commit 25cdda95fda78d22d44157da15aa7ea34be3c804 upstream.
This patch fixes a OOPs originally introduced by:
commit bb048357dad6d604520c91586334c9c230366a14
Author: Nicholas Bellinger <nab@linux-iscsi.org>
Date: Thu Sep 5 14:54:04 2013 -0700
iscsi-target: Add sk->sk_state_change to cleanup after TCP failure
which would trigger a NULL pointer dereference when a TCP connection
was closed asynchronously via iscsi_target_sk_state_change(), but only
when the initial PDU processing in iscsi_target_do_login() from iscsi_np
process context was blocked waiting for backend I/O to complete.
To address this issue, this patch makes the following changes.
First, it introduces some common helper functions used for checking
socket closing state, checking login_flags, and atomically checking
socket closing state + setting login_flags.
Second, it introduces a LOGIN_FLAGS_INITIAL_PDU bit to know when a TCP
connection has dropped via iscsi_target_sk_state_change(), but the
initial PDU processing within iscsi_target_do_login() in iscsi_np
context is still running. For this case, it sets LOGIN_FLAGS_CLOSED,
but doesn't invoke schedule_delayed_work().
The original NULL pointer dereference case reported by MNC is now handled
by iscsi_target_do_login() doing a iscsi_target_sk_check_close() before
transitioning to FFP to determine when the socket has already closed,
or iscsi_target_start_negotiation() if the login needs to exchange
more PDUs (eg: iscsi_target_do_login returned 0) but the socket has
closed. For both of these cases, the cleanup up of remaining connection
resources will occur in iscsi_target_start_negotiation() from iscsi_np
process context once the failure is detected.
Finally, to handle to case where iscsi_target_sk_state_change() is
called after the initial PDU procesing is complete, it now invokes
conn->login_work -> iscsi_target_do_login_rx() to perform cleanup once
existing iscsi_target_sk_check_close() checks detect connection failure.
For this case, the cleanup of remaining connection resources will occur
in iscsi_target_do_login_rx() from delayed workqueue process context
Reported-by: Mike Christie <mchristi@redhat.com>
Reviewed-by: Mike Christie <mchristi@redhat.com>
Tested-by: Mike Christie <mchristi@redhat.com>
Cc: Mike Christie <mchristi@redhat.com>
Reported-by: Hannes Reinecke <hare@suse.com>
Cc: Hannes Reinecke <hare@suse.com>
Cc: Sagi Grimberg <sagi@grimberg.me>
Cc: Varun Prakash <varun@chelsio.com>
commit 49cb77e297dc611a1b795cfeb79452b3002bd331 upstream.
This patch closes a race between se_lun deletion during configfs
unlink in target_fabric_port_unlink() -> core_dev_del_lun()
-> core_tpg_remove_lun(), when transport_clear_lun_ref() blocks
waiting for percpu_ref RCU grace period to finish, but a new
NodeACL mappedlun is added before the RCU grace period has
completed.
This can happen in target_fabric_mappedlun_link() because it
only checks for se_lun->lun_se_dev, which is not cleared until
after transport_clear_lun_ref() percpu_ref RCU grace period
finishes.
This bug originally manifested as NULL pointer dereference
OOPsen in target_stat_scsi_att_intr_port_show_attr_dev() on
v4.1.y code, because it dereferences lun->lun_se_dev without
a explicit NULL pointer check.
In post v4.1 code with target-core RCU conversion, the code
in target_stat_scsi_att_intr_port_show_attr_dev() no longer
uses se_lun->lun_se_dev, but the same race still exists.
To address the bug, go ahead and set se_lun>lun_shutdown as
early as possible in core_tpg_remove_lun(), and ensure new
NodeACL mappedlun creation in target_fabric_mappedlun_link()
fails during se_lun shutdown.
Reported-by: James Shen <jcs@datera.io>
Cc: James Shen <jcs@datera.io>
Tested-by: James Shen <jcs@datera.io>
commit 138d351eefb727ab9e41a3dc5f112ceb4f6e59f2 upstream.
This patch re-introduces part of a long standing login workaround that
was recently dropped by:
commit 1c99de981f30b3e7868b8d20ce5479fa1c0fea46
Date: Sun Apr 2 13:36:44 2017 -0700
iscsi-target: Drop work-around for legacy GlobalSAN initiator
Namely, the workaround for FirstBurstLength ended up being required by
Mellanox Flexboot PXE boot ROMs as reported by Robert.
So this patch re-adds the work-around for FirstBurstLength within
iscsi_check_proposer_for_optional_reply(), and makes the key optional
to respond when the initiator does not propose, nor respond to it.
Also as requested by Arun, this patch introduces a new TPG attribute
named 'login_keys_workaround' that controls the use of both the
FirstBurstLength workaround, as well as the two other existing
workarounds for gPXE iSCSI boot client.
By default, the workaround is enabled with login_keys_workaround=1,
since Mellanox FlexBoot requires it, and Arun has verified the Qlogic
MSFT initiator already proposes FirstBurstLength, so it's uneffected
by this re-adding this part of the original work-around.
