Add FLUSH/FUA support to blktrace. As FLUSH precedes WRITE and/or
FUA follows WRITE, use the same 'F' flag for both cases and
distinguish them by their (relative) position. The end results
look like (other flags might be shown also):
- WRITE: W
- WRITE_FLUSH: FW
- WRITE_FUA: WF
- WRITE_FLUSH_FUA: FWF
Note that we reuse TC_BARRIER due to lack of bit space of act_mask
so that the older versions of blktrace tools will report flush
requests as barriers from now on.
Signed-off-by: Namhyung Kim <namhyung@gmail.com>
Reviewed-by: Jeff Moyer <jmoyer@redhat.com>
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jeremy/xen
* 'upstream/xen-tracing2' of git://git.kernel.org/pub/scm/linux/kernel/git/jeremy/xen:
xen/tracing: fix compile errors when tracing is disabled.
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6:
jbd: change the field "b_cow_tid" of struct journal_head from type unsigned to tid_t
ext3.txt: update the links in the section "useful links" to the latest ones
ext3: Fix data corruption in inodes with journalled data
ext2: check xattr name_len before acquiring xattr_sem in ext2_xattr_get
ext3: Fix compilation with -DDX_DEBUG
quota: Remove unused declaration
jbd: Use WRITE_SYNC in journal checkpoint.
jbd: Fix oops in journal_remove_journal_head()
ext3: Return -EINVAL when start is beyond the end of fs in ext3_trim_fs()
ext3/ioctl.c: silence sparse warnings about different address spaces
ext3/ext4 Documentation: remove bh/nobh since it has been deprecated
ext3: Improve truncate error handling
ext3: use proper little-endian bitops
ext2: include fs.h into ext2_fs.h
ext3: Fix oops in ext3_try_to_allocate_with_rsv()
jbd: fix a bug of leaking jh->b_jcount
jbd: remove dependency on __GFP_NOFAIL
ext3: Convert ext3 to new truncate calling convention
jbd: Add fixed tracepoints
ext3: Add fixed tracepoints
Resolve conflicts in fs/ext3/fsync.c due to fsync locking push-down and
new fixed tracepoints.
git://git.kernel.org/pub/scm/linux/kernel/git/wfg/writeback
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/wfg/writeback: (27 commits)
mm: properly reflect task dirty limits in dirty_exceeded logic
writeback: don't busy retry writeback on new/freeing inodes
writeback: scale IO chunk size up to half device bandwidth
writeback: trace global_dirty_state
writeback: introduce max-pause and pass-good dirty limits
writeback: introduce smoothed global dirty limit
writeback: consolidate variable names in balance_dirty_pages()
writeback: show bdi write bandwidth in debugfs
writeback: bdi write bandwidth estimation
writeback: account per-bdi accumulated written pages
writeback: make writeback_control.nr_to_write straight
writeback: skip tmpfs early in balance_dirty_pages_ratelimited_nr()
writeback: trace event writeback_queue_io
writeback: trace event writeback_single_inode
writeback: remove .nonblocking and .encountered_congestion
writeback: remove writeback_control.more_io
writeback: skip balance_dirty_pages() for in-memory fs
writeback: add bdi_dirty_limit() kernel-doc
writeback: avoid extra sync work at enqueue time
writeback: elevate queue_io() into wb_writeback()
Fix up trivial conflicts in fs/fs-writeback.c and mm/filemap.c
When CONFIG_FUNCTION_TRACER is disabled, compilation fails as follows:
CC arch/x86/xen/setup.o
In file included from arch/x86/include/asm/xen/hypercall.h:42,
from arch/x86/xen/setup.c:19:
include/trace/events/xen.h:31: warning: 'struct multicall_entry' declared inside parameter list
include/trace/events/xen.h:31: warning: its scope is only this definition or declaration, which is probably not what you want
arch/x86/xen/trace.c:5: error: '__HYPERVISOR_set_trap_table' undeclared here (not in a function)
arch/x86/xen/trace.c:5: error: array index in initializer not of integer type
arch/x86/xen/trace.c:5: error: (near initialization for 'xen_hypercall_names')
arch/x86/xen/trace.c:6: error: '__HYPERVISOR_mmu_update' undeclared here (not in a function)
arch/x86/xen/trace.c:6: error: array index in initializer not of integer type
arch/x86/xen/trace.c:6: error: (near initialization for 'xen_hypercall_names')
Fix this by making sure struct multicall_entry has a declaration in
scope at all times, and don't bother compiling xen/trace.c when tracing
is disabled.
