[ Upstream commit e9d3009cb936bd0faf0719f68d98ad8afb1e613b ]
The iSCSI target driver is the only target driver that does not wait for
ongoing commands to finish before freeing a session. Make the iSCSI target
driver wait for ongoing commands to finish before freeing a session. This
patch fixes the following KASAN complaint:
BUG: KASAN: use-after-free in __lock_acquire+0xb1a/0x2710
Read of size 8 at addr ffff8881154eca70 by task kworker/0:2/247
CPU: 0 PID: 247 Comm: kworker/0:2 Not tainted 5.4.0-rc1-dbg+ #6
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.12.0-1 04/01/2014
Workqueue: target_completion target_complete_ok_work [target_core_mod]
Call Trace:
dump_stack+0x8a/0xd6
print_address_description.constprop.0+0x40/0x60
__kasan_report.cold+0x1b/0x33
kasan_report+0x16/0x20
__asan_load8+0x58/0x90
lock_acquire+0xd3/0x200
_raw_spin_lock_irqsave+0x43/0x60
target_release_cmd_kref+0x162/0x7f0 [target_core_mod]
target_put_sess_cmd+0x2e/0x40 [target_core_mod]
lio_check_stop_free+0x12/0x20 [iscsi_target_mod]
transport_cmd_check_stop_to_fabric+0xd8/0xe0 [target_core_mod]
target_complete_ok_work+0x1b0/0x790 [target_core_mod]
process_one_work+0x549/0xa40
worker_thread+0x7a/0x5d0
kthread+0x1bc/0x210
ret_from_fork+0x24/0x30
Allocated by task 889:
save_stack+0x23/0x90
__kasan_kmalloc.constprop.0+0xcf/0xe0
kasan_slab_alloc+0x12/0x20
kmem_cache_alloc+0xf6/0x360
transport_alloc_session+0x29/0x80 [target_core_mod]
iscsi_target_login_thread+0xcd6/0x18f0 [iscsi_target_mod]
kthread+0x1bc/0x210
Freed by task 1025:
__kasan_slab_free+0x13a/0x190
kasan_slab_free+0x12/0x20
kmem_cache_free+0x146/0x400
transport_free_session+0x179/0x2f0 [target_core_mod]
transport_deregister_session+0x130/0x180 [target_core_mod]
iscsit_close_session+0x12c/0x350 [iscsi_target_mod]
iscsit_logout_post_handler+0x136/0x380 [iscsi_target_mod]
iscsit_response_queue+0x8de/0xbe0 [iscsi_target_mod]
iscsi_target_tx_thread+0x27f/0x370 [iscsi_target_mod]
kthread+0x1bc/0x210
The buggy address belongs to the object at ffff8881154ec9c0
which belongs to the cache se_sess_cache of size 352
The buggy address is located 176 bytes inside of
352-byte region [ffff8881154ec9c0, ffff8881154ecb20)
The buggy address belongs to the page:
page:ffffea0004553b00 refcount:1 mapcount:0 mapping:ffff888101755400 index:0x0 compound_mapcount: 0
flags: 0x2fff000000010200(slab|head)
raw: 2fff000000010200 dead000000000100 dead000000000122 ffff888101755400
raw: 0000000000000000 0000000080130013 00000001ffffffff 0000000000000000
page dumped because: kasan: bad access detected
Memory state around the buggy address:
ffff8881154ec900: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
ffff8881154ec980: fc fc fc fc fc fc fc fc fb fb fb fb fb fb fb fb
>ffff8881154eca00: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
ffff8881154eca80: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
ffff8881154ecb00: fb fb fb fb fc fc fc fc fc fc fc fc fc fc fc fc
Cc: Mike Christie <mchristi@redhat.com>
Link: https://lore.kernel.org/r/20191113220508.198257-3-bvanassche@acm.org
Reviewed-by: Roman Bolshakov <r.bolshakov@yadro.com>
Signed-off-by: Bart Van Assche <bvanassche@acm.org>
commit 8f8fed0cdbbd6cdbf28d9ebe662f45765d2f7d39 upstream.
When a non-passthrough command is terminated with CHECK CONDITION, request
sense is executed by hijacking the command descriptor. Since
scsi_eh_prep_cmnd() and scsi_eh_restore_cmnd() do not save/restore the
original command resid, the value returned on failure of the original
command is lost and replaced with the value set by the execution of the
request sense command. This value may in many instances be unaligned to the
device sector size, causing sd_done() to print a warning message about the
incorrect unaligned resid before the command is retried.
Fix this problem by saving the original command residual in struct
scsi_eh_save using scsi_eh_prep_cmnd() and restoring it in
scsi_eh_restore_cmnd(). In addition, to make sure that the request sense
command is executed with a correctly initialized command structure, also
reset the residual to 0 in scsi_eh_prep_cmnd() after saving the original
command value in struct scsi_eh_save.
Cc: stable@vger.kernel.org
Link: https://lore.kernel.org/r/20191001074839.1994-1-damien.lemoal@wdc.com
Signed-off-by: Damien Le Moal <damien.lemoal@wdc.com>
Reviewed-by: Bart Van Assche <bvanassche@acm.org>
[ Upstream commit dccc96abfb21dc19d69e707c38c8ba439bba7160 ]
The data structure used for log messages is so large that it can cause a
boot failure. Since allocations from that data structure can fail anyway,
use kmalloc() / kfree() instead of that data structure.
