It has now become necessary to use a DAPM mutex instead of the codec
mutex to lock the DAPM operations. This is due to the recent multi
component support and forth coming Dynamic PCM updates.
Currently we lock DAPM operations with the codec mutex of the calling
RTD context. However, DAPM operations can span the whole card context
and all components.
This patch updates the DAPM operations that use the codec mutex to
now use the DAPM mutex PCM subclass for all DAPM ops.
We also add a mutex subclass for DAPM init and PCM operations.
Signed-off-by: Liam Girdwood <lrg@ti.com>
(cherry picked from commit a73fb2df01866b772a48fab93401fe3edbe0b38d)
Updated call sequences
Bug 1039523
Change-Id: If079bbe5032971251d6b5426c752cbcc6ad6bcf5
Signed-off-by: Sang-Hun Lee <sanlee@nvidia.com>
Reviewed-on: http://git-master/r/128937
Adding the code for supporting TI AIC3262 codec.
bug 816608
Change-Id: I19c3e03e8fd442c0c19a72a7efeddcd0ca05a7e1
Reviewed-on: http://git-master/r/67279
Reviewed-by: Vinod Gopalakrishnakurup <vinodg@nvidia.com>
Tested-by: Vinod Gopalakrishnakurup <vinodg@nvidia.com>
Reviewed-by: Scott Peterson <speterson@nvidia.com>
Bug: 862023
Change-Id: Ieb9247cef5feecf3e241d8980f9c4376cadf2965
Signed-off-by: Nikesh Oswal <noswal@nvidia.com>
Reviewed-on: http://git-master/r/55465
Reviewed-by: Sumit Bhattacharya <sumitb@nvidia.com>
Rebase-Id: Rf725fad369dbbe4d5f6eaa7b667170a127fa0a08
My gmail account got disabled and I'm not going to reopen it.
Signed-off-by: Jarkko Nikula <jarkko.nikula@bitmer.com>
Acked-by: Liam Girdwood <lrg@ti.com>
For marketing reasons the part will be called WM8996. In order to avoid
user confusion rename the driver to reflect this.
Acked-by: Kukjin Kim <kgene.kim@samsung.com>
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6
* 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (430 commits)
[media] ir-mce_kbd-decoder: include module.h for its facilities
[media] ov5642: include module.h for its facilities
[media] em28xx: Fix DVB-C maxsize for em2884
[media] tda18271c2dd: Fix saw filter configuration for DVB-C @6MHz
[media] v4l: mt9v032: Fix Bayer pattern
[media] V4L: mt9m111: rewrite set_pixfmt
[media] V4L: mt9m111: fix missing return value check mt9m111_reg_clear
[media] V4L: initial driver for ov5642 CMOS sensor
[media] V4L: sh_mobile_ceu_camera: fix Oops when USERPTR mapping fails
[media] V4L: soc-camera: remove soc-camera bus and devices on it
[media] V4L: soc-camera: un-export the soc-camera bus
[media] V4L: sh_mobile_csi2: switch away from using the soc-camera bus notifier
[media] V4L: add media bus configuration subdev operations
[media] V4L: soc-camera: group struct field initialisations together
[media] V4L: soc-camera: remove now unused soc-camera specific PM hooks
[media] V4L: pxa-camera: switch to using standard PM hooks
[media] NetUP Dual DVB-T/C CI RF: force card hardware revision by module param
[media] Don't OOPS if videobuf_dvb_get_frontend return NULL
[media] NetUP Dual DVB-T/C CI RF: load firmware according card revision
[media] omap3isp: Support configurable HS/VS polarities
Fix up conflicts:
- arch/arm/mach-omap2/board-rx51-peripherals.c:
cleanup regulator supply definitions in mach-omap2
vs
OMAP3: RX-51: define vdds_csib regulator supply
- drivers/staging/tm6000/tm6000-alsa.c (trivial)
Change locking to allow tea575x-radio device to be opened multiple times.
Signed-off-by: Ondrej Zary <linux@rainbow-software.org>
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl>
Convert tea575x-tuner to use the new V4L2 control framework. Also add
ext_init() callback that can be used by a card driver for additional
initialization right before registering the video device (for SF16-FMR2).
Also embed struct video_device to struct snd_tea575x to simplify the code.