Reported-by: Randy Dunlap <rdunlap@xenotime.net>
Signed-off-by: Jeremy Fitzhardinge <jeremy.fitzhardinge@citrix.com>
xen/trace: use class for multicall trace
xen/trace: convert mmu events to use DECLARE_EVENT_CLASS()/DEFINE_EVENT()
xen/multicall: move *idx fields to start of mc_buffer
xen/multicall: special-case singleton hypercalls
xen/multicalls: add unlikely around slowpath in __xen_mc_entry()
xen/multicalls: disable MC_DEBUG
xen/mmu: tune pgtable alloc/release
xen/mmu: use extend_args for more mmuext updates
xen/trace: add tlb flush tracepoints
xen/trace: add segment desc tracing
xen/trace: add xen_pgd_(un)pin tracepoints
xen/trace: add ptpage alloc/release tracepoints
xen/trace: add mmu tracepoints
xen/trace: add multicall tracing
xen/trace: set up tracepoint skeleton
xen/multicalls: remove debugfs stats
trace/xen: add skeleton for Xen trace events
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (297 commits)
ALSA: asihpi - Replace with snd_ctl_boolean_mono_info()
ALSA: asihpi - HPI version 4.08
ALSA: asihpi - Add volume mute controls
ALSA: asihpi - Control name updates
ALSA: asihpi - Use size_t for sizeof result
ALSA: asihpi - Explicitly include mutex.h
ALSA: asihpi - Add new node and message defines
ALSA: asihpi - Make local function static
ALSA: asihpi - Fix minor typos and spelling
ALSA: asihpi - Remove unused structures, macros and functions
ALSA: asihpi - Remove spurious adapter index check
ALSA: asihpi - Revise snd_pcm_debug_name, get rid of DEBUG_NAME macro
ALSA: asihpi - DSP code loader API now independent of OS
ALSA: asihpi - Remove controlex structs and associated special data transfer code
ALSA: asihpi - Increase request and response buffer sizes
ALSA: asihpi - Give more meaningful name to hpi request message type
ALSA: usb-audio - Add quirk for Roland / BOSS BR-800
ALSA: hda - Remove a superfluous argument of via_auto_init_output()
ALSA: hda - Fix indep-HP path (de-)activation for VT1708* codecs
ALSA: hda - Add documentation for codec-specific mixer controls
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (107 commits)
vfs: use ERR_CAST for err-ptr tossing in lookup_instantiate_filp
isofs: Remove global fs lock
jffs2: fix IN_DELETE_SELF on overwriting rename() killing a directory
fix IN_DELETE_SELF on overwriting rename() on ramfs et.al.
mm/truncate.c: fix build for CONFIG_BLOCK not enabled
fs:update the NOTE of the file_operations structure
Remove dead code in dget_parent()
AFS: Fix silly characters in a comment
switch d_add_ci() to d_splice_alias() in "found negative" case as well
simplify gfs2_lookup()
jfs_lookup(): don't bother with . or ..
get rid of useless dget_parent() in btrfs rename() and link()
get rid of useless dget_parent() in fs/btrfs/ioctl.c
fs: push i_mutex and filemap_write_and_wait down into ->fsync() handlers
drivers: fix up various ->llseek() implementations
fs: handle SEEK_HOLE/SEEK_DATA properly in all fs's that define their own llseek
Ext4: handle SEEK_HOLE/SEEK_DATA generically
Btrfs: implement our own ->llseek
fs: add SEEK_HOLE and SEEK_DATA flags
reiserfs: make reiserfs default to barrier=flush
Fix up trivial conflicts in fs/xfs/linux-2.6/xfs_super.c due to the new
shrinker callout for the inode cache, that clashed with the xfs code to
start the periodic workers later.