Reported-by: Robert LeBlanc <robert@leblancnet.us>
Cc: Robert LeBlanc <robert@leblancnet.us>
Reviewed-by: Arun Easi <arun.easi@cavium.com>
commit d36ad77f702356afb1009d2987b0ab55da4c7d57 upstream.
This patch converts core_tpg_set_initiator_node_queue_depth()
to use struct se_node_acl->acl_sess_list when performing
explicit se_tpg_tfo->shutdown_session() for active sessions,
in order for new se_node_acl->queue_depth to take effect.
This follows how core_tpg_del_initiator_node_acl() currently
works when invoking se_tpg_tfo->shutdown-session(), and ahead
of the next patch to take se_node_acl->acl_kref during lookup,
the extra get_initiator_node_acl() can go away. In order to
achieve this, go ahead and change target_get_session() to use
kref_get_unless_zero() and propigate up the return value
to know when a session is already being released.
This is because se_node_acl->acl_group is already protecting
se_node_acl->acl_group reference via configfs, and shutdown
within core_tpg_del_initiator_node_acl() won't occur until
sys_write() to core_tpg_set_initiator_node_queue_depth()
attribute returns back to user-space.
Also, drop the left-over iscsi-target hack, and obtain
se_portal_group->session_lock in lio_tpg_shutdown_session()
internally. Remove iscsi-target wrapper and unused se_tpg +
force parameters and associated code.
Reported-by: Christoph Hellwig <hch@lst.de>
Cc: Sagi Grimberg <sagig@mellanox.com>
Cc: Hannes Reinecke <hare@suse.de>
Cc: Andy Grover <agrover@redhat.com>
Cc: Mike Christie <michaelc@cs.wisc.edu>
commit bd4e2d2907fa23a11d46217064ecf80470ddae10 upstream.
When transport_clear_lun_ref() is shutting down a se_lun via
configfs with new I/O in-flight, it's possible to trigger a
NULL pointer dereference in transport_lookup_cmd_lun() due
to the fact percpu_ref_get() doesn't do any __PERCPU_REF_DEAD
checking before incrementing lun->lun_ref.count after
lun->lun_ref has switched to atomic_t mode.
This results in a NULL pointer dereference as LUN shutdown
code in core_tpg_remove_lun() continues running after the
existing ->release() -> core_tpg_lun_ref_release() callback
completes, and clears the RCU protected se_lun->lun_se_dev
pointer.
During the OOPs, the state of lun->lun_ref in the process
which triggered the NULL pointer dereference looks like
the following on v4.1.y stable code:
struct se_lun {
lun_link_magic = 4294932337,
lun_status = TRANSPORT_LUN_STATUS_FREE,
lun_se_dev = 0x0,
lun_sep = 0x0,
lun_ref = {
count = {
counter = 1
percpu_count_ptr = 3,
release = 0xffffffffa02fa1e0 <core_tpg_lun_ref_release>,
confirm_switch = 0x0,
force_atomic = false,
rcu = {
next = 0xffff88154fa1a5d0,
func = 0xffffffff8137c4c0 <percpu_ref_switch_to_atomic_rcu>
To address this bug, use percpu_ref_tryget_live() to ensure
once __PERCPU_REF_DEAD is visable on all CPUs and ->lun_ref
has switched to atomic_t, all new I/Os will fail to obtain
a new lun->lun_ref reference.
Also use an explicit percpu_ref_kill_and_confirm() callback
to block on ->lun_ref_comp to allow the first stage and
associated RCU grace period to complete, and then block on
->lun_ref_shutdown waiting for the final percpu_ref_put()
to drop the last reference via transport_lun_remove_cmd()
before continuing with core_tpg_remove_lun() shutdown.
Reported-by: Rob Millner <rlm@daterainc.com>
Tested-by: Rob Millner <rlm@daterainc.com>
Cc: Rob Millner <rlm@daterainc.com>
Tested-by: Vaibhav Tandon <vst@datera.io>
Cc: Vaibhav Tandon <vst@datera.io>
Tested-by: Bryant G. Ly <bryantly@linux.vnet.ibm.com>
commit 01d4d673558985d9a118e1e05026633c3e2ade9b upstream.
This patch addresses a long-standing bug with multi-session
(eg: iscsi-target + iser-target) se_node_acl dynamic free
withini transport_deregister_session().
This bug is caused when a storage endpoint is configured with
demo-mode (generate_node_acls = 1 + cache_dynamic_acls = 1)
initiators, and initiator login creates a new dynamic node acl
and attaches two sessions to it.
After that, demo-mode for the storage instance is disabled via
configfs (generate_node_acls = 0 + cache_dynamic_acls = 0) and
the existing dynamic acl is never converted to an explicit ACL.
The end result is dynamic acl resources are released twice when
the sessions are shutdown in transport_deregister_session().
If the storage instance is not changed to disable demo-mode,
or the dynamic acl is converted to an explict ACL, or there
is only a single session associated with the dynamic ACL,
the bug is not triggered.