Acked-by: Hans Verkuil <hverkuil@xs4all.nl>
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (22 commits)
ALSA: hda - Cirrus Logic CS421x support
ALSA: Make pcm.h self-contained
ALSA: hda - Allow codec-specific set_power_state ops
ALSA: hda - Add post_suspend patch ops
ALSA: hda - Make CONFIG_SND_HDA_POWER_SAVE depending on CONFIG_PM
ALSA: hda - Make sure mute led reflects master mute state
ALSA: hda - Fix invalid mute led state on resume of IDT codecs
ASoC: Revert "ASoC: SAMSUNG: Add I2S0 internal dma driver"
ALSA: hda - Add support of the 4 internal speakers on certain HP laptops
ALSA: Make snd_pcm_debug_name usable outside pcm_lib
ALSA: hda - Fix DAC filling for multi-connection pins in Realtek parser
ASoC: dapm - Add methods to retrieve snd_card and soc_card from dapm context.
ASoC: SAMSUNG: Modify I2S driver to support idma
ASoC: davinci: add missing break statement
ASoC: davinci: fix codec start and stop functions
ASoC: dapm - add DAPM macro for external enum widgets
ASoC: Acknowledge WM8962 interrupts before acting on them
ASoC: sgtl5000: guide user when regulator support is needed
ASoC: sgtl5000: refactor registering internal ldo
Move the macros depending on snd_mask_min() and co out of pcm.h into
pcm_params.h. Otherwise using some params_*() macros will give comiple
errors without inclusion of pcm_params.h.
Also use hw_param_interval_c() and hw_param_mask_c() for const pointer.
Reported-by: Tim Blechmann <tim@klingt.org>
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits)
fs: Merge split strings
treewide: fix potentially dangerous trailing ';' in #defined values/expressions
uwb: Fix misspelling of neighbourhood in comment
net, netfilter: Remove redundant goto in ebt_ulog_packet
trivial: don't touch files that are removed in the staging tree
lib/vsprintf: replace link to Draft by final RFC number
doc: Kconfig: `to be' -> `be'
doc: Kconfig: Typo: square -> squared
doc: Konfig: Documentation/power/{pm => apm-acpi}.txt
drivers/net: static should be at beginning of declaration
drivers/media: static should be at beginning of declaration
drivers/i2c: static should be at beginning of declaration
XTENSA: static should be at beginning of declaration
SH: static should be at beginning of declaration
MIPS: static should be at beginning of declaration
ARM: static should be at beginning of declaration
rcu: treewide: Do not use rcu_read_lock_held when calling rcu_dereference_check
Update my e-mail address
PCIe ASPM: forcedly -> forcibly
gma500: push through device driver tree
Fix up trivial conflicts:
- arch/arm/mach-ep93xx/dma-m2p.c (deleted)
- drivers/gpio/gpio-ep93xx.c (renamed and context nearby)
- drivers/net/r8169.c (just context changes)
Formatting a PCM name is useful for module debug too.
Add snd_prefix when making function public.
[minor coding-style fixes by tiwai]
Signed-off-by: Eliot Blennerhassett <eblennerhassett@audioscience.com>
All these are instances of
#define NAME value;
or
#define NAME(params_opt) value;
These of course fail to build when used in contexts like
if(foo $OP NAME)
while(bar $OP NAME)
and may silently generate the wrong code in contexts such as
foo = NAME + 1; /* foo = value; + 1; */
bar = NAME - 1; /* bar = value; - 1; */
baz = NAME & quux; /* baz = value; & quux; */
Reported on comp.lang.c,
Message-ID: <ab0d55fe-25e5-482b-811e-c475aa6065c3@c29g2000yqd.googlegroups.com>
Initial analysis of the dangers provided by Keith Thompson in that thread.
There are many more instances of more complicated macros having unnecessary
trailing semicolons, but this pile seems to be all of the cases of simple
values suffering from the problem. (Thus things that are likely to be found
in one of the contexts above, more complicated ones aren't.)
Signed-off-by: Phil Carmody <ext-phil.2.carmody@nokia.com>
Add a convenience macro for external enumerated widgets.
Allow platform probe to register platform kcontrols and DAPM just like
the CODEC probe().
Allow platform driver widgets to perform any IO required for DAPM.
In preparation for Dynamic PCM (AKA DSP) support.
Allow platform drivers to register kcontrols.
In preparation for ASoC Dynamic PCM (AKA DSP) support.
Allow platform driver to perform IO. Intended for platform DAPM.
One of ioctl definition in sound/sb16_csp.h contains the data size
over 8kB, and this causes build errors on architectures like MIPS,
which define _IOC_SIZEBITS=13.
For avoiding this build errors but keeping the compatibility, manually
expand with _IOC() instead of using _IOW() for the problematic ioctl.