It is impossible to understand what the shrinkers are actually doing
without instrumenting the code, so add a some tracepoints to allow
insight to be gained.
Signed-off-by: Dave Chinner <dchinner@redhat.com>
Add trace event balance_dirty_state for showing the global dirty page
counts and thresholds at each global_dirty_limits() invocation. This
will cover the callers throttle_vm_writeout(), over_bground_thresh()
and each balance_dirty_pages() loop.
Signed-off-by: Wu Fengguang <fengguang.wu@intel.com>
Pass struct wb_writeback_work all the way down to writeback_sb_inodes(),
and initialize the struct writeback_control there.
struct writeback_control is basically designed to control writeback of a
single file, but we keep abuse it for writing multiple files in
writeback_sb_inodes() and its callers.
It immediately clean things up, e.g. suddenly wbc.nr_to_write vs
work->nr_pages starts to make sense, and instead of saving and restoring
pages_skipped in writeback_sb_inodes it can always start with a clean
zero value.
It also makes a neat IO pattern change: large dirty files are now
written in the full 4MB writeback chunk size, rather than whatever
remained quota in wbc->nr_to_write.
Acked-by: Jan Kara <jack@suse.cz>
Proposed-by: Christoph Hellwig <hch@infradead.org>
Trace platform IO just like CODEC IO.
Signed-off-by: Liam Girdwood <lrg@ti.com>
This commit adds fixed tracepoint for jbd. It has been based on fixed
tracepoints for jbd2, however there are missing those for collecting
statistics, since I think that it will require more intrusive patch so I
should have its own commit, if someone decide that it is needed. Also
there are new tracepoints in __journal_drop_transaction() and
journal_update_superblock().
The list of jbd tracepoints:
jbd_checkpoint
jbd_start_commit
jbd_commit_locking
jbd_commit_flushing
jbd_commit_logging
jbd_drop_transaction
jbd_end_commit
jbd_do_submit_data
jbd_cleanup_journal_tail
jbd_update_superblock_end
Signed-off-by: Lukas Czerner <lczerner@redhat.com>
Cc: Jan Kara <jack@suse.cz>
This commit adds fixed tracepoints to the ext3 code. It is based on ext4
tracepoints, however due to the differences of both file systems, there
are some tracepoints missing (those for delaloc and for multi-block
allocator) and there are some ext3 specific as well (for reservation
windows).
Here is a list:
ext3_free_inode
ext3_request_inode
ext3_allocate_inode
ext3_evict_inode
ext3_drop_inode
ext3_mark_inode_dirty
ext3_write_begin
ext3_ordered_write_end
ext3_writeback_write_end
ext3_journalled_write_end
ext3_ordered_writepage
ext3_writeback_writepage
ext3_journalled_writepage
ext3_readpage
ext3_releasepage
ext3_invalidatepage
ext3_discard_blocks
ext3_request_blocks
ext3_allocate_blocks
ext3_free_blocks
ext3_sync_file_enter
ext3_sync_file_exit
ext3_sync_fs
ext3_rsv_window_add
ext3_discard_reservation
ext3_alloc_new_reservation
ext3_reserved
ext3_forget
ext3_read_block_bitmap
ext3_direct_IO_enter
ext3_direct_IO_exit
ext3_unlink_enter
ext3_unlink_exit
ext3_truncate_enter
ext3_truncate_exit
ext3_get_blocks_enter
ext3_get_blocks_exit
ext3_load_inode
This patch adds 2 tracepoints to get a status of a socket receive queue
and related parameter.
