[ Upstream commit 1c74d5c0de0c2cc29fef97a19251da2ad6f579bd ]
Currently we are enabling handling of interrupts specific to Tegra124+
which happen to overlap with previous generations. Let's specify
interrupts mask per SoC generation for consistency and in a preparation
of squashing of Tegra20 driver into the common one that will enable
handling of GART faults which may be undesirable by newer generations.
Signed-off-by: Dmitry Osipenko <digetx@gmail.com>
Signed-off-by: Thierry Reding <treding@nvidia.com>
Move this code from arch/arm/mach-tegra and make it common among 32-bit
and 64-bit Tegra SoCs. This is slightly complicated by the fact that on
32-bit Tegra, the SoC device is used as the parent for all devices that
are instantiated from device tree.
The BPMP firmware, found on Tegra186 and later, provides an ABI that can
be used to enable and disable power to several power partitions in Tegra
SoCs. The ABI allows for enumeration of the available power partitions,
so the driver can be reused on future generations, provided the BPMP ABI
remains stable.
Based on work by Stefan Kristiansson <stefank@nvidia.com> and Mikko
Perttunen <mperttunen@nvidia.com>.
Reviewed-by: Ulf Hansson <ulf.hansson@linaro.org>
Update the BPMP ABI header to a more recent version. The new version
adds support for a new powergating ABI as well as access to the ring
buffer console, which allows debug messages to be output to the BPMP
debug console.
Some of the previously undocumented fields have been documented and
missing bitmasks have been added. Furthermore the MRQ_RESET request
now has a sub-command that allows to determine the maximum ID which
in turn allows the resets to be enumerated, thereby allowing drivers
to become agnostic of the Tegra generation.
The flowctrl driver is required for both ARM and ARM64 Tegra devices
and in order to enable support for it for ARM64, move the Tegra flowctrl
driver into drivers/soc/tegra.
By moving the flowctrl driver, tegra_flowctrl_init() is now called by
via an early initcall and to prevent this function from attempting to
mapping IO space for a non-Tegra device, a test for 'soc_is_tegra()'
is also added.
Signed-off-by: Jon Hunter <jonathanh@nvidia.com>
With the new Tegra186 PMC driver merged, anything that relies on the previous
PMC driver fails to link when that is disabled:
arch/arm/mach-tegra/pm.o: In function `tegra_pm_set':
pm.c:(.text.tegra_pm_set+0x3c): undefined reference to `tegra_pmc_enter_suspend_mode'
arch/arm/mach-tegra/pm.o: In function `tegra_suspend_enter':
pm.c:(.text.tegra_suspend_enter+0x4): undefined reference to `tegra_pmc_get_suspend_mode'
arch/arm/mach-tegra/pm.o: In function `tegra_init_suspend':
pm.c:(.init.text+0x1c): undefined reference to `tegra_pmc_get_suspend_mode'
pm.c:(.init.text+0x74): undefined reference to `tegra_pmc_set_suspend_mode'
ERROR: tegra_powergate_sequence_power_up [drivers/ata/ahci_tegra.ko] undefined!
ERROR: tegra_powergate_power_off [drivers/ata/ahci_tegra.ko] undefined!
Making the definition depend on the presence of the driver makes it build
again, though that might not be the correct fix.
Reported-by: Krzysztof Kozlowski <krzk@kernel.org>
Fixes: 854014236290 ("soc/tegra: Implement Tegra186 PMC support")
git://git.kernel.org/pub/scm/linux/kernel/git/tegra/linux into next/drivers
soc: tegra: Core SoC changes for v4.10-rc1
This contains mostly cleanup and new feature work on the power
management controller as well as the addition of a Kconfig symbol for
the new Tegra186 (Parker) SoC generation.
* tag 'tegra-for-4.10-soc' of git://git.kernel.org/pub/scm/linux/kernel/git/tegra/linux:
soc/tegra: pmc: Use consistent naming for PM domains
soc/tegra: pmc: Remove genpd when adding provider fails
soc/tegra: pmc: Check return code for pm_genpd_init()
soc/tegra: pmc: Clean-up I/O rail error messages
soc/tegra: pmc: Simplify IO rail bit handling
soc/tegra: pmc: Guard against uninitialised PMC clock
soc/tegra: pmc: Add I/O pad voltage support
soc/tegra: pmc: Use consistent ordering of bit definitions
soc/tegra: pmc: Correct type of variable for tegra_pmc_readl()
soc/tegra: pmc: Use BIT macro for register field definition
The Boot and Power Management Processor (BPMP) is a co-processor found
on Tegra SoCs. It is designed to handle the early stages of the boot
process and offload power management tasks (such as clocks, resets,
powergates, ...) as well as system control services.