To address this big, move the release of dynamic se_node_acl
memory into target_complete_nacl() so it's only freed once
when se_node_acl->acl_kref reaches zero.
(Drop unnecessary list_del_init usage - HCH)
commit 21aaa23b0ebbd19334fa461370c03cbb076b3295 upstream.
This patch addresses a long standing race where obtaining
se_node_acl->acl_kref in __transport_register_session()
happens a bit too late, and leaves open the potential
for core_tpg_del_initiator_node_acl() to hit a NULL
pointer dereference.
Instead, take ->acl_kref in core_tpg_get_initiator_node_acl()
while se_portal_group->acl_node_mutex is held, and move the
final target_put_nacl() from transport_deregister_session()
into transport_free_session() so that fabric driver login
failure handling using the modern method to still work
as expected.
Also, update core_tpg_get_initiator_node_acl() to take
an extra reference for dynamically generated acls for
demo-mode, before returning to fabric caller. Also
update iscsi-target sendtargets special case handling
to use target_tpg_has_node_acl() when checking if
demo_mode_discovery == true during discovery lookup.
Note the existing wait_for_completion(&acl->acl_free_comp)
in core_tpg_del_initiator_node_acl() does not change.
commit 449a137846c84829a328757cd21fd9ca65c08519 upstream.
This patch addresses a bug where EXTENDED_COPY across multiple LUNs
results in a CHECK_CONDITION when the source + destination are not
located on the same physical node.
ESX Host environments expect sense COPY_ABORTED w/ COPY TARGET DEVICE
NOT REACHABLE to be returned when this occurs, in order to signal
fallback to local copy method.
As described in section 6.3.3 of spc4r22:
"If it is not possible to complete processing of a segment because the
copy manager is unable to establish communications with a copy target
device, because the copy target device does not respond to INQUIRY,
or because the data returned in response to INQUIRY indicates
an unsupported logical unit, then the EXTENDED COPY command shall be
terminated with CHECK CONDITION status, with the sense key set to
COPY ABORTED, and the additional sense code set to COPY TARGET DEVICE
NOT REACHABLE."
Tested on v4.1.y with ESX v5.5u2+ with BlockCopy across multiple nodes.
Reported-by: Nixon Vincent <nixon.vincent@calsoftinc.com>
Tested-by: Nixon Vincent <nixon.vincent@calsoftinc.com>
Cc: Nixon Vincent <nixon.vincent@calsoftinc.com>
Tested-by: Dinesh Israni <ddi@datera.io>
Signed-off-by: Dinesh Israni <ddi@datera.io>
Cc: Dinesh Israni <ddi@datera.io>
commit 410c29dfbfdf73d0d0b5d14a21868ab038eca703 upstream.
If a Simple command is sent with a failure, target_setup_cmd_from_cdb
returns with TCM_UNSUPPORTED_SCSI_OPCODE or TCM_INVALID_CDB_FIELD.
So in the cases where target_setup_cmd_from_cdb returns an error, we
never get far enough to call target_execute_cmd to increment simple_cmds.
Since simple_cmds isn't incremented, the result of the failure from
target_setup_cmd_from_cdb causes transport_generic_request_failure to
decrement simple_cmds, due to call to transport_complete_task_attr.
With this dev->simple_cmds or dev->dev_ordered_sync is now -1, not 0.
So when a subsequent command with an Ordered Task is sent, it causes
a hang, since dev->simple_cmds is at -1.
Signed-off-by: Bryant G. Ly <bryantly@linux.vnet.ibm.com>
Tested-by: Michael Cyr <mikecyr@linux.vnet.ibm.com>
Signed-off-by: Michael Cyr <mikecyr@linux.vnet.ibm.com>
commit ea263c7fada4af8ec7fe5fcfd6e7d7705a89351b upstream.
max_discard_sectors only 32bits, and some non scsi backend
devices will set this to the max 0xffffffff, so we can end up
overflowing during the max_unmap_lba_count calculation.
This fixes a regression caused by my patch:
commit 8a9ebe717a133ba7bc90b06047f43cc6b8bcb8b3
Author: Mike Christie <mchristi@redhat.com>
Date: Mon Jan 18 14:09:27 2016 -0600
target: Fix WRITE_SAME/DISCARD conversion to linux 512b sectors
which can result in extra discards being sent to due the overflow
causing max_unmap_lba_count to be smaller than what the backing
device can actually support.
Signed-off-by: Mike Christie <mchristi@redhat.com>
Reviewed-by: Bart Van Assche <bart.vanassche@sandisk.com>
commit dff0ca9ea7dc8be2181a62df4a722c32ce68ff4a upstream.
If a command with a Simple task attribute is failed due to a Unit
Attention, then a subsequent command with an Ordered task attribute
will hang forever. The reason for this is that the Unit Attention
status is checked for in target_setup_cmd_from_cdb, before the call
to target_execute_cmd, which calls target_handle_task_attr, which
in turn increments dev->simple_cmds.
