This is the 4.14.164 stable release
arch/arm/Kconfig.debug
arch/arm/boot/dts/imx7s.dtsi
arch/arm/mach-imx/cpuidle-imx6q.c
arch/arm/mach-imx/cpuidle-imx6sx.c
arch/arm64/kernel/cpu_errata.c
arch/arm64/kvm/hyp/tlb.c
drivers/crypto/caam/caamalg.c
drivers/crypto/mxs-dcp.c
drivers/dma/imx-sdma.c
drivers/gpio/gpio-vf610.c
drivers/gpu/drm/bridge/adv7511/adv7511_drv.c
drivers/input/keyboard/imx_keypad.c
drivers/input/keyboard/snvs_pwrkey.c
drivers/mmc/core/block.c
drivers/mmc/core/queue.h
drivers/mmc/host/sdhci-esdhc-imx.c
drivers/net/can/flexcan.c
drivers/net/can/rx-offload.c
drivers/net/ethernet/freescale/fec_main.c
drivers/net/wireless/ath/ath10k/pci.c
drivers/net/wireless/broadcom/brcm80211/brcmfmac/cfg80211.c
drivers/pci/dwc/pci-imx6.c
drivers/spi/spi-fsl-lpspi.c
drivers/usb/dwc3/gadget.c
include/net/tcp.h
sound/soc/fsl/Kconfig
sound/soc/fsl/fsl_esai.c
[ Upstream commit 1d200e9d6f635ae894993a7d0f1b9e0b6e522e3b ]
Fix the following compiler warnings:
In file included from ./include/linux/bitmap.h:9,
from ./include/linux/cpumask.h:12,
from ./arch/x86/include/asm/cpumask.h:5,
from ./arch/x86/include/asm/msr.h:11,
from ./arch/x86/include/asm/processor.h:21,
from ./arch/x86/include/asm/cpufeature.h:5,
from ./arch/x86/include/asm/thread_info.h:53,
from ./include/linux/thread_info.h:38,
from ./arch/x86/include/asm/preempt.h:7,
from ./include/linux/preempt.h:78,
from ./include/linux/spinlock.h:51,
from ./include/linux/mmzone.h:8,
from ./include/linux/gfp.h:6,
from ./include/linux/mm.h:10,
from ./include/linux/bvec.h:13,
from ./include/linux/blk_types.h:10,
from block/blk-wbt.c:23:
In function 'strncpy',
inlined from 'perf_trace_wbt_stat' at ./include/trace/events/wbt.h:15:1:
./include/linux/string.h:260:9: warning: '__builtin_strncpy' specified bound 32 equals destination size [-Wstringop-truncation]
return __builtin_strncpy(p, q, size);
inlined from 'perf_trace_wbt_lat' at ./include/trace/events/wbt.h:58:1:
inlined from 'perf_trace_wbt_step' at ./include/trace/events/wbt.h:87:1:
inlined from 'perf_trace_wbt_timer' at ./include/trace/events/wbt.h:126:1:
inlined from 'trace_event_raw_event_wbt_stat' at ./include/trace/events/wbt.h:15:1:
inlined from 'trace_event_raw_event_wbt_lat' at ./include/trace/events/wbt.h:58:1:
inlined from 'trace_event_raw_event_wbt_timer' at ./include/trace/events/wbt.h:126:1:
inlined from 'trace_event_raw_event_wbt_step' at ./include/trace/events/wbt.h:87:1:
Cc: Ming Lei <ming.lei@redhat.com>
Cc: Hannes Reinecke <hare@suse.com>
Cc: Johannes Thumshirn <jthumshirn@suse.de>
Fixes: e34cbd307477 ("blk-wbt: add general throttling mechanism"; v4.10).
Signed-off-by: Bart Van Assche <bvanassche@acm.org>
[ Upstream commit ff28915fd31ccafc0d38e6f84b66df280ed9e86a ]
include/trace/events/sched.h includes <linux/sched.h> (via
<linux/sched/numa_balancing.h>) and so knows about the TASK_* constants
used to interpret .prev_state. So instead of duplicating the magic
numbers make use of the defined macros to ease understanding the
mapping from state bits to letters which isn't completely intuitive for
an outsider.
Cc: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Cc: kernel@pengutronix.de
Link: http://lkml.kernel.org/r/20180905093636.24068-1-u.kleine-koenig@pengutronix.de
commit 3054426dc68e5d63aa6a6e9b91ac4ec78e3f3805 upstream.
commit 3f5fe9fef5b2 ("sched/debug: Fix task state recording/printout")
tried to fix the problem introduced by a previous commit efb40f588b43
("sched/tracing: Fix trace_sched_switch task-state printing"). However
the prev_state output in sched_switch is still broken.
task_state_index() uses fls() which considers the LSB as 1. Left
shifting 1 by this value gives an incorrect mapping to the task state.
Fix this by decrementing the value returned by __get_task_state()
before shifting.
Link: http://lkml.kernel.org/r/1540882473-1103-1-git-send-email-pkondeti@codeaurora.org
Cc: stable@vger.kernel.org
Fixes: 3f5fe9fef5b2 ("sched/debug: Fix task state recording/printout")
Signed-off-by: Pavankumar Kondeti <pkondeti@codeaurora.org>
Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
Signed-off-by: Sudip Mukherjee <sudipm.mukherjee@gmail.com>
Interactive governor has lived in Android sources for a very long time
and this commit is based on the code present in following branch:
https://android.googlesource.com/kernel/common android-4.4
The Interactive governor is designed for latency-sensitive workloads,
such as interactive user interfaces like the mobile phones and tablets.
The interactive governor aims to be significantly more responsive to
ramp CPU quickly up when CPU-intensive activity begins.
Existing governors sample CPU load at a particular rate, typically every
X ms and then update the frequency from a work-handler. This can lead
to under-powering UI threads for the period of time during which the
user begins interacting with a previously-idle system until the next
sample period happens.
The 'interactive' governor uses a different approach.
A real-time thread is used for scaling up, giving the remaining tasks
the CPU performance benefit, unlike existing governors which are more
likely to schedule ramp-up work to occur after your performance starved
tasks have completed.
The Android version of interactive governor also checks whether to scale
the CPU frequency up soon after coming out of idle. When the CPU comes
out of idle, the governor check if the CPU sampling is overdue or not.
If yes, it immediately starts the sampling. Otherwise, the utilization
hooks from the scheduler handle the sampling later. If the CPU is very
busy from exiting idle to when the evaluation happens, then it assumes
that the CPU is under-powered and ramps it to MAX speed.
If the CPU was not sufficiently busy to immediately ramp to MAX speed,
then the governor evaluates the CPU load since the last speed
adjustment, choosing the highest value between that longer-term load or
the short-term load since idle exit to determine the CPU speed to ramp
to.
Idle notifiers will be be handled later and are not included for now.
The core of this code is written and maintained (in Android
repositories) by Mike Chan and Todd Poyner over a long period of time.
Vireshk has made changes to to the governor to align it with the current
practices followed with mainline governors, like using utilization hooks
from the scheduler and handling kobject (for governor's sysfs directory)
in a race free manner. And of course this included general cleanup of
the governor as well.
Signed-off-by: Mike Chan <mike@android.com>
Signed-off-by: Todd Poynor <toddpoynor@google.com>
Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org>
commit fde872682e175743e0c3ef939c89e3c6008a1529 upstream.