Compared to the ARM SCPI, the services provided by BPMP are message-
based rather than method-based. The BPMP firmware driver provides the
services to transmit data to and receive data from the BPMP. Users can
also register a Message ReQuest (MRQ), for which a service routine will
be run when a corresponding event is received from the firmware.
A set of messages, called the BPMP ABI, are specified for a number of
different services provided by the BPMP (such as clocks or resets).
Based on work by Sivaram Nair <sivaramn@nvidia.com> and Joseph Lo
<josephl@nvidia.com>.
The Inter-VM communication (IVC) is a communication protocol which is
designed for interprocessor communication (IPC) or the communication
between the hypervisor and the virtual machine with a guest OS.
Message channels are used to communicate between processors. They are
backed by DRAM or SRAM, so care must be taken to maintain coherence of
data.
The IVC library maintains memory-based descriptors for the transmission
and reception channels as well as the data coherence of the counter and
payload. Clients, such as the driver for the BPMP firmware, can use the
library to exchange messages with remote processors.
Based on work by Peter Newman <pnewman@nvidia.com> and Joseph Lo
I/O pins on Tegra SoCs are grouped into so-called I/O pads. Each such
pad can be used to control the common voltage signal level and power
state of the pins in the given pad.
I/O pads can be powered down even if the system is active, which can
save power from that I/O interface. For SoC generations prior to
Tegra124 the I/O pad voltage is automatically detected and hence the
system software doesn't need to configure it. However, starting with
Tegra210 the detection logic has been removed, so explicit control of
the I/O pad voltage by system software is required.
The PCIe host controller found on Tegra20 has a hardware bug that causes
PCIe interrupts to get lost when LP2 is enabled. Stub out the workaround
on 64-bit ARM because none of the more recent Tegra SoC generations seem
to have this bug anymore.
Merge "soc/tegra: Add generic PM domain support" from Thierry Reding:
Implements generic PM domain support on top of the existing Tegra power-
gate API. Drivers are thus allowed to move away from the Tegra-specific
API and towards using generic power domains directly.
* tag 'tegra-for-4.7-genpd' of git://git.kernel.org/pub/scm/linux/kernel/git/tegra/linux:
soc/tegra: pmc: Add generic PM domain support
dt-bindings: Add power domain info for NVIDIA PMC
Merge "phy: tegra: Changes for v4.7-rc1" from Thierry Reding:
This set of patches adds support for the Tegra XUSB pad controller. The
controller provides a set of pads (lanes) that are used for I/O by other
IP blocks within Tegra SoCs (PCIe, SATA and XUSB).
* tag 'tegra-for-4.7-phy' of git://git.kernel.org/pub/scm/linux/kernel/git/tegra/linux:
phy: tegra: Add Tegra210 support
phy: Add Tegra XUSB pad controller support
dt-bindings: phy: tegra-xusb-padctl: Add Tegra210 support
dt-bindings: phy: Add NVIDIA Tegra XUSB pad controller binding
phy: core: Allow children node to be overridden
clk: tegra: Add interface to enable hardware control of SATA/XUSB PLLs
Adds generic PM domain support to the PMC driver where the PM domains
are populated from device-tree and the PM domain consumer devices are
bound to their relevant PM domains via device-tree as well.
Update the tegra_powergate_sequence_power_up() API so that internally
it calls the same tegra_powergate_xxx functions that are used by the
Tegra generic PM domain code for consistency.
To ensure that the Tegra power domains (a.k.a. powergates) cannot be
controlled via both the legacy tegra_powergate_xxx functions as well
as the generic PM domain framework, add a bit map for available
powergates that can be controlled via the legacy powergate functions.
Move the majority of the tegra_powergate_remove_clamping() function
to a sub-function, so that this can be used by both the legacy and
generic power domain code.
This is based upon work by Thierry Reding <treding@nvidia.com>
and Vince Hsu <vinceh@nvidia.com>.
Add support for the XUSB pad controller found on Tegra210 SoCs. The
hardware is roughly the same, but some of the registers have been moved
around and the number and type of supported pads has changed.