Kill tasklet usage in rawmidi core code. Use workq for the event callback
instead of tasklet (which is used only in core/seq/seq_midi.c).
Trival fixup for move of I/O code into separate file.
sound/soc/soc-cache.c
This will be removed in -next so let's drop it from mainline as soon as
we can in order to minimise surprises.
Normally DAPM will power up any connected audio path. This is not ideal
for sidetone paths as with sidetone paths the audio path is not wanted in
itself, it is only desired if the two paths it provides a sidetone between
are both active. If the sidetone path causes a power up then it can be
hard to minimise pops as we first power up either the sidetone or the main
output path and then power the other, with the second power up potentially
introducing a DC offset.
Address this by introducing the concept of a weak path. If a path is marked
as weak then DAPM will ignore that path when walking the graph, though all
the relevant controls are still available to the application layer to allow
these paths to be configured.
In preparation for the new ASoC Dynamic PCM support (AKA DSP support).
The new ASoC Dynamic PCM core allows DAIs to be dynamically re-routed
at runtime between the PCM device end (or Frontend - FE) and the physical DAI
(Backend - BE) using regular kcontrols (just like a hardware CODEC routes
audio in the analog domain). The Dynamic PCM core therefore must be
able to call PCM operations for both the Frontend and Backend(s) DAIs at
the same time.
Currently we have a global pcm_mutex that is used to serialise
the ASoC PCM operations. This patch removes the global mutex
and adds a mutex per RTD allowing the PCM operations to be reentrant and
allow control of more than one DAI at at time. e.g. a frontend PCM hw_params()
could configure multiple backend DAI hw_params() with similar or different
hw parameters at the same time.
Some ASoC components depend on other ASoC components to provide clocks and
power resources in order to probe() and vice versa for remove().
Allow components to be ordered so that components can be probed() and removed()
in sequences that conform to their dependencies.
Currently pcm_new() passes in 3 arguments :- card, pcm and DAI.
Refactor this to only pass in 1 argument (i.e. the rtd) since struct rtd contains
card, pcm and DAI along with other members too that are useful too.
The card callback will get called for each DAPM context in the card so it
can be useful for it to know which device is currently undergoing a
transition.
Rather than a simple flag to say if we want the DAPM context to be at full
power specify the target bias state. This should have no current effect
but is a bit more direct and so makes it easier to change our decisions
about the which bias state to go into in future.
git://git.kernel.org/pub/scm/linux/kernel/git/lrg/asoc-2.6 into topic/asoc
A driver for the AK4641 codec used in iPAQ hx4700 and Glofiish M800
among others.
Signed-off-by: Harald Welte <laforge@gnumonks.org>
Signed-off-by: Philipp Zabel <philipp.zabel@gmail.com>
Signed-off-by: Dmitry Artamonow <mad_soft@inbox.ru>
Provide real card and bus_info instead of hardcoded values.
struct snd_card *card is present in struct snd_tea575x but never used.
Remove it.
freq_fixup is a constant, no need to hold it in struct snd_tea575x and set in
each driver.
Allow ASoC machine drivers to register a driver name
and a longname. This allows user space to determine
the flavour of machine driver.
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com>
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Implement generic read/write functions to access TEA575x tuners. They're now
implemented 4 times (once in es1968 and 3 times in fm801).
This also allows mute to work on all cards.
Also improve tuner detection/initialization.
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 into for-2.6.40
A future change will allow multiple widgets to be affected by the same
control. For example, a single register bit that controls separate muxes
in both the L and R audio paths.
This change updates the code that handles relevant controls to be able
to iterate over a list of affected widgets. Note that only the put
functions need significant modification to implement the iteration; the
get functions do not need to iterate, nor unify the results, since all
affected widgets reference the same kcontrol.
When creating the list of widgets, always create a 1-sized list, since
the control sharing is not implemented in this change.
Future changes will need reference to the kcontrol created for a given
kcontrol_new. Store the created kcontrol values now.
A future change will modify struct snd_soc_dapm_widget to store the
actual kcontrol pointers for each kcontrol_new in a field named
kcontrols. Rename the existing kcontrols field to enable this.
Move the creation of the DAPM debugfs directory to snd_soc_dapm_debugfs_init
instead of having the same duplicated code in both codec and card DAPM setup.
The enum texts are supposed to be const char * const []. Without the
second const, it gets compile warnings like
sound/soc/codecs/max98095.c:607:2: warning: initialization discards qualifiers from pointer target type
