path: root/include/target
2012-01-25target: Set additional sense length field in sense dataRoland Dreier
commit 895f3022523361e9b383cf48f51feb1f7d5e7e53 upstream. The target code was not setting the additional sense length field in the sense data it returned, which meant that at least the Linux stack ignored the ASC/ASCQ fields. For example, without this patch, on a tcm_loop device: # sg_raw -v /dev/sda 2 0 0 0 0 0 gives cdb to send: 02 00 00 00 00 00 SCSI Status: Check Condition Sense Information: Fixed format, current; Sense key: Illegal Request Raw sense data (in hex): 70 00 05 00 00 00 00 00 while after the patch we correctly get the following (which matches what a regular disk returns): cdb to send: 02 00 00 00 00 00 SCSI Status: Check Condition Sense Information: Fixed format, current; Sense key: Illegal Request Additional sense: Invalid command operation code Raw sense data (in hex): 70 00 05 00 00 00 00 0a 00 00 00 00 20 00 00 00 00 00 Signed-off-by: Roland Dreier <roland@purestorage.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-05-24[SCSI] target: Convert REPORT_LUNs to use int_to_scsilunNicholas Bellinger
This patch converts transport_core_report_lun_response() to use drivers/scsi/scsi_scan.c:int_to_scsilun instead of using the struct target_core_fabric_ops->pack_lun() fabric provided API vector. It also removes the tfo->pack_lun check from target_fabric_tf_ops_check() and removes from struct target_core_fabric_ops->pack_lun() from target_core_fabric_ops.h, and the following mainline scsi-misc fabric modules: *) tcm_loop: Drop tcm_loop_pack_lun() usage *) tcm_fc: Drop ft_pack_lun() usage Reported-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: Nicholas A. Bellinger <nab@linux-iscsi.org> Signed-off-by: James Bottomley <jbottomley@parallels.com>
2011-05-24[SCSI] target: Fix bug with task_sg chained transport_free_dev_tasks releaseNicholas Bellinger
This patch addresses a bug in the target core release path for HW operation where transport_free_dev_tasks() was incorrectly being called from transport_lun_remove_cmd() while releasing a se_cmd reference and calling struct target_core_fabric_ops->queue_data_in(). This would result in a OOPs with HW target mode when the release of se_task->task_sg[] would happen before pci_unmap_sg() can be called in HW target mode fabric module code. This patch addresses the issue by moving transport_free_dev_tasks() from transport_lun_remove_cmd() into transport_generic_free_cmd(), and adding TRANSPORT_FREE_CMD_INTR and transport_generic_free_cmd_intr() to allow se_cmd descriptor release to happen fromfrom within transport_processing_thread() process context when release of se_cmd is not possible from HW interrupt context. Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org> Cc: stable@kernel.org Signed-off-by: James Bottomley <jbottomley@parallels.com>
2011-03-23[SCSI] target: add initial statisticsNicholas Bellinger
This patch adds a target_core_mib.c statistics conversion for backend context struct se_subsystem_dev + struct se_device config_group based statistics in target_core_device.c using CONFIGFS_EATTR() based struct config_item_types from target_core_stat.c code. The conversion from backend /proc/scsi_target/mib/ context output to configfs default groups+attributes include scsi_dev, scsi_lu, and scsi_tgt_dev output from within individual: /sys/kernel/config/target/core/$HBA/DEV/ The legacy procfs output now appear as individual configfs attributes under: *) $HBA/$DEV/statistics/scsi_dev: |-- indx |-- inst |-- ports `-- role *) $HBA/$DEV/statistics/scsi_lu: |-- creation_time |-- dev |-- dev_type |-- full_stat |-- hs_num_cmds |-- indx |-- inst |-- lu_name |-- lun |-- num_cmds |-- prod |-- read_mbytes |-- resets |-- rev |-- state_bit |-- status |-- vend `-- write_mbytes *) $HBA/$DEV/statistics/scsi_tgt_dev: |-- indx |-- inst |-- non_access_lus |-- num_lus |-- resets `-- status The conversion from backend /proc/scsi_target/mib/ context output to configfs default groups+attributes include scsi_port, scsi_tgt_port and scsi_transport output from within individual: /sys/kernel/config/target/fabric/$WWN/tpgt_$TPGT/lun/lun_$LUN_ID/statistics/ The legacy procfs output now appear as individual configfs attributes under: *) fabric/$WWN/tpgt_$TPGT/lun/lun_$LUN_ID/statistics/scsi_port |-- busy_count |-- dev |-- indx |-- inst `-- role *) fabric/$WWN/tpgt_$TPGT/lun/lun_$LUN_ID/statistics/scsi_tgt_port |-- dev |-- hs_in_cmds |-- in_cmds |-- indx |-- inst |-- name |-- port_index |-- read_mbytes `-- write_mbytes *) fabric/$WWN/tpgt_$TPGT/lun/lun_$LUN_ID/statistics/scsi_transport |-- dev_name |-- device |-- indx `-- inst The conversion from backend /proc/scsi_target/mib/ context output to configfs default groups+attributes include scsi_att_intr_port and scsi_auth_intr output from within individual: /sys/kernel/config/target/fabric/$WWN/tpgt_$TPGT/acls/$INITIATOR_WWN/lun_$LUN_ID/statistics/ The legacy procfs output now appear as individual configfs attributes under: *) acls/$INITIATOR_WWN/lun_$LUN_ID/statistics/scsi_att_intr_port |-- dev |-- indx |-- inst |-- port |-- port_auth_indx `-- port_ident *) acls/$INITIATOR_WWN/lun_$LUN_ID/statistics/scsi_auth_intr |-- att_count |-- creation_time |-- dev |-- dev_or_port |-- hs_num_cmds |-- indx |-- inst |-- intr_name |-- map_indx |-- num_cmds |-- port |-- read_mbytes |-- row_status `-- write_mbytes Also, this includes adding struct target_fabric_configfs_template-> tfc_wwn_fabric_stats_cit and ->tfc_tpg_nacl_stat_cit respectively for use during target_core_fabric_configfs.c:target_fabric_setup_cits() Signed-off-by: Nicholas A. Bellinger <nab@linux-iscsi.org> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2011-03-23[SCSI] target: update version to v4.0.0-rc7-mlNicholas Bellinger