The Tegra powergate and rail IDs are always positive values and so change
the type to be unsigned and remove the tests to see if the ID is less
than zero. Update the Tegra DC powergate type to be an unsigned as well.
Reviewed-by: Mathieu Poirier <mathieu.poirier@linaro.org>
git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu
Pull iommu updates for from Joerg Roedel:
"This time the IOMMU updates are mostly cleanups or fixes. No big new
features or drivers this time. In particular the changes include:
- Bigger cleanup of the Domain<->IOMMU data structures and the code
that manages them in the Intel VT-d driver. This makes the code
easier to understand and maintain, and also easier to keep the data
structures in sync. It is also a preparation step to make use of
default domains from the IOMMU core in the Intel VT-d driver.
- Fixes for a couple of DMA-API misuses in ARM IOMMU drivers, namely
in the ARM and Tegra SMMU drivers.
- Fix for a potential buffer overflow in the OMAP iommu driver's
debug code
- A couple of smaller fixes and cleanups in various drivers
- One small new feature: Report domain-id usage in the Intel VT-d
driver to easier detect bugs where these are leaked"
* tag 'iommu-updates-v4.3' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu: (83 commits)
iommu/vt-d: Really use upper context table when necessary
x86/vt-d: Fix documentation of DRHD
iommu/fsl: Really fix init section(s) content
iommu/io-pgtable-arm: Unmap and free table when overwriting with block
iommu/io-pgtable-arm: Move init-fn declarations to io-pgtable.h
iommu/msm: Use BUG_ON instead of if () BUG()
iommu/vt-d: Access iomem correctly
iommu/vt-d: Make two functions static
iommu/vt-d: Use BUG_ON instead of if () BUG()
iommu/vt-d: Return false instead of 0 in irq_remapping_cap()
iommu/amd: Use BUG_ON instead of if () BUG()
iommu/amd: Make a symbol static
iommu/amd: Simplify allocation in irq_remapping_alloc()
iommu/tegra-smmu: Parameterize number of TLB lines
iommu/tegra-smmu: Factor out tegra_smmu_set_pde()
iommu/tegra-smmu: Extract tegra_smmu_pte_get_use()
iommu/tegra-smmu: Use __GFP_ZERO to allocate zeroed pages
iommu/tegra-smmu: Remove PageReserved manipulation
iommu/tegra-smmu: Convert to use DMA API
iommu/tegra-smmu: smmu_flush_ptc() wants device addresses
ARM: tegra: Memory controller updates for v4.3-rc1
Adds support for Tegra210, which allows the SMMU to be used on this new
SoC generation.
* tag 'tegra-for-4.3-memory' of git://git.kernel.org/pub/scm/linux/kernel/git/tegra/linux:
memory: tegra: Add Tegra210 support
memory: tegra: Add support for a variable-size client ID bitfield
memory: tegra: Expose supported rates via debugfs
The number of TLB lines was increased from 16 on Tegra30 to 32 on
Tegra114 and later. Parameterize the value so that the initial default
can be set accordingly.
On Tegra30, initializing the value to 32 would effectively disable the
TLB and hence cause massive latencies for memory accesses translated
through the SMMU. This is especially noticeable for isochronuous clients
such as display, whose FIFOs would continuously underrun.
Fixes: 891846516317 ("memory: Add NVIDIA Tegra memory controller support")
Recent versions of the Tegra MC hardware extend the size of the client
ID bitfield in the MC_ERR_STATUS register by one bit. While one could
simply extend the bitfield for older hardware, that would allow data
from reserved bits into the driver code, which is generally a bad idea
on principle. So this patch instead passes in the client ID mask from
from the per-SoC MC data.
There's no MC support for T210 (yet), but when that support winds up
in the kernel, the appropriate soc->client_id_mask value for that chip
will be 0xff.
Based on an original patch by David Ung <davidu@nvidia.com>.
Signed-off-by: Paul Walmsley <paul@pwsan.com>
Cc: Paul Walmsley <pwalmsley@nvidia.com>
Cc: Thierry Reding <treding@nvidia.com>
Cc: David Ung <davidu@nvidia.com>
Drivers should not be using __cpuc_* functions nor outer_cache_flush()
directly. This change partly cleans up tegra-smmu.c.
The only difference between cache handling of the tegra variants is
Denver, which omits the call to outer_cache_flush(). This is due to
Denver being an ARM64 CPU, and the ARM64 architecture does not provide
this function. (This, in itself, is a good reason why these should not
be used.)
