path: root/include/sound/emu10k1.h
2005-05-29[ALSA] Improve SPDIF playback via the P16V/CA0151 chip.James Courtier-Dutton
EMU10K1/EMU10K2 driver Although we can set 44100 as the output rate, the SPDIF can do it, but the Analog output cannot. The SPDIF has the bug, whereby the Left channel arrives one sample late, so although we don't do any resampling, it is not good for AC3 non-audio output. Signed-off-by: James Courtier-Dutton <James@superbug.co.uk>
2005-05-29[ALSA] Check revision for the proper detection of audigy 2Takashi Iwai
EMU10K1/EMU10K2 driver Check ther revision to detect non-listed audigy 2 boards. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-05-29[ALSA] Use old default id strings for compatibilityTakashi Iwai
EMU10K1/EMU10K2 driver Use expliciitly the old default id strings for backward compatibility. This will make 'alsactl restore' working again. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-05-29[ALSA] clean up card featuresLee Revell
EMU10K1/EMU10K2 driver This patch converts the emu10k1 driver to use the card capabilities structure for some more things. Not extensively tested but seems to work. Signed-off-by: Lee Revell <rlrevell@joe-job.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-05-29[ALSA] Adds Capture to P16V chip.James Courtier-Dutton
EMU10K1/EMU10K2 driver One can select which capture source, but one cannot yet set volumes. Signed-off-by: James Courtier-Dutton <James@superbug.co.uk>