See also https://bugzilla.kernel.org/show_bug.cgi?id=204119.
See also commit ded85c193a39 ("scsi: Implement per-cpu logging buffer") # v4.0.
Reported-by: Jan Palus <jpalus@fastmail.com>
Cc: Hannes Reinecke <hare@suse.com>
Cc: Johannes Thumshirn <jthumshirn@suse.de>
Cc: Ming Lei <ming.lei@redhat.com>
Cc: Jan Palus <jpalus@fastmail.com>
commit 023358b136d490ca91735ac6490db3741af5a8bd upstream.
Gcc-9 complains for a memset across pointer boundaries, which happens as
the code tries to allocate a flexible array on the stack. Turns out we
cannot do this without relying on gcc-isms, so with this patch we'll embed
the fc_rport_priv structure into fcoe_rport, can use the normal
'container_of' outcast, and will only have to do a memset over one
structure.
Signed-off-by: Hannes Reinecke <hare@suse.de>
[ Upstream commit 8beb90aaf334a6efa3e924339926b5f93a234dbb ]
commit 1917d42d14b7 ("fcoe: use enum for fip_mode") introduces a separate
enum for the fip_mode that shall be used during initialisation handling
until it is passed to fcoe_ctrl_link_up to set the initial fip_state. That
change was incomplete and gcc quietly converted in various places between
the fip_mode and the fip_state enum values with implicit enum conversions,
which fortunately cannot cause any issues in the actual code's execution.
clang however warns about these implicit enum conversions in the scsi
drivers. This commit consolidates the use of the two enums, guided by
clang's enum-conversion warnings.
This commit now completes the use of the fip_mode: It expects and uses
fip_mode in {bnx2fc,fcoe}_interface_create and fcoe_ctlr_init, and it calls
fcoe_ctrl_set_set() with the correct values in fcoe_ctlr_link_up(). It
also breaks the association between FIP_MODE_AUTO and FIP_ST_AUTO to
indicate these two enums are distinct.
Link: https://github.com/ClangBuiltLinux/linux/issues/151
Fixes: 1917d42d14b7 ("fcoe: use enum for fip_mode")
Reported-by: Dmitry Golovin <dima@golovin.in>
Original-by: Lukas Bulwahn <lukas.bulwahn@gmail.com>
CC: Lukas Bulwahn <lukas.bulwahn@gmail.com>
CC: Nick Desaulniers <ndesaulniers@google.com>
CC: Nathan Chancellor <natechancellor@gmail.com>
Reviewed-by: Nathan Chancellor <natechancellor@gmail.com>
Tested-by: Nathan Chancellor <natechancellor@gmail.com>
Suggested-by: Johannes Thumshirn <jthumshirn@suse.de>
Signed-off-by: Sedat Dilek <sedat.dilek@gmail.com>
Signed-off-by: Hannes Reinecke <hare@suse.com>
commit 2f31115e940c4afd49b99c33123534e2ac924ffb upstream.
This patch introduces 'force_blk_mq' to the scsi_host_template so that
drivers that have no desire to support the legacy I/O path can signal
blk-mq only support.
[mkp: commit desc]
Cc: Omar Sandoval <osandov@fb.com>,
Cc: "Martin K. Petersen" <martin.petersen@oracle.com>,
Cc: James Bottomley <james.bottomley@hansenpartnership.com>,
Cc: Christoph Hellwig <hch@lst.de>,
Cc: Don Brace <don.brace@microsemi.com>
Cc: Kashyap Desai <kashyap.desai@broadcom.com>
Cc: Mike Snitzer <snitzer@redhat.com>
Cc: Laurence Oberman <loberman@redhat.com>
Signed-off-by: Ming Lei <ming.lei@redhat.com>
Reviewed-by: Hannes Reinecke <hare@suse.de>
[ Upstream commit 1875ede02ed5e176a18dccbca84abc28d5b3e141 ]
The SCSI PRE-FETCH (10 or 16) command is present both on hard disks
and some SSDs. It is useful when the address of the next block(s) to
be read is known but it is not following the LBA of the current READ
(so read-ahead won't help). It returns two "good" SCSI Status values.
If the requested blocks have fitted (or will most likely fit (when
the IMMED bit is set)) into the disk's cache, it returns CONDITION
MET. If it didn't (or will not) fit then it returns GOOD status.
The goal of this patch is to stop the SCSI subsystem treating the
CONDITION MET SCSI status as an error. The current state makes the
PRE-FETCH command effectively unusable via pass-throughs.
Signed-off-by: Douglas Gilbert <dgilbert@interlog.com>
Reviewed-by: Bart Van Assche <bart.vanassche@wdc.com>
commit 3be8828fc507cdafe7040a3dcf361a2bcd8e305b upstream.
Avoid that the recently introduced call_rcu() call in the SCSI core
triggers a double call_rcu() call.