[treding@nvidia.com: fix build failure on 64-bit ARM]
There's a mixture of core_* and soc_* prefixes for variables storing
information related to the VDD_CORE rail. Choose one (soc_*) and use it
more consistently.
Add Tegra210 support to the fuses driver and add Tegra210-specific
speedo definitions.
Tegra210 uses a power management controller that is compatible with
earlier SoC generations but adds a couple of power partitions for new
hardware blocks.
Reviewed-by: Paul Walmsley <paul@pwsan.com>
Pull ARM SoC driver updates from Kevin Hilman:
"Some of these are for drivers/soc, where we're now putting
SoC-specific drivers these days. Some are for other driver subsystems
where we have received acks from the appropriate maintainers.
Some highlights:
- simple-mfd: document DT bindings and misc updates
- migrate mach-berlin to simple-mfd for clock, pinctrl and reset
- memory: support for Tegra132 SoC
- memory: introduce tegra EMC driver for scaling memory frequency
- misc. updates for ARM CCI and CCN busses"
* tag 'armsoc-drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (48 commits)
drivers: soc: sunxi: Introduce SoC driver to map SRAMs
arm-cci: Add aliases for PMU events
arm-cci: Add CCI-500 PMU support
arm-cci: Sanitise CCI400 PMU driver specific code
arm-cci: Abstract handling for CCI events
arm-cci: Abstract out the PMU counter details
arm-cci: Cleanup PMU driver code
arm-cci: Do not enable CCI-400 PMU by default
firmware: qcom: scm: Add HDCP Support
ARM: berlin: add an ADC node for the BG2Q
ARM: berlin: remove useless chip and system ctrl compatibles
clk: berlin: drop direct of_iomap of nodes reg property
ARM: berlin: move BG2Q clock node
ARM: berlin: move BG2CD clock node
ARM: berlin: move BG2 clock node
clk: berlin: prepare simple-mfd conversion
pinctrl: berlin: drop SoC stub provided regmap
ARM: berlin: move pinctrl to simple-mfd nodes
pinctrl: berlin: prepare to use regmap provided by syscon
reset: berlin: drop arch_initcall initialization
Merge "ARM: tegra: Add EMC driver for v4.2-rc1" from Thierry Reding:
This introduces the EMC driver that's required to scale the external
memory frequency.
* tag 'tegra-for-4.2-emc' of git://git.kernel.org/pub/scm/linux/kernel/git/tegra/linux:
memory: tegra: Add EMC frequency debugfs entry
memory: tegra: Add EMC (external memory controller) driver
memory: tegra: Add API needed by the EMC driver
of: Add Tegra124 EMC bindings
of: Document timings subnode of nvidia,tegra-mc
Merge "ARM: tegra: RAM code access for v4.2-rc1" from Thierry Reding:
The RAM code is used by the memory and external memory controllers to
determine which set of timings to use for memory frequency scaling.
* tag 'tegra-for-4.2-ramcode' of git://git.kernel.org/pub/scm/linux/kernel/git/tegra/linux:
soc/tegra: fuse: Add RAM code reader helper
of: Document long-ram-code property in nvidia,tegra20-apbmisc
Implements functionality needed to change the rate of the memory bus
clock.
Signed-off-by: Mikko Perttunen <mperttunen@nvidia.com>
Signed-off-by: Tomeu Vizoso <tomeu.vizoso@collabora.com>
The EMC driver needs to know the number of external memory devices and
also needs to update the EMEM configuration based on the new rate of the
memory bus.
To know how to update the EMEM config, looks up the values of the burst
regs in the DT, for a given timing.
The pmc driver was previously exporting tegra_pmc_restart, which was
assigned to machine_desc.init_machine, taking precedence over the
restart handlers registered through register_restart_handler().
Signed-off-by: David Riley <davidriley@chromium.org>
[tomeu.vizoso@collabora.com: Rebased]
Reviewed-by: Alexandre Courbot <acourbot@nvidia.com>
[treding@nvidia.com: minor cleanups]
Needed for the EMC and MC drivers to know what timings from the DT to
use.
Provide clients and swgroups files in debugfs. These files show for
which clients IOMMU translation is enabled and which ASID is associated
with each SWGROUP.
Cc: Hiroshi Doyu <hdoyu@nvidia.com>
Acked-by: Joerg Roedel <jroedel@suse.de>
Subsequent patches will add debugfs files that print the status of the
SWGROUPs. Add a new names field and complement the SoC tables with the
names of the individual SWGROUPs.