However, transport_generic_request_failure still calls
transport_complete_task_attr, which will decrement dev->simple_cmds.
In this case, simple_cmds is now -1. So when a command with the
Ordered task attribute is sent, target_handle_task_attr sees that
dev->simple_cmds is not 0, so it decides it can't execute the
command until all the (nonexistent) Simple commands have completed.
Reported-by: Michael Cyr <mikecyr@linux.vnet.ibm.com>
Reported-by: Bryant G. Ly <bryantly@linux.vnet.ibm.com>
commit 8a9ebe717a133ba7bc90b06047f43cc6b8bcb8b3 upstream.
In a couple places we are not converting to/from the Linux
block layer 512 bytes sectors.
1.
The request queue values and what we do are a mismatch of
things:
max_discard_sectors - This is in linux block layer 512 byte
sectors. We are just copying this to max_unmap_lba_count.
discard_granularity - This is in bytes. We are converting it
to Linux block layer 512 byte sectors.
discard_alignment - This is in bytes. We are just copying
this over.
The problem is that the core LIO code exports these values in
spc_emulate_evpd_b0 and we use them to test request arguments
in sbc_execute_unmap, but we never convert to the block size
we export to the initiator. If we are not using 512 byte sectors
then we are exporting the wrong values or are checks are off.
And, for the discard_alignment/bytes case we are just plain messed
up.
2.
blkdev_issue_discard's start and number of sector arguments
are supposed to be in linux block layer 512 byte sectors. We are
currently passing in the values we get from the initiator which
might be based on some other sector size.
There is a similar problem in iblock_execute_write_same where
the bio functions want values in 512 byte sectors but we are
passing in what we got from the initiator.
[ kamal: backport to 4.4-stable: no unmap_zeroes_data ]
Signed-off-by: Kamal Mostafa <kamal@canonical.com>
commit 0f4a943168f31d29a1701908931acaba518b131a upstream.
To address the bug where fabric driver level shutdown
of se_cmd occurs at the same time when TMR CMD_T_ABORTED
is happening resulting in a -1 ->cmd_kref, this patch
adds a CMD_T_FABRIC_STOP bit that is used to determine
when TMR + driver I_T nexus shutdown is happening
concurrently.
It changes target_sess_cmd_list_set_waiting() to obtain
se_cmd->cmd_kref + set CMD_T_FABRIC_STOP, and drop local
reference in target_wait_for_sess_cmds() and invoke extra
target_put_sess_cmd() during Task Aborted Status (TAS)
when necessary.
Also, it adds a new target_wait_free_cmd() wrapper around
transport_wait_for_tasks() for the special case within
transport_generic_free_cmd() to set CMD_T_FABRIC_STOP,
and is now aware of CMD_T_ABORTED + CMD_T_TAS status
bits to know when an extra transport_put_cmd() during
TAS is required.
Note transport_generic_free_cmd() is expected to block on
cmd->cmd_wait_comp in order to follow what iscsi-target
expects during iscsi_conn context se_cmd shutdown.
Cc: Quinn Tran <quinn.tran@qlogic.com>
Cc: Himanshu Madhani <himanshu.madhani@qlogic.com>
Signed-off-by: Nicholas Bellinger <nab@daterainc.com>
commit febe562c20dfa8f33bee7d419c6b517986a5aa33 upstream.
This patch fixes a NULL pointer se_cmd->cmd_kref < 0
refcount bug during TMR LUN_RESET with active se_cmd
I/O, that can be triggered during se_cmd descriptor
shutdown + release via core_tmr_drain_state_list() code.
To address this bug, add common __target_check_io_state()
helper for ABORT_TASK + LUN_RESET w/ CMD_T_COMPLETE
checking, and set CMD_T_ABORTED + obtain ->cmd_kref for
both cases ahead of last target_put_sess_cmd() after
TFO->aborted_task() -> transport_cmd_finish_abort()
callback has completed.
It also introduces SCF_ACK_KREF to determine when
transport_cmd_finish_abort() needs to drop the second
extra reference, ahead of calling target_put_sess_cmd()
for the final kref_put(&se_cmd->cmd_kref).
It also updates transport_cmd_check_stop() to avoid
holding se_cmd->t_state_lock while dropping se_cmd
device state via target_remove_from_state_list(), now
that core_tmr_drain_state_list() is holding the
se_device lock while checking se_cmd state from
within TMR logic.
Finally, move transport_put_cmd() release of SGL +
TMR + extended CDB memory into target_free_cmd_mem()
in order to avoid potential resource leaks in TMR
ABORT_TASK + LUN_RESET code-paths. Also update
target_release_cmd_kref() accordingly.
Reviewed-by: Quinn Tran <quinn.tran@qlogic.com>
This patch addresses a race + use after free where the first
stage of COMPARE_AND_WRITE in compare_and_write_callback()
is rescheduled after the backend sends the secondary WRITE,
resulting in second stage compare_and_write_post() callback
completing in target_complete_ok_work() before the first
can return.