Reported-by: Natanael Copa <ncopa@alpinelinux.org>
Reported-by: Damien Le Moal <damien.lemoal@wdc.com>
References: https://bugzilla.kernel.org/show_bug.cgi?id=198861
Fixes: 3bd6f43f5cb3 ("scsi: core: Ensure that the SCSI error handler gets woken up")
Signed-off-by: Bart Van Assche <bart.vanassche@wdc.com>
Reviewed-by: Damien Le Moal <damien.lemoal@wdc.com>
Tested-by: Damien Le Moal <damien.lemoal@wdc.com>
Cc: Natanael Copa <ncopa@alpinelinux.org>
Cc: Damien Le Moal <damien.lemoal@wdc.com>
Cc: Alexandre Oliva <oliva@gnu.org>
Cc: Pavel Tikhomirov <ptikhomirov@virtuozzo.com>
Cc: <stable@vger.kernel.org>
commit 3bd6f43f5cb3714f70c591514f344389df593501 upstream.
If scsi_eh_scmd_add() is called concurrently with
scsi_host_queue_ready() while shost->host_blocked > 0 then it can
happen that neither function wakes up the SCSI error handler. Fix
this by making every function that decreases the host_busy counter
wake up the error handler if necessary and by protecting the
host_failed checks with the SCSI host lock.
Reported-by: Pavel Tikhomirov <ptikhomirov@virtuozzo.com>
References: https://marc.info/?l=linux-kernel&m=150461610630736
Fixes: commit 746650160866 ("scsi: convert host_busy to atomic_t")
Reviewed-by: Pavel Tikhomirov <ptikhomirov@virtuozzo.com>
Tested-by: Stuart Hayes <stuart.w.hayes@gmail.com>
Cc: Konstantin Khorenko <khorenko@virtuozzo.com>
Cc: Stuart Hayes <stuart.w.hayes@gmail.com>
commit c2e8fbf908afd81ad502b567a6639598f92c9b9d upstream.
The rps_resp buffer in ata_device is a DMA target, but it isn't
explicitly cacheline aligned. Due to this, adjacent fields can be
overwritten with stale data from memory on non-coherent architectures.
As a result, the kernel is sometimes unable to communicate with an SATA
device behind a SAS expander.
Fix this by ensuring that the rps_resp buffer is cacheline aligned.
This issue is similar to that fixed by Commit 84bda12af31f93 ("libata:
align ap->sector_buf") and Commit 4ee34ea3a12396f35b26 ("libata: Align
ata_device's id on a cacheline").
Signed-off-by: Huacai Chen <chenhc@lemote.com>
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
iscsi_session_teardown was the only user of this function. Function
currently is just short for iscsi_remove_session + iscsi_free_session.
Signed-off-by: Khazhismel Kumykov <khazhy@google.com>
Acked-by: Chris Leech <cleech@redhat.com>
SBC-4 states:
"A MAXIMUM UNMAP LBA COUNT field set to a non-zero value indicates the
maximum number of LBAs that may be unmapped by an UNMAP command"
"A MAXIMUM WRITE SAME LENGTH field set to a non-zero value indicates
the maximum number of contiguous logical blocks that the device server
allows to be unmapped or written in a single WRITE SAME command."
Despite the spec being clear on the topic, some devices incorrectly
expect WRITE SAME commands with the UNMAP bit set to be limited to the
value reported in MAXIMUM UNMAP LBA COUNT in the Block Limits VPD.
Implement a blacklist option that can be used to accommodate devices
with this behavior.
Reported-by: Bill Kuzeja <William.Kuzeja@stratus.com>
Reported-by: Ewan D. Milne <emilne@redhat.com>
Reviewed-by: Ewan D. Milne <emilne@redhat.com>
Tested-by: Laurence Oberman <loberman@redhat.com>
Pull SCSI fixes from James Bottomley:
"A tiny update: one patch corrects a Kconfig problem with the shift of
the SAS SMP code to BSG and the other removes a vestige of user space
target mode"
* tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi:
scsi: scsi_transport_sas: select BLK_DEV_BSGLIB
scsi: Remove Scsi_Host.uspace_req_q
A patch I wrote myself several years ago removed SCSI target support
from the code under drivers/scsi. That patch removed the code that sets
uspace_req_q to a non-NULL value. Hence also remove the code that
depends on uspace_req_q != NULL.
References: commit 066465251303 ("tgt: removal")
Cc: Hannes Reinecke <hare@suse.de>
Reviewed-by: Johannes Thumshirn <jthumshirn@suse.de>
If a pass-through request is submitted then blk_get_request()
initializes that request by calling scsi_initialize_rq(). Also call this
function for filesystem requests. Introduce CMD_INITIALIZED to keep
track of whether or not a request has already been initialized.
Cc: Brian King <brking@linux.vnet.ibm.com>
Simplify the SMP passthrough code by switching it to the generic bsg-lib
helpers that abstract away the details of the request code, and gets
drivers out of seeing struct scsi_request.
For the libsas host SMP code there is a small behavior difference in
that we now always clear the residual len for successful commands,
similar to the three other SMP handler implementations. Given that
there is no partial command handling in the host SMP handler this should
not matter in practice.
[mkp: typos and checkpatch fixes]
Introduce struct scsi_vpd for the VPD page length, data and the RCU head
that will be used to free the VPD data. Use kfree_rcu() instead of
kfree() to free VPD data. Move the VPD buffer pointer check inside the
RCU read lock in the sysfs code. Only annotate pointers that are shared
across threads with __rcu. Use rcu_dereference() when dereferencing an
RCU pointer. This patch suppresses about twenty sparse complaints about
the vpd_pg8[03] pointers. This patch also fixes a race condition, namely
that updating of the VPD pointers and length variables in struct
scsi_device was not atomic with reference to the code reading these
variables. See also "Does the update code tolerate concurrent accesses?"
in Documentation/RCU/checklist.txt.