One tracepoint is added to sock_queue_rcv_skb. It records rcvbuf size
and its usage. The other tracepoint is added to __sk_mem_schedule and
it records limitations of memory for sockets and current usage.
By using these tracepoints we're able to know detailed reason why kernel
drop the packet.
Signed-off-by: Satoru Moriya <satoru.moriya@hds.com>
This patch adds a tracepoint to __udp_queue_rcv_skb to get the
return value of ip_queue_rcv_skb. It indicates why kernel drops
a packet at this point.
ip_queue_rcv_skb returns following values in the packet drop case:
rcvbuf is full : -ENOMEM
sk_filter returns error : -EINVAL, -EACCESS, -ENOMEM, etc.
__sk_mem_schedule returns error: -ENOBUF
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4:
jbd2: Fix oops in jbd2_journal_remove_journal_head()
jbd2: Remove obsolete parameters in the comments for some jbd2 functions
ext4: fixed tracepoints cleanup
ext4: use FIEMAP_EXTENT_LAST flag for last extent in fiemap
ext4: Fix max file size and logical block counting of extent format file
ext4: correct comments for ext4_free_blocks()
* 'core-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip:
rcu: Move RCU_BOOST #ifdefs to header file
rcu: use softirq instead of kthreads except when RCU_BOOST=y
rcu: Use softirq to address performance regression
rcu: Simplify curing of load woes
While testing for memcg aware swap token, I observed a swap token was
often grabbed an intermittent running process (eg init, auditd) and they
never release a token.
Why?
Some processes (eg init, auditd, audispd) wake up when a process exiting.
And swap token can be get first page-in process when a process exiting
makes no swap token owner. Thus such above intermittent running process
often get a token.
And currently, swap token priority is only decreased at page fault path.
Then, if the process sleep immediately after to grab swap token, the swap
token priority never be decreased. That's obviously undesirable.
This patch implement very poor (and lightweight) priority aging. It only
be affect to the above corner case and doesn't change swap tendency
workload performance (eg multi process qsbench load)
Reviewed-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
This is useful for observing swap token activity.
example output:
zsh-1845 [000] 598.962716: update_swap_token_priority:
mm=ffff88015eaf7700 old_prio=1 new_prio=0
memtoy-1830 [001] 602.033900: update_swap_token_priority:
mm=ffff880037a45880 old_prio=947 new_prio=949
memtoy-1830 [000] 602.041509: update_swap_token_priority:
mm=ffff880037a45880 old_prio=949 new_prio=951
memtoy-1830 [000] 602.051959: update_swap_token_priority:
mm=ffff880037a45880 old_prio=951 new_prio=953
memtoy-1830 [000] 602.052188: update_swap_token_priority:
mm=ffff880037a45880 old_prio=953 new_prio=955
memtoy-1830 [001] 602.427184: put_swap_token:
token_mm=ffff880037a45880
zsh-1789 [000] 602.427281: replace_swap_token:
old_token_mm= (null) old_prio=0 new_token_mm=ffff88015eaf7018
new_prio=2
zsh-1789 [001] 602.433456: update_swap_token_priority:
mm=ffff88015eaf7018 old_prio=2 new_prio=4
zsh-1789 [000] 602.437613: update_swap_token_priority:
mm=ffff88015eaf7018 old_prio=4 new_prio=6
zsh-1789 [000] 602.443924: update_swap_token_priority:
mm=ffff88015eaf7018 old_prio=6 new_prio=8
zsh-1789 [000] 602.451873: update_swap_token_priority:
mm=ffff88015eaf7018 old_prio=8 new_prio=10
zsh-1789 [001] 602.462639: update_swap_token_priority:
mm=ffff88015eaf7018 old_prio=10 new_prio=12
Acked-by: Rik van Riel<riel@redhat.com>
Commit a26ac2455ffcf3(rcu: move TREE_RCU from softirq to kthread)
introduced performance regression. In an AIM7 test, this commit degraded
performance by about 40%.
