path: root/include/sound/rawmidi.h
2011-06-14ALSA: rawmidi - Use workq for event handlingTakashi Iwai
Kill tasklet usage in rawmidi core code. Use workq for the event callback instead of tasklet (which is used only in core/seq/seq_midi.c). Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-11-10sound: rawmidi: record a substream's owner processClemens Ladisch
Record the pid of the task that opened a RawMIDI substream. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-03-09ALSA: rawmidi - Refactor rawmidi open/close codesTakashi Iwai
Refactor rawmidi open/close code messes. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2007-10-16[ALSA] Changed Jaroslav Kysela's e-mail from perex@suse.cz to perex@perex.czJaroslav Kysela
Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2006-06-22[ALSA] rawmidi: add get_port_info callback for sequencer information flagsClemens Ladisch
Add a get_port_info callback to the snd_rawmidi_global_ops structure to allow the USB MIDI driver to supply information flags for the sequencer ports created by seq_midi. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2006-03-22[ALSA] semaphore -> mutex (core part)Ingo Molnar
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] dynamic minors (3/6): store device-specific object pointers dynamicallyClemens Ladisch
Instead of storing the pointers to the device-specific structures in an array, put them into the struct snd_minor, and look them up dynamically. This makes the device type modules independent of the minor number encoding. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2006-01-03[ALSA] Remove xxx_t typedefs: Raw MIDITakashi Iwai
Modules: RawMidi Midlevel Remove xxx_t typedefs from the core raw MIDI codes. Signed-off-by: Takashi Iwai <tiwai@suse.de>
