path: root/include/sound/hwdep.h
2015-02-02ALSA: hwdep: Embed struct deviceTakashi Iwai
Like the previous patch, this one embeds the device object into hwdep object. For a proper object lifecycle, it's freed in the release callback. This also allows us to create sysfs entries via passing to the groups field of the device without explicit function calls. Since each driver can see the device and touch its groups field directly, we don't need to delegate in hwdep core any longer. So, remove the groups field from snd_hwdep, and let the user (in this case only hda_hwdep.c) modify the device groups. Reviewed-by: Jaroslav Kysela <perex@perex.cz> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-02-25ALSA: hwdep: Allow to assign the given parentTakashi Iwai
Just like PCM, allow hwdep to be assigned to a different parent device than the card. It'll be used for the HD-audio codec device in the later patches. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-02-25ALSA: Create sysfs attribute files via groupsTakashi Iwai
Instead of calling each time device_create_file(), create the groups of sysfs attribute files at once in a normal way. Add a new helper function, snd_get_device(), to return the associated device object, so that we can handle the sysfs addition locally. Since the sysfs file addition is done differently now, snd_add_device_sysfs_file() helper function is removed. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2014-02-12ALSA: Drop unused name argument in snd_register_oss_device()Takashi Iwai
The last argument, name, of snd_oss_register_device() is nowhere referred in the function in the current code. Let's drop it. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-02-05ALSA: hwdep - Fix coding styleTakashi Iwai
Fix misc coding style issues in hwdep.h and add some comments. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2007-10-16[ALSA] Changed Jaroslav Kysela's e-mail from perex@suse.cz to perex@perex.czJaroslav Kysela
Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2006-03-22[ALSA] semaphore -> mutex (core part)Ingo Molnar
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] dynamic minors (3/6): store device-specific object pointers dynamicallyClemens Ladisch
Instead of storing the pointers to the device-specific structures in an array, put them into the struct snd_minor, and look them up dynamically. This makes the device type modules independent of the minor number encoding. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2006-01-03[ALSA] Remove xxx_t typedefs: HwdepTakashi Iwai
Modules: HWDEP Midlevel Remove xxx_t typedefs from the core hwdep codes. Signed-off-by: Takashi Iwai <tiwai@suse.de>