Some time back, nfsd switched from calling vfs_fsync() to using a new
commit_metadata() hook in export_operations(). If the file system did
not provide a commit_metadata() hook, it fell back to using
sync_inode_metadata(). Unfortunately doesn't work on all file
systems. In particular, it doesn't work on ext4 due to how the inode
gets journalled --- the VFS writeback code will not always call
ext4_write_inode().
So we need to provide our own ext4_nfs_commit_metdata() method which
calls ext4_write_inode() directly.
Google-Bug-Id: 121195940
Signed-off-by: Theodore Ts'o <tytso@mit.edu>
Cc: stable@kernel.org
commit 3f5fe9fef5b2da06b6319fab8123056da5217c3f upstream.
The recent conversion of the task state recording to use task_state_index()
broke the sched_switch tracepoint task state output.
task_state_index() returns surprisingly an index (0-7) which is then
printed with __print_flags() applying bitmasks. Not really working and
resulting in weird states like 'prev_state=t' instead of 'prev_state=I'.
Use TASK_REPORT_MAX instead of TASK_STATE_MAX to report preemption. Build a
bitmask from the return value of task_state_index() and store it in
entry->prev_state, which makes __print_flags() work as expected.
Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com>
Fixes: efb40f588b43 ("sched/tracing: Fix trace_sched_switch task-state printing")
Link: http://lkml.kernel.org/r/alpine.DEB.2.20.1711221304180.1751@nanos
commit 4ff648decf4712d39f184fc2df3163f43975575a upstream.
Since the following commit:
b91473ff6e97 ("sched,tracing: Update trace_sched_pi_setprio()")
the sched_pi_setprio trace point shows the "newprio" during a deboost:
|futex sched_pi_setprio: comm=futex_requeue_p pid"34 oldprio newprio=3D98
|futex sched_switch: prev_comm=futex_requeue_p prev_pid"34 prev_prio=120
This patch open codes __rt_effective_prio() in the tracepoint as the
'newprio' to get the old behaviour back / the correct priority:
|futex sched_pi_setprio: comm=futex_requeue_p pid"20 oldprio newprio=3D120
|futex sched_switch: prev_comm=futex_requeue_p prev_pid"20 prev_prio=120
Peter suggested to open code the new priority so people using tracehook
could get the deadline data out.
Reported-by: Mansky Christian <man@keba.com>
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Fixes: b91473ff6e97 ("sched,tracing: Update trace_sched_pi_setprio()")
Link: http://lkml.kernel.org/r/20180524132647.gg6ziuogczdmjjzu@linutronix.de
trace_xen_mmu_flush_tlb{_all}
commit 45dd9b0666a162f8e4be76096716670cf1741f0e upstream.
Doing an audit of trace events, I discovered two trace events in the xen
subsystem that use a hack to create zero data size trace events. This is not
what trace events are for. Trace events add memory footprint overhead, and
if all you need to do is see if a function is hit or not, simply make that
function noinline and use function tracer filtering.
Worse yet, the hack used was:
__array(char, x, 0)
Which creates a static string of zero in length. There's assumptions about
such constructs in ftrace that this is a dynamic string that is nul
terminated. This is not the case with these tracepoints and can cause
problems in various parts of ftrace.
Nuke the trace events!
Link: http://lkml.kernel.org/r/20180509144605.5a220327@gandalf.local.home
Fixes: 95a7d76897c1e ("xen/mmu: Use Xen specific TLB flush instead of the generic one.")
Reviewed-by: Juergen Gross <jgross@suse.com>
account
[ Upstream commit 91633eed73a3ac37aaece5c8c1f93a18bae616a9 ]
So far only CLOCK_MONOTONIC and CLOCK_REALTIME were taken into account as
well as HRTIMER_MODE_ABS/REL in the hrtimer_init tracepoint. The query for
detecting the ABS or REL timer modes is not valid anymore, it got broken
by the introduction of HRTIMER_MODE_PINNED.
HRTIMER_MODE_PINNED is not evaluated in the hrtimer_init() call, but for the
sake of completeness print all given modes.
Signed-off-by: Anna-Maria Gleixner <anna-maria@linutronix.de>
Cc: John Stultz <john.stultz@linaro.org>
Cc: keescook@chromium.org
Link: http://lkml.kernel.org/r/20171221104205.7269-9-anna-maria@linutronix.de
commit c658dc58c7eaa8569ceb0edd1ddbdfda84fe8aa5 upstream.
Swap the positions of blk_addr and blksz in the tracepoint print arguments
so that they match the print format.
Signed-off-by: Adrian Hunter <adrian.hunter@intel.com>
Fixes: d2f82254e4e8 ("mmc: core: Add members to mmc_request and mmc_data for CQE's")
Cc: <stable@vger.kernel.org> # 4.14+
Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
[ Upstream commit 975b820b6836b6b6c42fb84cd2e772e2b41bca67 ]
In some cases the clock parent would be set NULL when doing re-parent,
it will cause a NULL pointer accessing if clk_set trace event is
enabled.
This patch sets the parent as "none" if the input parameter is NULL.
Fixes: dfc202ead312 (clk: Add tracepoints for hardware operations)
Signed-off-by: Cai Li <cai.li@spreadtrum.com>
Signed-off-by: Chunyan Zhang <chunyan.zhang@spreadtrum.com>
Signed-off-by: Stephen Boyd <sboyd@codeaurora.org>
[ Upstream commit 23721a755f98ac846897a013c92cccb281c1bcc8 ]
We meet this compile warning, which caused by missing bpf.h in xdp.h.
In file included from ./include/trace/events/xdp.h:10:0,
from ./include/linux/bpf_trace.h:6,
from drivers/net/ethernet/intel/i40e/i40e_txrx.c:29:
./include/trace/events/xdp.h:93:17: warning: ‘struct bpf_map’ declared inside parameter list will not be visible outside of this definition or declaration
const struct bpf_map *map, u32 map_index),
./include/linux/tracepoint.h:187:34: note: in definition of macro ‘__DECLARE_TRACE’
static inline void trace_##name(proto) \
./include/linux/tracepoint.h:352:24: note: in expansion of macro ‘PARAMS’
__DECLARE_TRACE(name, PARAMS(proto), PARAMS(args), \
./include/linux/tracepoint.h:477:2: note: in expansion of macro ‘DECLARE_TRACE’
DECLARE_TRACE(name, PARAMS(proto), PARAMS(args))
./include/linux/tracepoint.h:477:22: note: in expansion of macro ‘PARAMS’
./include/trace/events/xdp.h:89:1: note: in expansion of macro ‘DEFINE_EVENT’
DEFINE_EVENT(xdp_redirect_template, xdp_redirect,
./include/trace/events/xdp.h:90:2: note: in expansion of macro ‘TP_PROTO’
TP_PROTO(const struct net_device *dev,
./include/linux/tracepoint.h:203:38: note: in definition of macro ‘__DECLARE_TRACE’
register_trace_##name(void (*probe)(data_proto), void *data) \
./include/linux/tracepoint.h:354:4: note: in expansion of macro ‘PARAMS’
PARAMS(void *__data, proto), \
Reported-by: Huang Daode <huangdaode@hisilicon.com>
Cc: Hanjun Guo <guohanjun@huawei.com>
Fixes: 8d3b778ff544 ("xdp: tracepoint xdp_redirect also need a map argument")
Signed-off-by: Xie XiuQi <xiexiuqi@huawei.com>
Acked-by: Jesper Dangaard Brouer <brouer@redhat.com>
Acked-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
__flush_tlb_one_[user|kernel]()
commit 1299ef1d8870d2d9f09a5aadf2f8b2c887c2d033 upstream.
flush_tlb_single() and flush_tlb_one() sound almost identical, but
they really mean "flush one user translation" and "flush one kernel
translation". Rename them to flush_tlb_one_user() and
flush_tlb_one_kernel() to make the semantics more obvious.