The commit runs rcu callbacks in a kthread instead of softirq. We observed
high rate of context switch which is caused by this. Out test system has
64 CPUs and HZ is 1000, so we saw more than 64k context switch per second
which is caused by RCU's per-CPU kthread. A trace showed that most of
the time the RCU per-CPU kthread doesn't actually handle any callbacks,
but instead just does a very small amount of work handling grace periods.
This means that RCU's per-CPU kthreads are making the scheduler do quite
a bit of work in order to allow a very small amount of RCU-related
processing to be done.
Alex Shi's analysis determined that this slowdown is due to lock
contention within the scheduler. Unfortunately, as Peter Zijlstra points
out, the scheduler's real-time semantics require global action, which
means that this contention is inherent in real-time scheduling. (Yes,
perhaps someone will come up with a workaround -- otherwise, -rt is not
going to do well on large SMP systems -- but this patch will work around
this issue in the meantime. And "the meantime" might well be forever.)
This patch therefore re-introduces softirq processing to RCU, but only
for core RCU work. RCU callbacks are still executed in kthread context,
so that only a small amount of RCU work runs in softirq context in the
common case. This should minimize ksoftirqd execution, allowing us to
skip boosting of ksoftirqd for CONFIG_RCU_BOOST=y kernels.
Signed-off-by: Shaohua Li <shaohua.li@intel.com>
Tested-by: "Alex,Shi" <alex.shi@intel.com>
Note that it adds a little overheads to account the moved/enqueued
inodes from b_dirty to b_io. The "moved" accounting may be later used to
limit the number of inodes that can be moved in one shot, in order to
keep spinlock hold time under control.
It is valuable to know how the dirty inodes are iterated and their IO size.
"writeback_single_inode: bdi 8:0: ino=134246746 state=I_DIRTY_SYNC|I_SYNC age=414 index=0 to_write=1024 wrote=0"
- "state" reflects inode->i_state at the end of writeback_single_inode()
- "index" reflects mapping->writeback_index after the ->writepages() call
- "to_write" is the wbc->nr_to_write at entrance of writeback_single_inode()
- "wrote" is the number of pages actually written
v2: add trace event writeback_single_inode_requeue as proposed by Dave.
CC: Dave Chinner <david@fromorbit.com>
Remove two unused struct writeback_control fields:
.encountered_congestion (completely unused)
.nonblocking (never set, checked/showed in XFS,NFS/btrfs)
The .for_background check in nfs_write_inode() is also removed btw,
as .for_background implies WB_SYNC_NONE.
When wbc.more_io was first introduced, it indicates whether there are
at least one superblock whose s_more_io contains more IO work. Now with
the per-bdi writeback, it can be replaced with a simple b_more_io test.
Acked-by: Mel Gorman <mel@csn.ul.ie>
Reviewed-by: Minchan Kim <minchan.kim@gmail.com>
While creating fixed tracepoints for ext3, basically by porting them
from ext4, I found a lot of useless retyping, wrong type usage, useless
variable passing and other inconsistencies in the ext4 fixed tracepoint
code.
This patch cleans the fixed tracepoint code for ext4 and also simplify
some of them.
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (40 commits)
tg3: Fix tg3_skb_error_unmap()
net: tracepoint of net_dev_xmit sees freed skb and causes panic
drivers/net/can/flexcan.c: add missing clk_put
net: dm9000: Get the chip in a known good state before enabling interrupts
drivers/net/davinci_emac.c: add missing clk_put
af-packet: Add flag to distinguish VID 0 from no-vlan.
caif: Fix race when conditionally taking rtnl lock
usbnet/cdc_ncm: add missing .reset_resume hook
vlan: fix typo in vlan_dev_hard_start_xmit()
net/ipv4: Check for mistakenly passed in non-IPv4 address
iwl4965: correctly validate temperature value
bluetooth l2cap: fix locking in l2cap_global_chan_by_psm
ath9k: fix two more bugs in tx power
cfg80211: don't drop p2p probe responses
Revert "net: fix section mismatches"
drivers/net/usb/catc.c: Fix potential deadlock in catc_ctrl_run()
sctp: stop pending timers and purge queues when peer restart asoc
drivers/net: ks8842 Fix crash on received packet when in PIO mode.