Because current code depends on checking se_cmd->se_cmd_flags
after return from se_cmd->transport_complete_callback(),
this results in first stage having SCF_COMPARE_AND_WRITE_POST
set, which incorrectly falls through into second stage CAW
processing code, eventually triggering a NULL pointer
dereference due to use after free.
To address this bug, pass in a new *post_ret parameter into
se_cmd->transport_complete_callback(), and depend upon this
value instead of ->se_cmd_flags to determine when to return
or fall through into ->queue_status() code for CAW.
Cc: <stable@vger.kernel.org> # v3.12+
git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending
Pull SCSI target updates from Nicholas Bellinger:
"This series contains HCH's changes to absorb configfs attribute
->show() + ->store() function pointer usage from it's original
tree-wide consumers, into common configfs code.
It includes usb-gadget, target w/ drivers, netconsole and ocfs2
changes to realize the improved simplicity, that now renders the
original include/target/configfs_macros.h CPP magic for fabric drivers
and others, unnecessary and obsolete.
And with common code in place, new configfs attributes can be added
easier than ever before.
Note, there are further improvements in-flight from other folks for
v4.5 code in configfs land, plus number of target fixes for post -rc1
code"
In the meantime, a new user of the now-removed old configfs API came in
through the char/misc tree in commit 7bd1d4093c2f ("stm class: Introduce
an abstraction for System Trace Module devices").
This merge resolution comes from Alexander Shishkin, who updated his stm
class tracing abstraction to account for the removal of the old
show_attribute and store_attribute methods in commit 517982229f78
("configfs: remove old API") from this pull. As Alexander says about
that patch:
"There's no need to keep an extra wrapper structure per item and the
awkward show_attribute/store_attribute item ops are no longer needed.
This patch converts policy code to the new api, all the while making
the code quite a bit smaller and easier on the eyes.
Signed-off-by: Alexander Shishkin <alexander.shishkin@linux.intel.com>"
That patch was folded into the merge so that the tree should be fully
bisectable.
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: (23 commits)
ocfs2/cluster: use per-attribute show and store methods
ocfs2/cluster: move locking into attribute store methods
netconsole: use per-attribute show and store methods
target: use per-attribute show and store methods
spear13xx_pcie_gadget: use per-attribute show and store methods
dlm: use per-attribute show and store methods
usb-gadget/f_serial: use per-attribute show and store methods
usb-gadget/f_phonet: use per-attribute show and store methods
usb-gadget/f_obex: use per-attribute show and store methods
usb-gadget/f_uac2: use per-attribute show and store methods
usb-gadget/f_uac1: use per-attribute show and store methods
usb-gadget/f_mass_storage: use per-attribute show and store methods
usb-gadget/f_sourcesink: use per-attribute show and store methods
usb-gadget/f_printer: use per-attribute show and store methods
usb-gadget/f_midi: use per-attribute show and store methods
usb-gadget/f_loopback: use per-attribute show and store methods
usb-gadget/ether: use per-attribute show and store methods
usb-gadget/f_acm: use per-attribute show and store methods
usb-gadget/f_hid: use per-attribute show and store methods
This also allows to remove the target-specific old configfs macros, and
gets rid of the target_core_fabric_configfs.h header which only had one
function declaration left that could be moved to a better place.
Reviewed-by: Nicholas Bellinger <nab@linux-iscsi.org>
Acked-by: Nicholas Bellinger <nab@linux-iscsi.org>
This patch adds a DF_READ_ONLY flag that is used by IBLOCK to
signal when a backend has been set to read-only mode, in order
to propigate read-only status up to core_tpg_add_lun() for all
future LUN fabric exports.
With this is place, existing emulation for reporting read-only
in spc_emulate_modesense() and normal transport_lookup_cmd_lun()
TCM_WRITE_PROTECTED status checking just works as expected.
Reported-by: Joeue Deng <joeue404@gmail.com>
Reported-by: Andy Grover <agrover@redhat.com>
"Here are the outstanding target-pending updates for v4.3-rc1.
Mostly bug-fixes and minor changes this round. The fallout from the
big v4.2-rc1 RCU conversion have (thus far) been minimal.