[ I was looking at some PTI-related code, and the flush-one-address code
is unnecessarily hard to understand because the names of the helpers are
uninformative. This came up during PTI review, but no one got around to
doing it. ]
Signed-off-by: Andy Lutomirski <luto@kernel.org>
Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org>
Cc: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Cc: Brian Gerst <brgerst@gmail.com>
Cc: Eduardo Valentin <eduval@amazon.com>
Cc: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: Juergen Gross <jgross@suse.com>
Cc: Kees Cook <keescook@google.com>
Cc: Linux-MM <linux-mm@kvack.org>
Link: http://lkml.kernel.org/r/3303b02e3c3d049dc5235d5651e0ae6d29a34354.1517414378.git.luto@kernel.org
commit d8be75663cec0069b85f80191abd2682ce4a512f upstream.
Now that kmemcheck is gone, we don't need the NOTRACK flags.
Link: http://lkml.kernel.org/r/20171007030159.22241-5-alexander.levin@verizon.com
Cc: Alexander Potapenko <glider@google.com>
Cc: Eric W. Biederman <ebiederm@xmission.com>
Cc: Michal Hocko <mhocko@kernel.org>
Cc: Pekka Enberg <penberg@kernel.org>
Cc: Tim Hansen <devtimhansen@gmail.com>
Cc: Vegard Nossum <vegardno@ifi.uio.no>
[ Upstream commit f859ab61875978eeaa539740ff7f7d91f5d60006 ]
RxRPC service endpoints expire like they're supposed to by the following
means:
(1) Mark dead rxrpc_net structs (with ->live) rather than twiddling the
global service conn timeout, otherwise the first rxrpc_net struct to
die will cause connections on all others to expire immediately from
then on.
(2) Mark local service endpoints for which the socket has been closed
(->service_closed) so that the expiration timeout can be much
shortened for service and client connections going through that
endpoint.
(3) rxrpc_put_service_conn() needs to schedule the reaper when the usage
count reaches 1, not 0, as idle conns have a 1 count.
(4) The accumulator for the earliest time we might want to schedule for
should be initialised to jiffies + MAX_JIFFY_OFFSET, not ULONG_MAX as
the comparison functions use signed arithmetic.
(5) Simplify the expiration handling, adding the expiration value to the
idle timestamp each time rather than keeping track of the time in the
past before which the idle timestamp must go to be expired. This is
much easier to read.
(6) Ignore the timeouts if the net namespace is dead.
(7) Restart the service reaper work item rather the client reaper.
commit e39d200fa5bf5b94a0948db0dae44c1b73b84a56 upstream.
Reported by syzkaller:
BUG: KASAN: stack-out-of-bounds in write_mmio+0x11e/0x270 [kvm]
Read of size 8 at addr ffff8803259df7f8 by task syz-executor/32298
CPU: 6 PID: 32298 Comm: syz-executor Tainted: G OE 4.15.0-rc2+ #18
Hardware name: LENOVO ThinkCentre M8500t-N000/SHARKBAY, BIOS FBKTC1AUS 02/16/2016
Call Trace:
dump_stack+0xab/0xe1
print_address_description+0x6b/0x290
kasan_report+0x28a/0x370
emulator_read_write_onepage+0x311/0x600 [kvm]
emulator_read_write+0xef/0x240 [kvm]
emulator_fix_hypercall+0x105/0x150 [kvm]
em_hypercall+0x2b/0x80 [kvm]
x86_emulate_insn+0x2b1/0x1640 [kvm]
x86_emulate_instruction+0x39a/0xb90 [kvm]
handle_exception+0x1b4/0x4d0 [kvm_intel]
vcpu_enter_guest+0x15a0/0x2640 [kvm]
kvm_arch_vcpu_ioctl_run+0x549/0x7d0 [kvm]
kvm_vcpu_ioctl+0x479/0x880 [kvm]
do_vfs_ioctl+0x142/0x9a0
SyS_ioctl+0x74/0x80
entry_SYSCALL_64_fastpath+0x23/0x9a
The path of patched vmmcall will patch 3 bytes opcode 0F 01 C1(vmcall)
to the guest memory, however, write_mmio tracepoint always prints 8 bytes
through *(u64 *)val since kvm splits the mmio access into 8 bytes. This
leaks 5 bytes from the kernel stack (CVE-2017-17741). This patch fixes
it by just accessing the bytes which we operate on.
Before patch:
syz-executor-5567 [007] .... 51370.561696: kvm_mmio: mmio write len 3 gpa 0x10 val 0x1ffff10077c1010f
After patch:
syz-executor-13416 [002] .... 51302.299573: kvm_mmio: mmio write len 3 gpa 0x10 val 0xc1010f
Reviewed-by: Darren Kenny <darren.kenny@oracle.com>
Reviewed-by: Marc Zyngier <marc.zyngier@arm.com>
Tested-by: Marc Zyngier <marc.zyngier@arm.com>
Cc: Radim Krčmář <rkrcmar@redhat.com>
Cc: Marc Zyngier <marc.zyngier@arm.com>
Cc: Christoffer Dall <christoffer.dall@linaro.org>
Signed-off-by: Wanpeng Li <wanpeng.li@hotmail.com>
Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
commit e9d4bf219c83d09579bc62512fea2ca10f025d93 upstream.
There is no guarantee that either the request or the svc_xprt exist
by the time we get round to printing the trace message.
Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com>
Signed-off-by: J. Bruce Fields <bfields@redhat.com>
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
Currently TASK_PARKED is masqueraded as TASK_INTERRUPTIBLE, give it
its own print state because it will not in fact get woken by regular
wakeups and is a long-term state.
This requires moving TASK_PARKED into the TASK_REPORT mask, and since
that latter needs to be a contiguous bitmask, we need to shuffle the
bits around a bit.
Markus reported that kthreads that idle using TASK_IDLE instead of
TASK_INTERRUPTIBLE are reported in as TASK_UNINTERRUPTIBLE and things
like htop mark those red.
This is undesirable, so add an explicit state for TASK_IDLE.
Reported-by: Markus Trippelsdorf <markus@trippelsdorf.de>
Convert trace_sched_switch to use the common task-state helpers and
fix the "X" and "Z" order, possibly they ended up in the wrong order
because TASK_REPORT has them in the wrong order too.
Pull networking fixes from David Miller:
1) Fix hotplug deadlock in hv_netvsc, from Stephen Hemminger.
2) Fix double-free in rmnet driver, from Dan Carpenter.
3) INET connection socket layer can double put request sockets, fix
from Eric Dumazet.
4) Don't match collect metadata-mode tunnels if the device is down,
from Haishuang Yan.
5) Do not perform TSO6/GSO on ipv6 packets with extensions headers in
be2net driver, from Suresh Reddy.
6) Fix scaling error in gen_estimator, from Eric Dumazet.
7) Fix 64-bit statistics deadlock in systemport driver, from Florian
Fainelli.
8) Fix use-after-free in sctp_sock_dump, from Xin Long.