ip_options_compile: properly handle unaligned pointer
iwlagn: fix incorrect PCI subsystem id for 6150 devices
Because there is a possibility that skb is kfree_skb()ed and zero cleared
after ndo_start_xmit, we should not see the contents of skb like skb->len and
skb->dev->name after ndo_start_xmit. But trace_net_dev_xmit does that
and causes panic by NULL pointer dereference.
This patch fixes trace_net_dev_xmit not to see the contents of skb directly.
If you want to reproduce this panic,
1. Get tracepoint of net_dev_xmit on
2. Create 2 guests on KVM
2. Make 2 guests use virtio_net
4. Execute netperf from one to another for a long time as a network burden
5. host will panic(It takes about 30 minutes)
Signed-off-by: Koki Sanagi <sanagi.koki@jp.fujitsu.com>
* 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (25 commits)
perf: Fix SIGIO handling
perf top: Don't stop if no kernel symtab is found
perf top: Handle kptr_restrict
perf top: Remove unused macro
perf events: initialize fd array to -1 instead of 0
perf tools: Make sure kptr_restrict warnings fit 80 col terms
perf tools: Fix build on older systems
perf symbols: Handle /proc/sys/kernel/kptr_restrict
perf: Remove duplicate headers
ftrace: Add internal recursive checks
tracing: Update btrfs's tracepoints to use u64 interface
tracing: Add __print_symbolic_u64 to avoid warnings on 32bit machine
ftrace: Set ops->flag to enabled even on static function tracing
tracing: Have event with function tracer check error return
ftrace: Have ftrace_startup() return failure code
jump_label: Check entries limit in __jump_label_update
ftrace/recordmcount: Avoid STT_FUNC symbols as base on ARM
scripts/tags.sh: Add magic for trace-events for etags too
scripts/tags.sh: Fix ctags for DEFINE_EVENT()
x86/ftrace: Fix compiler warning in ftrace.c
* 'gpio/next' of git://git.secretlab.ca/git/linux-2.6:
gpio/via: rename VIA local config struct
basic_mmio_gpio: split into a gpio library and platform device
gpio: remove some legacy comments in build files
gpio: add trace events for setting direction and value
gpio/pca953x: Use handle_simple_irq instead of handle_edge_irq
gpiolib: export gpiochip_find
gpio: remove redundant Kconfig depends on GPIOLIB
basic_mmio_gpio: convert to non-__raw* accessors
basic_mmio_gpio: support direction registers
basic_mmio_gpio: support different input/output registers
basic_mmio_gpio: detect output method at probe time
basic_mmio_gpio: request register regions
basic_mmio_gpio: allow overriding number of gpio
basic_mmio_gpio: convert to platform_{get,set}_drvdata()
basic_mmio_gpio: remove runtime width/endianness evaluation
To avoid 64->32 truncating WARNING, update btrfs's tracepoints.