The highlights this round include:
- Move sense handling routines into scsi_common code (Sagi)
- Return ABORTED_COMMAND sense key for PI errors (Sagi)
- Add tpg_enabled_sendtargets attribute for disabled iscsi-target
discovery (David)
- Shrink target struct se_cmd by rearranging fields (Roland)
- Drop iSCSI use of mutex around max_cmd_sn increment (Roland)
- Replace iSCSI __kernel_sockaddr_storage with sockaddr_storage (Andy +
Chris)
- Honor fabric max_data_sg_nents I/O transfer limit (Arun + Himanshu +
nab)
- Fix EXTENDED_COPY >= v4.1 regression OOPsen (Alex + nab)"
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: (37 commits)
target: use stringify.h instead of own definition
target/user: Fix UFLAG_UNKNOWN_OP handling
target: Remove no-op conditional
target/user: Remove unused variable
target: Fix max_cmd_sn increment w/o cmdsn mutex regressions
target: Attach EXTENDED_COPY local I/O descriptors to xcopy_pt_sess
target/qla2xxx: Honor max_data_sg_nents I/O transfer limit
target/iscsi: Replace __kernel_sockaddr_storage with sockaddr_storage
target/iscsi: Replace conn->login_ip with login_sockaddr
target/iscsi: Keep local_ip as the actual sockaddr
target/iscsi: Fix np_ip bracket issue by removing np_ip
target: Drop iSCSI use of mutex around max_cmd_sn increment
qla2xxx: Update tcm_qla2xxx module description to 24xx+
iscsi-target: Add tpg_enabled_sendtargets for disabled discovery
drivers: target: Drop unlikely before IS_ERR(_OR_NULL)
target: check DPO/FUA usage for COMPARE AND WRITE
target: Shrink struct se_cmd by rearranging fields
target: Remove cmd->se_ordered_id (unused except debug log lines)
target: add support for START_STOP_UNIT SCSI opcode
target: improve unsupported opcode message
This patch adds an optional fabric driver provided SGL limit
that target-core will honor as it's own internal I/O maximum
transfer length limit, as exposed by EVPD=0xb0 block limits
parameters.
This is required for handling cases when host I/O transfer
length exceeds the requested EVPD block limits maximum
transfer length. The initial user of this logic is qla2xxx,
so that we can avoid having to reject I/Os from some legacy
FC hosts where EVPD=0xb0 parameters are not honored.
When se_cmd payload length exceeds the provided limit in
target_check_max_data_sg_nents() code, se_cmd->data_length +
se_cmd->prot_length are reset with se_cmd->residual_count
plus underflow bit for outgoing TFO response callbacks.
It also checks for existing CDB level underflow + overflow
and recalculates final residual_count as necessary.
Note this patch currently assumes 1:1 mapping of PAGE_SIZE
per struct scatterlist entry.
Reported-by: Craig Watson <craig.watson@vanguard-rugged.com>
Cc: Craig Watson <craig.watson@vanguard-rugged.com>
Tested-by: Himanshu Madhani <himanshu.madhani@qlogic.com>
Cc: Roland Dreier <roland@purestorage.com>
Cc: Arun Easi <arun.easi@qlogic.com>
Cc: Giridhar Malavali <giridhar.malavali@qlogic.com>
Cc: Andrew Vasquez <andrew.vasquez@qlogic.com>
Cc: Martin K. Petersen <martin.petersen@oracle.com>
It appears to be what the rest of the kernel does, so let's do it too.
Signed-off-by: Andy Grover <agrover@redhat.com>
Very similar to how it went with local_sockaddr.
It was embedded in iscsi_login_stats so some changes there, and we needed
to copy in a sockaddr_storage comparison function. Hopefully the kernel
will get a standard one soon, our implementation makes the 3rd.
isert_set_conn_info() became much smaller.
IPV6_ADDRESS_SPACE define goes away, had to modify a call to in6_pton(),
can just use -1 since we are sure string is null-terminated.
This is a more natural format that lets us format it with the appropriate
printk specifier as needed.
This also lets us handle v4-mapped ipv6 addresses a little more nicely, by
storing the addr as an actual v4 sockaddr in conn->local_sockaddr.
Finally, we no longer need to maintain variables for port, since this is
contained in sockaddr. Remove iscsi_np.np_port and iscsi_conn.local_port.
Revert commit 1997e6259, which causes double brackets on ipv6
inaddr_any addresses.
Since we have np_sockaddr, if we need a textual representation we can
use "%pISc".
Change iscsit_add_network_portal() and iscsit_add_np() signatures to remove
*ip_str parameter.
Fix and extend some comments earlier in the function.
Tested to work for :: and ::1 via iscsiadm, previously :: failed, see
https://bugzilla.redhat.com/show_bug.cgi?id=1249107 .
CC: stable@vger.kernel.org
In a performance profile, taking a mutex in iscsit_increment_maxcmdsn()
shows up very high. However taking a mutex around "sess->max_cmd_sn += 1"
seems pretty silly: we're not serializing against other contexts in
any useful way.
I did a quick audit and there don't appear to be any other places that
use max_cmd_sn within the mutex more than once, so this lock can't be
providing any useful serialization.
(Get correct values for logging - fix whitespace damage)
Signed-off-by: Roland Dreier <roland@purestorage.com>
Signed-off-by: Spencer Baugh <sbaugh@catern.com>
This patch adds a new tpg_enabled_sendtargets configfs attribute
to allow in-band sendtargets discovery information to include
target-portal-groups (TPGs) in !TPG_STATE_ACTIVE state.
This functionality is useful for clustered iSCSI targets, where
TPGTs handled on remote cluster nodes should be advertised in
the SendTargets response.
By default, this new attribute retains the default behaviour of
existing code which to ignore portal-groups in !TPG_STATE_ACTIVE
state.