9) Reject invalid BPF_END instructions in verifier, from Edward Cree.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (43 commits)
mlxsw: spectrum_router: Only handle IPv4 and IPv6 events
Documentation: link in networking docs
tcp: fix data delivery rate
bpf/verifier: reject BPF_ALU64|BPF_END
sctp: do not mark sk dumped when inet_sctp_diag_fill returns err
sctp: fix an use-after-free issue in sctp_sock_dump
netvsc: increase default receive buffer size
tcp: update skb->skb_mstamp more carefully
net: ipv4: fix l3slave check for index returned in IP_PKTINFO
net: smsc911x: Quieten netif during suspend
net: systemport: Fix 64-bit stats deadlock
net: vrf: avoid gcc-4.6 warning
qed: remove unnecessary call to memset
tg3: clean up redundant initialization of tnapi
tls: make tls_sw_free_resources static
sctp: potential read out of bounds in sctp_ulpevent_type_enabled()
MAINTAINERS: review Renesas DT bindings as well
net_sched: gen_estimator: fix scaling error in bytes/packets samples
nfp: wait for the NSP resource to appear on boot
nfp: wait for board state before talking to the NSP
Pull more KVM updates from Paolo Bonzini:
- PPC bugfixes
- RCU splat fix
- swait races fix
- pointless userspace-triggerable BUG() fix
- misc fixes for KVM_RUN corner cases
- nested virt correctness fixes + one host DoS
- some cleanups
- clang build fix
- fix AMD AVIC with default QEMU command line options
- x86 bugfixes
* tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (28 commits)
kvm: nVMX: Handle deferred early VMLAUNCH/VMRESUME failure properly
kvm: vmx: Handle VMLAUNCH/VMRESUME failure properly
kvm: nVMX: Remove nested_vmx_succeed after successful VM-entry
kvm,mips: Fix potential swait_active() races
kvm,powerpc: Serialize wq active checks in ops->vcpu_kick
kvm: Serialize wq active checks in kvm_vcpu_wake_up()
kvm,x86: Fix apf_task_wake_one() wq serialization
kvm,lapic: Justify use of swait_active()
kvm,async_pf: Use swq_has_sleeper()
sched/wait: Add swq_has_sleeper()
KVM: VMX: Do not BUG() on out-of-bounds guest IRQ
KVM: Don't accept obviously wrong gsi values via KVM_IRQFD
kvm: nVMX: Don't allow L2 to access the hardware CR8
KVM: trace events: update list of exit reasons
KVM: async_pf: Fix #DF due to inject "Page not Present" and "Page Ready" exceptions simultaneously
KVM: X86: Don't block vCPU if there is pending exception
KVM: SVM: Add irqchip_split() checks before enabling AVIC
KVM: Add struct kvm_vcpu pointer parameter to get_enable_apicv()
KVM: SVM: Refactor AVIC vcpu initialization into avic_init_vcpu()
KVM: x86: fix clang build
Adding entries for exit reasons 23 - 27:
KVM_EXIT_EPR
KVM_EXIT_SYSTEM_EVENT
KVM_EXIT_S390_STSI
KVM_EXIT_IOAPIC_EOI
KVM_EXIT_HYPERV
Signed-off-by: Ladi Prosek <lprosek@redhat.com>
Reviewed-by: Cornelia Huck <cohuck@redhat.com>
Signed-off-by: Radim Krčmář <rkrcmar@redhat.com>
GFP_TEMPORARY was introduced by commit e12ba74d8ff3 ("Group short-lived
and reclaimable kernel allocations") along with __GFP_RECLAIMABLE. It's
primary motivation was to allow users to tell that an allocation is
short lived and so the allocator can try to place such allocations close
together and prevent long term fragmentation. As much as this sounds
like a reasonable semantic it becomes much less clear when to use the
highlevel GFP_TEMPORARY allocation flag. How long is temporary? Can the
context holding that memory sleep? Can it take locks? It seems there is
no good answer for those questions.
The current implementation of GFP_TEMPORARY is basically GFP_KERNEL |
__GFP_RECLAIMABLE which in itself is tricky because basically none of
the existing caller provide a way to reclaim the allocated memory. So
this is rather misleading and hard to evaluate for any benefits.
I have checked some random users and none of them has added the flag
with a specific justification. I suspect most of them just copied from
other existing users and others just thought it might be a good idea to
use without any measuring. This suggests that GFP_TEMPORARY just
motivates for cargo cult usage without any reasoning.
I believe that our gfp flags are quite complex already and especially
those with highlevel semantic should be clearly defined to prevent from
confusion and abuse. Therefore I propose dropping GFP_TEMPORARY and
replace all existing users to simply use GFP_KERNEL. Please note that
SLAB users with shrinkers will still get __GFP_RECLAIMABLE heuristic and
so they will be placed properly for memory fragmentation prevention.
I can see reasons we might want some gfp flag to reflect shorterm
allocations but I propose starting from a clear semantic definition and
only then add users with proper justification.
This was been brought up before LSF this year by Matthew [1] and it
turned out that GFP_TEMPORARY really doesn't have a clear semantic. It
seems to be a heuristic without any measured advantage for most (if not
all) its current users. The follow up discussion has revealed that
opinions on what might be temporary allocation differ a lot between
developers. So rather than trying to tweak existing users into a
semantic which they haven't expected I propose to simply remove the flag
and start from scratch if we really need a semantic for short term
allocations.
[1] http://lkml.kernel.org/r/20170118054945.GD18349@bombadil.infradead.org
[akpm@linux-foundation.org: fix typo]
[sfr@canb.auug.org.au: drm/i915: fix up]
Link: http://lkml.kernel.org/r/20170816144703.378d4f4d@canb.auug.org.au
Link: http://lkml.kernel.org/r/20170728091904.14627-1-mhocko@kernel.org
Signed-off-by: Michal Hocko <mhocko@suse.com>
Acked-by: Vlastimil Babka <vbabka@suse.cz>
Cc: Matthew Wilcox <willy@infradead.org>
Cc: Neil Brown <neilb@suse.de>
Cc: "Theodore Ts'o" <tytso@mit.edu>
Pull block fixes from Jens Axboe:
"Small collection of fixes that would be nice to have in -rc1. This
contains:
- NVMe pull request form Christoph, mostly with fixes for nvme-pci,
host memory buffer in particular.
- Error handling fixup for cgwb_create(), in case allocation of 'wb'
fails. From Christophe Jaillet.
- Ensure that trace_block_getrq() gets the 'dev' in an appropriate
fashion, to avoid a potential NULL deref. From Greg Thelen.
- Regression fix for dm-mq with blk-mq, fixing a problem with
stacking IO schedulers. From me.
- string.h fixup, fixing an issue with memcpy_and_pad(). This
original change came in through an NVMe dependency, which is why
I'm including it here. From Martin Wilck.
- Fix potential int overflow in __blkdev_sectors_to_bio_pages(), from
Mikulas.
- MBR enable fix for sed-opal, from Scott"
* 'for-linus' of git://git.kernel.dk/linux-block:
block: directly insert blk-mq request from blk_insert_cloned_request()
mm/backing-dev.c: fix an error handling path in 'cgwb_create()'
string.h: un-fortify memcpy_and_pad
nvme-pci: implement the HMB entry number and size limitations
nvme-pci: propagate (some) errors from host memory buffer setup
nvme-pci: use appropriate initial chunk size for HMB allocation
nvme-pci: fix host memory buffer allocation fallback
nvme: fix lightnvm check
block: fix integer overflow in __blkdev_sectors_to_bio_pages()
block: sed-opal: Set MBRDone on S3 resume path if TPER is MBREnabled
block: tolerate tracing of NULL bio
git://git.kernel.org/pub/scm/linux/kernel/git/jaegeuk/f2fs
Pull f2fs updates from Jaegeuk Kim:
"In this round, we've mostly tuned f2fs to provide better user
experience for Android. Especially, we've worked on atomic write
feature again with SQLite community in order to support it officially.