Fixes: commit 09e2b0b14690 ("scsi: rescan VPD attributes")
Acked-by: Hannes Reinecke <hare@suse.de>
Reviewed-by: Shane Seymour <shane.seymour@hpe.com>
Cc: Shane Seymour <shane.seymour@hpe.com>
The bus reset handler is calling I_T Nexus reset, which logically is a
target reset as it need to specify both the initiator and the target.
So move it to target reset.
Avoid that the following compiler warning is reported when building
with W=1:
drivers/scsi/scsi_transport_srp.c:92:19: warning: comparison is always false due to limited range of data type [-Wtype-limits]
Since commit e9c787e65c0c ("scsi: allocate scsi_cmnd structures as
part of struct request") struct request and struct scsi_cmnd are
adjacent. This means that there is now an alternative to reading
req->special to convert a pointer to a prepared request into a
SCSI command pointer, namely by using blk_mq_rq_to_pdu(). Make
this change where appropriate. Although this patch does not
change any functionality, it slightly improves performance and
slightly improves readability.
Signed-off-by: Bart Van Assche <bart.vanassche@sandisk.com>
Reviewed-by: Hannes Reinecke <hare@suse.com>
This patch avoids that smatch reports the following:
drivers/scsi/scsi_sysfs.c:506 scsi_bus_uevent() warn: argument 3 to %02x specifier has type 'char'
drivers/scsi/scsi_sysfs.c:872 sdev_show_modalias() warn: argument 4 to %02x specifier has type 'char'
Commit e9c787e65c0c ("scsi: allocate scsi_cmnd structures as part of
struct request") removed the scsi_get_command() function. Hence also
remove the declaration of that function.
Releasing a zone write lock only when the write commnand that acquired
the lock completes can cause deadlocks due to potential command
reordering if the lock owning request is requeued and not executed. This
problem exists only with the scsi-mq path as, unlike the legacy path,
requests are moved out of the dispatch queue before being prepared and
so before locking a zone for a write command.
Since sd_uninit_cmnd() is now always called when a request is requeued,
call sd_zbc_write_unlock_zone() from that function for write requests
that acquired a zone lock instead of from sd_done(). Acquisition of a zone
lock by a write command is indicated using the new command
flag SCMD_ZONE_WRITE_LOCK.
Reviewed-by: Bart Van Assche <Bart.VanAssche@wdc.com>
Scsi_cmnd is an unsuitable argument for eh_device_reset_handler(),
eh_target_reset_handler(), and eh_host_reset_handler() which do not have
the scope of one single SCSI command. These callbacks tend to use
fc_block_scsi_eh() requiring scsi_cmnd. In order to start decoupling
above eh callbacks from scsi_cmnd, introduce a new variant of the
function called fc_block_rport() taking an fc_rport as argument.
Refactor the old fc_block_scsi_eh() to simply delegate to
fc_block_rport().
Signed-off-by: Steffen Maier <maier@linux.vnet.ibm.com>
git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending
Pull SCSI target updates from Nicholas Bellinger:
"It's been usually busy for summer, with most of the efforts centered
around TCMU developments and various target-core + fabric driver bug
fixing activities. Not particularly large in terms of LoC, but lots of
smaller patches from many different folks.
The highlights include:
- ibmvscsis logical partition manager support (Michael Cyr + Bryant
Ly)
- Convert target/iblock WRITE_SAME to blkdev_issue_zeroout (hch +
nab)
- Add support for TMR percpu LUN reference counting (nab)
- Fix a potential deadlock between EXTENDED_COPY and iscsi shutdown
(Bart)
- Fix COMPARE_AND_WRITE caw_sem leak during se_cmd quiesce (Jiang Yi)
- Fix TMCU module removal (Xiubo Li)
- Fix iser-target OOPs during login failure (Andrea Righi + Sagi)
- Breakup target-core free_device backend driver callback (mnc)
- Perform TCMU add/delete/reconfig synchronously (mnc)
- Fix TCMU multiple UIO open/close sequences (mnc)
- Fix TCMU CHECK_CONDITION sense handling (mnc)
- Fix target-core SAM_STAT_BUSY + TASK_SET_FULL handling (mnc + nab)
- Introduce TYPE_ZBC support in PSCSI (Damien Le Moal)
- Fix possible TCMU memory leak + OOPs when recalculating cmd base
size (Xiubo Li + Bryant Ly + Damien Le Moal + mnc)
- Add login_keys_workaround attribute for non RFC initiators (Robert
LeBlanc + Arun Easi + nab)"
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: (68 commits)
iscsi-target: Add login_keys_workaround attribute for non RFC initiators
Revert "qla2xxx: Fix incorrect tcm_qla2xxx_free_cmd use during TMR ABORT"
tcmu: clean up the code and with one small fix
tcmu: Fix possbile memory leak / OOPs when recalculating cmd base size
target: export lio pgr/alua support as device attr
target: Fix return sense reason in target_scsi3_emulate_pr_out
target: Fix cmd size for PR-OUT in passthrough_parse_cdb
tcmu: Fix dev_config_store
target: pscsi: Introduce TYPE_ZBC support
target: Use macro for WRITE_VERIFY_32 operation codes
target: fix SAM_STAT_BUSY/TASK_SET_FULL handling
target: remove transport_complete
pscsi: finish cmd processing from pscsi_req_done
tcmu: fix sense handling during completion
target: add helper to copy sense to se_cmd buffer
target: do not require a transport_complete for SCF_TRANSPORT_TASK_SENSE
target: make device_mutex and device_list static
tcmu: Fix flushing cmd entry dcache page
tcmu: fix multiple uio open/close sequences
tcmu: drop configured check in destroy
Add WRITE_VERIFY_32 definition to scsi prototypes and use this macro
definition isntead of the hard coded value.
