as a auxiliary interface functions. Now some of these funcs can be removed or merged with other func after fcoe transport is gone, but that should be in another patch to keep this patch simple. Now the libfcoe.c file name for fcoe module doesn't go along well, so the libfcoe.c file renaming to fcoe.c as the only single fcoe module file is done in next patch to keep this patch clean and small for review. Signed-off-by: Vasu Dev <vasu.dev@intel.com> Signed-off-by: Robert Love <robert.w.love@intel.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-04-03[SCSI] fcoe: removes fc_transport_fcoe.[ch] code filesVasu Dev
Remove unused fc_transport_fcoe.c and fc_transport_fcoe.h files. Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-04-03[SCSI] fcoe: prep work to completely remove fc_transport_fcoe codeVasu Dev
The fcoe transport code was added for generic FCoE transport infrastructure to allow additional offload related module loading on demand, this is not required anymore after recently added different offload approach by having offload related func ops in netdev. This patch removes fcoe transport related code use, calls functions directly between existing libfcoe.c and fcoe_sw.c for now, for example fcoe_sw_destroy and fcoe_sw_create calling. The fcoe_sw.c and libfcoe.c code will be further consolidated in later patches and then also the default fcoe sw transport code file fcoe_sw.c will be completely removed. The fcoe transport code files are completely removed in next patch to keep this patch simple for reviewing. [This patch is an update to a previous patch. This update resolves a build error as well as fixes a defect related to not calling fc_release_transport().] Signed-off-by: Vasu Dev <vasu.dev@intel.com> Signed-off-by: Robert Love <robert.w.love@intel.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-04-03[SCSI] fcoe: Use per-CPU kernel function for dev_stats instead of an arrayRobert Love
Remove the hotplug creation of dev_stats, we allocate for all possible CPUs now when we allocate the lport. v2: Durring the 2.6.30 merge window, before these patches were comitted, 'percpu_ptr' was renamed 'per_cpu_ptr'. This latest update updates this patch for the name change. Signed-off-by: Yi Zou <yi.zou@intel.com> Signed-off-by: Robert Love <robert.w.love@intel.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-04-03[SCSI] fcoe: Use percpu kernel funcs for struct fcoe_percpu_sRobert Love
Convert fcoe_percpu array to use the per-cpu variables that the kernel provides. Use the kernel's functions to access this structure. The cpu member of the fcoe_percpu_s is no longer needed, so this patch removes it too. Signed-off-by: Yi Zou <yi.zou@intel.com> Signed-off-by: Robert Love <robert.w.love@intel.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-04-03[SCSI] fcoe: Initialize all possilbe skb_queue(s) when module is loadedRobert Love
Currently the skb_queue is initialized every time the associated CPU goes online. This patch has libfcoe initializing the skb_queue for all possible CPUs when the module is loaded. This patch also re-orders some declarations in the fcoe_rcv() function so the structure declarations are grouped before the primitive declarations. Lastly, this patch converts all CPU indicies to use unsigned int since CPU indicies should not be negative. Signed-off-by: Robert Love <robert.w.love@intel.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-13[SCSI] iscsi class: remove host no argument from session creation calloutMike Christie
We do not need to have llds set the host no for the session's parent, because we know the session's parent is going to be the host. This removes it from the session creation callback and converts the drivers. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-13[SCSI] libiscsi: pass session failure a session structMike Christie
The api for conn and session failures is akward because one takes a conn from the lib and one takes a session from the class. This syncs up the interfaces to use structs from the lib. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-13[SCSI] iscsi lib: remove qdepth param from iscsi host allocationMike Christie
The qdepth setting was useful when we needed libiscsi to verify the setting. Now we just need to make sure if older tools passed in zero then we need to set some default. So this patch just has us use the sht->cmd_per_lun or if for LLD does a host per session then we can set it on per host basis. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-13[SCSI] iscsi lib: have lib create work queue for transmitting IOMike Christie
We were using the shost work queue which ended up being a little akward since all iscsi hosts need a thread for scanning, but only drivers hooked into libiscsi need a workqueue for transmitting. So this patch moves the xmit workqueue to the lib. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-13[SCSI] iscsi class: fix lock dep warning on logoutMike Christie
We never should hit the lock up that is spit out when lock dep is on and we logout. But we have been using the shost work queue in a odd way. This patch has us use the work queue for scanning instead of creating our own, and this ends up also killing the lock dep warnings. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-03-13[SCSI] libiscsi: don't cap queue depth in iscsi modulesMike Christie
There is no need to cap the queue depth in the modules. We set this in userspace and can do that there. For performance testing with ram based targets, this is helpful since we can have very high queue depths. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