And we added or modified several facilities to analyze and enhance IO
behaviors.
Major changes include:
- add app/fs io stat
- add inode checksum feature
- support project/journalled quota
- enhance atomic write with new ioctl() which exposes feature set
- enhance background gc/discard/fstrim flows with new gc_urgent mode
- add F2FS_IOC_FS{GET,SET}XATTR
- fix some quota flows"
* tag 'f2fs-for-4.14' of git://git.kernel.org/pub/scm/linux/kernel/git/jaegeuk/f2fs: (63 commits)
f2fs: hurry up to issue discard after io interruption
f2fs: fix to show correct discard_granularity in sysfs
f2fs: detect dirty inode in evict_inode
f2fs: clear radix tree dirty tag of pages whose dirty flag is cleared
f2fs: speed up gc_urgent mode with SSR
f2fs: better to wait for fstrim completion
f2fs: avoid race in between read xattr & write xattr
f2fs: make get_lock_data_page to handle encrypted inode
f2fs: use generic terms used for encrypted block management
f2fs: introduce f2fs_encrypted_file for clean-up
Revert "f2fs: add a new function get_ssr_cost"
f2fs: constify super_operations
f2fs: fix to wake up all sleeping flusher
f2fs: avoid race in between atomic_read & atomic_inc
f2fs: remove unneeded parameter of change_curseg
f2fs: update i_flags correctly
f2fs: don't check inode's checksum if it was dirtied or writebacked
f2fs: don't need to update inode checksum for recovery
f2fs: trigger fdatasync for non-atomic_write file
f2fs: fix to avoid race in between aio and gc
Using bpf_redirect_map is allowed for generic XDP programs, but the
appropriate map lookup was never performed in xdp_do_generic_redirect().
Instead the map-index is directly used as the ifindex. For the
xdp_redirect_map sample in SKB-mode '-S', this resulted in trying
sending on ifindex 0 which isn't valid, resulting in getting SKB
packets dropped. Thus, the reported performance numbers are wrong in
commit 24251c264798 ("samples/bpf: add option for native and skb mode
for redirect apps") for the 'xdp_redirect_map -S' case.
Before commit 109980b894e9 ("bpf: don't select potentially stale
ri->map from buggy xdp progs") it could crash the kernel. Like this
commit also check that the map_owner owner is correct before
dereferencing the map pointer. But make sure that this API misusage
can be caught by a tracepoint. Thus, allowing userspace via
tracepoints to detect misbehaving bpf_progs.
Fixes: 6103aa96ec07 ("net: implement XDP_REDIRECT for xdp generic")
Fixes: 24251c264798 ("samples/bpf: add option for native and skb mode for redirect apps")
Signed-off-by: Jesper Dangaard Brouer <brouer@redhat.com>
__get_request() can call trace_block_getrq() with bio=NULL which causes
block_get_rq::TP_fast_assign() to deref a NULL pointer and panic.
Syzkaller fuzzer panics with
linux-next (1d53d908b79d7870d89063062584eead4cf83448):
kasan: GPF could be caused by NULL-ptr deref or user memory access
general protection fault: 0000 [#1] SMP KASAN
Modules linked in:
CPU: 0 PID: 2983 Comm: syzkaller401111 Not tainted 4.13.0-rc7-next-20170901+ #13
task: ffff8801cf1da000 task.stack: ffff8801ce440000
RIP: 0010:perf_trace_block_get_rq+0x697/0x970 include/trace/events/block.h:384
RSP: 0018:ffff8801ce4473f0 EFLAGS: 00010246
RAX: ffff8801cf1da000 RBX: 1ffff10039c88e84 RCX: 1ffffd1ffff84d27
RDX: dffffc0000000001 RSI: 1ffff1003b643e7a RDI: ffffe8ffffc26938
RBP: ffff8801ce447530 R08: 1ffff1003b643e6c R09: ffffe8ffffc26964
R10: 0000000000000002 R11: fffff91ffff84d2d R12: ffffe8ffffc1f890
R13: ffffe8ffffc26930 R14: ffffffff85cad9e0 R15: 0000000000000000
FS: 0000000002641880(0000) GS:ffff8801db200000(0000) knlGS:0000000000000000
CR2: 000000000043e670 CR3: 00000001d1d7a000 CR4: 00000000001406f0
DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400
Call Trace:
trace_block_getrq include/trace/events/block.h:423 [inline]
__get_request block/blk-core.c:1283 [inline]
get_request+0x1518/0x23b0 block/blk-core.c:1355
blk_old_get_request block/blk-core.c:1402 [inline]
blk_get_request+0x1d8/0x3c0 block/blk-core.c:1427
sg_scsi_ioctl+0x117/0x750 block/scsi_ioctl.c:451
sg_ioctl+0x192d/0x2ed0 drivers/scsi/sg.c:1070
vfs_ioctl fs/ioctl.c:45 [inline]
do_vfs_ioctl+0x1b1/0x1530 fs/ioctl.c:685
SYSC_ioctl fs/ioctl.c:700 [inline]
SyS_ioctl+0x8f/0xc0 fs/ioctl.c:691
entry_SYSCALL_64_fastpath+0x1f/0xbe
block_get_rq::TP_fast_assign() has multiple redundant ->dev assignments.
Only one of them is NULL tolerant. Favor the NULL tolerant one.