Signed-off-by: Liu Bo <liubo2009@cn.fujitsu.com>
Link: http://lkml.kernel.org/r/4DACE6E3.8080200@cn.fujitsu.com
This patch allows to trace gpio operations using ftrace
* 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (78 commits)
Revert "rcu: Decrease memory-barrier usage based on semi-formal proof"
net,rcu: convert call_rcu(prl_entry_destroy_rcu) to kfree
batman,rcu: convert call_rcu(softif_neigh_free_rcu) to kfree_rcu
batman,rcu: convert call_rcu(neigh_node_free_rcu) to kfree()
batman,rcu: convert call_rcu(gw_node_free_rcu) to kfree_rcu
net,rcu: convert call_rcu(kfree_tid_tx) to kfree_rcu()
net,rcu: convert call_rcu(xt_osf_finger_free_rcu) to kfree_rcu()
net/mac80211,rcu: convert call_rcu(work_free_rcu) to kfree_rcu()
net,rcu: convert call_rcu(wq_free_rcu) to kfree_rcu()
net,rcu: convert call_rcu(phonet_device_rcu_free) to kfree_rcu()
perf,rcu: convert call_rcu(swevent_hlist_release_rcu) to kfree_rcu()
perf,rcu: convert call_rcu(free_ctx) to kfree_rcu()
net,rcu: convert call_rcu(__nf_ct_ext_free_rcu) to kfree_rcu()
net,rcu: convert call_rcu(net_generic_release) to kfree_rcu()
net,rcu: convert call_rcu(netlbl_unlhsh_free_addr6) to kfree_rcu()
net,rcu: convert call_rcu(netlbl_unlhsh_free_addr4) to kfree_rcu()
security,rcu: convert call_rcu(sel_netif_free) to kfree_rcu()
net,rcu: convert call_rcu(xps_dev_maps_release) to kfree_rcu()
net,rcu: convert call_rcu(xps_map_release) to kfree_rcu()
net,rcu: convert call_rcu(rps_map_release) to kfree_rcu()
include/linux/gfp.h and include/trace/events/gfpflags.h are out of sync.
When tracing is enabled, certain flags are not recognised and the text
output is less useful as a result. Add the missing flags.
If RCU priority boosting is to be meaningful, callback invocation must
be boosted in addition to preempted RCU readers. Otherwise, in presence
of CPU real-time threads, the grace period ends, but the callbacks don't
get invoked. If the callbacks don't get invoked, the associated memory
doesn't get freed, so the system is still subject to OOM.
But it is not reasonable to priority-boost RCU_SOFTIRQ, so this commit
moves the callback invocations to a kthread, which can be boosted easily.
Also add comments and properly synchronized all accesses to
rcu_cpu_kthread_task, as suggested by Lai Jiangshan.
Signed-off-by: Paul E. McKenney <paul.mckenney@linaro.org>
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
It's a pretty close match to what we had before - the timer triggering
would mean that nobody unplugged the plug in due time, in the new
scheme this matches very closely what the schedule() unplug now is.
It's essentially the difference between an explicit unplug (IO unplug)
or an implicit unplug (timer unplug, we scheduled with pending IO
queued).
It was removed with the on-stack plugging, readd it and track the
depth of requests added when flushing the plug.
We no longer have an unplug timer running, so no point in keeping
the trace point.
git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable
* 'for-linus-unmerged' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable: (45 commits)
Btrfs: fix __btrfs_map_block on 32 bit machines
btrfs: fix possible deadlock by clearing __GFP_FS flag
btrfs: check link counter overflow in link(2)
btrfs: don't mess with i_nlink of unlocked inode in rename()
Btrfs: check return value of btrfs_alloc_path()
Btrfs: fix OOPS of empty filesystem after balance
Btrfs: fix memory leak of empty filesystem after balance
Btrfs: fix return value of setflags ioctl
Btrfs: fix uncheck memory allocations
btrfs: make inode ref log recovery faster
Btrfs: add btrfs_trim_fs() to handle FITRIM
Btrfs: adjust btrfs_discard_extent() return errors and trimmed bytes
Btrfs: make btrfs_map_block() return entire free extent for each device of RAID0/1/10/DUP
Btrfs: make update_reserved_bytes() public
btrfs: return EXDEV when linking from different subvolumes
Btrfs: Per file/directory controls for COW and compression
Btrfs: add datacow flag in inode flag
btrfs: use GFP_NOFS instead of GFP_KERNEL
Btrfs: check return value of read_tree_block()
btrfs: properly access unaligned checksum buffer
Fix up trivial conflicts in fs/btrfs/volumes.c due to plug removal in
the block layer.