(Drop WRITE_VERIFY_16 that's already part of another patch - nab)
Pull SCSI updates from James Bottomley:
"This is mostly updates of the usual suspects: lpfc, qla2xxx, bnx2fc,
qedf, hpsa, hisi_sas, smartpqi, cxlflash, aacraid, csiostor along with
a host of minor and miscellaneous changes"
* tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (276 commits)
qla2xxx: Fix NVMe entry_type for iocb packet on BE system
scsi: qla2xxx: avoid unused-function warning
scsi: snic: fix a couple of spelling mistakes/typos
scsi: qla2xxx: fix a bunch of typos and spelling mistakes
scsi: lpfc: don't double count abort errors
scsi: lpfc: spin_lock_irq() is not nestable
scsi: hisi_sas: optimise DMA slot memory
scsi: ibmvfc: constify dev_pm_ops structures.
scsi: ibmvscsi: constify dev_pm_ops structures.
scsi: cxlflash: Update debug prints in reset handlers
scsi: cxlflash: Update send_tmf() parameters
scsi: cxlflash: Avoid double free of character device
scsi: Add STARGET_CREATED_REMOVE state to scsi_target_state
scsi: ses: do not add a device to an enclosure if enclosure_add_links() fails.
scsi: ufs: flush eh_work when eh_work scheduled.
scsi: qla2xxx: Protect access to qpair members with qpair->qp_lock
scsi: sun_esp: fix device reference leaks
scsi: fnic: changing queue command to return result DID_IMM_RETRY when rport is init
scsi: fnic: correct speed display and add support for 25,40 and 100G
scsi: fnic: added timestamp reporting in fnic debug stats
git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata
Pull libata updates from Tejun Heo:
- Christoph added support for TCG OPAL self encrypting disks
- Minwoo added support for ATA PASS-THROUGH(32)
- Linus Walleij removed spurious drvdata assignments in some drivers
- Support for a few new device and other fixes
* 'for-4.13' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata: (33 commits)
sd: add support for TCG OPAL self encrypting disks
libata: fix build warning from unused goto label
libata: Support for an ATA PASS-THROUGH(32) command.
ahci: Add Device ID for ASMedia 1061R and 1062R
sata_via: Enable optional hotplug on VT6420
ata: ahci_brcm: Avoid writing to read-only registers
libata: Add the AHCI_HFLAG_NO_WRITE_TO_RO flag
libata: Add the AHCI_HFLAG_YES_ALPM flag
ata: ftide010: fix resource printing
libata: make the function name in comment match the actual function
ata: sata_rcar: make of_device_ids const.
ata: pata_octeon_cf: make of_device_ids const.
libata: Convert bare printks to pr_cont
libahci: wrong comments in ahci_do_softreset()
ata: declare ata_port_info structures as const
ata: Add driver for Faraday Technology FTIDE010
ata: Add DT bindings for the Gemini SATA bridge
ata: Add DT bindings for Faraday Technology FTIDE010
libata: implement SECURITY PROTOCOL IN/OUT
libata: factor out a ata_identify_page_supported helper
The addition of the STARGET_REMOVE state had the side effect of
introducing a race condition that can cause a crash.
scsi_target_reap_ref_release() checks the starget->state to
see if it still in STARGET_CREATED, and if so, skips calling
transport_remove_device() and device_del(), because the starget->state
is only set to STARGET_RUNNING after scsi_target_add() has called
device_add() and transport_add_device().