Fixes: 74d46992e0d9 ("block: replace bi_bdev with a gendisk pointer and partitions index")
Reviewed-by: Ming Lei <ming.lei@redhat.com>
Signed-off-by: Greg Thelen <gthelen@google.com>
git://git.kernel.org/pub/scm/linux/kernel/git/kdave/linux
Pull btrfs updates from David Sterba:
"The changes range through all types: cleanups, core chagnes, sanity
checks, fixes, other user visible changes, detailed list below:
- deprecated: user transaction ioctl
- mount option ssd does not change allocation alignments
- degraded read-write mount is allowed if all the raid profile
constraints are met, now based on more accurate check
- defrag: do not reset compression afterwards; the NOCOMPRESS flag
can be now overriden by defrag
- prep work for better extent reference tracking (related to the
qgroup slowness with balance)
- prep work for compression heuristics
- memory allocation reductions (may help latencies on a loaded
system)
- better accounting for io waiting states
- error handling improvements (removed BUGs)
- added more sanity checks for shared refs
- fix readdir vs pagefault deadlock under some circumstances
- fix for 'no-hole' mode, certain combination of compressed and
inline extents
- send: fix emission of invalid clone operations
- fixup file mode if setting acls fail
- more fixes from fuzzing
- oher cleanups"
* 'for-4.14' of git://git.kernel.org/pub/scm/linux/kernel/git/kdave/linux: (104 commits)
btrfs: submit superblock io with REQ_META and REQ_PRIO
btrfs: remove unnecessary memory barrier in btrfs_direct_IO
btrfs: remove superfluous chunk_tree argument from btrfs_alloc_dev_extent
btrfs: Remove chunk_objectid parameter of btrfs_alloc_dev_extent
btrfs: pass fs_info to btrfs_del_root instead of tree_root
Btrfs: add one more sanity check for shared ref type
Btrfs: remove BUG_ON in __add_tree_block
Btrfs: remove BUG() in add_data_reference
Btrfs: remove BUG() in print_extent_item
Btrfs: remove BUG() in btrfs_extent_inline_ref_size
Btrfs: convert to use btrfs_get_extent_inline_ref_type
Btrfs: add a helper to retrive extent inline ref type
btrfs: scrub: simplify scrub worker initialization
btrfs: scrub: clean up division in scrub_find_csum
btrfs: scrub: clean up division in __scrub_mark_bitmap
btrfs: scrub: use bool for flush_all_writes
btrfs: preserve i_mode if __btrfs_set_acl() fails
btrfs: Remove extraneous chunk_objectid variable
btrfs: Remove chunk_objectid argument from btrfs_make_block_group
btrfs: Remove extra parentheses from condition in copy_items()
Pull MMC updates from Ulf Hansson:
"MMC core:
- Continue to refactor the mmc block code to prepare for blkmq
- Move mmc block debugfs into block module
- Next step for eMMC CMDQ by adding a new mmc host interface for it
- Move Kconfig option MMC_DEBUG from core to host
- Some additional minor improvements
MMC host:
- Declare structs as const when applicable
- Explicitly request exclusive reset control when applicable
- Improve some error paths and other various cleanups
- sdhci: Preparations to support SDHCI OMAP
- sdhci: Improve some PM related code
- sdhci: Re-factoring and modernizations
- sdhci-xenon: Add runtime PM and system sleep support
- sdhci-xenon: Add support for eMMC HS400 Enhanced Strobe
- sdhci-cadence: Add system sleep support
- sdhci-of-at91: Improve system sleep support
- dw_mmc: Add support for Hisilicon hi3660
- sunxi: Add support for A83T eMMC
- sunxi: Add support for DDR52 mode
- meson-gx: Add support for UHS-I SD-cards
- meson-gx: Cleanups and improvements
- tmio: Fix CMD12 (STOP) handling
- tmio: Cleanups and improvements
- renesas_sdhi: Add r8a7743/5 support
- renesas-sdhi: Add support for R-Car Gen3 SDHI DMAC
- renesas_sdhi: Cleanups and improvements"
* tag 'mmc-v4.14' of git://git.kernel.org/pub/scm/linux/kernel/git/ulfh/mmc: (145 commits)
mmc: renesas_sdhi: Add r8a7743/5 support
mmc: meson-gx: fix __ffsdi2 undefined on arm32
mmc: sdhci-xenon: add runtime pm support and reimplement standby
mmc: core: Move mmc_start_areq() declaration
mmc: mmci: stop building qcom dml as module
mmc: sunxi: Reset the device at probe time
clk: sunxi-ng: Provide a default reset hook
mmc: meson-gx: rework tuning function
mmc: meson-gx: change default tx phase
mmc: meson-gx: implement voltage switch callback
mmc: meson-gx: use CCF to handle the clock phases
mmc: meson-gx: implement card_busy callback
mmc: meson-gx: simplify interrupt handler
mmc: meson-gx: work around clk-stop issue
mmc: meson-gx: fix dual data rate mode frequencies
mmc: meson-gx: rework clock init function
mmc: meson-gx: rework clk_set function
mmc: meson-gx: rework set_ios function
mmc: meson-gx: cfg init overwrite values
mmc: meson-gx: initialize sane clk default before clock register
Pull block layer updates from Jens Axboe:
"This is the first pull request for 4.14, containing most of the code
changes. It's a quiet series this round, which I think we needed after
the churn of the last few series. This contains:
- Fix for a registration race in loop, from Anton Volkov.
- Overflow complaint fix from Arnd for DAC960.
- Series of drbd changes from the usual suspects.
- Conversion of the stec/skd driver to blk-mq. From Bart.
- A few BFQ improvements/fixes from Paolo.
- CFQ improvement from Ritesh, allowing idling for group idle.
- A few fixes found by Dan's smatch, courtesy of Dan.
- A warning fixup for a race between changing the IO scheduler and
device remova. From David Jeffery.
- A few nbd fixes from Josef.
- Support for cgroup info in blktrace, from Shaohua.
- Also from Shaohua, new features in the null_blk driver to allow it
to actually hold data, among other things.
- Various corner cases and error handling fixes from Weiping Zhang.
- Improvements to the IO stats tracking for blk-mq from me. Can
drastically improve performance for fast devices and/or big
machines.
- Series from Christoph removing bi_bdev as being needed for IO
submission, in preparation for nvme multipathing code.
- Series from Bart, including various cleanups and fixes for switch
fall through case complaints"
* 'for-4.14/block' of git://git.kernel.dk/linux-block: (162 commits)
kernfs: checking for IS_ERR() instead of NULL
drbd: remove BIOSET_NEED_RESCUER flag from drbd_{md_,}io_bio_set
drbd: Fix allyesconfig build, fix recent commit
drbd: switch from kmalloc() to kmalloc_array()
drbd: abort drbd_start_resync if there is no connection
drbd: move global variables to drbd namespace and make some static
drbd: rename "usermode_helper" to "drbd_usermode_helper"
drbd: fix race between handshake and admin disconnect/down
drbd: fix potential deadlock when trying to detach during handshake
drbd: A single dot should be put into a sequence.
drbd: fix rmmod cleanup, remove _all_ debugfs entries
drbd: Use setup_timer() instead of init_timer() to simplify the code.
drbd: fix potential get_ldev/put_ldev refcount imbalance during attach
drbd: new disk-option disable-write-same
drbd: Fix resource role for newly created resources in events2
drbd: mark symbols static where possible
drbd: Send P_NEG_ACK upon write error in protocol != C
drbd: add explicit plugging when submitting batches
drbd: change list_for_each_safe to while(list_first_entry_or_null)
drbd: introduce drbd_recv_header_maybe_unplug
git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip
Pull xen updates from Juergen Gross:
- the new pvcalls backend for routing socket calls from a guest to dom0
- some cleanups of Xen code
- a fix for wrong usage of {get,put}_cpu()
* tag 'for-linus-4.14b-rc1-tag' of git://git.kernel.org/pub/scm/linux/kernel/git/xen/tip: (27 commits)
xen/mmu: set MMU_NORMAL_PT_UPDATE in remap_area_mfn_pte_fn
xen: Don't try to call xen_alloc_p2m_entry() on autotranslating guests
xen/events: events_fifo: Don't use {get,put}_cpu() in xen_evtchn_fifo_init()
xen/pvcalls: use WARN_ON(1) instead of __WARN()
xen: remove not used trace functions
xen: remove unused function xen_set_domain_pte()
xen: remove tests for pvh mode in pure pv paths
xen-platform: constify pci_device_id.
xen: cleanup xen.h
xen: introduce a Kconfig option to enable the pvcalls backend
xen/pvcalls: implement write
xen/pvcalls: implement read
xen/pvcalls: implement the ioworker functions
xen/pvcalls: disconnect and module_exit
xen/pvcalls: implement release command
xen/pvcalls: implement poll command
xen/pvcalls: implement accept command
xen/pvcalls: implement listen command
xen/pvcalls: implement bind command
xen/pvcalls: implement connect command
Merge updates from Andrew Morton:
- various misc bits
- DAX updates
- OCFS2
- most of MM
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (119 commits)
mm,fork: introduce MADV_WIPEONFORK
x86,mpx: make mpx depend on x86-64 to free up VMA flag
mm: add /proc/pid/smaps_rollup
mm: hugetlb: clear target sub-page last when clearing huge page
mm: oom: let oom_reap_task and exit_mmap run concurrently
swap: choose swap device according to numa node
mm: replace TIF_MEMDIE checks by tsk_is_oom_victim
mm, oom: do not rely on TIF_MEMDIE for memory reserves access
z3fold: use per-cpu unbuddied lists
mm, swap: don't use VMA based swap readahead if HDD is used as swap
mm, swap: add sysfs interface for VMA based swap readahead
mm, swap: VMA based swap readahead
mm, swap: fix swap readahead marking
mm, swap: add swap readahead hit statistics
mm/vmalloc.c: don't reinvent the wheel but use existing llist API
mm/vmstat.c: fix wrong comment
selftests/memfd: add memfd_create hugetlbfs selftest
mm/shmem: add hugetlbfs support to memfd_create()
mm, devm_memremap_pages: use multi-order radix for ZONE_DEVICE lookups
mm/vmalloc.c: halve the number of comparisons performed in pcpu_get_vm_areas()
Introduce MADV_WIPEONFORK semantics, which result in a VMA being empty
in the child process after fork. This differs from MADV_DONTFORK in one
important way.