Add the chip ID for the NVIDIA Tegra132 SoC family.
Tegra SoCs with 64-bit ARM support don't currently support deep CPU
low-power states in mainline Linux. When this support is added in the
future, it will probably look rather different from the existing
32-bit ARM support, since the ARM64 maintainers' strong preference is
to use PSCI to implement it.
So, for the time being, prevent the CPU suspend-related code and data
in the Tegra PMC driver from compiling on ARM64.
Signed-off-by: Paul Walmsley <pwalmsley@nvidia.com>
Cc: Allen Martin <amartin@nvidia.com>
Cc: Stephen Warren <swarren@nvidia.com>
Cc: Alexandre Courbot <gnurou@gmail.com>
The memory controller on NVIDIA Tegra exposes various knobs that can be
used to tune the behaviour of the clients attached to it.
Currently this driver sets up the latency allowance registers to the HW
defaults. Eventually an API should be exported by this driver (via a
custom API or a generic subsystem) to allow clients to register latency
requirements.
This driver also registers an IOMMU (SMMU) that's implemented by the
memory controller. It is supported on Tegra30, Tegra114 and Tegra124
currently. Tegra20 has a GART instead.
The Tegra SMMU operates on memory clients and SWGROUPs. A memory client
is a unidirectional, special-purpose DMA master. A SWGROUP represents a
set of memory clients that form a logical functional unit corresponding
to a single device. Typically a device has two clients: one client for
read transactions and one client for write transactions, but there are
also devices that have only read clients, but many of them (such as the
display controllers).
Because there is no 1:1 relationship between memory clients and devices
the driver keeps a table of memory clients and the SWGROUPs that they
belong to per SoC. Note that this is an exception and due to the fact
that the SMMU is tightly integrated with the rest of the Tegra SoC. The
use of these tables is discouraged in drivers for generic IOMMU devices
such as the ARM SMMU because the same IOMMU could be used in any number
of SoCs and keeping such tables for each SoC would not scale.
This commit converts the PMC support code to a platform driver. Because
the boot process needs to call into this driver very early, also set up
a minimal environment via an early initcall.
Rather than rely on explicit initialization order called from SoC setup
code, use a plain initcall and rely on initcall ordering to take care of
dependencies.
This driver exposes some functionality (querying the chip ID) needed at
very early stages of the boot process. An early initcall is good enough
provided that some of the dependencies are deferred to later stages. To
make sure any abuses are easily caught, output a warning message if the
chip ID is queried while it can't be read yet.
Subsequent patches will move some of the initialization code from SoC
setup code to regular initcalls. To prevent breakage on other SoCs in
multi-platform builds, these initcalls need to check that they indeed
run on Tegra.
The Tegra20 fuse driver is the only user of tegra_apb_readl_using_dma().
Therefore we can simply the code by incorporating the APB DMA handling into
the driver directly. tegra_apb_writel_using_dma() is dropped because there
are no users.
Signed-off-by: Peter De Schrijver <pdeschrijver@nvidia.com>
Implement fuse driver for Tegra20, Tegra30, Tegra114 and Tegra124. This
replaces functionality previously provided in arch/arm/mach-tegra, which
is removed in this patch.
While at it, move the only user of the global tegra_revision variable
over to tegra_sku_info.revision and export tegra_fuse_readl() to allow
drivers to read calibration fuses.
All fuse related functionality will move to a driver in the following
patches. To prepare for this, export all the required functionality in a
global header file and move all users of fuse.h to soc/tegra/fuse.h.
While we're at it, remove tegra_bct_strapping, as its only user was
removed in Commit a7cbe92cef27 ("ARM: tegra: remove tegra EMC scaling
driver").
Export APB DMA readl and writel. These are needed because we can't
access the fuses directly on Tegra20 without potentially causing a
system hang. Also have the APB DMA readl and writel return an error in
case of a read failure instead of just returning zero or ignore write
failures.
Instead of using a simple variable access to get at the Tegra chip ID,
use a function so that we can run additional code. This can be used to
determine where the chip ID is being accessed without being available.
That in turn will be handy for resolving boot sequence dependencies in
order to convert more code to regular initcalls rather than a sequence
fixed by Tegra SoC setup code.
In order to not clutter the include/linux directory with SoC specific
headers, move the Tegra-specific headers out into a separate directory.