Signed-off-by: David Disseldorp <ddiss@suse.de>
On x86-64, these changes reduce the struct size from 528 bytes to 496
bytes. We save a cacheline and get under 512 bytes for better packing.
Acked-by: Sagi Grimberg <sagig@mellanox.com>
For every command, we set se_ordered_id by doing atomic_inc_return on
dev->dev_ordered_id for the corresponding device. However, the only
places this value gets used are in pr_debug() calls, which doesn't
seem worth an extra atomic op per IO.
The initiatorname field in se_acl_lun is only a copy of the same field
in se_node_acl, so remove it and use the version in se_node_acl where
needed (it's actually only used for pr_debug)
Signed-off-by: Chris Zankel <czankel@purestorage.com>
Signed-off-by: Spencer Baugh <spencer.baugh@purestorage.com>
The lun_flags field is not used, so drop it.
This patch fixes a regression introduced with the following commit
in v4.0-rc1 code, where a iscsit_start_kthreads() failure triggers
a NULL pointer dereference OOPs:
commit 88dcd2dab5c23b1c9cfc396246d8f476c872f0ca
Date: Thu Feb 26 22:19:15 2015 -0800
iscsi-target: Convert iscsi_thread_set usage to kthread.h
To address this bug, move iscsit_start_kthreads() immediately
preceeding the transmit of last login response, before signaling
a successful transition into full-feature-phase within existing
iscsi_target_do_tx_login_io() logic.
This ensures that no target-side resource allocation failures can
occur after the final login response has been successfully sent.
Also, it adds a iscsi_conn->rx_login_comp to allow the RX thread
to sleep to prevent other socket related failures until the final
iscsi_post_login_handler() call is able to complete.
Cc: <stable@vger.kernel.org> # v3.10+
In case a LU spans 64bit sectors, fixed size sense data information
field is only 32 bits which means the sector information will be truncated.
Thus, if the LU spans 64bit sectors, use descriptor format sense data to
correctly report sector information.
Reviewed-by: Hannes Reinecke <hare@suse.de>
Reviewed-by: Martin K. Petersen <martin.petersen@oracle.com>
Signed-off-by: Sagi Grimberg <sagig@mellanox.com>
If the virtual SAS link is set to 'offline' we should be
queueing an I_T_NEXUS_LOSS_OCCURRED UA.
Signed-off-by: Hannes Reinecke <hare@suse.de>
Its not a good idea to keep target specific definition of
the same t10-pi tuple.
(Fix v4.2-rc1 patch fuzz - nab)
"It's been a busy development cycle for target-core in a number of
different areas.
The fabric API usage for se_node_acl allocation is now within
target-core code, dropping the external API callers for all fabric
drivers tree-wide.
There is a new conversion to RCU hlists for se_node_acl and
se_portal_group LUN mappings, that turns fast-past LUN lookup into a
completely lockless code-path. It also removes the original
hard-coded limitation of 256 LUNs per fabric endpoint.
The configfs attributes for backends can now be shared between core
and driver code, allowing existing drivers to use common code while
still allowing flexibility for new backend provided attributes.
The highlights include:
- Merge sbc_verify_dif_* into common code (sagi)
- Remove iscsi-target support for obsolete IFMarker/OFMarker
(Christophe Vu-Brugier)
- Add bidi support in target/user backend (ilias + vangelis + agover)
- Move se_node_acl allocation into target-core code (hch)
- Add crc_t10dif_update common helper (akinobu + mkp)
- Handle target-core odd SGL mapping for data transfer memory
(akinobu)
- Move transport ID handling into target-core (hch)
- Move task tag into struct se_cmd + support 64-bit tags (bart)
- Convert se_node_acl->device_list[] to RCU hlist (nab + hch +
paulmck)
- Convert se_portal_group->tpg_lun_list[] to RCU hlist (nab + hch +
paulmck)
- Simplify target backend driver registration (hch)
- Consolidate + simplify target backend attribute implementations
(hch + nab)
- Subsume se_port + t10_alua_tg_pt_gp_member into se_lun (hch)
- Drop lun_sep_lock for se_lun->lun_se_dev RCU usage (hch + nab)
- Drop unnecessary core_tpg_register TFO parameter (nab)
- Use 64-bit LUNs tree-wide (hannes)
- Drop left-over TARGET_MAX_LUNS_PER_TRANSPORT limit (hannes)"
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: (76 commits)
target: Bump core version to v5.0
target: remove target_core_configfs.h
target: remove unused TARGET_CORE_CONFIG_ROOT define
target: consolidate version defines
target: implement WRITE_SAME with UNMAP bit using ->execute_unmap
target: simplify UNMAP handling
target: replace se_cmd->execute_rw with a protocol_data field
target/user: Fix inconsistent kmap_atomic/kunmap_atomic
target: Send UA when changing LUN inventory
target: Send UA upon LUN RESET tmr completion
target: Send UA on ALUA target port group change
target: Convert se_lun->lun_deve_lock to normal spinlock
target: use 'se_dev_entry' when allocating UAs
target: Remove 'ua_nacl' pointer from se_ua structure
target_core_alua: Correct UA handling when switching states
xen-scsiback: Fix compile warning for 64-bit LUN
target: Remove TARGET_MAX_LUNS_PER_TRANSPORT
target: use 64-bit LUNs
target: Drop duplicate + unused se_dev_check_wce
target: Drop unnecessary core_tpg_register TFO parameter
Pull SCSI updates from James Bottomley:
"This is the usual grab bag of driver updates (lpfc, hpsa,
megaraid_sas, cxgbi, be2iscsi) plus an assortment of minor updates.