If a child process accesses memory that was MADV_WIPEONFORK, it will get
zeroes. The address ranges are still valid, they are just empty.
If a child process accesses memory that was MADV_DONTFORK, it will get a
segmentation fault, since those address ranges are no longer valid in
the child after fork.
Since MADV_DONTFORK also seems to be used to allow very large programs
to fork in systems with strict memory overcommit restrictions, changing
the semantics of MADV_DONTFORK might break existing programs.
MADV_WIPEONFORK only works on private, anonymous VMAs.
The use case is libraries that store or cache information, and want to
know that they need to regenerate it in the child process after fork.
Examples of this would be:
- systemd/pulseaudio API checks (fail after fork) (replacing a getpid
check, which is too slow without a PID cache)
- PKCS#11 API reinitialization check (mandated by specification)
- glibc's upcoming PRNG (reseed after fork)
- OpenSSL PRNG (reseed after fork)
The security benefits of a forking server having a re-inialized PRNG in
every child process are pretty obvious. However, due to libraries
having all kinds of internal state, and programs getting compiled with
many different versions of each library, it is unreasonable to expect
calling programs to re-initialize everything manually after fork.
A further complication is the proliferation of clone flags, programs
bypassing glibc's functions to call clone directly, and programs calling
unshare, causing the glibc pthread_atfork hook to not get called.
It would be better to have the kernel take care of this automatically.
The patch also adds MADV_KEEPONFORK, to undo the effects of a prior
MADV_WIPEONFORK.
This is similar to the OpenBSD minherit syscall with MAP_INHERIT_ZERO:
https://man.openbsd.org/minherit.2
[akpm@linux-foundation.org: numerically order arch/parisc/include/uapi/asm/mman.h #defines]
Link: http://lkml.kernel.org/r/20170811212829.29186-3-riel@redhat.com
Signed-off-by: Rik van Riel <riel@redhat.com>
Reported-by: Florian Weimer <fweimer@redhat.com>
Reported-by: Colm MacCártaigh <colm@allcosts.net>
Reviewed-by: Mike Kravetz <mike.kravetz@oracle.com>
Cc: "Kirill A. Shutemov" <kirill@shutemov.name>
Cc: Helge Deller <deller@gmx.de>
Cc: Will Drewry <wad@chromium.org>
Cc: <linux-api@vger.kernel.org>
When servicing mmap() reads from file holes the current DAX code
allocates a page cache page of all zeroes and places the struct page
pointer in the mapping->page_tree radix tree.
This has three major drawbacks:
1) It consumes memory unnecessarily. For every 4k page that is read via
a DAX mmap() over a hole, we allocate a new page cache page. This
means that if you read 1GiB worth of pages, you end up using 1GiB of
zeroed memory. This is easily visible by looking at the overall
memory consumption of the system or by looking at /proc/[pid]/smaps:
7f62e72b3000-7f63272b3000 rw-s 00000000 103:00 12 /root/dax/data
Rss: 1048576 kB
Pss: 1048576 kB
Shared_Clean: 0 kB
Shared_Dirty: 0 kB
Private_Clean: 1048576 kB
Private_Dirty: 0 kB
Referenced: 1048576 kB
Anonymous: 0 kB
LazyFree: 0 kB
AnonHugePages: 0 kB
ShmemPmdMapped: 0 kB
Shared_Hugetlb: 0 kB
Private_Hugetlb: 0 kB
Swap: 0 kB
SwapPss: 0 kB
KernelPageSize: 4 kB
MMUPageSize: 4 kB
Locked: 0 kB
2) It is slower than using a common zero page because each page fault
has more work to do. Instead of just inserting a common zero page we
have to allocate a page cache page, zero it, and then insert it. Here
are the average latencies of dax_load_hole() as measured by ftrace on
a random test box:
Old method, using zeroed page cache pages: 3.4 us
New method, using the common 4k zero page: 0.8 us
This was the average latency over 1 GiB of sequential reads done by
this simple fio script:
[global]
size=1G
filename=/root/dax/data
fallocate=none
[io]
rw=read
ioengine=mmap
3) The fact that we had to check for both DAX exceptional entries and
for page cache pages in the radix tree made the DAX code more
complex.
Solve these issues by following the lead of the DAX PMD code and using a
common 4k zero page instead. As with the PMD code we will now insert a
DAX exceptional entry into the radix tree instead of a struct page
pointer which allows us to remove all the special casing in the DAX
code.
Note that we do still pretty aggressively check for regular pages in the
DAX radix tree, especially where we take action based on the bits set in
the page. If we ever find a regular page in our radix tree now that
most likely means that someone besides DAX is inserting pages (which has
happened lots of times in the past), and we want to find that out early
and fail loudly.
This solution also removes the extra memory consumption. Here is that
same /proc/[pid]/smaps after 1GiB of reading from a hole with the new
code:
7f2054a74000-7f2094a74000 rw-s 00000000 103:00 12 /root/dax/data
Rss: 0 kB
Pss: 0 kB
Shared_Clean: 0 kB
Shared_Dirty: 0 kB
Private_Clean: 0 kB
Private_Dirty: 0 kB
Referenced: 0 kB
Anonymous: 0 kB
LazyFree: 0 kB
AnonHugePages: 0 kB
Swap: 0 kB
SwapPss: 0 kB
MMUPageSize: 4 kB
Locked: 0 kB
Overall system memory consumption is similarly improved.
Another major change is that we remove dax_pfn_mkwrite() from our fault
flow, and instead rely on the page fault itself to make the PTE dirty
and writeable. The following description from the patch adding the
vm_insert_mixed_mkwrite() call explains this a little more:
"To be able to use the common 4k zero page in DAX we need to have our
PTE fault path look more like our PMD fault path where a PTE entry
can be marked as dirty and writeable as it is first inserted rather
than waiting for a follow-up dax_pfn_mkwrite() =>
finish_mkwrite_fault() call.
Right now we can rely on having a dax_pfn_mkwrite() call because we
can distinguish between these two cases in do_wp_page():
case 1: 4k zero page => writable DAX storage
case 2: read-only DAX storage => writeable DAX storage
This distinction is made by via vm_normal_page(). vm_normal_page()
returns false for the common 4k zero page, though, just as it does
for DAX ptes. Instead of special casing the DAX + 4k zero page case
we will simplify our DAX PTE page fault sequence so that it matches
our DAX PMD sequence, and get rid of the dax_pfn_mkwrite() helper.
We will instead use dax_iomap_fault() to handle write-protection
faults.