However, if an rport loss occurs while a target is being scanned,
it can happen that scsi_remove_target() will be called while the
starget is still in the STARGET_CREATED state. In this case, the
starget->state will be set to STARGET_REMOVE, and as a result,
scsi_target_reap_ref_release() will take the wrong path. The end
result is a panic:
[ 1255.356653] Oops: 0000 [#1] SMP
[ 1255.360154] Modules linked in: x86_pkg_temp_thermal kvm_intel kvm irqbypass crc32c_intel ghash_clmulni_i
[ 1255.393234] CPU: 5 PID: 149 Comm: kworker/u96:4 Tainted: G W 4.11.0+ #8
[ 1255.401879] Hardware name: Dell Inc. PowerEdge R320/08VT7V, BIOS 2.0.22 11/19/2013
[ 1255.410327] Workqueue: scsi_wq_6 fc_scsi_scan_rport [scsi_transport_fc]
[ 1255.417720] task: ffff88060ca8c8c0 task.stack: ffffc900048a8000
[ 1255.424331] RIP: 0010:kernfs_find_ns+0x13/0xc0
[ 1255.429287] RSP: 0018:ffffc900048abbf0 EFLAGS: 00010246
[ 1255.435123] RAX: 0000000000000000 RBX: 0000000000000000 RCX: 0000000000000000
[ 1255.443083] RDX: 0000000000000000 RSI: ffffffff8188d659 RDI: 0000000000000000
[ 1255.451043] RBP: ffffc900048abc10 R08: 0000000000000000 R09: 0000012433fe0025
[ 1255.459005] R10: 0000000025e5a4b5 R11: 0000000025e5a4b5 R12: ffffffff8188d659
[ 1255.466972] R13: 0000000000000000 R14: ffff8805f55e5088 R15: 0000000000000000
[ 1255.474931] FS: 0000000000000000(0000) GS:ffff880616b40000(0000) knlGS:0000000000000000
[ 1255.483959] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[ 1255.490370] CR2: 0000000000000068 CR3: 0000000001c09000 CR4: 00000000000406e0
[ 1255.498332] Call Trace:
[ 1255.501058] kernfs_find_and_get_ns+0x31/0x60
[ 1255.505916] sysfs_unmerge_group+0x1d/0x60
[ 1255.510498] dpm_sysfs_remove+0x22/0x60
[ 1255.514783] device_del+0xf4/0x2e0
[ 1255.518577] ? device_remove_file+0x19/0x20
[ 1255.523241] attribute_container_class_device_del+0x1a/0x20
[ 1255.529457] transport_remove_classdev+0x4e/0x60
[ 1255.534607] ? transport_add_class_device+0x40/0x40
[ 1255.540046] attribute_container_device_trigger+0xb0/0xc0
[ 1255.546069] transport_remove_device+0x15/0x20
[ 1255.551025] scsi_target_reap_ref_release+0x25/0x40
[ 1255.556467] scsi_target_reap+0x2e/0x40
[ 1255.560744] __scsi_scan_target+0xaa/0x5b0
[ 1255.565312] scsi_scan_target+0xec/0x100
[ 1255.569689] fc_scsi_scan_rport+0xb1/0xc0 [scsi_transport_fc]
[ 1255.576099] process_one_work+0x14b/0x390
[ 1255.580569] worker_thread+0x4b/0x390
[ 1255.584651] kthread+0x109/0x140
[ 1255.588251] ? rescuer_thread+0x330/0x330
[ 1255.592730] ? kthread_park+0x60/0x60
[ 1255.596815] ret_from_fork+0x29/0x40
[ 1255.600801] Code: 24 08 48 83 42 40 01 5b 41 5c 5d c3 66 66 66 2e 0f 1f 84 00 00 00 00 00 66 66 66 66 90
[ 1255.621876] RIP: kernfs_find_ns+0x13/0xc0 RSP: ffffc900048abbf0
[ 1255.628479] CR2: 0000000000000068
[ 1255.632756] ---[ end trace 34a69ba0477d036f ]---
Fix this by adding another scsi_target state STARGET_CREATED_REMOVE
to distinguish this case.
Fixes: f05795d3d771 ("scsi: Add intermediate STARGET_REMOVE state to scsi_target_state")
Reported-by: David Jeffery <djeffery@redhat.com>
Signed-off-by: Ewan D. Milne <emilne@redhat.com>
Reviewed-by: Laurence Oberman <loberman@redhat.com>
Just wire up the generic TCG OPAL infrastructure to the SCSI disk driver
and the Security In/Out commands.
Note that I don't know of any actual SCSI disks that do support TCG OPAL,
but this is required to support ATA disks through libata.
Acked-by: Martin K. Petersen <martin.petersen@oracle.com>
libsas uses scsi_queue_work() to queue its internal event notifications.
scsi_queue_work() can return -EINVAL if the work queue doesn't exist and
it does call queue_work() which can return false if the work is already
queued.
Make the SAS event code capable of returning errors up to the caller,
which is handy when changing to dynamically allocated work in libsas
as well, as discussed here: https://lkml.org/lkml/2017/6/14/121.
[mkp: fixed typo]
Signed-off-by: Johannes Thumshirn <jthumshirn@suse.de>
SAT-4(SCSI/ATA Translation) supports for an ata pass-thru(32).
This patch will allow to translate an ata pass-thru(32) SCSI cmd
to an ATA cmd.
Signed-off-by: Minwoo Im <dn3108@gmail.com>
The symbolic name VLC_SA_RECEIVE_CREDENTIAL is not used anywhere in the
kernel. Additionally, since SPC 5 the RECEIVE CREDENTIAL command is
obsolete. The VLC_SA_RECEIVE_CREDENTIAL definition is misleading since
it occurs outside the list of other variable length CDB service action
codes (READ_32, WRITE_32, ...). Hence remove this definition.
References: commit e9ccc998b70f ("[SCSI] Add missing SPC-4 CDB and
MAINTENANCE_[IN,OUT] service action definitions")
After commit 556e26a70b64 ("scsi: remove tsk_mgmt_response and
it_nexus_response transport methods"), the target driver support was
removed totally. Drop the residual.
Signed-off-by: Kefeng Wang <wangkefeng.wang@huawei.com>
Since 9c58b395 ("scsi: scsi_devinfo: remove synchronous ALUA for NETAPP
devices") this code is unused.
Since scsi_req_init() works on a struct scsi_request, change the
argument type into struct scsi_request *.