There is also one new driver: the Cisco snic. The advansys driver has
been rewritten to get rid of the warning about converting it to the
DMA API, the tape statistics patch got in and finally, there's a
resuffle of SCSI header files to separate more cleanly initiator from
target mode (and better share the common definitions)"
* tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (156 commits)
snic: driver for Cisco SCSI HBA
qla2xxx: Fix indentation
qla2xxx: Comment out unreachable code
fusion: remove dead MTRR code
advansys: fix compilation errors and warnings when CONFIG_PCI is not set
mptsas: fix depth param in scsi_track_queue_full
megaraid: fix irq setup process regression
lpfc: Update version to 10.7.0.0 for upstream patch set.
lpfc: Fix to drop PLOGIs from fabric node till LOGO processing completes
lpfc: Fix scsi task management error message.
lpfc: Fix cq_id masking problem.
lpfc: Fix scsi prep dma buf error.
lpfc: Add support for using block multi-queue
lpfc: Devices are not discovered during takeaway/giveback testing
lpfc: Fix vport deletion failure.
lpfc: Check for active portpeerbeacon.
lpfc: Update driver version for upstream patch set 10.6.0.1.
lpfc: Change buffer pool empty message to miscellaneous category
lpfc: Fix incorrect log message reported for empty FCF record.
lpfc: Fix rport leak.
The remaining defintions are private to the target core and can be merged
into target_core_internal.h.
Reviewed-by: Andy Grover <agrover@redhat.com>
Move a little more processing into the core code, and lift the previous
do_unmap callback into the sbc_ops structure.
Instead of leaking this SBC read/write implementation detail just add an
opaqueue protocol specific pointer to struct se_cmd that we can assign
the sbc_ops vector to.
Unused.
LUN allocation is now fully dynamic, so there is no need to
artificially restrain the number of exported LUNs.
As we're now using a list to hold the LUNs the target core
can now converted to use 64-bit LUNs internally.
This patch drops unnecessary target_core_fabric_ops parameter usage
for core_tpg_register() during fabric driver TFO->fabric_make_tpg()
se_portal_group creation callback execution.
Instead, use the existing se_wwn->wwn_tf->tf_ops pointer to ensure
fabric driver is really using the same TFO provided at module_init
time.
Also go ahead and drop the forward TFO declarations tree-wide, and
handling the special case for iscsi-target discovery TPG.
Only include SCSI initiator header files in target code that needs
these header files, namely the SCSI pass-through code and the tcm_loop
driver. Change SCSI_SENSE_BUFFERSIZE into TRANSPORT_SENSE_BUFFER in
target code because the former is intended for initiator code and the
latter for target code. With this patch the only initiator include
directives in target code that remain are as follows:
$ git grep -nHE 'include .scsi/(scsi.h|scsi_host.h|scsi_device.h|scsi_cmnd.h)' drivers/target drivers/infiniband/ulp/{isert,srpt} drivers/usb/gadget/legacy/tcm_*.[ch] drivers/{vhost,xen} include/{target,trace/events/target.h}
drivers/target/loopback/tcm_loop.c:29:#include <scsi/scsi.h>
drivers/target/loopback/tcm_loop.c:31:#include <scsi/scsi_host.h>
drivers/target/loopback/tcm_loop.c:32:#include <scsi/scsi_device.h>
drivers/target/loopback/tcm_loop.c:33:#include <scsi/scsi_cmnd.h>
drivers/target/target_core_pscsi.c:39:#include <scsi/scsi_device.h>
drivers/target/target_core_pscsi.c:40:#include <scsi/scsi_host.h>
drivers/xen/xen-scsiback.c:52:#include <scsi/scsi_host.h> /* SG_ALL */
Signed-off-by: Bart Van Assche <bart.vanassche@sandisk.com>
Signed-off-by: James Bottomley <JBottomley@Odin.com>
Correct the comment above the definition of TCM_MAX_COMMAND_SIZE.
A quote from Christoph:
There aren't any legacy issues, we just decided to handle >
16 byte CDBs in the slow path.
With se_port_t and t10_alua_tg_pt_gp_member being absored into se_lun,
there is no need for an extra atomic_t based reference count for PR
ALL_TG_PT=1 and ALUA access state transition.
Go ahead and use the existing percpu se_lun->lun_ref instead, and
convert the two special cases to percpu_ref_tryget_live() to avoid
se_lun if transport_clear_lun_ref() has already been invoked to
shutdown the se_lun.