This means that insert_pfn() needs to follow the lead of
insert_pfn_pmd() and allow us to pass in a 'mkwrite' flag. If
'mkwrite' is set insert_pfn() will do the work that was previously
done by wp_page_reuse() as part of the dax_pfn_mkwrite() call path"
Link: http://lkml.kernel.org/r/20170724170616.25810-4-ross.zwisler@linux.intel.com
Signed-off-by: Ross Zwisler <ross.zwisler@linux.intel.com>
Cc: "Darrick J. Wong" <darrick.wong@oracle.com>
Cc: Andreas Dilger <adilger.kernel@dilger.ca>
Cc: Dan Williams <dan.j.williams@intel.com>
Cc: Jonathan Corbet <corbet@lwn.net>
Cc: Matthew Wilcox <mawilcox@microsoft.com>
Cc: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
Pull networking updates from David Miller:
1) Support ipv6 checksum offload in sunvnet driver, from Shannon
Nelson.
2) Move to RB-tree instead of custom AVL code in inetpeer, from Eric
Dumazet.
3) Allow generic XDP to work on virtual devices, from John Fastabend.
4) Add bpf device maps and XDP_REDIRECT, which can be used to build
arbitrary switching frameworks using XDP. From John Fastabend.
5) Remove UFO offloads from the tree, gave us little other than bugs.
6) Remove the IPSEC flow cache, from Florian Westphal.
7) Support ipv6 route offload in mlxsw driver.
8) Support VF representors in bnxt_en, from Sathya Perla.
9) Add support for forward error correction modes to ethtool, from
Vidya Sagar Ravipati.
10) Add time filter for packet scheduler action dumping, from Jamal Hadi
Salim.
11) Extend the zerocopy sendmsg() used by virtio and tap to regular
sockets via MSG_ZEROCOPY. From Willem de Bruijn.
12) Significantly rework value tracking in the BPF verifier, from Edward
Cree.
13) Add new jump instructions to eBPF, from Daniel Borkmann.
14) Rework rtnetlink plumbing so that operations can be run without
taking the RTNL semaphore. From Florian Westphal.
15) Support XDP in tap driver, from Jason Wang.
16) Add 32-bit eBPF JIT for ARM, from Shubham Bansal.
17) Add Huawei hinic ethernet driver.
18) Allow to report MD5 keys in TCP inet_diag dumps, from Ivan
Delalande.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1780 commits)
i40e: point wb_desc at the nvm_wb_desc during i40e_read_nvm_aq
i40e: avoid NVM acquire deadlock during NVM update
drivers: net: xgene: Remove return statement from void function
drivers: net: xgene: Configure tx/rx delay for ACPI
drivers: net: xgene: Read tx/rx delay for ACPI
rocker: fix kcalloc parameter order
rds: Fix non-atomic operation on shared flag variable
net: sched: don't use GFP_KERNEL under spin lock
vhost_net: correctly check tx avail during rx busy polling
net: mdio-mux: add mdio_mux parameter to mdio_mux_init()
rxrpc: Make service connection lookup always check for retry
net: stmmac: Delete dead code for MDIO registration
gianfar: Fix Tx flow control deactivation
cxgb4: Ignore MPS_TX_INT_CAUSE[Bubble] for T6
cxgb4: Fix pause frame count in t4_get_port_stats
cxgb4: fix memory leak
tun: rename generic_xdp to skb_xdp
tun: reserve extra headroom only when XDP is set
net: dsa: bcm_sf2: Configure IMP port TC2QOS mapping
net: dsa: bcm_sf2: Advertise number of egress queues
This extends bridge fdb table tracepoints to also cover
learned fdb entries in the br_fdb_update path. Note that
unlike other tracepoints I have moved this to when the fdb
is modified because this is in the datapath and can generate
a lot of noise in the trace output. br_fdb_update is also called
from added_by_user context in the NTF_USE case which is already
traced ..hence the !added_by_user check.
Signed-off-by: Roopa Prabhu <roopa@cumulusnetworks.com>
Acked-by: Nikolay Aleksandrov <nikolay@cumulusnetworks.com>
There are some Xen specific trace functions defined in
include/trace/events/xen.h. Remove them.
Signed-off-by: Juergen Gross <jgross@suse.com>
Reviewed-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
Signed-off-by: Boris Ostrovsky <boris.ostrovsky@oracle.com>
The function xen_set_domain_pte() is used nowhere in the kernel.
Remove it.
Most of the information needed to issue requests to a CQE is already in
struct mmc_request and struct mmc_data. Add data block address, some flags,
and the task id (tag), and allow for cmd being NULL which it is for CQE
tasks.
A few useful tracepoints to trace bridge forwarding
database updates.
Reviewed-by: Florian Fainelli <f.fainelli@gmail.com>
Creating as specific xdp_redirect_map variant of the xdp tracepoints
allow users to write simpler/faster BPF progs that get attached to
these tracepoints.
Goal is to still keep the tracepoints in xdp_redirect and xdp_redirect_map
similar enough, that a tool can read the top part of the TP_STRUCT and
produce similar monitor statistics.
There is a need to separate the xdp_redirect tracepoint into two
tracepoints, for separating the error case from the normal forward
case.
Due to the extreme speeds XDP is operating at, loading a tracepoint
have a measurable impact. Single core XDP REDIRECT (ethtool tuned
rx-usecs 25) can do 13.7 Mpps forwarding, but loading a simple
bpf_prog at the tracepoint (with a return 0) reduce perf to 10.2 Mpps
(CPU E5-1650 v4 @ 3.60GHz, driver: ixgbe)
The overhead of loading a bpf-based tracepoint can be calculated to
cost 25 nanosec ((1/13782002-1/10267937)*10^9 = -24.83 ns).
Using perf record on the tracepoint event, with a non-matching --filter
expression, the overhead is much larger. Performance drops to 8.3 Mpps,
cost 48 nanosec ((1/13782002-1/8312497)*10^9 = -47.74))
Having a separate tracepoint for err cases, which should be less
frequent, allow running a continuous monitor for errors while not
affecting the redirect forward performance (this have also been
verified by measurements).
Acked-by: Alexei Starovoitov <ast@kernel.org>
Given previous patch expose the map_id, it seems natural to also
report the bpf prog id.
To make sense of the map index, the tracepoint user also need to know
that map we are talking about. Supply the map pointer but only expose
the map->id.
The 'to_index' is renamed 'to_ifindex'. In the xdp_redirect_map case,
this is the result of the devmap lookup. The map lookup key is exposed
as map_index, which is needed to troubleshoot in case the lookup failed.
The 'to_ifindex' is placed after 'err' to keep TP_STRUCT as common as
possible.
This also keeps the TP_STRUCT similar enough, that userspace can write
a monitor program, that doesn't need to care about whether
bpf_redirect or bpf_redirect_map were used.
Supplying the action argument XDP_REDIRECT to the tracepoint xdp_redirect
is redundant as it is only called in-case this action was specified.
Remove the argument, but keep "act" member of the tracepoint struct and
populate it with XDP_REDIRECT. This makes it easier to write a common bpf_prog
processing events.
Remove the net_device string name from the xdp_exception tracepoint,
like the xdp_redirect tracepoint.
Align the TP_STRUCT to have common entries between these two
tracepoint.
Acked-by: Daniel Borkmann <daniel@iogearbox.net>
There is too much overhead in the current trace_xdp_redirect
tracepoint as it does strcpy and strlen on the net_device names.
Besides, exposing the ifindex/index is actually the information that
is needed in the tracepoint to diagnose issues. When a lookup fails
(either ifindex or devmap index) then there is a need for saying which
to_index that have issues.
V2: Adjust args to be aligned with trace_xdp_exception.