Reviewed-by: Martin K. Petersen <martin.petersen@oracle.com>
Instead of explicitly calling scsi_req_init() after blk_get_request(),
call that function from inside blk_get_request(). Add an
.initialize_rq_fn() callback function to the block drivers that need
it. Merge the IDE .init_rq_fn() function into .initialize_rq_fn()
because it is too small to keep it as a separate function. Keep the
scsi_req_init() call in ide_prep_sense() because it follows a
blk_rq_init() call.
References: commit 82ed4db499b8 ("block: split scsi_request out of struct request")
Cc: Nicholas Bellinger <nab@linux-iscsi.org>
Serializing SCSI device state changes avoids that two state changes can
occur concurrently, e.g. the state changes in scsi_target_block() and
__scsi_remove_device(). This serialization is essential to make patch
"Make __scsi_remove_device go straight from BLOCKED to DEL" work
reliably.
Enable this mechanism for all scsi_target_*block() callers but not for
the scsi_internal_device_unblock() calls from the mpt3sas driver because
that driver can call scsi_internal_device_unblock() from atomic context.
This will make it easier to serialize SCSI device state changes through
a mutex.
Cc: Sreekanth Reddy <sreekanth.reddy@broadcom.com>
Instead of passing a "wait" argument to scsi_internal_device_block(),
split this function into a function that waits and a function that
doesn't wait. This will make it easier to serialize SCSI device state
changes through a mutex.
Dereferencing shost from scsi_exit_rq() is not safe because the SCSI
host may already have been freed when scsi_exit_rq() is called.
Increasing the shost reference count in scsi_init_rq() and dropping that
reference in scsi_exit_rq() is nontrivial since scsi_host_dev_release()
may sleep and since scsi_exit_rq() may be called from interrupt
context. Since scsi_exit_rq() only needs a single bit from shost, copy
that bit into struct scsi_cmnd.
Reported-by: Scott Bauer <scott.bauer@intel.com>
Fixes: e9c787e65c0c ("scsi: allocate scsi_cmnd structures as part of struct request")
Cc: Scott Bauer <scott.bauer@intel.com>
Cc: Jan Kara <jack@suse.cz>
Currently we use nornal Linux errno values in the block layer, and while
we accept any error a few have overloaded magic meanings. This patch
instead introduces a new blk_status_t value that holds block layer specific
status codes and explicitly explains their meaning. Helpers to convert from
and to the previous special meanings are provided for now, but I suspect
we want to get rid of them in the long run - those drivers that have a
errno input (e.g. networking) usually get errnos that don't know about
the special block layer overloads, and similarly returning them to userspace
will usually return somethings that strictly speaking isn't correct
for file system operations, but that's left as an exercise for later.
For now the set of errors is a very limited set that closely corresponds
to the previous overloaded errno values, but there is some low hanging
fruite to improve it.
blk_status_t (ab)uses the sparse __bitwise annotations to allow for sparse
typechecking, so that we can easily catch places passing the wrong values.
Signed-off-by: Jens Axboe <axboe@fb.com>
"Things were a lot more calm than previously expected. It's primarily
fixes in various areas, with most of the new functionality centering
around TCMU backend driver work that Xiubo Li has been driving.
Here's the summary on the feature side:
- Make T10-PI verify configurable for emulated (FILEIO + RD) backends
(Dmitry Monakhov)
- Allow target-core/TCMU pass-through to use in-kernel SPC-PR logic
(Bryant Ly + MNC)
- Add TCMU support for growing ring buffer size (Xiubo Li + MNC)
- Add TCMU support for global block data pool (Xiubo Li + MNC)
and on the bug-fix side:
- Fix COMPARE_AND_WRITE non GOOD status handling for READ phase
failures (Gary Guo + nab)
- Fix iscsi-target hang with explicitly changing per NodeACL
CmdSN number depth with concurrent login driven session
reinstatement. (Gary Guo + nab)
- Fix ibmvscsis fabric driver ABORT task handling (Bryant Ly)
- Fix target-core/FILEIO zero length handling (Bart Van Assche)
Also, there was an OOPs introduced with the WRITE_VERIFY changes that
I ended up reverting at the last minute, because as not unusual Bart
and I could not agree on the fix in time for -rc1. Since it's specific
to a conformance test, it's been reverted for now.
There is a separate patch in the queue to address the underlying
control CDB write overflow regression in >= v4.3 separate from the
WRITE_VERIFY revert here, that will be pushed post -rc1"
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: (30 commits)
Revert "target: Fix VERIFY and WRITE VERIFY command parsing"
IB/srpt: Avoid that aborting a command triggers a kernel warning
IB/srpt: Fix abort handling
target/fileio: Fix zero-length READ and WRITE handling
ibmvscsis: Do not send aborted task response
tcmu: fix module removal due to stuck thread
target: Don't force session reset if queue_depth does not change
iscsi-target: Set session_fall_back_to_erl0 when forcing reinstatement
target: Fix compare_and_write_callback handling for non GOOD status
tcmu: Recalculate the tcmu_cmd size to save cmd area memories
tcmu: Add global data block pool support
tcmu: Add dynamic growing data area feature support
target: fixup error message in target_tg_pt_gp_tg_pt_gp_id_store()
target: fixup error message in target_tg_pt_gp_alua_access_type_store()
target/user: PGR Support
target: Add WRITE_VERIFY_16
Documentation/target: add an example script to configure an iSCSI target
target: Use kmalloc_array() in transport_kmap_data_sg()
target: Use kmalloc_array() in compare_and_write_callback()
target: Improve size determinations in two functions
Regularly, when a new header is created in include/uapi/, the developer
forgets to add it in the corresponding Kbuild file. This error is usually
detected after the release is out.