2011-03-23[SCSI] target: Convert TMR REQ/RSP definitions to target namespaceNicholas Bellinger
This patch changes include/target/target_core_tmr.h code to use target specific 'TMR_*' prefixed definitions for fabric independent SCSI Task Management Request/Request naming in include/scsi/scsi.h definitions for mainline target code. Signed-off-by: Nicholas A. Bellinger <nab@linux-iscsi.org> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2011-03-23[SCSI] target: Remove spurious double cast from structure macro accessorsNicholas Bellinger
Reported-by: Fubo Chen <fubo.chen@gmail.com> Cc: James Bottomley <James.Bottomley@suse.de> Signed-off-by: Nicholas A. Bellinger <nab@linux-iscsi.org> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2011-03-23[SCSI] target: Minor sparse warning fixes and annotationsDan Carpenter
This patch addresses the majority of sparse warnings and adds proper locking annotations. It also fixes the dubious one-bit signed bitfield, for which the signed one-bit types can be 0 or -1 which can cause a problem if someone ever checks if (foo->lu_gp_assoc == 1). The current code is fine because everyone just checks zero vs non-zero. But Sparse complains about it so lets change it. The warnings look like this: include/target/target_core_base.h:228:26: error: dubious one-bit signed bitfield Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Fubo Chen <fubo.chen@gmail.com> Signed-off-by: Nicholas A. Bellinger <nab@linux-iscsi.org> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2011-02-28[SCSI] target: Fix t_transport_aborted handling in LUN_RESET + active I/O ↵Nicholas Bellinger
shutdown This patch addresses two outstanding bugs related to T_TASK(cmd)->t_transport_aborted handling during TMR LUN_RESET and active I/O shutdown. This first involves adding two explict t_transport_aborted=1 assignments in core_tmr_lun_reset() in order to signal the task has been aborted, and updating transport_generic_wait_for_tasks() to skip sleeping when t_transport_aborted=1 has been set. This fixes an issue where transport_generic_wait_for_tasks() would end up sleeping indefinately when called from fabric module context while TMR LUN_RESET was happening with long outstanding backend struct se_task not yet being completed. The second adds a missing call to transport_remove_task_from_execute_queue() when task->task_execute_queue=1 is set in order to fix an OOPs when task->t_execute_list has not been dropped. It also fixes the same case in transport_processing_shutdown() to prevent the issue from happening during active I/O struct se_device shutdown. Signed-off-by: Nicholas A. Bellinger <nab@linux-iscsi.org> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2011-02-12[SCSI] target: fix use after free detected by SLUB poisonNicholas Bellinger
This patch moves a large number of memory release paths inside of the configfs callback target_core_hba_item_ops->release() called from within fs/configfs/item.c: config_item_cleanup() context. This patch resolves the SLUB 'Poison overwritten' warnings. Signed-off-by: Nicholas A. Bellinger <nab@linux-iscsi.org> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2011-02-12[SCSI] target: Remove procfs based target_core_mib.c codeNicholas Bellinger
This patch removes the legacy procfs based target_core_mib.c code, and moves the necessary scsi_index_tables functions and defines into target_core_transport.c and target_core_base.h code to allow existing fabric independent statistics to function. This includes the removal of a handful of 'atomic_t mib_ref_count' counters used in struct se_node_acl, se_session and se_hba to prevent removal while using seq_list procfs walking logic. [jejb: fix up compile failures] Signed-off-by: Nicholas A. Bellinger <nab@linux-iscsi.org> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2011-01-14[SCSI] target: Add LIO target core v4.0.0-rc6Nicholas Bellinger
LIO target is a full featured in-kernel target framework with the following feature set: High-performance, non-blocking, multithreaded architecture with SIMD support. Advanced SCSI feature set: * Persistent Reservations (PRs) * Asymmetric Logical Unit Assignment (ALUA) * Protocol and intra-nexus multiplexing, load-balancing and failover (MC/S) * Full Error Recovery (ERL=0,1,2) * Active/active task migration and session continuation (ERL=2) * Thin LUN provisioning (UNMAP and WRITE_SAMExx) Multiprotocol target plugins Storage media independence: * Virtualization of all storage media; transparent mapping of IO to LUNs * No hard limits on number of LUNs per Target; maximum LUN size ~750 TB * Backstores: SATA, SAS, SCSI, BluRay, DVD, FLASH, USB, ramdisk, etc. Standards compliance: * Full compliance with IETF (RFC 3720) * Full implementation of SPC-4 PRs and ALUA Significant code cleanups done by Christoph Hellwig. [jejb: fix up for new block bdev exclusive interface. Minor fixes from Randy Dunlap and Dan Carpenter.] Signed-off-by: Nicholas A. Bellinger <nab@linux-iscsi.org> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