In fact, all headers under uapi directories should be exported, thus it's
useless to have an exhaustive list.
After this patch, the following files, which were not exported, are now
exported (with make headers_install_all):
asm-arc/kvm_para.h
asm-arc/ucontext.h
asm-blackfin/shmparam.h
asm-blackfin/ucontext.h
asm-c6x/shmparam.h
asm-c6x/ucontext.h
asm-cris/kvm_para.h
asm-h8300/shmparam.h
asm-h8300/ucontext.h
asm-hexagon/shmparam.h
asm-m32r/kvm_para.h
asm-m68k/kvm_para.h
asm-m68k/shmparam.h
asm-metag/kvm_para.h
asm-metag/shmparam.h
asm-metag/ucontext.h
asm-mips/hwcap.h
asm-mips/reg.h
asm-mips/ucontext.h
asm-nios2/kvm_para.h
asm-nios2/ucontext.h
asm-openrisc/shmparam.h
asm-parisc/kvm_para.h
asm-powerpc/perf_regs.h
asm-sh/kvm_para.h
asm-sh/ucontext.h
asm-tile/shmparam.h
asm-unicore32/shmparam.h
asm-unicore32/ucontext.h
asm-x86/hwcap2.h
asm-xtensa/kvm_para.h
drm/armada_drm.h
drm/etnaviv_drm.h
drm/vgem_drm.h
linux/aspeed-lpc-ctrl.h
linux/auto_dev-ioctl.h
linux/bcache.h
linux/btrfs_tree.h
linux/can/vxcan.h
linux/cifs/cifs_mount.h
linux/coresight-stm.h
linux/cryptouser.h
linux/fsmap.h
linux/genwqe/genwqe_card.h
linux/hash_info.h
linux/kcm.h
linux/kcov.h
linux/kfd_ioctl.h
linux/lightnvm.h
linux/module.h
linux/nbd-netlink.h
linux/nilfs2_api.h
linux/nilfs2_ondisk.h
linux/nsfs.h
linux/pr.h
linux/qrtr.h
linux/rpmsg.h
linux/sched/types.h
linux/sed-opal.h
linux/smc.h
linux/smc_diag.h
linux/stm.h
linux/switchtec_ioctl.h
linux/vfio_ccw.h
linux/wil6210_uapi.h
rdma/bnxt_re-abi.h
Note that I have removed from this list the files which are generated in every
exported directories (like .install or .install.cmd).
Thanks to Julien Floret <julien.floret@6wind.com> for the tip to get all
subdirs with a pure makefile command.
For the record, note that exported files for asm directories are a mix of
files listed by:
- include/uapi/asm-generic/Kbuild.asm;
- arch/<arch>/include/uapi/asm/Kbuild;
- arch/<arch>/include/asm/Kbuild.
Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
Acked-by: Daniel Vetter <daniel.vetter@ffwll.ch>
Acked-by: Russell King <rmk+kernel@armlinux.org.uk>
Acked-by: Mark Salter <msalter@redhat.com>
Acked-by: Michael Ellerman <mpe@ellerman.id.au> (powerpc)
"This update includes the usual round of major driver updates
(hisi_sas, ufs, fnic, cxlflash, be2iscsi, ipr, stex). There's also the
usual amount of cosmetic and spelling stuff"
* tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (155 commits)
scsi: qla4xxx: fix spelling mistake: "Tempalate" -> "Template"
scsi: stex: make S6flag static
scsi: mac_esp: fix to pass correct device identity to free_irq()
scsi: aacraid: pci_alloc_consistent() failures on ARM64
scsi: ufs: make ufshcd_get_lists_status() register operation obvious
scsi: ufs: use MASK_EE_STATUS
scsi: mac_esp: Replace bogus memory barrier with spinlock
scsi: fcoe: make fcoe_e_d_tov and fcoe_r_a_tov static
scsi: sd_zbc: Do not write lock zones for reset
scsi: sd_zbc: Remove superfluous assignments
scsi: sd: sd_zbc: Rename sd_zbc_setup_write_cmnd
scsi: Improve scsi_get_sense_info_fld
scsi: sd: Cleanup sd_done sense data handling
scsi: sd: Improve sd_completed_bytes
scsi: sd: Fix function descriptions
scsi: mpt3sas: remove redundant wmb
scsi: mpt: Move scsi_remove_host() out of mptscsih_remove_host()
scsi: sg: reset 'res_in_use' after unlinking reserved array
scsi: mvumi: remove code handling zero scsi_sg_count(scmd) case
scsi: fusion: fix spelling mistake: "Persistancy" -> "Persistency"
This patch addresses clients who needs write_verify_16 for
large volume groups such as AIX.
Signed-off-by: Bryant G. Ly <bryantly@linux.vnet.ibm.com>
Use get_unaligned_be32 and get_unaligned_be64 to obtain values from the
sense buffer instead of open coding the operations. Also change the
function return value to a bool and fix the function signature
declaration to remove spaces triggering checkpatch warnings.
No functional change is introduced by this patch.
Reviewed-by: Bart Van Assche <Bart.VanAssche@sandisk.com>
